path: root/drivers/ata/ahci.c
2009-08-12ahci: add workaround for on-board 5723s on some gigabyte boardsTejun Heo
Some gigabytes have on-board SIMG5723s connected to JMB ahcis. These are used to implement hardware raid. Unfortunately some firmware revisions on these 5723s don't bring the link down when all the downstream ports are unoccupied while not responding to reset protocol which makes libata think that there's device attached to the port but is not responding and retry. This results in painfully wrong boot detection time for these ports when they're empty. This patch quirks those boards such that ahci gives up after the initial timeout. Combined with parallel probing, this gives quick enough probing and also is safe because SIMG5723 will respond to the first try if any of the downstream ports is occupied. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Marc Bowes <marcbowes@gmail.com> Reported-by: Nicolas Mailhot <Nicolas.Mailhot@LaPoste.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-08-12ahci: Soften up the dmesg on SB600 PMP softreset failure recoveryShane Huang
Too strong words led to spurious bug reports: Novell bugzilla #527748, RedHat bugzilla #468800. This patch is used to soften up the dmesg on SB600 PMP softreset failure recovery, so as to remove the scariness and concern from community. Reported-by: pgnet Dev <pgnet.dev@gmail.com> Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-07-28ahci: add device IDs for Ibex Peak ahci controllersDavid Milburn
Add device IDS for Ibex Peak SATA AHCI Controllers Signed-off-by: Jaroslav Kysela <jkysela@redhat.com> Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-07-14ahci: add device ID for 82801JI sata controllerMark Goodwin
Add device ID for Intel 82801JI SATA AHCI controller. Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10[libata] ahci: Restore SB600 SATA controller 64 bit DMAShane Huang
Community reported one SB600 SATA issue(BZ #9412), which led to 64 bit DMA disablement for all SB600 revisions by driver maintainers with commits c7a42156d99bcea7f8173ba7a6034bbaa2ecb77c and 4cde32fc4b32e96a99063af3183acdfd54c563f0. But the root cause is ASUS M2A-VM system BIOS bug in old revisions like 0901, while forcing into 32bit DMA happens to work as workaround. Now it's time to withdraw 4cde32fc4b32e96a99063af3183acdfd54c563f0 so as to restore the SB600 SATA 64bit DMA capability. This patch is also adding the workaround for M2A-VM old BIOS revisions, but users are suggested to upgrade their system BIOS to the latest one if they meet this issue. Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10ahci: misc cleanups for EM stuffTejun Heo
Make the following EM related cleanups. * Use msleep(1) instead of udelay(100) and reduce retry count to 5. * s/MAX_SLOTS/EM_MAX_SLOTS/, s/MAX_RETRY/EM_MAX_RETRY/ * Make EM constants enums as suggested by Jeff. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10[libata] ahci: use less error-prone array initializersJeff Garzik
Also, remove unneeded prototype. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-05ahci: add warning messages for hp laptops with broken suspendTejun Heo
Harddisks on HP dv[4-6] and HDX18 fail to come online after resume on earlier BIOSen. Fortunately, HP recently released BIOS updates for all machines to fix the issue. Detect old BIOSen, warn the user to update BIOS on boot and suspend attempts and fail suspend. Kudos to all the bug reporters. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: kernel.org@epperson.homelinux.net Cc: emisca@gmail.com Cc: Gadi Cohen <dragon@wastelands.net> Cc: Paul Swanson <paul@procursa.com> Cc: s@ourada.org Cc: Trevor Davenport <trevor.davenport@gmail.com> Cc: corruptor1972 <steven_tierney@yahoo.co.uk> Cc: Victoria Wilson <mail@vwilson.co.uk> Cc: khiraly <khiraly.list@gmail.com> Cc: Sean <wollombi@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-13ahci: force CAP_NCQ for earlier NV MCPsTejun Heo
Along with MCP65, MCP67 and 73 also don't set CAP_NCQ. Force it. Reported by zaceni@yandex.ru on bko#13014 and confirmed by Peer Chen. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: NightFox <zaceni2@yandex.ru> Cc: Peer Chen <pchen@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-07Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: sata_mv: shorten register names sata_mv: workaround errata SATA#13 sata_mv: cosmetic renames sata_mv: workaround errata SATA#26 sata_mv: workaround errata PCI#7 sata_mv: replace 0x1f with ATA_PIO4 (v2) sata_mv: fix irq mask races sata_mv: revert SoC irq breakage libata: ahci enclosure management bios workaround ata: Add TRIM infrastructure ata_piix: VGN-BX297XP wants the controller power up on suspend libata: Remove some redundant casts from pata_octeon_cf.c pata_artop: typo
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06libata: ahci enclosure management bios workaroundDavid Milburn
During driver initialization ahci_start_port may not be able to turn LEDs off because the hardware may still be transmitting a message. And since the BIOS may not be setting the LEDs to off the drive LEDs may end up in a fault state. This has been seen on ICH9r and ICH10r when configured in AHCI mode instead of RAID mode, this patch doesn't key off a specific set of device IDs but will give the EM transmit bit a chance to clear if busy. Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] ahci: correct enclosure LED state saveDavid Milburn
ahci_transmit_led_message saves off the led_state with a value that includes the port number OR'd in, this incorrect value maybe reported back in ahci_led_store. For instance, if you turn off all the leds for port 1 and cat the value back it will report 1 instead of 0. # echo 0 > /sys/class/scsi_host/host1/em_message # cat /sys/class/scsi_host/host1/em_message 1 Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24ahci: Blacklist HP Compaq 6720s that spins off disks during ACPI power offMaciej Rutecki
Blacklist HP Compaq 6720s so that it doesn't play a "spin down, spin up, spin down" ping-pong with the hard disk during system power off. Signed-off-by: Maciej Rutecki <maciej.rutecki@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24ahci: drop intx manipulation on msi enableTejun Heo
There's no need to turn off intx explicitly on msi enable. This is automatically handled by pci. Drop it. This might be needed on machines if the BIOS turns intx off during boot. However, there's no evidence of such behavior for ahci and the only such case seems to be ICH5 PATA according to ata_piix. Also, given the way ahci operates, it's highly unlikely BIOS ever disables IRQ for the controller. However, as this change has slight possibility of introducing failure, please schedule it for #upstream. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-05ahci: Add the Device IDs for MCP89 and remove IDs of MCP7B to/from ahci.cpeerchen
Added the Device IDs for MCP89 AHCI controller. Removed the IDs of MCP7B because this chipset had been cancelled. Signed-off-by: Peer Chen <peerchen@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-02-02ahci: add a module parameter to ignore the SSS flags for async scanningArjan van de Ven
The SSS flag, which directs the OS to spin up one disk at a time to not have the PSU blow out, sometimes gets set even when not needed. The effect of this is a longer-than-needed boot time. This patch adds a module parameter that makes the driver ignore SSS at least as far as the parallel scan during boot is concerned... Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-27SATA AHCI: Blacklist system that spins off disks during ACPI power offRafael J. Wysocki
Some notebooks from HP have the problem that their BIOSes attempt to spin down hard drives before entering ACPI system states S4 and S5. This leads to a yo-yo effect during system power-off shutdown and the last phase of hibernation when the disk is first spun down by the kernel and then almost immediately turned on and off by the BIOS. This, in turn, may result in shortening the disk's life times. To prevent this from happening we can blacklist the affected systems using DMI information. Blacklist HP nx6310 that uses the AHCI driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-10libata: Add a per-host flag to opt-in into parallel port probesArjan van de Ven
This patch adds a per host flag that allows drivers to opt in into having its busses scanned in parallel. Drivers that do not set this flag get their ports scanned in the "original" sequence. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08[libata] ahci: Withdraw IGN_SERR_INTERNAL for SB800 SATAShane Huang
There is an issue in ATI SB600/SB700 SATA that PxSERR.E should not be set on some conditions, which will lead to many SATA ODD error messages. commit 55a61604cd1354e1783364e1c901034f2f474b7d is the workaround. Since SB800 fixed this HW issue, IGN_SERR_INTERNAL should be withdrawn for SB800. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08[libata] ahci: Add SATA GEN3 related messagesShane Huang
The present AHCI driver seems to support SATA GEN 3 speed, but the related messages should be modified. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-28libata: beef up iteratorsTejun Heo
There currently are the following looping constructs. * __ata_port_for_each_link() for all available links * ata_port_for_each_link() for edge links * ata_link_for_each_dev() for all devices * ata_link_for_each_dev_reverse() for all devices in reverse order Now there's a need for looping construct which is similar to __ata_port_for_each_link() but iterates over PMP links before the host link. Instead of adding another one with long name, do the following cleanup. * Implement and export ata_link_next() and ata_dev_next() which take @mode parameter and can be used to build custom loop. * Implement ata_for_each_link() and ata_for_each_dev() which take looping mode explicitly. The following iteration modes are implemented. * ATA_LITER_EDGE : loop over edge links * ATA_LITER_HOST_FIRST : loop over all links, host link first * ATA_LITER_PMP_FIRST : loop over all links, PMP links first * ATA_DITER_ENABLED : loop over enabled devices * ATA_DITER_ENABLED_REVERSE : loop over enabled devices in reverse order * ATA_DITER_ALL : loop over all devices * ATA_DITER_ALL_REVERSE : loop over all devices in reverse order This change removes exlicit device enabledness checks from many loops and makes it clear which ones are iterated over in which direction. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-28libata: ahci enclosure management bit maskDavid Milburn
Enclosure management bit mask definitions. Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-28libata: ahci enclosure management led syncDavid Milburn
Synchronize ahci_sw_activity and ahci_sw_activity_blink with ata_port lock. Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27ahci: Add support for Promise PDC42819Mark Nelson
Add an appropriate entry for the Promise PDC42819 controller. It has an AHCI mode and so far works correctly with board_ahci. This chip is found on Promise's FastTrak TX2650 (2 port) and TX4650 (4 port) software-based RAID cards (for which there is a binary driver, t3sas) and can be found on some motherboards, for example the MSI K9A2 Platinum, which calls the chip a Promise T3 controller. Although this controller also supports SAS devices, its default bootup mode is AHCI and the binary driver has to do some magic to get the chip into the appropriate mode to drive SAS disks. Seeing as no documentation is provided by Promise, adding this entry to the ahci driver allows the controller to be useful to people as a SATA controller (with no ill effects on the system if a SAS disk is connected - probing of the port just times out with "link online but device misclassified"), without having to resort to using the binary driver. Users who require SAS or the proprietary software raid can get this functionality using the binary driver. Signed-off-by: Mark Nelson <mdnelson8@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: Implement disk shock protection supportElias Oltmanns
On user request (through sysfs), the IDLE IMMEDIATE command with UNLOAD FEATURE as specified in ATA-7 is issued to the device and processing of the request queue is stopped thereafter until the specified timeout expires or user space asks to resume normal operation. This is supposed to prevent the heads of a hard drive from accidentally crashing onto the platter when a heavy shock is anticipated (like a falling laptop expected to hit the floor). In fact, the whole port stops processing commands until the timeout has expired in order to avoid any resets due to failed commands on another device. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: make SCR access ops per-linkTejun Heo
Logically, SCR access ops should take @link; however, there was no compelling reason to convert all SCR access ops when adding @link abstraction as there's one-to-one mapping between a port and a non-PMP link. However, that assumption won't hold anymore with the scheduled addition of slave link. Make SCR access ops per-link. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-08ahci: RAID mode SATA patch for Intel Ibex Peak DeviceIDsSeth Heasley
Add the Intel Ibex Peak (PCH) SATA RAID Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-08ahci: disable PMP for marvell ahcisTejun Heo
Marvell ahcis don't play nicely with PMPs. Disable it. Reported by KueiHuan Chen in the following thread. http://thread.gmane.org/gmane.linux.ide/33296 Signed-off-by: Tejun Heo <tj@kernel.org> Cc: KueiHuan Chen <kueihuan.chen@gmail.com> Cc: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-08ahci, pata_marvell: play nicely togetherAlan Cox
I've been chasing Jeff about this for months. Jeff added the Marvell device identifiers to the ahci driver without making the AHCI driver handle the PATA port. This means a lot of users can't use current kernels and in most distro cases can't even install. This has been going on since March 2008 for the 6121 Marvell, and late 2007 for the 6145!!! This was all pointed out at the time and repeatedly ignored. Bugs assigned to Jeff about this are ignored also. To quote Jeff in email > "Just switch the order of 'ahci' and 'pata_marvell' in > /etc/modprobe.conf, then use Fedora's tools regenerate the initrd. > See? It's not rocket science, and the current configuration can be > easily made to work for Fedora users." (Which isn't trivial, isn't end user, shouldn't be needed, and as it usually breaks at install time is in fact impossible) To quote Jeff in August 2007 > " mv-ahci-pata > Marvell 6121/6141 PATA support. Needs fixing in the 'PATA controller > command' area before it is usable, and can go upstream." Only he add the ids anyway later and caused regressions, adding a further id in March causing more regresions. The actual fix for the moment is very simple. If the user has included the pata_marvell driver let it drive the ports. If they've only selected for SATA support give them the AHCI driver which will run the port a fraction faster. Allow the user to control this decision via ahci.marvell_enable as a module parameter so that distributions can ship 'it works' defaults and smarter users (or config tools) can then flip it over it desired. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22ahci: sis controllers actually can do PMPTejun Heo
SIS controllers were blacklisted for PMP as enabling it made device detection fail whether the device was PMP or not - the natural conclusion was the controller chokes on SRST w/ pmp==15. However, it turned out that the controller just didn't like issuing SRST after hardreset w/o clearing SError first. Interestingly, the SRST itself succeeds but the following commands fail. If SError is cleared between hardreset and SRST, which is the default behavior now, everything works fine and SIS controllers work with PMPs happily. Remove PMP blacklisting for SIS AHCIs. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Piter PUNK <piterpunk@slackware.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22ahci: RAID mode SATA patch for Intel Ibex Peak DeviceIDsSeth Heasley
Resend with proper whitespace. This patch adds the Intel Ibex Peak (PCH) SATA RAID Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-25Fix ahci driver 'flags' typeLinus Torvalds
The new type checking of the flags arguments to irqsave and friends (commit 3f307891ce0e7b0438c432af1aacd656a092ff45) pointed out this thing with a big nice warning. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14AHCI: Remove an unnecessary flush from ahci_qc_issueMatthew Wilcox
In an I/O heavy workload (IOZone), ahci_qc_issue is the second-highest consumer of CPU cycles. Removing the flush gets us approximately 10% bandwidth improvement. I believe this to be because the CPU can start queueing the next request instead of waiting for the readl() to flush the writes to the device. The flush isn't necessary because we're using a 'queue' metaphor; we don't guarantee the command has got to the device, nor do we need to guarantee the command has got to the controller. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-14AHCI: speed up resumeZhang Rui
During resume, sleep 1 second to wait for the HBA reset to finish is a waste of time. According to the AHCI 1.2 spec, We should poll the HOST_CTL register, and return error if the host reset is not finished within 1 second. Test results show that the HBA reset can be done quickly(in usecs). And this patch may save nearly 1 second during resume. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-14libata/ahci: enclosure management supportKristen Carlson Accardi
Add Enclosure Management support to libata and ahci. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-05ahci: give another shot at clearing all bits in irq_statTejun Heo
Commit ea0c62f7cf70f13a67830471b613337bd0c9a62e tried to clear all bits in irq_stat but it didn't actually achieve that as irq_stat was anded with port_map right after read. This patch makes ahci driver always use the unmasked value to clear irq_status. While at it, add explanation on the peculiarities of ahci IRQ clearing. This was spotted by Linus Torvalds. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04ahci: always clear all bits in irq_statTejun Heo
Some AHCI controllers (ICH7 was reported) set pending bit in HOST_IRQ_STAT for non-existent ports and when it's not cleared falls into IRQ storm. Always clear full irq_stat instead of only the bits that are handled. As nothing changes for recognized ports, the risk of breaking things is pretty low. Reported and verified by Philipp Thomas in the following suse bugzilla. https://bugzilla.novell.com/attachment.cgi?id=215692 Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Philipp Thomas <pth@novell.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-18ahci: sis can't do PMPTejun Heo
From: Piter PUNK <piterpunk@slackware.com> SiS AHCIs say they can do PMP but can't and fail detection if SRST w/ pmp==15 is used. Turn off PMP support. tj: added patch description, adapted patch to #upstream-fixes and renamed board_ahci_sis to board_ahci_nopmp. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-18ahci: jmb361 has only one portTejun Heo
JMB361 has only one port but reports it has two causing longish probe failure on the second one. Quirk it. Reported by Gajo Petrovic in bz 10911. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Gajo Petrovic <gajo01@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-13ahci: Workaround HW bug for SB600/700 SATA controller PMP supportShane Huang
There is one bug in ATI SATA PMP of SB600 and SB700 old revision, which leads to soft reset failure. This patch can fix the bug. Signed-off-by: Shane Huang <shane.huang@amd.com> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-13ahci: workarounds for mcp65Tejun Heo
MCP65 ahci can do NCQ but doesn't set the CAP bit and rev A0 and A1 can't do MSI but have MSI capability. Implement AHCI_HFLAG_YES_NCQ and apply appropriate workarounds. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Peer Chen <pchen@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30ahci: change the Device IDs of nvidia MCP7B AHCI controller in ahci.cpeerchen
Change the partial Device IDs of nvidia MCP7B AHCI controller in ahci.c, as the actual PCI IDs deployed in the field differed from the forecasted ones preemptively placed in the driver. Signed-off-by: Peer Chen <peerchen@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-06libata: improve post-reset device ready testTejun Heo
Some controllers (jmb and inic162x) use 0x77 and 0x7f to indicate that the device isn't ready yet. It looks like they use 0xff if device presence is detected but connection isn't established. 0x77 or 0x7f after connection is established and use the value from signature FIS after receiving it. This patch implements ata_check_ready(), which takes TF status value and determines whether the port is ready or not considering the above and other conditions, and use it in @check_ready() functions. This is safe as both 0x77 and 0x7f aren't valid ready status value even though they have BSY bit cleared. This fixes hot plug detection failures which can be triggered with certain drives if they aren't already spun up when the data connector is hot plugged. Tested on sil, sil24, ahci (jmb/ich), piix and inic162x combined with eight drives from all major vendors. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29ahci: SB600 ahci can't do MSI, blacklist that capabilityTejun Heo
This fixes bz#10507. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Shane Huang <Shane.Huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ahci: retry enabling AHCI a few times before spitting out WARN_ON()Tejun Heo
Some chips need AHCI_EN set more than once to actually set it. Try a few times before giving up and spitting out WARN_ON(). Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Peer Chen <pchen@nvidia.com> Cc: Volker Armin Hemmann <volker.armin.hemmann@tu-clausthal.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-17libata: move link onlineness check out of softreset methodsTejun Heo
Currently, SATA softresets should do link onlineness check before actually performing SRST protocol but it doesn't really belong to softreset. This patch moves onlineness check in softreset to ata_eh_reset() and ata_eh_followup_srst_needed() to clean up code and help future sata_mv changes which need clear separation between SCR and TF accesses. sata_fsl is peculiar in that its softreset really isn't softreset but combination of hardreset and softreset. This patch adds dummy private ->prereset to keep the current behavior but the driver really should implement separate hard and soft resets and return -EAGAIN from hardreset if it should be follwed by softreset. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
