Commit 871af1210f13966ab911ed2166e4ab2ce775b99d enabled 32bit PIO for
PATA piix but didn't for SATA. There's no reason not to use 32bit PIO
on SATA piix. Enable it.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Fix erroneous check for ap->udma_mask in do_pata_set_dmamode()
resulting in controller not being programmed properly for MWDMA.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Commit log for commit 517d3cc15b36392e518abab6bacbb72089658313
("[libata] ata_piix: Enable parallel scan") says:
This patch turns on parallel scanning for the ata_piix driver.
This driver is used on most netbooks (no AHCI for cheap storage it seems).
The scan is the dominating time factor in the kernel boot for these
devices; with this flag it gets cut in half for the device I used
for testing (eeepc).
Alan took a look at the driver source and concluded that it ought to be safe
to do for this driver. Alan has also checked with the hardware team.
and it is all true but once we put all things together additional
constraints for PATA controllers show up (some hardware registers
have per-host not per-port atomicity) and we risk misprogramming
the controller.
I used the following test to check whether the issue is real:
@@ -736,8 +736,20 @@ static void piix_set_piomode(struct ata_
(timings[pio][1] << 8);
pci_write_config_word(dev, master_port, master_data);
- if (is_slave)
+ if (is_slave) {
+ if (ap->port_no == 0) {
+ u8 tmp = slave_data;
+ while (slave_data == tmp) {
+ pci_read_config_byte(dev, slave_port, &tmp);
+ msleep(50);
+ dev_printk(KERN_ERR, &dev->dev, "PATA parallel scan "
+ "race detected\n");
pci_write_config_byte(dev, slave_port, slave_data);
/* Ensure the UDMA bit is off - it will be turned back on if
UDMA is selected */
and it indeed triggered the error message.
Lets fix all such races by adding an extra locking to ->set_piomode
and ->set_dmamode methods for PATA controllers.
[ Alan: would be better to take the host lock in libata-core for these
cases so that we fix all the adapters in one swoop. "Looks fine as a
temproary quickfix tho" ]
Cc: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Jeff Garzik <jgarzik@redhat.com>
OriginalAuthor: Tony Espy <espy@canonical.com>
Signed-off-by: Steve Conklin <sconklin@canonical.com>
OriginalAuthor: Michael Frey <michael.frey@canonical.com>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Combined mode pci quirk hacks went away - so the table to keep in sync
no longer exists.
We can't do this for the later ones as they have all sorts of magic boot
time stuff that needs reviewing and the like. However we can do it for the
older ones and it turns out we need to as some IBM docking stations have a
second PIIX series device in them and without this change you can't use it
very well
HP Compaq nc6000 suffers from the double disk spindown issue.
Add it to the broken poweroff DMI list.
Signed-off-by: Ville Syrjala <syrjala@sci.fi>
The Sony TZ90 needs the cable type hardcoding. See bug #12734
See Errata documentation. The recommended workaround is to use PIO4 instead
which will we automatically do by flagging this mode not available.
Signed-off-by: Alan Cox <alan.cox@linux.intel.com>
Sony VGN-BX297XP fails suspend if the controller is powered down when
calling into ACPI suspend. Add the machine to piix_broken_suspend
list.
This problem was reported by GNUtoo@no-log.org on bko#10293.
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Reported-by: GNUtoo@no-log.org
No functional changes in this patch.
Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net>
Samsung DB-P70 somehow botched the first ICH9 SATA port. The board
doesn't expose the first port but somehow SStatus reports link online
while failing SRST protocol leading to repeated probe failures and
thus long boot delay.
Because the BIOS doesn't carry any identifying DMI information, the
port can't be blacklisted safely. Fortunately, the controller does
have subsystem vendor and ID set. It's unclear whether the subsystem
IDs are used only for the board but it can be safely worked around by
disabling SIDPR access and just using SRST works around the problem.
Even when the workaround is triggered on an unaffected board the only
side effect will be missing SCR access.
Reported-by: Joseph Jang <josephjang@gmail.com>
Reported-by: Jonghyon Sohn <mrsohn@gmail.com>
Some notebooks from HP have the problem that their BIOSes attempt to
spin down hard drives before entering ACPI system states S4 and S5.
This leads to a yo-yo effect during system power-off shutdown and the
last phase of hibernation when the disk is first spun down by the
kernel and then almost immediately turned on and off by the BIOS.
This, in turn, may result in shortening the disk's life times.
To prevent this from happening we can blacklist the affected systems
using DMI information.
Blacklist HP 2510p that uses the ata_piix driver.
This matters for some controllers and in one or two cases almost doubles
PIO performance. Add a bmdma32 operations set we can inherit and activate
it for some controllers
Signed-off-by: Alan Cox <alan@redhat.com>
Certain ACPI implementations mess up IOCFG on _STM making libata
detect cable type incorrectly after a suspend/resume cycle. This
patch makes ata_piix save IOCFG on attach, use the saved value for
things which aren't dynamic and restore it on detach so that the next
driver also gets the BIOS initialized value.
This patch contains the following changes.
* makes ich_pata_cable_detect() use saved_iocfg.
* make piix_iocfg_bit18_quirk() take @host and use saved_iocfg.
* hpriv allocation moved upwards to save iocfg before doing anything
else.
This fixes bz#11879. Andreas Mohr reported and diagnosed the problem.
Cc: Andreas Mohr <andi@lisas.de>
Commit
ATA: piix, fix pointer deref on suspend
fixed a possible oops in an ugly manner. Use newly introduced dmi_match()
to make the code pretty again.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Alexandru Romanescu <a_romanescu@yahoo.co.uk>
Cc: Tejun Heo <tj@kernel.org>
I've found this issue in the mmotm 2008-12-02-17-08.
Commit
ata_piix: add borked Tecra M4 to broken suspend list
introduced DMI variables checking, but they can be null, so that
we possibly dereference null.
Check if they are null and avoid checks in that case.
Solves:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
IP: [<ffffffff8043da97>] piix_pci_device_suspend+0x117/0x230
Tecra M4 sometimes forget what it is and reports bogus data via DMI
which makes the machine evade broken suspend matching and thus fail
suspend/resume. This patch updates piix_broken_suspend() such that it
can match such case. As the borked DMI data is a bit generic,
matching many entries to make the match more specific is necessary.
As the usual DMI matching is limited to four entries, this patch uses
hard coded manual matching.
This is reported by Alexandru Romanescu.
Remove excess kernel-doc function parameter notation from drivers/ata/:
Warning(drivers/ata/libata-core.c:1622): Excess function parameter or struct member 'fn' description in 'ata_pio_queue_task'
Warning(drivers/ata/libata-core.c:4655): Excess function parameter or struct member 'err_mask' description in 'ata_qc_complete'
Warning(drivers/ata/ata_piix.c:751): Excess function parameter or struct member 'udma' description in 'do_pata_set_dmamode'
This patch updates the Intel Ibex Peak (PCH) IDE mode SATA Controller DeviceIDs.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Now that libata has slave_link, there's no need to keep ugly merged
SCR access. Drop it and use slave_link instead. This results in
simpler code and much better separate link handling for master and
slave.
Logically, SCR access ops should take @link; however, there was no
compelling reason to convert all SCR access ops when adding @link
abstraction as there's one-to-one mapping between a port and a non-PMP
link. However, that assumption won't hold anymore with the scheduled
addition of slave link.
Make SCR access ops per-link.
drivers/ata/ata_piix.c:1502:7: warning: symbol 'rc' shadows an earlier one
This patch adds the Intel Ibex Peak (PCH) IDE mode SATA Controller DeviceIDs.
Subsys 106b:00a3 also is the weird apple ich8m which chokes when the
latter two ports are accessed, add it. Reported by Felipe Sere.
Cc: Felipe Sere <dodofxp@gmail.com>
TOSHIBA also used "TECRA M4" in additon to "Tecra M4", add it.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Add ICH6 on ACER Aspire 1694WLMi to list of laptops that use short cables
rather than 80 wire
OriginalAuthor: Tiago Sousa
OriginalLocation: http://launchpadlibrarian.net/11627664/new.ich_laptop.short.cables.diff
Bug: #187121
Signed-off-by: maximilian attems <max@stro.at>
ICH8M on macbooks are peculiar in that some of them lock up when the
second port is enabled, some return bogus values on SIDPR access while
yet others hang on SIDPR access. Also, the ich8m_apple_sata entry was
wrongly added below generic ich8m entry making it virtually useless.
This patch works around macbook ich8m problems by
* moving ich8m_apple_sata entry above generic ich8m entry
* dropping PIIX_FLAG_SIDPR from ich8m_apple_sata
* adding subsystem 106b:00a1 as ich8m_apple_sata
Reported and tested by MATSUBAYASHI.
Cc: MATSUBAYASHI 'Shaolin' Kohji <shaolin@rhythmaning.org>
On certain configurations (certain macbooks), even though all the
conditions for SIDPR access described in the datasheet are met,
actually reading those registers just returns 0 and have no effect on
write. Verify SIDPR is actually working before enabling it.
This is reported by Ryan Roth in bz#10512.
Cc: Ryan Roth <ryan.roth@ch2m.com>
The drive is directly soldered to the controller, so there is no cable at
all. Remove the 40-wire assumption so the drive can operate at max speed.
Before patch:
$ dd if=/dev/sda of=/dev/null bs=2M count=64 iflag=direct
134217728 bytes (134 MB) copied, 5.29612 s, 25.3 MB/s
After patch:
134217728 bytes (134 MB) copied, 3.94955 s, 34.0 MB/s
Signed-off-by: Dan McGee <dpmcgee@gmail.com>
Implement sata_std_hardreset(), which simply wraps around
sata_link_hardreset(). sata_std_hardreset() becomes new standard
hardreset method for sata_port_ops and sata_sff_hardreset() moves from
ata_base_port_ops to ata_sff_port_ops, which is where it really
belongs.
ata_is_builtin_hardreset() is added so that both
ata_std_error_handler() and ata_sff_error_handler() skip both builtin
hardresets if SCR isn't accessible.
piix_sidpr_hardreset() in ata_piix.c is identical to
sata_std_hardreset() in functionality and got replaced with the
standard function.
sata_sff_hardreset() contains link readiness wait logic which isn't
SFF specific. Move that part into sata_link_hardreset(), which now
takes two more parameters - @online and @check_ready. Both are
optional. The former is out parameter for link onlineness after
reset. The latter is used to wait for link readiness after hardreset.
Users of sata_link_hardreset() is updated to use new funtionality and
ahci_hardreset() is updated to use sata_link_hardreset() instead of
sata_sff_hardreset(). This doesn't really cause any behavior change.
SFF functions have confusing names. Some have sff prefix, some have
bmdma, some std, some pci and some none. Unify the naming by...
* SFF functions which are common to both BMDMA and non-BMDMA are
prefixed with ata_sff_.
* SFF functions which are specific to BMDMA are prefixed with
ata_bmdma_.
* SFF functions which are specific to PCI but apply to both BMDMA and
non-BMDMA are prefixed with ata_pci_sff_.
* SFF functions which are specific to PCI and BMDMA are prefixed with
ata_pci_bmdma_.
* Drop generic prefixes from LLD specific routines. For example,
bfin_std_dev_select -> bfin_dev_select.
The following renames are noteworthy.
ata_qc_issue_prot() -> ata_sff_qc_issue()
ata_pci_default_filter() -> ata_bmdma_mode_filter()
ata_dev_try_classify() -> ata_sff_dev_classify()
This rename is in preparation of separating SFF support out of libata
core layer. This patch strictly renames functions and doesn't
introduce any behavior difference.
ich6_sata_ahci and ich6_sata are identical. Kill ich6_sata_ahci and
drop _ahci postfixes from controller ids, which doesn't really mean
anything at this point.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
ata_piix when attached to ICH6M in AHCI mode doesn't provide any
benefit over using ahci and has detection problems. Don't let
ata_piix claim ICH6M if it's in AHCI mode.
This change makes ICH6R the only one which ata_piix can attach to even
when it's in ahci mode which is necessary as some devices don't work
properly under ahci mode. Drop PIIX_FLAG_AHCI and match the
controller directly so that piix_disable_ahci() is called only for it.
This change makes PIIX_SCC no longer used and it gets dropped too.
This fixes bz 9491.
Cc: Robert M. Albrecht <romal@gmx.de>
Currently reset methods are not specified directly in the
ata_port_operations table. If a LLD wants to use custom reset
methods, it should construct and use a error_handler which uses those
reset methods. It's done this way for two reasons.
First, the ops table already contained too many methods and adding
four more of them would noticeably increase the amount of necessary
boilerplate code all over low level drivers.
Second, as ->error_handler uses those reset methods, it can get
confusing. ie. By overriding ->error_handler, those reset ops can be
made useless making layering a bit hazy.
Now that ops table uses inheritance, the first problem doesn't exist
anymore. The second isn't completely solved but is relieved by
providing default values - most drivers can just override what it has
implemented and don't have to concern itself about higher level
callbacks. In fact, there currently is no driver which actually
modifies error handling behavior. Drivers which override
->error_handler just wraps the standard error handler only to prepare
the controller for EH. I don't think making ops layering strict has
any noticeable benefit.
This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and
their PMP counterparts propoer ops. Default ops are provided in the
base ops tables and drivers are converted to override individual reset
methods instead of creating custom error_handler.
* ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs
aren't accessible. sata_promise doesn't need to use separate
error_handlers for PATA and SATA anymore.
* softreset is broken for sata_inic162x and sata_sx4. As libata now
always prefers hardreset, this doesn't really matter but the ops are
forced to NULL using ATA_OP_NULL for documentation purpose.
* pata_hpt374 needs to use different prereset for the first and second
PCI functions. This used to be done by branching from
hpt374_error_handler(). The proper way to do this is to use
separate ops and port_info tables for each function. Converted.
libata lets low level drivers build ata_port_operations table and
register it with libata core layer. This allows low level drivers
high level of flexibility but also burdens them with lots of
boilerplate entries.
This becomes worse for drivers which support related similar
controllers which differ slightly. They share most of the operations
except for a few. However, the driver still needs to list all
operations for each variant. This results in large number of
duplicate entries, which is not only inefficient but also error-prone
as it becomes very difficult to tell what the actual differences are.
This duplicate boilerplates all over the low level drivers also make
updating the core layer exteremely difficult and error-prone. When
compounded with multi-branched development model, it ends up
accumulating inconsistencies over time. Some of those inconsistencies
cause immediate problems and fixed. Others just remain there dormant
making maintenance increasingly difficult.
To rectify the problem, this patch implements ata_port_operations
inheritance. To allow LLDs to easily re-use their own ops tables
overriding only specific methods, this patch implements poor man's
class inheritance. An ops table has ->inherits field which can be set
to any ops table as long as it doesn't create a loop. When the host
is started, the inheritance chain is followed and any operation which
isn't specified is taken from the nearest ancestor which has it
specified. This operation is called finalization and done only once
per an ops table and the LLD doesn't have to do anything special about
it other than making the ops table non-const such that libata can
update it.
libata provides four base ops tables lower drivers can inherit from -
base, sata, pmp, sff and bmdma. To avoid overriding these ops
accidentaly, these ops are declared const and LLDs should always
inherit these instead of using them directly.
After finalization, all the ops table are identical before and after
the patch except for setting .irq_handler to ata_interrupt in drivers
which didn't use to. The .irq_handler doesn't have any actual effect
and the field will soon be removed by later patch.
* sata_sx4 is still using old style EH and currently doesn't take
advantage of ops inheritance.
libata lets low level drivers build scsi_host_template and register it
to the SCSI layer. This allows low level drivers high level of
flexibility but also burdens them with lots of boilerplate entries.
This patch implements SHT initializers which can be used to initialize
all the boilerplate entries in a sht. Three variants of them are
implemented - BASE, BMDMA and NCQ - for different types of drivers.
Note that entries can be overriden by putting individual initializers
after the helper macro.
All sht tables are identical before and after this patch.
Over the time, port info, ops and sht structures developed quite a bit
of inconsistencies. This patch updates drivers.
* Enable/disable_pm callbacks added to all ahci ops tables.
* Every driver for SFF controllers now uses ata_sff_port_start()
instead of ata_port_start() unless the driver has custom
implementation.
* Every driver for SFF controllers now uses ata_pci_default_filter()
unless the driver has custom implementation.
* Removed an odd port_info->sht initialization from ata_piix.c.
Likely a merge byproduct.
* A port which has ATA_FLAG_SATA set doesn't need to set cable_detect
to ata_cable_sata(). Remove it from via and mv port ops.
* Some drivers had unnecessary .max_sectors initialization which is
ignored and was missing .slave_destroy callback. Fixed.
* Removed unnecessary sht initializations port_info's.
* Removed onsolete scsi device suspend/resume callbacks from
pata_bf54x.
* No reason to set ata_pci_default_filter() and bmdma functions for
PIO-only drivers. Remove those callbacks and replace
ata_bmdma_irq_clear with ata_noop_irq_clear.
* pata_platform sets port_start to ata_dummy_ret0. port_start can
just be set to NULL.
* sata_fsl supports NCQ but was missing qc_defer. Fixed.
* pata_rb600_cf implements dummy port_start. Removed.
During the last step of hibernation in the "platform" mode (with the
help of ACPI) we use the suspend code, including the devices'
->suspend() methods, to prepare the system for entering the ACPI S4
system sleep state.
But at least for some devices the operations performed by the
->suspend() callback in that case must be different from its operations
during regular suspend.
For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and
pass it to the device drivers' ->suspend() methods during the last phase
of hibernation, so that they can distinguish this case and handle it as
appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a
special way and need to handle PM_EVENT_HIBERNATE in the same way.
These changes are necessary to fix a hibernation regression related
to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488).
Acked-by: Pavel Machek <pavel@ucw.cz>
Tested-by: Jeff Chua <jeff.chua.linux@gmail.com>
drivers/ata/ata_piix.c:1655:8: warning: symbol 'rc' shadows an earlier one
drivers/ata/ata_piix.c:1616:6: originally declared here
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch fixes the following section mismatches:
<-- snip -->
WARNING: drivers/ata/built-in.o(.text+0x15072): Section mismatch in reference from the function piix_init_one() to the function .devinit.text:piix_init_sata_map()
WARNING: drivers/ata/built-in.o(.text+0x150dd): Section mismatch in reference from the function piix_init_one() to the function .devinit.text:piix_init_pcs()
WARNING: drivers/ata/built-in.o(.text+0x150e5): Section mismatch in reference from the function piix_init_one() to the function .devinit.text:piix_init_sidpr()
WARNING: drivers/ata/built-in.o(.text+0x15107): Section mismatch in reference from the function piix_init_one() to the function .devinit.text:piix_check_450nx_errata()
<-- snip -->
Signed-off-by: Adrian Bunk <bunk@kernel.org>
piix_merge_scr() can become static.
