If device_add() is called with a device which does not have dev->p set
up, then device_private_init() is called. If that succeeds, then the
error variable is set to 0. Now if the dev_name(dev) check further
down fails, then device_add() correctly terminates, but returns 0.
That of course lets the driver progress. If later another driver uses
this half set up device as parent then device_add() of the child
device explodes and renders sysfs completely unusable.
Set the error to -EINVAL if dev_name() check fails.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: "Hans J. Koch" <hjk@linutronix.de>
Many struct bin_attribute descriptors are purely read-only
structures, and there's no need to change them. Therefore
make the promise not to, which will let those descriptors
be put in a ro section.
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Most device_attributes are const, and are begging to be
put in a ro section. However, the create and remove
file interfaces were failing to propagate the const promise
which the only functions they call offer.
This patch (as1310) works around a race in dev_driver_string(). If
the device is unbound while the function is running, dev->driver might
become NULL after we test it and before we dereference it.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable <stable@kernel.org>
Cc: Oliver Neukum <oliver@neukum.org>
device_shutdown is defined to just shutdown the hardware and to not
clean up any kernel data structures. Therefore don't put the kobjects
for /sys/dev and /sys/dev/block and /sys/dev/char.
This ensures we don't remove /sys/dev/block and /sys/dev/char while
we still have symlinks from there to the actual devices.
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This allows subsytems to provide devtmpfs with non-default permissions
for the device node. Instead of the default mode of 0600, null, zero,
random, urandom, full, tty, ptmx now have a mode of 0666, which allows
non-privileged processes to access standard device nodes in case no
other userspace process applies the expected permissions.
This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain.
Devtmpfs lets the kernel create a tmpfs instance called devtmpfs
very early at kernel initialization, before any driver-core device
is registered. Every device with a major/minor will provide a
device node in devtmpfs.
Devtmpfs can be changed and altered by userspace at any time,
and in any way needed - just like today's udev-mounted tmpfs.
Unmodified udev versions will run just fine on top of it, and will
recognize an already existing kernel-created device node and use it.
The default node permissions are root:root 0600. Proper permissions
and user/group ownership, meaningful symlinks, all other policy still
needs to be applied by userspace.
If a node is created by devtmps, devtmpfs will remove the device node
when the device goes away. If the device node was created by
userspace, or the devtmpfs created node was replaced by userspace, it
will no longer be removed by devtmpfs.
If it is requested to auto-mount it, it makes init=/bin/sh work
without any further userspace support. /dev will be fully populated
and dynamic, and always reflect the current device state of the kernel.
With the commonly used dynamic device numbers, it solves the problem
where static devices nodes may point to the wrong devices.
It is intended to make the initial bootup logic simpler and more robust,
by de-coupling the creation of the inital environment, to reliably run
userspace processes, from a complex userspace bootstrap logic to provide
a working /dev.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Tested-By: Harald Hoyer <harald@redhat.com>
Tested-By: Scott James Remnant <scott@ubuntu.com>
Let attribute group vectors be declared "const". We'd
like to let most attribute metadata live in read-only
sections... this is a start.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
No one should directly access the driver_data field, so remove the field
and make it private. We dynamically create the private field now if it
is needed, to handle drivers that call get/set before they are
registered with the driver core.
Also update the copyright notices on these files while we are there.
This patch (as1271) affects when new devices get linked into their
bus's list of devices. Currently this happens after probing, and it
doesn't happen at all if probing fails. Clearly this is wrong,
because at that point quite a few symbolic links have already been
created in sysfs. We are committed to adding the device, so it should
be linked into the bus's list regardless.
In addition, this needs to happen before the uevent announcing the new
device gets issued. Otherwise user programs might try to access the
device before it has been added to the bus.
To fix both these problems, the patch moves the call to
klist_add_tail() forward from bus_attach_device() to bus_add_device().
Since bus_attach_device() now does nothing but probe for drivers, it
has been renamed to bus_probe_device(). And lastly, the kerneldoc is
updated.
CC: Kay Sievers <kay.sievers@vrfy.org>
This adds the nodename callback for struct class, struct device_type and
struct device, to allow drivers to send userspace hints on the device
name and subdirectory that should be used for it.
This removes the
warning: format not a string literal and no format arguments
warnings in the driver core that gcc 4.3.3 complains about.
A patch series to make .shutdown execute asynchronously. Some drivers's
shutdown can take a lot of time. The patches can help save some shutdown
time. The patches use Arjan's async API.
This patch:
synchronize all tasks submitted by .shutdown
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
drivers
We also fix a problem with cleaning up properly when initializing
drivers and devices, so checks like this will work successfully.
Portions of the patch by Linus and Greg and Ingo.
Reported-by: Ozan Çağlayan <ozan@pardus.org.tr>
notice one system /proc/iomem some entries missed the name for pci_devices
it turns that dev->dev.kobj name is changed after device_add.
for pci code: via acpi_pci_root_driver.ops.add (aka acpi_pci_root_add)
==> pci_acpi_scan_root is used to scan pci bus/device, and at the same
time we read the resource for pci_dev in the pci_read_bases, we have
res->name = pci_name(pci_dev); pci_name is calling dev_name.
later via acpi_pci_root_driver.ops.start (aka acpi_pci_root_start) ==>
pci_bus_add_device to add all pci_dev in kobj tree. pci_bus_add_device
will call device_add.
actually in device_add
/* first, register with generic layer. */
error = kobject_add(&dev->kobj, dev->kobj.parent, "%s", dev_name(dev));
if (error)
goto Error;
will get one new name for that kobj, old name is freed.
[Impact: fix corrupted names in /proc/iomem ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
David Vrabel noticed that the wireless usb stack likes to call
device_for_each_chile() with an empty bus. This used to work fine, but
now oopses. This patch fixes the oops and makes the code behave like it
used to.
Reported-by: David Vrabel <david.vrabel@csr.com>
Tested-by: David Vrabel <david.vrabel@csr.com>
dpm_list currently relies on the fact that child devices will
be registered after their parents to get a correct suspend
order. Using device_move() however destroys this assumption, as
an already registered device may be moved under a newly registered
one.
This patch adds a new argument to device_move(), allowing callers
to specify how dpm_list should be adapted.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
This patch implements uevent suppress in kobject and removes it
from struct device, based on the following ideas:
1,Uevent sending should be one attribute of kobject, so suppressing it
in kobject layer is more natural than in device layer. By this way,
we can do it for other objects embedded with kobject.
2,It may save several bytes for each instance of struct device.(On my
omap3(32bit ARM) based box, can save 8bytes per device object)
This patch also introduces dev_set|get_uevent_suppress() helpers to
set and query uevent_suppress attribute in case to help kobject
as private part of struct device in future.
[This version is against the latest driver-core patch set of Greg,please
ignore the last version.]
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Nothing outside of the driver core should ever touch klist_children, or
knode_parent, so move them out of the public eye.
This is to be used to move things out of struct device that no code
outside of the driver core should ever touch.
Now that all users of bus_id is gone, we can remove it from struct
device.
Fix function parameter name in kernel-doc:
Warning(linux-next-20090120//drivers/base/core.c:1289): No description found for parameter 'dev'
Warning(linux-next-20090120//drivers/base/core.c:1289): Excess function parameter 'root' description in 'root_device_unregister'
Acked-by: Mark McLoughlin <markmc@redhat.com>
Commit 3ada8b7e ("block: struct device - replace bus_id with dev_name(),
dev_set_name()") deleted the code in register_disk() that changed a '/'
to a '!' in the device name when registering a disk, but dev_set_name()
does not perform this conversion.
This leads to amusing problems with disks that have '/' in their names:
for example a failure to boot with the root partition on a cciss device,
even though the kernel says it knows about the root device:
VFS: Cannot open root device "cciss/c0d0p6" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
6800 71652960 cciss/c0d0 driver: cciss
6802 1 cciss/c0d0p2
6805 2931831 cciss/c0d0p5
6806 34354908 cciss/c0d0p6
6810 71652960 cciss/c0d1 driver: cciss
Fix this by adding code to change '/' to '!' in dev_set_name() to handle
this until dev_set_name() is converted to use kobject_set_name().
Signed-off-by: Roland Dreier <rolandd@cisco.com>
This reverts commit 2831fe6f9cc4e16c103504ee09a47a084297c0f3.
Turns out that device_initialize shouldn't fail silently.
This series needs to be reworked in order to get into proper
shape.
Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
This reverts commit 11c3b5c3e08f4d855cbef52883c266b9ab9df879.
shape.
Add support for allocating root device objects which group
device objects under /sys/devices directories.
Also add a sysfs 'module' symlink which points to the owner
of the root device object. This symlink will be used in virtio
to allow userspace to determine which virtio bus implementation
a given device is associated with.
[Includes suggestions from Cornelia Huck]
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
This patch (as1184) changes the location of the notifications in
device_add() and device_del(). Now the BUS_NOTIFY_ADD_DEVICE message
is sent after dpm_sysfs_add(), which is necessary for clients that
want to add attributes to the power/ subdirectory. The
BUS_NOTIFY_DEL_DEVICE message is correspondingly moved before
dpm_sysfs_remove().
When looking at kobject_rename I found two bugs with
that exist when sysfs support is disabled in the kernel.
kobject_rename does not change the name on the kobject when
sysfs support is not compiled in.
kobject_rename without locking attempts to check the
validity of a rename operation, which the kobject layer
simply does not have the infrastructure to do.
This patch documents the previously unstated requirement of
kobject_rename that is the responsibility of the caller to
provide mutual exclusion and to be certain that the new_name
for the kobject is valid.
This patch modifies sysfs_rename_dir in !CONFIG_SYSFS case
to call kobject_set_name to actually change the kobject_name.
This patch removes the bogus and misleading check in kobject_rename
that attempts to see if a rename is valid. The check is bogus
because we do not have the proper locking. The check is misleading
because it looks like we can and do perform checking at the kobject
level that we don't.
If device_register() in device_create_vargs() fails, the device
must be cleaned up with put_device() (which is also fine on NULL)
instead of kfree().
Make the comments on how to use device_initialize(), device_add()
and device_register() a bit clearer - in particular, explicitly
note that put_device() must be used once we tried to add the device
to the hierarchy.
Iterating over entries using callback usually isn't too fun especially
when the entry being iterated over can't be manipulated freely. This
patch converts class->p->class_devices to klist and implements class
device iterator so that the users can freely build their own control
structure. The users are also free to call back into class code
without worrying about locking.
class_for_each_device() and class_find_device() are converted to use
the new iterators, so their users don't have to worry about locking
anymore either.
Note: This depends on klist-dont-iterate-over-deleted-entries patch
because class_intf->add/remove_dev() depends on proper synchronization
with device removal.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Jens Axboe <jens.axboe@oracle.com>
This gives us a way to handle both the bus_id and init_name values being
used for a while during the transition period.
is set
This patch (as1124) fixes a couple of bugs in the PM core. The new
dev->power.status field should be initialized regardless of whether
CONFIG_PM_SLEEP is enabled, and similarly dpm_sysfs_add() should be
called whenever CONFIG_PM is enabled.
The patch separates out the call to dpm_sysfs_add() from the call to
device_pm_add(). As a result device_pm_add() can no longer return an
error, so its return type is changed to void.
Tested-by: Romit Dasgupta <romit@ti.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Add const markings to dev_name and dev_driver_string to make it clear that
dev_printk doesn't modify dev. This is a prerequisite to adding more
const markings to other functions make it clearer, which functions can
modify dev and which can't.
Use WARN() instead of a printk+WARN_ON() pair; this way the message
becomes part of the warning section for better reporting/collection.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Greg KH <greg@kroah.com>
driver core: Suppress sysfs warnings for device_rename().
Renaming network devices to an already existing name is not
something we want sysfs to print a scary warning for, since the
callers can deal with this correctly. So let's introduce
sysfs_create_link_nowarn() which gets rid of the common warning.
Now that the lockdep infrastructure in the class core is in place, we
should be able to properly change the internal class semaphore to be a
mutex.
David wrote the original patch, and Greg fixed it up to apply properly
due to all of the recent changes in this area.
Cc: Matthew Wilcox <matthew@wil.cx>
This renames the struct class "sem" field to be "class_sem" to make
things easier when struct bus_type and struct class merge in the future.
It also makes grepping for fields easier as well.
Based on an idea from Kay.
This renames the struct class "subsys" field to be "class_subsys" to
make things easier when struct bus_type and struct class merge in the
future. It also makes grepping for fields easier as well.
This renames the struct class "interfaces" field to be
"class_interfaces" to make things easier when struct bus_type and struct
class merge in the future. It also makes grepping for fields easier as
well.
This renames the struct class "devices" field to be "class_devices" to
This moves the portions of struct class that are dynamic (kobject and
lock and lists) out of the main structure and into a dynamic, private,
structure.
This mirrors the functionality that driver_find_device has as well.
We add a start variable, and all callers of the function are fixed up at
the same time.
The block layer will be using this new functionality in a follow-on
patch.
Now that device_create() has been audited, rename things back to the
original call to be sane.
Keep the device_create_drvdata macro around to make merges easier.
There are no more users of this, and it is racy. Use
device_create_drvdata() or device_create_vargs() instead.
Why?:
There are occasions where userspace would like to access sysfs
attributes for a device but it may not know how sysfs has named the
device or the path. For example what is the sysfs path for
/dev/disk/by-id/ata-ST3160827AS_5MT004CK? With this change a call to
stat(2) returns the major:minor then userspace can see that
/sys/dev/block/8:32 links to /sys/block/sdc.
What are the alternatives?:
1/ Add an ioctl to return the path: Doable, but sysfs is meant to reduce
the need to proliferate ioctl interfaces into the kernel, so this
seems counter productive.
2/ Use udev to create these symlinks: Also doable, but it adds a
udev dependency to utilities that might be running in a limited
environment like an initramfs.
3/ Do a full-tree search of sysfs.
[kay.sievers@vrfy.org: fix duplicate registrations]
[kay.sievers@vrfy.org: cleanup suggestions]
Cc: Neil Brown <neilb@suse.de>
Cc: Tejun Heo <htejun@gmail.com>
Reviewed-by: SL Baur <steve@xemacs.org>
Acked-by: Mark Lord <lkml@rtr.ca>
Acked-by: H. Peter Anvin <hpa@zytor.com>
