path: root/drivers/ata/libata-sff.c
2012-03-20ata: remove the second argument of k[un]map_atomic()Cong Wang
Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-01-08libata-sff: use ATAPI_{COD|IO}Sergei Shtylyov
atapi_pio_bytes() uses bare numbers for the ATAPI interrupt reason bits despite these are #define'd in <linux/ata.h>. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-11-17libata: fix build without BMDMAAlexander Beregalov
fix these errors: drivers/ata/libata-sff.c:2538:3: error: implicit declaration of function 'ata_pci_bmdma_prepare_host' drivers/ata/libata-sff.c:2549:40: error: 'ata_bmdma_interrupt' undeclared (first use in this function) Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-10-31ide/ata: Add module.h to the implicit modular usersPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in the ide dir are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-14libata: make ata_sff_data_xfer_noirq() work with 32-bit PIOBartlomiej Zolnierkiewicz
Always use ata_sff_data_xfer32() in ata_sff_data_xfer_noirq() so the latter can be also used for host controllers supporting 32-bit PIO operations. It is a completely safe thing to do because if 32-bit PIO is not supported or enabled ata_sff_data_xfer32() will fallback to a standard method. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-10-14libata: reduce ata_pci_[sff,bmdma]_init_one() sizeBartlomiej Zolnierkiewicz
Turn both helpers (which are used only during LLDs initialization time and thus are not performance sensitive) into wrappers around the new ata_pci_init_one() function, this cuts 20 LOC and saves ~1.1k of the output code size (x86-64): text data bss dec hex filename 21392 0 19 21411 53a3 drivers/ata/libata-sff.o.before 20256 0 19 20275 4f33 drivers/ata/libata-sff.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-10-07libata: clear PIO pad areaTejun Heo
ata_sff_data_xfer[32]() use pad area if the transfer size isn't multiple of transfer size; however, this area wasn't cleared and garbage data in pad area could be transferred to the device. Make sure the pad area is cleared. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Lei Ming <tom.leiming@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-07-23[libata] Prevent warning during PMP error recoveryGwendal Grignou
Cleanup sff_pio_task_link when a command is cancel while the pio_task thread has been scheduled. Signed-off-by: Gwendal Grignou <gwendal@google.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert dev_printk(KERN_<LEVEL> to dev_<level>(Joe Perches
Saves a bit of text as the call takes fewer args. Coalesce a few formats. Convert a few bare printks to pr_cont. $ size drivers/ata/built-in.o* text data bss dec hex filename 558429 73893 117864 750186 b726a drivers/ata/built-in.o.allyesconfig.new 559574 73893 117888 751355 b76fb drivers/ata/built-in.o.allyesconfig.old 149567 14689 4220 168476 2921c drivers/ata/built-in.o.defconfig.new 149851 14689 4220 168760 29338 drivers/ata/built-in.o.defconfig.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-05-14libata-sff: prevent irq descriptions for dummy portsJames Bottomley
This is a cosmetic change to prevent libata-sff adding irq descriptions to dummy ports, since the information, while largely unused, is erroneous. Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-14libata-sff: add ata_sff_queue_work() & ata_sff_queue_delayed_work()Viresh Kumar
This patch adds ata_sff_queue_work() & ata_sff_queue_delayed_work() routine in libata-sff.c file. This routine can be used by ata drivers to use ata_sff_wq. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-02[libata] trivial: trim trailing whitespace for drivers/ata/*.[ch]Jeff Garzik
2011-01-07Merge branch 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits) usb: don't use flush_scheduled_work() speedtch: don't abuse struct delayed_work media/video: don't use flush_scheduled_work() media/video: explicitly flush request_module work ioc4: use static work_struct for ioc4_load_modules() init: don't call flush_scheduled_work() from do_initcalls() s390: don't use flush_scheduled_work() rtc: don't use flush_scheduled_work() mmc: update workqueue usages mfd: update workqueue usages dvb: don't use flush_scheduled_work() leds-wm8350: don't use flush_scheduled_work() mISDN: don't use flush_scheduled_work() macintosh/ams: don't use flush_scheduled_work() vmwgfx: don't use flush_scheduled_work() tpm: don't use flush_scheduled_work() sonypi: don't use flush_scheduled_work() hvsi: don't use flush_scheduled_work() xen: don't use flush_scheduled_work() gdrom: don't use flush_scheduled_work() ... Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c as per Tejun.
2010-12-24libata-sff: fix HSM_ST_ERR handling in __ata_sff_port_intr()Tejun Heo
While separating out BMDMA irq handler from SFF, commit c3b28894 (libata-sff: separate out BMDMA irq handler) incorrectly made __ata_sff_port_intr() consider an IRQ to be an idle one if the host state was transitioned to HSM_ST_ERR by ata_bmdma_port_intr(). This makes BMDMA drivers ignore IRQs reporting host bus error which leads to timeouts instead of triggering EH immediately. Fix it by making __ata_sff_port_intr() consider the IRQ to be an idle one iff the state is HSM_ST_IDLE. This is equivalent to adding HSM_ST_ERR to the "break"ing case but less error-prone. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Antonio Toma <antonio.toma@gmail.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-12-15workqueue: convert cancel_rearming_delayed_work[queue]() users to ↵Tejun Heo
cancel_delayed_work_sync() cancel_rearming_delayed_work[queue]() has been superceded by cancel_delayed_work_sync() quite some time ago. Convert all the in-kernel users. The conversions are completely equivalent and trivial. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: "David S. Miller" <davem@davemloft.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: netdev@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Alex Elder <aelder@sgi.com> Cc: xfs-masters@oss.sgi.com Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: netfilter-devel@vger.kernel.org Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: linux-nfs@vger.kernel.org
2010-10-22Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: remove in_workqueue_context() workqueue: Clarify that schedule_on_each_cpu is synchronous memory_hotplug: drop spurious calls to flush_scheduled_work() shpchp: update workqueue usage pciehp: update workqueue usage isdn/eicon: don't call flush_scheduled_work() from diva_os_remove_soft_isr() workqueue: add and use WQ_MEM_RECLAIM flag workqueue: fix HIGHPRI handling in keep_working() workqueue: add queue_work and activate_work trace points workqueue: prepare for more tracepoints workqueue: implement flush[_delayed]_work_sync() workqueue: factor out start_flush_work() workqueue: cleanup flush/cancel functions workqueue: implement alloc_ordered_workqueue() Fix up trivial conflict in fs/gfs2/main.c as per Tejun
2010-10-21libata: add @ap to ata_wait_register() and introduce ata_msleep()Tejun Heo
Add optional @ap argument to ata_wait_register() and replace msleep() calls with ata_msleep() which take optional @ap in addition to the duration. These will be used to implement EH exclusion. This patch doesn't cause any behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21[libata] Fix section mismatch: ata_sff_exitLuck, Tony
This build error showed up in linux-next tag next-20100820 for ia64: WARNING: vmlinux.o(.init.text+0x4a952): Section mismatch in reference from the function ata_init() to the function .exit.text:ata_sff_exit() The function __init ata_init() references a function __exit ata_sff_exit(). This is often seen when error handling in the init function uses functionality in the exit path. The fix is often to remove the __exit annotation of ata_sff_exit() so it may be used outside an exit section. Sure enough, dropping the __exit fixes the problem. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-11workqueue: add and use WQ_MEM_RECLAIM flagTejun Heo
Add WQ_MEM_RECLAIM flag which currently maps to WQ_RESCUER, mark WQ_RESCUER as internal and replace all external WQ_RESCUER usages to WQ_MEM_RECLAIM. This makes the API users express the intent of the workqueue instead of indicating the internal mechanism used to guarantee forward progress. This is also to make it cleaner to add more semantics to WQ_MEM_RECLAIM. For example, if deemed necessary, memory reclaim workqueues can be made highpri. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Steven Whitehouse <swhiteho@redhat.com>
2010-09-09libata-sff: Reenable Port Multiplier after libata-sff remodeling.Gwendal Grignou
Keep track of the link on the which the current request is in progress. It allows support of links behind port multiplier. Not all libata-sff is PMP compliant. Code for native BMDMA controller does not take in accound PMP. Tested on Marvell 7042 and Sil7526. Signed-off-by: Gwendal Grignou <gwendal@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09libata,pata_via: revert ata_wait_idle() removal from ata_sff/via_tf_load()Tejun Heo
Commit 978c0666 (libata: Remove excess delay in the tf_load path) removed ata_wait_idle() from ata_sff_tf_load() and via_tf_load(). This caused obscure detection problems in sata_sil. https://bugzilla.kernel.org/show_bug.cgi?id=16606 The commit was pure performance optimization. Revert it for now. Reported-by: Dieter Plaetinck <dieter@plaetinck.be> Reported-by: Jan Beulich <JBeulich@novell.com> Bisected-by: gianluca <gianluca@sottospazio.it> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-08-25libata-sff: remove harmful BUG_ON from ata_bmdma_qc_issueMark Lord
Remove harmful BUG_ON() from ata_bmdma_qc_issue(), as it casts too wide of a net and breaks sata_mv. It also crashes the kernel while doing the BUG_ON(). There's already a WARN_ON_ONCE() further down to catch the case of POLLING for a BMDMA operation. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: stable@kernel.org
2010-07-02libata: take advantage of cmwq and remove concurrency limitationsTejun Heo
libata has two concurrency related limitations. a. ata_wq which is used for polling PIO has single thread per CPU. If there are multiple devices doing polling PIO on the same CPU, they can't be executed simultaneously. b. ata_aux_wq which is used for SCSI probing has single thread. In cases where SCSI probing is stalled for extended period of time which is possible for ATAPI devices, this will stall all probing. #a is solved by increasing maximum concurrency of ata_wq. Please note that polling PIO might be used under allocation path and thus needs to be served by a separate wq with a rescuer. #b is solved by using the default wq instead and achieving exclusion via per-port mutex. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2010-05-25libata-sff: make BMDMA optionalTejun Heo
Make BMDMA optional depending on new config variable CONFIG_ATA_BMDMA. In Kconfig, drivers are grouped into five groups - non-SFF native, SFF w/ custom DMA interface, SFF w/ BMDMA, PIO-only SFF, and generic fallback / legacy ones. Kconfig and Makefile are reorganized according to the groups and ordered alphabetically inside each group. ata_ioports.bmdma_addr and ata_port.bmdma_prd[_dma] are put into CONFIG_ATA_BMDMA, as are all bmdma related ops, variables and functions. This increase the binary size slightly when BMDMA is enabled but on both native-only and PIO-only configurations the size is slightly reduced. Either way, the size difference is insignificant. This change is more meaningful to signify the separation between SFF and BMDMA and as a tool to verify the separation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: separate out BMDMA initTejun Heo
Separate out ata_pci_bmdma_prepare_host() and ata_pci_bmdma_init_one() from their SFF counterparts. SFF ones no longer try to initialize BMDMA or set PCI master. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: separate out BMDMA irq handlerTejun Heo
Separate out BMDMA irq handler from SFF irq handler. The misnamed host_intr() functions are renamed to ata_sff_port_intr() and ata_bmdma_port_intr(). Common parts are factored into __ata_sff_port_intr() and __ata_sff_interrupt() and used by sff and bmdma interrupt routines. All BMDMA drivers now use ata_bmdma_interrupt() or ata_bmdma_port_intr() while all non-BMDMA SFF ones use ata_sff_interrupt() or ata_sff_port_intr(). For now, ata_pci_sff_init_one() uses ata_bmdma_interrupt() as it's used by both SFF and BMDMA drivers. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: ata_sff_irq_clear() is BMDMA specificTejun Heo
ata_sff_irq_clear() is BMDMA specific. Rename it to ata_bmdma_irq_clear(), move it to ata_bmdma_port_ops and make ->sff_irq_clear() optional. Note: ata_bmdma_irq_clear() is actually only needed by ata_piix and possibly by sata_sil. This should be moved to respective low level drivers later. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: separate out BMDMA qc_issueTejun Heo
Separate out ata_bmdma_qc_issue() from ata_sff_qc_issue() such that ata_sff_qc_issue() only deals with non-BMDMA SFF protocols (PIO and nodata) while ata_bmdma_qc_issue() deals with the BMDMA protocols and uses ata_sff_qc_issue() for non-DMA commands. All the users are updated accordingly. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: prd is BMDMA specificTejun Heo
struct ata_prd and ap->prd are BMDMA specific. Add bmdma_ prefix to them and move them inside CONFIG_ATA_SFF. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: ata_sff_[dumb_]qc_prep are BMDMA specificTejun Heo
Both qc_prep functions deal only with BMDMA PRD setup and PIO only SFF drivers don't need them. Rename to ata_bmdma_[dumb_]qc_prep() and relocate. All usages are renamed except for pdc_adma and sata_qstor. Those two drivers are not BMDMA drivers and don't need to call BMDMA qc_prep functions. Calls to ata_sff_qc_prep() in the two drivers are removed. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: separate out BMDMA EHTejun Heo
Some of error handling logic in ata_sff_error_handler() and all of ata_sff_post_internal_cmd() are for BMDMA. Create ata_bmdma_error_handler() and ata_bmdma_post_internal_cmd() and move BMDMA part into those. While at it, change DMA protocol check to ata_is_dma(), fix post_internal_cmd to call ap->ops->bmdma_stop instead of directly calling ata_bmdma_stop() and open code hardreset selection so that ata_std_error_handler() doesn't have to know about sff hardreset. As these two functions are BMDMA specific, there's no reason to check for bmdma_addr before calling bmdma methods if the protocol of the failed command is DMA. sata_mv and pata_mpc52xx now don't need to set .post_internal_cmd to ATA_OP_NULL and pata_icside and sata_qstor don't need to set it to their bmdma_stop routines. ata_sff_post_internal_cmd() becomes noop and is removed. This fixes p3 described in clean-up-BMDMA-initialization patch. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: port_task is SFF specificTejun Heo
port_task is tightly bound to the standard SFF PIO HSM implementation. Using it for any other purpose would be error-prone and there's no such user and if some drivers need such feature, it would be much better off using its own. Move it inside CONFIG_ATA_SFF and rename it to sff_pio_task. The only function which is exposed to the core layer is ata_sff_flush_pio_task() which is renamed from ata_port_flush_task() and now also takes care of resetting hsm_task_state to HSM_ST_IDLE, which is possible as it's now specific to PIO HSM. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: ap->[last_]ctl are SFF specificTejun Heo
ap->[last_]ctl are specific to SFF controllers. Put them inside CONFIG_ATA_SFF and move initialization into ata_sff_port_init(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: rename ap->ops->drain_fifo() to sff_drain_fifo()Tejun Heo
->drain_fifo() is SFF specific. Rename and relocate it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: introduce ata_sff_init/exit() and ata_sff_port_init()Tejun Heo
In preparation of proper SFF/BMDMA separation, introduce ata_sff_init/exit() and ata_sff_port_init(). These functions currently don't do anything. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: clean up BMDMA initializationTejun Heo
When BMDMA initialization failed or BMDMA was not available for whatever reason, bmdma_addr was left at zero and used as an indication that BMDMA shouldn't be used. This leads to the following problems. p1. For BMDMA drivers which don't use traditional BMDMA register, ata_bmdma_mode_filter() incorrectly inhibits DMA modes. Those drivers either have to inherit from ata_sff_port_ops or clear ->mode_filter explicitly. p2. non-BMDMA drivers call into BMDMA PRD table allocation. It doesn't actually allocate PRD table if bmdma_addr is not initialized but is still confusing. p3. For BMDMA drivers which don't use traditional BMDMA register, some methods might not be invoked as expected (e.g. bmdma_stop from ata_sff_post_internal_cmd()). p4. SFF drivers w/ custom DMA interface implement noop BMDMA ops worrying libata core might call into one of them. These problems are caused by the muddy line between SFF and BMDMA and the assumption that all BMDMA controllers initialize bmdma_addr. This patch fixes p1 and p2 by removing the bmdma_addr assumption and moving prd allocation to BMDMA port start. Later patches will fix the remaining issues. This patch improves BMDMA initialization such that * When BMDMA register initialization fails, falls back to PIO instead of failing. ata_pci_bmdma_init() never fails now. * When ata_pci_bmdma_init() falls back to PIO, it clears ap->mwdma_mask and udma_mask instead of depending on ata_bmdma_mode_filter(). This makes ata_bmdma_mode_filter() unnecessary thus resolving p1. * ata_port_start() which actually is BMDMA specific is moved to ata_bmdma_port_start(). ata_port_start() and ata_sff_port_start() are killed. * ata_sff_port_start32() is moved and renamed to ata_bmdma_port_start32(). Drivers which no longer call into PRD table allocation are... pdc_adma, sata_inic162x, sata_qstor, sata_sx4, pata_cmd640 and all drivers which inherit from ata_sff_port_ops. pata_icside sets ->port_start to ATA_OP_NULL as it doesn't need PRD but is a BMDMA controller and doesn't have custom port_start like other such controllers. Note that with the previous patch which makes all and only BMDMA drivers inherit from ata_bmdma_port_ops, this change doesn't break drivers which need PRD table. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-17libata-sff: reorder SFF/BMDMA functionsTejun Heo
Reorder functions such that SFF and BMDMA functions are grouped. While at it, s/BMDMA/SFF in a few comments where it actually meant SFF. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-17libata: kill ATA_FLAG_DISABLEDTejun Heo
ATA_FLAG_DISABLED is only used by drivers which don't use ->error_handler framework and is largely broken. Its only meaningful function is to make irq handlers skip processing if the flag is set, which is largely useless and even harmful as it makes those ports more likely to cause IRQ storms. Kill ATA_FLAG_DISABLED and makes the callers disable attached devices instead. ata_port_probe() and ata_port_disable() which manipulate the flag are also killed. This simplifies condition check in IRQ handlers. While updating IRQ handlers, remove ap NULL check as libata guarantees consecutive port allocation (unoccupied ports are initialized with dummies) and long-obsolete ATA_QCFLAG_ACTIVE check (checked by ata_qc_from_tag()). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14libata-sff: kill unused prototype and make ata_dev_select() staticTejun Heo
ata_irq_on() was renamed to ata_sff_irq_on() and exported a while ago but prototype for the original function lingered in drivers/ata/libata.h. Kill it. Also, ata_dev_select() is only used inside drivers/ata/libata-sff.c. Make it static. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14libata-sff: update bmdma host bus error handlingTejun Heo
* Clearing IRQ from ata_sff_error_handler() is necessary only when the port is gonna be thawed before performing EH actions and some controllers don't like being accessed after certain failure modes until they're reset. Clear IRQ iff the port is being thawed. * When the controller succesfully indicated bus error, the point of thawing doesn't matter. Move thawing inside bmdma part of EH. This is a bit ugly but will ease code reorganization later. * Remove the unneeded ata_sff_sync(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14libata: Remove excess delay in the tf_load pathAlan Cox
We don't need to stall and wait after loading the task file and before issuing a command, so don't do it. This shows up on profiles and is not needed. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14libata: don't flush dcache on slab pagesSebastian Andrzej Siewior
page_mapping() check this via VM_BUG_ON(PageSlab(page)) so we bug here with the according debuging turned on. Future TODO: replace this with a flush_dcache_page_for_pio() API Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: stable@kernel.org
2010-05-14libata: make sff_irq_on() method optionalSergei Shtylyov
Now, with the introduction of the sff_set_devctl() method, we can use it in sff_irq_on() method too -- that way its implementations in 'pata_bf54x' and 'pata_scc' become virtually identical to ata_sff_irq_on(). The sff_irq_on() method now becomes quite superfluous, and the only reason not to remove it completely is the existence of the 'pata_octeon_cf' driver which implements it as an empty function. Just make the method optional then, with ata_sff_irq_on() becoming generic taskfile-bound function, still global for the 'pata_bf54x' driver to be able to call it from its thaw() and postreset() methods. While at it, make the sff_irq_on() method and ata_sff_irq_on() return 'void' as the result is always ignored anyway. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14libata: introduce sff_set_devctl() methodSergei Shtylyov
The set of libata's taskfile access methods is clearly incomplete as it lacks a method to write to the device control register -- which forces drivers like 'pata_bf54x' and 'pata_scc' to implement more "high level" (and more weighty) methods like freeze() and postreset(). So, introduce the optional sff_set_devctl() method which the drivers only have to implement if the standard iowrite8() can't be used (just like the existing sff_check_altstatus() method) and make use of it in the freeze() and postreset() method implementations (I could also have used it in softreset() method but it also reads other taskfile registers without using tf_read() making that quite pointless); this makes freeze() method implementations in the 'pata_bf54x' and 'pata_scc' methods virtually identical to ata_sff_freeze(), so we can get rid of them completely. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-14libata-sff: kill unused ata_bus_reset()Sergei Shtylyov
... since I see no callers of it. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-04-06libata: don't whine on spurious IRQTejun Heo
On configurations where IRQ line is shared with a different controller, spurious IRQs may happen continuously. The message was put there primarily for debugging anyway. Kill it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-23libata-sff: fix spurious IRQ handlingTejun Heo
Commit 27943620cbd960f710a385ff4a538e14ed3f1922 introduced spurious IRQ handling but it has a race condition where valid completion can be lost while trying to clear spurious IRQ leading to occassional command timeouts. This patch improves SFF interrupt handler such that 1. Once BMDMA HSM is stopped, the condition is never considered spurious. As there's no way to resume stopped BMDMA HSM, if device status doesn't agree with BMDMA status, the only way out is aborting the command (otherwise, it will just end up timing out). 2. ap->ops->sff_check_status() can be safely called to clear spurious device IRQ as it atomically returns completion status but BMDMA IRQ status can't be cleared in safe way if command is in flight. After a spurious IRQ, call ap->ops->sff_irq_clear() only if the respective device is idle and retry completion if sff_check_status() indicates command completion. Please note that ata_piix uses bmdma_status for sff_irq_check() and #2 won't weaken spurious IRQ handling even with in-flight command because if bmdma_status indicates IRQ pending but device status is not on spurious check, the next IRQ handler invocation will abort the command due to #1. This fixes bko#15537. https://bugzilla.kernel.org/show_bug.cgi?id=15537 Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andrew Benton <b3nton@gmail.com> Cc: Petr Uzel <petr.uzel@centrum.cz> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
