path: root/drivers/acpi
2013-07-30ACPI / battery: Fix parsing _BIX return valueLan Tianyu
The _BIX method returns extended battery info as a package. According the ACPI spec (ACPI 5, Section 10.2.2.2), the first member of that package should be "Revision". However, the current ACPI battery driver treats the first member as "Power Unit" which should be the second member. This causes the result of _BIX return data parsing to be incorrect. Fix this by adding a new member called 'revision' to struct acpi_battery and adding the offsetof() information on it to extended_info_offsets[] as the first row. [rjw: Changelog] Reported-and-tested-by: Jan Hoffmann <jan.christian.hoffmann@gmail.com> References: http://bugzilla.kernel.org/show_bug.cgi?id=60519 Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Cc: 2.6.34+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-26Revert "ACPI / video / i915: No ACPI backlight if firmware expects Windows 8"Rafael J. Wysocki
We attempted to address a regression introduced by commit a57f7f9 (ACPICA: Add Windows8/Server2012 string for _OSI method.) after which ACPI video backlight support doesn't work on a number of systems, because the relevant AML methods in the ACPI tables in their BIOSes become useless after the BIOS has been told that the OS is compatible with Windows 8. That problem is tracked by the bug entry at: https://bugzilla.kernel.org/show_bug.cgi?id=51231 Commit 8c5bd7a (ACPI / video / i915: No ACPI backlight if firmware expects Windows 8) introduced for this purpose essentially prevented the ACPI backlight support from being used if the BIOS had been told that the OS was compatible with Windows 8 and the i915 driver was loaded, in which case the backlight would always be handled by i915. Unfortunately, however, that turned out to cause problems with backlight to appear on multiple systems with symptoms indicating that i915 was unable to control the backlight on those systems as expected. For this reason, revert commit 8c5bd7a, but leave the function acpi_video_backlight_quirks() introduced by it, because another commit on top of it uses that function. References: https://lkml.org/lkml/2013/7/21/119 References: https://lkml.org/lkml/2013/7/22/261 References: https://lkml.org/lkml/2013/7/23/429 References: https://lkml.org/lkml/2013/7/23/459 References: https://lkml.org/lkml/2013/7/23/81 References: https://lkml.org/lkml/2013/7/24/27 Reported-and-tested-by: James Hogan <james@albanarts.com> Reported-and-tested-by: Kamal Mostafa <kamal@canonical.com> Reported-and-tested-by: Jörg Otte <jrg.otte@gmail.com> Reported-and-tested-by: Steven Newbury <steve@snewbury.org.uk> Reported-by: Martin Steigerwald <Martin@lichtvoll.de> Reported-by: Kalle Valo <kvalo@adurom.com> Tested-by: Joerg Platte <jplatte@naasa.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-21Merge tag 'acpi-video-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI video support fixes from Rafael Wysocki: "I'm sending a separate pull request for this as it may be somewhat controversial. The breakage addressed here is not really new and the fixes may not satisfy all users of the affected systems, but we've had so much back and forth dance in this area over the last several weeks that I think it's time to actually make some progress. The source of the problem is that about a year ago we started to tell BIOSes that we're compatible with Windows 8, which we really need to do, because some systems shipping with Windows 8 are tested with it and nothing else, so if we tell their BIOSes that we aren't compatible with Windows 8, we expose our users to untested BIOS/AML code paths. However, as it turns out, some Windows 8-specific AML code paths are not tested either, because Windows 8 actually doesn't use the ACPI methods containing them, so if we declare Windows 8 compatibility and attempt to use those ACPI methods, things break. That occurs mostly in the backlight support area where in particular the _BCM and _BQC methods are plain unusable on some systems if the OS declares Windows 8 compatibility. [ The additional twist is that they actually become usable if the OS says it is not compatible with Windows 8, but that may cause problems to show up elsewhere ] Investigation carried out by Matthew Garrett indicates that what Windows 8 does about backlight is to leave backlight control up to individual graphics drivers. At least there's evidence that it does that if the Intel graphics driver is used, so we've decided to follow Windows 8 in that respect and allow i915 to control backlight (Daniel likes that part). The first commit from Aaron Lu makes ACPICA export the variable from which we can infer whether or not the BIOS believes that we are compatible with Windows 8. The second commit from Matthew Garrett prepares the ACPI video driver by making it initialize the ACPI backlight even if it is not going to be used afterward (that is needed for backlight control to work on Thinkpads). The third commit implements the actual workaround making i915 take over backlight control if the firmware thinks it's dealing with Windows 8 and is based on the work of multiple developers, including Matthew Garrett, Chun-Yi Lee, Seth Forshee, and Aaron Lu. The final commit from Aaron Lu makes us follow Windows 8 by informing the firmware through the _DOS method that it should not carry out automatic brightness changes, so that brightness can be controlled by GUI. Hopefully, this approach will allow us to avoid using blacklists of systems that should not declare Windows 8 compatibility just to avoid backlight control problems in the future. - Change from Aaron Lu makes ACPICA export a variable which can be used by driver code to determine whether or not the BIOS believes that we are compatible with Windows 8. - Change from Matthew Garrett makes the ACPI video driver initialize the ACPI backlight even if it is not going to be used afterward (that is needed for backlight control to work on Thinkpads). - Fix from Rafael J Wysocki implements Windows 8 backlight support workaround making i915 take over bakclight control if the firmware thinks it's dealing with Windows 8. Based on the work of multiple developers including Matthew Garrett, Chun-Yi Lee, Seth Forshee, and Aaron Lu. - Fix from Aaron Lu makes the kernel follow Windows 8 by informing the firmware through the _DOS method that it should not carry out automatic brightness changes, so that brightness can be controlled by GUI" * tag 'acpi-video-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / video: no automatic brightness changes by win8-compatible firmware ACPI / video / i915: No ACPI backlight if firmware expects Windows 8 ACPI / video: Always call acpi_video_init_brightness() on init ACPICA: expose OSI version
2013-07-19Merge tag 'pm+acpi-3.11-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: "These are fixes collected over the last week, most importnatly two cpufreq reverts fixing regressions introduced in 3.10, an autoseelp fix preventing systems using it from crashing during shutdown and two ACPI scan fixes related to hotplug. Specifics: - Two cpufreq commits from the 3.10 cycle introduced regressions. The first of them was buggy (it did way much more than it needed to do) and the second one attempted to fix an issue introduced by the first one. Fixes from Srivatsa S Bhat revert both. - If autosleep triggers during system shutdown and the shutdown callbacks of some device drivers have been called already, it may crash the system. Fix from Liu Shuo prevents that from happening by making try_to_suspend() check system_state. - The ACPI memory hotplug driver doesn't clear its driver_data on errors which may cause a NULL poiter dereference to happen later. Fix from Toshi Kani. - The ACPI namespace scanning code should not try to attach scan handlers to device objects that have them already, which may confuse things quite a bit, and it should rescan the whole namespace branch starting at the given node after receiving a bus check notify event even if the device at that particular node has been discovered already. Fixes from Rafael J Wysocki. - New ACPI video blacklist entry for a system whose initial backlight setting from the BIOS doesn't make sense. From Lan Tianyu. - Garbage string output avoindance for ACPI PNP from Liu Shuo. - Two Kconfig fixes for issues introduced recently in the s3c24xx cpufreq driver (when moving the driver to drivers/cpufreq) from Paul Bolle. - Trivial comment fix in pm_wakeup.h from Chanwoo Choi" * tag 'pm+acpi-3.11-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / video: ignore BIOS initial backlight value for Fujitsu E753 PNP / ACPI: avoid garbage in resource name cpufreq: Revert commit 2f7021a8 to fix CPU hotplug regression cpufreq: s3c24xx: fix "depends on ARM_S3C24XX" in Kconfig cpufreq: s3c24xx: rename CONFIG_CPU_FREQ_S3C24XX_DEBUGFS PM / Sleep: Fix comment typo in pm_wakeup.h PM / Sleep: avoid 'autosleep' in shutdown progress cpufreq: Revert commit a66b2e to fix suspend/resume regression ACPI / memhotplug: Fix a stale pointer in error path ACPI / scan: Always call acpi_bus_scan() for bus check notifications ACPI / scan: Do not try to attach scan handlers to devices having them
2013-07-18ACPI / video: ignore BIOS initial backlight value for Fujitsu E753Lan Tianyu
The BIOS of FUjitsu E753 reports an incorrect initial backlight value for WIN8 compatible OS, causing backlight to be dark during startup. This change causes the incorrect initial value from BIOS to be ignored. References: https://bugzilla.kernel.org/show_bug.cgi?id=60161 Reported-and-tested-by: Jan Hinnerk Stosch <janhinnerk.stosch@gmail.com> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Cc: 3.7+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-18ACPI / video: no automatic brightness changes by win8-compatible firmwareAaron Lu
Starting from win8, MS backlight control driver will set bit 2 of the parameter of control method _DOS, to inform firmware it should not perform any automatic brightness changes. This mostly affects hotkey notification deliver - if we do not set this bit, on hotkey press, firmware may choose to adjust brightness level instead of sending out notification and doing nothing. So this patch sets bit 2 when calling _DOS so that GUIs can show the notification window on hotkey press. This behavior change is only necessary for win8 systems. The MS document on win8 backlight control is here: http://msdn.microsoft.com/en-US/library/windows/hardware/jj159305 References: https://bugzilla.kernel.org/show_bug.cgi?id=52951 References: https://bugzilla.kernel.org/show_bug.cgi?id=56711 Reported-by: Micael Dias <kam1kaz3@gmail.com> Reported-by: Dan Garton <dan.garton@gmail.com> Reported-by: Bob Ziuchkovski <bob.ziuchkovski@gmail.com> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-18ACPI / video / i915: No ACPI backlight if firmware expects Windows 8Rafael J. Wysocki
According to Matthew Garrett, "Windows 8 leaves backlight control up to individual graphics drivers rather than making ACPI calls itself. There's plenty of evidence to suggest that the Intel driver for Windows [8] doesn't use the ACPI interface, including the fact that it's broken on a bunch of machines when the OS claims to support Windows 8. The simplest thing to do appears to be to disable the ACPI backlight interface on these systems". There's a problem with that approach, however, because simply avoiding to register the ACPI backlight interface if the firmware calls _OSI for Windows 8 may not work in the following situations: (1) The ACPI backlight interface actually works on the given system and the i915 driver is not loaded (e.g. another graphics driver is used). (2) The ACPI backlight interface doesn't work on the given system, but there is a vendor platform driver that will register its own, equally broken, backlight interface if not prevented from doing so by the ACPI subsystem. Therefore we need to allow the ACPI backlight interface to be registered until the i915 driver is loaded which then will unregister it if the firmware has called _OSI for Windows 8 (or will register the ACPI video driver without backlight support if not already present). For this reason, introduce an alternative function for registering ACPI video, acpi_video_register_with_quirks(), that will check whether or not the ACPI video driver has already been registered and whether or not the backlight Windows 8 quirk has to be applied. If the quirk has to be applied, it will block the ACPI backlight support and either unregister the backlight interface if the ACPI video driver has already been registered, or register the ACPI video driver without the backlight interface otherwise. Make the i915 driver use acpi_video_register_with_quirks() instead of acpi_video_register() in i915_driver_load(). This change is based on earlier patches from Matthew Garrett, Chun-Yi Lee and Seth Forshee and includes a fix from Aaron Lu's. References: https://bugzilla.kernel.org/show_bug.cgi?id=51231 Tested-by: Aaron Lu <aaron.lu@intel.com> Tested-by: Igor Gnatenko <i.gnatenko.brain@gmail.com> Tested-by: Yves-Alexis Perez <corsac@debian.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Matthew Garrett <matthew.garrett@nebula.com>
2013-07-18ACPI / video: Always call acpi_video_init_brightness() on initMatthew Garrett
We have to call acpi_video_init_brightness() even if we're not going to initialise the backlight - Thinkpads seem to use this as the trigger for enabling ACPI notifications rather than handling it in firmware. [rjw: Drop the brightness object created by acpi_video_init_brightness() if we are not going to use it.] Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-18ACPICA: expose OSI versionAaron Lu
Expose acpi_gbl_osi_data so that code outside of ACPICA can check the value of the last successfull _OSI call. The definitions for OSI versions are moved to actypes.h so that other components can access them too. Based on a patch from Matthew Garrett which in turn was based on an earlier patch from Seth Forshee. [rjw: Changelog] Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-14acpi: delete __cpuinit usage from all acpi filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. This removes all the drivers/acpi uses of the __cpuinit macros from all C files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Len Brown <lenb@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: linux-acpi@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-15ACPI / memhotplug: Fix a stale pointer in error pathToshi Kani
device->driver_data needs to be cleared when releasing its data, mem_device, in an error path of acpi_memory_device_add(). The function evaluates the _CRS of memory device objects, and fails when it gets an unexpected resource or cannot allocate memory. A kernel crash or data corruption may occur when the kernel accesses the stale pointer. Signed-off-by: Toshi Kani <toshi.kani@hp.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: 2.6.32+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-15ACPI / scan: Always call acpi_bus_scan() for bus check notificationsRafael J. Wysocki
An ACPI_NOTIFY_BUS_CHECK notification means that we should scan the entire namespace starting from the given handle even if the device represented by that handle is present (other devices below it may just have appeared). For this reason, modify acpi_scan_bus_device_check() to always run acpi_bus_scan() if the notification being handled is of type ACPI_NOTIFY_BUS_CHECK. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Cc: 3.10+ <stable@vger.kernel.org>
2013-07-15ACPI / scan: Do not try to attach scan handlers to devices having themRafael J. Wysocki
In acpi_bus_device_attach(), if there is an ACPI device object for the given handle and that device object has a scan handler attached to it already, there's nothing more to do for that handle. Moreover, if acpi_scan_attach_handler() is called then, it may execute the .attach() callback of the ACPI scan handler already attached to the device object and that may lead to interesting breakage. For this reason, make acpi_bus_device_attach() return success immediately when the handle's device object has a scan handler attached to it. Reported-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Cc: 3.10+ <stable@vger.kernel.org>
2013-07-11Merge tag 'pm+acpi-3.11-rc1-more' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management and ACPI updates from Rafael Wysocki: - Fix for a recent cpufreq regression that caused WARN() to trigger overzealously in a couple of places and spam the kernel log with useless garbage as a result. From Viresh Kumar. - ACPI dock fix removing a discrepancy between the definition of acpi_dock_init(), which says that the function returns int, and its header in the header file, which says that it is a void function. The function is now defined as void too. - ACPI PM fix for failures to update device power states as needed, for example, during resume from system suspend, because the old state was deeper than the new one, but the new one is not D0. - Fix for two debug messages in the ACPI power resources code that don't have a newline at the end and make the kernel log difficult to read. From Mika Westerberg. - Two ACPI cleanups from Naresh Bhat and Haicheng Li. - cpupower updates from Thomas Renninger, including Intel Haswell support improvements and a new idle-set subcommand among other things. * tag 'pm+acpi-3.11-rc1-more' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / power: add missing newline to debug messages cpupower: Add Haswell family 0x45 specific idle monitor to show PC8,9,10 states cpupower: Haswell also supports the C-states introduced with SandyBridge cpupower: Introduce idle-set subcommand and C-state enabling/disabling cpupower: Implement disabling of cstate interface cpupower: Make idlestate usage unsigned ACPI / fan: Initialize acpi_state variable ACPI / scan: remove unused LIST_HEAD(acpi_device_list) ACPI / dock: Actually define acpi_dock_init() as void ACPI / PM: Fix corner case in acpi_bus_update_power() cpufreq: Fix serialization of frequency transitions
2013-07-05ACPI / power: add missing newline to debug messagesMika Westerberg
There are few places in power.c where debug messages have no newline at the end. Reading such debug messages from dmesg is not fun, so fix this by adding the missing newlines. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Cc: All <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "This is the powerpc changes for the 3.11 merge window. In addition to the usual bug fixes and small updates, the main highlights are: - Support for transparent huge pages by Aneesh Kumar for 64-bit server processors. This allows the use of 16M pages as transparent huge pages on kernels compiled with a 64K base page size. - Base VFIO support for KVM on power by Alexey Kardashevskiy - Wiring up of our nvram to the pstore infrastructure, including putting compressed oopses in there by Aruna Balakrishnaiah - Move, rework and improve our "EEH" (basically PCI error handling and recovery) infrastructure. It is no longer specific to pseries but is now usable by the new "powernv" platform as well (no hypervisor) by Gavin Shan. - I fixed some bugs in our math-emu instruction decoding and made it usable to emulate some optional FP instructions on processors with hard FP that lack them (such as fsqrt on Freescale embedded processors). - Support for Power8 "Event Based Branch" facility by Michael Ellerman. This facility allows what is basically "userspace interrupts" for performance monitor events. - A bunch of Transactional Memory vs. Signals bug fixes and HW breakpoint/watchpoint fixes by Michael Neuling. And more ... I appologize in advance if I've failed to highlight something that somebody deemed worth it." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) pstore: Add hsize argument in write_buf call of pstore_ftrace_call powerpc/fsl: add MPIC timer wakeup support powerpc/mpic: create mpic subsystem object powerpc/mpic: add global timer support powerpc/mpic: add irq_set_wake support powerpc/85xx: enable coreint for all the 64bit boards powerpc/8xx: Erroneous double irq_eoi() on CPM IRQ in MPC8xx powerpc/fsl: Enable CONFIG_E1000E in mpc85xx_smp_defconfig powerpc/mpic: Add get_version API both for internal and external use powerpc: Handle both new style and old style reserve maps powerpc/hw_brk: Fix off by one error when validating DAWR region end powerpc/pseries: Support compression of oops text via pstore powerpc/pseries: Re-organise the oops compression code pstore: Pass header size in the pstore write callback powerpc/powernv: Fix iommu initialization again powerpc/pseries: Inform the hypervisor we are using EBB regs powerpc/perf: Add power8 EBB support powerpc/perf: Core EBB support for 64-bit book3s powerpc/perf: Drop MMCRA from thread_struct powerpc/perf: Don't enable if we have zero events ...
2013-07-04ACPI / fan: Initialize acpi_state variableNaresh Bhat
Make the following compiler warning go away: CC drivers/acpi/fan.o drivers/acpi/fan.c: In function ‘fan_get_cur_state’: drivers/acpi/fan.c:96:9: warning: ‘acpi_state’ may be used uninitialized in this function [-Wuninitialized] by initializing the local variable acpi_state in fan_get_cur_state(). [rjw: Changelog] Signed-off-by: Naresh Bhat <naresh.bhat@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-04ACPI / scan: remove unused LIST_HEAD(acpi_device_list)Haicheng Li
The acpi_device_list list is not used, so removed it. [rjw: Changelog] Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-04ACPI / dock: Actually define acpi_dock_init() as voidRafael J. Wysocki
Commit 94add0f (ACPI / dock: Initialize ACPI dock subsystem upfront) changed the header of acpi_dock_init() in internal.h so that it is supposed to be a void function now, but it forgot to update its actual definition in dock.c according to which it still is supposed to return int. Although that didn't cause any visible breakage or even a compiler warning to be thrown, which is odd enough, fix it. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: 3.10+ <stable@vger.kernel.org>
2013-07-04ACPI / PM: Fix corner case in acpi_bus_update_power()Rafael J. Wysocki
The role of acpi_bus_update_power() is to update the given ACPI device object's power.state field to reflect the current physical state of the device (as inferred from the configuration of power resources and _PSC, if available). For this purpose it calls acpi_device_set_power() that should update the power resources' reference counters and set power.state as appropriate. However, that doesn't work if the "new" state is D1, D2 or D3hot and the the current value of power.state means D3cold, because in that case acpi_device_set_power() will refuse to transition the device from D3cold to non-D0. To address this problem, make acpi_bus_update_power() call acpi_power_transition() directly to update the power resources' reference counters and only use acpi_device_set_power() to put the device into D0 if the current physical state of it cannot be determined. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: 3.9+ <stable@vger.kernel.org>
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03Merge tag 'pci-v3.11-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "PCI device hotplug - Add pci_alloc_dev() interface (Gu Zheng) - Add pci_bus_get()/put() for reference counting (Jiang Liu) - Fix SR-IOV reference count issues (Jiang Liu) - Remove unused acpi_pci_roots list (Jiang Liu) MSI - Conserve interrupt resources on x86 (Alexander Gordeev) AER - Force fatal severity when component has been reset (Betty Dall) - Reset link below Root Port as well as Downstream Port (Betty Dall) - Fix "Firmware first" flag setting (Bjorn Helgaas) - Don't parse HEST for non-PCIe devices (Bjorn Helgaas) ASPM - Warn when we can't disable ASPM as driver requests (Bjorn Helgaas) Miscellaneous - Add CircuitCo PCI IDs (Darren Hart) - Add AMD CZ SATA and SMBus PCI IDs (Shane Huang) - Work around Ivytown NTB BAR size issue (Jon Mason) - Detect invalid initial BAR values (Kevin Hao) - Add pcibios_release_device() (Sebastian Ott) - Fix powerpc & sparc PCI_UNKNOWN power state usage (Bjorn Helgaas)" * tag 'pci-v3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits) MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci PCI: Add CircuitCo vendor ID and subsystem ID PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM) PCI: Return early on allocation failures to unindent mainline code PCI: Simplify IOV implementation and fix reference count races PCI: Drop redundant setting of bus->is_added in virtfn_add_bus() unicore32/PCI: Remove redundant call of pci_bus_add_devices() m68k/PCI: Remove redundant call of pci_bus_add_devices() PCI / ACPI / PM: Use correct power state strings in messages PCI: Fix comment typo for pcie_pme_remove() PCI: Rename pci_release_bus_bridge_dev() to pci_release_host_bridge_dev() PCI: Fix refcount issue in pci_create_root_bus() error recovery path ia64/PCI: Clean up pci_scan_root_bus() usage PCI/AER: Reset link for devices below Root Port or Downstream Port ACPI / APEI: Force fatal AER severity when component has been reset PCI/AER: Remove "extern" from function declarations PCI/AER: Move AER severity defines to aer.h PCI/AER: Set dev->__aer_firmware_first only for matching devices PCI/AER: Factor out HEST device type matching PCI/AER: Don't parse HEST table for non-PCIe devices ...
2013-07-03clean up scary strncpy(dst, src, strlen(src)) usesKees Cook
Fix various weird constructions of strncpy(dst, src, strlen(src)). Length limits should be about the space available in the destination, not repurposed as a method to either always include or always exclude a trailing NULL byte. Either the NULL should always be copied (using strlcpy), or it should not be copied (using something like memcpy). Readable code should not depend on the weird behavior of strncpy when it hits the length limit. Better to avoid the anti-pattern entirely. [akpm@linux-foundation.org: revert getdelays.c part due to missing bsd/string.h] Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [staging] Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [acpi] Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ursula Braun <ursula.braun@de.ibm.com> Cc: Frank Blaschka <blaschka@linux.vnet.ibm.com> Cc: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Merge tag 'pm+acpi-3.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "This time the total number of ACPI commits is slightly greater than the number of cpufreq commits, but Viresh Kumar (who works on cpufreq) remains the most active patch submitter. To me, the most significant change is the addition of offline/online device operations to the driver core (with the Greg's blessing) and the related modifications of the ACPI core hotplug code. Next are the freezer updates from Colin Cross that should make the freezing of tasks a bit less heavy weight. We also have a couple of regression fixes, a number of fixes for issues that have not been identified as regressions, two new drivers and a bunch of cleanups all over. Highlights: - Hotplug changes to support graceful hot-removal failures. It sometimes is necessary to fail device hot-removal operations gracefully if they cannot be carried out completely. For example, if memory from a memory module being hot-removed has been allocated for the kernel's own use and cannot be moved elsewhere, it's desirable to fail the hot-removal operation in a graceful way rather than to crash the kernel, but currenty a success or a kernel crash are the only possible outcomes of an attempted memory hot-removal. Needless to say, that is not a very attractive alternative and it had to be addressed. However, in order to make it work for memory, I first had to make it work for CPUs and for this purpose I needed to modify the ACPI processor driver. It's been split into two parts, a resident one handling the low-level initialization/cleanup and a modular one playing the actual driver's role (but it binds to the CPU system device objects rather than to the ACPI device objects representing processors). That's been sort of like a live brain surgery on a patient who's riding a bike. So this is a little scary, but since we found and fixed a couple of regressions it caused to happen during the early linux-next testing (a month ago), nobody has complained. As a bonus we remove some duplicated ACPI hotplug code, because the ACPI-based CPU hotplug is now going to use the common ACPI hotplug code. - Lighter weight freezing of tasks. These changes from Colin Cross and Mandeep Singh Baines are targeted at making the freezing of tasks a bit less heavy weight operation. They reduce the number of tasks woken up every time during the freezing, by using the observation that the freezer simply doesn't need to wake up some of them and wait for them all to call refrigerator(). The time needed for the freezer to decide to report a failure is reduced too. Also reintroduced is the check causing a lockdep warining to trigger when try_to_freeze() is called with locks held (which is generally unsafe and shouldn't happen). - cpufreq updates First off, a commit from Srivatsa S Bhat fixes a resume regression introduced during the 3.10 cycle causing some cpufreq sysfs attributes to return wrong values to user space after resume. The fix is kind of fresh, but also it's pretty obvious once Srivatsa has identified the root cause. Second, we have a new freqdomain_cpus sysfs attribute for the acpi-cpufreq driver to provide information previously available via related_cpus. From Lan Tianyu. Finally, we fix a number of issues, mostly related to the CPUFREQ_POSTCHANGE notifier and cpufreq Kconfig options and clean up some code. The majority of changes from Viresh Kumar with bits from Jacob Shin, Heiko Stübner, Xiaoguang Chen, Ezequiel Garcia, Arnd Bergmann, and Tang Yuantian. - ACPICA update A usual bunch of updates from the ACPICA upstream. During the 3.4 cycle we introduced support for ACPI 5 extended sleep registers, but they are only supposed to be used if the HW-reduced mode bit is set in the FADT flags and the code attempted to use them without checking that bit. That caused suspend/resume regressions to happen on some systems. Fix from Lv Zheng causes those registers to be used only if the HW-reduced mode bit is set. Apart from this some other ACPICA bugs are fixed and code cleanups are made by Bob Moore, Tomasz Nowicki, Lv Zheng, Chao Guan, and Zhang Rui. - cpuidle updates New driver for Xilinx Zynq processors is added by Michal Simek. Multidriver support simplification, addition of some missing kerneldoc comments and Kconfig-related fixes come from Daniel Lezcano. - ACPI power management updates Changes to make suspend/resume work correctly in Xen guests from Konrad Rzeszutek Wilk, sparse warning fix from Fengguang Wu and cleanups and fixes of the ACPI device power state selection routine. - ACPI documentation updates Some previously missing pieces of ACPI documentation are added by Lv Zheng and Aaron Lu (hopefully, that will help people to uderstand how the ACPI subsystem works) and one outdated doc is updated by Hanjun Guo. - Assorted ACPI updates We finally nailed down the IA-64 issue that was the reason for reverting commit 9f29ab11ddbf ("ACPI / scan: do not match drivers against objects having scan handlers"), so we can fix it and move the ACPI scan handler check added to the ACPI video driver back to the core. A mechanism for adding CMOS RTC address space handlers is introduced by Lan Tianyu to allow some EC-related breakage to be fixed on some systems. A spec-compliant implementation of acpi_os_get_timer() is added by Mika Westerberg. The evaluation of _STA is added to do_acpi_find_child() to avoid situations in which a pointer to a disabled device object is returned instead of an enabled one with the same _ADR value. From Jeff Wu. Intel BayTrail PCH (Platform Controller Hub) support is added to the ACPI driver for Intel Low-Power Subsystems (LPSS) and that driver is modified to work around a couple of known BIOS issues. Changes from Mika Westerberg and Heikki Krogerus. The EC driver is fixed by Vasiliy Kulikov to use get_user() and put_user() instead of dereferencing user space pointers blindly. Code cleanups are made by Bjorn Helgaas, Nicholas Mazzuca and Toshi Kani. - Assorted power management updates The "runtime idle" helper routine is changed to take the return values of the callbacks executed by it into account and to call rpm_suspend() if they return 0, which allows us to reduce the overall code bloat a bit (by dropping some code that's not necessary any more after that modification). The runtime PM documentation is updated by Alan Stern (to reflect the "runtime idle" behavior change). New trace points for PM QoS are added by Sahara (<keun-o.park@windriver.com>). PM QoS documentation is updated by Lan Tianyu. Code cleanups are made and minor issues are addressed by Bernie Thompson, Bjorn Helgaas, Julius Werner, and Shuah Khan. - devfreq updates New driver for the Exynos5-bus device from Abhilash Kesavan. Minor cleanups, fixes and MAINTAINERS update from MyungJoo Ham, Abhilash Kesavan, Paul Bolle, Rajagopal Venkat, and Wei Yongjun. - OMAP power management updates Adaptive Voltage Scaling (AVS) SmartReflex voltage control driver updates from Andrii Tseglytskyi and Nishanth Menon." * tag 'pm+acpi-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits) cpufreq: Fix cpufreq regression after suspend/resume ACPI / PM: Fix possible NULL pointer deref in acpi_pm_device_sleep_state() PM / Sleep: Warn about system time after resume with pm_trace cpufreq: don't leave stale policy pointer in cdbs->cur_policy acpi-cpufreq: Add new sysfs attribute freqdomain_cpus cpufreq: make sure frequency transitions are serialized ACPI: implement acpi_os_get_timer() according the spec ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scan ACPI: Add CMOS RTC Operation Region handler support ACPI / processor: Drop unused variable from processor_perflib.c cpufreq: tegra: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: s3c64xx: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: omap: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: imx6q: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: exynos: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: dbx500: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: davinci: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: arm-big-little: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: powernow-k8: call CPUFREQ_POSTCHANGE notfier in error cases cpufreq: pcc: call CPUFREQ_POSTCHANGE notfier in error cases ...
2013-07-03Merge tag 'please-pull-pstore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull pstore update from Tony Luck: "Fixes for pstore for 3.11 merge window" * tag 'please-pull-pstore' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: efivars: If pstore_register fails, free unneeded pstore buffer acpi: Eliminate console msg if pstore.backend excludes ERST pstore: Return unique error if backend registration excluded by kernel param pstore: Fail to unlink if a driver has not defined pstore_erase pstore/ram: remove the power of buffer size limitation pstore/ram: avoid atomic accesses for ioremapped regions efi, pstore: Cocci spatch "memdup.spatch"
2013-07-02Merge branch 'x86-ras-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 RAS update from Ingo Molnar: "The changes in this tree are: - ACPI APEI (ACPI Platform Error Interface) improvements, by Chen Gong - misc MCE fixes/cleanups" * 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mce: Update MCE severity condition check mce: acpi/apei: Add comments to clarify usage of the various bitfields in the MCA subsystem ACPI/APEI: Update einj documentation for param1/param2 ACPI/APEI: Add parameter check before error injection ACPI, APEI, EINJ: Fix error return code in einj_init() x86, mce: Fix "braodcast" typo
2013-07-01pstore: Pass header size in the pstore write callbackAruna Balakrishnaiah
Header size is needed to distinguish between header and the dump data. Incorporate the addition of new argument (hsize) in the pstore write callback. Signed-off-by: Aruna Balakrishnaiah <aruna@linux.vnet.ibm.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-29Merge branch 'acpi-assorted'Rafael J. Wysocki
* acpi-assorted: ACPI: implement acpi_os_get_timer() according the spec
2013-06-29Merge branch 'acpi-pm'Rafael J. Wysocki
* acpi-pm: ACPI / PM: Fix possible NULL pointer deref in acpi_pm_device_sleep_state()
2013-06-29Merge branch 'acpi-hotplug'Rafael J. Wysocki
* acpi-hotplug: ACPI / processor: Drop unused variable from processor_perflib.c ACPI / processor: Remove unused macros in processor_driver.c
2013-06-28acpi: Eliminate console msg if pstore.backend excludes ERSTLenny Szubowicz
This is patch 2/3 of a patch set that avoids what misleadingly appears to be a error during boot: ERST: Could not register with persistent store This message is displayed if the system has a valid ACPI ERST table and the pstore.backend kernel parameter has been used to disable use of ERST by pstore. But this same message is used for errors that preclude registration. In erst_init don't complain if the setting of kernel parameter pstore.backend precludes use of ACPI ERST for pstore. Routine pstore_register will inform about the facility that does register. Also, don't leave a dangling pointer to deallocated mem for the pstore buffer when registration fails. Signed-off-by: Lenny Szubowicz <lszubowi@redhat.com> Reported-by: Naotaka Hamaguchi <n.hamaguchi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-06-28Merge branch 'pm-assorted'Rafael J. Wysocki
* pm-assorted: PM / QoS: Add pm_qos and dev_pm_qos to events-power.txt PM / QoS: Add dev_pm_qos_request tracepoints PM / QoS: Add pm_qos_request tracepoints PM / QoS: Add pm_qos_update_target/flags tracepoints PM / QoS: Update Documentation/power/pm_qos_interface.txt PM / Sleep: Print last wakeup source on failed wakeup_count write PM / QoS: correct the valid range of pm_qos_class PM / wakeup: Adjust messaging for wake events during suspend PM / Runtime: Update .runtime_idle() callback documentation PM / Runtime: Rework the "runtime idle" helper routine PM / Hibernate: print physical addresses consistently with other parts of kernel
2013-06-28Merge branch 'acpi-assorted'Rafael J. Wysocki
* acpi-assorted: ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scan ACPI: Add CMOS RTC Operation Region handler support ACPI: Remove unused flags in acpi_device_flags ACPI: Remove useless initializers ACPI / battery: Make sure all spaces are in correct places ACPI: add _STA evaluation at do_acpi_find_child() ACPI / EC: access user space with get_user()/put_user()
2013-06-28Merge branch 'acpi-lpss'Rafael J. Wysocki
* acpi-lpss: ACPI / LPSS: override SDIO private register space size from ACPI tables ACPI / LPSS: mask the UART TX completion interrupt ACPI / LPSS: add support for Intel BayTrail Conflicts: drivers/acpi/acpi_lpss.c (with commit b9e95fc)
2013-06-28Merge branch 'acpi-pm'Rafael J. Wysocki
* acpi-pm: ACPI / PM: Rework and clean up acpi_dev_pm_get_state() ACPI / PM: Replace ACPI_STATE_D3 with ACPI_STATE_D3_COLD in device_pm.c ACPI / PM: Rename function acpi_device_power_state() and make it static ACPI / PM: acpi_processor_suspend() can be static xen / ACPI / sleep: Register an acpi_suspend_lowlevel callback. x86 / ACPI / sleep: Provide registration for acpi_suspend_lowlevel.
2013-06-28Merge branch 'acpi-scan'Rafael J. Wysocki
* acpi-scan: ACPI / scan: Do not bind ACPI drivers to objects with scan handlers ACPI / ia64 / sba_iommu: Use ACPI scan handler for device discovery ACPI / scan: Simplify ACPI driver probing
2013-06-28Merge branch 'acpica'Rafael J. Wysocki
* acpica: (21 commits) ACPICA: Update version to 20130517 ACPICA: _CST repair: Handle null package entries ACPICA: Add several repairs for _CST predefined name ACPICA: Move _PRT repair into the standard complex repair module ACPICA: Clear events initialized flag upon event component termination ACPICA: Fix possible memory leak in GPE init error path ACPICA: ACPICA Termination: Delete global lock pending lock ACPICA: Update interface to acpi_ut_valid_acpi_name() ACPICA: Do not use extended sleep registers unless HW-reduced bit is set ACPICA: Split table print utilities to a new a separate file ACPICA: Add option to disable loading of SSDTs from the RSDT/XSDT ACPICA: Standardize all switch() blocks ACPICA: Split internal error msg routines to a separate file ACPICA: Split buffer dump routines into separate file ACPICA: Update version to 20130418 ACPICA: Update for "orphan" embedded controller _REG method support ACPICA: Remove unused macros, no functional change ACPICA: Predefined name support: Remove unused local variable ACPICA: Add argument typechecking for all predefined ACPI names ACPICA: Add BIOS error interface for predefined name validation support ...
2013-06-28Merge branch 'acpi-hotplug'Rafael J. Wysocki
* acpi-hotplug: ACPI: Do not use CONFIG_ACPI_HOTPLUG_MEMORY_MODULE ACPI / cpufreq: Add ACPI processor device IDs to acpi-cpufreq Memory hotplug: Move alternative function definitions to header ACPI / processor: Fix potential NULL pointer dereference in acpi_processor_add() Memory hotplug / ACPI: Simplify memory removal ACPI / scan: Add second pass of companion offlining to hot-remove code Driver core / MM: Drop offline_memory_block() ACPI / processor: Pass processor object handle to acpi_bind_one() ACPI: Drop removal_type field from struct acpi_device Driver core / memory: Simplify __memory_block_change_state() ACPI / processor: Initialize per_cpu(processors, pr->id) properly CPU: Fix sysfs cpu/online of offlined CPUs Driver core: Introduce offline/online callbacks for memory blocks ACPI / memhotplug: Bind removable memory blocks to ACPI device nodes ACPI / processor: Use common hotplug infrastructure ACPI / hotplug: Use device offline/online for graceful hot-removal Driver core: Use generic offline/online for CPU offline/online Driver core: Add offline/online device operations
2013-06-28ACPI / PM: Fix possible NULL pointer deref in acpi_pm_device_sleep_state()Rafael J. Wysocki
After commit fa1675b (ACPI / PM: Rework and clean up acpi_dev_pm_get_state()) a NULL pointer dereference will take place if NULL is passed to acpi_pm_device_sleep_state() as the second argument. Fix that by avoiding to use the pointer that may be NULL until it's necessary to store a return value at the location pointed to by it (if not NULL). Reported-and-tested-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-27ACPI: implement acpi_os_get_timer() according the specMika Westerberg
ACPI Timer() opcode should return monotonically increasing clock with 100ns granularity according the ACPI 5.0 spec. Testing the current Timer() implementation with following ASL code (and an additional debug print in acpi_os_sleep() to get the sleep times dumped out to dmesg): // Test: 10ms Store(Timer, Local1) Sleep(10) Divide(Subtract(Timer, Local1), 10000,, Local1) Sleep(Local1) // Test: 200ms Store(Timer, Local1) Sleep(200) Divide(Subtract(Timer, Local1), 10000,, Local1) Sleep(Local1) // Test 1300ms Store(Timer, Local1) Sleep(1300) Divide(Subtract(Timer, Local1), 10000,, Local1) Sleep(Local1) The second sleep value is calculated using Timer(). If the implementation is good enough we should be able to get the second value pretty close to the first. However, the current Timer() gives pretty bad sleep times: [ 11.488100] ACPI: acpi_os_get_timer() TBD [ 11.492150] ACPI: Sleep(10) [ 11.502993] ACPI: Sleep(0) [ 11.506315] ACPI: Sleep(200) [ 11.706237] ACPI: Sleep(0) [ 11.709550] ACPI: Sleep(1300) [ 13.008929] ACPI: Sleep(0) Fix this with the help of ktime_get(). Once the fix is applied and run against the same ASL code we get: [ 11.486786] ACPI: Sleep(10) [ 11.499029] ACPI: Sleep(12) [ 11.512350] ACPI: Sleep(200) [ 11.712282] ACPI: Sleep(200) [ 11.912170] ACPI: Sleep(1300) [ 13.211577] ACPI: Sleep(1300) That is much more closer to the values we expected. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-27ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scanLan Tianyu
HP Folio 13's BIOS defines CMOS RTC Operation Region and the EC's _REG method will access that region. To allow the CMOS RTC region handler to be installed before the EC _REG method is first invoked, add ec_skip_dsdt_scan() as HP Folio 13's callback to ec_dmi_table. References: https://bugzilla.kernel.org/show_bug.cgi?id=54621 Reported-and-tested-by: Stefan Nagy <public@stefan-nagy.at> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Cc: 3.9+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-27ACPI: Add CMOS RTC Operation Region handler supportLan Tianyu
On HP Folio 13-2000, the BIOS defines a CMOS RTC Operation Region and the EC's _REG methord accesses that region. Thus an appropriate address space handler must be registered for that region before the EC driver is loaded. Introduce a mechanism for adding CMOS RTC address space handlers. Register an ACPI scan handler for CMOS RTC devices such that, when a device of that kind is detected during an ACPI namespace scan, a common CMOS RTC operation region address space handler will be installed for it. References: https://bugzilla.kernel.org/show_bug.cgi?id=54621 Reported-and-tested-by: Stefan Nagy <public@stefan-nagy.at> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Cc: 3.9+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-26Merge tag 'please-pull-mce-bitmap-comment' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras into x86/ras Pull MCE updates from Tony Luck: "Better comments so we understand our existing machine check bank bitmaps - prelude to adding another bitmap soon." Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-25ACPI / processor: Drop unused variable from processor_perflib.cLan Tianyu
The count variable in acpi_processor_preregister_performance() is only initalized as 1 for one CPU and incremented when another CPU sharing the same dependency domain is found. It isn't referenced anywhere else, so drop it. Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-24ACPI / processor: Remove unused macros in processor_driver.cHanjun Guo
ACPI_PROCESSOR_FILE_INFO, ACPI_PROCESSOR_FILE_THROTTLING and ACPI_PROCESSOR_FILE_LIMIT are used for procfs, but this feature was removed in commit d09fe555 (ACPI processor: remove deprecated ACPI procfs I/F) long ago. So, these macros should also be removed. ACPI_PROCESSOR_LIMIT_USER and ACPI_PROCESSOR_LIMIT_THERMAL are not used by any code, remove them too. Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-24ACPI / dock / PCI: Synchronous handling of dock events for PCI devicesRafael J. Wysocki
The interactions between the ACPI dock driver and the ACPI-based PCI hotplug (acpiphp) are currently problematic because of ordering issues during hot-remove operations. First of all, the current ACPI glue code expects that physical devices will always be deleted before deleting the companion ACPI device objects. Otherwise, acpi_unbind_one() will fail with a warning message printed to the kernel log, for example: [ 185.026073] usb usb5: Oops, 'acpi_handle' corrupt [ 185.035150] pci 0000:1b:00.0: Oops, 'acpi_handle' corrupt [ 185.035515] pci 0000:18:02.0: Oops, 'acpi_handle' corrupt [ 180.013656] port1: Oops, 'acpi_handle' corrupt This means, in particular, that struct pci_dev objects have to be deleted before the struct acpi_device objects they are "glued" with. Now, the following happens the during the undocking of an ACPI-based dock station: 1) hotplug_dock_devices() invokes registered hotplug callbacks to destroy physical devices associated with the ACPI device objects depending on the dock station. It calls dd->ops->handler() for each of those device objects. 2) For PCI devices dd->ops->handler() points to handle_hotplug_event_func() that queues up a separate work item to execute _handle_hotplug_event_func() for the given device and returns immediately. That work item will be executed later. 3) hotplug_dock_devices() calls dock_remove_acpi_device() for each device depending on the dock station. This runs acpi_bus_trim() for each of them, which causes the underlying ACPI device object to be destroyed, but the work items queued up by handle_hotplug_event_func() haven't been started yet. 4) _handle_hotplug_event_func() queued up in step 2) are executed and cause the above failure to happen, because the PCI devices they handle do not have the companion ACPI device objects any more (those objects have been deleted in step 3). The possible breakage doesn't end here, though, because hotplug_dock_devices() may return before at least some of the _handle_hotplug_event_func() work items spawned by it have a chance to complete and then undock() will cause _DCK to be evaluated and that will cause the devices handled by the _handle_hotplug_event_func() to go away possibly while they are being accessed. This means that dd->ops->handler() for PCI devices should not point to handle_hotplug_event_func(). Instead, it should point to a function that will do the work of _handle_hotplug_event_func() synchronously. For this reason, introduce such a function, hotplug_event_func(), and modity acpiphp_dock_ops to point to it as the handler. Unfortunately, however, this is not sufficient, because if the dock code were not changed further, hotplug_event_func() would now deadlock with hotplug_dock_devices() that called it, since it would run unregister_hotplug_dock_device() which in turn would attempt to acquire the dock station's hp_lock mutex already acquired by hotplug_dock_devices(). To resolve that deadlock use the observation that unregister_hotplug_dock_device() won't need to acquire hp_lock if PCI bridges the devices on the dock station depend on are prevented from being removed prematurely while the first loop in hotplug_dock_devices() is in progress. To make that possible, introduce a mechanism by which the callers of register_hotplug_dock_device() can provide "init" and "release" routines that will be executed, respectively, during the addition and removal of the physical device object associated with the given ACPI device handle. Make acpiphp use two new functions, acpiphp_dock_init() and acpiphp_dock_release(), that call get_bridge() and put_bridge(), respectively, on the acpiphp bridge holding the given device, for this purpose. In addition to that, remove the dock station's list of "hotplug devices" and make the dock code always walk the whole list of "dependent devices" instead in such a way that the loops in hotplug_dock_devices() and dock_event() (replacing the loops over "hotplug devices") will take references to the list entries that register_hotplug_dock_device() has been called for. That prevents the "release" routines associated with those entries from being called while the given entry is being processed and for PCI devices this means that their bridges won't be removed (by a concurrent thread) while hotplug_event_func() handling them is being executed. This change is based on two earlier patches from Jiang Liu. References: https://bugzilla.kernel.org/show_bug.cgi?id=59501 Reported-and-tested-by: Alexander E. Patrakov <patrakov@gmail.com> Tracked-down-by: Jiang Liu <jiang.liu@huawei.com> Tested-by: Illya Klymov <xanf@xanf.me> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: 3.9+ <stable@vger.kernel.org>
2013-06-23ACPI / dock: Initialize ACPI dock subsystem upfrontJiang Liu
Commit 3b63aaa70e1 (PCI: acpiphp: Do not use ACPI PCI subdriver mechanism) introduced an ACPI dock support regression, because it changed the relative initialization order of the ACPI dock subsystem and the ACPI-based PCI hotplug (acpiphp). Namely, the ACPI dock subsystem has to be initialized before acpiphp_enumerate_slots() is first run, which after commit 3b63aaa70e1 happens during the initial enumeration of the PCI hierarchy triggered by the initial ACPI namespace scan in acpi_scan_init(). For this reason, the dock subsystem has to be initialized before the initial ACPI namespace scan in acpi_scan_init(). To make that happen, modify the ACPI dock subsystem to be non-modular and add the invocation of its initialization routine, acpi_dock_init(), to acpi_scan_init() directly before the initial namespace scan. [rjw: Changelog, removal of dock_exit().] References: https://bugzilla.kernel.org/show_bug.cgi?id=59501 Reported-and-tested-by: Alexander E. Patrakov <patrakov@gmail.com> Tested-by: Illya Klymov <xanf@xanf.me> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: 3.9+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-20ACPICA: _CST repair: Handle null package entriesLv Zheng
Sort package only after null/bad elements have been removed. Fixes a problem where the _CST sort was performed too early. This change sorts the package only after null/bad elements have been removed. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-20ACPICA: Add several repairs for _CST predefined nameLv Zheng
Sort list based on the C-state, remove invalid/zero entries. ACPICA BZ 890. Lv Zheng. Fixes these possible problems with the _CST object: 1. Sort the list ascending by C state type. 2. Ensure type cannot be zero. 3. A sub-package count of zero means _CST is meaningless. 4. Count must match the number of C state sub-packages. References: https://bugs.acpica.org/show_bug.cgi?id=890 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-20ACPICA: Move _PRT repair into the standard complex repair moduleLv Zheng
Moved this longstanding repair to the relatively new predefined name repair module. ACPICA BZ 783. Lv Zheng. No functional change. This change simply moves the repair code from where it was originally implemented to the (more recent) repair module where it now belongs. References: https://bugs.acpica.org/show_bug.cgi?id=783 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
