path: root/drivers/bcma/Kconfig
2013-01-02bcma: BCMA_DRIVER_GPIO should depend on GPIOLIB instead of selecting itGeert Uytterhoeven
Commit cf0936b06d8e98a157630e99f647e2ff6d29d7ad ("bcma: add GPIO driver") added BCMA_DRIVER_GPIO, which unconditionally selects GPIOLIB, causing a Kconfig warning: warning: (ARCH_REQUIRE_GPIOLIB && SSB_DRIVER_GPIO && BCMA_DRIVER_GPIO && MFD_TC6393XB && FB_VIA) selects GPIOLIB which has unmet direct dependencies (ARCH_WANT_OPTIONAL_GPIOLIB || ARCH_REQUIRE_GPIOLIB) and build failure for m68k/allmodconfig: In file included from include/linux/bcma/bcma.h:8, from drivers/bcma/bcma_private.h:9, from drivers/bcma/main.c:9: include/linux/bcma/bcma_driver_chipcommon.h:582: error: field ‘gpio’ has incomplete type In file included from include/linux/bcma/bcma.h:12, from drivers/bcma/bcma_private.h:9, from drivers/bcma/main.c:9: include/linux/ssb/ssb.h:440: error: field ‘gpio’ has incomplete type make[4]: *** [drivers/bcma/main.o] Error 1 make[3]: *** [drivers/bcma/] Error 2 Turn the select into a dependency to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-11-21bcma: add GPIO driverHauke Mehrtens
Register a GPIO driver to access the GPIOs provided by the chip. The GPIOs of the SoC should always start at 0 and the other GPIOs could start at a random position. There is just one SoC in a system and when they start at 0 the number is predictable. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Patchwork: http://patchwork.linux-mips.org/patch/4587 Acked-by: Florian Fainelli <florian@openwrt.org>
2012-08-21bcma: detect and register NAND flash deviceRafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-21bcma: detect and register serial flash deviceRafał Miłecki
2012-07-17bcma: add place for flash memory supportRafał Miłecki
2012-07-12bcma: add trivial GBIT MAC COMMON driverRafał Miłecki
GMAC COMMON core is present on BCM4706 and is used for example to access board PHYs (PHYs can not be accessed directly using GBIT MAC core). Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10bcma: fix build error on MIPS; implicit pcibios_enable_devicePaul Gortmaker
The following is seen during allmodconfig builds for MIPS: drivers/bcma/driver_pci_host.c:518:2: error: implicit declaration of function 'pcibios_enable_device' [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors make[3]: *** [drivers/bcma/driver_pci_host.o] Error 1 Most likey introduced by commit 49dc9577155576b10ff79f0c1486c816b01f58bf "bcma: add PCIe host controller" Add the header instead of implicitly assuming it will be present. Sounds like a good idea, but that alone doesn't fix anything. The real problem is that the Kconfig has settings related to whether PCI is possible, i.e. config BCMA_HOST_PCI_POSSIBLE bool depends on BCMA && PCI = y default y config BCMA_HOST_PCI bool "Support for BCMA on PCI-host bus" depends on BCMA_HOST_PCI_POSSIBLE ...but what is missing is that BCMA_DRIVER_PCI_HOSTMODE doesn't have any dependencies on the above. Add one. CC: Hauke Mehrtens <hauke@hauke-m.de> CC: John W. Linville <linville@tuxdriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08bcma: add mips driverHauke Mehrtens
This adds a mips driver to bcma. This is only found on embedded devices. For now the driver just initializes the irqs used on this system. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08bcma: add SOC busHauke Mehrtens
This patch adds support for using bcma on a Broadcom SoC as the system bus. An SoC like the bcm4716 could register this bus and use it to searches for the bcma cores and register the devices on this bus. BCMA_HOSTTYPE_NONE was intended for SoCs at first but BCMA_HOSTTYPE_SOC is a better name. Acked-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-07bcma: detect PCI core working in hostmodeRafał Miłecki
We must not init it like clientmode one, it would break device (tested by Hauke on BCM4718). Add stub hostmode driver for now. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01bcma: host pci: implement block R/W operationsRafał Miłecki
2011-05-10bcma: add Broadcom specific AMBA bus driverRafał Miłecki
Broadcom has released cards based on a new AMBA-based bus type. From a programming point of view, this new bus type differs from AMBA and does not use AMBA common registers. It also differs enough from SSB. We decided that a new bus driver is needed to keep the code clean. In its current form, the driver detects devices present on the bus and registers them in the system. It allows registering BCMA drivers for specified bus devices and provides them basic operations. The bus driver itself includes two important bus managing drivers: ChipCommon core driver and PCI(c) core driver. They are early used to allow correct initialization. Currently code is limited to supporting buses on PCI(e) devices, however the driver is designed to be used also on other hosts. The host abstraction layer is implemented and already used for PCI(e). Support for PCI(e) hosts is working and seems to be stable (access to 80211 core was tested successfully on a few devices). We can still optimize it by using some fixed windows, but this can be done later without affecting any external code. Windows are just ranges in MMIO used for accessing cores on the bus. Cc: Greg KH <greg@kroah.com> Cc: Michael Büsch <mb@bu3sch.de> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: George Kashperko <george@znau.edu.ua> Cc: Arend van Spriel <arend@broadcom.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Botting <andy@andybotting.com> Cc: linuxdriverproject <devel@linuxdriverproject.org> Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
