path: root/drivers/ata/pata_pcmcia.c
2013-03-15drivers/ata: use module_pcmcia_driver() in pcmcia driversH Hartley Sweeten
Use the new module_pcmcia_driver() macro to remove the boilerplate module init/exit code in the pcmcia drivers. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-25drivers/ata/pata_pcmcia.c: adjust suspicious bit operationJulia Lawall
IO_DATA_PATH_WIDTH_8 is 0, so a bit-and with it is always false. The value IO_DATA_PATH_WIDTH covers the bits of the IO_DATA_PATH constants, so first pick those bits and then make the test using !=. This problem was found using Coccinelle (http://coccinelle.lip6.fr/). Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-03-02[libata] trivial: trim trailing whitespace for drivers/ata/*.[ch]Jeff Garzik
2010-09-29pcmcia: move driver name to struct pcmcia_driverDominik Brodowski
Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: use autoconfiguration feature for ioports and iomemDominik Brodowski
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding fields in struct pcmcia_device *p_dev->resource[0,1,2] are set accordinly. Drivers wishing to override certain settings may do so in the callback function, but they no longer need to parse the CIS entries stored in cistpl_cftable_entry_t themselves. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: introduce autoconfiguration featureDominik Brodowski
Introduce an autoconfiguration feature to set certain values in pcmcia_loop_config(), instead of copying the same code over and over in each PCMCIA driver. At first, introduce the following options: CONF_AUTO_CHECK_VCC check or matching Vcc entry CONF_AUTO_SET_VPP set Vpp CONF_AUTO_AUDIO enable the speaker line CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify IntTypeDominik Brodowski
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO (all other drivers). As this flags seems to relate to ioport access, make it conditional to the driver having requested IO port access. There are two drivers which do not request IO ports, but did set INT_MEMORY_AND_IO: ray_cs and b43. For those, we consistently only set INT_MEMORY in future. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move Vpp setup to struct pcmcia_deviceDominik Brodowski
Some drivers prefer to explicitly set Vpp. Instead of passing the voltage inside config_req_t, store it in struct pcmcia_device. CC: linux-ide@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-mtd@lists.infradead.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: linux-usb@vger.kernel.org CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t when calling pcmcia_request_io()Dominik Brodowski
Instead of io_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[0,1] for up to two ioport ranges. After a call to pcmcia_request_io(), the ports found there are reserved, after calling pcmcia_request_configuration(), they may be used. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t after call to pcmcia_request_io()Dominik Brodowski
After pcmcia_request_io(), do not make use of the values stored in io_req_t, but instead use those found in struct pcmcia_device->resource[]. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-20Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (49 commits) libata-sff: separate out BMDMA qc_issue libata-sff: prd is BMDMA specific libata-sff: ata_sff_[dumb_]qc_prep are BMDMA specific libata-sff: separate out BMDMA EH libata-sff: port_task is SFF specific libata-sff: ap->[last_]ctl are SFF specific libata-sff: rename ap->ops->drain_fifo() to sff_drain_fifo() libata-sff: introduce ata_sff_init/exit() and ata_sff_port_init() libata-sff: clean up BMDMA initialization libata-sff: clean up inheritance in several drivers libata-sff: reorder SFF/BMDMA functions sata_inic162x: kill PORT_PRD_ADDR initialization libata: kill ATA_FLAG_DISABLED libata-sff: kill unused prototype and make ata_dev_select() static libata-sff: update bmdma host bus error handling sata_mv: remove unnecessary initialization sata_inic162x: inic162x is not dependent on CONFIG_ATA_SFF pata_sch: use ata_pci_sff_init_one() pata_sil680: Do our own exec_command posting libata: Remove excess delay in the tf_load path ...
2010-05-19libata-sff: rename ap->ops->drain_fifo() to sff_drain_fifo()Tejun Heo
->drain_fifo() is SFF specific. Rename and relocate it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-10pata_pcmcia: get rid of extra indirectionDominik Brodowski
We don't need ata_pcmcia_info any more. Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: re-work pcmcia_request_irq()Dominik Brodowski
Instead of the old pcmcia_request_irq() interface, drivers may now choose between: - calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq. - use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will clean up automatically on calls to pcmcia_disable_device() or device ejection. - drivers still not capable of IRQF_SHARED (or not telling us so) may use the deprecated pcmcia_request_exclusive_irq() for the time being; they might receive a shared IRQ nonetheless. CC: linux-bluetooth@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-usb@vger.kernel.org CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-05pata_pcmcia / ide-cs: Fix bad hashes for Transcend and kingston IDsKristoffer Ericson
This patch fixes the bad hashes for one Kingston and one Transcend card. Thanks to komuro for pointing this out. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-04-22pata_pcmcia/ide-cs: add IDs for transcend and kingston cardsKristoffer Ericson
This patch adds idstrings for Kingston 1GB/4GB and Transcend 4GB/8GB. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-01libata: make functions/variables staticRobert Hancock
Make some variables in ahci and a function in pata_pcmcia static, as found using sparse. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-28pcmcia: rework the irq_req_t typedefDominik Brodowski
Most of the irq_req_t typedef'd struct can be re-worked quite easily: (1) IRQInfo2 was unused in any case, so drop it. (2) IRQInfo1 was used write-only, so drop it. (3) Instance (private data to be passed to the IRQ handler): Most PCMCIA drivers using pcmcia_request_irq() to actually register an IRQ handler set the "dev_id" to the same pointer as the "priv" pointer in struct pcmcia_device. Modify the two exceptions (ipwireless, ibmtr_cs) to also work this waym and set the IRQ handler's "dev_id" to p_dev->priv unconditionally. (4) Handler is to be of type irq_handler_t. (5) Handler != NULL already tells whether an IRQ handler is present. Therefore, we do not need the IRQ_HANDLER_PRESENT flag in irq_req_t.Attributes. CC: netdev@vger.kernel.org CC: linux-bluetooth@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-scsi@vger.kernel.org CC: alsa-devel@alsa-project.org CC: Jaroslav Kysela <perex@perex.cz> CC: Jiri Kosina <jkosina@suse.cz> CC: Karsten Keil <isdn@linux-pingi.de> for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-08pcmcia: use dynamic debug infrastructure, deprecate CS_CHECK (ide)Dominik Brodowski
ide-cs.c is the only PCMCIA device driver making use of CONFIG_PCMCIA_DEBUG, so convert it to use the dynamic debug infrastructure. Also, remove all usages of the CS_CHECK macro and replace them with proper Linux style calling and return value checking. The extra error reporting may be dropped, as the PCMCIA core already complains about any (non-driver-author) errors. CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-07-28pata_pcmcia: add CNF-CDROM-IDWolfram Sang
Fixes this report: http://article.gmane.org/gmane.linux.kernel.pcmcia.devel/2228/ Reported-by: John McGrath <john@john-mcgrath.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] Drain data on errorsAlan Cox
If the device is signalling that there is data to drain after an error we should read the bytes out and throw them away. Without this some devices and controllers get wedged and don't recover. Based on earlier work by Mark Lord Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-11[libata] pata_pcmcia: another memory card supportMarc Pignat
Support for Apacer photo steno pro card. Signed-off-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27ata: Switch all my stuff to a common addressAlan Cox
2008-08-23Merge branches 'pcmcia-config-loop' and 'pcmcia-printk' into pcmciaDominik Brodowski
* pcmcia-config-loop: pcmcia: pcmcia_config_loop() improvement by passing vcc pcmcia: pcmcia_config_loop() default CIS entry handling pcmcia: pcmcia_config_loop() ConfigIndex unification pcmcia: use pcmcia_loop_config in misc pcmcia drivers pcmcia: use pcmcia_loop_config in net pcmcia drivers pcmcia: use pcmcia_loop_config in ISDN pcmcia drivers pcmcia: use pcmcia_loop_config in scsi pcmcia drivers pcmcia: use pcmcia_loop_config in bluetooth drivers pcmcia: use pcmcia_loop_config in pata and ide drivers pcmcia: add pcmcia_loop_config() helper * pcmcia-printk: pcmcia: don't add extra DEBUG cflag pcmcia: remove unused cs_socket_name() definition pcmcia: use dev_printk in module rsrc_nonstatic pcmcia: use dev_printk in module pcmcia pcmcia: use dev_printk in module pcmcia_core pcmcia: use dev_printk and dev_dbg in yenta_socket
2008-08-23pcmcia: pcmcia_config_loop() improvement by passing vccDominik Brodowski
By passing the current Vcc setting to the pcmcia_config_loop callback function, we can remove pcmcia_get_configuration_info() calls from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() default CIS entry handlingDominik Brodowski
Many drivers use the default CIS entry within their pcmcia_config_loop() callback function. Therefore, factor the default CIS entry handling out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() ConfigIndex unificationDominik Brodowski
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in the pcmcia_config_loop() callback function. Therefore, factor it out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: use pcmcia_loop_config in pata and ide driversDominik Brodowski
Use the config loop helper in pata_pcmcia and ide_cs CC: Tejun Heo <htejun@gmail.com> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: uniform device IDs of pata_pcmcia and ide-csDominik Brodowski
Over time, a few differences have accumulated between pata_pcmcia and ide-cs. Fix those. CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-06-20pcmcia: add another pata/ide IDKristoffer Ericson
Addition of Transcend 1GB 45x id so that it is properly detected. [bart: fix typo in ide-cs's ID spotted by Alan Cox] Signed-off-by: William Peters <w1ll14@gmail.com> Signed-off-by: Kristoffer Ericson <Kristoffer_e1@hotmail.com> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-20pcmcia: add an pata/ide IDMatt Reimer
Add an id for: product info: "M-Systems", "CF300", "" manfid: 0x000a, 0x0000 function: 4 (fixed disk) Signed-off-by: Matt Reimer <mreimer@vpop.net> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ata_noop_irq_clear()Tejun Heo
->irq_clear() is used to clear IRQ bit of a SFF controller and isn't useful for drivers which don't use libata SFF HSM implementation. However, it's a required callback and many drivers implement their own noop version as placeholder. This patch implements ata_noop_irq_clear and use it to replace those custom placeholders. Also, SFF drivers which don't support BMDMA don't need to use ata_bmdma_irq_clear(). It becomes noop if BMDMA address isn't initialized. Convert them to use ata_noop_irq_clear(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-01-23pata_pcmcia: convert to new data_xfer prototypeTejun Heo
While merging data_xfer prototype change, pata_pcmcia was left out. Convert it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23pata_pcmcia: Minor cleanups and support for dual channel cardsAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23pata_pcmcia: Add support for dumb 8bit IDE emulationsAlan Cox
2007-10-29[libata] Address some checkpatch-spotted issuesJeff Garzik
2007-10-15[libata] pata_pcmcia: Add additional id string (corsair, 1GB)Kristoffer Ericson
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
