path: root/drivers/ata/sata_sil24.c
2009-09-01sata_sil24: always set protocol override for non-ATAPI data commandsRobert Hancock
The sil24 hardware has a built-in list of commands and associated protocols that gets used by default to decide how to handle a given command. However, if the command is not known to the controller then it presumably assumes it to be a non-data command which then causes protocol mismatch errors if the device ends up requesting data transfer. The new DATA SET MANAGEMENT - Trim command causes this issue since it's a DMA data-out command. Since we should always know best what protocol the command should be using, let's just set the override flag to inform the controller what protocol to use for all non-ATAPI commands with data transfer. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Tested-by: Mark Lord <liml@rtr.ca> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08sata_sil24: remove unused sil24_port_multiplierGrant Grundler
AFAICT, struct sil24_port_multiplier isn't used anywhere. Remove it. Signed-off-by: Grant Grundler <grundler@google.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27sata_sil24: configure max read request size to 4kTejun Heo
Due to request posting limitations, bandwidth of sil3132 is limited to around 120MB/s with the minimum pci-e payload size (128bytes) which is used by most consumer systems. However, write throughput can be slightly (~3%) increased by increasing the max read requeset size. Configure it to 4k which is the maximum supported. This optimization is also done by SIMG's windows driver. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: make SCR access ops per-linkTejun Heo
Logically, SCR access ops should take @link; however, there was no compelling reason to convert all SCR access ops when adding @link abstraction as there's one-to-one mapping between a port and a non-PMP link. However, that assumption won't hold anymore with the scheduled addition of slave link. Make SCR access ops per-link. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04sata_sil24: add DID for another adaptec flavorTejun Heo
There's another DID used for Adaptec card. Add it. Reported by Travis Read. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Travis Read <ics@dark.net.au> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-19sata_sil24: don't use NCQ if marvell 4140 PMP is attachedTejun Heo
When 4140 PMP is attached to sil24, NCQ commands to fan out port 1 and 2 (0 based) often stall if commands are in progress to other ports. I've tried a number of things but can't tell what's going on. It never happens w/ ahci and reportedly sata_mv which can issue NCQ commands to multiple devices simultaneously like sil24 does. Disable NCQ for devices behind 4140 PMP for the time being. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Mark Lord <liml@rtr.ca> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: move link onlineness check out of softreset methodsTejun Heo
Currently, SATA softresets should do link onlineness check before actually performing SRST protocol but it doesn't really belong to softreset. This patch moves onlineness check in softreset to ata_eh_reset() and ata_eh_followup_srst_needed() to clean up code and help future sata_mv changes which need clear separation between SCR and TF accesses. sata_fsl is peculiar in that its softreset really isn't softreset but combination of hardreset and softreset. This patch adds dummy private ->prereset to keep the current behavior but the driver really should implement separate hard and soft resets and return -EAGAIN from hardreset if it should be follwed by softreset. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: kill dead code paths in reset pathTejun Heo
Some code paths which had been made obsolete by recent reset simplification were still around. Kill them. * ata_eh_reset() checked for ATA_DEV_UNKNOWN to determine classification failure. This is no longer applicable. * ata_do_reset() should convert ATA_DEV_UNKNOWN to ATA_DEV_NONE regardless of reset result (e.g. -EAGAIN). * LLDs don't need to convert ATA_DEV_UNKNOWN to ATA_DEV_NONE. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: implement PMP helpersTejun Heo
Implement helpers to test whether PMP is supported, attached and determine pmp number to use when issuing SRST to a link. While at it, move ata_is_host_link() so that it's together with the two new PMP helpers. This change simplifies LLDs and helps making PMP support optional. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: don't use ap->ioaddr in non-SFF driversTejun Heo
ap->ioaddr is to carry addresses for TF and BMDMA registers of a SFF controller, don't abuse it in non-SFF controllers. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: remove check_status from non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->[alt_]check_status(). In fact, no one calls them for non-SFF drivers anymore. Kill them. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: replace tf_read with qc_fill_rtf for non-SFF driversTejun Heo
Now that all SFF stuff is separated out of core layer, core layer doesn't call ops->tf_read directly. It gets called only via ops->qc_fill_rtf() for non-SFF drivers. This patch directly implements private ops->qc_fill_rtf() for non-SFF controllers and kill ops->tf_read(). This is much cleaner for non-SFF controllers as some of them have to cache SFF register values in private data structure and report the cached values via ops->tf_read(). Also, ops->tf_read() gets nasty for controllers which don't have clear notion of TF registers when operation is not in progress. As this change makes default ops->qc_fill_rtf unnecessary, move ata_sff_qc_fill_rtf() form ata_base_port_ops to ata_sff_port_ops where it belongs. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: drop @finish_qc from ata_qc_complete_multiple()Tejun Heo
ata_qc_complete_multiple() took @finish_qc and called it on every qc before completing it. This was to give opportunity to update TF cache before ata_qc_complete() tries to fill result_tf. Now that result TF is a separate operation, this is no longer necessary. Update sata_sil24, which was the only user of this mechanism, such that it implements its own ops->qc_fill_rtf() and drop @finish_qc from ata_qc_complete_multiple(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: move PMP SCR access failure during reset to ata_eh_reset()Tejun Heo
If PMP fan-out reset fails and SCR isn't accessible, PMP should be reset. This used to be tested by sata_pmp_std_hardreset() and communicated to EH by -ERESTART. However, this logic is generic and doesn't really have much to do with specific hardreset implementation. This patch moves SCR access failure detection logic to ata_eh_reset() where it belongs. As this makes sata_pmp_std_hardreset() identical to sata_std_hardreset(), the function is killed and replaced with the standard method. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF port opsTejun Heo
Add sff_ prefix to SFF specific port ops. This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames ops and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ata_noop_irq_clear()Tejun Heo
->irq_clear() is used to clear IRQ bit of a SFF controller and isn't useful for drivers which don't use libata SFF HSM implementation. However, it's a required callback and many drivers implement their own noop version as placeholder. This patch implements ata_noop_irq_clear and use it to replace those custom placeholders. Also, SFF drivers which don't support BMDMA don't need to use ata_bmdma_irq_clear(). It becomes noop if BMDMA address isn't initialized. Convert them to use ata_noop_irq_clear(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: kill ATA_LFLAG_SKIP_D2H_BSYTejun Heo
Some controllers can't reliably record the initial D2H FIS after SATA link is brought online for whatever reason. Advanced controllers which don't have traditional TF register based interface often have this problem as they don't really have the TF registers to update while the controller and link are being initialized. SKIP_D2H_BSY works around the problem by skipping the wait for device readiness before issuing SRST, so for such controllers libata issues SRST blindly and hopes for the best. Now that libata defaults to hardreset, this workaround is no longer necessary. For controllers which have support for hardreset, SRST is never issued by itself. It is only issued as follow-up SRST for device classification and PMP initialization, so there's no need to wait for it from prereset. Kill ATA_LFLAG_SKIP_D2H_BSY. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: prefer hardresetTejun Heo
When both soft and hard resets are available, libata preferred softreset till now. The logic behind it was to be softer to devices; however, this doesn't really help much. Rationales for the change: * BIOS may freeze lock certain things during boot and softreset can't unlock those. This by itself is okay but during operation PHY event or other error conditions can trigger hardreset and the device may end up with different configuration. For example, after a hardreset, previously unlockable HPA can be unlocked resulting in different device size and thus revalidation failure. Similar condition can occur during or after resume. * Certain ATAPI devices require hardreset to recover after certain error conditions. On PATA, this is done by issuing the DEVICE RESET command. On SATA, COMRESET has equivalent effect. The problem is that DEVICE RESET needs its own execution protocol. For SFF controllers with bare TF access, it can be easily implemented but more advanced controllers (e.g. ahci and sata_sil24) require specialized implementations. Simply using hardreset solves the problem nicely. * COMRESET initialization sequence is the norm in SATA land and many SATA devices don't work properly if only SRST is used. For example, some PMPs behave this way and libata works around by always issuing hardreset if the host supports PMP. Like the above example, libata has developed a number of mechanisms aiming to promote softreset to hardreset if softreset is not going to work. This approach is time consuming and error prone. Also, note that, dependingon how you read the specs, it could be argued that PMP fan-out ports require COMRESET to start operation. In fact, all the PMPs on the market except one don't work properly if COMRESET is not issued to fan-out ports after PMP reset. * COMRESET is an integral part of SATA connection and any working device should be able to handle COMRESET properly. After all, it's the way to signal hardreset during reboot. This is the most used and recommended (at least by the ahci spec) method of resetting devices. So, this patch makes libata prefer hardreset over softreset by making the following changes. * Rename ATA_EH_RESET_MASK to ATA_EH_RESET and use it whereever ATA_EH_{SOFT|HARD}RESET used to be used. ATA_EH_{SOFT|HARD}RESET is now only used to tell prereset whether soft or hard reset will be issued. * Strip out now unneeded promote-to-hardreset logics from ata_eh_reset(), ata_std_prereset(), sata_pmp_std_prereset() and other places. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-02-19libata: eliminate the home grown dma padding in favour ofJames Bottomley
that provided by the block layer ATA requires that all DMA transfers begin and end on word boundaries. Because of this, a large amount of machinery grew up in ide to adjust scatterlists on this basis. However, as of 2.5, the block layer has a dma_alignment variable which ensures both the beginning and length of a DMA transfer are aligned on the dma_alignment boundary. Although the block layer does adjust the beginning of the transfer to ensure this happens, it doesn't actually adjust the length, it merely makes sure that space is allocated for transfers beyond the declared length. The upshot of this is that scatterlists may be padded to any size between the actual length and the length adjusted to the dma_alignment safely knowing that memory is allocated in this region. Right at the moment, SCSI takes the default dma_aligment which is on a 512 byte boundary. Note that this aligment only applies to transfers coming in from user space. However, since all kernel allocations are automatically aligned on a minimum of 32 byte boundaries, it is safe to adjust them in this manner as well. tj: * Adjusting sg after padding is done in block layer. Make libata set queue alignment correctly for ATAPI devices and drop broken sg mangling from ata_sg_setup(). * Use request->raw_data_len for ATAPI transfer chunk size. * Killed qc->raw_nbytes. * Separated out killing qc->n_iter. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-23libata: convert to chained sgTejun Heo
libata used private sg iterator to handle padding sg. Now that sg can be chained, padding can be handled using standard sg ops. Convert to chained sg. * s/qc->__sg/qc->sg/ * s/qc->pad_sgent/qc->extra_sg[]/. Because chaining consumes one sg entry. There need to be two extra sg entries. The renaming is also for future addition of other extra sg entries. * Padding setup is moved into ata_sg_setup_extra() which is organized in a way that future addition of other extra sg entries is easy. * qc->orig_n_elem is unused and removed. * qc->n_elem now contains the number of sg entries that LLDs should map. qc->mapped_n_elem is added to carry the original number of mapped sgs for unmapping. * The last sg of the original sg list is used to chain to extra sg list. The original last sg is pointed to by qc->last_sg and the content is stored in qc->saved_last_sg. It's restored during ata_sg_clean(). * All sg walking code has been updated. Unnecessary assertions and checks for conditions the core layer already guarantees are removed. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: implement protocol testsTejun Heo
Implement protocol tests - ata_is_atapi(), ata_is_nodata(), ata_is_pio(), ata_is_dma(), ata_is_ncq() and ata_is_data() and use them to replace is_atapi_taskfile() and hard coded protocol tests. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-14sata_sil24: freeze on non-dev errors reported via CERRTejun Heo
CERR reports errors detected during executing a command. This doesn't mean the error is tied to the command and can be recovered by just issuing it again. Many of the errors are fatal port-wide connditions including HSM violation, host bus error and ATA bus error and require freezing and port reset. The freezing part wasn't implemented previously. This used to be okay because port resets were scheduled anyway and EH eventually resets and recovers the port. With PMP support added, this is no longer true. The error condition and recover actions are attributed to the fan-out port and the host port condition isn't properly recovered leading to EH failures. This patch makes CERR errors which require resets to freeze the port. This will force host port reset and proper recovery. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Andrew Ryder <tireman@shaw.ca> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-14sata_sil24: fix stupid typoTejun Heo
Fix stupid typo. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-10sata_sil24: prevent hba lockup when pass-through ATA commands are usedGwendal Grignou
Fix commands timeout with Sil3124/3132 based HBA when pass-through ATA commands [where ATA_QCFLAG_RESULT_TF is set] are used while other commands are active on other devices connected to the same port with a Port Multiplier. Due to a hardware bug, these commands must be sent alone, like ATAPI commands. Signed-off-by: Gwendal Grignou <gwendal@google.com> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-23sata_sil24: fix sg table sizingTejun Heo
sil24 unnecessarily used LIBATA_MAX_PRD and ATAPI sg table was short by one entry which might cause very obscure problems. This patch updates sg table sizing such that * One full page is used for PRB + sg table. On 4k page, this results in 253 sg's. * Make ATAPI sg block properly sized. * Make build fail if command block size doesn't equal PAGE_SIZE. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-30libata: stop being overjealous about non-IO commandsTejun Heo
libata EH always revalidated device and retried failed command after error except for ATAPI CCs. This is unnecessary and hinders with users issuing direct commands. This patch makes the following changes. * Make sata_sil24 not request ATA_EH_REVALIDATE on device errors. sil24 is the only driver which does this. All others let libata EH core code decide. * Don't request revalidation after device error of non-IO command. Revalidation doesn't really help anybody. As ATA_EH_REVALIDATE isn't set by default, there's no reason to clear it after sense data is read. Kill ATA_EH_REVALIDATE clearing code while at it. * Don't retry non-IO command after device error. Device has rejected the command. There's no point in retrying. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-29[libata] Address some checkpatch-spotted issuesJeff Garzik
2007-10-18[libata] kill ata_sg_is_last()Jeff Garzik
Short term, this works around a bug introduced by early sg-chaining work. Long term, removing this function eliminates a branch from a hot path loop in each scatter/gather table build. Also, as this code demonstrates, we don't need to _track_ the end of the s/g list, as long as we mark it in some way. And doing so programatically is nice. So its a useful cleanup, regardless of its short term effects. Based conceptually on a quick patch by Jens Axboe. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12libata: use ata_exec_internal() for PMP register accessTejun Heo
PMP registers used to be accessed with dedicated accessors ->pmp_read and ->pmp_write. During reset, those callbacks are called with the port frozen so they should be able to run without depending on interrupt delivery. To achieve this, they were implemented polling. However, as resetting the host port makes the PMP to isolate fan-out ports until SError.X is cleared, resetting fan-out ports while port is frozen doesn't buy much additional safety. This patch updates libata PMP support such that PMP registers are accessed using regular ata_exec_internal() mechanism and kills ->pmp_read/write() callbacks. The following changes are made. * PMP access helpers - sata_pmp_read_init_tf(), sata_pmp_read_val(), sata_pmp_write_init_tf() are folded into sata_pmp_read/write() which are now standalone PMP register access functions. * sata_pmp_read/write() returns err_mask instead of rc. This is consistent with other functions which issue internal commands and allows more detailed error reporting. * ahci interrupt handler is modified to ignore BAD_PMP and spurious/illegal completion IRQs while reset is in progress. These conditions are expected during reset. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12sata_sil24: implement PORT_RSTTejun Heo
As DEV_RST (hardreset) sometimes fail to recover the controller (especially after PMP DMA CS errata). In such cases, perform PORT_RST prior to DEV_RST. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12sata_sil24: implement PMP supportTejun Heo
Implement PMP support. sil24 supports full FIS-switching. However, it has a PMP DMA CS errata which requires port-wide resetting if commands are outstanding to three or more devices when an error occurs on one of them. ATAPI commands often result in CHECK SENSE and it's crucial to not reset them before fetching sense data. Unfortunately, ATAPI CHECK SENSE causes a lot of problem if command is outstanding to any other device usually resulting in port-wide reset. So, sata_sil24 implements sil24_qc_defer() which guarantees ATAPI command is run by itself. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-pmp-prep: implement sata_async_notification()Tejun Heo
AN serves multiple purposes. For ATAPI, it's used for media change notification. For PMP, for downstream PHY status change notification. Implement sata_async_notification() which demultiplexes AN. To avoid unnecessary port events, ATAPI AN is not enabled if PMP is attached but SNTF is not available. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Kriten Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-pmp-prep: implement ops->qc_defer()Tejun Heo
Controllers which support PMP have various restrictions on which combinations of commands are allowed to what number of devices concurrently. This patch implements ops->qc_defer() which determines whether a qc can be issued at the moment or should be deferred. If the function returns ATA_DEFER_LINK, the qc will be deferred until a qc completes on the link. If ATA_DEFER_PORT, until a qc completes on any link. The defer conditions are advisory and in general ATA_DEFER_LINK can be considered as lower priority deferring than ATA_DEFER_PORT. ops->qc_defer() replaces fixed ata_scmd_need_defer(). For standard NCQ/non-NCQ exclusion, ata_std_qc_defer() is implemented. ahci and sata_sil24 are converted to use ata_std_qc_defer(). ops->qc_defer() is heavier than the original mechanism because full qc is prepped before determining to defer it, but various information is needed to determine defer conditinos and fully translating a qc is the only way to supply such information in generic manner. IMHO, this shouldn't cause any noticeable performance issues as * for most cases deferring occurs rarely (except for NCQ-aware cmd-switching PMP) * translation itself isn't that expensive * once deferred the command won't be repeated until another command completes which usually is a very long time cpu-wise. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: misc updates for ANTejun Heo
Update AN support in preparation of PMP support. * s/ata_id_has_AN/ata_id_has_atapi_AN/ * add AN enabled reporting during configuration * add err_mask to AN configuration failure reporting * update LOCKING comment for ata_scsi_media_change_notify() * check whether ATA dev is attached to SCSI dev ata_scsi_media_change_notify() * set ATA_FLAG_AN in ahci and sata_sil24 Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Kriten Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata: implement and use ata_port_desc() to report port configurationTejun Heo
Currently, port configuration reporting has the following problems. * iomapped address is reported instead of raw address * report contains irrelevant fields or lacks necessary fields for non-SFF controllers. * host->irq/irq2 are there just for reporting and hacky. This patch implements and uses ata_port_desc() and ata_port_pbar_desc(). ata_port_desc() is almost identical to ata_ehi_push_desc() except that it takes @ap instead of @ehi, has no locking requirement, can only be used during host initialization and " " is used as separator instead of ", ". ata_port_pbar_desc() is a helper to ease reporting of a PCI BAR or an offsetted address into it. LLD pushes whatever description it wants using the above two functions. The accumulated description is printed on host registration after "[S/P]ATA max MAX_XFERMODE ". SFF init helpers and ata_host_activate() automatically add descriptions for addresses and irq respectively, so only LLDs which isn't standard SFF need to add custom descriptions. In many cases, such controllers need to report different things anyway. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->port_disable() hookJeff Garzik
It was always set to ata_port_disable(). Removed the hook, and replaced the very few ap->ops->port_disable() callsites with direct calls to ata_port_disable(). Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12[libata] Remove ->irq_ack() hook, and ata_dummy_irq_on()Jeff Garzik
* ->irq_ack() is redundant to what the irq handler already performs... chk-status + irq-clear. Furthermore, it is only called in one place, when screaming-irq-debugging is enabled, so we don't want to bother with a hook just for that. * ata_dummy_irq_on() is only ever used in drivers that have no callpath reaching ->irq_on(). Remove .irq_on hook from those drivers, and the now-unused ata_dummy_irq_on() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: make two port flags HRST_TO_RESUME and SKIP_D2H_BSY link flagsTejun Heo
HRST_TO_RESUME and SKIP_D2H_BSY are link attributes. Move them to ata_link->flags. This will allow host and PMP links to have different attributes. ata_port_info->link_flags is added and used by LLDs to specify these flags during initialization. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify resetTejun Heo
Make reset methods and related functions deal with ata_link instead of ata_port. * ata_do_reset() * ata_eh_reset() * all prereset/reset/postreset methods and related functions This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: linkify PHY-related functionsTejun Heo
Make the following PHY-related functions to deal with ata_link instead of ata_port. * sata_print_link_status() * sata_down_spd_limit() * ata_set_sata_spd_limit() and friends * sata_link_debounce/resume() * sata_scr_valid/read/write/write_flush() * ata_link_on/offline() This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-12libata-link: introduce ata_linkTejun Heo
Introduce ata_link. It abstracts PHY and sits between ata_port and ata_device. This new level of abstraction is necessary to support SATA Port Multiplier, which basically adds a bunch of links (PHYs) to a ATA host port. Fields related to command execution, spd_limit and EH are per-link and thus moved to ata_link. This patch only defines the host link. Multiple link handling will be added later. Also, a lot of ap->link derefences are added but many of them will be removed as each part is converted to deal directly with ata_link instead of ata_port. This patch introduces no behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-09-25sata_sil24: fix IRQ clearing race when PCIX_IRQ_WOC is usedTejun Heo
When PCIX_IRQ_WOC is used, sil24 has an inherent race condition between clearing IRQ pending and reading IRQ status. If IRQ pending is cleared after reading IRQ status, there's possibility of lost IRQ. If IRQ pending is cleared before reading IRQ status, spurious IRQs will occur. sata_sil24 till now cleared IRQ pending after reading IRQ status thus losing IRQs on machines where PCIX_IRQ_WOC was used. Reverse the order and ignore spurious IRQs if PCIX_IRQ_WOC. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-31[libata] Bump driver versionsJeff Garzik
Bump the versions for drivers that were modified, but had not already had a version number bump. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-20libata: make ->scr_read/write callbacks return error codeTejun Heo
Convert ->scr_read/write callbacks to return error code to better indicate failure. This will help handling of SCR_NOTIFICATION. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
