commit 1c34203a1496d1849ba978021b878b3447d433c8 upstream.
It is not necessary to call device_remove_groups() when device_add_groups()
fails.
The group added by device_add_groups() should be removed if sysfs_create_link()
fails.
Fixes: fa6fdb33b486 ("driver core: bus_type: add dev_groups")
Signed-off-by: Junjie Mao <junjie_mao@yeah.net>
commit 7085a7401ba54e92bbb5aa24d6f428071e18e509 upstream.
This fixes a regression from the net subsystem:
After commit d52fdbb735c36a209f36a628d40ca9185b349ba7
"smc91x: retrieve IRQ and trigger flags in a modern way"
a regression would appear on some legacy platforms such
as the ARM PXA Zylonite that specify IRQ resources like
this:
static struct resource r = {
.start = X,
.end = X,
.flags = IORESOURCE_IRQ | IORESOURCE_IRQ_HIGHEDGE,
The previous code would retrieve the resource and parse
the high edge setting in the SMC91x driver, a use pattern
that means every driver specifying an IRQ flag from a
static resource need to parse resource flags and apply
them at runtime.
As we switched the code to use IRQ descriptors to retrieve
the the trigger type like this:
irqd_get_trigger_type(irq_get_irq_data(...));
the code would work for new platforms using e.g. device
tree as the backing irq descriptor would have its flags
properly set, whereas this kind of oldstyle static
resources at no point assign the trigger flags to the
corresponding IRQ descriptor.
To make the behaviour identical on modern device tree
and legacy static platform data platforms, modify
platform_get_irq() to assign the trigger flags to the
irq descriptor when a client looks up an IRQ from static
resources.
Fixes: d52fdbb735c3 ("smc91x: retrieve IRQ and trigger flags in a modern way")
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 8a7d95f95c95f396decbd4cda6d4903fc4664946 upstream.
On architectures that depend on DT for obtaining cache hierarcy, we need
to validate the device node for all the cache indices, failing to do so
might result in wrong information being exposed to the userspace.
This is quite possible on initial/incomplete versions of the device
trees. In such cases, it's better to bail out if all the required device
nodes are not present.
This patch adds checks for the validation of device node for all the
caches and doesn't initialise the cacheinfo if there's any error.
Reported-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap fix from Mark Brown:
"This patch fixes a bad interaction between the support that was added
for having regmaps without devices for early system controller
initialization and the trace support.
There's a very good analysis of the actual issue in the commit message
for the change"
* tag 'regmap-fix-v4.0-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: introduce regmap_name to fix syscon regmap trace events
This patch fixes a NULL pointer dereference when enabling regmap event
tracing in the presence of a syscon regmap, introduced by commit bdb0066df96e
("mfd: syscon: Decouple syscon interface from platform devices").
That patch introduced syscon regmaps that have their dev field set to NULL.
The regmap trace events expect it to point to a valid struct device and feed
it to dev_name():
$ echo 1 > /sys/kernel/debug/tracing/events/regmap/enable
Unable to handle kernel NULL pointer dereference at virtual address 0000002c
pgd = 80004000
[0000002c] *pgd=00000000
Internal error: Oops: 17 [#1] SMP ARM
Modules linked in: coda videobuf2_vmalloc
CPU: 0 PID: 304 Comm: kworker/0:2 Not tainted 4.0.0-rc2+ #9197
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
Workqueue: events_freezable thermal_zone_device_check
task: 9f25a200 ti: 9f1ee000 task.ti: 9f1ee000
PC is at ftrace_raw_event_regmap_block+0x3c/0xe4
LR is at _regmap_raw_read+0x1bc/0x1cc
pc : [<803636e8>] lr : [<80365f2c>] psr: 600f0093
sp : 9f1efd78 ip : 9f1efdb8 fp : 9f1efdb4
r10: 00000004 r9 : 00000001 r8 : 00000001
r7 : 00000180 r6 : 00000000 r5 : 9f00e3c0 r4 : 00000003
r3 : 00000001 r2 : 00000180 r1 : 00000000 r0 : 9f00e3c0
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 2d91004a DAC: 00000015
Process kworker/0:2 (pid: 304, stack limit = 0x9f1ee210)
Stack: (0x9f1efd78 to 0x9f1f0000)
fd60: 9f1efda4 9f1efd88
fd80: 800708c0 805f9510 80927140 800f0013 9f1fc800 9eb2f490 00000000 00000180
fda0: 808e3840 00000001 9f1efdfc 9f1efdb8 80365f2c 803636b8 805f8958 800708e0
fdc0: a00f0013 803636ac 9f16de00 00000180 80927140 9f1fc800 9f1fc800 9f1efe6c
fde0: 9f1efe6c 9f732400 00000000 00000000 9f1efe1c 9f1efe00 80365f70 80365d7c
fe00: 80365f3c 9f1fc800 9f1fc800 00000180 9f1efe44 9f1efe20 803656a4 80365f48
fe20: 9f1fc800 00000180 9f1efe6c 9f1efe6c 9f732400 00000000 9f1efe64 9f1efe48
fe40: 803657bc 80365634 00000001 9e95f910 9f1fc800 9f1efeb4 9f1efe8c 9f1efe68
fe60: 80452ac0 80365778 9f1efe8c 9f1efe78 9e93d400 9e93d5e8 9f1efeb4 9f72ef40
fe80: 9f1efeac 9f1efe90 8044e11c 80452998 8045298c 9e93d608 9e93d400 808e1978
fea0: 9f1efecc 9f1efeb0 8044fd14 8044e0d0 ffffffff 9f25a200 9e93d608 9e481380
fec0: 9f1efedc 9f1efed0 8044fde8 8044fcec 9f1eff1c 9f1efee0 80038d50 8044fdd8
fee0: 9f1ee020 9f72ef40 9e481398 00000000 00000008 9f72ef54 9f1ee020 9f72ef40
ff00: 9e481398 9e481380 00000008 9f72ef40 9f1eff5c 9f1eff20 80039754 80038bfc
ff20: 00000000 9e481380 80894100 808e1662 00000000 9e4f2ec0 00000000 9e481380
ff40: 800396f8 00000000 00000000 00000000 9f1effac 9f1eff60 8003e020 80039704
ff60: ffffffff 00000000 ffffffff 9e481380 00000000 00000000 9f1eff78 9f1eff78
ff80: 00000000 00000000 9f1eff88 9f1eff88 9e4f2ec0 8003df30 00000000 00000000
ffa0: 00000000 9f1effb0 8000eb60 8003df3c 00000000 00000000 00000000 00000000
ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff
Backtrace:
[<803636ac>] (ftrace_raw_event_regmap_block) from [<80365f2c>] (_regmap_raw_read+0x1bc/0x1cc)
r9:00000001 r8:808e3840 r7:00000180 r6:00000000 r5:9eb2f490 r4:9f1fc800
[<80365d70>] (_regmap_raw_read) from [<80365f70>] (_regmap_bus_read+0x34/0x6c)
r10:00000000 r9:00000000 r8:9f732400 r7:9f1efe6c r6:9f1efe6c r5:9f1fc800
r4:9f1fc800
[<80365f3c>] (_regmap_bus_read) from [<803656a4>] (_regmap_read+0x7c/0x144)
r6:00000180 r5:9f1fc800 r4:9f1fc800 r3:80365f3c
[<80365628>] (_regmap_read) from [<803657bc>] (regmap_read+0x50/0x70)
r9:00000000 r8:9f732400 r7:9f1efe6c r6:9f1efe6c r5:00000180 r4:9f1fc800
[<8036576c>] (regmap_read) from [<80452ac0>] (imx_get_temp+0x134/0x1a4)
r6:9f1efeb4 r5:9f1fc800 r4:9e95f910 r3:00000001
[<8045298c>] (imx_get_temp) from [<8044e11c>] (thermal_zone_get_temp+0x58/0x74)
r7:9f72ef40 r6:9f1efeb4 r5:9e93d5e8 r4:9e93d400
[<8044e0c4>] (thermal_zone_get_temp) from [<8044fd14>] (thermal_zone_device_update+0x34/0xec)
r6:808e1978 r5:9e93d400 r4:9e93d608 r3:8045298c
[<8044fce0>] (thermal_zone_device_update) from [<8044fde8>] (thermal_zone_device_check+0x1c/0x20)
r5:9e481380 r4:9e93d608
[<8044fdcc>] (thermal_zone_device_check) from [<80038d50>] (process_one_work+0x160/0x3d4)
[<80038bf0>] (process_one_work) from [<80039754>] (worker_thread+0x5c/0x4f4)
r10:9f72ef40 r9:00000008 r8:9e481380 r7:9e481398 r6:9f72ef40 r5:9f1ee020
r4:9f72ef54
[<800396f8>] (worker_thread) from [<8003e020>] (kthread+0xf0/0x108)
r10:00000000 r9:00000000 r8:00000000 r7:800396f8 r6:9e481380 r5:00000000
r4:9e4f2ec0
[<8003df30>] (kthread) from [<8000eb60>] (ret_from_fork+0x14/0x34)
r7:00000000 r6:00000000 r5:8003df30 r4:9e4f2ec0
Code: e3140040 1a00001a e3140020 1a000016 (e596002c)
---[ end trace 193c15c2494ec960 ]---
Fixes: bdb0066df96e (mfd: syscon: Decouple syscon interface from platform devices)
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Mark Brown <broonie@kernel.org>
Cc: stable@vger.kernel.org
Pull regmap fixes from Mark Brown:
"A few things here:
- a change from Lars to fix insertion of cache values at the start of
rather than end of a rbtree block. This hadn't been noticed before
since almost everything lists registers in ascending order.
- a fix from Takashi for spurious warnings during cache sync with
read once registers, a problem which can be very noticeable on
devices that it affects.
- a fix from Valentin for a tighening of the oneshot IRQ request
interface which would have broken affected devices"
* tag 'regmap-v4.0-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: regcache-rbtree: Fix present bitmap resize
regmap: Skip read-only registers in regcache_sync()
regmap-irq: set IRQF_ONESHOT flag to ensure IRQ request
'regmap/fix/sync' into regmap-linus
When inserting a new register into a block at the lower end the present
bitmap is currently shifted into the wrong direction. The effect of this is
that the bitmap becomes corrupted and registers which are present might be
reported as not present and vice versa.
Fix this by shifting left rather than right.
Fixes: 472fdec7380c("regmap: rbtree: Reduce number of nodes, take 2")
Reported-by: Daniel Baluta <daniel.baluta@gmail.com>
* pm-domains:
PM / Domains: cleanup: rename gpd -> genpd in debugfs interface
* pm-cpufreq:
cpufreq: ppc: Add missing #include <asm/smp.h>
Export pm_system_wakeup function to allow irq handlers to deal with system
wakeup.
This is needed for shared IRQ lines where one of the handler is registered
with IRQF_NO_SUSPEND, while the other ones want to configure it as a wakeup
source.
In this specific case, irq core does not handle the wakeup process and
leave the decision to each irq handler.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
regcache_sync() spews warnings when a value was cached for a read-only
register as it tries to write all registers no matter whether they are
writable or not. This patch adds regmap_wrtieable() checks for
avoiding it in regcache_sync_block_single() and regcache_block_raw().
To keep consisitency with the rest of the file, use 'genpd' as the
name of the 'struct generic_pm_domain' pointer instead of 'gpd'.
This is just a rename, no functional changes.
Signed-off-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Pavel Machek <pavel@ucw.cz>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg KH:
"Really tiny set of patches for this kernel. Nothing major, all
described in the shortlog and have been in linux-next for a while"
* tag 'driver-core-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
sysfs: fix warning when creating a sysfs group without attributes
firmware_loader: handle timeout via wait_for_completion_interruptible_timeout()
firmware_loader: abort request if wait_for_completion is interrupted
firmware: Correct function name in comment
device: Change dev_<level> logging functions to return void
device: Fix dev_dbg_once macro
Merge fourth set of updates from Andrew Morton:
- the rest of lib/
- checkpatch updates
- a few misc things
- kasan: kernel address sanitizer
- the rtc tree
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (108 commits)
ARM: mvebu: enable Armada 38x RTC driver in mvebu_v7_defconfig
ARM: mvebu: add Device Tree description of RTC on Armada 38x
MAINTAINERS: add the RTC driver for the Armada38x
drivers/rtc/rtc-armada38x: add a new RTC driver for recent mvebu SoCs
rtc: armada38x: add the device tree binding documentation
rtc: rtc-ab-b5ze-s3: add sub-minute alarm support
rtc: add support for Abracon AB-RTCMC-32.768kHz-B5ZE-S3 I2C RTC chip
of: add vendor prefix for Abracon Corporation
drivers/rtc/rtc-rk808.c: fix rtc time reading issue
drivers/rtc/rtc-isl12057.c: constify struct regmap_config
drivers/rtc/rtc-at91sam9.c: constify struct regmap_config
drivers/rtc/rtc-imxdi.c: add more known register bits
drivers/rtc/rtc-imxdi.c: trivial clean up code
ARM: mvebu: ISL12057 rtc chip can now wake up RN102, RN102 and RN2120
rtc: rtc-isl12057: add isil,irq2-can-wakeup-machine property for in-tree users
drivers/rtc/rtc-isl12057.c: add alarm support to Intersil ISL12057 RTC driver
drivers/rtc/rtc-pcf2123.c: add support for devicetree
kprobes: makes kprobes/enabled works correctly for optimized kprobes.
kprobes: set kprobes_all_disarmed earlier to enable re-optimization.
init: remove CONFIG_INIT_FALLBACK
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject
bogus threaded irq requests") threaded IRQs without a primary handler
need to be requested with IRQF_ONESHOT, otherwise the request will fail.
The %irq_flags flag is used to request the threaded IRQ and is also a
parameter of the caller. Hence, we cannot be sure that IRQF_ONESHOT is
set. This change avoids the potentially missing flag by setting
IRQF_ONESHOT when requesting the threaded IRQ.
Generated by: scripts/coccinelle/misc/irqf_oneshot.cocci
Signed-off-by: Valentin Rothberg <Valentin.Rothberg@lip6.fr>
printk and friends can now format bitmaps using '%*pb[l]'. cpumask
and nodemask also provide cpumask_pr_args() and nodemask_pr_args()
respectively which can be used to generate the two printf arguments
necessary to format the specified cpu/nodemask.
* Line termination only requires one extra space at the end of the
buffer. Use PAGE_SIZE - 1 instead of PAGE_SIZE - 2 when formatting.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
* pm-cpufreq:
cpufreq: speedstep-smi: enable interrupts when waiting
* pm-cpuidle:
intel_idle: support additional Broadwell model
* pm-devfreq:
PM / devfreq: event: testing the wrong variable
* pm-opp:
PM / OPP / clk: Remove unnecessary OOM message
* pm-tools:
tools/power turbostat: support additional Broadwell model
tools/power turbostat: update parameters, documentation
tools/power turbostat: Skip printing disabled package C-states
This patch reduces the kernel size by removing error messages that duplicate
the normal OOM message.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
identifier f,print,l;
expression e;
constant char[] c;
e = \(kzalloc\|kmalloc\|devm_kzalloc\|devm_kmalloc\)(...);
if (e == NULL) {
- print(...,c,...);
... when any
goto l;
return ...;
Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com>
Acked-by: Nishanth Menon <nm@ti.com>
Pull ACPI and power management updates from Rafael Wysocki:
"We have a few new features this time, including a new SFI-based
cpufreq driver, a new devfreq driver for Tegra Activity Monitor, a new
devfreq class for providing its governors with raw utilization data
and a new ACPI driver for AMD SoCs.
Still, the majority of changes here are reworks of existing code to
make it more straightforward or to prepare it for implementing new
features on top of it. The primary example is the rework of ACPI
resources handling from Jiang Liu, Thomas Gleixner and Lv Zheng with
support for IOAPIC hotplug implemented on top of it, but there is
quite a number of changes of this kind in the cpufreq core, ACPICA,
ACPI EC driver, ACPI processor driver and the generic power domains
core code too.
The most active developer is Viresh Kumar with his cpufreq changes.
Specifics:
- Rework of the core ACPI resources parsing code to fix issues in it
and make using resource offsets more convenient and consolidation
of some resource-handing code in a couple of places that have grown
analagous data structures and code to cover the the same gap in the
core (Jiang Liu, Thomas Gleixner, Lv Zheng).
- ACPI-based IOAPIC hotplug support on top of the resources handling
rework (Jiang Liu, Yinghai Lu).
- ACPICA update to upstream release 20150204 including an interrupt
handling rework that allows drivers to install raw handlers for
ACPI GPEs which then become entirely responsible for the given GPE
and the ACPICA core code won't touch it (Lv Zheng, David E Box,
Octavian Purdila).
- ACPI EC driver rework to fix several concurrency issues and other
problems related to events handling on top of the ACPICA's new
support for raw GPE handlers (Lv Zheng).
- New ACPI driver for AMD SoCs analogous to the LPSS (Low-Power
Subsystem) driver for Intel chips (Ken Xue).
- Two minor fixes of the ACPI LPSS driver (Heikki Krogerus, Jarkko
Nikula).
- Two new blacklist entries for machines (Samsung 730U3E/740U3E and
510R) where the native backlight interface doesn't work correctly
while the ACPI one does (Hans de Goede).
- Rework of the ACPI processor driver's handling of idle states to
make the code more straightforward and less bloated overall (Rafael
J Wysocki).
- Assorted minor fixes related to ACPI and SFI (Andreas Ruprecht,
Andy Shevchenko, Hanjun Guo, Jan Beulich, Rafael J Wysocki, Yaowei
Bai).
- PCI core power management modification to avoid resuming (some)
runtime-suspended devices during system suspend if they are in the
right states already (Rafael J Wysocki).
- New SFI-based cpufreq driver for Intel platforms using SFI
(Srinidhi Kasagar).
- cpufreq core fixes, cleanups and simplifications (Viresh Kumar,
Doug Anderson, Wolfram Sang).
- SkyLake CPU support and other updates for the intel_pstate driver
(Kristen Carlson Accardi, Srinivas Pandruvada).
- cpufreq-dt driver cleanup (Markus Elfring).
- Init fix for the ARM big.LITTLE cpuidle driver (Sudeep Holla).
- Generic power domains core code fixes and cleanups (Ulf Hansson).
- Operating Performance Points (OPP) core code cleanups and kernel
documentation update (Nishanth Menon).
- New dabugfs interface to make the list of PM QoS constraints
available to user space (Nishanth Menon).
- New devfreq driver for Tegra Activity Monitor (Tomeu Vizoso).
- New devfreq class (devfreq_event) to provide raw utilization data
to devfreq governors (Chanwoo Choi).
- Assorted minor fixes and cleanups related to power management
(Andreas Ruprecht, Krzysztof Kozlowski, Rickard Strandqvist, Pavel
Machek, Todd E Brandt, Wonhong Kwon).
- turbostat updates (Len Brown) and cpupower Makefile improvement
(Sriram Raghunathan)"
* tag 'pm+acpi-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (151 commits)
tools/power turbostat: relax dependency on APERF_MSR
tools/power turbostat: relax dependency on invariant TSC
Merge branch 'pci/host-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into acpi-resources
tools/power turbostat: decode MSR_*_PERF_LIMIT_REASONS
tools/power turbostat: relax dependency on root permission
ACPI / video: Add disable_native_backlight quirk for Samsung 510R
ACPI / PM: Remove unneeded nested #ifdef
USB / PM: Remove unneeded #ifdef and associated dead code
intel_pstate: provide option to only use intel_pstate with HWP
ACPI / EC: Add GPE reference counting debugging messages
ACPI / EC: Add query flushing support
ACPI / EC: Refine command storm prevention support
ACPI / EC: Add command flushing support.
ACPI / EC: Introduce STARTED/STOPPED flags to replace BLOCKED flag
ACPI: add AMD ACPI2Platform device support for x86 system
ACPI / table: remove duplicate NULL check for the handler of acpi_table_parse()
ACPI / EC: Update revision due to raw handler mode.
ACPI / EC: Reduce ec_poll() by referencing the last register access timestamp.
ACPI / EC: Fix several GPE handling issues by deploying ACPI_GPE_DISPATCH_RAW_HANDLER mode.
ACPICA: Events: Enable APIs to allow interrupt/polling adaptive request based GPE handling model
* pm-domains:
PM: Convert dev_pm_put_subsys_data() into a void function
PM: Update function header for dev_pm_get_subsys_data()
PM / Domains: Handle errors from genpd's ->attach_dev() callback
PM / Domains: Re-order initialization of generic_pm_domain_data
PM / Domains: Free pm_subsys_data in error path in __pm_genpd_add_device()
PM / Domains: Eliminate the mutex for the generic_pm_domain_data
PM / Domains: Don't check for an existing device when adding a new
PM / Domains: Don't allow an existing generic_pm_domain_data
PM / Domains: Remove reference counting for the generic_pm_domain_data
PM / Domains: Rename __pm_genpd_alloc|free_dev_data()
PM / Domains: Remove pm_genpd_dev_need_restore() API
* pm-qos:
PM / QoS: Use lockdep asserts to find missing hold of power.lock
PM / QoS: Add debugfs support to view the list of constraints
* pm-opp:
PM / OPP: Assert RCU lock in exported functions
PM / OPP: Update kernel documentation
PM / OPP: Ensure consistent naming of static functions
PM / OPP: export dev_pm_opp_get_notifier
* pm-devfreq:
PM / devfreq: event: Add documentation for exynos-ppmu devfreq-event driver
devfreq: Fix build break of devfreq-event class
PM / devfreq: event: Add devfreq_event class
PM / devfreq: tegra: add devfreq driver for Tegra Activity Monitor
'regmap/topic/smbus' into regmap-next
SMBus access functions assume that 16-bit values are formatted as
little endian numbers. The direct i2c access functions in regmap,
however, assume that 16-bit values are formatted as big endian numbers.
As a result, the current code returns different values if an i2c chip's
16-bit registers are accessed through i2c access functions vs. SMBus
access functions.
Use regmap_smbus_read_word_swapped and regmap_smbus_write_word_swapped
for 16-bit SMBus accesses if a chip is configured as REGMAP_ENDIAN_BIG.
If the chip is configured as REGMAP_ENDIAN_LITTLE, keep using
regmap_smbus_write_word_data and regmap_smbus_read_word_data. Otherwise
reject registration if the controller does not support direct i2c accesses.
We'll need to call it from regmap-i2c.c, which can be built as module.
It is simpler to handle timeout by wait_for_completion_interruptible_timeout(),
so remove previous delay work for timeout.
Signed-off-by: Ming Lei <ming.lei@canonical.com>
If current request is interrupted by signal, such as 'ctrl + c',
this request has to be aborted for the following reasons:
- the buf need to be removed from pending list
- same requests from other contexts need to be completed
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Use the correct function name in the kernel-doc comment above it.
Acked-by: Ming Lei <ming.lei@canonical.com>
Clients using the dev_pm_put_subsys_data() API isn't interested of a
return value. They care only of decreasing a reference to the device's
pm_subsys_data. So, let's convert the API to a void function, which
anyway seems like reasonable thing to do.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
The commit "PM: Make dev_pm_get_subsys_data() always return 0 on success"
changed the return value from dev_pm_get_subsys_data(). Let's update the
comment in the function header to reflect this change as well.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
The optional genpd's ->attach_dev() callback is invoked from
__pm_genpd_add_device(). Let's add error handling from the response
from this callback and propagate the error code.
When __pm_genpd_add_device() is invoked through the generic OF-based PM
domain look-up path, the device is being probed. Returning an error
will mean the device won't be attached to its PM domain. Errors of
-EPROBE_DEFER get special treatment and is propagated to the driver
core.
Therefore this change also enables the ->attach_dev() callback to
be able to request for a deferred probe sequence.
Move the initialization of the struct generic_pm_domain_data into
genpd_alloc_dev_data(), including the assignment of the device's
->pm_domain() callback. Make corresponding changes to
genpd_free_dev_data().
These changes will make the related code more readable. It will also
decrease the critical regions for where genpd's mutex is being held and
for where the device's power related spinlock is being held.
The error path in __pm_genpd_add_device() didn't decrease the reference
to the struct pm_subsys_data.
Let's move the calls to dev_pm_get|put_subsys_data() into
genpd_alloc|free_dev_data() to fix this issue and thus prevent a
potential memory leakage.
While adding devices to their PM domains, dev_pm_qos_add_notifier() was
invoked while allocating the generic_pm_domain_data for the device.
Since the generic_pm_domain_data's device pointer will be assigned
after allocation, the ->genpd_dev_pm_qos_notifier() callback could be
called prior having a valid pointer to the device. Similar scenario
existed while removing a device from a genpd.
To cope with these scenarios a mutex was used to protect the pointer to
the device.
By re-order the sequence for when dev_pm_qos_add|remove_notifier() are
invoked, we make sure the ->genpd_dev_pm_qos_notifier() callback are
always called with a valid device pointer available.
In this way, we eliminate the need for protecting the pointer and thus
we can remove the mutex from the struct generic_pm_domain_data.
When adding a device to a genpd, we no longer need to walk genpd's list
of existing devices to verify it hasn't already been added.
Instead we can now rely on the verification of not allowing existing
generic_pm_domain_data for a device, since that has the same meaning.
When adding a device to a genpd, a struct generic_pm_domain_data is
allocated per device.
Verify that there are no existing generic_pm_domain_data for the device
we are about to add, since that tells us it has already been added to a
genpd.
When genpd supported PM domain device callbacks, this was a valid
scenario. Now it isn't so let's return an error code.
The reference counting was needed when genpd supported PM domain device
callbacks. Since this option has been removed, let's also remove the
reference counting of the struct generic_pm_domain_data.
In a step to get consistent names of functions in genpd, rename
the internal __pm_genpd_alloc|free_dev_data() into
gendp_alloc|free_dev_data().
As discussed on the linux-pm list, let's move towards the following
name rules:
Internal functions:
genpd_*
_genpd_*
__genpd_*
External functions:
pm_genpd_*
_pm_genpd_*
__pm_genpd_*
No caller or macro uses the return value so make all
the functions return void.
Compiled x86 allyesconfig and defconfig w/o CONFIG_PRINTK
There are currently no users of this API, let's remove it.
Additionally, if such feature would be needed future wise, a better
option is likely use pm_runtime_set_active|suspended() in some form.
Acked-by: Kevin Hilman <khilman@linaro.org>
Add lockdep asserts for holding the RCU lock when calling
dev_pm_opp_get_freq() and dev_pm_opp_get_voltage() to aid in detecting
RCU misuses.
These are called often after dev_pm_opp_find_freq_ceil/exact() which
already asserts for RCU lock. However one could make an error by
releasing lock too early - just after dev_pm_opp_find_freq_ceil().
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Add lockdep asserts for holding the dev->power.lock to non-static
functions which require this. They could be used outside of the file so
asserts may help in detecting locking misuse.
kernel doc has gotten bit-rotted over time. Re-sync with Locking and
Return information. document all functions properly and ensure that
./scripts/kernel-doc -v ./drivers/base/power/opp.c >/dev/null returns
no errors
Signed-off-by: Nishanth Menon <nm@ti.com>
All exported functions use dev_pm_* prefix and all static functions
are now standardized with _ prefix. This is better than having to deal
with multiple function naming styles within the same file.
Allows user drivers such as devfreq to be modules.
* pm-domains:
PM / Domains: Export of_genpd_get_from_provider function
* powercap:
powercap / RAPL: add IDs for future Xeon CPUs
* pm-tools:
tools / cpupower: Fix no idle state information return value
tools / cpupower: Correctly detect if running as root
* pm-opp:
PM / OPP: take RCU lock in dev_pm_opp_get_opp_count
PM / OPP: fix warning in of_free_opp_table()
PM / OPP: add some lockdep annotations
Pull more ACPI and power management updates from Rafael Wysocki:
"These are regression fixes (leds-gpio, ACPI backlight driver,
operating performance points library, ACPI device enumeration
messages, cpupower tool), other bug fixes (ACPI EC driver, ACPI device
PM), some cleanups in the operating performance points (OPP)
framework, continuation of CONFIG_PM_RUNTIME elimination, a couple of
minor intel_pstate driver changes, a new MAINTAINERS entry for it and
an ACPI fan driver change needed for better support of thermal
management in user space.
Specifics:
- Fix a regression in leds-gpio introduced by a recent commit that
inadvertently changed the name of one of the properties used by the
driver (Fabio Estevam).
- Fix a regression in the ACPI backlight driver introduced by a
recent fix that missed one special case that had to be taken into
account (Aaron Lu).
- Drop the level of some new kernel messages from the ACPI core
introduced by a recent commit to KERN_DEBUG which they should have
used from the start and drop some other unuseful KERN_ERR messages
printed by ACPI (Rafael J Wysocki).
- Revert an incorrect commit modifying the cpupower tool (Prarit
Bhargava).
- Fix two regressions introduced by recent commits in the OPP library
and clean up some existing minor issues in that code (Viresh
Kumar).
- Continue to replace CONFIG_PM_RUNTIME with CONFIG_PM throughout the
tree (or drop it where that can be done) in order to make it
possible to eliminate CONFIG_PM_RUNTIME (Rafael J Wysocki, Ulf
Hansson, Ludovic Desroches).
There will be one more "CONFIG_PM_RUNTIME removal" batch after this
one, because some new uses of it have been introduced during the
current merge window, but that should be sufficient to finally get
rid of it.
- Make the ACPI EC driver more robust against race conditions related
to GPE handler installation failures (Lv Zheng).
- Prevent the ACPI device PM core code from attempting to disable
GPEs that it has not enabled which confuses ACPICA and makes it
report errors unnecessarily (Rafael J Wysocki).
- Add a "force" command line switch to the intel_pstate driver to
make it possible to override the blacklisting of some systems in
that driver if needed (Ethan Zhao).
- Improve intel_pstate code documentation and add a MAINTAINERS entry
for it (Kristen Carlson Accardi).
- Make the ACPI fan driver create cooling device interfaces witn
names that reflect the IDs of the ACPI device objects they are
associated with, except for "generic" ACPI fans (PNP ID "PNP0C0B").
That's necessary for user space thermal management tools to be able
to connect the fans with the parts of the system they are supposed
to be cooling properly. From Srinivas Pandruvada"
* tag 'pm+acpi-3.19-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
MAINTAINERS: add entry for intel_pstate
ACPI / video: update the skip case for acpi_video_device_in_dod()
power / PM: Eliminate CONFIG_PM_RUNTIME
NFC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
ACPI / EC: Fix unexpected ec_remove_handlers() invocations
Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()"
tracing / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
x86 / PM: Replace CONFIG_PM_RUNTIME in io_apic.c
PM: Remove the SET_PM_RUNTIME_PM_OPS() macro
mmc: atmel-mci: use SET_RUNTIME_PM_OPS() macro
PM / Kconfig: Replace PM_RUNTIME with PM in dependencies
ARM / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
sound / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
phy / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
video / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
tty / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
spi: Replace CONFIG_PM_RUNTIME with CONFIG_PM
ACPI / PM: Do not disable wakeup GPEs that have not been enabled
ACPI / utils: Drop error messages from acpi_evaluate_reference()
* pm-opp:
PM / OPP: do error handling at the bottom of dev_pm_opp_add_dynamic()
PM / OPP: handle allocation of device_opp in a separate routine
PM / OPP: reuse find_device_opp() instead of duplicating code
PM / OPP: Staticize __dev_pm_opp_remove()
PM / OPP: replace kfree with kfree_rcu while freeing 'struct device_opp'
* pm-cpufreq:
intel_pstate: Add a few comments
intel_pstate: add kernel parameter to force loading
* pm-tools:
