path: root/drivers/atm/ambassador.h
2011-07-08ATM: Delete no use FILL_RX_POOLS_IN_BH marcoWang Shaoyan
The macro FILL_RX_POOLS_IN_BH is never been used, in order to avoid the compiler reports error because of the usage of function INIT_WORK, we just delete the marco. Cc: Chas Williams <chas@cmf.nrl.navy.mil> Cc: linux-atm-general@lists.sourceforge.net Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-10firmware: convert Ambassador ATM driver to request_firmware()David Woodhouse
Since it had various regions to be loaded to separate addresses, and it wanted to do them in fairly small chunks anyway, switch it to use the new ihex code. Encode the start address in the first record. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Chas Williams <chas@cmf.nrl.navy.mil>
2008-04-29atm: ambassador: vcc_sf semaphore to mutexDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-14long vs. unsigned long - low-hanging fruits in driversAl Viro
deal with signedness of the stuff passed to set_bit() et.al. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
