path: root/drivers/acpi/utilities
2008-06-11ACPICA: fix stray va_end() caused by mis-mergeLen Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-30Merge branches 'release', 'acpica', 'bugzilla-10224', 'bugzilla-9772', ↵Len Brown
'bugzilla-9916', 'ec', 'eeepc', 'idle', 'misc', 'pm-legacy', 'sysfs-links-2.6.26', 'thermal', 'thinkpad' and 'video' into release
2008-04-24ACPI: GPE enabling should happen after EC installationAlexey Starikovskiy
GPE could try to access EC region, so should not be enabled before EC is installed http://bugzilla.kernel.org/show_bug.cgi?id=9916 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-23ACPICA: update Intel copyrightLen Brown
2008-04-22ACPICA: Update for new Notify valuesZhang Rui
Implemented several changes for Notify handling: Added support for new Notify values (ACPI 2.0+) and improved the Notify debug output. Notify on PowerResource objects is no longer allowed, as per the ACPI specification. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Fixes for external Reference ObjectsBob Moore
All Reference Objects returned via the AcpiEvaluteObject interface are now marked as type "REFERENCE" instead of "ANY". The type ANY is now reservered for NULL objects - either NULL package elements or unresolved named references. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Fix to handle NULL package elements correctlyLin Ming
Fixed problem where NULL package elements were not returned to the AcpiEvaluateObject interface correctly. Instead of returning a NULL ACPI_OBJECT package element, the element was simply ignored, potentially causing a buffer overflow and/or confusing the caller who expected a fixed number of elements. http://bugzilla.kernel.org/show_bug.cgi?id=10132 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Fix for possible error when packages/buffers are passed to methods ↵Bob Moore
externally Fixed a problem where buffer and package objects passed as arguments to a control method via the external AcpiEvaluateObject interface could cause an AE_AML_INTERNAL exception depending on the order and type of operators executed by the target control method. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Added new error messagesBob Moore
New messages for the 2 AE_SUPPORT cases. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Add va_end statements as appropriateBob Moore
Added missing va_end statements that should correspond with each va_start statement. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Fixes for Unload and DDBHandlesLin Ming
Implemented support for the use of DDBHandles as an Indexed Reference, as per the ACPI spec. http://www.acpica.org/bugzilla/show_bug.cgi?id=486. Implemented support for UserTerm (Method invocation) for the Unload operator as per the ACPI spec. http://www.acpica.org/bugzilla/show_bug.cgi?id=580 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Implemented full argument resolution support for the BankValue ↵Lin Ming
argument to BankField Previously, only constants were supported, now any TermArg may be used. http://www.acpica.org/bugzilla/show_bug.cgi?id=387 http://www.acpica.org/bugzilla/show_bug.cgi?id=393 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Fixed a problem with FromBCD and ToBCD with some compilersBob Moore
On some compilers, the ShortDivide function worked incorrectly, causing problems with the BCD functions with large input values. (Truncation from 64-bit to 32-bit occurred.) Internal http://www.acpica.org/bugzilla/show_bug.cgi?id=435 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Cosmetic changes only, no functional changesBob Moore
Lint changes, fix compiler warnings, etc. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Fixed a memory leak when Device or Thermal objects referenced in ↵Bob Moore
packages Problem introduced in fix for Package references. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Fix for fault if Load() failsBob Moore
Fixed a problem with the Load operator when loading a table from a buffer object. The input buffer was prematurely zeroed and/or deleted. http://www.acpica.org/bugzilla/show_bug.cgi?id=577 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: New interfaces for table event handlersLin Ming
Designed and implemented new external interfaces to install and remove handlers for ACPI table-related events. Current events that are defined are LOAD and UNLOAD. These interfaces allow the host to track ACPI tables as they are dynamically loaded and unloaded. See AcpiInstallTableHandler and AcpiRemoveTableHandler. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Support for iASL - multiple files and wildcardsBob Moore
Implemented support to allow multiple files to be compiled/disassembled in a single invocation. This includes command line wildcard support for both the Windows and Unix versions of the compiler. This feature simplifies the disassembly and compilation of multiple ACPI tables in a single directory. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Update for mutiple global lock acquisitions by same threadBob Moore
Allows AcpiAcquireGlobalLock external interface to be called multiple times by the same thread. Allows use of AML fields that require the global lock while the running AML is already holding the global lock. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-13Merge branches 'release', 'button-sysfs', 'misc', 'mismatch', 'randconfig' ↵Len Brown
and 'toshiba' into release
2008-03-11ACPI: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-03-11ACPI: fix boot oops regression in thermalLin Ming
Fix a memory overflow bug when copying NULL internal package element object to external. http://bugzilla.kernel.org/show_bug.cgi?id=10132 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-06ACPI: create /sys/firmware/acpi/interruptsLen Brown
See Documentation/ABI/testing/sysfs-firmware-acpi Based-on-original-patch-by: Luming Yu <luming.yu@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-03drivers/acpi/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-25ACPI: add dump_stack() to trace acpi_format_exception programming errorsAndrew Morton
Dump the stack so we can find the secretive caller to acpi_format_exception(). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-23ACPI: autoload modules - ACPICA modificationsThomas Renninger
Define standardized HIDs - Rename current acpi_device_id to acpica_device_id Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22Pull osi into release branchLen Brown
2007-07-03ACPICA: Update _OSI string listBob Moore
Latest update for the Windows strings, with comments. Removed unused strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-06-18ACPICA: fix error path in new external package objects as method argumentsMyron Stowe
In the routine acpi_ut_create_package_object(), if the ACPI_ALLOCATE_ZEROED() fails then ACPI_FREE(package_desc) is called as part of the cleanup. This should instead be acpi_ut_remove_reference(package_desc) in order to remove the reference acquired from acpi_ut_create_internal_object() [see the routine acpi_ut_create_buffer_object() as an example of proper functionality]. Signed-off-by: Myron Stowe <myron.stowe@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-06-02Pull osi-now into release branchLen Brown
2007-06-02ACPICA: Support for external package objects as method argumentsBob Moore
Implemented support to allow Package objects to be passed as method arguments to the acpi_evaluate_object interface. Previously, this would return an AE_NOT_IMPLEMENTED exception. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-30ACPI: add __init to acpi_initialize_subsystem()Len Brown
Add __init to: acpi_initialize_subsystem() (and un-export it) acpi_os_initialize() Add __initdata to: acpi_osl_dmi_table[] Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-30ACPI: Make _OSI(Linux) a special caseLen Brown
_OSI("Linux") is like _OS("Linux"), it is ill-defined and virtually no BIOS vendors test interaction with it. As a result, it can do more damage than good because it causes the BIOS to follow un-tested paths. Recently, several machines have turned up that erroneously test this string in a way which causes them to _not_ test other compatibility strings, including the ZI9 and Toshiba. So it appears that this bad code has made it into a BIOS vendor's reference BIOS. Linux has no choice but to stop advertising compatibility with _OSI string "Linux" - as there are an unbounded number of possible incompatibilities going forward. But some BIOSes have already shipped which do use it for things like conditionally re-enabling video on resume from S3. (Too bad they didn't do that unconditionally) Add special case code for _OSI(Linux) Squawk to dmesg if _OSI(Linux) is requested Add DMI list both to enable and disable _OSI(Linux) But for now, keep the default enabled via #define OSI_LINUX_ENABLED. http://bugzilla.kernel.org/show_bug.cgi?id=7787 Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-29ACPI: extend "acpi_osi=" boot optionLen Brown
The boot option "acpi_osi=" has always disabled Linux _OSI support, thus disabling all OS Interface strings which are advertised by Linux to the BIOS. Now... acpi_osi="string" adds the interface string, and acpi_osi="!string" invalidates the pre-defined interface string eg. acpi_osi="!Windows 2006" would disable Linux's claim of Vista compatibility. Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-09ACPICA: LindentLen Brown
2007-05-09Revert "ACPICA: fix AML mutex re-entrancy"Len Brown
This reverts commit c0d127b56937c3e72c2b1819161d2f6718eee877. These changes to AML locking were made to allow Notify handlers to be called on the stack and not deadlock. However, that scheme turns out to be flawed and was reverted by the previous commit, so this commit restores the locking to it previous design. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-15ACPICA: fix AML mutex re-entrancyAlexey Starikovskiy
ACPI AML supports "serialized" methods which are protected by an implicit mutex. The mutex is re-entrant for that AML thread to allow recursion. However, Linux implements notify() by creating a new AML thread. So for systems where notify() re-enters a serialized method, deadlock results. The fix is to use the Linux thread_id as the key to allowing re-entrancy, not the AML thread pointer. http://bugzilla.kernel.org/show_bug.cgi?id=5534 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: fix gcc build warningsAlexey Starikovskiy
drivers/acpi/namespace/nsparse.c:126: warning: int format, different type arg (arg 7) drivers/acpi/tables/tbfadt.c:224: warning: unsigned int format, different type arg (arg 6) drivers/acpi/utilities/utdebug.c:184: warning: cast from pointer to integer of different size drivers/acpi/utilities/utdebug.c:184: warning: cast from pointer to integer of different size drivers/acpi/utilities/utdebug.c:197: warning: cast from pointer to integer of different size drivers/acpi/processor_idle.c:1093: warning: long long unsigned int format, u64 arg (arg 5) Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Added option to display memory statistics upon termination.Bob Moore
2007-02-02ACPICA: Enhance debugger statistics/memory command.Valery A. Podrezov
Debugger: Enhanced the Statistics/Memory command to emit the total (maximum) memory used during execution, as well as the maximum memory consumed by each of the various object types. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Add new subsystem state bit that is set after SubsystemInitialize is ↵Bob Moore
called Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Delete stale FADT functions outside tbfadt.c.Bob Moore
Moved all FADT-related functions to a new file, tbfadt.c. Eliminated the acpi_hw_initialize function - the FADT registers are now validated when the table is loaded. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Cleanup of FADT verification function.Bob Moore
Removed offset display, not needed. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Split acpi_format_exception into two partsBob Moore
Split acpi_format_exception into two parts. New function is acpi_ut_verify_exception and will be used to verify exception codes returned by user. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Store GPE number instead of bitmaskAlexey Starikovskiy
Update internal GPE data structure to simplify debug, use gpe_number instead of register bitmask. Signed-off-by: Bob Moore <bob.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Fix unalignment in acpi_ut_repair_nameBob Moore
Update interface to acpi_ut_repair_name() to avoid alignment issues on IA64 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Add acpi_gpe_count global to track the number of GPE eventsBob Moore
2007-02-02ACPICA: misc fixes for new Table Manager:Bob Moore
2007-02-02ACPICA: Implement simplified Table ManagerBob Moore
The Table Manager component has been completely redesigned and reimplemented. The new design is much simpler, and reduces the overall code and data size of the kernel-resident ACPICA by approximately 5%. Also, it is now possible to obtain the ACPI tables very early during kernel initialization, even before dynamic memory management is initialized. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
