path: root/drivers/base
2008-06-11dev_set_name: fix missing kernel-docRandy Dunlap
Fix kernel-doc for new dev_set_name() function: Warning(lin2626-rc5//drivers/base/core.c:767): No description found for parameter 'fmt' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29driver-core: prepare for 2.6.27 api change by adding dev_set_nameStephen Rothwell
Create the dev_set_name function now so that various subsystems can start changing over to it before other changes in 2.6.27 will make it compulsory. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) pktgen: make sure that pktgen_thread_worker has been executed [VLAN]: Propagate selected feature bits to VLAN devices drivers/atm/: remove CVS keywords vlan: Correctly handle device notifications for layered VLAN devices net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() net_sched: cls_api: fix return value for non-existant classifiers ipsec: Use the correct ip_local_out function ipv6 addrconf: Allow infinite prefix lifetime. ipv6 route: Fix lifetime in netlink. ipv6 addrconf: Fix route lifetime setting in corner case. ndisc: Add missing strategies for per-device retrans timer/reachable time settings. ipv6: Move <linux/in6.h> from header-y to unifdef-y. l2tp: avoid skb truesize bug if headroom is increased wireless: Create 'device' symlink in sysfs wireless, airo: waitbusy() won't delay libertas: fix command timeout after firmware failure mac80211: Add RTNL version of ieee80211_iterate_active_interfaces mac80211 : Association with 11n hidden ssid ap. hostap: fix "registers" registration in procfs isdn/capi: Return proper errnos on module init. ...
2008-05-20Driver core: add device_create_vargs and device_create_drvdataGreg Kroah-Hartman
We want to have the drvdata field set properly when creating the device as sysfs callbacks can assume it is present and it can race the later setting of this field. So, create two new functions, deviec_create_vargs() and device_create_drvdata() that take this new field. device_create_drvdata() will go away in 2.6.27 as the drvdata field will just be moved to the device_create() call as it should be. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-15Clean up 'print_fn_descriptor_symbol()' typesLinus Torvalds
Everybody wants to pass it a function pointer, and in fact, that is what you _must_ pass it for it to make sense (since it knows that ia64 and ppc64 use descriptors for function pointers and fetches the actual address from there). So don't make the argument be a 'unsigned long' and force everybody to add a cast. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14sysfs: remove error messages for -EEXIST caseStephen Hemminger
It is possible that the entry in sysfs already exists, one case of this is when a network device is renamed to bonding_masters. Anyway, in this case the proper error path is for device_rename to return an error code, not to generate bogus backtrace and errors. Also, to avoid possible races, the create link should be done before the remove link. This makes a device rename atomic operation like other renames. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: Driver core: struct class remove children list block: do_mounts - accept root=<non-existant partition>
2008-05-14Driver core: struct class remove children listDave Young
because of the class_device was removed, now do the children list removing Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (73 commits) net: Fix typo in net/core/sock.c. ppp: Do not free not yet unregistered net device. netfilter: xt_iprange: module aliases for xt_iprange netfilter: ctnetlink: dump conntrack ID in event messages irda: Fix a misalign access issue. (v2) sctp: Fix use of uninitialized pointer cipso: Relax too much careful cipso hash function. tcp FRTO: work-around inorder receivers tcp FRTO: Fix fallback to conventional recovery New maintainer for Intel ethernet adapters DM9000: Use delayed work to update MII PHY state DM9000: Update and fix driver debugging messages DM9000: Add __devinit and __devexit attributes to probe and remove sky2: fix simple define thinko [netdrvr] sfc: sfc: Add self-test support [netdrvr] sfc: Increment rx_reset when reported as driver event [netdrvr] sfc: Remove unused macro EFX_XAUI_RETRAIN_MAX [netdrvr] sfc: Fix code formatting [netdrvr] sfc: Remove kernel-doc comments for removed members of struct efx_nic [netdrvr] sfc: Remove garbage from comment ...
2008-05-13memory: Introduce exports for memory notifiersHannes Hering
This patch introduces two exports to allow modules to use memory notifiers. Signed-off-by: Hannes Hering <hering2@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-06Fix bogus warning in sysdev_driver_register()OGAWA Hirofumi
if ((drv->entry.next != drv->entry.prev) || (drv->entry.next != NULL)) { warns list_empty(&drv->entry). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Greg KH <gregkh@suse.de> Cc: Len Brown <lenb@kernel.org> [ Version 2 totally redone based on suggestions from Linus & Greg ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01cpu: change cpu_sys_devices from array to per_cpu variableMike Travis
Change cpu_sys_devices from array to per_cpu variable in drivers/base/cpu.c. Signed-off-by: Mike Travis <travis@sgi.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30driver core: remove no longer used "struct class_device"Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-30driver core: warn about duplicate driver names on the same busStas Sergeev
Currently an attempt to register multiple drivers with the same name causes the stack trace with some cryptic error message. The attached patch adds the necessary check and the clear error message. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-30mm: Add NR_WRITEBACK_TEMP counterMiklos Szeredi
Fuse will use temporary buffers to write back dirty data from memory mappings (normal writes are done synchronously). This is needed, because there cannot be any guarantee about the time in which a write will complete. By using temporary buffers, from the MM's point if view the page is written back immediately. If the writeout was due to memory pressure, this effectively migrates data from a full zone to a less full zone. This patch adds a new counter (NR_WRITEBACK_TEMP) for the number of pages used as temporary buffers. [Lee.Schermerhorn@hp.com: add vmstat_text for NR_WRITEBACK_TEMP] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-bigbox-pci * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-bigbox-pci: x86: add pci=check_enable_amd_mmconf and dmi check x86: work around io allocation overlap of HT links acpi: get boot_cpu_id as early for k8_scan_nodes x86_64: don't need set default res if only have one root bus x86: double check the multi root bus with fam10h mmconf x86: multi pci root bus with different io resource range, on 64-bit x86: use bus conf in NB conf fun1 to get bus range on, on 64-bit x86: get mp_bus_to_node early x86 pci: remove checking type for mmconfig probe x86: remove unneeded check in mmconf reject driver core: try parent numa_node at first before using default x86: seperate mmconf for fam10h out from setup_64.c x86: if acpi=off, force setting the mmconf for fam10h x86_64: check MSR to get MMCONFIG for AMD Family 10h x86_64: check and enable MMCONFIG for AMD Family 10h x86_64: set cfg_size for AMD Family 10h in case MMCONFIG x86: mmconf enable mcfg early x86: clear pci_mmcfg_virt when mmcfg get rejected x86: validate against acpi motherboard resources Fixed up fairly trivial conflicts in arch/x86/pci/{init.c,pci.h} due to OLPC support manually.
2008-04-29firmware loader: printk when requesting firmwareCiaran McCreesh
Before requesting firmware, printk a message saying what we're requesting. This makes it easier to see what's going on, and provides an explanation for the huge silent delay that one would otherwise get after accidentally building ipw2200 as a non-module. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26driver core: try parent numa_node at first before using defaultYinghai Lu
in the device_add, we try to use use parent numa_node. need to make sure pci root bus's bridge device numa_node is set. then we could use device->numa_node direclty for all device. and don't need to call pcibus_to_node(). Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-22bus_remove_device: be more careful about incomplete initializationRafael J. Wysocki
Prevent bus_remove_device() from crashing if dev->knode_bus has not been initialized before it's called. This can happen if the device_add() ended up breaking out early due to an error, for example. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22Relax check on adding children of suspended devicesRafael J. Wysocki
Do not refuse to actually register children of suspended devices, but still warn about attempts to do that. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits) SCSI: convert struct class_device to struct device DRM: remove unused dev_class IB: rename "dev" to "srp_dev" in srp_host structure IB: convert struct class_device to struct device memstick: convert struct class_device to struct device driver core: replace remaining __FUNCTION__ occurrences sysfs: refill attribute buffer when reading from offset 0 PM: Remove destroy_suspended_device() Firmware: add iSCSI iBFT Support PM: Remove legacy PM (fix) Kobject: Replace list_for_each() with list_for_each_entry(). SYSFS: Explicitly include required header file slab.h. Driver core: make device_is_registered() work for class devices PM: Convert wakeup flag accessors to inline functions PM: Make wakeup flags available whenever CONFIG_PM is set PM: Fix misuse of wakeup flag accessors in serial core Driver core: Call device_pm_add() after bus_add_device() in device_add() PM: Handle device registrations during suspend/resume block: send disk "change" event for rescan_partitions() sysdev: detect multiple driver registrations ... Fixed trivial conflict in include/linux/memory.h due to semaphore header file change (made irrelevant by the change to mutex).
2008-04-21Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Deprecate the asm/semaphore.h files in feature-removal-schedule. Convert asm/semaphore.h users to linux/semaphore.h security: Remove unnecessary inclusions of asm/semaphore.h lib: Remove unnecessary inclusions of asm/semaphore.h kernel: Remove unnecessary inclusions of asm/semaphore.h include: Remove unnecessary inclusions of asm/semaphore.h fs: Remove unnecessary inclusions of asm/semaphore.h drivers: Remove unnecessary inclusions of asm/semaphore.h net: Remove unnecessary inclusions of asm/semaphore.h arch: Remove unnecessary inclusions of asm/semaphore.h
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19driver core: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19PM: Remove destroy_suspended_device()Rafael J. Wysocki
After 2.6.24 there was a plan to make the PM core acquire all device semaphores during a suspend/hibernation to protect itself from concurrent operations involving device objects. That proved to be too heavy-handed and we found a better way to achieve the goal, but before it happened, we had introduced the functions device_pm_schedule_removal() and destroy_suspended_device() to allow drivers to "safely" destroy a suspended device and we had adapted some drivers to use them. Now that these functions are no longer necessary, it seems reasonable to remove them and modify their users to use the normal device unregistration instead. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19Driver core: make device_is_registered() work for class devicesGreg Kroah-Hartman
device_is_registered() can use the kobject value for this, so it will now work with devices that are associated with only a class, not a bus and a driver. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19PM: Make wakeup flags available whenever CONFIG_PM is setAlan Stern
The various wakeup flags and their accessor macros in struct dev_pm_info should be available whenever CONFIG_PM is enabled, not just when CONFIG_PM_SLEEP is on. Otherwise remote wakeup won't always be configurable for runtime power management. This patch (as1056b) fixes the oversight. David Brownell adds: More accurately, fixes the "regression" ... as noted sometime last summer, after 296699de6bdc717189a331ab6bbe90e05c94db06 introduced CONFIG_SUSPEND. But that didn't make the regression list for that kernel, ergo the delay in fixing it. [rjw: rebased] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19Driver core: Call device_pm_add() after bus_add_device() in device_add()Rafael J. Wysocki
Include dpm_sysfs_add() into device_pm_add(), in analogy with device_pm_remove(), and modify device_add() to call the latter after bus_add_device(), to avoid situations in which the PM core may attempt to suspend a device the registration of which has not been successful. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19PM: Handle device registrations during suspend/resumeRafael J. Wysocki
Modify the PM core to protect its data structures, specifically the dpm_active list, from being corrupted if a child of the currently suspending device is registered concurrently with its ->suspend() callback. In that case, since the new device (the child) is added to dpm_active after its parent, the PM core will attempt to suspend it after the parent, which is wrong. Introduce a new member of struct dev_pm_info, called 'sleeping', and use it to check if the parent of the device being added to dpm_active has been suspended, in which case the device registration fails. Also, use 'sleeping' for checking if the ordering of devices on dpm_active is correct. Introduce variable 'all_sleeping' that will be set to 'true' once all devices have been suspended and make new device registrations fail until 'all_sleeping' is reset to 'false', in order to avoid having unsuspended devices around while the system is going into a sleep state. Remove pm_sleep_rwsem which is not necessary any more. Special thanks to Alan Stern for discussions and suggestions that lead to the creation of this patch. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19sysdev: detect multiple driver registrationsBen Dooks
I've just found how easy it is to accidentally register a sysdev_driver for two different classes. When this happens, bad things happen as the sysdev_driver structure keeps has the list entry for the driver registration. The following patch makes a WARN_ON() if this happens, although I think BUG_ON or returning -EAGAIN could also be valid responses to this. Signed-off-by: Ben Dooks <ben@fluff.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19driver core: cpu: fix section mismatch in cpu.c:store_onlineSam Ravnborg
Fix following warning: WARNING: vmlinux.o(.text+0x64609c): Section mismatch in reference from the function store_online() to the function .cpuinit.text:cpu_up() store_online() is defined inside a HOTPLUG_CPU block so references are OK. Ignore references by annotating store_online() with __ref. Note: This is needed because cpu_up() most likely should not have been __cpuinit but all the hotplug cpu code misuses the __cpuinit annotation. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19power_state: remove it from driver corePavel Machek
power_state is scheduled for removal, and it is used only for debug prints by driver core. Remove it. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19driver core: register_memory/unregister_memory clean ups and bugfixBadari Pulavarty
register_memory()/unregister_memory() never gets called with "root". unregister_memory() is accessing kobject_name of the object just freed up. Since no one uses the code, lets take the code out. And also, make register_memory() static. Another bug fix - before calling unregister_memory() remove_memory_block() gets a ref on kobject. unregister_memory() need to drop that ref before calling sysdev_unregister(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19driver core: memory: semaphore to mutexDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19cpumask: add show cpu map functionsMike Travis
* Add cpu_sysdev_class functions to display the following maps with cpulist_scnprintf(). cpu_online_map cpu_present_map cpu_possible_map * Small change to include/linux/sysdev.h to allow the attribute name and label to be different (to avoid collision with the "attr_online" entry for bringing cpus on- and off-line.) Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19cpumask: use new cpus_scnprintf functionMike Travis
* Cleaned up references to cpumask_scnprintf() and added new cpulist_scnprintf() interfaces where appropriate. * Fix some small bugs (or code efficiency improvments) for various uses of cpumask_scnprintf. * Clean up some checkpatch errors. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19nodemask: use new node_to_cpumask_ptr functionMike Travis
* Use new node_to_cpumask_ptr. This creates a pointer to the cpumask for a given node. This definition is in mm patch: asm-generic-add-node_to_cpumask_ptr-macro.patch * Use new set_cpus_allowed_ptr function. Depends on: [mm-patch]: asm-generic-add-node_to_cpumask_ptr-macro.patch [sched-devel]: sched: add new set_cpus_allowed_ptr function [x86/latest]: x86: add cpus_scnprintf function Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Greg Banks <gnb@melbourne.sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-07[SCSI] transport_class: BUG if we can't release the attribute containerJames Bottomley
Every current transport class calls transport_container_release but ignores the return value. This is catastrophic if it returns an error because the containers are part of a global list and the next action of almost every transport class is to free the memory used by the container. Fix this by making transport_container_release a void, but making it BUG if attribute_container_release returns an error ... this catches the root cause of a system panic much earlier. If we don't do this, we get an eventual BUG when the attribute container list notices the corruption caused by the freed memory it's still referencing. Also made attribute_container_release __must_check as a reminder. Cc: Greg KH <greg@kroah.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-28driver core: fix small mem leak in driver_add_kobj()Jesper Juhl
The Coverity checker spotted that we leak the storage allocated to 'name' in int driver_add_kobj(). The leak looks legit to me - this is the code : int driver_add_kobj(struct device_driver *drv, struct kobject *kobj, const char *fmt, ...) { va_list args; char *name; int ret; va_start(args, fmt); name = kvasprintf(GFP_KERNEL, fmt, args); ^^^^^^^^ This dynamically allocates space... va_end(args); if (!name) return -ENOMEM; return kobject_add(kobj, &drv->p->kobj, "%s", name); ^^^^^^^^ This neglects to free the space allocated } Inside kobject_add() a copy of 'name' will be made and used. As far as I can see, Coverity is correct in flagging this as a leak, but I'd like some configmation before the patch is applied. This should fix it. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-24driver core: debug for bad dev_attr_show() return value.Andrew Morton
Try to find the culprit who caused http://bugzilla.kernel.org/show_bug.cgi?id=10150 Cc: <balajirrao@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10drivers: fix dma_get_required_maskJames Bottomley
There's a bug in the current implementation of dma_get_required_mask() where it ands the returned mask with the current device mask. This rather defeats the purpose if you're using the call to determine what your mask should be (since you will at that time have the default DMA_32BIT_MASK). This bug results in any driver that uses this function *always* getting a 32 bit mask, which is wrong. Fix by removing the and with dev->dma_mask. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10sysdev: fix problem with sysdev_class being re-registeredGreg Kroah-Hartman
We need to initialize the kobject for a sysdev_class as it could have been recycled (stupid static kobjects...) We also do the same thing in case sysdev devices are being re-registered. Thanks to Balaji Rao <balajirrao@gmail.com> for pointing out the problem. Signed-off-by: Balaji Rao <balajirrao@gmail.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04Driver core: Fix cleanup when failing device_add().Cornelia Huck
Driver core: Fix cleanup when failing device_add(). - Don't call cleanup_device_parent() if we didn't call setup_parent(). - dev->kobj.parent may be NULL when cleanup_device_parent() is called, so we need to handle glue_dir == NULL in cleanup_glue_dir(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04driver core: Remove dpm_sysfs_remove() from error path of device_add()Rafael J. Wysocki
Since device_pm_remove(dev) calls dpm_sysfs_remove(dev), it's incorrect to call the latter after the former in the device_add() error path. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04PM: fix new mutex-locking bug in the PM coreAlan Stern
This patch (as1041) fixes a bug introduced by the acquire-all-device-semaphores reversion. The error pathway of dpm_suspend() fails to reacquire a mutex it should be holding. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04PM: Do not acquire device semaphores upfront during suspendRafael J. Wysocki
Remove the code that acquires all device semaphores from the suspend code path as it causes multiple problems to appear (most notably, http://bugzilla.kernel.org/show_bug.cgi?id=10030) and revert the change introduced by commit 4145ed6dc597a9bea5f6ae8c574653b2de10620f depending on the code being removed. Remove pm_sleep_lock()/pm_sleep_unlock() from device_add() to avoid the issue reported at http://bugzilla.kernel.org/show_bug.cgi?id=9874. It should fix the regreesions reported at: http://bugzilla.kernel.org/show_bug.cgi?id=9874 http://bugzilla.kernel.org/show_bug.cgi?id=10030 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-03docbook: fix kernel-api source filesRandy Dunlap
Fix docbook problems in kernel-api.tmpl. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-21Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (26 commits) PM: Make suspend_device() static PCI ACPI: Fix comment describing acpi_pci_choose_state Hibernation: Handle DEBUG_PAGEALLOC on x86 ACPI: fix build warning ACPI: TSC breaks atkbd suspend ACPI: remove is_processor_present prototype acer-wmi: Add DMI match for mail LED on Acer TravelMate 4200 series ACPI: sparse fix, replace macro with static function ACPI: thinkpad-acpi: add tablet-mode reporting ACPI: thinkpad-acpi: minor hotkey_radio_sw fixes ACPI: thinkpad-acpi: improve thinkpad-acpi input device documentation ACPI: thinkpad-acpi: issue input events for tablet swivel events ACPI: thinkpad-acpi: make the video output feature optional ACPI: thinkpad-acpi: synchronize input device switches ACPI: thinkpad-acpi: always track input device open/close ACPI: thinkpad-acpi: trivial fix to documentation ACPI: thinkpad-acpi: trivial fix to module_desc typo intel_menlo: extract return values using PTR_ERR ACPI video: check for error from thermal_cooling_device_register ACPI thermal: extract return values using PTR_ERR ...
2008-02-21PM: Remove unbalanced mutex_unlock() from dpm_resume()Rafael J. Wysocki
Remove an unnecessary unlocking of dpm_list_mtx in the error path in drivers/base/power/main.c:dpm_suspend() . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
