Commit b7ab83e (PM: Use spinlock instead of mutex in clock
management functions) introduced a regression causing clocks_mutex
to be acquired under a spinlock. This happens because
pm_clk_suspend() and pm_clk_resume() call pm_clk_acquire() under
pcd->lock, but pm_clk_acquire() executes clk_get() which causes
clocks_mutex to be acquired. Similarly, __pm_clk_remove(),
executed under pcd->lock, calls clk_put(), which also causes
To fix those problems make pm_clk_add() call pm_clk_acquire(), so
that pm_clk_suspend() and pm_clk_resume() don't have to do that.
Change pm_clk_remove() and pm_clk_destroy() to separate
modifications of the pcd->clock_list list from the actual removal of
PM clock entry objects done by __pm_clk_remove().
Reported-and-tested-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
The lock member of struct pm_clk_data is of type struct mutex,
which is a problem, because the suspend and resume routines
defined in drivers/base/power/clock_ops.c cannot be executed
with interrupts disabled for this reason. Modify
struct pm_clk_data so that its lock member is a spinlock.
Acked-by: Magnus Damm <damm@opensource.se>
The common PM clock management functions may be used for system
suspend/resume as well as for runtime PM, so rename them
accordingly. Modify kerneldoc comments describing these functions
and kernel messages printed by them, so that they refer to power
management in general rather that to runtime PM.
Reviewed-by: Kevin Hilman <khilman@ti.com>
The common clocks management code in drivers/base/power/clock_ops.c
is going to be used during system-wide power transitions as well as
for runtime PM, so it shouldn't depend on CONFIG_PM_RUNTIME.
However, the suspend/resume functions provided by it for
CONFIG_PM_RUNTIME unset, to be used during system-wide power
transitions, should not behave in the same way as their counterparts
defined for CONFIG_PM_RUNTIME set, because in that case the clocks
are managed differently at run time.
The names of the functions still contain the word "runtime" after
this change, but that is going to be modified by a separate patch
later.
The naming convention used by commit 7538e3db6e015e890825fbd9f86599b
(PM: Add support for device power domains), which introduced the
struct dev_power_domain type for representing device power domains,
evidently confuses some developers who tend to think that objects
of this type must correspond to "power domains" as defined by
hardware, which is not the case. Namely, at the kernel level, a
struct dev_power_domain object can represent arbitrary set of devices
that are mutually dependent power management-wise and need not belong
to one hardware power domain. To avoid that confusion, rename struct
dev_power_domain to struct dev_pm_domain and rename the related
pointers in struct device and struct pm_clk_notifier_block from
pwr_domain to pm_domain.
Acked-by: Kevin Hilman <khilman@ti.com>
Commit 85eb8c8d0b0900c073b0e6f89979ac9c439ade1a (PM / Runtime:
Generic clock manipulation rountines for runtime PM (v6)) converted
the shmobile platform to using generic code for runtime PM clock
management, but it changed the behavior for CONFIG_PM_RUNTIME unset
incorrectly.
Specifically, for CONFIG_PM_RUNTIME unset pm_runtime_clk_notify()
should enable clocks for action equal to BUS_NOTIFY_BIND_DRIVER and
it should disable them for action equal to BUS_NOTIFY_UNBOUND_DRIVER
(instead of BUS_NOTIFY_ADD_DEVICE and BUS_NOTIFY_DEL_DEVICE,
respectively). Make this function behave as appropriate.
The loops over connection ID strings in pm_runtime_clk_notify()
should actually iterate over the strings and not over the elements
of the first of them, so make them behave as appropriate.
This fixes a regression introduced by commit 600b776eb39a13a28b090
(OMAP1 / PM: Use generic clock manipulation routines for runtime PM).
Reported-and-tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Fix a build issue in drivers/base/power/clock_ops.c occuring when
CONFIG_PM_RUNTIME is not set.
Many different platforms and subsystems may want to disable device
clocks during suspend and enable them during resume which is going to
be done in a very similar way in all those cases. For this reason,
provide generic routines for the manipulation of device clocks during
suspend and resume.
Convert the ARM shmobile platform to using the new routines.
