path: root/drivers/ata/sata_mv.c
2007-10-18[libata] kill ata_sg_is_last()Jeff Garzik
Short term, this works around a bug introduced by early sg-chaining work. Long term, removing this function eliminates a branch from a hot path loop in each scatter/gather table build. Also, as this code demonstrates, we don't need to _track_ the end of the s/g list, as long as we mark it in some way. And doing so programatically is nice. So its a useful cleanup, regardless of its short term effects. Based conceptually on a quick patch by Jens Axboe. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12libata: update ata_dev_try_classify() argumentsTejun Heo
Make ata_dev_try_classify() take a pointer to ata_device instead of ata_port/port_number combination for consistency and add @present argument. @present indicates whether the device seems present during reset. It's the result of TF access during softreset and link onlineness during hardreset. @present will be used to improve diagnostic failure handling. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify resetTejun Heo
Make reset methods and related functions deal with ata_link instead of ata_port. * ata_do_reset() * ata_eh_reset() * all prereset/reset/postreset methods and related functions This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify PHY-related functionsTejun Heo
Make the following PHY-related functions to deal with ata_link instead of ata_port. * sata_print_link_status() * sata_down_spd_limit() * ata_set_sata_spd_limit() and friends * sata_link_debounce/resume() * sata_scr_valid/read/write/write_flush() * ata_link_on/offline() This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] sata_mv: more S/G fixesJeff Garzik
* corruption fix: we only want the lower 16 bits of length (0 == 64kb) * ditto: the upper layer sets max-phys-segments to LIBATA_MAX_PRD, so we must reset it to own hw-specific length. * delete unused mv_fill_sg() return value Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-09sata_mv: correct S/G table limitsJeff Garzik
The recent mv_fill_sg() rewrite, to fix a data corruption problem related to IOMMU virtual merging, forgot to account for the potentially-increased size of the scatter/gather table after its run. Additionally, the DMA boundary is reduced from 0xffffffff to 0xffff to more closely match the needs of mv_fill_sg(). Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-03libata: fix for sata_mv >64KB DMA segmentsOlof Johansson
Fix bug in sata_mv for cases where the IOMMU layer has merged SG entries to larger than 64KB. They need to be split up before being sent to the driver. Just for simplicity's sake, split up at 64K boundary instead of 64K size, since that's what the common code does anyway. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-31[libata] Bump driver versionsJeff Garzik
Bump the versions for drivers that were modified, but had not already had a version number bump. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-15sata_mv: PCI IDs for Hightpoint RocketRaid 1740/1742Alan Cox
Underneath all the HPT packaging, PCI identifiers, binary driver modules and stuff you find that ... Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20libata: make ->scr_read/write callbacks return error codeTejun Heo
Convert ->scr_read/write callbacks to return error code to better indicate failure. This will help handling of SCR_NOTIFICATION. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20libata: improve EH report formattingTejun Heo
Requiring LLDs to format multiple error description messages properly doesn't work too well. Help LLDs a bit by making ata_ehi_push_desc() insert ", " on each invocation. __ata_ehi_push_desc() is the raw version without the automatic separator. While at it, make ehi_desc interface proper functions instead of macros. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20[libata] sata_mv: minor cleanupsJeff Garzik
* trim trailing whitespace * document some flags, registers, and register bits * fix locking around EDMA on/off and configuration * continue replacing "constant OP var" with "var OP constant" * use new pci_try_set_mwi() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20[libata] sata_mv: Micro-optimization and cleanupsJeff Garzik
* Micro-optimization in the EDMA interrupt handling code * s/EDMA_ERR_CRBQ_PAR/EDMA_ERR_CRQB_PAR/ * Document EDMA Error Interrupt Cause register bits Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[libata] sata_mv: use pci_try_set_mwi()Jeff Garzik
Because sometimes in life, it's ok to fail. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits) PCI: Only build PCI syscalls on architectures that want them PCI: limit pci_get_bus_and_slot to domain 0 PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3 PCI: hotplug: pciehp: wait for 1 second after power off slot PCI: pci_set_power_state(): check for PM capabilities earlier PCI: cpci_hotplug: Convert to use the kthread API PCI: add pci_try_set_mwi PCI: pcie: remove SPIN_LOCK_UNLOCKED PCI: ROUND_UP macro cleanup in drivers/pci PCI: remove pci_dac_dma_... APIs PCI: pci-x-pci-express-read-control-interfaces cleanups PCI: Fix typo in include/linux/pci.h PCI: pci_ids, remove double or more empty lines PCI: pci_ids, add atheros and 3com_2 vendors PCI: pci_ids, reorder some entries PCI: i386: traps, change VENDOR to DEVICE PCI: ATM: lanai, change VENDOR to DEVICE PCI: Change all drivers to use pci_device->revision ...
2007-07-12[libata] sata_mv: Fix and clean up per-chip-generation testsJeff Garzik
Due to a mistake in test logic, Gen-IIE chips were being treated as Gen-II chips in some cases. Fix this, and in the process, clean up IS_50XX/IS_60XX tests to the more uniform IS_GEN_{I,II,IIE} tests. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-12[libata] sata_mv: Convert to new exception handling (EH) infrastructureJeff Garzik
This makes hotplug, NCQ, etc. possible, and removes one of the few remaining old-EH drivers. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-12[libata] sata_mv: minor bug fixes, enhancements, and cleanups (prep for new EH)Jeff Garzik
* Continue replacing "CONSTANT & var" tests with "var & CONSTANT" * Don't clear EDMA_CFG_NCQ_GO_ON_ERR on Gen-IIE, where that bit does not exist * Set I/O Id field in descriptor, where present. Appears to work fine on all versions, even though queueing is still disabled. * call pci_set_mwi(), to (a) make sure cacheline size is set properly, and (b) enable MWI transactions * Remove never-used handling of coalescing interrupt bits (these events are always masked) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11[libata] sata_mv: Minor cleanups and renaming, preparing for new EH & NCQJeff Garzik
Minor cleanups, new definitions, and code movement, preparing for upcoming new-EH and NCQ changes. This commit shoult not change behavior at all. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09[libata] sata_mv: print out additional chip info during probeJeff Garzik
Indicate whether this is a Generation-I (50xx), Generation-II (60xx), or Generation-II-E (6042/7042) chip. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-09[libata] Use ATA_UDMAx standard masks when filling driver's udma_mask infoJeff Garzik
The ATA_UDMAx masks are self-documenting, and far better than manually writing in the hex mask. Note that pata_it8213 mask differed from the comment. Added a FIXME there. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-03sata_mv: PCI-ID for Adaptec 1430SA SATA ControllerFlorian Attenberger
Signed-off-by: Florian Attenberger <valdyn@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-24[libata] sata_mv: add TODO listJeff Garzik
2007-05-21libata: bump versionsJeff Garzik
2007-04-28libata: convert the remaining SATA drivers to new init modelTejun Heo
Convert ahci, sata_sil, sata_sil24, sata_svw, sata_qstor, sata_mv, sata_sx4, sata_vsc and sata_inic162x to new init model. Now that host and ap are available during intialization, functions are converted to take either host or ap instead of low level parameters which were inevitable for functions shared between init and other paths. This simplifies code quite a bit. * init_one()'s now follow more consistent init order * ahci_setup_port() and ahci_host_init() collapsed into ahci_init_one() for init order consistency * sata_vsc uses port_info instead of setting fields manually * in sata_svw, k2_board_info converted to port_info (info is now in port flags). port number is honored now. Tested on ICH7/8 AHCI, jmb360, sil3112, 3114, 3124 and 3132. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28[libata] sata_mv: support ->cable_detectJeff Garzik
2007-04-28Support for Marvell 7042 ChipMorrison, Tom
Added Support for Marvell 7042 Chip - 7042 has same capabilities & behavior as 6042. Signed-off-by: Thomas A. Morrison <tmorrison@empirix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28[libata] sata_mv: clean up DMA boundary issues, turn on 64-bit DMAJeff Garzik
The chips covered by sata_mv have a 32-bit DMA boundary they must not cross, not a 64K boundary. We are merely limited to a 64K maximum segment size. Therefore, the DMA scatter/gather table fill code can be greatly simplified, and we need not cut in half the S/G table size as reported to the SCSI layer. Also, the driver forget to turn on 64-bit DMA at the PCI layer. All other data structures (both hardware and software) have been prepped for 64-bit PCI DMA. It was simply never turned on. <fingers crossed> let's see if it still works... Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28[libata] sata_mv: remove extra bracesJeff Garzik
2007-02-26[libata] bump versionsJeff Garzik
Bump versions based on changes submitted during 2.6.21 merge window. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] sata_mv: Fix 50xx irq maskJeff Garzik
IRQ mask bits assumed a 60xx or newer generation chip, which is very wrong for the 50xx series. Luckily both generations shared the per-port interrupt mask bits, leaving only the "misc chip features" bits to be completely mismatched. Fix 50xx by ensuring we only program bits that exist. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[libata] sata_mv: don't touch reserved bits in EDMA config registerJeff Garzik
The code in mv_edma_cfg() reflected its 60xx origins, by doing things [slightly] incorrectly on the older 50xx and newer 6042/7042 chips. Clean up the EDMA configuration setup such that, each chip family carefully initializes its own EDMA setup. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-24sata_mv: fix pci_enable_msi() error handlingTejun Heo
intx should be turned on when pci_enable_msi() fails not when it succeeds. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21libata: s/ap->id/ap->print_id/gTejun Heo
ata_port has two different id fields - id and port_no. id is system-wide 1-based unique id for the port while port_no is 0-based host-wide port number. The former is primarily used to identify the ATA port to the user in printk messages while the latter is used in various places in libata core and LLDs to index the port inside the host. The two fields feel quite similar and sometimes ap->id is used in place of ap->port_no, which is very difficult to spot. This patch renames ap->id to ap->print_id to reduce the possibility of such bugs. Some printk messages are adjusted such that id string (ata%u[.%u]) isn't printed twice and/or to use ata_*_printk() instead of hardcoded id format. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-21SATA: use NULL for ptrsRandy Dunlap
Fix sparse warnings in SATA: drivers/ata/sata_sil.c:342:9: warning: Using plain integer as NULL pointer drivers/ata/sata_mv.c:2056:55: warning: Using plain integer as NULL pointer Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-19sata_mv HighPoint 2310 support (88SX7042)Olof Johansson
With the following patch, my HighPoint 2310 with a Marvell 88SX7042 on it seems to work OK. The controller only has 4 ports, with MV_FLAG_DUAL_HC it seems to init 8 ports and fails miserably at probe time. There are no other devices mapped to that chip, maybe it was just incorrectly specified in the first place? Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-28[libata] PCI ID table cleanup in various driversJeff Garzik
* Use PCI_VDEVICE() macro * const-ify pci_device_id table * standardize list terminator as "{ }" * convert spaces to tab in pci_driver struct (Alan-ism) * various minor whitespace cleanups Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-27[libata] sata_mv: fix oops by filling in missing hookJeff Garzik
Only two of three ata_port_operations structs had a ->data_xfer member, which led to, uh, a lack of data xfer. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-11Merge branch 'upstream-fixes' into upstreamJeff Garzik
Conflicts: drivers/ata/ata_piix.c
2006-08-24libata: Grand renaming.Jeff Garzik
The biggest change is that ata_host_set is renamed to ata_host. * ata_host_set => ata_host * ata_probe_ent->host_flags => ata_probe_ent->port_flags * ata_probe_ent->host_set_flags => ata_probe_ent->_host_flags * ata_host_stats => ata_port_stats * ata_port->host => ata_port->scsi_host * ata_port->host_set => ata_port->host * ata_port_info->host_flags => ata_port_info->flags * ata_(.*)host_set(.*)\(\) => ata_\1host\2() The leading underscore in ata_probe_ent->_host_flags is to avoid reusing ->host_flags for different purpose. Currently, the only user of the field is libata-bmdma.c and probe_ent itself is scheduled to be removed. ata_port->host is reused for different purpose but this field is used inside libata core proper and of different type. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
