Use a single mechanism to show driver version.
Reduces text a tiny bit too.
Remove uses of static int printed_version
Add and use ata_print_version(const struct device *, const char *ver)
and ata_print_version_once.
$ size drivers/ata/built-in.*
544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o
543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o
141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o
141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Saves text by removing nearly duplicated text format strings by
creating ata_<foo>_printk functions and printf extension %pV.
ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB)
Format string duplication comes from:
#define ata_link_printk(link, lv, fmt, args...) do { \
if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \
printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \
(link)->pmp , ##args); \
else \
printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \
} while(0)
Coalesce long formats.
558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o
149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o
Saves a bit of text as the call takes fewer args.
Coalesce a few formats.
Convert a few bare printks to pr_cont.
$ size drivers/ata/built-in.o*
558429 73893 117864 750186 b726a drivers/ata/built-in.o.allyesconfig.new
559574 73893 117888 751355 b76fb drivers/ata/built-in.o.allyesconfig.old
149567 14689 4220 168476 2921c drivers/ata/built-in.o.defconfig.new
149851 14689 4220 168760 29338 drivers/ata/built-in.o.defconfig.old
All checks of ATA_FLAG_NO_LEGACY have been removed by the commits
c791c30670ea61f19eec390124128bf278e854fe ([libata] minor PCI IDE probe
fixes and cleanups) and f0d36efdc624beb3d9e29b9ab9e9537bf0f25d5b (libata:
update libata core layer to use devres), so I think it's time to finally
get rid of this flag...
Commit 0d5ff566779f894ca9937231a181eb31e4adff0e (libata: convert to iomap)
removed all checks of ATA_FLAG_MMIO but neglected to remove the flag itself.
Do it now, at last...
Currently, sata_fsl, mv and nv call ata_qc_complete() multiple times
from their interrupt handlers to indicate completion of NCQ commands.
This limits the visibility the libata core layer has into how commands
are being executed and completed, which is necessary to support IRQ
expecting in generic way. libata already has an interface to complete
multiple commands at once - ata_qc_complete_multiple() which ahci and
sata_sil24 already use.
This patch updates the three drivers to use ata_qc_complete_multiple()
too and updates comments on ata_qc_complete[_multiple]() regarding
their usages with NCQ completions. This change not only provides
better visibility into command execution to the core layer but also
simplifies low level drivers.
* sata_fsl: It already builds done_mask. Conversion is straight
forward.
* sata_mv: mv_process_crpb_response() no longer checks for illegal
completions, it just returns whether the tag is completed or not.
mv_process_crpb_entries() builds done_mask from it and passes it to
ata_qc_complete_multiple() which will check for illegal completions.
* sata_nv adma: Similar to sata_mv. nv_adma_check_cpb() now just
returns the tag status and nv_adma_interrupt() builds done_mask from
it and passes it to ata_qc_complete_multiple().
* sata_nv swncq: It already builds done_mask. Drop unnecessary
illegal transition checks and call ata_qc_complete_multiple().
In the long run, it might be a good idea to make ata_qc_complete()
whine if called when multiple NCQ commands are in flight.
Cc: Ashish Kalra <ashish.kalra@freescale.com>
Cc: Saeed Bishara <saeed@marvell.com>
Cc: Mark Lord <liml@rtr.ca>
Cc: Robert Hancock <hancockr@shaw.ca>
Keep track of the link on the which the current request is in progress.
It allows support of links behind port multiplier.
Not all libata-sff is PMP compliant. Code for native BMDMA controller
does not take in accound PMP.
Tested on Marvell 7042 and Sil7526.
Signed-off-by: Gwendal Grignou <gwendal@google.com>
Fix DSM/TRIM commands in sata_mv (v2).
These need to be issued using old-school "BM DMA",
rather than via the EDMA host queue.
Since the chips don't have proper BM DMA status,
we need to be more careful with setting the ATA_DMA_INTR bit,
since DSM/TRIM often has a long delay between "DMA complete"
and "command complete".
GEN_I chips don't have BM DMA, so no TRIM for them.
Signed-off-by: Mark Lord <mlord@pobox.com>
Cc: stable@kernel.org
Make the following changes to prepare for NCQ command completion
update. Changes made by this patch don't cause any functional
difference.
* sata_fsl_host_intr(): rename the local variable qc_active to
done_mask as that's what it is.
* mv_process_crpb_response(): restructure if clause for easier update.
* nv_adma_interrupt(): drop unnecessary error variable.
* nv_swncq_sdbfis(): drop unnecessary nr_done and return 0 on success.
Typo fix.
* nv_swncq_dmafis(): drop unused return value and return void.
* nv_swncq_host_interrupt(): drop unnecessary return value handling.
Separate out BMDMA irq handler from SFF irq handler. The misnamed
host_intr() functions are renamed to ata_sff_port_intr() and
ata_bmdma_port_intr(). Common parts are factored into
__ata_sff_port_intr() and __ata_sff_interrupt() and used by sff and
bmdma interrupt routines.
All BMDMA drivers now use ata_bmdma_interrupt() or
ata_bmdma_port_intr() while all non-BMDMA SFF ones use
ata_sff_interrupt() or ata_sff_port_intr().
For now, ata_pci_sff_init_one() uses ata_bmdma_interrupt() as it's
used by both SFF and BMDMA drivers.
Now that BMDMA EH ops are separated out from SFF ops, mv5_ops doesn't
have to explicitly reset ->error_handler() and ->post_internal_cmd().
Drop them.
Separate out ata_bmdma_qc_issue() from ata_sff_qc_issue() such that
ata_sff_qc_issue() only deals with non-BMDMA SFF protocols (PIO and
nodata) while ata_bmdma_qc_issue() deals with the BMDMA protocols and
uses ata_sff_qc_issue() for non-DMA commands. All the users are
updated accordingly.
port_task is tightly bound to the standard SFF PIO HSM implementation.
Using it for any other purpose would be error-prone and there's no
such user and if some drivers need such feature, it would be much
better off using its own. Move it inside CONFIG_ATA_SFF and rename it
to sff_pio_task.
The only function which is exposed to the core layer is
ata_sff_flush_pio_task() which is renamed from ata_port_flush_task()
and now also takes care of resetting hsm_task_state to HSM_ST_IDLE,
which is possible as it's now specific to PIO HSM.
When BMDMA initialization failed or BMDMA was not available for
whatever reason, bmdma_addr was left at zero and used as an indication
that BMDMA shouldn't be used. This leads to the following problems.
p1. For BMDMA drivers which don't use traditional BMDMA register,
ata_bmdma_mode_filter() incorrectly inhibits DMA modes. Those
drivers either have to inherit from ata_sff_port_ops or clear
->mode_filter explicitly.
p2. non-BMDMA drivers call into BMDMA PRD table allocation. It
doesn't actually allocate PRD table if bmdma_addr is not
initialized but is still confusing.
p3. For BMDMA drivers which don't use traditional BMDMA register, some
methods might not be invoked as expected (e.g. bmdma_stop from
ata_sff_post_internal_cmd()).
p4. SFF drivers w/ custom DMA interface implement noop BMDMA ops
worrying libata core might call into one of them.
These problems are caused by the muddy line between SFF and BMDMA and
the assumption that all BMDMA controllers initialize bmdma_addr.
This patch fixes p1 and p2 by removing the bmdma_addr assumption and
moving prd allocation to BMDMA port start. Later patches will fix the
remaining issues.
This patch improves BMDMA initialization such that
* When BMDMA register initialization fails, falls back to PIO instead
of failing. ata_pci_bmdma_init() never fails now.
* When ata_pci_bmdma_init() falls back to PIO, it clears
ap->mwdma_mask and udma_mask instead of depending on
ata_bmdma_mode_filter(). This makes ata_bmdma_mode_filter()
unnecessary thus resolving p1.
* ata_port_start() which actually is BMDMA specific is moved to
ata_bmdma_port_start(). ata_port_start() and ata_sff_port_start()
are killed.
* ata_sff_port_start32() is moved and renamed to
ata_bmdma_port_start32().
Drivers which no longer call into PRD table allocation are...
pdc_adma, sata_inic162x, sata_qstor, sata_sx4, pata_cmd640 and all
drivers which inherit from ata_sff_port_ops.
pata_icside sets ->port_start to ATA_OP_NULL as it doesn't need PRD
but is a BMDMA controller and doesn't have custom port_start like
other such controllers.
Note that with the previous patch which makes all and only BMDMA
drivers inherit from ata_bmdma_port_ops, this change doesn't break
drivers which need PRD table.
1. pata_cmd640 is PIO only. Inherit from sff.
2. pata_macio is BMDMA. Inherit from bmdma and drop explicit
bmdma_mode_filter() setting.
3. In sata_mv, unlike mv5, mv6 is BMDMA. Inherit from bmdma and
don't clear ->post_internal_cmd().
4. bf54x and icside are quasi-BMDMA controllers which don't use the
standard BMDMA registers so they don't initialize bmdma_addr and
inherit from sff to avoid the default mode_filter which disables
DMA modes if bmdma_addr is not initialized.
For 2 and 3, this patch makes the drivers explicitly specify
->mode_filter to ATA_OP_NULL while inheriting from ata_bmdma_port_ops.
These will be removed by the next patch.
This patch makes all and only BMDMA drivers inherit from
ata_bmdma_port_ops to ease further SFF/BMDMA separation.
ATA_FLAG_DISABLED is only used by drivers which don't use
->error_handler framework and is largely broken. Its only meaningful
function is to make irq handlers skip processing if the flag is set,
which is largely useless and even harmful as it makes those ports more
likely to cause IRQ storms.
Kill ATA_FLAG_DISABLED and makes the callers disable attached devices
instead. ata_port_probe() and ata_port_disable() which manipulate the
flag are also killed.
This simplifies condition check in IRQ handlers. While updating IRQ
handlers, remove ap NULL check as libata guarantees consecutive port
allocation (unoccupied ports are initialized with dummies) and
long-obsolete ATA_QCFLAG_ACTIVE check (checked by ata_qc_from_tag()).
sata_mv initializes unused ioports fields including bmdma_addr to
NULL. As later changes will conditionalize BMDMA, this makes sata_mv
unnecessarily dependent on BMDMA. Remove the unnecessary
initialization.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
sata_mv: remove pointless NULL test
pata_hpt3x2n: fix clock turnaround
libata: fix reporting of drained bytes when clearing DRQ
sata_mv: add power management support for the PCI controllers.
sata_mv: store the board_idx into the host private data
pata_octeon_cf: use resource_size(), to fix resource sizing bug
libata: use the WRITE_SAME_16 define
sata_mv: move the PCI bar description initialization code
sata_mv: add power management support for the platform driver
sata_mv: support clkdev framework
sata_mv: increase PIO IORDY timeout
Fixed crazy mode-change in merge.
Remove !ap test, where ap is guaranteed not-NULL. Found by way of automated
bug report from Alexander Strakh via "Linux Device Drivers Verification
Project (Svace Detector)"
Signed-off-by: Saeed Bishara <saeed@marvell.com>
This information will be used in the resume function.
The mv_init_host will be used to initialize the host hw on resume.
The PCI bar description need to be initialized only once when the
device probed.
The old value (0xbc) in cycles of the IORDY timeout is suitable for
devices with core clock of 166 MHz, but some SoC controllers have
faster core clocks. The new value will make the IORDY timeout large
enough also for all SoC devices.
Use ARRAY_SIZE macro of kernel api instead.
Signed-off-by: Thiago Farina <tfransosi@gmail.com>
Use excl_link when non NCQ commands are defered, to be sure they are processed
as soon as outstanding commands are completed. It prevents some commands to be
defered indifinitely when using a port multiplier.
Use the function resource_size, which reduces the chance of introducing
off-by-one errors in calculating the resource size.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
struct resource *res;
- (res->end - res->start) + 1
+ resource_size(res)
// </smpl>
Cc: Jeff Garzik <jeff@garzik.org>
host->ports[] always contain pointers to valid port structures since
a "dummy port" structure is used in case if there is no physical port.
This patch takes care of two entries from Dan's list:
drivers/ata/sata_sil.c +535 sil_interrupt(13) warning: variable derefenced before check 'ap'
drivers/ata/sata_mv.c +2517 mv_unexpected_intr(6) warning: variable derefenced before check 'ap'
and of another needless NULL pointer check in pata_octeon_cf.c.
Reported-by: Dan Carpenter <error27@gmail.com>
Cc: corbet@lwn.net
Cc: eteo@redhat.com
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Marvell's new SoC (65 nano) needs different settings for its SATA
PHY registers.
Tested-by: Martin Michlmayr <tbm@cyrius.com>
Workaround for errata SATA#24 in sata_mv.
This errata affects WRITE_MULTI* commands when
the device multi_count produces a DRQ block size >= 4Kbytes.
We work around it here by converting such operations
into ordinary PIO_WRITEs instead.
Note that this might result in a PIO FUA write unavoidably being converted
into a non-FUA write. In practice, any system using FUA is also going to be
using DMA rather than PIO, so this shouldn't affect anyone in the real world.
Tidy up qc->tf accesses in the mv_qc_prep() functions.
sata_mv: shorten register names
sata_mv: workaround errata SATA#13
sata_mv: cosmetic renames
sata_mv: workaround errata SATA#26
sata_mv: workaround errata PCI#7
sata_mv: replace 0x1f with ATA_PIO4 (v2)
sata_mv: fix irq mask races
sata_mv: revert SoC irq breakage
libata: ahci enclosure management bios workaround
ata: Add TRIM infrastructure
ata_piix: VGN-BX297XP wants the controller power up on suspend
libata: Remove some redundant casts from pata_octeon_cf.c
pata_artop: typo
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
Rename a slew of register name constants in sata_mv,
removing the _OFS suffix from them, and shortening some
of them in other ways as well.
Also, bump up the version number to reflect all recent changes.
In theory, no actual changes to the generated code,
other than the version number bump.
Add remainder of workaround for errata SATA#13.
This prevents writes of certain adjacent 32-bit registers
from being combined into single 64-bit writes, which might
fail for the affected registers.
Most of sata_mv is already safe from this issue,
but adding this code to mv_write_cached_reg() will
catch the remaining cases and hopefully prevent future ones.
Add _OFS suffix to more of the register offset names,
for consistency with the rest of the driver.
Also tag the defines for LTMODE and PHY_MODE4 to note
that read-after-write is necessary when updating those regs.
No code changes here.
[NOTE: this commit is undone a few commits later]
Workaround for errata SATA#26.
Prevents accidently putting a drive to sleep when attempting COMRESET,
by ORing 0xf000 with the values written to SCR_CONTROL.
Workaround for 60x1-B2 errata PCI#7.
Write-combining may be unreliable when chip operates in PCI-X mode,
so disable write-combining when in PCI-X mode.
Also, update the errata comments at the top of sata_mv,
and include a note about errata PCI#11.
Cosmetic change: replace .pio_mask=0x1f with .pio_mask=ATA_PIO4 everywhere.
Originally from Erik Inge Bolsø, now reworked for latest sata_mv.
Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net>
Prevent racing on the main interrupt mask during port_start and port_stop.
Otherwise, we end up with IRQs masked on inactive ports,
and hotplug insertions then get missed later on.
Found while debugging (out of tree) target mode operations,
but the bug is present and impacting mainline as well.
This patch should also be considered for -stable.
Revert most of commit 6be96ac1d5e4d913e1f48299db083ada5321803b2,
originally from Lennert Buijtenheck (Marvell) and Saeed Bishara (Marvell),
since that commit causes sata_mv to oops at startup on SOC "Kirkwood".
The SOC variants do not have the hpriv->irq_{cause,mask}_ofs registers,
so don't try to write to them!
Reported-by: Maxime Bizon <mbizon@freebox.fr>
On a timeout call a device specific handler early in the recovery so that
we can complete and process successful commands which timed out due to IRQ
loss or the like rather more elegantly.
[Revised to exclude the timeout handling on a few devices that inherit from
SFF but are not SFF enough to use the default timeout handler]
Signed-off-by: Alan Cox <alan@redhat.com>
For Marvell SoC chips, the HDD LED does not blink when there is
disk I/O if NCQ is enabled. Add a quirk that enables blink mode for
the LED while NCQ is enabled on any port of a SoC host controller.
Normal LED function is restored when NCQ is not enabled on any port.
The code to enable the blink mode is based on earlier code
and suggestions from Frans Pop, Saeed Bishara, and possibly others.
Tested-by: Frans Pop <elendil@planet.nl>
Enable use of the "all ports" IRQ coalescing optimization
for GEN_II / GEN_IIE chips that have dual host-controllers (8-ports).
Currently only the 6081 chip qualifies, but other chips may come along someday.
Rather than each half of the chip having to satisfy a local set of coalescing thresholds,
use of this feature groups all ports together under a single set of thresholds.
Add IRQ coalescing to sata_mv (off by default).
This feature can reduce total interrupt overhead for RAID setups
in some situations, by deferring the interrupt signal until one or both of:
a) a specified io_count (completed SATA commands) is achieved, or
b) a specified time interval elapses after an IO completion.
For now, module parameters are used to set the irq_coalescing_io_count
and irq_coalescing_usecs (timeout) globally. These may eventually
be supplemented with sysfs attributes, so that thresholds can be set
on-the-fly and on a per-chip (or even per-host_controller) basis.
Various cosmetic changes in preparation for the IRQ coalescing feature.
Note that the various MV_IRQ_COAL_* definitions are restored/renamed
in the folloup patch which adds IRQ coalescing to the driver.
