path: root/drivers/atm/iphase.h
2013-02-08atm/iphase: rename fregt_t -> ffreg_tHeiko Carstens
We have conflicting type qualifiers for "freg_t" in s390's ptrace.h and the iphase atm device driver, which causes the compile error below. Unfortunately the s390 typedef can't be renamed, since it's a user visible api, nor can I change the include order in s390 code to avoid the conflict. So simply rename the iphase typedef to a new name. Fixes this compile error: In file included from drivers/atm/iphase.c:66:0: drivers/atm/iphase.h:639:25: error: conflicting type qualifiers for 'freg_t' In file included from next/arch/s390/include/asm/ptrace.h:9:0, from next/arch/s390/include/asm/lowcore.h:12, from next/arch/s390/include/asm/thread_info.h:30, from include/linux/thread_info.h:54, from include/linux/preempt.h:9, from include/linux/spinlock.h:50, from include/linux/seqlock.h:29, from include/linux/time.h:5, from include/linux/stat.h:18, from include/linux/module.h:10, from drivers/atm/iphase.c:43: next/arch/s390/include/uapi/asm/ptrace.h:197:3: note: previous declaration of 'freg_t' was here Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: chas williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-03atm/iphase : removal of PCI space dereferences.françois romieu
Mostly PHY access and a few (ugly) debug statements for DMA control. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-11ATM: iphase, remove sleep-inside-atomicJiri Slaby
Stanse found that ia_init_one locks a spinlock and inside of that it calls ia_start which calls: * request_irq * tx_init which does kmalloc(GFP_KERNEL) Both of them can thus sleep and result in a deadlock. I don't see a reason to have a per-device spinlock there which is used only there and inited right before the lock location. So remove it completely. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-14iphase: Fix 64bit warning.Alan Cox
Time is unsigned long (except when you are in a hurry) so we need to store rx_tmp_jif in the right sized object. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
