chipsets(v2)
commit 5e5a4f5d5a08c9c504fe956391ac3dae2c66556d upstream.
This quirk patch fixes one kind of bug inside some Intel Sandybridge
chipsets, see reports from
https://bugzilla.kernel.org/show_bug.cgi?id=40592.
Many guys also have reported the problem before:
https://bugs.launchpad.net/bugs/737388
https://bugs.launchpad.net/bugs/794642
https://bugs.launchpad.net/bugs/782389
With help from Tejun, the problem is found to be caused by 32bit PIO
mode, so introduce the quirk patch to disable 32bit PIO on SATA piix
for some Sandybridge CPT chipsets.
Seth also tested the patch on all five affected chipsets
(pci device ID: 0x1c00, 0x1c01, 0x1d00, 0x1e00, 0x1e01), and found
the patch does fix the problem.
Tested-by: Heasley, Seth <seth.heasley@intel.com>
Cc: Alan Cox <alan@linux.intel.com>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Acked-by: Tejun Heo <htejun@gmail.com>
Use a single mechanism to show driver version.
Reduces text a tiny bit too.
Remove uses of static int printed_version
Add and use ata_print_version(const struct device *, const char *ver)
and ata_print_version_once.
$ size drivers/ata/built-in.*
544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o
543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o
141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o
141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Saves a bit of text as the call takes fewer args.
Coalesce a few formats.
Convert a few bare printks to pr_cont.
$ size drivers/ata/built-in.o*
558429 73893 117864 750186 b726a drivers/ata/built-in.o.allyesconfig.new
559574 73893 117888 751355 b76fb drivers/ata/built-in.o.allyesconfig.old
149567 14689 4220 168476 2921c drivers/ata/built-in.o.defconfig.new
149851 14689 4220 168760 29338 drivers/ata/built-in.o.defconfig.old
The previously submitted patch was word-wrapped.
This patch adds the IDE-mode SATA DeviceIDs for the Intel Panther
Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
ICH4-L is a variant of ICH4 lacking USB2 functionality and with some
different device IDs.
It is documented in Intel specification update 290745-025, currently
at <http://www.intel.com/assets/pdf/specupdate/290745.pdf>, and is
included in the device ID table for piix.
Now that libata provides proper cross-port EH exclusion. The SIDPR
locking added by commit 213373cf (ata_piix: fix locking around SIDPR
access) is no longer necessary. Remove it.
Now that DIPM can be used independently from HIPM, ata_piix can
support LPM too.
This patch adds the Intel Patsburg (PCH) IDE mode SATA Controller DeviceIDs.
SIDPR window registers are shared across ports and as each access is
done in two steps, accesses to different ports under EH may race.
This primarily is caused by incorrect host locking in EH context and
should be fixed by defining locking requirements for each EH operation
which can be used during EH and enforcing them but for now work around
the problem by adding a dedicated SIDPR lock and grabbing it for each
SIDPR access.
Reported-by: Mark Knecht <markknecht@gmail.com>
Reported-by: Paul Check <paul@thechecks.ca>
Cc: stable@kernel.org
Separate out ata_pci_bmdma_prepare_host() and ata_pci_bmdma_init_one()
from their SFF counterparts. SFF ones no longer try to initialize
BMDMA or set PCI master.
Separate out BMDMA irq handler from SFF irq handler. The misnamed
host_intr() functions are renamed to ata_sff_port_intr() and
ata_bmdma_port_intr(). Common parts are factored into
__ata_sff_port_intr() and __ata_sff_interrupt() and used by sff and
bmdma interrupt routines.
All BMDMA drivers now use ata_bmdma_interrupt() or
ata_bmdma_port_intr() while all non-BMDMA SFF ones use
ata_sff_interrupt() or ata_sff_port_intr().
For now, ata_pci_sff_init_one() uses ata_bmdma_interrupt() as it's
used by both SFF and BMDMA drivers.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
[Ss]ytem => [Ss]ystem
udpate => update
paramters => parameters
orginal => original
Signed-off-by: Thomas Weber <swirl@gmx.li>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Traditional IDE interface sucks in that it doesn't have a reliable IRQ
pending bit, so if the controller raises IRQ while the driver is
expecting it not to, the IRQ won't be cleared and eventually the IRQ
line will be killed by interrupt subsystem. Some controllers have
non-standard mechanism to indicate IRQ pending so that this condition
can be detected and worked around.
This patch adds an optional operation ->sff_irq_check() which will be
called for each port from the ata_sff_interrupt() if an unexpected
interrupt is received. If the operation returns %true,
->sff_check_status() and ->sff_irq_clear() will be cleared for the
port. Note that this doesn't mark the interrupt as handled so it
won't prevent IRQ subsystem from killing the IRQ if this mechanism
fails to clear the spurious IRQ.
This patch also implements ->sff_irq_check() for ata_piix. Note that
this adds slight overhead to shared IRQ operation as IRQs which are
destined for other controllers will trigger extra register accesses to
check whether IDE interrupt is pending but this solves rare screaming
IRQ cases and for some curious reason also helps weird BIOS related
glitch on Samsung n130 as reported in bko#14314.
http://bugzilla.kernel.org/show_bug.cgi?id=14314
* piix_base_ops dropped as suggested by Sergei.
* Spurious IRQ detection doesn't kick in anymore if polling qc is in
progress. This provides less protection but some controllers have
possible data corruption issues if the wrong register is accessed
while a command is in progress.
Reported-by: Johannes Stezenbach <js@sig21.net>
Reported-by: Hans Werner <hwerner4@gmx.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Commit 871af1210f13966ab911ed2166e4ab2ce775b99d enabled 32bit PIO for
PATA piix but didn't for SATA. There's no reason not to use 32bit PIO
on SATA piix. Enable it.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Fix erroneous check for ap->udma_mask in do_pata_set_dmamode()
resulting in controller not being programmed properly for MWDMA.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Commit log for commit 517d3cc15b36392e518abab6bacbb72089658313
("[libata] ata_piix: Enable parallel scan") says:
This patch turns on parallel scanning for the ata_piix driver.
This driver is used on most netbooks (no AHCI for cheap storage it seems).
The scan is the dominating time factor in the kernel boot for these
devices; with this flag it gets cut in half for the device I used
for testing (eeepc).
Alan took a look at the driver source and concluded that it ought to be safe
to do for this driver. Alan has also checked with the hardware team.
and it is all true but once we put all things together additional
constraints for PATA controllers show up (some hardware registers
have per-host not per-port atomicity) and we risk misprogramming
the controller.
I used the following test to check whether the issue is real:
@@ -736,8 +736,20 @@ static void piix_set_piomode(struct ata_
(timings[pio][1] << 8);
pci_write_config_word(dev, master_port, master_data);
- if (is_slave)
+ if (is_slave) {
+ if (ap->port_no == 0) {
+ u8 tmp = slave_data;
+ while (slave_data == tmp) {
+ pci_read_config_byte(dev, slave_port, &tmp);
+ msleep(50);
+ dev_printk(KERN_ERR, &dev->dev, "PATA parallel scan "
+ "race detected\n");
pci_write_config_byte(dev, slave_port, slave_data);
/* Ensure the UDMA bit is off - it will be turned back on if
UDMA is selected */
and it indeed triggered the error message.
Lets fix all such races by adding an extra locking to ->set_piomode
and ->set_dmamode methods for PATA controllers.
[ Alan: would be better to take the host lock in libata-core for these
cases so that we fix all the adapters in one swoop. "Looks fine as a
temproary quickfix tho" ]
Cc: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Jeff Garzik <jgarzik@redhat.com>
OriginalAuthor: Tony Espy <espy@canonical.com>
Signed-off-by: Steve Conklin <sconklin@canonical.com>
OriginalAuthor: Michael Frey <michael.frey@canonical.com>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Combined mode pci quirk hacks went away - so the table to keep in sync
no longer exists.
We can't do this for the later ones as they have all sorts of magic boot
time stuff that needs reviewing and the like. However we can do it for the
older ones and it turns out we need to as some IBM docking stations have a
second PIIX series device in them and without this change you can't use it
very well
HP Compaq nc6000 suffers from the double disk spindown issue.
Add it to the broken poweroff DMI list.
Signed-off-by: Ville Syrjala <syrjala@sci.fi>
The Sony TZ90 needs the cable type hardcoding. See bug #12734
See Errata documentation. The recommended workaround is to use PIO4 instead
which will we automatically do by flagging this mode not available.
Signed-off-by: Alan Cox <alan.cox@linux.intel.com>
Sony VGN-BX297XP fails suspend if the controller is powered down when
calling into ACPI suspend. Add the machine to piix_broken_suspend
list.
This problem was reported by GNUtoo@no-log.org on bko#10293.
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Reported-by: GNUtoo@no-log.org
No functional changes in this patch.
Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net>
Samsung DB-P70 somehow botched the first ICH9 SATA port. The board
doesn't expose the first port but somehow SStatus reports link online
while failing SRST protocol leading to repeated probe failures and
thus long boot delay.
Because the BIOS doesn't carry any identifying DMI information, the
port can't be blacklisted safely. Fortunately, the controller does
have subsystem vendor and ID set. It's unclear whether the subsystem
IDs are used only for the board but it can be safely worked around by
disabling SIDPR access and just using SRST works around the problem.
Even when the workaround is triggered on an unaffected board the only
side effect will be missing SCR access.
Reported-by: Joseph Jang <josephjang@gmail.com>
Reported-by: Jonghyon Sohn <mrsohn@gmail.com>
Some notebooks from HP have the problem that their BIOSes attempt to
spin down hard drives before entering ACPI system states S4 and S5.
This leads to a yo-yo effect during system power-off shutdown and the
last phase of hibernation when the disk is first spun down by the
kernel and then almost immediately turned on and off by the BIOS.
This, in turn, may result in shortening the disk's life times.
To prevent this from happening we can blacklist the affected systems
using DMI information.
Blacklist HP 2510p that uses the ata_piix driver.
This matters for some controllers and in one or two cases almost doubles
PIO performance. Add a bmdma32 operations set we can inherit and activate
it for some controllers
Signed-off-by: Alan Cox <alan@redhat.com>
Certain ACPI implementations mess up IOCFG on _STM making libata
detect cable type incorrectly after a suspend/resume cycle. This
patch makes ata_piix save IOCFG on attach, use the saved value for
things which aren't dynamic and restore it on detach so that the next
driver also gets the BIOS initialized value.
This patch contains the following changes.
* makes ich_pata_cable_detect() use saved_iocfg.
* make piix_iocfg_bit18_quirk() take @host and use saved_iocfg.
* hpriv allocation moved upwards to save iocfg before doing anything
else.
This fixes bz#11879. Andreas Mohr reported and diagnosed the problem.
Cc: Andreas Mohr <andi@lisas.de>
Commit
ATA: piix, fix pointer deref on suspend
fixed a possible oops in an ugly manner. Use newly introduced dmi_match()
to make the code pretty again.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Alexandru Romanescu <a_romanescu@yahoo.co.uk>
Cc: Tejun Heo <tj@kernel.org>
I've found this issue in the mmotm 2008-12-02-17-08.
Commit
ata_piix: add borked Tecra M4 to broken suspend list
introduced DMI variables checking, but they can be null, so that
we possibly dereference null.
Check if they are null and avoid checks in that case.
Solves:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
IP: [<ffffffff8043da97>] piix_pci_device_suspend+0x117/0x230
Tecra M4 sometimes forget what it is and reports bogus data via DMI
which makes the machine evade broken suspend matching and thus fail
suspend/resume. This patch updates piix_broken_suspend() such that it
can match such case. As the borked DMI data is a bit generic,
matching many entries to make the match more specific is necessary.
As the usual DMI matching is limited to four entries, this patch uses
hard coded manual matching.
This is reported by Alexandru Romanescu.
Remove excess kernel-doc function parameter notation from drivers/ata/:
Warning(drivers/ata/libata-core.c:1622): Excess function parameter or struct member 'fn' description in 'ata_pio_queue_task'
Warning(drivers/ata/libata-core.c:4655): Excess function parameter or struct member 'err_mask' description in 'ata_qc_complete'
Warning(drivers/ata/ata_piix.c:751): Excess function parameter or struct member 'udma' description in 'do_pata_set_dmamode'
This patch updates the Intel Ibex Peak (PCH) IDE mode SATA Controller DeviceIDs.
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Now that libata has slave_link, there's no need to keep ugly merged
SCR access. Drop it and use slave_link instead. This results in
simpler code and much better separate link handling for master and
slave.
Logically, SCR access ops should take @link; however, there was no
compelling reason to convert all SCR access ops when adding @link
abstraction as there's one-to-one mapping between a port and a non-PMP
link. However, that assumption won't hold anymore with the scheduled
addition of slave link.
Make SCR access ops per-link.
drivers/ata/ata_piix.c:1502:7: warning: symbol 'rc' shadows an earlier one
This patch adds the Intel Ibex Peak (PCH) IDE mode SATA Controller DeviceIDs.
Subsys 106b:00a3 also is the weird apple ich8m which chokes when the
latter two ports are accessed, add it. Reported by Felipe Sere.
Cc: Felipe Sere <dodofxp@gmail.com>
TOSHIBA also used "TECRA M4" in additon to "Tecra M4", add it.
Signed-off-by: Tejun Heo <htejun@gmail.com>
