path: root/drivers/android
2017-08-30ANDROID: binder: fix proc->tsk check.Martijn Coenen
commit b2a6d1b999a4c13e5997bb864694e77172d45250 upstream. Commit c4ea41ba195d ("binder: use group leader instead of open thread")' was incomplete and didn't update a check in binder_mmap(), causing all mmap() calls into the binder driver to fail. Signed-off-by: Martijn Coenen <maco@android.com> Tested-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30binder: Use wake up hint for synchronous transactions.Riley Andrews
commit 00b40d613352c623aaae88a44e5ded7c912909d7 upstream. Use wake_up_interruptible_sync() to hint to the scheduler binder transactions are synchronous wakeups. Disable preemption while waking to avoid ping-ponging on the binder lock. Signed-off-by: Todd Kjos <tkjos@google.com> Signed-off-by: Omprakash Dhyade <odhyade@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30binder: use group leader instead of open threadTodd Kjos
commit c4ea41ba195d01c9af66fb28711a16cc97caa9c5 upstream. The binder allocator assumes that the thread that called binder_open will never die for the lifetime of that proc. That thread is normally the group_leader, however it may not be. Use the group_leader instead of current. Signed-off-by: Todd Kjos <tkjos@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30Revert "android: binder: Sanity check at binder ioctl"Todd Kjos
commit a2b18708ee14baec4ef9c0fba96070bba14d0081 upstream. This reverts commit a906d6931f3ccaf7de805643190765ddd7378e27. The patch introduced a race in the binder driver. An attempt to fix the race was submitted in "[PATCH v2] android: binder: fix dangling pointer comparison", however the conclusion in the discussion for that patch was that the original patch should be reverted. The reversion is being done as part of the fine-grained locking patchset since the patch would need to be refactored when proc->vmm_vm_mm is removed from struct binder_proc and added in the binder allocator. Signed-off-by: Todd Kjos <tkjos@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-24ANDROID: binder: Clear binder and cookie when setting handle in flat binder ↵Arve Hjønnevåg
struct Prevents leaking pointers between processes Signed-off-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Martijn Coenen <maco@android.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-24ANDROID: binder: Add strong ref checksArve Hjønnevåg
Prevent using a binder_ref with only weak references where a strong reference is required. Signed-off-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Martijn Coenen <maco@android.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-15android: binder: Remove deprecated create_singlethread_workqueueBhaktipriya Shridhar
The workqueue is being used to run deferred work for the android binder. The "binder_deferred_workqueue" queues only a single work item and hence does not require ordering. Also, this workqueue is not being used on a memory recliam path. Hence, the singlethreaded workqueue has been replaced with the use of system_wq. System workqueues have been able to handle high level of concurrency for a long time now and hence it's not required to have a singlethreaded workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue created with create_singlethread_workqueue(), system_wq allows multiple work items to overlap executions even on the same CPU; however, a per-cpu workqueue doesn't have any CPU locality or global ordering guarantee unless the target CPU is explicitly specified and thus the increase of local concurrency shouldn't make any difference. Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-01Merge 4.5-rc6 into staging-nextGreg Kroah-Hartman
We want the staging fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-22Merge char-misc-next into staging-nextGreg Kroah-Hartman
This resolves the merge issues and confusions people were having with the goldfish drivers due to changes for them showing up in two different trees. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-20drivers: android: correct the size of struct binder_uintptr_t for ↵Lisa Du
BC_DEAD_BINDER_DONE There's one point was missed in the patch commit da49889deb34 ("staging: binder: Support concurrent 32 bit and 64 bit processes."). When configure BINDER_IPC_32BIT, the size of binder_uintptr_t was 32bits, but size of void * is 64bit on 64bit system. Correct it here. Signed-off-by: Lisa Du <cldu@marvell.com> Signed-off-by: Nicolas Boichat <drinkcat@chromium.org> Fixes: da49889deb34 ("staging: binder: Support concurrent 32 bit and 64 bit processes.") Cc: <stable@vger.kernel.org> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-11android: drivers: Avoid debugfs race in binderRiley Andrews
If a /d/binder/proc/[pid] entry is kept open after linux has torn down the associated process, binder_proc_show can deference an invalid binder_proc that has been stashed in the debugfs inode. Validate that the binder_proc ptr passed into binder_proc_show has not been freed by looking for it within the global process list whilst the global lock is held. If the ptr is not valid, print nothing. Cc: Colin Cross <ccross@android.com> Cc: Arve Hjønnevåg <arve@android.com> Cc: Dmitry Shmidt <dimitrysh@google.com> Cc: Rom Lemarchand <romlem@google.com> Cc: Serban Constantinescu <serban.constantinescu@arm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Android Kernel Team <kernel-team@android.com> Signed-off-by: Dmitry Shmidt <dimitrysh@google.com> [jstultz: Minor commit message tweaks] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-11android: binder: More offset validationArve Hjønnevåg
Make sure offsets don't point to overlapping flat_binder_object structs. Cc: Colin Cross <ccross@android.com> Cc: Arve Hjønnevåg <arve@android.com> Cc: Dmitry Shmidt <dimitrysh@google.com> Cc: Rom Lemarchand <romlem@google.com> Cc: Serban Constantinescu <serban.constantinescu@arm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Android Kernel Team <kernel-team@android.com> Signed-off-by: Dmitry Shmidt <dimitrysh@google.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-07android: binder: Sanity check at binder ioctlChen Feng
Sanity check at binder ioctl function, Only allow the shared mm_struct to use the same binder-object to do binder operate. And add proc->vma_vm_mm = current->mm at the open function. The libbinder do ioctl before mmap called. V2: Fix compile error for error commit V3: Change the condition to proc->vma_vm_mm Signed-off-by: Chen Feng <puck.chen@hisilicon.com> Signed-off-by: Wei Dong <weidong2@hisilicon.com> Signed-off-by: Junmin Zhao <zhaojunmin@huawei.com> Reviewed-by: Zhuangluan Su <suzhuangluan@hisilicon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-10mm: mark most vm_operations_struct constKirill A. Shutemov
With two exceptions (drm/qxl and drm/radeon) all vm_operations_struct structs should be constant. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Minchan Kim <minchan@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-01android: binder: fix binder mmap failuresAndrey Ryabinin
binder_update_page_range() initializes only addr and size fields in 'struct vm_struct tmp_area;' and passes it to map_vm_area(). Before 71394fe50146 ("mm: vmalloc: add flag preventing guard hole allocation") this was because map_vm_area() didn't use any other fields in vm_struct except addr and size. Now get_vm_area_size() (used in map_vm_area()) reads vm_struct's flags to determine whether vm area has guard hole or not. binder_update_page_range() don't initialize flags field, so this causes following binder mmap failures: -----------[ cut here ]------------ WARNING: CPU: 0 PID: 1971 at mm/vmalloc.c:130 vmap_page_range_noflush+0x119/0x144() CPU: 0 PID: 1971 Comm: healthd Not tainted 4.0.0-rc1-00399-g7da3fdc-dirty #157 Hardware name: ARM-Versatile Express [<c001246d>] (unwind_backtrace) from [<c000f7f9>] (show_stack+0x11/0x14) [<c000f7f9>] (show_stack) from [<c049a221>] (dump_stack+0x59/0x7c) [<c049a221>] (dump_stack) from [<c001cf21>] (warn_slowpath_common+0x55/0x84) [<c001cf21>] (warn_slowpath_common) from [<c001cfe3>] (warn_slowpath_null+0x17/0x1c) [<c001cfe3>] (warn_slowpath_null) from [<c00c66c5>] (vmap_page_range_noflush+0x119/0x144) [<c00c66c5>] (vmap_page_range_noflush) from [<c00c716b>] (map_vm_area+0x27/0x48) [<c00c716b>] (map_vm_area) from [<c038ddaf>] (binder_update_page_range+0x12f/0x27c) [<c038ddaf>] (binder_update_page_range) from [<c038e857>] (binder_mmap+0xbf/0x1ac) [<c038e857>] (binder_mmap) from [<c00c2dc7>] (mmap_region+0x2eb/0x4d4) [<c00c2dc7>] (mmap_region) from [<c00c3197>] (do_mmap_pgoff+0x1e7/0x250) [<c00c3197>] (do_mmap_pgoff) from [<c00b35b5>] (vm_mmap_pgoff+0x45/0x60) [<c00b35b5>] (vm_mmap_pgoff) from [<c00c1f39>] (SyS_mmap_pgoff+0x5d/0x80) [<c00c1f39>] (SyS_mmap_pgoff) from [<c000ce81>] (ret_fast_syscall+0x1/0x5c) ---[ end trace 48c2c4b9a1349e54 ]--- binder: 1982: binder_alloc_buf failed to map page at f0e00000 in kernel binder: binder_mmap: 1982 b6bde000-b6cdc000 alloc small buf failed -12 Use map_kernel_range_noflush() instead of map_vm_area() as this is better API for binder's purposes and it allows to get rid of 'vm_struct tmp_area' at all. Fixes: 71394fe50146 ("mm: vmalloc: add flag preventing guard hole allocation") Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reported-by: Amit Pundir <amit.pundir@linaro.org> Tested-by: Amit Pundir <amit.pundir@linaro.org> Acked-by: David Rientjes <rientjes@google.com> Tested-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-25Add security hooks to binder and implement the hooks for SELinux.Stephen Smalley
Add security hooks to the binder and implement the hooks for SELinux. The security hooks enable security modules such as SELinux to implement controls over binder IPC. The security hooks include support for controlling what process can become the binder context manager (binder_set_context_mgr), controlling the ability of a process to invoke a binder transaction/IPC to another process (binder_transaction), controlling the ability of a process to transfer a binder reference to another process (binder_transfer_binder), and controlling the ability of a process to transfer an open file to another process (binder_transfer_file). These hooks have been included in the Android kernel trees since Android 4.3. (Updated to reflect upstream relocation and changes to the binder driver, changes to the LSM audit data structures, coding style cleanups, and to add inline documentation for the hooks). Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Nick Kralevich <nnk@google.com> Acked-by: Jeffrey Vander Stoep <jeffv@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20android: binder: remove binder.hGreg Kroah-Hartman
binder.h isn't needed to just include a uapi file and set a single define, so move it into binder.c to save a few lines of code. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20staging: android: binder: move to the "real" part of the kernelGreg Kroah-Hartman
The Android binder code has been "stable" for many years now. No matter what comes in the future, we are going to have to support this API, so might as well move it to the "real" part of the kernel as there's no real work that needs to be done to the existing code. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
