path: root/drivers/bcma/driver_chipcommon_sflash.c
2014-01-03bcma: fix sparse warnings in driver_chipcommon_sflash.cHauke Mehrtens
CHECK drivers/bcma/driver_chipcommon_sflash.c drivers/bcma/driver_chipcommon_sflash.c:41:11: warning: Using plain integer as NULL pointer drivers/bcma/driver_chipcommon_sflash.c:59:11: warning: Using plain integer as NULL pointer drivers/bcma/driver_chipcommon_sflash.c:70:11: warning: Using plain integer as NULL pointer Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-17bcma: use const for serial flash hardware tableRafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-01bcma: Xflash: reorder includes to make pr_fmt workRafał Miłecki
2013-01-02bcma: correct M25P32 serial flash IDRafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-10-19bcma: add some more flash chips for serial flashHauke Mehrtens
2012-10-19bcma: add and use constants for the flash windowsHauke Mehrtens
2012-08-21bcma: detect and register serial flash deviceRafał Miłecki
2012-07-17bcma: add place for flash memory supportRafał Miłecki
