Upgrade the Tegra 3 SATA driver to support kernel 3.1.
The driver supports runtime_pm when doing power-gating during idle.
A new CONFIG_TEGRA_SATA_IDLE_POWERGATE is provided to enable/disable
When sata clocks (sata, sata-oob and pll_e clocks) are in the
core_dvfs_table[] table, CONFIG_TEGRA_SATA_IDLE_POWERGATE must not
be enabled.
Currently, sata clocks are in the core_dvfs_table[]. Those clocks
will not be in that table in the future. By then,
CONFIG_TEGRA_SATA_IDLE_POWERGATE can then be enabled.
Change-Id: I15b585713bfd891f8827fd028b21bf3e5c2b80d9
Signed-off-by: Yen Lin <yelin@nvidia.com>
Reviewed-on: http://git-master/r/89614
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
chipsets(v2)
commit 5e5a4f5d5a08c9c504fe956391ac3dae2c66556d upstream.
This quirk patch fixes one kind of bug inside some Intel Sandybridge
chipsets, see reports from
https://bugzilla.kernel.org/show_bug.cgi?id=40592.
Many guys also have reported the problem before:
https://bugs.launchpad.net/bugs/737388
https://bugs.launchpad.net/bugs/794642
https://bugs.launchpad.net/bugs/782389
With help from Tejun, the problem is found to be caused by 32bit PIO
mode, so introduce the quirk patch to disable 32bit PIO on SATA piix
for some Sandybridge CPT chipsets.
Seth also tested the patch on all five affected chipsets
(pci device ID: 0x1c00, 0x1c01, 0x1d00, 0x1e00, 0x1e01), and found
the patch does fix the problem.
Tested-by: Heasley, Seth <seth.heasley@intel.com>
Cc: Alan Cox <alan@linux.intel.com>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Acked-by: Tejun Heo <htejun@gmail.com>
Currently, error handling code in this function calls the function
sata_dwc_port_stop, but this function has essentially no effect if hsdevp
has not been stored in ap, which is the case throughout this function. The
only effect is to print a debugging message including ap->print_id.
The code is rewritten to not call sata_dwc_port_stop, but instead to jump
to a local label that prints the original error message and the print_id
information. In the case where hsdevp has been already allocated (but not
yet stored in ap), this value is freed as well.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@exists@
local idexpression x;
statement S,S1;
expression E;
identifier fl;
expression *ptr != NULL;
x = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...kfree(x)...+> }
when any
when != true x == NULL
x->fl
if (x == NULL) S1
if (...) { ... when != x
when forall
return \(0\|<+...x...+>\|ptr\);
* return ...;
// </smpl>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Add basic support for pata on iMX. It has been tested only on imx51.
SDMA support will probably be added later so this version supports only
PIO.
v2:
- enable only when needed IORDY
- use dev_get_drvdata
v3:
- add missing clk_put() calls
- use platform_get_irq()
- fix resume code to avoid disabling IORDY on resume
v4:
- Remove EXPERIMENTAL and switch to depends on ARCH_MXC
- Use devm_kzalloc()
- make clock a must-have
- Use only 1 ioremap
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
On AVERATEC 3200, pata_via causes memory corruption with ATAPI DMA,
which often leads to random kernel oops. The cause of the problem is
not well understood yet and only small subset of machines using the
controller seem affected. Blacklist ATAPI DMA on the machine.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=11426
Reported-and-tested-by: Jim Bray <jimsantelmo@gmail.com>
Cc: stable@kernel.org
Init 'serror' to silence the following warning:
drivers/ata/sata_sil.c: In function ‘sil_interrupt’:
drivers/ata/sata_sil.c:453:14: warning: ‘serror’ may be used uninitialized in
this function [-Wuninitialized]
This is not a 'can never happen' but is nonetheless extremely unlikely.
The easiest and cleanest warning fix is simply to init the var,
rather than worry about marking the var uninit-ok.
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (28 commits)
ACPI: delete stale reference in kernel-parameters.txt
ACPI: add missing _OSI strings
ACPI: remove NID_INVAL
thermal: make THERMAL_HWMON implementation fully internal
thermal: split hwmon lookup to a separate function
thermal: hide CONFIG_THERMAL_HWMON
ACPI print OSI(Linux) warning only once
ACPI: DMI workaround for Asus A8N-SLI Premium and Asus A8N-SLI DELUX
ACPI / Battery: propagate sysfs error in acpi_battery_add()
ACPI / Battery: avoid acpi_battery_add() use-after-free
ACPI: introduce "acpi_rsdp=" parameter for kdump
ACPI: constify ops structs
ACPI: fix CONFIG_X86_REROUTE_FOR_BROKEN_BOOT_IRQS
ACPI: fix 80 char overflow
ACPI / Battery: Resolve the race condition in the sysfs_remove_battery()
ACPI / Battery: Add the check before refresh sysfs in the battery_notify()
ACPI / Battery: Add the hibernation process in the battery_notify()
ACPI / Battery: Rename acpi_battery_quirks2 with acpi_battery_quirks
ACPI / Battery: Change 16-bit signed negative battery current into correct value
ACPI / Battery: Add the power unit macro
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Tejun Heo <tj@kernel.org>
Cc: Joe Perches <joe@perches.com>
Fix kconfig unmet dependency warning:
warning: (PATA_ARASAN_CF && VIDEO_TIMBERDALE && SND_SOC_SH4_SIU) selects DMA_ENGINE which has unmet direct dependencies (DMADEVICES)
Cc: Viresh Kumar <viresh.kumar@st.com>
Compile tested.
remove unnecessary code that matches this coccinelle pattern
if (...)
return ret;
return ret;
Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu>
Cleanup sff_pio_task_link when a command is cancel while the
pio_task thread has been scheduled.
Signed-off-by: Gwendal Grignou <gwendal@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
This patch adds an additional SATA RAID controller DeviceID for the Intel Panther Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
The missing comma causes the wrong RAID type to be displayed.
Introduced by commit 963e4975c6f93c148ca809d986d412201df9af89 three
years ago, odd that nobody noticed before.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Fixed hsdev memleak on sata_dwc_probe() error.
As dma_dwc_exit() can be called multiple times without sata_dma_regs and
irq_dma changes, it might lead to double free on sequential
dma_dwc_exit() calls. So, zero these fields after free calls.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Like e65cc194f7628ecaa02462f22f42fb09b50dcd49 this patch enables 64bit DMA
for the AHCI SATA controller of a board that has the SB600 southbridge. In
this case though we're enabling 64bit DMA for the Asus M3A motherboard. It
is a new enough board that all of the BIOS releases since the initial
release (0301 from 2007-10-22) work correctly with 64bit DMA enabled.
Signed-off-by: Mark Nelson <mdnelson8@gmail.com>
Link resume failure in itself isn't an error condition and may happen
regularly depending on hardware configuration. Reporting it as
KERN_ERR makes the condition unnecessarily prominent (e.g. reported
during boot). Use KERN_WARNING instead.
Reported-by: David Shaw <dshaw@jabberwocky.com>
ahci_sb600_softreset was in ahci.c. This function is used
to fix soft reset failure and renames as ahci_pmp_retry_softreset
in libahci.c.
Signed-off-by: Yuan-Hsin Chen <yhchen@faraday-tech.com>
libata EH intentionally left a port frozen if it failed
ata_eh_reset(). The intention was avoiding continuous loop of resets
when the controller or attached device is flaky and reporting spurious
hotplug events. Once port enters this state, it can be recovered with
manual rescan, which seemed reasonable.
However, outside of my convoluted test setup, there have been very few
reports justifying this choice while there have been more cases where
the automatic freezing of the port after hotplug attempt of a faulty
device caused confusion and led to unnecessary resets.
This patch changes the behavior so that the port is thawed after reset
failure. This change doesn't necessarily solve but makes it easier
and more intuitive to work around hotplug related problems
(ie. re-pluggin or power cycling the device) as reported in the
followings.
https://bugzilla.kernel.org/show_bug.cgi?id=34712
http://thread.gmane.org/gmane.linux.kernel/1123265/focus=49548
Reported-by: Reartes Guillermo <rtguille@gmail.com>
Reported-by: Bruce Stenning <b.stenning@indigovision.com>
Use normal debugging path for dynamic debug capability.
Convert dev_printk(KERN_DEBUG to dev_dbg(
Use a single mechanism to show driver version.
Reduces text a tiny bit too.
Remove uses of static int printed_version
Add and use ata_print_version(const struct device *, const char *ver)
and ata_print_version_once.
$ size drivers/ata/built-in.*
544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o
543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o
141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o
141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o
Saves text by removing nearly duplicated text format strings by
creating ata_<foo>_printk functions and printf extension %pV.
ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB)
Format string duplication comes from:
#define ata_link_printk(link, lv, fmt, args...) do { \
if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \
printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \
(link)->pmp , ##args); \
else \
printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \
} while(0)
Coalesce long formats.
558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o
149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o
Saves a bit of text as the call takes fewer args.
Coalesce a few formats.
Convert a few bare printks to pr_cont.
$ size drivers/ata/built-in.o*
558429 73893 117864 750186 b726a drivers/ata/built-in.o.allyesconfig.new
559574 73893 117888 751355 b76fb drivers/ata/built-in.o.allyesconfig.old
149567 14689 4220 168476 2921c drivers/ata/built-in.o.defconfig.new
149851 14689 4220 168760 29338 drivers/ata/built-in.o.defconfig.old
Structs battery_file, acpi_dock_ops, file_operations,
thermal_cooling_device_ops, thermal_zone_device_ops, kernel_param_ops
are not changed in runtime. It is safe to make them const.
register_hotplug_dock_device() was altered to take const "ops" argument
to respect acpi_dock_ops' const notion.
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Signed-off-by: Len Brown <len.brown@intel.com>
It's not so much an error as a warning about normal Marvell crazines.
So don't use KERN_ERR that ends up spamming the console even in quiet
mode, it's not _that_ critical.
Explained by Jeff:
"Long explanation, it's a mess:
Marvell took standard AHCI, and bastardized it to include a weird mode
whereby PATA devices appear inside the AHCI DMA and interrupt
infrastructure you're familiar with.
So, PATA devices appear via pata_marvell driver, using basic legacy
IDE programming interface. But SATA devices, which might also be
attached to this chip, either work in under-performing mode or
simply don't work at all (e.g. newer 6 Gbps devices or port
multiplier attachments, NCQ, ...)
On the other hand, 'ahci' driver loads and works with the chip's
attached SATA devices quite beautifully, but is completely unable to
drive any attached PATA devices, due to the Marvell-specific
PATA-under-AHCI interface.
The "masking port_map 0x7 -> 0x3" message is the ahci driver "hiding"
the PATA port(s) from itself, making sure it will only drive the SATA
ports it knows how to drive."
This patch enables support for Marvell IDE PATA controllers found on
Asus P8P67LE motherboard.
The formatting has been corrected and I also received a report from two
users of this motherboard that the patch works.
Signed-off-by: Paweł Drewniak <czajernia@gmail.com>
On 16.06.2011 [08:28:39 -0500], Brian King wrote:
> On 06/16/2011 02:51 AM, Tejun Heo wrote:
> > On Wed, Jun 15, 2011 at 04:34:17PM -0700, Nishanth Aravamudan wrote:
> >>> That looks like the right thing to do. For ipr's usage of
> >>> libata, we don't have the concept of a port frozen state, so this flag
> >>> should really never get set. The alternate way to fix this would be to
> >>> only set ATA_PFLAG_FROZEN in ata_port_alloc if ap->ops->error_handler
> >>> is not NULL.
> >> It seemed like ipr is as you say, but I wasn't sure if it was
> >> appropriate to make the change above in the common libata-scis code or
> >> not. I don't want to break some other device on accident.
> >> Also, I tried your suggestion, but I don't think that can happen in
> >> ata_port_alloc? ata_port_alloc is allocated ap itself, and it seems like
> >> ap->ops typically gets set only after ata_port_alloc returns?
> > Maybe we can test error_handler in ata_sas_port_start()?
> Good point. Since libsas is converted to the new eh now, we would need to have
> this test.
Commit 7b3a24c57d2eeda8dba9c205342b12689c4679f9 ("ahci: don't enable
port irq before handler is registered") caused a regression for CD-ROMs
attached to the IPR SATA bus on Power machines:
ata_port_alloc: ENTER
ata_port_probe: ata1: bus probe begin
ata1.00: ata_dev_read_id: ENTER
ata1.00: failed to IDENTIFY (I/O error, err_mask=0x40)
ata1.00: limiting speed to UDMA7:PIO5
ata1.00: disabled
ata_port_probe: ata1: bus probe end
scsi_alloc_sdev: Allocation failure during SCSI scanning, some SCSI devices might not be configured
The FROZEN flag added in that commit is only cleared by the new EH code,
which is not used by ipr. Clear this flag in the SAS code if we don't
support new EH.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
regardless of firmware revision
It's unlikely NOSETXFER works for a revision of drive but doesn't for
another and pioneer doesn't seem to be fixing firmwares for the
affected drives. Apply NOSETXFER to the affected pioneer drives
regardless of firmware revision.
http://article.gmane.org/gmane.linux.ide/49734
Reported-by: fl-00@gmx.de
The patch below fixes a typo.
To work around controllers which can't properly plug events while
reset, ata_eh_reset() clears error states and ATA_PFLAG_EH_PENDING
after reset but before RESET is marked done. As reset is the final
recovery action and full verification of devices including onlineness
and classfication match is done afterwards, this shouldn't lead to
lost devices or missed hotplug events.
Unfortunately, it forgot to thaw the port when clearing EH_PENDING, so
if the condition happens after resetting an empty port, the port could
be left frozen and EH will end without thawing it, making the port
unresponsive to further hotplug events.
Thaw if the port is frozen after clearing EH_PENDING. This problem is
reported by Bruce Stenning in the following thread.
stable: I think we should weather this patch a bit longer in -rcX
before sending it to -stable. Please wait at least a month
after this patch makes upstream. Thanks.
-v2: Fixed spelling in the comment per Dave Howorth.
Cc: Dave Howorth <dhoworth@mrc-lmb.cam.ac.uk>
* 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-block: (40 commits)
cfq-iosched: free cic_index if cfqd allocation fails
cfq-iosched: remove unused 'group_changed' in cfq_service_tree_add()
cfq-iosched: reduce bit operations in cfq_choose_req()
cfq-iosched: algebraic simplification in cfq_prio_to_maxrq()
blk-cgroup: Initialize ioc->cgroup_changed at ioc creation time
block: move bd_set_size() above rescan_partitions() in __blkdev_get()
block: call elv_bio_merged() when merged
cfq-iosched: Make IO merge related stats per cpu
cfq-iosched: Fix a memory leak of per cpu stats for root group
backing-dev: Kill set but not used var in bdi_debug_stats_show()
block: get rid of on-stack plugging debug checks
blk-throttle: Make no throttling rule group processing lockless
blk-cgroup: Make cgroup stat reset path blkg->lock free for dispatch stats
blk-cgroup: Make 64bit per cpu stats safe on 32bit arch
blk-throttle: Make dispatch stats per cpu
blk-throttle: Free up a group only after one rcu grace period
blk-throttle: Use helper function to add root throtl group to lists
blk-throttle: Introduce a helper function to fill in device details
blk-throttle: Dynamically allocate root group
blk-cgroup: Allow sleeping while dynamically allocating a group
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: Make struct pcmcia_device_id const, sound drivers edition
staging: pcmcia: Convert pcmcia_device_id declarations to const
pcmcia: Make declaration and uses of struct pcmcia_device_id const
pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: Power off empty ports
libata-pmp: add support for Thermaltake BlackX Duet esata drive dock
ATA: Don't powerdown Compaq Triflex IDE device on suspend
libata: Use Maximum Write Same Length to report discard size limit
drivers/ata/acard-ahci.c: fix enum warning
pata_at91: SMC settings calculation bugfixes, support for t6z and IORDY
libata-sff: prevent irq descriptions for dummy ports
pata_cm64x: fix boot crash on parisc
Since for-2.6.40/core was forked off the 2.6.39 devel tree, we've
had churn in the core area that makes it difficult to handle
patches for eg cfq or blk-throttle. Instead of requiring that they
be based in older versions with bugs that have been fixed later
in the rc cycle, merge in 2.6.39 final.
Also fixes up conflicts in the below files.
drivers/block/paride/pcd.c
drivers/cdrom/viocd.c
drivers/ide/ide-cd.c
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Give users the option of completely powering off unoccupied
SATA ports using the existing min_power link_power_management_policy
option. When the use selects this option on an empty port, we
will power the port off by setting DET to off. For occupied ports,
behavior is unchanged.
Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com>
Some errors still show up, but the dock works, both drives can be
accessed at the same time
The chip maker and designation is unknown - possibly jmicron JMB350?
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
This fixes APM suspend on Compaq Armada 7400.
APM BIOS doesn't suspend if IDE is powered down when suspending.
The Triflex controller is found only on old Compaq boards,
so this patch will hopefully have no side effects.
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Previously we used Maximum Unmap LBA Count in the Block Limits VPD to
signal the maximum number of sectors we could handle in a single Write
Same command.
Starting with SBC3r26 the Block Limits VPD has an explicit limit on the
number of blocks in a Write Same. This means we can stop abusing a field
related to the Unmap command and let our SAT use the proper value in the
VPD (Maximum Write Same Length).
libata: fix oops when LPM is used with PMP
* New code correctly calculates SMC registers values, adjusts calculated
to admissible ranges, enlarges cycles when required and converts values
into SMC's format.
* Support for TDF cycles (ATA t6z) and IORDY line added.
* Eliminate need in the initial_timing structure.
* Code cleanup.
Signed-off-by: Igor Plyatov <plyatov@gmail.com>
This is a cosmetic change to prevent libata-sff adding irq
descriptions to dummy ports, since the information, while largely
unused, is erroneous.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
The old IDE cmd64x checks the status of the CNTRL register to see if
the ports are enabled before probing them. pata_cmd64x doesn't do
this, which causes a HPMC on parisc when it tries to poke at the
secondary port because apparently the BAR isn't wired up (and a
non-responding piece of memory causes a HPMC).
Fix this by porting the CNTRL register port detection logic from IDE
cmd64x. In addition, following converns from Alan Cox, add a check to
see if a mobility electronics bridge is the immediate parent and forgo
the check if it is (prevents problems on hotplug controllers).
ae01b2493c (libata: Implement ATA_FLAG_NO_DIPM and apply it to mcp65)
added ATA_FLAG_NO_DIPM and made ata_eh_set_lpm() check the flag.
However, @ap is NULL if @link points to a PMP link and thus the
unconditional @ap->flags dereference leads to the following oops.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: [<ffffffff813f98e1>] ata_eh_recover+0x9a1/0x1510
Pid: 295, comm: scsi_eh_4 Tainted: P 2.6.38.5-core2 #1 System76, Inc. Serval Professional/Serval Professional
RIP: 0010:[<ffffffff813f98e1>] [<ffffffff813f98e1>] ata_eh_recover+0x9a1/0x1510
RSP: 0018:ffff880132defbf0 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff880132f40000 RCX: 0000000000000000
RDX: ffff88013377c000 RSI: ffff880132f40000 RDI: 0000000000000000
RBP: ffff880132defce0 R08: ffff88013377dc58 R09: ffff880132defd98
R10: 0000000000000000 R11: 00000000ffffffff R12: 0000000000000000
R13: 0000000000000000 R14: ffff88013377c000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff8800bf700000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000018 CR3: 0000000001a03000 CR4: 00000000000406e0
Process scsi_eh_4 (pid: 295, threadinfo ffff880132dee000, task ffff880133b416c0)
Stack:
0000000000000000 ffff880132defcc0 0000000000000000 ffff880132f42738
ffffffff813ee8f0 ffffffff813eefe0 ffff880132defd98 ffff88013377f190
ffffffffa00b3e30 ffffffff813ef030 0000000032defc60 ffff880100000000
Call Trace:
[<ffffffff81400867>] sata_pmp_error_handler+0x607/0xc30
[<ffffffffa00b273f>] ahci_error_handler+0x1f/0x70 [libahci]
[<ffffffff813faade>] ata_scsi_error+0x5be/0x900
[<ffffffff813cf724>] scsi_error_handler+0x124/0x650
[<ffffffff810834b6>] kthread+0x96/0xa0
[<ffffffff8100cd64>] kernel_thread_helper+0x4/0x10
Code: 8b 95 70 ff ff ff b8 00 00 00 00 48 3b 9a 10 2e 00 00 48 0f 44 c2 48 89 85 70 ff ff ff 48 8b 8d 70 ff ff ff f6 83 69 02 00 00 01 <48> 8b 41 18 0f 85 48 01 00 00 48 85 c9 74 12 48 8b 51 08 48 83
RIP [<ffffffff813f98e1>] ata_eh_recover+0x9a1/0x1510
RSP <ffff880132defbf0>
Fix it by testing @link->ap->flags instead.
stable: ATA_FLAG_NO_DIPM was added during 2.6.39 cycle but was
backported to 2.6.37 and 38. This is a fix for that and thus
also applicable to 2.6.37 and 38.
Reported-by: "Nathan A. Mourey II" <nmoureyii@ne.rr.com>
LKML-Reference: <1304555277.2059.2.camel@localhost.localdomain>
Cc: Connor H <cmdkhh@gmail.com>
This reverts commit 270dac35c26433d06a89150c51e75ca0181ca7e4.
The commits causes command timeouts on AC plug/unplug. It isn't yet
clear why. As the commit was for a single rather obscure controller,
revert the change for now.
The problem was reported and bisected by Gu Rui in bug#34692.
https://bugzilla.kernel.org/show_bug.cgi?id=34692
Also, reported by Rafael and Michael in the following thread.
http://thread.gmane.org/gmane.linux.kernel/1138771
Reported-by: Gu Rui <chaos.proton@gmail.com>
Reported-by: Rafael J. Wysocki <rjw@sisk.pl>
Reported-by: Michael Leun <lkml20100708@newton.leun.net>
Cc: Jian Peng <jipeng2005@gmail.com>
Enable non-queueable flush flag for SATA.
Stable: 2.6.39 only
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Saves about 50KB of data.
Old/new size of all objects:
563015 80096 130684 773795 bcea3 (TOTALS)
610916 32256 130632 773804 bceac (TOTALS)
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c)
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
At the end of section 10.1 of AHCI spec (rev 1.3), it states
Software shall not set PxCMD.ST to 1 until it is determined that
a functoinal device is present on the port as determined by
PxTFD.STS.BSY=0, PxTFD.STS.DRQ=0 and PxSSTS.DET=3h
Even though most AHCI host controller works without this check,
specific controller will fail under this condition.
Signed-off-by: Jian Peng <jipeng2005@gmail.com>
The "struct ata_timing" must contain 10 members, but ".dmack_hold" member was
forgotten for "initial_timing" initialisation. This patch fixes such a problem.
The AT91SAM9 microcontrollers with master clock higher then 105 MHz
and PIO0, have overflow of the NCS_RD_PULSE value in the MSB. This
lead to "NCS_RD_PULSE" pulse longer then "NRD_CYCLE" pulse and driver
does not detect ATA device.
The previously submitted patch was word-wrapped.
This patch adds the AHCI-mode SATA DeviceIDs for the Intel Panther Point PCH.
