path: root/drivers/ata/ahci.c
2010-09-28ahci: fix module refcount breakage introduced by libahci splitTejun Heo
libata depends on scsi_host_template for module reference counting and sht's should be owned by each low level driver. During libahci split, the sht was left with libahci.ko leaving the actual low level drivers not reference counted. This made ahci and ahci_platform always unloadable even while they're being actively used. Fix it by defining AHCI_SHT() macro in ahci.h and defining a sht for each low level ahci driver. stable: only applicable to 2.6.35. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Pedro Francisco <pedrogfrancisco@gmail.com> Tested-by: Michael Tokarev <mjt@tls.msk.ru> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09ahci: AHCI and RAID mode SATA patch for Intel Patsburg DeviceIDsSeth Heasley
This patch adds the Intel Patsburg (PCH) SATA AHCI and RAID Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25ahci: add HFLAG_YES_FBS and apply it to 88SE9128Tejun Heo
88SE9128 can do FBS and sets it in HOST_CAP but forgets to set FBSCP in PORT_CMD. Implement AHCI_HFLAG_YES_FBS and apply it to 88SE9128. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-01[libata] ahci: Fix warning: comparison between 'enum <anonymous>' and 'enum ↵Justin P. Mattock
<anonymous>' The below patch casts ATA_MAX_QUEUE to int because GCC will give a warning message about the two different enum blocks: CC drivers/ata/ahci.o drivers/ata/ahci.c: In function 'ahci_init_one': drivers/ata/ahci.c:1045:2: warning: comparison between 'enum <anonymous>' and 'enum <anonymous>' Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-07-01ahci,ata_generic: let ata_generic handle new MBP w/ MCP89Tejun Heo
For yet unknown reason, MCP89 on MBP 7,1 doesn't work w/ ahci under linux but the controller doesn't require explicit mode setting and works fine with ata_generic. Make ahci ignore the controller on MBP 7,1 and let ata_generic take it for now. Reported in bko#15923. https://bugzilla.kernel.org/show_bug.cgi?id=15923 NVIDIA is investigating why ahci mode doesn't work. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peer Chen <pchen@nvidia.com> Cc: stable@kernel.org Reported-by: Anders Østhus <grapz666@gmail.com> Reported-by: Andreas Graf <andreas_graf@csgraf.de> Reported-by: Benoit Gschwind <gschwind@gnu-log.net> Reported-by: Damien Cassou <damien.cassou@gmail.com> Reported-by: tixetsal@juno.com Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: EM message type auto detectHarry Zhang
Detect enclosure management message type automatically at driver initialization, instead of using module parameter "ahci_em_messages". Signed-off-by: Harry Zhang <harry.zhang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: implement AHCI_HFLAG_NO_FPDMA_AA and update NV quirksTejun Heo
It turns out different generations of MCPs have differing quirks. * MCP 65-73 : FPDMA AA broken, lies about PMP support, forgets to report NCQ * MCP 77-79 : FPDMA AA broken, lies about PMP support * MCP 89 : FPDMA AA broken Instead of turngin off FPDMA AA on all NVIDIAs, implement HFLAG_NO_FPDMA_AA, define additional board IDs and apply necessary quirks. This fixes bko#15481 and the list of quirks is verified by Peer Chen. http://bugzilla.kernel.org/show_bug.cgi?id=15481 Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peer Chen <pchen@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: clean up board IDsTejun Heo
ahci over time has grown a number of board IDs and it's a bit of mess right now. Clean it up such that, * board_id_* now live in a separate enum board_ids and numbers are assigned automatically. * Board IDs assigned to features are separated from the ones assigned to specific implementations and both are ordered alphabetically. * For NV MCPs, define per-generation alias board_ids and assign matching aliases in the pci id table. This makes mcp_linux, 67-73 use board_ahci_mcp65 instead of board_ahci_yesncq. Both are identical in content. * Kill now unused board_ahci_nopmp and board_ahci_yesncq. This patch doesn't cause any functional change but will make future changes to board_ids and quirks much less painful. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peer Chen <pchen@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Move generic code into libahciAnton Vorontsov
This patch should contain no functional changes, just moves code around. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Introduce ahci_set_em_messages()Anton Vorontsov
Factor out some ahci_em_messages handling code from ahci_init_one(). We would like to reuse it for non-PCI devices. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Factor out PCI specifics from ahci_print_info()Anton Vorontsov
Introduce ahci_pci_print_info() that now handles PCI stuff. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Factor out PCI specifics from ahci_init_controller()Anton Vorontsov
Move PCI stuff into ahci_pci_init_controller(). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Get rid of pci_dev argument in ahci_port_init()Anton Vorontsov
To make the function bus-independand we have to get rid of "struct pci_dev *", so let's pass just "struct devce *". Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Factor out PCI specifics from ahci_reset_controller()Anton Vorontsov
Move PCI stuff into ahci_pci_reset_controller(). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Get rid of pci_dev argument in ahci_save_initial_config()Anton Vorontsov
To make the function generic we have to get rid of "struct pci_dev *", so let's pass just a "struct devce *". Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Factor out PCI specifics from ahci_save_initial_config()Anton Vorontsov
Make ahci_save_initial_config() a bit more generic by introducing force_port_map and mask_port_map arguments. Move PCI stuff into ahci_pci_save_initial_config(). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14ahci: Get rid of host->iomap usageAnton Vorontsov
Currently the driver uses host->iomap to store all the iomapped BARs of a PCI device (while AHCI devices actually use just a single memory window). We're going to teach AHCI to work with non-PCI buses, so there are two options to make this work: 1. "fake" host->iomap array for non-PCI devices, and place the needed address at iomap[AHCI_PCI_BAR]; 2. Get rid of host->iomap usage, instead introduce a private mmio field. This patch implements the second option. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-17ahci: pp->active_link is not reliable when FBS is enabledShane Huang
pp->active_link is not reliable when FBS is enabled. Both PORT_SCR_ACT and PORT_CMD_ISSUE should be checked because mixed NCQ and non-NCQ commands may be in flight. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-17ahci: use BIOS date in broken_suspend listTejun Heo
HP is recycling both DMI_PRODUCT_NAME and DMI_BIOS_VERSION making ahci_broken_suspend() trigger for later products which are not affected by the original problems. Match BIOS date instead of version and add references to bko's so that full information can be found easier later. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=15462 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: tigerfishdaisy@gmail.com Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-17ahci: add missing nv IDsTejun Heo
bko#15481 shows that we're missing some NVIDIA ahci PCI IDs. Peer Chen confirms that IDs 0x580-0x58f are reserved for cases where Linux ID option is selected in the BIOS and are only used for mcp65-73. Add 0x0581-0x058f. http://bugzilla.kernel.org/show_bug.cgi?id=15481 Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peer Chen <pchen@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01libata: make functions/variables staticRobert Hancock
Make some variables in ahci and a function in pata_pcmcia static, as found using sparse. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01ahci: AHCI and RAID mode SATA patch for Intel Cougar Point DeviceIDsSeth Heasley
2010-03-01ahci: Implement SATA AHCI FIS-based switching supportShane Huang
Tested on AMD internal reference board. Signed-off-by: Shane Huang <shane.huang@amd.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-02-24ahci: disable FPDMA auto-activate optimization on NVIDIA AHCIRobert Hancock
Mike Cui reported that his system with an NVIDIA MCP79 (aka MCP7A) chipset stopped working with 2.6.32. The problem appears to be that 2.6.32 now enables the FPDMA auto-activate optimization in the ahci driver. The drive works fine with this enabled on an Intel AHCI so this appears to be a chipset bug. Since MCP79 is a fairly recent NVIDIA chipset and we don't have any info on whether any other NVIDIA chipsets have this issue, disable FPDMA AA optimization on all NVIDIA AHCI controllers for now. Should address http://bugzilla.kernel.org/show_bug.cgi?id=14922 Signed-off-by: Robert Hancock <hancockrwd@gmail.com> While-we-investigate-issue-this-patch-looks-good-to-me-by: Prajakta Gudadhe <pgudadhe@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: stable@kernel.org
2010-02-04ahci: add Acer G725 to broken suspend listTejun Heo
Acer G725 shares the same suspend problem with the HP laptops which lose ATA devices on resume. New firmware which fixes the problem is already available. Add G725 with old firmwares to the broken suspend list. This problem has been reported in bko#15104. http://bugzilla.kernel.org/show_bug.cgi?id=15104 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jani-Matti Hätinen <jani-matti.hatinen@iki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03ahci: let users know that Promise PDC42819 support is limited to SATA devicesMark Nelson
ahci can drive the Promise PDC42819, but obviously it can only use SATA disks connected to this controller. The controller can actually support SAS disks as well, but we only know how to use it in it's AHCI mode. Add a message to let users know that because ahci is driving their chip they can only use the SATA disks connected to this controller. Signed-off-by: Mark Nelson <mdnelson8@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03ahci: disable SNotification capability for ich8Shaohua Li
I obseved there is a sata_async_notification() for every ahci interrupt. But the async notification does nothing (this is hard disk drive and no pmp). This cause cpu wastes some time on sntf register access. It appears ICH AHCI doesn't support SNotification register, but the controller reports it does. After quirking it, the async notification disappears. PS. it appears all ICH don't support SNotification register from ICH manual, don't know if we need quirk all ICH. I don't have machines with all kinds of ICH. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-11-03ahci: Enable SB600 64bit DMA on MSI K9A2 Platinum v2Mark Nelson
Like the Asus M2A-VM, MSI's K9A2 Platinum (MS-7376) can also support 64bit DMA. It is a new enough board that all the BIOS releases work correctly with 64bit DMA enabled. Signed-off-by: Mark Nelson <mdnelson8@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-16ahci / atiixp / pci quirks: rename AMD SB900 into Hudson-2Shane Huang
This patch renames the code name SB900 into Hudson-2 Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-16ahci: Add the AHCI controller Linux Device ID for NVIDIA chipsets.peer chen
Add the generic device ID for NVIDIA AHCI controller. Signed-off-by: Peer Chen <peerchen@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-09ahci: Add ifdef wrapper to ahci_gtf_filter_workaroundMarkus Trippelsdorf
Commit f80ae7e45a0e03da188494c6e947a5c8b0cdfb4a ahci: filter FPDMA non-zero offset enable for Aspire 3810T breaks the current git build for configurations that don't define CONFIG_ATA_ACPI. This adds an ifdef wrapper to ahci_gtf_filter_workaround. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06ahci: filter FPDMA non-zero offset enable for Aspire 3810TTejun Heo
Curiously, Aspire 3810T issues many SATA feature enable commands via _GTF, of which one is invalid and another is not supported by the drive. In the process, it also enables FPDMA non-zero offset. However, the feature also needs to be supported and enabled from the controller and it's wrong to enable it from _GTF unless the controller can do it by default. Currently, this ends up enabling FPDMA non-zero offset only on the drive side leading to NCQ command failures and eventual disabling of NCQ. This patch makes libata filter out FPDMA non-zero offset enable for the machine. This was reported by Marcus Meissner in bnc#522790. https://bugzilla.novell.com/show_bug.cgi?id=522790 Reported-by: Marcus Meissner <meissner@novell.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06ahci: display all AHCI 1.3 HBA capability flags (v2)Robert Hancock
Update the AHCI driver to display all of the HBA capabilities defined in the AHCI 1.3 specification. Some of these are in a new CAP2 (HBA Capabilities Extended) register which is only defined on AHCI 1.2 or later. The spec says that undefined registers should always return 0 on read, but to be safe we assume a value of 0 unless the controller reports AHCI version 1.2 or later. The value can also be retrieved through sysfs as with the existing capability field. For example, on an Intel Ibex Peak (PCH) controller: ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ems sxs apst We don't do anything special with the new flags yet. Also, change the code that displays the flags to use the same bit enumerations that are used to control actual operation. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06ahci: disable 64bit DMA by default on SB600sTejun Heo
Till now only one board, ASUS M2A-VM, can do 64bit dma with recent BIOSen. Enabling 64bit DMA by default already broke three boards. Enabling 64bit DMA isn't worth these regressions. Disable 64bit DMA by default and enable it only on boards which are known to work. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Gabriele Balducci <balducci@units.it> Reported-by: maierp@informatik.tu-muenchen.de Cc: Shane Huang <shane.huang@amd.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-17ahci: restore pci_intx() handlingTejun Heo
Commit a5bfc4714b3f01365aef89a92673f2ceb1ccf246 dropped explicit pci_intx() manipulation from ahci because it seemed unnecessary and ahci doesn't seem to be the right place to be tweaking it if it were. This was largely okay but there are exceptions. There was one on an embedded platform which was fixed via firmware and now bko#14124 reports it on a HP DL320. http://bugzilla.kernel.org/show_bug.cgi?id=14124 I still think this isn't something libata drivers should be caring about (the only ones which are calling pci_intx() explicitly are libata ones and one other driver) but for now reverting the change seems to be the right thing to do. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-11ahci: kill @force_restart and refine CLO for ahci_kick_engine()Shane Huang
This patch refines ahci_kick_engine() after discussion with Tejun about FBS(FIS-based switching) support preparation: a. Kill @force_restart and always kick the engine. The only case where @force_restart is zero is when it's called from ahci_p5wdh_hardreset() Actually at that point, BSY is pretty much guaranteed to be set. b. If PMP is attached, ignore busy and always do CLO. (AHCI-1.3 9.2) Signed-off-by: Shane Huang <shane.huang@amd.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-11ahci: Add AMD SB900 SATA/IDE controller device IDsShane Huang
Add AMD SB900 SATA/IDE controller device IDs. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-08ahci: Gigabyte GA-MA69VM-S2 can't do 64bit DMATejun Heo
Gigabyte GA-MA69VM-S2 can't do 64bit DMA either. It's yet unknown whether recent BIOS fixes the problem. Blacklist regardless of BIOS revisions for now. Sandor Bodo-Merle reported and provided the initial patch for this issue. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Sandor Bodo-Merle <sbodomerle@gmail.com> Cc: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-08ahci: make ahci_asus_m2a_vm_32bit_only() quirk more genericTejun Heo
It turns out ASUS M2A-VM isn't the only one with the 32bit DMA problem. Make ahci_asus_m2a_vm_32bit_only() more generic using the new dmi_get_date() and rename it to ahci_sb600_32bit_only(). Cut off date is now pointed to by dmi_system_id->driver_data in "yyyymmdd" format and it's now also allowed to be omitted. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Sandor Bodo-Merle <sbodomerle@gmail.com> Cc: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-08dmi: extend dmi_get_year() to dmi_get_date()Tejun Heo
There are cases where full date information is required instead of just the year. Add month and day parsing to dmi_get_year() and rename it to dmi_get_date(). As the original function only required '/' followed by any number of parseable characters at the end of the string, keep that behavior to avoid upsetting existing users. The new function takes dates of format [mm[/dd]]/yy[yy]. Year, month and date are checked to be in the ranges of [1-9999], [1-12] and [1-31] respectively and any invalid or out-of-range component is returned as zero. The dummy implementation is updated accordingly but the return value is updated to indicate field not found which is consistent with how other dummy functions behave. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01libata: Export AHCI capabilitiesMatthew Garrett
AHCI exports various capability bits that may be of interest to userspace such as whether the BIOS claims a port is hotpluggable or eSATA. Providing these via sysfs along with the version of the AHCI spec implemented by the host allows userspace to make policy decisions for things like ALPM. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01[libata] add DMA setup FIS auto-activate featureShaohua Li
Hopefully results in fewer on-the-wire FIS's and no breakage. We'll see! Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-08-12ahci: add workaround for on-board 5723s on some gigabyte boardsTejun Heo
Some gigabytes have on-board SIMG5723s connected to JMB ahcis. These are used to implement hardware raid. Unfortunately some firmware revisions on these 5723s don't bring the link down when all the downstream ports are unoccupied while not responding to reset protocol which makes libata think that there's device attached to the port but is not responding and retry. This results in painfully wrong boot detection time for these ports when they're empty. This patch quirks those boards such that ahci gives up after the initial timeout. Combined with parallel probing, this gives quick enough probing and also is safe because SIMG5723 will respond to the first try if any of the downstream ports is occupied. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Marc Bowes <marcbowes@gmail.com> Reported-by: Nicolas Mailhot <Nicolas.Mailhot@LaPoste.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-08-12ahci: Soften up the dmesg on SB600 PMP softreset failure recoveryShane Huang
Too strong words led to spurious bug reports: Novell bugzilla #527748, RedHat bugzilla #468800. This patch is used to soften up the dmesg on SB600 PMP softreset failure recovery, so as to remove the scariness and concern from community. Reported-by: pgnet Dev <pgnet.dev@gmail.com> Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-07-28ahci: add device IDs for Ibex Peak ahci controllersDavid Milburn
Add device IDS for Ibex Peak SATA AHCI Controllers Signed-off-by: Jaroslav Kysela <jkysela@redhat.com> Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-07-14ahci: add device ID for 82801JI sata controllerMark Goodwin
Add device ID for Intel 82801JI SATA AHCI controller. Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10[libata] ahci: Restore SB600 SATA controller 64 bit DMAShane Huang
Community reported one SB600 SATA issue(BZ #9412), which led to 64 bit DMA disablement for all SB600 revisions by driver maintainers with commits c7a42156d99bcea7f8173ba7a6034bbaa2ecb77c and 4cde32fc4b32e96a99063af3183acdfd54c563f0. But the root cause is ASUS M2A-VM system BIOS bug in old revisions like 0901, while forcing into 32bit DMA happens to work as workaround. Now it's time to withdraw 4cde32fc4b32e96a99063af3183acdfd54c563f0 so as to restore the SB600 SATA 64bit DMA capability. This patch is also adding the workaround for M2A-VM old BIOS revisions, but users are suggested to upgrade their system BIOS to the latest one if they meet this issue. Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10ahci: misc cleanups for EM stuffTejun Heo
Make the following EM related cleanups. * Use msleep(1) instead of udelay(100) and reduce retry count to 5. * s/MAX_SLOTS/EM_MAX_SLOTS/, s/MAX_RETRY/EM_MAX_RETRY/ * Make EM constants enums as suggested by Jeff. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10[libata] ahci: use less error-prone array initializersJeff Garzik
Also, remove unneeded prototype. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
