cciss needs to call disk_stat_add() for iostat to work.
Fix a crash when running hpacucli with multiple logical volumes on a cciss
controller. We were not properly initializing the disk->queue and causing
a fault.
Thanks to Hasso Tepper for reporting the problem. Thanks to Steve Cameron
for root causing the problem. Most of the patch just moves things around.
The fix is a one-liner.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Signed-off-by: Stephen Cameron <steve.cameron@hp.com>
free_hba() sets hba[i] to NULL, the dereference afterwards results in this
crash. Setting busy_initializing to 0 actually looks unnecessary, but I'm
not entirely sure, which is why I left it in.
cciss: controller appears to be disabled
Unable to handle kernel NULL pointer dereference at virtual address 00000370
printing eip:
c1114d53
*pde = 00000000
Oops: 0002 [#1]
Modules linked in:
CPU: 0
EIP: 0060:[<c1114d53>] Not tainted VLI
EFLAGS: 00010286 (2.6.16 #1)
EIP is at cciss_init_one+0x4e9/0x4fe
eax: 00000000 ebx: c132cd60 ecx: c13154e4 edx: c27d3c00
esi: 00000000 edi: c2748800 ebp: c2536ee4 esp: c2536eb8
ds: 007b es: 007b ss: 0068
Process swapper (pid: 1, threadinfo=c2536000 task=c2535a30)
Stack: <0>00000000 00000000 00000000 c13fdba0 c2536ee8 c13159c0 c2536f38
f7c74740
c132cd60 c132cd60 ffffffed c2536ef0 c10c1d51 c2748800 c2536f04
c10c1d85
c132cd60 c2748800 c132cd8c c2536f14 c10c1db8 c2748848 00000000
c2536f28
Call Trace:
[<c10031d5>] show_stack_log_lvl+0xa8/0xb0
[<c1003305>] show_registers+0x102/0x16a
[<c10034a2>] die+0xc1/0x13c
[<c1288160>] do_page_fault+0x38a/0x525
[<c1002e9b>] error_code+0x4f/0x54
[<c10c1d51>] pci_call_probe+0xd/0x10
[<c10c1d85>] __pci_device_probe+0x31/0x43
[<c10c1db8>] pci_device_probe+0x21/0x34
[<c110a654>] driver_probe_device+0x44/0x99
[<c110a73f>] __driver_attach+0x39/0x5d
[<c1109e1c>] bus_for_each_dev+0x35/0x5a
[<c110a777>] driver_attach+0x14/0x16
[<c110a220>] bus_add_driver+0x5c/0x8f
[<c110ab22>] driver_register+0x73/0x78
[<c10c1f6d>] __pci_register_driver+0x5f/0x71
[<c13bf935>] cciss_init+0x1a/0x1c
[<c13aa718>] do_initcalls+0x4c/0x96
[<c13aa77e>] do_basic_setup+0x1c/0x1e
[<c10002b1>] init+0x35/0x118
[<c1000cf5>] kernel_thread_helper+0x5/0xb
Code: 04 b5 e0 de 40 c1 8d 50 04 8b 40 34 e8 3f b7 f9 ff 8b 04 b5 e0 de
40 c1 e8 aa f3 ff ff 89 f0 e8 e8 fa ff ff 8b 04 b5 e0 de 40 c1 <c7> 80
70 03 00 00 00 00 00 00 83 c8 ff 8d 65 f4 5b 5e 5f 5d c3
<0>Kernel panic - not syncing: Attempted to kill init!
Cc: <mike.miller@hp.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
The softirq rq completion handler needs to save/restore interrupt flags
appropriately.
Signed-off-by: Jens Axboe <axboe@suse.de>
Replace obsolete pci_module_init() with pci_register_driver().
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
This sneaked in with one of the updates.
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a
duplicate of ARRAY_SIZE. Some trailing whitespaces are also removed.
drivers/block/acsi* has been left out as it's marked BROKEN.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Cc: Jens Axboe <axboe@suse.de>
This creates a new function, cciss_interrupt_mode called from
cciss_pci_init. This function determines what type of interrupt vector to
use, i.e., MSI, MSI-X, or IO-APIC.
One noticeable difference is changing the interrupt field of the controller
struct to an array of 4 unsigned ints. The Smart Array HW is capable of
generating 4 distinct interrupts depending on the transport method in use
during operation. These are:
#define DOORBELL_INT 0
Used to notify the contoller of configuration updates. We only use
this feature when in polling mode.
#define PERF_MODE_INT 0
Used when the controller is in Performant Mode.
#define SIMPLE_MODE_INT 2
Used when the controller is in Simple Mode (current Linux implementation).
#define MEMQ_INT_MODE 3
Not used.
When using IO-APIC interrupts these 4 lines are OR'ed together so when any
one fires an interrupt an is generated. In MSI or MSI-X mode this hardware
OR'ing is ignored. We must register for our interrupt depending on what
mode the controller is running. For Linux we use SIMPLE_MODE_INT
exclusively at this time. Please consider this for inclusion.
HDIO_GETGEO is implemented in most block drivers, and all of them have to
duplicate the code to copy the structure to userspace, as well as getting
the start sector. This patch moves that to common code [1] and adds a
->getgeo method to fill out the raw kernel hd_geometry structure. For many
drivers this means ->ioctl can go away now.
[1] the s390 block drivers are odd in this respect. xpram sets ->start
to 4 always which seems more than odd, and the dasd driver shifts
the start offset around, probably because of it's non-standard
sector size.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo Giarrusso <blaisorblade@yahoo.it>
Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Markus Lidel <Markus.Lidel@shadowconnect.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
add @uptodate argument to end_that_request_last() and @error
to rq_end_io_fn(). there's no generic way to pass error code
to request completion function, making generic error handling
of non-fs request difficult (rq->errors is driver-specific and
each driver uses it differently). this patch adds @uptodate
to end_that_request_last() and @error to rq_end_io_fn().
for fs requests, this doesn't really matter, so just using the
same uptodate argument used in the last call to
end_that_request_first() should suffice. imho, this can also
help the generic command-carrying request jens is working on.
Signed-off-by: tejun heo <htejun@gmail.com>
Signed-Off-By: Jens Axboe <axboe@suse.de>
This patch adds setting our drv->queue = NULL back in deregister_disk. The
drv->queue is part of our controller struct. blk_cleanup_queue works only
on the queue in the gendisk struct.
This undoes the put_disk patch I sent in before.
If I had been paying attention I would have seen that we call put_disk
from free_hba during driver unload. That's the only time we want to
call it. If it's called from deregister disk we may remove the
controller (cNd0) unintentionally.
Jeff Garzik pointed me to his code to see how to remove a disk from
the system _properly_. Well, here it is...
Every place we remove disks we are now testing before calling del_gendisk
or blk_cleanup_queue and then call put_disk.
Applications using CCISS_BIG_PASSTHRU complained that the data written
was zeros. The problem is that the buffer is being cleared after the
user copy, unless the user copy has failed... Correct that logic.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
This is the remaining misc drivers/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in misc files in
drivers/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org>
Acked-by: Roland Dreier <rolandd@cisco.com>
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
Acked-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Len Brown <len.brown@intel.com>
Acked-by: "Antonino A. Daplas" <adaplas@gmail.com>
This patch adds SCSI error handling code to the SCSI portion
of the cciss driver.
Signed-off-by: Stephen M. Cameron <steve.cameron@hp.com>
Acked-by: Mike Miller <mike.miller@hp.com>
This patch fixes the problem Bjorn reported. The busy_initializing flag
should have cleared before going into the for loop.
The CCISS driver seems to loose track of DMA mappings created by it's
fill_cmd() routine. Neither callers of this routine are extracting the DMA
address created in order to do the unmap.
Instead, they simply try to unmap 0x0. It's easy to see this problem on an
x86_64 system when using the "swiotlb=force" boot option. In this case, the
driver is leaking resources of the swiotlb and not causing a sync of the
bounce buffer.
Signed-off-by: Alex Williamson <alex.williamson@hp.com>
This patch fixes a bug in cciss_remove_one. A set of braces was missing for
the if statement causing an Oops on driver unload.
This patch changes the way we complete commands. In the old method when we
got a completion we searched our command list from the top until we find it.
This method uses a tag associated with each command (not SCSI command tagging)
to index us directly to the completed command. This helps performance.
Signed-off-by: Don Brace <dab@hp.com>
This patch removes a couple of functions dealing with configuration and
replaces them with new functions. This implementation fixes some bugs
associated with the ACUXE. It also allows a logical volume to be removed from
the middle without deleting all volumes behind it.
If a user has 5 logical volumes and decides he wants to reconfigure volume
number 3, he can now do that without removing volumes 4 & 5 first. This code
has been tested in our labs against all application software.
Signed-off-by: Chase Maupin <chase.maupin@hp.com>
This patch adds a flag called busy_initializing. If there are multiple
controllers in a server AND the HP agents are running it's possible the agents
may try to poll a card that is still initializing if the driver is removed and
then added again.
This patch adds new PCI and subsystem ID's that finally made the spec. It
also include a name change for one controller. I know there's a lot of
duplicat names but the fw folks wanted this for the different implementations.
Even though the same ASIC is used it may be embedded on some platforms,
standup card in others, and a mezzanine in other servers.
Use schedule_timeout_{un,}interruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
This patch adds per disk queue functionality to cciss. Sometime back I
submitted a patch but it looks like only part of what I needed. In the 2.6
kernel if we have more than one logical volume the driver will Oops during
rmmod. It seems all of the queues actually point back to the same queue.
So after deleting the first volume you hit a null pointer on the second
one.
This has been tested in our labs. There is no difference in performance,
it just fixes the Oops.
This patch fulfills a promise I made to Christoph sometime back. I am
removing the partition info from the CCISS_GETLUNINFO ioctl as I was informed
my "driver had no damn business reading that structure." ;)
The application folks are to use /proc or /sys for partition info from now on.
I am only aware of a few apps that use this ioctl and I'm not sure they ever
used the partition info.
Acked-by: Jeff Garzik <jgarzik@pobox.com>
This is pass 2 of my patch to add pci domain info to an existing ioctl. This
time I insert the domain between dev_fn and board_id as Willy suggested and
change the var to unsigned short to ease Christoph's concerns. Although I
thought unsigned int was the correct var type for this. I also thought it
didn't matter where I inserted it in the structure.
This patch fixes a PCI ID I got wrong before. It also adds support for
another new SAS controller due out this summer. I didn't have a marketing
name prior to my last submission. Also modifies the copyright date range.
Patch removes our homegrown DMA masks and uses the ones defined in the kernel.
This patch replaces the broken one I sent in earlier. It has been tested and works. Please discard the first submission.
infrastructure for it.
Let it rip!
