In rpm_suspend, when suspend fail,
before going to reschedule another autosuspend,
wake_up_all is required to avoid remote wakeup
issues.
Bug 1026169
Bug 1027598
Bug 1032565
Change-Id: Ieaf9282dae59b2cb343bf01aa2ba837a8cdc39c7
Signed-off-by: BH Hsieh <bhsieh@nvidia.com>
Reviewed-on: http://git-master/r/122978
Reviewed-by: Neil Patel <neilp@nvidia.com>
Tested-by: Neil Patel <neilp@nvidia.com>
Tested-by: Steve Lin <stlin@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Steve Lin <stlin@nvidia.com>
debug uart driver needs to be resumed before calling printk
so move debug message after finishing resume
bug 992588
Change-Id: Ia8991a4b7be7a4e2a765c8e6b494fd906b38b98c
Signed-off-by: Daehyoung Ko <dko@nvidia.com>
Reviewed-on: http://git-master/r/108435
(cherry picked from commit 75e7ef273d52b40d5d662541043e7eebc74ee24e)
Reviewed-on: http://git-master/r/110433
In some chips the IRQ status registers are not contiguous in the register
map but spaced at even spaces. This is an easy case to handle with minor
changes. It is assume for this purpose that the stride for status is
equal to the stride for mask/ack registers as well.
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
(cherry picked from commit 022f926a2401c80ed36ebb48a1bffbac08f34d98)
Change-Id: I68a59c8fd8a67062dac0eceaefcc85ed597f4a29
Reviewed-on: http://git-master/r/111484
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Commit f01ee60fffa4 ("regmap: implement register striding") caused the
compile errors below. Fix them.
drivers/base/regmap/regmap-irq.c: In function 'regmap_irq_sync_unlock':
drivers/base/regmap/regmap-irq.c:62:12: error: 'map' undeclared (first use in this function)
drivers/base/regmap/regmap-irq.c:62:12: note: each undeclared identifier is reported only once for each function it appears in
drivers/base/regmap/regmap-irq.c: In function 'regmap_irq_enable':
drivers/base/regmap/regmap-irq.c:77:37: error: 'map' undeclared (first use in this function)
drivers/base/regmap/regmap-irq.c: In function 'regmap_irq_disable':
drivers/base/regmap/regmap-irq.c:85:37: error: 'map' undeclared (first use in this function)
(cherry picked from commit 56806555de5485d6786bf0f8df01b8ed9fc5d006)
Change-Id: I1b0787c81695ddbfb081a1342690a44162474574
Reviewed-on: http://git-master/r/96511
Reviewed-by: Simone Willett <swillett@nvidia.com>
regmap_config.reg_stride is introduced. All extant register addresses
are a multiple of this value. Users of serial-oriented regmap busses will
typically set this to 1. Users of the MMIO regmap bus will typically set
this based on the value size of their registers, in bytes, so 4 for a
32-bit register.
Throughout the regmap code, actual register addresses are used. Wherever
the register address is used to index some array of values, the address
is divided by the stride to determine the index, or vice-versa. Error-
checking is added to all entry-points for register address data to ensure
that register addresses actually satisfy the specified stride. The MMIO
bus ensures that the specified stride is large enough for the register
size.
(cherry picked from commit f01ee60fffa4dc6c77122121233a793f7f696e67)
Change-Id: I634977dcb0fe9ff95c7932e9195a2c1918eb1c18
Reviewed-on: http://git-master/r/96510
Commit 79c64d5 "regmap: allow regmap instances to be named" changed the
prototype of regmap_debugfs_init, but didn't update the dummy inline used
when !CONFIG_DEBUGFS. Fix this.
(cherry picked from commit abec95adefaeb2229cb28de65f3d32cd149b9dd9)
Change-Id: Ieb049fa9ed0dd26d21a37592ecb25488b0909c0b
Reviewed-on: http://git-master/r/96509
Some devices have multiple separate register regions. Logically, one
regmap would be created per region. One issue that prevents this is that
each instance will attempt to create the same debugfs files. Avoid this
by allowing regmaps to be named, and use the name to construct the
debugfs directory name.
cherry-picked form mainline d3c242e
Change-Id: Ia3301fb4d28645f1d3593e547f9409ce20c0acfe
Reviewed-on: http://git-master/r/96508
val_len should be a multiple of val_bytes. If it's not, error out early.
(cherry picked from commit 851960ba7cb38a6a108d102e4c8b0ab702972e22)
Change-Id: Ic17d4bd832b5ea3e426d00ff5d0ae342b8abba45
Reviewed-on: http://git-master/r/96507
These error checks are implemented in regmap core. Remove the duplicate
code from regmap-mmio.c
(cherry picked from commit 9878647f4349dbaa46b4026ed9bbf8acfc0de34c)
Change-Id: I32979da1bbca852470c0cb8d8d997b2c77d6703f
Reviewed-on: http://git-master/r/96506
Some of the error conditions detected by regmap_mmio_*() are pure internal
errors, rather than user-/client-triggerable conditions. Convert these to
BUG().
(cherry picked from commit 40606dba450830e50420599c52a86cf6ce5c6a14)
Change-Id: Ibf926ca6774e4b3d3dd855d42814065858318628
Reviewed-on: http://git-master/r/96505
This is a basic memory-mapped-IO bus for regmap. It has the following
features and limitations:
* Registers themselves may be 8, 16, 32, or 64-bit. 64-bit is only
supported on 64-bit platforms.
* Register offsets are limited to precisely 32-bit.
* IO is performed using readl/writel, with no provision for using the
__raw_readl or readl_relaxed variants.
(cherry picked from commit 45f5ff8107a845854b1d1812ab1d9c5541f08b4d)
Change-Id: Ia84cf3fec838ee687e5b77ce771fc2450abe8436
Reviewed-on: http://git-master/r/96504
Some bus types have very fast IO. For these, acquiring a mutex for every
IO operation is a significant overhead. Allow busses to indicate their IO
is fast, and enhance regmap to use a spinlock for those busses.
[Currently limited to native endian registers -- broonie]
(cherry picked from commit bacdbe077342ecc9e7b3e374cc5a41995116706a)
Change-Id: I337f27a09f2b176b46e8f6d05401957a1abc0609
Reviewed-on: http://git-master/r/96503
The only context needed by I2C and SPI bus definitions is the device
itself; this can be converted to an i2c_client or spi_device in order
to perform IO on the device. However, other bus types may need more
context in order to perform IO. Enable this by having regmap_init accept
a bus_context parameter, and pass this to all bus callbacks. The
existing callbacks simply pass the struct device here. Future bus types
may pass something else.
(cherry picked from commit 0135bbcc7a0cc056f0203ff839466236b8e3dc19)
Change-Id: I36b3fb3433af6e6f1e673fc6c73ba21f7eb4d054
Reviewed-on: http://git-master/r/96502
If there are no nodes in the cache, nodes will be 0, so calculating
"registers / nodes" will cause division by zero.
Cc: stable@vger.kernel.org
(cherry picked from commit c04c1b9ee8f30c7a3a25e20e406247003f634ebe)
Change-Id: I30047f1e0bd08417794c3d19e2fe1d480a74e083
Reviewed-on: http://git-master/r/96501
regcache_sync_region() isn't going to be useful to most drivers if we
don't export it since otherwise they can't use it when built modular.
(cherry picked from commit e466de05194b666114713b753e2f4be1d4200140)
Change-Id: I38b12c791f0a462ebbbfbe4a6b25cfa3265ffacc
Reviewed-on: http://git-master/r/96500
This change combines any padding bits into the register address bits when
determining register format handlers to use the next byte-divisible
register size.
A reg_shift member is introduced to the regmap struct to enable fixup
of the reg format.
Format handlers now take an extra parameter specifying the number of
bits to shift the value by.
Signed-off-by: Marc Reilly <marc@cpdesign.com.au>
(cherry picked from commit d939fb9a78b4743bc4bc3cc415894ed42050c5cc)
Change-Id: I80921cfa4dd6aea5e7038927a313baeb347689e2
Reviewed-on: http://git-master/r/96499
Add support for devices with 24 data bits.
(cherry picked from commit ea279fc5619e2541a0c28196b0fa06447d9ad026)
Change-Id: I69ccd494eb8622c442d55294c24ecd6acd78cfcb
Reviewed-on: http://git-master/r/96498
The code currently passes the register offset in the current block to
regcache_lookup_reg. This works fine as long as there is only one block and with
base register of 0, but in all other cases it will look-up the default for a
wrong register, which can cause unnecessary register writes. This patch fixes
it by passing the actual register number to regcache_lookup_reg.
Cc: <stable@vger.kernel.org>
(cherry picked from commit 4b4e9e43fd210e0cd2a5d29357e7c000e13e08ae)
Change-Id: Ibed70828471423df5432fea67316ca9ad8aeb52a
Reviewed-on: http://git-master/r/96497
Remove for_each_set_bit_cont() after confirming that no one uses
for_each_set_bit_cont() anymore.
[sfr@canb.auug.org.au: regmap: cope with bitops API change]
Cc: Robert Richter <robert.richter@amd.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cherry-pick from mainline 0a329d2
Change-Id: I6655096e5d58a1215b225035daa8dd8a2f6327d9
Reviewed-on: http://git-master/r/96496
[Fix for breakage which will be introduced during the merge window via
header reworks in another tree, the regmap tree does include device.h
but Paul's tree breaks that. Reworded subject to reflect -- broonie]
regmap.s uses devres_alloc() and others that are prototyped in device.h.
Include that to solve the following:
drivers/base/regmap/regmap.c: In function 'devm_regmap_init':
drivers/base/regmap/regmap.c:331:2: error: implicit declaration of function 'devres_alloc' [-Werror=implicit-function-declaration]
drivers/base/regmap/regmap.c:338:3: error: implicit declaration of function 'devres_add' [-Werror=implicit-function-declaration]
drivers/base/regmap/regmap.c:340:3: error: implicit declaration of function 'devres_free' [-Werror=implicit-function-declaration]
drivers/base/regmap/regmap.c: In function '_regmap_raw_write':
drivers/base/regmap/regmap.c:421:5: error: implicit declaration of function 'dev_err' [-Werror=implicit-function-declaration]
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
(cherry picked from commit f5d6eba74b8aac7d4bf646c5445807aa6a247e6c)
Change-Id: I38c390fb5085bf3e815aa5c4048d4f89d8698563
Reviewed-on: http://git-master/r/96495
Otherwise we'll end up running with bogus register numbers.
(cherry picked from commit f9353e70bcebd00cd182d946083afd7d8eddd259)
Change-Id: I7615fd2d63ec29dd869585fb20a151067b53c72a
Reviewed-on: http://git-master/r/96494
Most of the current users have register 0 as a volatile register or don't
have a register 0 so it's not been apparent that it's not getting synced.
(cherry picked from commit 994f5db65ef4b83db0321842bd43c6bc0a51f000)
Change-Id: Iaada5ae8ba705f45049eb1c85a1909a9f192f765
Reviewed-on: http://git-master/r/96493
Remove unused module.h and/or replace with export.h
as required.
(cherry picked from commit 19694b5ea1d3a723dafe9544b5ee9a935414dc28)
Change-Id: Icf76b35f6d0d1f4720ca6d51fa9b2ebf123604b1
Reviewed-on: http://git-master/r/96492
(cherry picked from commit a0941e562e8008804f9fe4400315ceb164752fac)
Change-Id: Ic582509f74612ddc48f854116553e2f40954e4ae
Reviewed-on: http://git-master/r/96491
Provide a regcache_sync_region() operation which allows drivers to
write only part of the cache back to the hardware. This is intended
for use in cases like power domains or DSP memories where part of the
device register map may be reset without fully resetting the device.
Fully supporting these devices is likely to require additional work to
make specific regions of the register map cache only while they are in
reset, but this is enough for most devices.
(cherry picked from commit 4d4cfd1656b5f6c88eae51c40741a695b108b006)
Change-Id: Ia8cccf7986611485ae090e234bb68084671d7641
Reviewed-on: http://git-master/r/96490
In order to allow us to support partial sync operations add minimum and
maximum register arguments to the sync operation and update the rbtree
and lzo caches to use this new information. The LZO implementation is
obviously not good, we could exit the iteration earlier, but there may
be room for more wide reaching optimisation there.
(cherry picked from commit ac8d91c801905a061ca883dca427a5e19602a1e7)
Change-Id: I92ceee1c704ea7c864bff0559d36cf34554c3ba5
Reviewed-on: http://git-master/r/96489
Useful for figuring out where the hardware interaction went or came from.
(cherry picked from commit 5d5b7d4f80ed6e861c1c220fd57e3dad0912526e)
Change-Id: Ie7c0659458a3a4a2f100d86db552c606d9da0e6b
Reviewed-on: http://git-master/r/96488
Previously the cache would never be marked clean, meaning syncs would
never be suppressed which isn't the end of the world but could be
inefficient.
(cherry picked from commit 6ff7373809a9b4eb644d83e2e299da297e1cbffa)
Change-Id: I52aef73bc6bc0df10dd64da92d0bf591e44ddc0e
Reviewed-on: http://git-master/r/96487
It's not used as all cache types have sync operations so it's just dead
code which never gets tested.
(cherry picked from commit c3ec23288a92e20e0aff84a4cb6fbc7cc9bcf567)
Change-Id: I3ba8c8afee9a7c945dc0a52e87c9f4a357e79308
Reviewed-on: http://git-master/r/96486
Saves some I/O when resyncing; we assume that syncs start from the device
reset state.
(cherry picked from commit a3c3774176838bbfa4f6e48133644903818e56dc)
Change-Id: Ib4471bd06856ccd2652f21dd0d9d51319df00939
Reviewed-on: http://git-master/r/96485
Add a file called 'name' containing the name of the driver.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
(cherry picked from commit f0c2319f9f196726ebe4d7508fd8fbd804988db3)
Change-Id: Id67e73cfd573a71377fe6bbc5c3068718822ef38
Reviewed-on: http://git-master/r/96484
To enable writing to the regmap debugfs registers file users will
need to modify the source directly and #define REGMAP_ALLOW_WRITE_DEBUGFS.
The reason for this is that it is dangerous to expose this
functionality in general where clients could potentially be PMICs.
[A couple of minor style updates -- broonie]
(cherry picked from commit 09c6ecd394105c4864a0e409e181c9b1578c2a63)
Change-Id: Ia9408880e25d5060796ab79812a023def00b10bc
Reviewed-on: http://git-master/r/96483
Fall back to a register by register read to do so; most likely we'll be
cache only so the overhead will be low.
(cherry picked from commit b8fb5ab156055b745254609f4635fcfd6b7dabc8)
Change-Id: I9f3b6011f4704987c5a014de8b30a2e6e3196d21
Reviewed-on: http://git-master/r/96482
Generic infrastructure based on top of regmap may want to operate on
blocks of data and therefore find it useful to find the size of the
register values. Provide an accessor operation for this.
Cherry-pick from mainline a6539c3
Change-Id: I455ace158eea38f6a92938f6330ec074bc18f0da
Reviewed-on: http://git-master/r/96481
(cherry picked from commit 7d5e525b9ceda0e3b85da0acdaa2de19fea51edc)
Change-Id: I6f6fec44b439b4916eba7f32ece1fa011e3ac021
Reviewed-on: http://git-master/r/96480
During regcache_init, if client has not passed the
default data of cached register then it is directly
read from the hw to initialize cache. This hw register
read happens before cache ops are initialized and hence
avoiding register read to check for the data available
on cache or not by enabling flag of cache_bypass.
(cherry picked from commit df00c79f78d8b0ad788daf689ea461ace9d0811f)
Change-Id: I4398162bd6b12689c795afe5ee02397e975e456c
Reviewed-on: http://git-master/r/87593
Currently registers with a value of 0 are ignored when initializing the register
defaults from raw defaults. This worked in the past, because registers without a
explicit default were assumed to have a default value of 0. This was changed in
commit b03622a8 ("regmap: Ensure rbtree syncs registers set to zero properly").
As a result registers, which have a raw default value of 0 are now assumed to
have no default. This again can result in unnecessary writes when syncing the
cache. It will also result in unnecessary reads for e.g. the first update
operation. In the case where readback is not possible this will even let the
update operation fail, if the register has not been written to before.
So this patch removes the check. Instead it adds a check to ignore raw defaults
for registers which are volatile, since those registers are not cached.
(cherry picked from commit 61cddc57dc14a5dffa0921d9a24fd68edbb374ac)
Change-Id: Iccd58a95a432d222befd8b339fe0c6edd26666bb
Reviewed-on: http://git-master/r/87592
The bulk_write() supports the data transfer to multi
register which takes the data into cpu_endianness format
and does formatting of data to device format before
sending to device.
The transfer can be completed in single transfer or multiple
transfer based on data formatting.
(cherry picked from commit 8eaeb21925563075ae036c2e5ba8d041b70e18fa)
Change-Id: Id97fbcfa0ed7d00d97dc3ab89fdb2b025850c9b1
Reviewed-on: http://git-master/r/87591
Adding support for caching of data into the
non-volatile register from the call of reg_raw_write().
This will allow the larger block of data write into multiple
register without worrying whether register is cached or not
through reg_raw_write().
(cherry picked from commit c9157198417076c0c2664ba997e7b0217f61fcce)
Change-Id: I6e6a96bc9e08ca9b7fe0f52a0a5692a4a61ef0ae
Reviewed-on: http://git-master/r/87590
The first parameter should be "number of elements" and the second parameter
should be "element size".
(cherry picked from commit 2a14d7d9b7439fe62082a60a7f8983ccb463d134)
Change-Id: Ibe00000c7c6db1b36e5530e00713cdb434052f0a
Reviewed-on: http://git-master/r/87589
Show all the cache status flags in debugfs if we have a cache.
(cherry picked from commit 028a01e601487b5991b70dba506dfe87d83543f6)
Change-Id: I2b5297143ea8c81477a5124c7db0e6683fd56255
Reviewed-on: http://git-master/r/87588
This was a cut'n'paste from some older code.
Since we're about to add debugfs support don't do the obvious thing and
use bool, use u32 instead (which debugfs has been using since time
immemorial).
cherry-picked from mainline
847fb6fdf58c0ef4c207d2853a043a4da3db9c76
Change-Id: I0eff043969a97190e7470bc695ef78323e9cb8d7
Reviewed-on: http://git-master/r/87587
regcache_set_val() returns false if cache[idx] != val.
Thus it actually is not unreachable.
(cherry picked from commit aa795d129246cb4c973076e3242b8a2eb374f1ef)
Change-Id: I83bbce848914e4648723a5c5dd0ca7f04ba0c64e
Reviewed-on: http://git-master/r/87586
Save error handling and unwinding code in drivers by providing managed
versions of the regmap init functions, simplifying usage.
(cherry picked from commit c0eb46766d395da8d62148bda2e59bad5e6ee2f2)
Change-Id: I6df96ae10ad8a882feb7da908dd46c2f56a28f9f
Reviewed-on: http://git-master/r/87585
Using .format_write means, we have a custom function to write to the
chip, but not to read back. Also, mark registers as "not precious" and
"not volatile" which is implicit because we cannot read them. Make those
functions use 'regmap_readable' to reuse the checks done there.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
(cherry picked from commit 4191f19792bf91267835eb090d970e9cd6277a65)
Change-Id: Iff0be114904ada151315750fdd92ba562dab6314
Reviewed-on: http://git-master/r/87584
For the upcoming 2/6-format, we don't see debugfs output otherwise,
since the current division results in 0. I'd think 10/14 is broken
currently, too.
(cherry picked from commit c212acccc368a087a53559aac2b7d3be941b1252)
Change-Id: I2d8d1683f1649697ad73aa7544a3ac994931e237
Reviewed-on: http://git-master/r/87583
(cherry picked from commit 9aa507505cdcd10b7390398790f013374ee74a26)
Change-Id: I3af1a4c4e9aa30f9ebbd64d5c1818e3e04328e7e
Reviewed-on: http://git-master/r/87582
Most of the data exposed via debugfs is for or from the cache so reset
all the debugfs configuration to make sure everything is up to date with
the latest configuration, especially if we're changing cache type.
cherry-picked from mainline commit
a24f64a648376766497fddd8bc24b1ca5b906431
Change-Id: I9db449602d9c37b22e024bf78a54fd7d09a07638
Reviewed-on: http://git-master/r/87581
Otherwise any patch that affects a register which is writable may trash
cached values.
(cherry picked from commit 8a892d6996b60c822f19ad1844eb15b96ce393c7)
Change-Id: I278d4f4aa34709e2e15d0cc83238e4b419f159cb
Reviewed-on: http://git-master/r/87580
On the basis that if we don't actually need to resync the cache then the
patches are probably also already applied.
(cherry picked from commit d9db762708e27c2892db9d8a54e735a8e506e16e)
Change-Id: I1b41ea112ae97812be6c9e2e3ea8c490e0835732
Reviewed-on: http://git-master/r/87579
