path: root/drivers/acpi
2011-05-29Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI EC: remove redundant code ACPI: Add D3 cold state ACPI: processor: fix processor_physically_present in UP kernel ACPI: Split out custom_method functionality into an own driver ACPI: Cleanup custom_method debug stuff ACPI EC: enable MSI workaround for Quanta laptops ACPICA: Update to version 20110413 ACPICA: Execute an orphan _REG method under the EC device ACPICA: Move ACPI_NUM_PREDEFINED_REGIONS to a more appropriate place ACPICA: Update internal address SpaceID for DataTable regions ACPICA: Add more methods eligible for NULL package element removal ACPICA: Split all internal Global Lock functions to new file - evglock ACPI: EC: add another DMI check for ASUS hardware ACPI EC: remove dead code ACPICA: Fix code divergence of global lock handling ACPICA: Use acpi_os_create_lock interface ACPI: osl, add acpi_os_create_lock interface ACPI:Fix goto flows in thermal-sys
2011-05-29Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param x86 idle: deprecate "no-hlt" cmdline param x86 idle APM: deprecate CONFIG_APM_CPU_IDLE x86 idle floppy: deprecate disable_hlt() x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it x86 idle: clarify AMD erratum 400 workaround idle governor: Avoid lock acquisition to read pm_qos before entering idle cpuidle: menu: fixed wrapping timers at 4.294 seconds
2011-05-29Merge branch 'ec-cleanup' into releaseLen Brown
Conflicts: drivers/platform/x86/compal-laptop.c
2011-05-29Merge branches 'acpica', 'aml-custom', 'bugzilla-16548', 'bugzilla-20242', ↵Len Brown
'd3-cold', 'ec-asus' and 'thermal-fix' into release
2011-05-29x86 idle: clarify AMD erratum 400 workaroundLen Brown
The workaround for AMD erratum 400 uses the term "c1e" falsely suggesting: 1. Intel C1E is somehow involved 2. All AMD processors with C1E are involved Use the string "amd_c1e" instead of simply "c1e" to clarify that this workaround is specific to AMD's version of C1E. Use the string "e400" to clarify that the workaround is specific to AMD processors with Erratum 400. This patch is text-substitution only, with no functional change. cc: x86@kernel.org Acked-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI EC: remove redundant codeZhang Rui
ec->handle is set in ec_parse_device(), so don't bother to set it again. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI: Add D3 cold stateLin Ming
_SxW returns an Integer containing the lowest D-state supported in state Sx. If OSPM has not indicated that it supports _PR3, then the value “3” corresponds to D3. If it has indicated _PR3 support, the value “3” represents D3hot and the value “4” represents D3cold. Linux does set _OSC._PR3, so we should fix it to expect that _SxW can return 4. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI: processor: fix processor_physically_present in UP kernelLin Ming
Usually, there are multiple processors defined in ACPI table, for example Scope (_PR) { Processor (CPU0, 0x00, 0x00000410, 0x06) {} Processor (CPU1, 0x01, 0x00000410, 0x06) {} Processor (CPU2, 0x02, 0x00000410, 0x06) {} Processor (CPU3, 0x03, 0x00000410, 0x06) {} } processor_physically_present(...) will be called to check whether those processors are physically present. Currently we have below codes in processor_physically_present, cpuid = acpi_get_cpuid(...); if ((cpuid == -1) && (num_possible_cpus() > 1)) return false; return true; In UP kernel, acpi_get_cpuid(...) always return -1 and num_possible_cpus() always return 1, so processor_physically_present(...) always returns true for all passed in processor handles. This is wrong for UP processor or SMP processor running UP kernel. This patch removes the !SMP version of acpi_get_cpuid(), so both UP and SMP kernel use the same acpi_get_cpuid function. And for UP kernel, only processor 0 is valid. https://bugzilla.kernel.org/show_bug.cgi?id=16548 https://bugzilla.kernel.org/show_bug.cgi?id=16357 Tested-by: Anton Kochkov <anton.kochkov@gmail.com> Tested-by: Ambroz Bizjak <ambrop7@gmail.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI: Split out custom_method functionality into an own driverThomas Renninger
With /sys/kernel/debug/acpi/custom_method root can write to arbitrary memory and increase his priveleges, even if these are restricted. -> Make this an own debug .config option and warn about the security issue in the config description. -> Still keep acpi/debugfs.c which now only creates an empty /sys/kernel/debug/acpi directory. There might be other users of it later. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: rui.zhang@intel.com Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI: Cleanup custom_method debug stuffThomas Renninger
- Move param aml_debug_output to other params into sysfs.c - Split acpi_debugfs_init to prepare custom_method to be an own .config option and driver. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: rui.zhang@intel.com Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI EC: enable MSI workaround for Quanta laptopsZhang Rui
Enable MSI workaround for Quanta laptops. https://bugzilla.kernel.org/show_bug.cgi?id=20242 Tested-by: Jan-Matthias Braun <jan_braun@gmx.net> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-25Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: New driver for the SMSC EMC6W201 hwmon: (abituguru) Depend on DMI hwmon: (it87) Use request_muxed_region hwmon: (sch5627) Trigger Vbat measurements hwmon: (sch5627) Add sch5627_send_cmd function i8k: Integrate with the hwmon subsystem hwmon: (max6650) Properly support the MAX6650 hwmon: (max6650) Drop device detection Move ACPI power meter driver to hwmon hwmon: (f71882fg) Add support for F71808A hwmon: (f71882fg) Split has_beep in fan_has_beep and temp_has_beep hwmon: (asc7621) Drop duplicate dependency hwmon: (jc42) Change detection class hwmon: Add driver for AMD family 15h processor power information hwmon: (k10temp) Add support for Fam15h (Bulldozer) hwmon: Use helper functions to set and get driver data i8k: Avoid lahf in 64-bit code
2011-05-25Move ACPI power meter driver to hwmonJean Delvare
As discussed earlier, the ACPI power meter driver would better live in drivers/hwmon, as its only purpose is to create hwmon-style interfaces for ACPI 4.0 power meter devices. Users are more likely to look for it there, and less likely to accidentally hide it by unselecting its dependencies. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: "Darrick J. Wong" <djwong@us.ibm.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Len Brown <lenb@kernel.org>
2011-05-25x86: remove 32-bit versions of readq()/writeq()Roland Dreier
The presense of a writeq() implementation on 32-bit x86 that splits the 64-bit write into two 32-bit writes turns out to break the mpt2sas driver (and in general is risky for drivers as was discussed in <http://lkml.kernel.org/r/adaab6c1h7c.fsf@cisco.com>). To fix this, revert 2c5643b1c5c7 ("x86: provide readq()/writeq() on 32-bit too") and follow-on cleanups. This unfortunately leads to pushing non-atomic definitions of readq() and write() to various x86-only drivers that in the meantime started using the definitions in the x86 version of <asm/io.h>. However as discussed exhaustively, this is actually the right thing to do, because the right way to split a 64-bit transaction is hardware dependent and therefore belongs in the hardware driver (eg mpt2sas needs a spinlock to make sure no other accesses occur in between the two halves of the access). Build tested on 32- and 64-bit x86 allmodconfig. Link: http://lkml.kernel.org/r/x86-32-writeq-is-broken@mdm.bga.com Acked-by: Hitoshi Mitake <h.mitake@gmail.com> Cc: Kashyap Desai <Kashyap.Desai@lsi.com> Cc: Len Brown <lenb@kernel.org> Cc: Ravi Anand <ravi.anand@qlogic.com> Cc: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Acked-by: James Bottomley <James.Bottomley@parallels.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-20Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] define "_sdata" symbol pstore: Fix Kconfig dependencies for apei->pstore pstore: fix potential logic issue in pstore read interface pstore: fix pstore filesystem mount/remount issue pstore: fix one type of return value in pstore [IA64] fix build warning in arch/ia64/oprofile/backtrace.c
2011-05-20pstore: Fix Kconfig dependencies for apei->pstoreLuck, Tony
Geert Uytterhoeven ran a dependency checker which kicked out this warning: + warning: (ACPI_APEI) selects PSTORE which has unmet direct dependencies (MISC_FILESYSTEMS): => N/A Randy confirmed that the fix was to "select MISC_FILESYSTEMS" too. Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-19Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits) x86, mm: Allow ZONE_DMA to be configurable x86, NUMA: Trim numa meminfo with max_pfn in a separate loop x86, NUMA: Rename setup_node_bootmem() to setup_node_data() x86, NUMA: Enable emulation on 32bit too x86, NUMA: Enable CONFIG_AMD_NUMA on 32bit too x86, NUMA: Rename amdtopology_64.c to amdtopology.c x86, NUMA: Make numa_init_array() static x86, NUMA: Make 32bit use common NUMA init path x86, NUMA: Initialize and use remap allocator from setup_node_bootmem() x86-32, NUMA: Add @start and @end to init_alloc_remap() x86, NUMA: Remove long 64bit assumption from numa.c x86, NUMA: Enable build of generic NUMA init code on 32bit x86, NUMA: Move NUMA init logic from numa_64.c to numa.c x86-32, NUMA: Update numaq to use new NUMA init protocol x86-32, NUMA: Replace srat_32.c with srat.c x86-32, NUMA: implement temporary NUMA init shims x86, NUMA: Move numa_nodes_parsed to numa.[hc] x86-32, NUMA: Move get_memcfg_numa() into numa_32.c x86, NUMA: make srat.c 32bit safe x86, NUMA: rename srat_64.c to srat.c ...
2011-05-19Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] remove redundant sprintf from request_module call. [CPUFREQ] cpufreq_stats.c: Fixed brace coding style issue [CPUFREQ] Fix memory leak in cpufreq_stat [CPUFREQ] cpufreq.h: Fix some checkpatch.pl coding style issues. [CPUFREQ] use dynamic debug instead of custom infrastructure [CPUFREQ] CPU hotplug, re-create sysfs directory and symlinks [CPUFREQ] Fix _OSC UUID in pcc-cpufreq
2011-05-16pstore: fix potential logic issue in pstore read interfaceChen Gong
1) in the calling of erst_read, the parameter of buffer size maybe overflows and cause crash 2) the return value of erst_read should be checked more strictly Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-16pstore: fix pstore filesystem mount/remount issueChen Gong
Currently after mount/remount operation on pstore filesystem, the content on pstore will be lost. It is because current ERST implementation doesn't support multi-user usage, which moves internal pointer to the end after accessing it. Adding multi-user support for pstore usage. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-16pstore: fix one type of return value in pstoreChen Gong
the return type of function _read_ in pstore is size_t, but in the callback function of _read_, the logic doesn't consider it too much, which means if negative value (assuming error here) is returned, it will be converted to positive because of type casting. ssize_t is enough for this function. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-10PCI/ACPI: Report _OSC control mask returned on failure to get controlRafael J. Wysocki
If an attempt to get _OSC control of the PCIe native features from the BIOS fails, report the resulting mask of control flags the BIOS was willing to grant in the error message. Moreover, if the _OSC support mask is insufficient for requesting control of the PCIe native features or pcie_ports_disabled is set, print a diagnostic message containing the _OSC support mask. This helps to diagnose obscure _OSC-related problems on a number machines. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-09ACPICA: Execute an orphan _REG method under the EC deviceBob Moore
This change will force the execution of a _REG method underneath the EC device even if there is no corresponding operation region of type EmbeddedControl. Fixes a problem seen on some machines and apparently is compatible with Windows behavior. http://www.acpica.org/bugzilla/show_bug.cgi?id=875 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-09ACPICA: Move ACPI_NUM_PREDEFINED_REGIONS to a more appropriate placeBob Moore
Moved to where the predefined regions are actually defined. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-09ACPICA: Update internal address SpaceID for DataTable regionsBob Moore
Moved this internal space id in preparation for ACPI 5.0 changes that will include some new space IDs. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-09ACPICA: Add more methods eligible for NULL package element removalBob Moore
This change adds another group of predefined names to the list of names eligible to have NULL package elements dynamically removed. This group is the names that return a single variable-length package containing simple data types such as integers, buffers, strings. This includes: _ALx,_BCL,_CID, _DOD,_EDL,_FIX,_PCL,_PLD,_PMD,_PRx,_PSL,_Sx, and _TZD. http://www.acpica.org/bugzilla/show_bug.cgi?id=914 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-09ACPICA: Split all internal Global Lock functions to new file - evglockBob Moore
These functions were moved from evmisc.c Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-04[CPUFREQ] use dynamic debug instead of custom infrastructureDominik Brodowski
With dynamic debug having gained the capability to report debug messages also during the boot process, it offers a far superior interface for debug messages than the custom cpufreq infrastructure. As a first step, remove the old cpufreq_debug_printk() function and replace it with a call to the generic pr_debug() function. How can dynamic debug be used on cpufreq? You need a kernel which has CONFIG_DYNAMIC_DEBUG enabled. To enabled debugging during runtime, mount debugfs and $ echo -n 'module cpufreq +p' > /sys/kernel/debug/dynamic_debug/control for debugging the complete "cpufreq" module. To achieve the same goal during boot, append ddebug_query="module cpufreq +p" as a boot parameter to the kernel of your choice. For more detailled instructions, please see Documentation/dynamic-debug-howto.txt Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2011-05-02Merge branch 'x86/urgent' into x86-mmTejun Heo
Merge reason: Pick up the following two fix commits. 2be19102b7: x86, NUMA: Fix empty memblk detection in numa_cleanup_meminfo() 765af22da8: x86-32, NUMA: Fix ACPI NUMA init broken by recent x86-64 change Scheduled NUMA init 32/64bit unification changes depend on these. Signed-off-by: Tejun Heo <tj@kernel.org>
2011-04-26ACPI / PM: Avoid infinite recurrence while registering power resourcesRafael J. Wysocki
There is at least one BIOS with a DSDT containing a power resource object with a _PR0 entry pointing back to that power resource. In consequence, while registering that power resource acpi_bus_get_power_flags() sees that it depends on itself and tries to register it again, which leads to an infinitely deep recurrence. This problem was introduced by commit bf325f9538d8c89312be305b9779e (ACPI / PM: Register power resource devices as soon as they are needed). To fix this problem use the observation that power resources cannot be power manageable and prevent acpi_bus_get_power_flags() from being called for power resource objects. References: https://bugzilla.kernel.org/show_bug.cgi?id=31872 Reported-and-tested-by: Pascal Dormeau <pdormeau@free.fr> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Len Brown <lenb@kernel.org> Cc: stable@kernel.org
2011-04-25ACPI: EC: add another DMI check for ASUS hardwarePeter Collingbourne
Commit 0adf3c746a73684b3f8c2821a584e1db998f61e9 introduced a regression by making the ECDT validation test for ASUS hardware more restrictive. The previous test used the dmi_name_in_vendors function which searches a number of DMI fields, while the new test checked only the BIOS vendor, which is known to not match on an ASUS F5GL laptop which requires ECDT validation. Add a rule to ec_dmi_table based on an alternative DMI pattern for ASUS hardware as found elsewhere in the kernel. Signed-off-by: Peter Collingbourne <peter@pcc.me.uk> Signed-off-by: Len Brown <len.brown@intel.com>
2011-04-01ACPI EC: remove dead codeThomas Renninger
static void acpi_ec_gpe_query(void *ec_cxt); -> The function is right above this declaration -> not needed. poll_force is also not used, cleaned up in ec.c and its users: compal-laptop and msi-laptop. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-29acpi throttling: Use this_cpu_has and simplify code current cpuChristoph Lameter
With the this_cpu_xx we no longer need to pass an acpi structure to the msr management code. Simplifies code and improves performance. NOTE: This code is x86 specific (see #ifdef CONFIG_X86) but not under arch/x86. Signed-off-by: Christoph Lameter <cl@linux.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-03-28acpi: Remove sysfs_create_link from video driverMatthew Garrett
The acpi video driver attempts to explicitly create a sysfs link between the acpi device and the associated PCI device. However, we're now also doing this from the backlight core, which means that we get a backtrace caused by a duplicate file. Remove the code and leave it up to the backlight core. Reported-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Alessandro Suardi <alessandro.suardi@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: Disable ASPM when _OSC control is not granted for PCIe services PCI: Changing ASPM policy, via /sys, to POWERSAVE could cause NMIs PCI: PCIe links may not get configured for ASPM under POWERSAVE mode PCI/ACPI: Report ASPM support to BIOS if not disabled from command line
2011-03-25ACPICA: Fix code divergence of global lock handlingLin Ming
Commit 9cd0314(ACPI / ACPICA: Fix global lock acquisition) was backported into ACPICA code base, and some divergence was introduced. This patch fixed it, - rename acpi_ev_global_lock_pending/acpi_ev_global_lock_pending_lock to acpi_gbl_global_lock_pending/acpi_gbl_global_lock_pending_lock. - move the initialization of acpi_gbl_global_lock_pending_lock from acpi_ut_mutex_initialize to acpi_ev_init_global_lock_handler. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-25ACPICA: Use acpi_os_create_lock interfaceLin Ming
Replace spin_lock_init with acpi_os_create_lock. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-25ACPI: osl, add acpi_os_create_lock interfaceLin Ming
2011-03-23Merge branch 'sysdev' into releaseLen Brown
2011-03-23Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/acpi/sleep.c Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-23Merge branch 'battery-sysfs-notifier' into releaseLen Brown
2011-03-23Merge branch 'reset' into releaseLen Brown
2011-03-23Merge branch 'misc' into releaseLen Brown
2011-03-23ACPI: minor printk format change in acpi_padNaga Chumbalkar
Minor format change. Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-23ACPI: make acpi_pad /sys output more readableNaga Chumbalkar
Make /sys output from acpi_pad more readable. Before the fix: # cat idlecpus idlepct rrtime 00000000510 After the fix: # cat idlecpus idlepct rrtime 00000000 5 10 Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-22ACPI: Make sure the FADT is at least rev 2 before using the reset registerMatthew Garrett
The reset register was only introduced with version 2 of the FADT, so we should check that the FADT revision before trusting its contents. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
