ATA_DFLAG_DETACH is set
commit 8305f72f952cff21ce8109dc1ea4b321c8efc5af upstream.
During system resume from suspend, this can be observed on ASM1062 PMP
controller:
ata10.01: SATA link down (SStatus 0 SControl 330)
ata10.02: hard resetting link
ata10.02: SATA link down (SStatus 0 SControl 330)
ata10.00: configured for UDMA/133
Kernel panic - not syncing: stack-protector: Kernel
in: sata_pmp_eh_recover+0xa2b/0xa40
CPU: 2 PID: 230 Comm: scsi_eh_9 Tainted: P OE
#49-Ubuntu
Hardware name: System manufacturer System Product
1001 12/10/2017
Call Trace:
dump_stack+0x63/0x8b
panic+0xe4/0x244
? sata_pmp_eh_recover+0xa2b/0xa40
__stack_chk_fail+0x19/0x20
? ahci_do_softreset+0x260/0x260 [libahci]
? ahci_do_hardreset+0x140/0x140 [libahci]
? ata_phys_link_offline+0x60/0x60
? ahci_stop_engine+0xc0/0xc0 [libahci]
sata_pmp_error_handler+0x22/0x30
ahci_error_handler+0x45/0x80 [libahci]
ata_scsi_port_error_handler+0x29b/0x770
? ata_scsi_cmd_error_handler+0x101/0x140
ata_scsi_error+0x95/0xd0
? scsi_try_target_reset+0x90/0x90
scsi_error_handler+0xd0/0x5b0
kthread+0x121/0x140
? scsi_eh_get_sense+0x200/0x200
? kthread_create_worker_on_cpu+0x70/0x70
ret_from_fork+0x22/0x40
Kernel Offset: 0xcc00000 from 0xffffffff81000000
(relocation range: 0xffffffff80000000-0xffffffffbfffffff)
Since sata_pmp_eh_recover_pmp() doens't set rc when ATA_DFLAG_DETACH is
set, sata_pmp_eh_recover() continues to run. During retry it triggers
the stack protector.
Set correct rc in sata_pmp_eh_recover_pmp() to let sata_pmp_eh_recover()
jump to pmp_fail directly.
BugLink: https://bugs.launchpad.net/bugs/1821434
Cc: stable@vger.kernel.org
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Based on 1 normalized pattern(s):
this file is released under the gplv2
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 68 file(s).
Reviewed-by: Armijn Hemel <armijn@tjaldur.nl>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190531190114.292346262@linutronix.de
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
This commit adds the necessary quirk to make the Marvell 4140 SATA PMP
work properly. This PMP doesn't like SRST on port number 4 (the host
port) so this commit marks this port as not supporting SRST.
Signed-off-by: Lior Amsalem <alior@marvell.com>
Reviewed-by: Nadav Haklai <nadavh@marvell.com>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Without the patch the kernel generates the following error.
ata11.15: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
ata11.15: Port Multiplier vendor mismatch '0x197b' != '0x123'
ata11.15: PMP revalidation failed (errno=-19)
ata11.15: failed to recover PMP after 5 tries, giving up
This patch helps to bypass this error and the device becomes
functional.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: <linux-ide@vger.kernel.org>
Fixing support for the Silicon Image 3826 port multiplier, by applying
to it the same quirks applied to the Silicon Image 3726. Specifically
fixes the repeated timeout/reset process which previously afflicted
the 3726, as described from line 290. Slightly based on notes from:
https://bugzilla.redhat.com/show_bug.cgi?id=890237
Signed-off-by: Terry Suereth <terry.suereth@gmail.com>
For some reason, a lot of port-multipliers have issues with softreset.
SIMG [34]7x series port-multipliers have been quite erratic in this
regard. I recall that it was better with some firmware revisions and
the current list of quirks worked fine for a while. I think it got
worse with later firmwares or maybe my test coverage wasn't good
enough. Anyways, HPA is reporting that his 3726 setup suffers SRST
failures and then the PMP gets confused and fails to probe the last
port.
The hope was that we try to stick to the standard as much as possible
and soonish the PMPs and their firmwares will improve in quality, so
the quirk list was kept to minimum. Well, it seems like that's never
gonna happen.
Let's set NO_SRST for all [34]7x PMPs so that whatever remaining
userbase of the device suffer the least. Maybe we should do the same
for 57xx's but unfortunately I don't have any device left to test and
I'm not even sure 57xx's have ever been made widely available, so
let's leave those alone for now.
Reported-by: "H. Peter Anvin" <hpa@zytor.com>
Now that we have the ability to directly glue the ACPI namespace to the
driver model in libata, we don't need the custom code to handle the same
thing. Remove it and migrate the functions over to the new code.
Signed-off-by: Holger Macht <holger@homac.de>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Reenable sending SRST to devices connected behind a Sil3726 PMP.
This allow staggered spinups and handles drives that spins up slowly.
While the drives spin up, the PMP will not accept SRST.
Most controller reissues the reset until the drive is ready, while
some [Sil3124] returns an error.
In ata_eh_error, wait 10s before reset the ATA port and try again.
Signed-off-by: Gwendal Grignou <gwendal@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
They were getting this implicitly by an include of module.h
from device.h -- but we are going to clean that up and break
that include chain, so include export.h explicitly now.
Saves text by removing nearly duplicated text format strings by
creating ata_<foo>_printk functions and printf extension %pV.
ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB)
Format string duplication comes from:
#define ata_link_printk(link, lv, fmt, args...) do { \
if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \
printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \
(link)->pmp , ##args); \
else \
printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \
} while(0)
Coalesce long formats.
$ size drivers/ata/built-in.*
544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o
558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o
141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o
149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Some errors still show up, but the dock works, both drives can be
accessed at the same time
The chip maker and designation is unknown - possibly jmicron JMB350?
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Port multipliers can do DIPM on fan-out links fine. Implement support
for it. Tested w/ SIMG 57xx and marvell PMPs. Both the host and
fan-out links enter power save modes nicely.
SIMG 37xx and 47xx report link offline on SStatus causing EH to detach
the devices. Blacklisted.
This is a scheleton for libata transport class.
All information is read only, exporting information from libata:
- ata_port class: one per ATA port
- ata_link class: one per ATA port or 15 for SATA Port Multiplier
- ata_device class: up to 2 for PATA link, usually one for SATA.
Reviewed-by: Grant Grundler <grundler@google.com>
In 2009, While running "cache read" performance test of drives behind
SII PMP we encountered a "all 5 drives" timeout on more than 30% of the
machines under test. This patch reduces the rate by a factor of about 70.
Low enough that we didn't care to further investigate the issue.
Performance impact with any sort of "normal" use was ~2%+ CPU and less
than 1% throughput degradation. Worst case impact (cached read) was
6% IOPS reduction. This is with NCQ off (q=1) but I believe FIS based
switching enabled in the SATA driver.
The patch disables "Early ACK" in the 3726 port multiplier.
"Early ACK" is issued when device sends a FIS to the host (via PMP)
and the PMP sends an ACK immediately back to the device - well before
the host gets the response. Under worst case IOPs load (cached read
test) and more than 2 PMPs connected to a 4-port SATA controller,
I suspect the time to service all of the PMPs is exceeding the PMPs
ability to keep track of outstanding FIS it owes the Host. Reducing
the number of PMPs to 2 (or 1) reduces the frequency by several orders
of magnitude. Kudos to Gwendal for initial debugging of this issue.
[Any errors in the description are mine, not his.]
Patch is currently in production on Google servers.
Signed-off-by: Grant Grundler <grundler@google.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This small patch is just adding the information for PMP spec 1.2
Signed-off-by: Shane Huang <shane.huang@amd.com>
Add @spd_limit to sata_down_spd_limit() so that the caller can specify
the SPD limit it wants. This parameter doesn't get in the way even
when it's too low. The closest possible limit is applied.
There currently are the following looping constructs.
* __ata_port_for_each_link() for all available links
* ata_port_for_each_link() for edge links
* ata_link_for_each_dev() for all devices
* ata_link_for_each_dev_reverse() for all devices in reverse order
Now there's a need for looping construct which is similar to
__ata_port_for_each_link() but iterates over PMP links before the host
link. Instead of adding another one with long name, do the following
cleanup.
* Implement and export ata_link_next() and ata_dev_next() which take
@mode parameter and can be used to build custom loop.
* Implement ata_for_each_link() and ata_for_each_dev() which take
looping mode explicitly.
The following iteration modes are implemented.
* ATA_LITER_EDGE : loop over edge links
* ATA_LITER_HOST_FIRST : loop over all links, host link first
* ATA_LITER_PMP_FIRST : loop over all links, PMP links first
* ATA_DITER_ENABLED : loop over enabled devices
* ATA_DITER_ENABLED_REVERSE : loop over enabled devices in reverse order
* ATA_DITER_ALL : loop over all devices
* ATA_DITER_ALL_REVERSE : loop over all devices in reverse order
This change removes exlicit device enabledness checks from many loops
and makes it clear which ones are iterated over in which direction.
EH retries were delayed by 5 seconds to ensure that resets don't occur
back-to-back. However, this 5 second delay is superflous or excessive
in many cases. For example, after IDENTIFY times out, there's no
reason to wait five more seconds before retrying.
This patch adds ehc->last_reset timestamp and record the timestamp for
the last reset trial or success and uses it to space resets by
ATA_EH_RESET_COOL_DOWN which is 5 secs and removes unconditional 5 sec
sleeps.
As this change makes inter-try waits often shorter and they're
redundant in nature, this patch also removes the "retrying..."
messages.
While at it, convert explicit rounding up division to DIV_ROUND_UP().
This change speeds up EH in many cases w/o sacrificing robustness.
Signed-off-by: Tejun Heo <htejun@gmail.com>
libata has been using mix of jiffies and msecs for time druations.
This is getting confusing. As writing sub HZ values in jiffies is
PITA and msecs_to_jiffies() can't be used as initializer, unify unit
for all time durations to msecs. So, durations are in msecs and
deadlines are in jiffies. ata_deadline() is added to compute deadline
from a start time and duration in msecs.
While at it, drop now superflous _msec suffix from arguments and
rename @timeout to @deadline if it represents a fixed point in time
rather than duration.
As in sil4726, SRST can't be trusted on sil3726 causing detection
problems under certain configuraitons. I thought it was from the
Config Disk device but apparently not.
PMP notification during reset can make some controllers fail reset
processing and needs to be turned off during resets. PMP attach and
full-revalidation path did this via sata_pmp_configure() but the quick
revalidation wasn't. Move the notification disable code right above
fan-out port recovery so that it's always turned off.
This fixes obscure reset failures.
This timeout was set low because previously PMP register access was
done via polling and register access timeouts could stack up. This is
no longer the case. One timeout will make all following accesses fail
immediately.
In rare cases both marvell and SIMG PMPs need almost a second. Bump
it to 3s.
While at it, rename it to SATA_PMP_RW_TIMEOUT. It's not specific to
SCR access.
Previously reset freeze/thaw handling lived outside of ata_eh_reset()
mainly because the original PMP reset code needed the port frozen
while resetting all the fan-out ports, which is no longer the case.
This patch moves freeze/thaw handling into ata_eh_reset().
@prereset() and @postreset() are now called w/o freezing the port
although @prereset() an be called frozen if the port is frozen prior
to entering ata_eh_reset().
This makes code simpler and will help removing hotplug event related
races.
Implement helpers to test whether PMP is supported, attached and
determine pmp number to use when issuing SRST to a link. While at it,
move ata_is_host_link() so that it's together with the two new PMP
helpers.
This change simplifies LLDs and helps making PMP support optional.
Most of PMP support code is already in libata-pmp.c. All that are in
libata-core.c are sata_pmp_port_ops and EXPORTs. Move them to
libata-pmp.c. Also, collect PMP related prototypes and declarations
in header files and move them right above of SFF stuff.
This change is to make PMP support optional.
If PMP fan-out reset fails and SCR isn't accessible, PMP should be
reset. This used to be tested by sata_pmp_std_hardreset() and
communicated to EH by -ERESTART. However, this logic is generic and
doesn't really have much to do with specific hardreset implementation.
This patch moves SCR access failure detection logic to ata_eh_reset()
where it belongs. As this makes sata_pmp_std_hardreset() identical to
sata_std_hardreset(), the function is killed and replaced with the
standard method.
SError used to be cleared in ->postreset. This has small hotplug race
condition. If a device is plugged in after reset is complete but
postreset hasn't run yet, its hotplug event gets lost when SError is
cleared. This patch makes sata_link_resume() clear SError. This
kills the race condition and makes a lot of sense as some PMP and host
PHYs don't work properly without SError cleared.
This change makes sata_pmp_std_{pre|post}_reset()'s unnecessary as
they become identical to ata_std counterparts. It also simplifies
sata_pmp_hardreset() and ahci_vt8251_hardreset().
sata_link_hardreset()
sata_sff_hardreset() contains link readiness wait logic which isn't
SFF specific. Move that part into sata_link_hardreset(), which now
takes two more parameters - @online and @check_ready. Both are
optional. The former is out parameter for link onlineness after
reset. The latter is used to wait for link readiness after hardreset.
Users of sata_link_hardreset() is updated to use new funtionality and
ahci_hardreset() is updated to use sata_link_hardreset() instead of
sata_sff_hardreset(). This doesn't really cause any behavior change.
Currently reset methods are not specified directly in the
ata_port_operations table. If a LLD wants to use custom reset
methods, it should construct and use a error_handler which uses those
reset methods. It's done this way for two reasons.
First, the ops table already contained too many methods and adding
four more of them would noticeably increase the amount of necessary
boilerplate code all over low level drivers.
Second, as ->error_handler uses those reset methods, it can get
confusing. ie. By overriding ->error_handler, those reset ops can be
made useless making layering a bit hazy.
Now that ops table uses inheritance, the first problem doesn't exist
anymore. The second isn't completely solved but is relieved by
providing default values - most drivers can just override what it has
implemented and don't have to concern itself about higher level
callbacks. In fact, there currently is no driver which actually
modifies error handling behavior. Drivers which override
->error_handler just wraps the standard error handler only to prepare
the controller for EH. I don't think making ops layering strict has
any noticeable benefit.
This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and
their PMP counterparts propoer ops. Default ops are provided in the
base ops tables and drivers are converted to override individual reset
methods instead of creating custom error_handler.
* ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs
aren't accessible. sata_promise doesn't need to use separate
error_handlers for PATA and SATA anymore.
* softreset is broken for sata_inic162x and sata_sx4. As libata now
always prefers hardreset, this doesn't really matter but the ops are
forced to NULL using ATA_OP_NULL for documentation purpose.
* pata_hpt374 needs to use different prereset for the first and second
PCI functions. This used to be done by branching from
hpt374_error_handler(). The proper way to do this is to use
separate ops and port_info tables for each function. Converted.
ata_ehi_schedule_probe() was created to hide details of link-resuming
reset magic. Now that all the softreset workarounds are gone,
scheduling probe is very simple - set probe_mask and request RESET.
Kill ata_ehi_schedule_probe() and open code it. This also increases
consistency as ata_ehi_schedule_probe() couldn't cover individual
device probings so they were open-coded even when the helper existed.
While at it, define ATA_ALL_DEVICES as mask of all possible devices on
a link and always use it when requesting probe on link level for
simplicity and consistency. Setting extra bits in the probe_mask
doesn't hurt anybody.
ATA_EHI_RESUME_LINK has two functions - promote reset to hardreset if
ATA_LFLAG_HRST_TO_RESUME is set and preventing EH from shortcutting
reset action when probing is requested. The former is gone now and
the latter can easily be achieved by making EH to perform at least one
reset if reset is requested, which also makes more sense than
depending on RESUME_LINK flag.
As ATA_EHI_RESUME_LINK was the only EHI reset modifier, this also
kills reset modifier handling.
Now that hardreset is the preferred method of resetting, there's no
need for ATA_LFLAG_HRST_TO_RESUME flag. Kill it.
When both soft and hard resets are available, libata preferred
softreset till now. The logic behind it was to be softer to devices;
however, this doesn't really help much. Rationales for the change:
* BIOS may freeze lock certain things during boot and softreset can't
unlock those. This by itself is okay but during operation PHY event
or other error conditions can trigger hardreset and the device may
end up with different configuration.
For example, after a hardreset, previously unlockable HPA can be
unlocked resulting in different device size and thus revalidation
failure. Similar condition can occur during or after resume.
* Certain ATAPI devices require hardreset to recover after certain
error conditions. On PATA, this is done by issuing the DEVICE RESET
command. On SATA, COMRESET has equivalent effect. The problem is
that DEVICE RESET needs its own execution protocol.
For SFF controllers with bare TF access, it can be easily
implemented but more advanced controllers (e.g. ahci and sata_sil24)
require specialized implementations. Simply using hardreset solves
the problem nicely.
* COMRESET initialization sequence is the norm in SATA land and many
SATA devices don't work properly if only SRST is used. For example,
some PMPs behave this way and libata works around by always issuing
hardreset if the host supports PMP.
Like the above example, libata has developed a number of mechanisms
aiming to promote softreset to hardreset if softreset is not going
to work. This approach is time consuming and error prone.
Also, note that, dependingon how you read the specs, it could be
argued that PMP fan-out ports require COMRESET to start operation.
In fact, all the PMPs on the market except one don't work properly
if COMRESET is not issued to fan-out ports after PMP reset.
* COMRESET is an integral part of SATA connection and any working
device should be able to handle COMRESET properly. After all, it's
the way to signal hardreset during reboot. This is the most used
and recommended (at least by the ahci spec) method of resetting
devices.
So, this patch makes libata prefer hardreset over softreset by making
the following changes.
* Rename ATA_EH_RESET_MASK to ATA_EH_RESET and use it whereever
ATA_EH_{SOFT|HARD}RESET used to be used. ATA_EH_{SOFT|HARD}RESET is
now only used to tell prereset whether soft or hard reset will be
issued.
* Strip out now unneeded promote-to-hardreset logics from
ata_eh_reset(), ata_std_prereset(), sata_pmp_std_prereset() and
other places.
>> Mark Lord wrote:
>>> Tejun, I've added PMP to sata_mv, and am now trying to get it
>>> to work with a Marvell PM attached.
>>> And the behaviour I see is very bizarre.
>>> After hard+soft resets, the PM signature is found,
>>> and libata interrogates the PM registers.
>>> It successfully reads register 0, and then register 1.
>>> But all subsequent registers read out (incorrectly) as zeros.
This behavior has been confirmed by Marvell with a SATA analyzer.
The Marvell port-multiplier apparently likes to see clean HOB
information when accessing PMP registers.
Since sata_mv uses PIO shadow register access, this doesn't happen
automatically, as it might in a more purely FIS-based driver (eg. ahci).
One way to fix this is to flag these commands with ATA_TFLAG_LBA48,
forcing libata to write out the HOB fields with known (zero) values.
Signed-off-by: Saeed Bishara <saeed@marvell.com>
Acked-by: Mark Lord <mlord@pobox.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
4726 hates SRST even on non-config ports. Don't use it.
PMP registers used to be accessed with dedicated accessors ->pmp_read
and ->pmp_write. During reset, those callbacks are called with the
port frozen so they should be able to run without depending on
interrupt delivery. To achieve this, they were implemented polling.
However, as resetting the host port makes the PMP to isolate fan-out
ports until SError.X is cleared, resetting fan-out ports while port is
frozen doesn't buy much additional safety.
This patch updates libata PMP support such that PMP registers are
accessed using regular ata_exec_internal() mechanism and kills
->pmp_read/write() callbacks. The following changes are made.
* PMP access helpers - sata_pmp_read_init_tf(), sata_pmp_read_val(),
sata_pmp_write_init_tf() are folded into sata_pmp_read/write() which
are now standalone PMP register access functions.
* sata_pmp_read/write() returns err_mask instead of rc. This is
consistent with other functions which issue internal commands and
allows more detailed error reporting.
* ahci interrupt handler is modified to ignore BAD_PMP and
spurious/illegal completion IRQs while reset is in progress. These
conditions are expected during reset.
Implement sata_pmp_qc_defer_cmd_switch() - standard qc_defer for
command switching PMP support.
Extend ata_acpi_associate_sata_port() such that it can handle PMP and
call it when PMP is attached and detached.
Build breakage when !CONFIG_ATA_ACPI was spotted and fixed by Petr
Vandrovec.
Cc: Petr Vandrovec <petr@vandrovec.name>
Implement Port Multiplier support. To support PMP, a LLDD has to
supply ops->pmp_read() and pmp_write(). If non-null, ->pmp_attach and
->pmp_detach are called on PMP attach and detach, respectively.
->pmp_read/write() can be called while the port is frozen, so they
must be implemented by polling. This patch supplies several helpers
to ease ->pmp_read/write() implementation.
Also, irq_handler and error_handler must be PMP aware. Most of PMP
aware EH can be done by calling ata_pmp_do_eh() with appropriate
methods. PMP EH uses separate set of reset methods and this patch
implements standard prereset, hardreset and postreset methods.
This patch only implements PMP support. The next patch will integrate
PMP into the reset of libata and thus enable PMP support.
