ata_host_alloc_pinfo() assigns the host pointer to the
struct device * drvdata, do not assign it a second time.
The RB532 platform specific irq_to_gpio() implementation has been
removed with commit 832f5dacfa0b ("MIPS: Remove all the uses of
custom gpio.h"). Now the platform uses the generic stub which causes
the following error:
pata-rb532-cf pata-rb532-cf: no GPIO found for irq149
pata-rb532-cf: probe of pata-rb532-cf failed with error -2
Drop the irq_to_gpio() call and get the GPIO number from platform
data instead. After this change, the driver works again:
scsi host0: pata-rb532-cf
ata1: PATA max PIO4 irq 149
ata1.00: CFA: CF 1GB, 20080820, max MWDMA4
ata1.00: 1989792 sectors, multi 0: LBA
ata1.00: configured for PIO4
scsi 0:0:0:0: Direct-Access ATA CF 1GB 0820 PQ: 0\
ANSI: 5
sd 0:0:0:0: [sda] 1989792 512-byte logical blocks: (1.01 GB/971 MiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't\
support DPO or FUA
sda: sda1 sda2
sd 0:0:0:0: [sda] Attached SCSI disk
Fixes: 832f5dacfa0b ("MIPS: Remove all the uses of custom gpio.h")
Cc: Alban Bedel <albeu@free.fr>
Cc: <stable@vger.kernel.org> #v4.3+
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Currently CONFIG_ARCH_HAVE_CUSTOM_GPIO_H is defined for all MIPS
machines, and each machine type provides its own gpio.h. However
only a handful really implement the GPIO API, most just forward
everythings to gpiolib.
The Alchemy machine is notable as it provides a system to allow
implementing the GPIO API at the board level. But it is not used by
any board currently supported, so it can also be removed.
For most machine types we can just remove the custom gpio.h, as well
as the custom wrappers if some exists. Some of the code found in
the wrappers must be moved to the respective GPIO driver.
A few more fixes are need in some drivers as they rely on linux/gpio.h
to provides some machine specific definitions, or used asm/gpio.h
instead of linux/gpio.h for the gpio API.
Signed-off-by: Alban Bedel <albeu@free.fr>
Cc: linux-mips@linux-mips.org
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Florian Fainelli <florian@openwrt.org>
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Joe Perches <joe@perches.com>
Cc: Daniel Walter <dwalter@google.com>
Cc: Sergey Ryazanov <ryazanov.s.a@gmail.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: James Hartley <james.hartley@imgtec.com>
Cc: Andrew Bresticker <abrestic@chromium.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Varka Bhadram <varkabhadram@gmail.com>
Cc: Masanari Iida <standby24x7@gmail.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Michael Buesch <m@bues.ch>
Cc: abdoulaye berthe <berthe.ab@gmail.com>
Cc: linux-ide@vger.kernel.org
Cc: linux-gpio@vger.kernel.org
Cc: linux-input@vger.kernel.org
Cc: netdev@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/10828/
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
This patch converts the drivers in drivers/ata/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: Viresh Kumar <viresh.kumar@st.com>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Sylvain Munaut <tnt@246tNt.com>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Mark Miesfeld <mmiesfeld@amcc.com>
Cc: Ashish Kalra <ashish.kalra@freescale.com>
Scripted with coccinelle.
All checks of ATA_FLAG_NO_LEGACY have been removed by the commits
c791c30670ea61f19eec390124128bf278e854fe ([libata] minor PCI IDE probe
fixes and cleanups) and f0d36efdc624beb3d9e29b9ab9e9537bf0f25d5b (libata:
update libata core layer to use devres), so I think it's time to finally
get rid of this flag...
Commit 0d5ff566779f894ca9937231a181eb31e4adff0e (libata: convert to iomap)
removed all checks of ATA_FLAG_MMIO but neglected to remove the flag itself.
Do it now, at last...
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Use the function resource_size, which reduces the chance of introducing
off-by-one errors in calculating the resource size.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
struct resource *res;
- (res->end - res->start) + 1
+ resource_size(res)
// </smpl>
Cc: Jeff Garzik <jeff@garzik.org>
platform_get_irq() can return -ENXIO, but since 'irq' is an
unsigned int, it does not show when the IRQ resource wasn't found.
Make irq an int so that we can use a single variable to test the
platform_get_irq() return value.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Phil Sutter <n0-1@freewrt.org>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
No functional changes in this patch.
Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net>
I'm not quite sure what freezing and thawing is used for. Tests showed
that the port is being frozen at initialisation state and thawed right
afterwards, then the functions were not called anymore. Dropping the
complete custom code for handling the frozen state seems to work at
least for a standard use case including mounting a partition, copying
some files in it (in parallel) and finally removing them and unmounting
the partition.
The biggest difference between rb532_pata_data_xfer() and
ata_sff_data_xfer32() is the call to ata_sff_pause() at the end of
rb532_pata_data_xfer() which I suppose to be unnecessary since it works
without. I've also tested using ata_sff_data_xfer() as replacement, but
since we know that the driver supports 32bit IO, using the optimised
version should be safe.
The only difference between rb532_pata_exec_command() and
ata_sff_exec_command() is added debugging output, so it can be dropped
and the standard op used instead.
Since the delay used internally is just the same as ata_sff_pause()
uses, rb532_pata_finish_io() does exactly the same as ata_sff_pause()
and thus can be replaced by the later one.
The driver has been tested without the call to set_irq_type at this
point and occurs to work fine, so it should be safe to remove it.
Per definition, this function should return the number of bytes
consumed. As the original parameter "buflen" is being decremented inside
the read/write loop, save it in "retlen" at the beginning.
Acked-by: Sergei Shtyltov <sshtylyov@ru.mvista.com>
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Acked-by: Florian Fainelli <florian@openwrt.org>
The original standalone driver uses a custom address for the error
register. Use it in pata_rb532_cf, too.
Rename two register definitions:
- The address offset 0x0800 in fact is the ATA base, not ATA command
address.
- The offset 0x0C00 is not a regular ATA data address, but a buffered one
allowing 4-byte IO.
- Make ata_sff_altstatus private so nobody uses it by mistake
- Drop the 400nS delay from it
Add
ata_sff_irq_status - encapsulates the IRQ check logic
This function keeps the existing behaviour for altstatus using devices. I
actually suspect the logic was wrong before the changes but -rc isn't the
time to play with that
ata_sff_sync - ensure writes hit the device
Really we want an io* operation for 'is posted' eg ioisposted(ioaddr) so
that we can fix the nasty delay this causes on most systems.
- ata_sff_pause - 400nS delay
Ensure the command hit the device and delay 400nS
- ata_sff_dma_pause
Ensure the I/O hit the device and enforce an HDMA1:0 transition delay.
Requires altstatus register exists, BUG if not so we don't risk
corruption in MWDMA modes. (UDMA the checksum will save your backside in
theory)
The only other complication then is devices with their own handlers.
rb532 can use dma_pause but scc needs to access its own altstatus
register for internal errata workarounds so directly call the drivers own
altstatus function.
Signed-off-by: Alan Cox <alan@redhat.com>
The platform is actually named routerboard 532 so let's call it this. This
patch only rename files, Kconfig and C symbols; no functional changes.
