path: root/drivers/base/firmware.c
2008-01-24firmware: change firmware_kset to firmware_kobjGreg Kroah-Hartman
There is no firmware "subsystem" it's just a directory in /sys that other portions of the kernel want to hook into. So make it a kobject not a kset to help alivate anyone who tries to do some odd kset-like things with this. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24firmware: remove firmware_(un)register()Greg Kroah-Hartman
These functions are no longer called or needed, so we can remove them. As I rewrote the whole firmware.c file, add my copyright. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24firmware: export firmware_kset so that people can use that instead of the ↵Greg Kroah-Hartman
braindead firmware_register interface Needed for future firmware subsystem cleanups. In the end, the firmware_register/unregister functions will be deleted entirely, but we need this symbol so that subsystems can migrate over. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Matt Tolentino <matthew.e.tolentino@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert drivers/base/firmware.c to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] drivers/base - fix sparse warningsBen Dooks
There are a number of sparse warnings from the latest sparse snapshot being generated from the drivers/base build. The main culprits are due to the initialisation functions not being declared in a header file. Also, the firmware.c file should include <linux/device.h> to get the prototype of firmware_register() and firmware_unregister(). This patch moves the init function declerations from the init.c file to the base.h, and ensures it is included in all the relevant c sources. It also adds <linux/device.h> to the included headers for firmware.c. The patch does not solve all the sparse errors generated, but reduces the count significantly. drivers/base/core.c:161:1: warning: symbol 'devices_subsys' was not declared. Should it be static? drivers/base/core.c:417:12: warning: symbol 'devices_init' was not declared. Should it be static? drivers/base/sys.c:253:6: warning: symbol 'sysdev_shutdown' was not declared. Should it be static? drivers/base/sys.c:326:5: warning: symbol 'sysdev_suspend' was not declared. Should it be static? drivers/base/sys.c:428:5: warning: symbol 'sysdev_resume' was not declared. Should it be static? drivers/base/sys.c:450:12: warning: symbol 'system_bus_init' was not declared. Should it be static? drivers/base/bus.c:133:1: warning: symbol 'bus_subsys' was not declared. Should it be static? drivers/base/bus.c:667:12: warning: symbol 'buses_init' was not declared. Should it be static? drivers/base/class.c:759:12: warning: symbol 'classes_init' was not declared. Should it be static? drivers/base/platform.c:313:12: warning: symbol 'platform_bus_init' was not declared. Should it be static? drivers/base/cpu.c:110:12: warning: symbol 'cpu_dev_init' was not declared. Should it be static? drivers/base/firmware.c:17:5: warning: symbol 'firmware_register' was not declared. Should it be static? drivers/base/firmware.c:23:6: warning: symbol 'firmware_unregister' was not declared. Should it be static? drivers/base/firmware.c:28:12: warning: symbol 'firmware_init' was not declared. Should it be static? drivers/base/init.c:28:13: warning: symbol 'driver_init' was not declared. Should it be static? drivers/base/dmapool.c:174:10: warning: implicit cast from nocast type drivers/base/attribute_container.c:439:1: warning: symbol 'attribute_container_init' was not declared. Should it be static? drivers/base/power/runtime.c:76:6: warning: symbol 'dpm_set_power_state' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
