path: root/drivers/atm/fore200e.c
2008-03-17fore2000 - fix misannotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-05atm: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-14[ATM]: Fix compiler warning noise with FORE200E driverTom "spot" Callaway
gcc throws these warnings with: CONFIG_ATM_FORE200E=m # CONFIG_ATM_FORE200E_PCA is not set drivers/atm/fore200e.c:2695: warning: 'fore200e_pca_detect' defined but not used drivers/atm/fore200e.c:2748: warning: 'fore200e_pca_remove_one' defined but not used By moving the #ifdef CONFIG_ATM_FORE200E_PCA around those two functions, the compiler warnings are silenced. Signed-off-by: Tom "spot" Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-13[ATM]: fore200e_param_bs_queue() must be __devinitAdrian Bunk
WARNING: drivers/built-in.o(.text+0x6203bb): Section mismatch: reference to .init.text:fore200e_param_bs_queue (between 'fore200e_initialize' and 'fore200e_monitor_putc') Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[ATM]: Use mutex instead of binary semaphore in FORE Systems 200E-series driverMatthias Kaehlcke
(akpm: remove CVS control string too) Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-22[ATM] drivers/atm/fore200e.c: Cleanups.Adrian Bunk
This patch contains the following transformations from custom functions to standard kernel version: - fore200e_kmalloc() -> kzalloc() - fore200e_kfree() -> kfree() - fore200e_swap() -> cpu_to_be32() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-04[ATM]: [fore200e] fix section mismatch warningsSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[ATM]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in atm code: net/atm/atm_misc.c:35:44: warning: implicit cast to nocast type drivers/atm/fore200e.c:183:33: warning: implicit cast to nocast type Also use kzalloc() instead of kmalloc(). Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Store skb->timestamp as offset to a base timestampPatrick McHardy
Reduces skb size by 8 bytes on 64-bit. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-02[ATM]: [drivers] kill pointless NULL checks and casts before kfree()Jesper Juhl
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[ATM]: [fore200e] pci doesn't use global board list; use pci_register_driver()chas williams
