path: root/drivers/acpi
2014-06-30ACPI: Fix conflict between customized DSDT and DSDT local copyLv Zheng
commit 73577d1df8e1f31f6b1a5eebcdbc334eb0330e47 upstream. This patch fixes the following issue: If DSDT is customized, no local DSDT copy is needed. References: https://bugzilla.kernel.org/show_bug.cgi?id=69711 Signed-off-by: Enrico Etxe Arte <goitizena.generoa@gmail.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> [rjw: Subject] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30ACPICA: utstring: Check array index bound before use.David Binderman
commit 5d42b0fa25df7ef2f575107597c1aaebe2407d10 upstream. ACPICA BZ 1077. David Binderman. References: https://bugs.acpica.org/show_bug.cgi?id=1077 Signed-off-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30ACPI: add dynamic_debug supportBjørn Mork
commit 45fef5b88d1f2f47ecdefae6354372d440ca5c84 upstream. Commit 1a699476e258 ("ACPI / hotplug / PCI: Hotplug notifications from acpi_bus_notify()") added debug messages for a few common events. These debug messages are unconditionally enabled if CONFIG_DYNAMIC_DEBUG is defined, contrary to the documented meaning, making the ACPI system spew lots of unwanted noise on any kernel with dynamic debugging. The bug was introduced by commit fbfddae69657 ("ACPI: Add acpi_handle_<level>() interfaces"), which added the CONFIG_DYNAMIC_DEBUG dependency without respecting its meaning. Fix by adding real support for dynamic_debug. Fixes: fbfddae69657 ("ACPI: Add acpi_handle_<level>() interfaces") Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI / video: Revert native brightness quirk for ThinkPad T530Hans de Goede
commit 07d1d29ee1e194b932328ad2dc1d40297062ab7f upstream. Seems it helps some users, but causes issues for other users: https://bugzilla.redhat.com/show_bug.cgi?id=1089545 So lets drop it for now until we've figured out a better fix. Fixes: 43d949024425 (ACPI / video: Add use_native_backlight quirks for more systems) References: https://bugzilla.redhat.com/show_bug.cgi?id=1089545 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI / video: correct DMI tag for Dell Inspiron 7520Aaron Lu
commit 5ff365fb6aed4c7ee5aae7b0239ce0b514aefabc upstream. The DMI tag used to identify Dell Inspiron 7520 should be product name instead of product version. Fixes: 0e9f81d3b7cd (ACPI / video: Add systems that should favour native backlight interface) Reported-and-tested-by: Téo Mazars <teomazars@gmail.com> References: https://bugzilla.redhat.com/show_bug.cgi?id=909552 Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI: blacklist win8 OSI for Dell Inspiron 7737Edward Lin
commit b753631b3576bf343151a82513c5d56fcda1e24f upstream. With win8 capabiltiy, the machine will boot itself immediately after shutdown command has executed. Work around this issue by disabling win8 capcability. This workaround also makes wireless hotkey work. Signed-off-by: Edward Lin <yidi.lin@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI: Revert "ACPI / AC: convert ACPI ac driver to platform bus"Guenter Roeck
commit 98012849e0cbf980326f8e34d571f4474866a88e upstream. Revert commit cc8ef5270734 (ACPI / AC: convert ACPI ac driver to platform bus) that is reported to break thermal management on MacBook Air 2013 with ArchLinux. Fixes: cc8ef5270734 (ACPI / AC: convert ACPI ac driver to platform bus) References: https://bugzilla.kernel.org/show_bug.cgi?id=71711 Cc: Zhang Rui <rui.zhang@intel.com> Reported-and-tested-by: Manuel Krause <manuelkrause@netscape.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI / processor: do not mark present at boot but not onlined CPU as onlinedIgor Mammedov
commit 0b9d46dd7debf8e6dc8614106f1c1909fa8de64d upstream. acpi_processor_add() assumes that present at boot CPUs are always onlined, it is not so if a CPU failed to become onlined. As result acpi_processor_add() will mark such CPU device as onlined in sysfs and following attempts to online/offline it using /sys/device/system/cpu/cpuX/online attribute will fail. Do not poke into device internals in acpi_processor_add() and touch "struct device { .offline }" attribute, since for CPUs onlined at boot it's set by: topology_init() -> arch_register_cpu() -> register_cpu() before ACPI device tree is parsed, and for hotplugged CPUs it's set when userspace onlines CPU via sysfs. Signed-off-by: Igor Mammedov <imammedo@redhat.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI / blacklist: Add dmi_enable_osi_linux quirk for Asus EEE PC 1015PXHans de Goede
commit f6e6e1b9fee88c90586787b71dc49bb3ce62bb89 upstream. Without this this EEE PC exports a non working WMI interface, with this it exports a working "good old" eeepc_laptop interface, fixing brightness control not working as well as rfkill being stuck in a permanent wireless blocked state. This is not an ideal way to fix this, but various attempts to fix this otherwise have failed, see: References: https://bugzilla.redhat.com/show_bug.cgi?id=1067181 Reported-and-tested-by: lou.cardone@gmail.com Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI / video: Add use_native_backlight quirks for more systemsHans de Goede
commit 43d9490244254d2d6adb0f3c6275c7b8d032a2dd upstream. ThinkPad T430: extend the T430s entry to also cover the T430 (note we also have another entry for T430's with a different DMI_PRODUCT_VERSION). ThinkPad T430 Reported-and-tested-by: edm <fuffi.il.fuffo@gmail.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=51231 Thinkpad T530 Reported-and-tested-by: Balint Szigeti <balint.szgt@gmail.com> References: https://bugzilla.redhat.com/show_bug.cgi?id=1089545 Acer Aspire 5742G Reported-and-tested-by: AnAkkk <anakin.cs@gmail.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=35622 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI: Revert "ACPI / Battery: Remove battery's proc directory"Lan Tianyu
commit 3a670cc79342c36d308decd5f90351830ed1685c upstream. The commit 1e2d9cd and 7d7ee95 remove ACPI Proc Battery directory and breaks some old userspace tools. This patch is to revert commit 1e2d9cd. Fixes: 1e2d9cdfb449 (ACPI / Battery: Remove battery's proc directory) Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI: Revert "ACPI: Remove CONFIG_ACPI_PROCFS_POWER and cm_sbsc.c"Lan Tianyu
commit e2a7c3d7812369daae56f069eab2e8f3e548d231 upstream. The commit 1e2d9cd and 7d7ee95 remove ACPI Proc Battery directory and breaks some old userspace tools. This patch is to revert 7d7ee95. Fixes: 7d7ee958867a (ACPI: Remove CONFIG_ACPI_PROCFS_POWER and cm_sbsc.c) Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPICA: Tables: Restore old behavor to favor 32-bit FADT addresses.Lv Zheng
commit 85dbd5801f62b66e2aa7826aaefcaebead44c8a6 upstream. We need to find a smarter way to switch to 64-bit FADT addresses according to the bug report. This patch reverts Linux to the original behavior. Fixes: 0249ed2444d6 (ACPICA: Add option to favor 32-bit FADT addresses.) References: https://bugzilla.kernel.org/show_bug.cgi?id=74021 Reported-and-tested-by: Oswald Buddenhagen <ossi@kde.org> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPICA: Tables: Fix invalid pointer accesses in acpi_tb_parse_root_table().Lv Zheng
commit d48dc067450d84324067f4472dc0b169e9af4454 upstream. Linux XSDT validation mechanism backport has introduced a regreession: Commit: 671cc68dc61f029d44b43a681356078e02d8dab8 Subject: ACPICA: Back port and refine validation of the XSDT root table. There is a pointer still accessed after unmapping. This patch fixes this issue. Lv Zheng. Fixes: 671cc68dc61f (ACPICA: Back port and refine validation of the XSDT root table.) References: https://bugzilla.kernel.org/show_bug.cgi?id=73911 References: https://bugs.archlinux.org/task/39811 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Reported-and-tested-by: Bruce Chiarelli <mano155@gmail.com> Reported-and-tested-by: Spyros Stathopoulos <spystath@gmail.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ACPI / EC: Process rather than discard events in acpi_ec_clearKieran Clancy
commit 3eba563e280101209bad27d40bfc83ddf1489234 upstream. Address a regression caused by commit ad332c8a4533: (ACPI / EC: Clear stale EC events on Samsung systems) After the earlier patch, there was found to be a race condition on some earlier Samsung systems (N150/N210/N220). The function acpi_ec_clear was sometimes discarding a new EC event before its GPE was triggered by the system. In the case of these systems, this meant that the "lid open" event was not registered on resume if that was the cause of the wake, leading to problems when attempting to close the lid to suspend again. After testing on a number of Samsung systems, both those affected by the previous EC bug and those affected by the race condition, it seemed that the best course of action was to process rather than discard the events. On Samsung systems which accumulate stale EC events, there does not seem to be any adverse side-effects of running the associated _Q methods. This patch adds an argument to the static function acpi_ec_sync_query so that it may be used within the acpi_ec_clear loop in place of acpi_ec_query_unlocked which was used previously. With thanks to Stefan Biereigel for reporting the issue, and for all the people who helped test the new patch on affected systems. Fixes: ad332c8a4533 (ACPI / EC: Clear stale EC events on Samsung systems) References: https://lkml.kernel.org/r/532FE3B2.9060808@biereigel-wb.de References: https://bugzilla.kernel.org/show_bug.cgi?id=44161#c173 Reported-by: Stefan Biereigel <stefan@biereigel.de> Signed-off-by: Kieran Clancy <clancy.kieran@gmail.com> Tested-by: Stefan Biereigel <stefan@biereigel.de> Tested-by: Dennis Jansen <dennis.jansen@web.de> Tested-by: Nicolas Porcel <nicolasporcel06@gmail.com> Tested-by: Maurizio D'Addona <mauritiusdadd@gmail.com> Tested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com> Tested-by: Giannis Koutsou <giannis.koutsou@gmail.com> Tested-by: Kieran Clancy <clancy.kieran@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13ACPI / processor: Fix failure of loading acpi-cpufreq driverLan Tianyu
commit 4985c32ee4241d1aba1beeac72294faa46aaff10 upstream. According commit d640113fe (ACPI: processor: fix acpi_get_cpuid for UP processor), BIOS may not provide _MAT or MADT tables and acpi_get_apicid() always returns -1. For these cases, original code will pass apic_id with vaule of -1 to acpi_map_cpuid() and it will check the acpi_id. If acpi_id is equal to zero, ignores apic_id and return zero for CPU0. Commit b981513 (ACPI / scan: bail out early if failed to parse APIC ID for CPU) changed the behavior. Return ENODEV when find apic_id is less than zero after calling acpi_get_apicid(). This causes acpi-cpufreq driver fails to be loaded on some machines. This patch is to fix it. Fixes: b981513f806d (ACPI / scan: bail out early if failed to parse APIC ID for CPU) References: https://bugzilla.kernel.org/show_bug.cgi?id=73781 Reported-and-tested-by: KATO Hiroshi <katoh@mikage.ne.jp> Reported-and-tested-by: Stuart Foster <smf.linux@ntlworld.com> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06ACPICA: Restore code that repairs NULL package elements in return values.Lv Zheng
commit 61db45ca21630f5ab7f678d54c5d969c21647854 upstream. The original code was lost accidently, it was not generated along with the following commit of mechanism improvements and thus not get merged: Commit: d5a36100f62fa6db5541344e08b361b34e9114c5 Subject: ACPICA: Add mechanism for early object repairs on a per-name basis Adds the framework to allow object repairs very early in the return object analysis. Enables repairs like string->unicode, etc. This patch restores the implementation of the NULL element repair code for ACPI_RTYPE_NONE. In the original design, ACPI_RTYPE_NONE is defined to collect simple NULL object repairs. Lv Zheng. Buglink: https://bugzilla.kernel.org/show_bug.cgi?id=67901 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26ACPI / button: Add ACPI Button event via netlink routineLan Tianyu
commit 0bf6368ee8f25826d0645c0f7a4f17c8845356a4 upstream. Commit 1696d9d (ACPI: Remove the old /proc/acpi/event interface) removed ACPI Button event which originally was sent to userspace via /proc/acpi/event. This caused ACPI shutdown regression on gentoo in VirtualBox. Now ACPI events are sent to userspace via netlink, so add ACPI Button event back via netlink routine. References: https://bugzilla.kernel.org/show_bug.cgi?id=71721 Reported-and-tested-by: Richard Musil <richard.musil@gmail.com> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-13ACPI / sleep: Add extra checks for HW Reduced ACPI mode sleep statesRafael J. Wysocki
If the HW Reduced ACPI mode bit is set in the FADT, ACPICA uses the optional sleep control and sleep status registers for making the system enter sleep states (including S5), so it is not possible to use system sleep states or power it off using ACPI if the HW Reduced ACPI mode bit is set and those registers are not available. For this reason, add a new function, acpi_sleep_state_supported(), checking if the HW Reduced ACPI mode bit is set and whether or not system sleep states are usable in that case in addition to checking the return value of acpi_get_sleep_type_data() and make the ACPI sleep setup routines use that function to check the availability of system sleep states. Among other things, this prevents the kernel from attempting to use ACPI for powering off HW Reduced ACPI systems without the sleep control and sleep status registers, because ACPI power off doesn't have a chance to work on them. That allows alternative power off mechanisms that may actually work to be used on those systems. The affected machines include Dell Venue 8 Pro, Asus T100TA, Haswell Desktop SDP and Ivy Bridge EP Demo depot. References: https://bugzilla.kernel.org/show_bug.cgi?id=70931 Reported-by: Adam Williamson <awilliam@redhat.com> Tested-by: Aubrey Li <aubrey.li@linux.intel.com> Cc: 3.4+ <stable@vger.kernel.org> # 3.4+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-09Revert "ACPI / sleep: pm_power_off needs more sanity checks to be installed"Rafael J. Wysocki
Revert commit 3130497f5bab ("ACPI / sleep: pm_power_off needs more sanity checks to be installed") that breaks power ACPI power off on a lot of systems, because it checks wrong registers. Fixes: 3130497f5bab ("ACPI / sleep: pm_power_off needs more sanity checks to be installed") Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-08Merge branches 'acpi-resources', 'acpi-ec' and 'acpi-sleep'Rafael J. Wysocki
* acpi-resources: ACPI / resources: ignore invalid ACPI device resources * acpi-ec: ACPI / EC: Clear stale EC events on Samsung systems * acpi-sleep: ACPI / sleep: pm_power_off needs more sanity checks to be installed
2014-03-06ACPI / EC: Clear stale EC events on Samsung systemsKieran Clancy
A number of Samsung notebooks (530Uxx/535Uxx/540Uxx/550Pxx/900Xxx/etc) continue to log events during sleep (lid open/close, AC plug/unplug, battery level change), which accumulate in the EC until a buffer fills. After the buffer is full (tests suggest it holds 8 events), GPEs stop being triggered for new events. This state persists on wake or even on power cycle, and prevents new events from being registered until the EC is manually polled. This is the root cause of a number of bugs, including AC not being detected properly, lid close not triggering suspend, and low ambient light not triggering the keyboard backlight. The bug also seemed to be responsible for performance issues on at least one user's machine. Juan Manuel Cabo found the cause of bug and the workaround of polling the EC manually on wake. The loop which clears the stale events is based on an earlier patch by Lan Tianyu (see referenced attachment). This patch: - Adds a function acpi_ec_clear() which polls the EC for stale _Q events at most ACPI_EC_CLEAR_MAX (currently 100) times. A warning is logged if this limit is reached. - Adds a flag EC_FLAGS_CLEAR_ON_RESUME which is set to 1 if the DMI system vendor is Samsung. This check could be replaced by several more specific DMI vendor/product pairs, but it's likely that the bug affects more Samsung products than just the five series mentioned above. Further, it should not be harmful to run acpi_ec_clear() on systems without the bug; it will return immediately after finding no data waiting. - Runs acpi_ec_clear() on initialisation (boot), from acpi_ec_add() - Runs acpi_ec_clear() on wake, from acpi_ec_unblock_transactions() References: https://bugzilla.kernel.org/show_bug.cgi?id=44161 References: https://bugzilla.kernel.org/show_bug.cgi?id=45461 References: https://bugzilla.kernel.org/show_bug.cgi?id=57271 References: https://bugzilla.kernel.org/attachment.cgi?id=126801 Suggested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com> Signed-off-by: Kieran Clancy <clancy.kieran@gmail.com> Reviewed-by: Lan Tianyu <tianyu.lan@intel.com> Reviewed-by: Dennis Jansen <dennis.jansen@web.de> Tested-by: Kieran Clancy <clancy.kieran@gmail.com> Tested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com> Tested-by: Dennis Jansen <dennis.jansen@web.de> Tested-by: Maurizio D'Addona <mauritiusdadd@gmail.com> Tested-by: San Zamoyski <san@plusnet.pl> Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-03ACPI / sleep: pm_power_off needs more sanity checks to be installedLi, Aubrey
Sleep control and status registers need santity checks as well before ACPI installs acpi_power_off to pm_power_off hook. The checking code in acpi_enter_sleep_state() is too late, we should not allow a not-working pm_power_off function to be hooked up. Signed-off-by: Aubrey Li <aubrey.li@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-01ACPI / resources: ignore invalid ACPI device resourcesZhang Rui
ACPI table may export resource entry with 0 length. But the current code interprets this kind of resource in a wrong way. It will create a resource structure with res->end = acpi_resource->start + acpi_resource->len - 1; This patch fixes a problem on my machine that a platform device fails to be created because one of its ACPI IO resource entry (start = 0, end = 0, length = 0) is translated into a generic resource with start = 0, end = 0xffffffff. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-27ACPI / processor: Rework processor throttling with work_on_cpu()Lan Tianyu
acpi_processor_set_throttling() uses set_cpus_allowed_ptr() to make sure that the (struct acpi_processor)->acpi_processor_set_throttling() callback will run on the right CPU. However, the function may be called from a worker thread already bound to a different CPU in which case that won't work. Make acpi_processor_set_throttling() use work_on_cpu() as appropriate instead of abusing set_cpus_allowed_ptr(). Reported-and-tested-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Cc: All applicable <stable@vger.kernel.org> [rjw: Changelog] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-21Merge branches 'acpi-pm' and 'acpi-video'Rafael J. Wysocki
* acpi-pm: ACPI / thermal: fix thermal driver compile error when CONFIG_PM_SLEEP is undefined ACPI / SBS: fix SBS driver compile error when CONFIG_PM_SLEEP is undefined ACPI / fan: fix fan driver compile error when CONFIG_PM_SLEEP is undefined ACPI / button: fix button driver compile error when CONFIG_PM_SLEEP is undefined ACPI / battery: fix battery driver compile error when CONFIG_PM_SLEEP is undefined ACPI / AC: fix AC driver compile error when CONFIG_PM_SLEEP is undefined * acpi-video: Revert "ACPI: Blacklist Win8 OSI for some HP laptop 2013 models" ACPI / video: Add systems that should favour native backlight interface ACPI / video: Filter the _BCL table for duplicate brightness values
2014-02-21Merge branches 'acpi-cleanup', 'acpi-dock', 'acpi-pci' and 'acpi-dsm'Rafael J. Wysocki
* acpi-cleanup: ACPI / SBS: Fix incorrect sscanf() string * acpi-dock: ACPI / dock: Make 'docked' sysfs attribute work as documented * acpi-pci: ACPI / PCI: Fix memory leak in acpi_pci_irq_enable() * acpi-dsm: ACPI / nouveau: fix probing regression related to _DSM
2014-02-20Revert "ACPI: Blacklist Win8 OSI for some HP laptop 2013 models"Rafael J. Wysocki
This reverts commit 2d4054d84224 (ACPI: Blacklist Win8 OSI for some HP laptop 2013 models) that is not necessary any more after previous commit 1811fcb029fa (ACPI / video: Add systems that should favour native backlight interface). Requested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-20ACPI / video: Add systems that should favour native backlight interfaceAaron Lu
Some system's ACPI video backlight control interface is broken and the native backlight control interface should be used by default. This patch sets the use_native_backlight parameter to true for those systems so that video backlight control interface will not be created. For detailed models that are added here, reference the following list. Note that the user specified kernel cmdline option will always have the highest priority, i.e. if use_native_backlight=0 is specified and the system is in the DMI table, the video module will not skip registering backlight interface for it. Thinkpad T430s: Reported-by: Theodore Tso <tytso@mit.edu> Reported-and-tested-by: Peter Weber <bugs@ttyhoney.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=51231 Thinkpad X230: Reported-and-tested-by: Igor Gnatenko <i.gnatenko.brain@gmail.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=51231 ThinkPad X1 Carbon: Reported-and-tested-by: Igor Gnatenko <i.gnatenko.brain@gmail.com> Lenovo Yoga 13: Reported-by: Lennart Poettering <lennart@poettering.net> Reported-and-tested-by: Kevin Smith <thirdwiggin@gmail.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=63811 Dell Inspiron 7520: Reported-by: Rinat Ibragimov <ibragimovrinat@mail.ru> Acer Aspire 5733Z: Reported-by: <sov.info@mail.ru> References: https://bugzilla.kernel.org/show_bug.cgi?id=62941 Acer Aspire V5-431: Reported-by: Thomas Christensen <christensenthomas@gmail.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=68751 HP ProBook 4340s: Reported-and-tested-by: Vladimir Sherenkov <a_12300@mail.ru> References: http://redmine.russianfedora.pro/issues/1258 HP EliteBook/ProBook 2013 models, ZBook and some others: Provided-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-20ACPI / video: Filter the _BCL table for duplicate brightness valuesHans de Goede
Some devices have duplicate entries in there brightness levels table, ie on my Dell Latitude E6430 the table looks like this: [ 3.686060] acpi backlight index 0, val 80 [ 3.686095] acpi backlight index 1, val 50 [ 3.686122] acpi backlight index 2, val 5 [ 3.686147] acpi backlight index 3, val 5 [ 3.686172] acpi backlight index 4, val 5 [ 3.686197] acpi backlight index 5, val 5 [ 3.686223] acpi backlight index 6, val 5 [ 3.686248] acpi backlight index 7, val 5 [ 3.686273] acpi backlight index 8, val 6 [ 3.686332] acpi backlight index 9, val 7 [ 3.686356] acpi backlight index 10, val 8 [ 3.686380] acpi backlight index 11, val 9 etc. Notice that brightness values 0-5 are all mapped to 5. This means that if userspace writes any value between 0 and 5 to the brightness sysfs attribute and then reads it, it will always return 0, which is somewhat unexpected. This is a problem for ie gnome-settings-daemon, which uses read-modify-write logic when the users presses the brightness up or down keys. This is done this way to take brightness changes from other sources into account. On this specific laptop what happens once the brightness has been set to 0, is that gsd reads 0, adds 5, writes 5, and on the next brightness up key press again reads 0, so things get stuck at the lowest brightness setting. Filtering out the duplicate table entries, makes any write to brightness read back as the written value as one would expect, fixing this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com> Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-18ACPI / PCI: Fix memory leak in acpi_pci_irq_enable()Tomasz Nowicki
acpi_pci_link_allocate_irq() can return negative gsi even if entry != NULL. For that case we have a memory leak, so free entry before returning from acpi_pci_irq_enable() for gsi < 0. Signed-off-by: Tomasz Nowicki <tomasz.nowicki@linaro.org> Cc: All applicable <stable@vger.kernel.org> [rjw: Subject and changelog] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-15ACPI / dock: Make 'docked' sysfs attribute work as documentedRafael J. Wysocki
After recent ACPI core changes acpi_bus_get_device() will always succeed for dock station ACPI device objects, so show_docked() should not use that function's return value as an indicator of whether or not the dock device is present. Make it use acpi_device_enumerated() for this purpose. Fixes: 202317a573b2 (ACPI / scan: Add acpi_device objects for all device nodes in the namespace) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-13ACPI / SBS: Fix incorrect sscanf() stringLuis G.F
Fix incorrect sscanf() string in function acpi_battery_alarm_store(). Signed-off-by: Luis G.F <luisgf@luisgf.es> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-13ACPI / thermal: fix thermal driver compile error when CONFIG_PM_SLEEP is ↵Shuah Khan
undefined The ACPI thermal driver defines acpi_thermal_resume() when CONFIG_PM_SLEEP is defined. This results in the following compile error when CONFIG_PM_SLEEP is undefined. CC drivers/acpi/thermal.o drivers/acpi/thermal.c:107:8: error: ‘acpi_thermal_resume’ undeclared here (not in a function) make[2]: *** [drivers/acpi/thermal.o] Error 1 Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-13ACPI / SBS: fix SBS driver compile error when CONFIG_PM_SLEEP is undefinedShuah Khan
The ACPI SBS driver defines acpi_sbs_resume() when CONFIG_PM_SLEEP is defined. This results in the following compile error when CONFIG_PM_SLEEP is undefined: CC [M] drivers/acpi/sbs.o drivers/acpi/sbs.c:674:8: error: ‘acpi_sbs_resume’ undeclared here (not in a function) Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-13ACPI / fan: fix fan driver compile error when CONFIG_PM_SLEEP is undefinedShuah Khan
The ACPI fan driver defines acpi_fan_suspend() and acpi_fan_resume() when CONFIG_PM_SLEEP is defined. This results in the following compile errors when CONFIG_PM_SLEEP is undefined: drivers/acpi/fan.c:60:8: error: ‘acpi_fan_suspend’ undeclared here (not in a function) drivers/acpi/fan.c:60:8: error: ‘acpi_fan_resume’ undeclared here (not in a function) Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-13ACPI / button: fix button driver compile error when CONFIG_PM_SLEEP is undefinedShuah Khan
The ACPI button driver defines acpi_button_resume() when CONFIG_PM_SLEEP is defined. This results in the following compile error when CONFIG_PM_SLEEP is undefined: drivers/acpi/button.c:85:8: error: ‘acpi_button_resume’ undeclared here (not in a function) Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-13ACPI / battery: fix battery driver compile error when CONFIG_PM_SLEEP is ↵Shuah Khan
undefined The ACPI battery driver defines acpi_battery_resume() when CONFIG_PM_SLEEP is defined. This results in the following compile error when CONFIG_PM_SLEEP is undefined: drivers/acpi/battery.c:847:8: error: ‘acpi_battery_resume’ undeclared here (not in a function) Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-13ACPI / AC: fix AC driver compile error when CONFIG_PM_SLEEP is undefinedShuah Khan
The ACPI AC driver defines acpi_ac_resume() when CONFIG_PM_SLEEP is defined. This results in the following compile error when CONFIG_PM_SLEEP is undefined: drivers/acpi/ac.c:248:8: error: ‘acpi_ac_resume’ undeclared here (not in a function) Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-12Merge branches 'acpi-dock', 'acpi-scan' and 'acpi-pci-hotplug'Rafael J. Wysocki
* acpi-dock: ACPI / dock: Use acpi_device_enumerated() to check if dock is present * acpi-scan: ACPI / container: Fix error code path in container_device_attach() * acpi-pci-hotplug: ACPI / hotplug / PCI: Relax the checking of _STA return values
2014-02-12ACPI / container: Fix error code path in container_device_attach()Rafael J. Wysocki
To avoid leaking memory on errors from device_register(), do a put_device() on the device object in question in the error code path of container_device_attach(). Fixes: caa73ea158de (ACPI / hotplug / driver core: Handle containers in a special way) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
2014-02-10ACPI / dock: Use acpi_device_enumerated() to check if dock is presentRafael J. Wysocki
After commit 202317a573b2 (ACPI / scan: Add acpi_device objects for all device nodes in the namespace) acpi_bus_get_device() will always return 0 for dock devices in dock_notify(), so the dock station docking code under ACPI_NOTIFY_DEVICE_CHECK will never be executed and docking will not work as a result of that. Fix the problem by making dock_notify() use acpi_device_enumerated() to check the presence of the device instead of checking the return value of acpi_bus_get_device(). Fixes: 202317a573b2 (ACPI / scan: Add acpi_device objects for all device nodes in the namespace) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-06Merge branches 'acpi-cleanup' and 'acpi-video'Rafael J. Wysocki
* acpi-cleanup: ACPI / battery: Fix incorrect sscanf() string in acpi_battery_init_alarm() ACPI / proc: remove unneeded NULL check ACPI / utils: remove a pointless NULL check * acpi-video: ACPI / video: Add HP EliteBook Revolve 810 to the blacklist
2014-02-05ACPI / hotplug: Fix panic on eject to ejected deviceToshi Kani
When an eject request is sent to an ejected ACPI device, the following panic occurs: ACPI: \_SB_.SCK3.CPU3: ACPI_NOTIFY_EJECT_REQUEST event BUG: unable to handle kernel NULL pointer dereference at 0000000000000070 IP: [<ffffffff813a7cfe>] acpi_device_hotplug+0x10b/0x33b : Call Trace: [<ffffffff813a24da>] acpi_hotplug_work_fn+0x1c/0x27 [<ffffffff8109cbe5>] process_one_work+0x175/0x430 [<ffffffff8109d7db>] worker_thread+0x11b/0x3a0 This is becase device->handler is NULL in acpi_device_hotplug(). This case was used to fail in acpi_hotplug_notify_cb() as the target had no acpi_deivce. However, acpi_device now exists after ejection. Added a check to verify if acpi_device->handler is valid for an eject request in acpi_hotplug_notify_cb(). Note that handler passed from an argument is still valid while acpi_device->handler is NULL. Fixes: 202317a573b2 (ACPI / scan: Add acpi_device objects for all device nodes in the namespace) Signed-off-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-05ACPI / battery: Fix incorrect sscanf() string in acpi_battery_init_alarm()Luis G.F
Fix incorrect sscanf() string in acpi_battery_init_alarm(). Change from %ld to %lu, because 'x' is unsigned long. Signed-off-by: Luis G.F <luisgf@luisgf.es> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-05ACPI / proc: remove unneeded NULL checkDan Carpenter
We already verified that "ldev" was non-NULL earlier and also we dereference again without checking a three lines later. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-05ACPI / utils: remove a pointless NULL checkDan Carpenter
"element" can't be NULL because it is the address of a struct member. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-05ACPI / video: Add HP EliteBook Revolve 810 to the blacklistMika Westerberg
On HP EliteBook Revolve 810 the ACPI backlight device doesn't work as expected. For example when resuming from system sleep, it seems to lose backlight settings. Forcing Intel driver fixes the problem so add this machine the ACPI video detect blacklist. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-29Merge branches 'acpi-processor', 'acpi-hotplug', 'acpi-init', 'acpi-pm' and ↵Rafael J. Wysocki
'acpica' * acpi-processor: ACPI / scan: reduce log level of "ACPI: \_PR_.CPU4: failed to get CPU APIC ID" ACPI / processor: Return specific error value when mapping lapic id * acpi-hotplug: ACPI / scan: Clear match_driver flag in acpi_bus_trim() * acpi-init: ACPI / init: Flag use of ACPI and ACPI idioms for power supplies to regulator API * acpi-pm: ACPI / PM: Use ACPI_COMPANION() to get ACPI companions of devices * acpica: ACPICA: Remove bool usage from ACPICA.
2014-01-29ACPI / scan: Clear match_driver flag in acpi_bus_trim()Rafael J. Wysocki
Drivers should not bind to struct acpi_device objects that acpi_bus_trim() has been called for, so make that function clear flags.match_driver for those objects. If that is not done, an ACPI driver may theoretically try to operate a device that is not physically present. Fixes: 202317a573b2 (ACPI / scan: Add acpi_device objects for all device nodes in the namespace) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com>
