path: root/drivers/block/aoe
2011-01-19drivers/block/aoe/Makefile: replace the use of <module>-objs with <module>-yTracey Dent
Change Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and should now be switched. According to (documentation/kbuild/makefiles.txt). Signed-off-by: Tracey Dent <tdent48227@gmail.com> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-14Merge branch 'master' of ↵David S. Miller
2010-11-10block: remove REQ_HARDBARRIERChristoph Hellwig
REQ_HARDBARRIER is dead now, so remove the leftovers. What's left at this point is: - various checks inside the block layer. - sanity checks in bio based drivers. - now unused bio_empty_barrier helper. - Xen blockfront use of BLKIF_OP_WRITE_BARRIER - it's dead for a while, but Xen really needs to sort out it's barrier situaton. - setting of ordered tags in uas - dead code copied from old scsi drivers. - scsi different retry for barriers - it's dead and should have been removed when flushes were converted to FS requests. - blktrace handling of barriers - removed. Someone who knows blktrace better should add support for REQ_FLUSH and REQ_FUA, though. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-08aoe: remove dev_base_lock use from aoecmd_cfg_pkts()Eric Dumazet
dev_base_lock is the legacy way to lock the device list, and is planned to disappear. (writers hold RTNL, readers hold RCU lock) Convert aoecmd_cfg_pkts() to RCU locking. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-28drivers/block/aoe/aoeblk.c: ratelimit a warning printkAndrew Morton
As described in https://bugzilla.kernel.org/show_bug.cgi?id=19922 : I had an AoE device go down overnight, and while a server was trying to : write to it, it was also writing this message to its logs: : : 209 printk(KERN_INFO "aoe: device %ld.%d is not up\n", : 210 d->aoemajor, d->aoeminor); : : The message appeared many times per second, and over several hours : produced about 7.5 gigabytes of log files, filling up all free space on : the root filesystem. Cc: "Ed L. Cashin" <ecashin@coraid.com> Suggested-by: Roman Mamedov <roman@rm.pp.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-28aoe: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. Directly cancel aoedev->work on free instead of depending on flush_scheduled_works(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-08-07block: push down BKL into .open and .releaseArnd Bergmann
The open and release block_device_operations are currently called with the BKL held. In order to change that, we must first make sure that all drivers that currently rely on this have no regressions. This blindly pushes the BKL into all .open and .release operations for all block drivers to prepare for the next step. The drivers can subsequently replace the BKL with their own locks or remove it completely when it can be shown that it is not needed. The functions blkdev_get and blkdev_put are the only remaining users of the big kernel lock in the block layer, besides a few uses in the ioctl code, none of which need to serialize with blkdev_{get,put}. Most of these two functions is also under the protection of bdev->bd_mutex, including the actual calls to ->open and ->release, and the common code does not access any global data structures that need the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-22aoe: switch to the new bio_flush_dcache_pages() interfaceAndrew Morton
Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Horton <phorton@bitbox.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-01aoe: prevent cache aliasesPeter Horton
Prevent the AoE block driver from creating cache aliases of page cache pages on machines with virtually indexed caches. Building kernels on an AT91SAM9G20 board without this patch fails with segmentation faults after a couple of passes. Signed-off-by: Peter Horton <zero@colonel-panic.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-19Driver-Core: extend devnode callbacks to provide permissionsKay Sievers
This allows subsytems to provide devtmpfs with non-default permissions for the device node. Instead of the default mode of 0600, null, zero, random, urandom, full, tty, ptmx now have a mode of 0666, which allows non-privileged processes to access standard device nodes in case no other userspace process applies the expected permissions. This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-14Merge branch 'for-2.6.32' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.32' of git://git.kernel.dk/linux-2.6-block: (29 commits) block: use blkdev_issue_discard in blk_ioctl_discard Make DISCARD_BARRIER and DISCARD_NOBARRIER writes instead of reads block: don't assume device has a request list backing in nr_requests store block: Optimal I/O limit wrapper cfq: choose a new next_req when a request is dispatched Seperate read and write statistics of in_flight requests aoe: end barrier bios with EOPNOTSUPP block: trace bio queueing trial only when it occurs block: enable rq CPU completion affinity by default cfq: fix the log message after dispatched a request block: use printk_once cciss: memory leak in cciss_init_one() splice: update mtime and atime on files block: make blk_iopoll_prep_sched() follow normal 0/1 return convention cfq-iosched: get rid of must_alloc flag block: use interrupts disabled version of raise_softirq_irqoff() block: fix comment in blk-iopoll.c block: adjust default budget for blk-iopoll block: fix long lines in block/blk-iopoll.c block: add blk-iopoll, a NAPI like approach for block devices ...
2009-09-14aoe: end barrier bios with EOPNOTSUPPEd Cashin
BugLink: http://bugzilla.kernel.org/show_bug.cgi?id=13942 Bruno Premont noticed that aoe throws a BUG during umount of an XFS in 2.6.31: [ 5259.349897] aoe: bi_io_vec is NULL [ 5259.349940] ------------[ cut here ]------------ [ 5259.349958] kernel BUG at /usr/src/linux-2.6/drivers/block/aoe/aoeblk.c:177! [ 5259.349990] invalid opcode: 0000 [#1] The bio in question is a barrier. Jens Axboe suggested that such bios need to be recognized and ended with -EOPNOTSUPP by any driver that provides its own ->make_request_fn handler and does not handle barriers. In testing the changes below eliminate the BUG. (Better would be real barrier support, something that Ed says he'll add for later in the .32 cycle. For now, this at least gets rid of a bug with crashing on an empty barrier. Jens) Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-09aoe: allocate unused request_queue for sysfsEd Cashin
Andy Whitcroft reported an oops in aoe triggered by use of an incorrectly initialised request_queue object: [ 2645.959090] kobject '<NULL>' (ffff880059ca22c0): tried to add an uninitialized object, something is seriously wrong. [ 2645.959104] Pid: 6, comm: events/0 Not tainted 2.6.31-5-generic #24-Ubuntu [ 2645.959107] Call Trace: [ 2645.959139] [<ffffffff8126ca2f>] kobject_add+0x5f/0x70 [ 2645.959151] [<ffffffff8125b4ab>] blk_register_queue+0x8b/0xf0 [ 2645.959155] [<ffffffff8126043f>] add_disk+0x8f/0x160 [ 2645.959161] [<ffffffffa01673c4>] aoeblk_gdalloc+0x164/0x1c0 [aoe] The request queue of an aoe device is not used but can be allocated in code that does not sleep. Bruno bisected this regression down to cd43e26f071524647e660706b784ebcbefbd2e44 block: Expose stacked device queues in sysfs "This seems to generate /sys/block/$device/queue and its contents for everyone who is using queues, not just for those queues that have a non-NULL queue->request_fn." Addresses http://bugs.launchpad.net/bugs/410198 Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13942 Note that embedding a queue inside another object has always been an illegal construct, since the queues are reference counted and must persist until the last reference is dropped. So aoe was always buggy in this respect (Jens). Signed-off-by: Ed Cashin <ecashin@coraid.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Bruno Premont <bonbons@linux-vserver.org> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-15Driver Core: aoe: add nodename for aoe devicesKay Sievers
This adds support to the AOE core to report the proper device name to userspace for the AOE devices. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-27aoe: Remove superfluous clearing of skb fields in new_skb().David S. Miller
This code uses alloc_skb() which clears them out for us. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-01aoe: WIN_* -> ATA_CMD_*Bartlomiej Zolnierkiewicz
* Use ATA_CMD_* defines instead of WIN_* ones. * Include <linux/ata.h> directly instead of through <linux/hdreg.h>. Cc: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04aoe: error printed 1 too earlyRoel Kluin
with while (i-- > 0); i reaches -1 after the loop, so the test below is printed one too early: 0 still means success. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18aoe: ignore vendor extension AoE responsesEd Cashin
The Welland ME-747K-SI AoE target generates unsolicited AoE responses that are marked as vendor extensions. Instead of ignoring these packets, the aoe driver was generating kernel messages for each unrecognized response received. This patch corrects the behavior. Signed-off-by: Ed Cashin <ecashin@coraid.com> Reported-by: <karaluh@karaluh.pl> Tested-by: <karaluh@karaluh.pl> Cc: <stable@kernel.org> Cc: Alex Buell <alex.buell@munted.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-25aoe: remove private mac address format functionHarvey Harrison
Add %pm to omit the colons when printing a mac address. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-21[PATCH] switch aoeblkAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-20x86: sysfs: kill owner field from attributeParag Warudkar
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs attribute->owner unnecessary. But the field was left in the structure to ease the merge. It's been over a year since that change and it is now time to start killing attribute->owner along with its users - one arch at a time! This patch is attempt #1 to get rid of attribute->owner only for CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on as and when possible - avr32 will be the next since that is something I can test. Compile (make allyesconfig / make allmodconfig / custom config) and boot tested. akpm: the idea is that we put the declaration of sttribute.owner inside `#ifndef CONFIG_X86'. But that proved to be too ambitious for now because new usages kept on turning up in subsystem trees. [akpm: remove the ifdef for now] Signed-off-by: Parag Warudkar <parag.lkml@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <htejun@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16device create: block: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1075 commits) myri10ge: update driver version number to 1.4.3-1.369 r8169: add shutdown handler r8169: preliminary 8168d support r8169: support additional 8168cp chipset r8169: change default behavior for mildly identified 8168c chipsets r8169: add a new 8168cp flavor r8169: add a new 8168c flavor (bis) r8169: add a new 8168c flavor r8169: sync existing 8168 device hardware start sequences with vendor driver r8169: 8168b Tx performance tweak r8169: make room for more specific 8168 hardware start procedure r8169: shuffle some registers handling around (8168 operation only) r8169: new phy init parameters for the 8168b r8169: update phy init parameters r8169: wake up the PHY of the 8168 af_key: fix SADB_X_SPDDELETE response ath9k: Fix return code when ath9k_hw_setpower() fails on reset ath9k: remove nasty FAIL macro from ath9k_hw_reset() gre: minor cleanups in netlink interface gre: fix copy and paste error ...
2008-10-09block: move stats from disk to part0Tejun Heo
Move stats related fields - stamp, in_flight, dkstats - from disk to part0 and unify stat handling such that... * part_stat_*() now updates part0 together if the specified partition is not part0. ie. part_stat_*() are now essentially all_stat_*(). * {disk|all}_stat_*() are gone. * part_round_stats() is updated similary. It handles part0 stats automatically and disk_round_stats() is killed. * part_{inc|dec}_in_fligh() is implemented which automatically updates part0 stats for parts other than part0. * disk_map_sector_rcu() is updated to return part0 if no part matches. Combined with the above changes, this makes NULL special case handling in callers unnecessary. * Separate stats show code paths for disk are collapsed into part stats show code paths. * Rename disk_stat_lock/unlock() to part_stat_lock/unlock() While at it, reposition stat handling macros a bit and add missing parentheses around macro parameters. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: move capacity from disk to part0Tejun Heo
Move disk->capacity to part0->nr_sects and convert all users who directly accessed the field to use {get|set}_capacity(). This is done early to allow the __dev field to be moved. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: implement and use {disk|part}_to_dev()Tejun Heo
Implement {disk|part}_to_dev() and use them to access generic device instead of directly dereferencing {disk|part}->dev. To make sure no user is left behind, rename generic devices fields to __dev. This is in preparation of unifying partition 0 handling with other partitions. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: fix diskstats accessTejun Heo
There are two variants of stat functions - ones prefixed with double underbars which don't care about preemption and ones without which disable preemption before manipulating per-cpu counters. It's unclear whether the underbarred ones assume that preemtion is disabled on entry as some callers don't do that. This patch unifies diskstats access by implementing disk_stat_lock() and disk_stat_unlock() which take care of both RCU (for partition access) and preemption (for per-cpu counter access). diskstats access should always be enclosed between the two functions. As such, there's no need for the versions which disables preemption. They're removed and double underbars ones are renamed to drop the underbars. As an extra argument is added, there's no danger of using the old version unconverted. disk_stat_lock() uses get_cpu() and returns the cpu index and all diskstat functions which access per-cpu counters now has @cpu argument to help RT. This change adds RCU or preemption operations at some places but also collapses several preemption ops into one at others. Overall, the performance difference should be negligible as all involved ops are very lightweight per-cpu ones. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: fix disk->part[] dereferencing raceTejun Heo
disk->part[] is protected by its matching bdev's lock. However, non-critical accesses like collecting stats and printing out sysfs and proc information used to be performed without any locking. As partitions can come and go dynamically, partitions can go away underneath those non-critical accesses. As some of those accesses are writes, this theoretically can lead to silent corruption. This patch fixes the race by using RCU for the partition array and dev reference counter to hold partitions. * Rename disk->part[] to disk->__part[] to make sure no one outside genhd layer proper accesses it directly. * Use RCU for disk->__part[] dereferencing. * Implement disk_{get|put}_part() which can be used to get and put partitions from gendisk respectively. * Iterators are implemented to help iterate through all partitions safely. * Functions which require RCU readlock are marked with _rcu suffix. * Use disk_put_part() in __blkdev_put() instead of directly putting the contained kobject. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: misc updatesTejun Heo
This patch makes the following misc updates in preparation for disk->part dereference fix and extended block devt support. * implment part_to_disk() * fix comment about gendisk->part indexing * rename get_part() to disk_map_sector() * don't use n which is always zero while printing disk information in diskstats_show() Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-09-23aoe: Fix OOPS after SKB queue changes.David S. Miller
Reported by Thomas Graf. If we don't unlink the SKB from the queue when we send it out in aoenet_xmit(), dev_hard_start_xmit() will see skb->next as non-NULL and interpret this to mean the SKB is part of a GSO segment list. Add __skb_unlink() call to fix that. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-21aoe: Use SKB interfaces for list management instead of home-grown stuff.David S. Miller
2008-08-01Remove newline from the description of module parametersNiels de Vos
Some module parameters with only one line have the '\n' at the end of the description. This is not needed nor wanted as after the description the type (i.e. int) is followed by a newline. Some modules contain a multi-line description, these are not affected by this patch. Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Ed L. Cashin <ecashin@coraid.com> Cc: Dave Airlie <airlied@linux.ie> Cc: Roland Dreier <rolandd@cisco.com> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25aoe: convert emsgs_sema into a completionMatthias Kaehlcke
ATA over Ethernet: The semaphore emsgs_sema is used for signalling an event, convert it in a completion. Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21device create: block: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-04block: use get_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-20AoE: cdev lock_kernel() pushdownJonathan Corbet
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-07block: avoid duplicate calls to get_part() in disk stat codeJens Axboe
get_part() is fairly expensive, as it O(N) loops over partitions to find the right one. In lots of normal IO paths we end up looking up the partition twice, to make matters even worse. Change the stat add code to accept a passed in partition instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29drivers/block: use get_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Ed L. Cashin <ecashin@coraid.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29remove aoedev_isbusy()Adrian Bunk
Remove the no longer used aoedev_isbusy(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
