path: root/drivers/ata/libata-acpi.c
2011-08-02Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (28 commits) ACPI: delete stale reference in kernel-parameters.txt ACPI: add missing _OSI strings ACPI: remove NID_INVAL thermal: make THERMAL_HWMON implementation fully internal thermal: split hwmon lookup to a separate function thermal: hide CONFIG_THERMAL_HWMON ACPI print OSI(Linux) warning only once ACPI: DMI workaround for Asus A8N-SLI Premium and Asus A8N-SLI DELUX ACPI / Battery: propagate sysfs error in acpi_battery_add() ACPI / Battery: avoid acpi_battery_add() use-after-free ACPI: introduce "acpi_rsdp=" parameter for kdump ACPI: constify ops structs ACPI: fix CONFIG_X86_REROUTE_FOR_BROKEN_BOOT_IRQS ACPI: fix 80 char overflow ACPI / Battery: Resolve the race condition in the sysfs_remove_battery() ACPI / Battery: Add the check before refresh sysfs in the battery_notify() ACPI / Battery: Add the hibernation process in the battery_notify() ACPI / Battery: Rename acpi_battery_quirks2 with acpi_battery_quirks ACPI / Battery: Change 16-bit signed negative battery current into correct value ACPI / Battery: Add the power unit macro ...
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-16ACPI: constify ops structsVasiliy Kulikov
Structs battery_file, acpi_dock_ops, file_operations, thermal_cooling_device_ops, thermal_zone_device_ops, kernel_param_ops are not changed in runtime. It is safe to make them const. register_hotplug_dock_device() was altered to take const "ops" argument to respect acpi_dock_ops' const notion. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-02libata: remove ATA_FLAG_MMIOSergei Shtylyov
Commit 0d5ff566779f894ca9937231a181eb31e4adff0e (libata: convert to iomap) removed all checks of ATA_FLAG_MMIO but neglected to remove the flag itself. Do it now, at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-15gcc-4.6: ACPI: fix unused but set variables in ACPIAndi Kleen
Some minor improvements in error handling, but overall it was mostly dead code. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-28ACPI: replace acpi_integer by u64Lin Ming
acpi_integer is now obsolete and removed from the ACPICA code base, replaced by u64. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-03libata-acpi: missing _SDD is not an errorTejun Heo
Missing _SDD is not an error. Don't treat it as one. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: make gtf_filter per-devTejun Heo
Add ->gtf_filter to ata_device and set it to ata_acpi_gtf_filter when initializing ata_link. This is to allow quirks which apply different gtf filters. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: implement more acpi filtering optionsTejun Heo
Currently libata-acpi can only filter DIPM among SATA feature enables via _GTF. This patch adds the capability to filter out FPDMA non-zero offset, in-order guarantee and auto-activation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: cosmetic updatesTejun Heo
We're about to add more SATA_* and ATA_ACPI_FILTER_* constants. Reformat them in preparation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01libata: add command name parsing for error outputRobert Hancock
This patch improve libata's output for error/notification messages to allow easier comprehension and debugging: When ATAPI commands issued through the SCSI layer fail, use SCSI functions to print the CDB in human-readable form instead of just dumping out the CDB in hex. Print out the name of the failed command (as defined by the ATA specification) in error handling output along with the raw register contents. When reporting status of ACPI taskfile commands executed on resume, also output the names of the commands being executed (or not) in readable form. Since the extra data for printing command names increases kernel size slightly, a config option has been added to allow disabling command name output (as well as some of the error register parsing) for those highly sensitive to kernel text size. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-12trivial: fix typos s/paramter/parameter/ and s/excute/execute/ in ↵Martin Olsson
documentation and source comments. Signed-off-by: Martin Olsson <martin@minimum.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-09Merge branch 'linus' into releaseLen Brown
2008-12-31ACPI: remove private acpica headers from driver filesLin Ming
External driver files should not include any private acpica headers. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-28libata: beef up iteratorsTejun Heo
There currently are the following looping constructs. * __ata_port_for_each_link() for all available links * ata_port_for_each_link() for edge links * ata_link_for_each_dev() for all devices * ata_link_for_each_dev_reverse() for all devices in reverse order Now there's a need for looping construct which is similar to __ata_port_for_each_link() but iterates over PMP links before the host link. Instead of adding another one with long name, do the following cleanup. * Implement and export ata_link_next() and ata_dev_next() which take @mode parameter and can be used to build custom loop. * Implement ata_for_each_link() and ata_for_each_dev() which take looping mode explicitly. The following iteration modes are implemented. * ATA_LITER_EDGE : loop over edge links * ATA_LITER_HOST_FIRST : loop over all links, host link first * ATA_LITER_PMP_FIRST : loop over all links, PMP links first * ATA_DITER_ENABLED : loop over enabled devices * ATA_DITER_ENABLED_REVERSE : loop over enabled devices in reverse order * ATA_DITER_ALL : loop over all devices * ATA_DITER_ALL_REVERSE : loop over all devices in reverse order This change removes exlicit device enabledness checks from many loops and makes it clear which ones are iterated over in which direction. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-23dock: introduce .uevent for devices in dock, eg libataShaohua Li
dock's uevent reported itself, not ata. It might be difficult to find an ata device just according to a dock. This patch introduces docking ops for each device in a dock. when docking, dock driver can send device specific uevent. This should help dock station too (not just bay) Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-09-23libata: remove functions now handed by ACPI dock driverShaohua Li
dock driver can handle ata(bay) hotplug now. dock driver already handles _EJ0 and _STA, so remove them. Also libata doesn't need register notification handler anymore. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-11libata-acpi: don't call sleeping function from invalid contextZhang Rui
The problem is introduced by commit 664d080c41463570b95717b5ad86e79dc1be0877. acpi_evaluate_integer is a sleeping function, and it should not be called with spin_lock_irqsave. https://bugzilla.redhat.com/show_bug.cgi?id=451399 Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-11libata-acpi: filter out DIPM enableTejun Heo
Some BIOSen enable DIPM via _GTF which causes command timeouts under certain configuration. This didn't occur on 2.6.25 because 2.6.25 defaulted to SRST, so _GTF wasn't executed during boot probe, so ahci host reset disabled DIPM and as _GTF wasn't executed after SRST, DIPM wasn't enabled. On 2.6.26, hardreset is used during probe and after probe _GTF is executed enabling DIPM and thus the failures. This patch could theoretically disable DIPM on machines which used to have it enabled on 2.6.25 but AFAIK ahci is currently the only driver which uses SATA ACPI hierarchy (_SDD) and as the host reset would have always disabled DIPM, this shouldn't happen. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-04[libata] ACPI: Properly handle bay devices in dock stationsHolger Macht
* Differentiate between bay devices in dock stations and others: - When an ACPI_NOTIFY_EJECT_REQUEST appears, just signal uevent to userspace (that is when the optional eject button on a bay device is pressed/pulled) giving the possibility to unmount file systems and to clean up. Also, only send uevent in case we get an EJECT_REQUEST without doing anything else. In other cases, you'll get an add/remove event because libata attaches/detaches the device. - In case of a dock event, which in turn signals an ACPI_NOTIFY_EJECT_REQUEST, immediately detach the device, because it may already have been gone * In case of an ACPI_NOTIFY_DEVICE/BUS_CHECK, evaluate _STA to check if the device has been plugged or unplugged. If plugged, hotplug it, if unplugged, just signal event to userspace (initial patch by Matthew Garrett <mjg59@srcf.ucam.org>) * Call ACPI _EJ0 for detached devices Signed-off-by: Holger Macht <hmacht@suse.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-19drivers/ata: trim trailing whitespaceJeff Garzik
2008-05-19Fixups to ATA ACPI hotplugMatthew Garrett
The libata-acpi.c code currently accepts hotplug messages from both the port and the device. This does not match the behaviour of the bay driver, and may result in confusion when two hotplug requests are received for the same device. This patch limits the hotplug notification to removable ACPI devices, which in turn allows it to use the _STA method to determine whether the device has been removed or inserted. On removal, devices are marked as detached. On insertion, a hotplug scan is started. This should avoid lockups caused by the ata layer attempting to scan devices which have been removed. The uevent sending is moved outside the spinlock in order to avoid a warning generated by it firing when interrupts are disabled. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25libata-acpi.c: remove unneeded #if'sAdrian Bunk
These #if's are unneeded since they: - did anyway not handle the CONFIG_ACPI_DOCK_MODULE case correctly and - this is already handled in include/acpi/acpi_drivers.h and - it's now correctly handled in kconfig. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17ata-acpi: don't call _GTF for disabled driveShaohua Li
I got below log after a S3 resume in a ASUS A6VC laptop. The system has only one IDE drive. It appears there is no reason calling _GTF for disabled drive. ACPI Error (dsopcode-0483): Attempt to CreateField of length zero [20070126] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.IDE0.RATA] (Node df822a7c), AE_AML_OPERAND_VALUE ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.IDE0.CHN1.DRV0._GTF] (Node df822bd0), AE_AML_OPERAND_VALUE ata2.00: _GTF evaluation failed (AE 0x3006) ACPI Error (dsopcode-0483): Attempt to CreateField of length zero [20070126] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.IDE0.RATA] (Node df822a7c), AE_AML_OPERAND_VALUE ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.IDE0.CHN1.DRV1._GTF] (Node df822b94), AE_AML_OPERAND_VALUE ata2.01: _GTF evaluation failed (AE 0x3006) Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: implement PMP helpersTejun Heo
Implement helpers to test whether PMP is supported, attached and determine pmp number to use when issuing SRST to a link. While at it, move ata_is_host_link() so that it's together with the two new PMP helpers. This change simplifies LLDs and helps making PMP support optional. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-03-17libata-acpi: improve dock event handlingTejun Heo
Improve ACPI hotplug handling such that dock event is handled properly. * Register handlers for dock events. * Directly detach device on EJECT_REQUEST instead of signaling hotplug event. This prevents libata from accessing severed controller and/or device. * While at it, use named constants for ACPI events and move uevent signaling inside host lock. Original patch and testing by Holger Macht. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Holger Macht <hmacht@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10ata: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: reimplement ata_acpi_cbl_80wire() using ata_acpi_gtm_xfermask()Tejun Heo
Reimplement ata_acpi_cbl_80wire() using ata_acpi_gtm_xfermask() and while at it relocate the function below ata_acpi_gtm_xfermask(). New ata_acpi_cbl_80wire() implementation takes @gtm, in both pata_via and pata_amd, use the initial GTM value. Both are trying to peek initial BIOS configuration, so using initial caching value makes sense. This fixes ACPI part of cable detection in pata_amd which previously always returned 0 because configuring PIO0 during reset clears DMA configuration. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: implement ata_timing_cycle2mode() and use it in libata-acpi and ↵Tejun Heo
pata_acpi libata-acpi is using separate timing tables for transfer modes although libata-core has the complete ata_timing table. Implement ata_timing_cycle2mode() to look for matching mode given transfer type and cycle duration and use it in libata-acpi and pata_acpi to replace private timing tables. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: fix ata_acpi_gtm_xfermask()Tejun Heo
ata_acpi_gtm_xfermask() as separated out from pacpi_discover_modes() has various bugs. Fix them. * The wrong comparison operator is used when finding for matching cycle resulting totally bogus result. * With the comparion operator fixed, boundary condtion handling is clumsy. * Setting of any DMA mask bit set all bits in PIO mask. * MWDMA and UDMA blocks are swapped. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: separate out ata_acpi_gtm_xfermask() from pacpi_discover_modes()Tejun Heo
Finding out matching transfer mode from ACPI GTM values is useful for other purposes too. Separate out the function and timing tables from pata_acpi::pacpi_discover_modes(). Other than checking shared-configuration bit after doing ata_acpi_gtm() in pacpi_discover_modes() which should be safe, this patch doesn't introduce any behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata-acpi: add ACPI _PSx methodShaohua Li
ACPI spec (ver 3.0a, p289) requires IDE power on/off executes ACPI _PSx methods. As recently most PATA drivers use libata, this patch adds _PSx method support in libata. ACPI spec doesn't mention if SATA requires the same _PSx method. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-12-17libata-acpi: implement _GTF command filteringTejun Heo
Implement _GTF command filtering which can be controlled by libata.acpi_filter kernel parameter. Currently SETXFER and LOCK commands are filtered. libata configures transfer mode by itself and _GTF SETXFER commands can potentially disrupt device configuration. _GTM/_STM mechanism can't handle hotplugging too well and when _GTF is executed, controller is in PIO0 rather than the mode _STM configured. Note that detecting SET MAX LOCK requires looking at the previous command. This adds a bit to code complexity. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: improve _GTF execution error handling and reportingTejun Heo
As _GTF commands can't transfer data, device error never signals transfer error. It indicates that the device vetoed the operation, so it's meaningless to retry. This patch makes libata-acpi to report and continue on device errors when executing _GTF commands. Also commands rejected by device don't contribute to the number of _GTF commands executed. While at it, update _GTF execution reporting such that all successful commands are logged at KERN_DEBUG and rename taskfile_load_raw() to ata_acpi_run_tf() for consistency. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: improve ACPI disablingTejun Heo
* If _GTF evalution fails, it's pointless to retry. If nothing else is wrong, just ignore the error. * After disabling ACPI, return success iff the number of executed _GTF command equals zero. Otherwise, tell EH to retry. This change fixes bogus 1 return bug where ata_acpi_on_devcfg() expects the caller to reload IDENTIFY data and continue but the caller interprets it as an error. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: implement dev->gtf_cache and evaluate _GTF right after _STM ↵Tejun Heo
during resume On certain implementations, _GTF evaluation depends on preceding _STM and both can be pretty picky about the configuration. Using _GTM result cached during controller initialization satisfies the most neurotic _STM implementation. However, libata evaluates _GTF after reset during device configuration and the hardware state can be different from what _GTF expects and can cause evaluation failure. This patch adds dev->gtf_cache and updates ata_dev_get_GTF() such that it uses the cached value if available. Cache is cleared with a call to ata_acpi_clear_gtf(). Because for SATA ACPI nodes _GTF must be evaluated after _SDD which can't be done till IDENTIFY is complete, _GTF caching from ata_acpi_on_resume() is used only for IDE ACPI nodes. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: implement and use ata_acpi_init_gtm()Tejun Heo
_GTM fetches currently configured transfer mode while _STM configures controller according to _GTM parameter and prepares transfer mode configuration TFs for _GTF. In many cases _GTM and _STM implementations are quite brittle and can't cope with configuration changed by libata. libata does not depend on ATA ACPI to configure devices. The only reason libata performs _GTM and _STM are to make _GTF evaluation succeed and libata also doesn't care about how _GTF TFs configure transfer mode. It overrides that configuration anyway, so from libata's POV, it doesn't matter what value is feeded to _STM as long as evaluation succeeds for _STM and following _GTF. This patch adds dev->__acpi_init_gtm and store initial _GTM values on host initialization before modified by reset and mode configuration. If the field is valid, ata_acpi_init_gtm() returns pointer to the saved _GTM structure; otherwise, NULL. This saved value is used for _STM during resume and peek at BIOS/firmware programmed initial timing for later use. The accessor is there to make building w/o ACPI easy as dev->__acpi_init doesn't exist if ACPI is not enabled. On driver detach, the initial BIOS configuration is restored by executing _STM with the initial _GTM values such that the next driver can also use the initial BIOS configured values. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: add new hooks ata_acpi_dissociate() and ata_acpi_on_disable()Tejun Heo
Add two hooks - ata_acpi_dissociate() which is called during driver detach after the whole host is shutdown and ata_acpi_on_disable() which is called when a device is disabled. Signed-off-by: Tejun heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-17libata-acpi: adjust constness in ata_acpi_gtm/stm() parametersTejun Heo
* No internal function uses const ata_port. Drop const from @ap. * Make ata_acpi_stm() copy @stm before using it and change @stm to const. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-10libata: Don't fail device revalidation for bad _GTF methodsMatthew Garrett
Experience suggests that the _GTF method may be bad. We currently fail device revalidation in that case, which seems excessive. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-23[libata] checkpatch-inspired cleanupsJeff Garzik
Tackle the relatively sane complaints of checkpatch --file. The vast majority is indentation and whitespace changes, the rest are * #include fixes * printk KERN_xxx prefix addition * BSS/initializer cleanups Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12libata: add @timeout to ata_exec_internal[_sg]()Tejun Heo
Add @timeout argument to ata_exec_internal[_sg](). If 0, default timeout ata_probe_timeout is used. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-core: Expose gtm methods for driver useAlan Cox
Talk to the dark side our driver has to, yes. Much misleading is the data. Store it in a structure we do so that it may be parsed. Signed-off-by: Alan Cox <alan@redhat.com> -- Whats small, old and shouts phrases out of order across mountains ? Yodla.. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: Integrate ACPI-based PATA/SATA hotplug - version 5Matthew Garrett
Modern laptops with hotswap bays still tend to utilise a PATA interface on a SATA bridge, generally with the host controller in some legacy emulation mode rather than AHCI. This means that the existing hotplug code in libata is unable to work. The ACPI specification states that these devices can send notifications when hotswapped, which avoids the need to obtain notification from the controller. This patch uses the existing libata-acpi code and simply registers a notification in order to trigger a rescan whenever the firmware signals an event. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-pmp: extend ACPI support to cover PMPTejun Heo
Extend ata_acpi_associate_sata_port() such that it can handle PMP and call it when PMP is attached and detached. Build breakage when !CONFIG_ATA_ACPI was spotted and fixed by Petr Vandrovec. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] add ACPI cable detect APIAlan Cox
Combined from two Alan Cox patches: 1) libata: ACPI checks for 80wire cable We can use the ACPI mode information with several drivers as a hint to cable type. If the ACPI mode set by the BIOS is faster than UDMA33 then we know the BIOS thinks there are 80wire cables. If it doesn't set such a mode or it has no ACPI method then we get no further information and can rely on existing approaches Introduce the function headers needed. Null it out for non ACPI boxes Signed-off-by: Alan Cox <alan@redhat.com> 2) libata: ACPI checks for 80wire cable Provide actual methods for checking if the ACPI support thinks the cable is 80wire, or doesn't know Signed-off-by: Alan Cox <alan@redhat.com> Combined into a single changeset and Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: implement and use link/device iteratorsTejun Heo
Multiple links and different number of devices per link should be considered to iterate over links and devices. This patch implements and uses link and device iterators - ata_port_for_each_link() and ata_link_for_each_dev() - and ata_link_max_devices(). This change makes a lot of functions iterate over only possible devices instead of from dev 0 to dev ATA_MAX_DEVICES. All such changes have been examined and nothing should be broken. While at it, add a separating comment before device helpers to distinguish them better from link helpers and others. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09libata-acpi: implement _GTM/_STM supportTejun Heo
Implement _GTM/_STM support. acpi_gtm is added to ata_port which stores _GTM parameters over suspend/resume cycle. A new hook ata_acpi_on_suspend() is responsible for storing _GTM parameters during suspend. _STM is executed in ata_acpi_on_resume(). With this change, invoking _GTF is safe on IDE hierarchy and acpi_sata check before _GTF is removed. ata_acpi_gtm() and ata_acpi_stm() implementation is taken from Alan Cox's pata_acpi implementation. ata_acpi_gtm() is fixed such that the result parameter is not shifted by sizeof(union acpi_object). Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
