path: root/drivers/atm/he.h
2015-01-18atm: remove deprecated use of pci apichas williams - CONTRACTOR
Signed-off-by: Chas Williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31atm: [he] rewrite buffer handling in receive pathchas williams - CONTRACTOR
Instead of a fixed list of buffers, use the buffer pool correctly and keep track of the outstanding buffer indexes using a fixed table. Resolves reported HBUF_ERR's -- failures due to lack of receive buffers. Signed-off-by: Chas Williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31atm: [he] remove small buffer allocation/handling codechas williams - CONTRACTOR
2008-06-17atm: [he] remove #ifdef clutterChas Williams
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16atm: [he] only support suni driver on multimode interfacesChas Williams
2008-05-20drivers/atm/: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[ATM]: [he] Use the DMA_32BIT_MASK constant from dma-mapping.hchas williams
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
