path: root/drivers/base/transport_class.c
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-07[SCSI] transport_class: BUG if we can't release the attribute containerJames Bottomley
Every current transport class calls transport_container_release but ignores the return value. This is catastrophic if it returns an error because the containers are part of a global list and the next action of almost every transport class is to free the memory used by the container. Fix this by making transport_container_release a void, but making it BUG if attribute_container_release returns an error ... this catches the root cause of a system panic much earlier. If we don't do this, we get an eventual BUG when the attribute container list notices the corruption caused by the freed memory it's still referencing. Also made attribute_container_release __must_check as a reminder. Cc: Greg KH <greg@kroah.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-03docbook: fix kernel-api source filesRandy Dunlap
Fix docbook problems in kernel-api.tmpl. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-08-28[SCSI] fix transport class corner case after reworkJames Bottomley
If your transport class sets the ATTRIBUTE_CONTAINER_NO_CLASSDEVS flag, then its configure method never gets called. This patch fixes that so that the configure method is called with a NULL classdev. Also remove a spurious inverted comma in the transport_class comments. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-14[SCSI] correct transport class abstraction to work outside SCSIJames Bottomley
I recently tried to construct a totally generic transport class and found there were certain features missing from the current abstract transport class. Most notable is that you have to hang the data on the class_device but most of the API is framed in terms of the generic device, not the class_device. These changes are two fold - Provide the class_device to all of the setup and configure APIs - Provide and extra API to take the device and the attribute class and return the corresponding class_device Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
