arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
As max_num usage is not necessary, removing it.
Change-Id: I7b668bbbf0d5a388c8ade017194958976c861ea3
Reviewed-on: http://git-master/r/60855
Tested-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: R131970045a24c494f94de0a51eea6c73bdf994ea
In case of jiffies roll over, delta is made zero.
Hence fixing it, after taking roll over into consideration.
Change-Id: I7dacaa12deafbd2bd20705948c0e18292b718aa4
Reviewed-on: http://git-master/r/60147
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R0fa2027be53f95c16e11e8ea46c833c86182a3a9
The list of functions that can be called in atomic context is
non-intuitive (pm_runtime_put_sync can not, but
pm_runtime_put_sync_suspend can, if pm_runtime_irq_safe has
been called?). The code is actively misleading - the entry
points all start with spin_lock_irqsave, suggesting they
are safe to call in atomic context, but may later
enable interrupts.
Add might_sleep_if to all the __pm_runtime_* entry points
to enforce correct usage.
Also add pm_runtime_put_sync_autosuspend to the list of
functions that can be called in atomic context.
Change-Id: Icac17a10d77c64d44bd2761a91a588dfd1d0c6f0
Signed-off-by: Colin Cross <ccross@android.com>
commit 886486b792e4f6f96d4fbe8ec5bf20811cab7d6a upstream.
Originally, the runtime PM core would send an idle notification
whenever a suspend attempt failed. The idle callback routine could
then schedule a delayed suspend for some time later.
However this behavior was changed by commit
f71648d73c1650b8b4aceb3856bebbde6daa3b86 (PM / Runtime: Remove idle
notification after failing suspend). No notifications were sent, and
there was no clear mechanism to retry failed suspends.
This caused problems for the usbhid driver, because it fails
autosuspend attempts as long as a key is being held down. Therefore
this patch (as1492) adds a mechanism for retrying failed
autosuspends. If the callback routine updates the last_busy field so
that the next autosuspend expiration time is in the future, the
autosuspend will automatically be rescheduled.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Henrik Rydberg <rydberg@euromail.se>
Currently the use of pm_runtime_put_sync() is not safe from
interrupts-disabled context because rpm_idle() will release the
spinlock and enable interrupts for the idle callbacks. This enables
interrupts during a time where interrupts were expected to be
disabled, and can have strange side effects on drivers that expected
interrupts to be disabled.
This is not a bug since the documentation clearly states that only
_put_sync_suspend() is safe in IRQ-safe mode.
However, pm_runtime_put_sync() could be made safe when in IRQ-safe
mode by releasing the spinlock but not re-enabling interrupts, which
is what this patch aims to do.
Problem was found when using some buggy drivers that set
pm_runtime_irq_safe() and used _put_sync() in interrupts-disabled
context.
Reported-by: Colin Cross <ccross@google.com>
Tested-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
dev->power.deferred_resume is used as a bool typically, so change
one assignment to false from 0, like other places.
Signed-off-by: ShuoX Liu <shuox.liu@intel.com>
The runtime PM documentation and kerneldoc comments sometimes spell
"runtime" with a dash (i.e. "run-time"). Replace all of those
instances with "runtime" to make the naming consistent.
Some callers of pm_runtime_get_sync() and other runtime PM helper
functions, scsi_autopm_get_host() and scsi_autopm_get_device() in
particular, need to distinguish error codes returned when runtime PM
is disabled (i.e. power.disable_depth is nonzero for the given
device) from error codes returned in other situations. For this
reason, make the runtime PM helper functions return -EACCES when
power.disable_depth is nonzero and ensure that this error code
won't be returned by them in any other circumstances. Modify
scsi_autopm_get_host() and scsi_autopm_get_device() to check the
error code returned by pm_runtime_get_sync() and ignore -EACCES.
The naming convention used by commit 7538e3db6e015e890825fbd9f86599b
(PM: Add support for device power domains), which introduced the
struct dev_power_domain type for representing device power domains,
evidently confuses some developers who tend to think that objects
of this type must correspond to "power domains" as defined by
hardware, which is not the case. Namely, at the kernel level, a
struct dev_power_domain object can represent arbitrary set of devices
that are mutually dependent power management-wise and need not belong
to one hardware power domain. To avoid that confusion, rename struct
dev_power_domain to struct dev_pm_domain and rename the related
pointers in struct device and struct pm_clk_notifier_block from
pwr_domain to pm_domain.
Acked-by: Kevin Hilman <khilman@ti.com>
Change the PM core's behavior related to power domains in such a way
that, if a power domain is defined for a given device, its callbacks
will be executed instead of and not in addition to the device
subsystem's PM callbacks.
The idea behind the initial implementation of power domains handling
by the PM core was that power domain callbacks would be executed in
addition to subsystem callbacks, so that it would be possible to
extend the subsystem callbacks by using power domains. It turns out,
however, that this wouldn't be really convenient in some important
situations.
For example, there are systems in which power can only be removed
from entire power domains. On those systems it is not desirable to
execute device drivers' PM callbacks until it is known that power is
going to be removed from the devices in question, which means that
they should be executed by power domain callbacks rather then by
subsystem (e.g. bus type) PM callbacks, because subsystems generally
have no information about what devices belong to which power domain.
Thus, for instance, if the bus type in question is the platform bus
type, its PM callbacks generally should not be called in addition to
power domain callbacks, because they run device drivers' callbacks
unconditionally if defined.
While in principle the default subsystem PM callbacks, or a subset of
them, may be replaced with different functions, it doesn't seem
correct to do so, because that would change the subsystem's behavior
with respect to all devices in the system, regardless of whether or
not they belong to any power domains. Thus, the only remaining
option is to make power domain callbacks take precedence over
subsystem callbacks.
The code handling system-wide power transitions (eg. suspend-to-RAM)
can in theory execute callbacks provided by the device's bus type,
device type and class in each phase of the power transition. In
turn, the runtime PM core code only calls one of those callbacks at
a time, preferring bus type callbacks to device type or class
callbacks and device type callbacks to class callbacks.
It seems reasonable to make them both behave in the same way in that
respect. Moreover, even though a device may belong to two subsystems
(eg. bus type and device class) simultaneously, in practice power
management callbacks for system-wide power transitions are always
provided by only one of them (ie. if the bus type callbacks are
defined, the device class ones are not and vice versa). Thus it is
possible to modify the code handling system-wide power transitions
so that it follows the core runtime PM code (ie. treats the
subsystem callbacks as mutually exclusive).
On the other hand, the core runtime PM code will choose to execute,
for example, a runtime suspend callback provided by the device type
even if the bus type's struct dev_pm_ops object exists, but the
runtime_suspend pointer in it happens to be NULL. This is confusing,
because it may lead to the execution of callbacks from different
subsystems during different operations (eg. the bus type suspend
callback may be executed during runtime suspend of the device, while
the device type callback will be executed during system suspend).
Make all of the power management code treat subsystem callbacks in
a consistent way, such that:
(1) If the device's type is defined (eg. dev->type is not NULL)
and its pm pointer is not NULL, the callbacks from dev->type->pm
will be used.
(2) If dev->type is NULL or dev->type->pm is NULL, but the device's
class is defined (eg. dev->class is not NULL) and its pm pointer
is not NULL, the callbacks from dev->class->pm will be used.
(3) If dev->type is NULL or dev->type->pm is NULL and dev->class is
NULL or dev->class->pm is NULL, the callbacks from dev->bus->pm
will be used provided that both dev->bus and dev->bus->pm are
not NULL.
Reasoning-sounds-sane-to: Grant Likely <grant.likely@secretlab.ca>
The platform bus type is often used to handle Systems-on-a-Chip (SoC)
where all devices are represented by objects of type struct
platform_device. In those cases the same "platform" device driver
may be used with multiple different system configurations, but the
actions needed to put the devices it handles into a low-power state
and back into the full-power state may depend on the design of the
given SoC. The driver, however, cannot possibly include all the
information necessary for the power management of its device on all
the systems it is used with. Moreover, the device hierarchy in its
current form also is not suitable for representing this kind of
information.
The patch below attempts to address this problem by introducing
objects of type struct dev_power_domain that can be used for
representing power domains within a SoC. Every struct
dev_power_domain object provides a sets of device power
management callbacks that can be used to perform what's needed for
device power management in addition to the operations carried out by
the device's driver and subsystem.
Namely, if a struct dev_power_domain object is pointed to by the
pwr_domain field in a struct device, the callbacks provided by its
ops member will be executed in addition to the corresponding
callbacks provided by the device's subsystem and driver during all
power transitions.
Tested-and-acked-by: Kevin Hilman <khilman@ti.com>
This patch (as1445) fixes a bug in the runtime PM core left over from
the addition of the no_callbacks flag. If this flag is set then it is
possible for rpm_suspend() to be called in_interrupt, so when
releasing spinlocks it's important not to re-enable interrupts.
To avoid an unnecessary save-and-restore of the interrupt flag, the
patch also inlines a pm_request_idle() call.
This fixes Bugzilla #27482.
(The offending code was added in 2.6.37, so it's not necessary to apply
this to any earlier stable kernels.)
Reported-by: tim blechmann <tim@klingt.org>
CC: <stable@kernel.org>
This patch (as1431c) makes the synchronous runtime-PM interface
suitable for use in interrupt handlers. Subsystems can call the new
pm_runtime_irq_safe() function to tell the PM core that a device's
runtime_suspend and runtime_resume callbacks should be invoked with
interrupts disabled and the spinlock held. This permits the
pm_runtime_get_sync() and the new pm_runtime_put_sync_suspend()
routines to be called from within interrupt handlers.
When a device is declared irq-safe in this way, the PM core increments
the parent's usage count, so the parent will never be runtime
suspended. This prevents difficult situations in which an irq-safe
device can't resume because it is forced to wait for its non-irq-safe
parent.
GCC version 4.5.1 gives the following warning:
drivers/base/power/runtime.c: In function ‘rpm_check_suspend_allowed’:
drivers/base/power/runtime.c:146:25: warning: comparison between ‘enum dpm_state’ and ‘enum rpm_status’
which seems to be a typo in that dev->power.runtime_status
should be compared instead of dev->power.status.
Signed-off-by: Kevin Winchester <kjwinchester@gmail.com>
For device with no_callbacks flag set, its power lock and its parent's
power lock may be held nestedly in rpm_resume, so we should take
spin_lock_nested(lock, SINGLE_DEPTH_NESTING) to acquire parent power lock
to avoid lockdep warning.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
If runtime suspend of a device fails returning -EAGAIN or -EBUSY,
which means that it's safe to try to suspend it again, the PM core
runs the runtime idle helper function for it. Unfortunately this may
lead to problems, for example for PCI devices whose drivers don't
implement the ->runtime_idle() callback, because in that case the
PCI bus type's ->runtime_idle() always calls pm_runtime_suspend()
for the given device. Then, if there's an automatic idle
notification after the driver's ->runtime_suspend() returning -EAGAIN
or -EBUSY, it will make the suspend happen again possibly causing a
busy loop to appear. To avoid that, remove the idle notification
after failing runtime suspend of a device altogether and let the
callers of pm_runtime_suspend() repeat the operation if need be.
Reduce code duplication in rpm_idle(), rpm_suspend() and rpm_resume()
by using local pointers to store callback addresses and moving some
duplicated code into a separate function.
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1427) implements the "autosuspend" facility for runtime
PM. A few new fields are added to the dev_pm_info structure and
several new PM helper functions are defined, for telling the PM core
whether or not a device uses autosuspend, for setting the autosuspend
delay, and for marking periods of device activity.
Drivers that do not want to use autosuspend can continue using the
same helper functions as before; their behavior will not change. In
addition, drivers supporting autosuspend can also call the old helper
functions to get the old behavior.
The details are all explained in Documentation/power/runtime_pm.txt
and Documentation/ABI/testing/sysfs-devices-power.
Some devices, such as USB interfaces, cannot be power-managed
independently of their parents, i.e., they cannot be put in low power
while the parent remains at full power. This patch (as1425) creates a
new "no_callbacks" flag, which tells the PM core not to invoke the
runtime-PM callback routines for the such devices but instead to
assume that the callbacks always succeed. In addition, the
non-debugging runtime-PM sysfs attributes for the devices are removed,
since they are pretty much meaningless.
The advantage of this scheme comes not so much from avoiding the
callbacks themselves, but rather from the fact that without the need
for a process context in which to run the callbacks, more work can be
done in interrupt context.
This patch (as1424) combines the various public entry points for the
runtime PM routines into three simple functions: one for idle, one for
suspend, and one for resume. A new bitflag specifies whether or not
to increment or decrement the usage_count field.
The new entry points are named __pm_runtime_idle,
__pm_runtime_suspend, and __pm_runtime_resume, to reflect that they
are trampolines. Simultaneously, the corresponding internal routines
are renamed to rpm_idle, rpm_suspend, and rpm_resume.
This patch (as1423) merges the asynchronous routines
__pm_request_idle(), __pm_request_suspend(), and __pm_request_resume()
with their synchronous counterparts. The RPM_ASYNC bitflag argument
serves to indicate what sort of operation to perform.
In the course of performing this merger, it became apparent that the
various functions don't all behave consistenly with regard to error
reporting and cancellation of outstanding requests. A new routine,
rpm_check_suspend_allowed(), was written to centralize much of the
testing, and the other functions were revised to follow a simple
algorithm:
If the operation is disallowed because of the device's
settings or current state, return an error.
Cancel pending or scheduled requests of lower priority.
Schedule, queue, or perform the desired operation.
A few special cases and exceptions are noted in comments.
The "from_wq" argument in __pm_runtime_suspend() and
__pm_runtime_resume() supposedly indicates whether or not the function
was called by the PM workqueue thread, but in fact it isn't always
used this way. It really indicates whether or not the function should
return early if the requested operation is already in progress.
Along with this badly-named boolean argument, later patches in this
series will add several other boolean arguments to these functions and
others. Therefore this patch (as1422) begins the conversion process
by replacing from_wq with a bitflag argument. The same bitflags are
also used in __pm_runtime_get() and __pm_runtime_put(), where they
indicate whether or not the operation should be asynchronous.
This patch (as1421) moves the PM runtime accounting subroutines up to
the beginning of runtime.c, taking them out of the middle of the
functions that do the actual work. No operational changes.
Introduce struct wakeup_source for representing system wakeup sources
within the kernel and for collecting statistics related to them.
Make the recently introduced helper functions pm_wakeup_event(),
pm_stay_awake() and pm_relax() use struct wakeup_source objects
internally, so that wakeup statistics associated with wakeup devices
can be collected and reported in a consistent way (the definition of
pm_relax() is changed, which is harmless, because this function is
not called directly by anyone yet). Introduce new wakeup-related
sysfs device attributes in /sys/devices/.../power for reporting the
device wakeup statistics.
Change the global wakeup events counters event_count and
events_in_progress into atomic variables, so that it is not necessary
to acquire a global spinlock in pm_wakeup_event(), pm_stay_awake()
and pm_relax(), which should allow us to avoid lock contention in
these functions on SMP systems with many wakeup devices.
In order for PowerTOP to be able to report how well the new runtime PM is
working for the various drivers, the kernel needs to export some basic
statistics in sysfs.
This patch adds two sysfs files in the runtime PM domain that expose the
total time a device has been active, and the time a device has been
suspended.
With this PowerTOP can compute the activity percentage
Active %age = 100 * (delta active) / (delta active + delta suspended)
and present the information to the user.
I've written the PowerTOP code (slated for version 1.12) already, and the
output looks like this:
Runtime Device Power Management statistics
Active Device name
10.0% 06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller
[version 2: fix stat update bugs noticed by Alan Stern]
[version 3: rebase to -next and move the sysfs declaration]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This patch (as1361) changes the runtime PM interface slightly; it
allows suspend requests to be scheduled while the runtime_suspend
method is running. If the method succeeds then the scheduled request
is cancelled, whereas if the method fails then an idle notification is
sent only if no request was scheduled.
Being able to schedule suspend requests from within a runtime_suspend
method is useful for drivers that need to test for idleness and
suspend the device all while holding a single spinlock, or for drivers
that want to check for idleness by polling.
Add new device sysfs attribute, power/control, allowing the user
space to block the run-time power management of the devices. If this
attribute is set to "on", the driver of the device won't be able to power
manage it at run time (without breaking the rules) and the device will
always be in the full power state (except when the entire system goes
into a sleep state).
The power management of some devices is handled through device types
and device classes rather than through bus types. Since these
devices may also benefit from using the run-time power management
core, extend it so that the device type and device class run-time PM
callbacks can be taken into consideration by it if the bus type
callback is not defined.
Update the run-time PM core documentation to reflect this change.
This patch (as1308c) fixes __pm_runtime_get(). Currently the routine
will resume a device if the prior usage count was 0. But this isn't
right; thanks to pm_runtime_get_noresume() the usage count can be
positive even while the device is suspended.
Some braces in __pm_runtime_set_status() are not necessary, so
remove them.
The runtime PM core code assumes that dev->power.timer_expires is
nonzero when the timer is scheduled, but it may become zero
incidentally in pm_schedule_suspend(). Prevent this from happening
by bumping dev->power.timer_expires up to 1 if it's 0 before calling
mod_timer().
Reported-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1307) adds a small optimization to
__pm_request_resume(). If the device is currently being suspended,
there's no need to queue a work routine to resume it. Setting the
deferred_resume flag will suffice. (There's also a minor improvement
to the function's code layout: An unnecessary "else" is removed.)
Also, the patch clarifies the usage of the deferred_resume flag. It
is meaningful only while a suspend is in progress, so it should be
cleared just before a suspend starts, not just after one ends.
Lockdep complains about taking the parent lock in
__pm_runtime_set_status(), so mark it as nested.
Cc: stable@kernel.org
This patch (as1305) fixes a bug in the irq-enable settings and removes
some related overhead in the runtime PM code.
In __pm_runtime_resume(), within the scope of the original
spin_lock_irq(), we know that irqs are disabled. There's no
reason to go through a pair of enable/disable cycles when
acquiring and releasing the parent's lock.
In __pm_runtime_set_status(), irqs are already disabled when
the parent's lock is acquired, and they must remain disabled
when it is released.
pm_runtime_idle() is somewhat noisy. Remove debug prints.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Introduce a core framework for run-time power management of I/O
devices. Add device run-time PM fields to 'struct dev_pm_info'
and device run-time PM callbacks to 'struct dev_pm_ops'. Introduce
a run-time PM workqueue and define some device run-time PM helper
functions at the core level. Document all these things.
Special thanks to Alan Stern for his help with the design and
multiple detailed reviews of the pereceding versions of this patch
and to Magnus Damm for testing feedback.
Acked-by: Magnus Damm <damm@igel.co.jp>
This patch (as933) removes the deprecated dpm_runtime_suspend() and
dpm_runtime_resume() routines from the PM core. The only user of
those routines is the PCMCIA ds driver; local replacements are added.
CC: Dominik Brodowski <linux@dominikbrodowski.net>
The Power Management code uses semaphores as mutexes. Use the mutex API
instead of the (binary) semaphores.
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Merge the suspend and resume methods for 16-bit PCMCIA cards into the
device model -- for both runtime power management and suspend to ram/disk.
Bugfix in ds.c by Richard Purdie
Signed-Off-By: Richard Purdie <rpurdie@rpsys.net>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
This patch #if 0's an unused global function.
This patch collects various small updates related to root hubs, to shrink
later patches which build on them.
- For root hub suspend/resume support:
* Make the existing usb_hcd_resume_root_hub() routine respect pmcore
locking, exporting and using the dpm_runtime_resume() method.
* Add a new usb_hcd_suspend_root_hub() to pair with that routine.
(Essential to make OHCI autosuspend behave again...)
* HC_SUSPENDED by itself only refers to the root hub's downstream ports.
So let HCDs see root hub URBs unless the parent device is suspended.
- Remove an assertion we no longer need (and now, also don't want).
- Generic suspend/resume updates to work better with swsusp.
* Ignore the FREEZE vs SUSPEND distinction for hardware; trying to
use it breaks the swsusp snapshots it's supposed to help (sigh).
* On resume, mark devices as resumed right away, but then
do nothing else if the device is marked NOTATTACHED.
These changes shouldn't be very noticable by themselves.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
drivers/base/power/runtime.c | 1
drivers/usb/core/hcd.c | 64 ++++++++++++++++++++++++++++++++++++++-----
drivers/usb/core/hcd.h | 1
drivers/usb/core/hub.c | 45 ++++++++++++++++++++++++------
drivers/usb/core/usb.c | 20 +++++++++----
drivers/usb/core/usb.h | 1
6 files changed, 111 insertions(+), 21 deletions(-)
This adds type-checking to pm_message_t, so that people can't confuse it
with int or u32. It also allows us to fix "disk yoyo" during suspend (disk
spinning down/up/down).
[We've tried that before; since that cpufreq problems were fixed and I've
tried make allyes config and fixed resulting damage.]
Signed-off-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: Alexander Nyberg <alexn@telia.com>
infrastructure for it.
Let it rip!
