path: root/drivers/block/loop.c
2011-07-31loop: fix deadlock when sysfs and LOOP_CLR_FD race against each otherKay Sievers
LOOP_CLR_FD takes lo->lo_ctl_mutex and tries to remove the loop sysfs files. Sysfs calls show() and waits for lo->lo_ctl_mutex. LOOP_CLR_FD waits for show() to finish to remove the sysfs file. cat /sys/class/block/loop0/loop/backing_file mutex_lock_nested+0x176/0x350 ? loop_attr_do_show_backing_file+0x2f/0xd0 [loop] ? loop_attr_do_show_backing_file+0x2f/0xd0 [loop] loop_attr_do_show_backing_file+0x2f/0xd0 [loop] dev_attr_show+0x1b/0x60 ? sysfs_read_file+0x86/0x1a0 ? __get_free_pages+0x12/0x50 sysfs_read_file+0xaf/0x1a0 ioctl(LOOP_CLR_FD): wait_for_common+0x12c/0x180 ? try_to_wake_up+0x2a0/0x2a0 wait_for_completion+0x18/0x20 sysfs_deactivate+0x178/0x180 ? sysfs_addrm_finish+0x43/0x70 ? sysfs_addrm_start+0x1d/0x20 sysfs_addrm_finish+0x43/0x70 sysfs_hash_and_remove+0x85/0xa0 sysfs_remove_group+0x59/0x100 loop_clr_fd+0x1dc/0x3f0 [loop] lo_ioctl+0x223/0x7a0 [loop] Instead of taking the lo_ctl_mutex from sysfs code, take the inner lo->lo_lock, to protect the access to the backing_file data. Thanks to Tejun for help debugging and finding a solution. Cc: Milan Broz <mbroz@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-31loop: add BLK_DEV_LOOP_MIN_COUNT=%i to allow distros 0 pre-allocated loop ↵Kay Sievers
devices Instead of unconditionally creating a fixed number of dead loop devices which need to be investigated by storage handling services, even when they are never used, we allow distros start with 0 loop devices and have losetup(8) and similar switch to the dynamic /dev/loop-control interface instead of searching /dev/loop%i for free devices. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-31loop: add management interface for on-demand device allocationKay Sievers
Loop devices today have a fixed pre-allocated number of usually 8. The number can only be changed at module init time. To find a free device to use, /dev/loop%i needs to be scanned, and all devices need to be opened until a free one is possibly found. This adds a new /dev/loop-control device node, that allows to dynamically find or allocate a free device, and to add and remove loop devices from the running system: LOOP_CTL_ADD adds a specific device. Arg is the number of the device. It returns the device i or a negative error code. LOOP_CTL_REMOVE removes a specific device, Arg is the number the device. It returns the device i or a negative error code. LOOP_CTL_GET_FREE finds the next unbound device or allocates a new one. No arg is given. It returns the device i or a negative error code. The loop kernel module gets automatically loaded when /dev/loop-control is accessed the first time. The alias specified in the module, instructs udev to create this 'dead' device node, even when the module is not loaded. Example: cfd = open("/dev/loop-control", O_RDWR); # add a new specific loop device err = ioctl(cfd, LOOP_CTL_ADD, devnr); # remove a specific loop device err = ioctl(cfd, LOOP_CTL_REMOVE, devnr); # find or allocate a free loop device to use devnr = ioctl(cfd, LOOP_CTL_GET_FREE); sprintf(loopname, "/dev/loop%i", devnr); ffd = open("backing-file", O_RDWR); lfd = open(loopname, O_RDWR); err = ioctl(lfd, LOOP_SET_FD, ffd); Cc: Tejun Heo <tj@kernel.org> Cc: Karel Zak <kzak@redhat.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-31loop: replace linked list of allocated devices with an idr indexKay Sievers
Replace the linked list, that keeps track of allocated devices, with an idr index to allow a more efficient lookup of devices. Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-27loop: export module parametersNamhyung Kim
Export 'max_loop' and 'max_part' parameters to sysfs so user can know that how many devices are allowed and how many partitions are supported. If 'max_loop' is 0, there is no restriction on the number of loop devices. User can create/use the devices as many as minor numbers available. If 'max_part' is 0, it means simply the device doesn't support partitioning. Also note that 'max_part' can be adjusted to power of 2 minus 1 form if needed. User should check this value after the module loading if he/she want to use that number correctly (i.e. fdisk, mknod, etc.). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-24loop: handle on-demand devices correctlyNamhyung Kim
When finding or allocating a loop device, loop_probe() did not take partition numbers into account so that it can result to a different device. Consider following example: $ sudo modprobe loop max_part=15 $ ls -l /dev/loop* brw-rw---- 1 root disk 7, 0 2011-05-24 22:16 /dev/loop0 brw-rw---- 1 root disk 7, 16 2011-05-24 22:16 /dev/loop1 brw-rw---- 1 root disk 7, 32 2011-05-24 22:16 /dev/loop2 brw-rw---- 1 root disk 7, 48 2011-05-24 22:16 /dev/loop3 brw-rw---- 1 root disk 7, 64 2011-05-24 22:16 /dev/loop4 brw-rw---- 1 root disk 7, 80 2011-05-24 22:16 /dev/loop5 brw-rw---- 1 root disk 7, 96 2011-05-24 22:16 /dev/loop6 brw-rw---- 1 root disk 7, 112 2011-05-24 22:16 /dev/loop7 $ sudo mknod /dev/loop8 b 7 128 $ sudo losetup /dev/loop8 ~/temp/disk-with-3-parts.img $ sudo losetup -a /dev/loop128: [0805]:278201 (/home/namhyung/temp/disk-with-3-parts.img) $ ls -l /dev/loop* brw-rw---- 1 root disk 7, 0 2011-05-24 22:16 /dev/loop0 brw-rw---- 1 root disk 7, 16 2011-05-24 22:16 /dev/loop1 brw-rw---- 1 root disk 7, 2048 2011-05-24 22:18 /dev/loop128 brw-rw---- 1 root disk 7, 2049 2011-05-24 22:18 /dev/loop128p1 brw-rw---- 1 root disk 7, 2050 2011-05-24 22:18 /dev/loop128p2 brw-rw---- 1 root disk 7, 2051 2011-05-24 22:18 /dev/loop128p3 brw-rw---- 1 root disk 7, 32 2011-05-24 22:16 /dev/loop2 brw-rw---- 1 root disk 7, 48 2011-05-24 22:16 /dev/loop3 brw-rw---- 1 root disk 7, 64 2011-05-24 22:16 /dev/loop4 brw-rw---- 1 root disk 7, 80 2011-05-24 22:16 /dev/loop5 brw-rw---- 1 root disk 7, 96 2011-05-24 22:16 /dev/loop6 brw-rw---- 1 root disk 7, 112 2011-05-24 22:16 /dev/loop7 brw-r--r-- 1 root root 7, 128 2011-05-24 22:17 /dev/loop8 After this patch, /dev/loop8 - instead of /dev/loop128 - was accessed correctly. In addition, 'range' passed to blk_register_region() should include all range of dev_t that LOOP_MAJOR can address. It does not need to be limited by partition numbers unless 'max_loop' param was specified. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-24loop: limit 'max_part' module param to DISK_MAX_PARTSNamhyung Kim
The 'max_part' parameter controls the number of maximum partition a loop block device can have. However if a user specifies very large value it would exceed the limitation of device minor number and can cause a kernel panic (or, at least, produce invalid device nodes in some cases). On my desktop system, following command kills the kernel. On qemu, it triggers similar oops but the kernel was alive: $ sudo modprobe loop max_part0000 ------------[ cut here ]------------ kernel BUG at /media/Linux_Data/project/linux/fs/sysfs/group.c:65! invalid opcode: 0000 [#1] SMP last sysfs file: CPU 0 Modules linked in: loop(+) Pid: 43, comm: insmod Tainted: G W 2.6.39-qemu+ #155 Bochs Bochs RIP: 0010:[<ffffffff8113ce61>] [<ffffffff8113ce61>] internal_create_group= +0x2a/0x170 RSP: 0018:ffff880007b3fde8 EFLAGS: 00000246 RAX: 00000000ffffffef RBX: ffff880007b3d878 RCX: 00000000000007b4 RDX: ffffffff8152da50 RSI: 0000000000000000 RDI: ffff880007b3d878 RBP: ffff880007b3fe38 R08: ffff880007b3fde8 R09: 0000000000000000 R10: ffff88000783b4a8 R11: ffff880007b3d878 R12: ffffffff8152da50 R13: ffff880007b3d868 R14: 0000000000000000 R15: ffff880007b3d800 FS: 0000000002137880(0063) GS:ffff880007c00000(0000) knlGS:00000000000000= 00 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000422680 CR3: 0000000007b50000 CR4: 00000000000006b0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 0000000000000000 DR7: 0000000000000000 Process insmod (pid: 43, threadinfo ffff880007b3e000, task ffff880007afb9c= 0) Stack: ffff880007b3fe58 ffffffff811e66dd ffff880007b3fe58 ffffffff811e570b 0000000000000010 ffff880007b3d800 ffff880007a7b390 ffff880007b3d868 0000000000400920 ffff880007b3d800 ffff880007b3fe48 ffffffff8113cfc8 Call Trace: [<ffffffff811e66dd>] ? device_add+0x4bc/0x5af [<ffffffff811e570b>] ? dev_set_name+0x3c/0x3e [<ffffffff8113cfc8>] sysfs_create_group+0xe/0x12 [<ffffffff810b420e>] blk_trace_init_sysfs+0x14/0x16 [<ffffffff8116a090>] blk_register_queue+0x47/0xf7 [<ffffffff8116f527>] add_disk+0xdf/0x290 [<ffffffffa00060eb>] loop_init+0xeb/0x1b8 [loop] [<ffffffffa0006000>] ? 0xffffffffa0005fff [<ffffffff8100020a>] do_one_initcall+0x7a/0x12e [<ffffffff81096804>] sys_init_module+0x9c/0x1e0 [<ffffffff813329bb>] system_call_fastpath+0x16/0x1b Code: c3 55 48 89 e5 41 57 41 56 41 89 f6 41 55 41 54 49 89 d4 53 48 89 fb= 48 83 ec 28 48 85 ff 74 0b 85 f6 75 0b 48 83 7f 30 00 75 14 <0f> 0b eb fe = 48 83 7f 30 00 b9 ea ff ff ff 0f 84 18 01 00 00 49 RIP [<ffffffff8113ce61>] internal_create_group+0x2a/0x170 RSP <ffff880007b3fde8> ---[ end trace a123eb592043acad ]--- Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-04Merge branch 'for-linus' of ../linux-2.6-block into block-for-2.6.39/coreTejun Heo
This merge creates two set of conflicts. One is simple context conflicts caused by removal of throtl_scheduled_delayed_work() in for-linus and removal of throtl_shutdown_timer_wq() in for-2.6.39/core. The other is caused by commit 255bb490c8 (block: blk-flush shouldn't call directly into q->request_fn() __blk_run_queue()) in for-linus crashing with FLUSH reimplementation in for-2.6.39/core. The conflict isn't trivial but the resolution is straight-forward. * __blk_run_queue() calls in flush_end_io() and flush_data_end_io() should be called with @force_kblockd set to %true. * elv_insert() in blk_kick_flush() should use %ELEVATOR_INSERT_REQUEUE. Both changes are to avoid invoking ->request_fn() directly from request completion path and closely match the changes in the commit 255bb490c8. Signed-off-by: Tejun Heo <tj@kernel.org>
2011-03-03block: kill loop_mutexPetr Uzel
Following steps lead to deadlock in kernel: dd if=/dev/zero of=img bs=512 count=1000 losetup -f img mkfs.ext2 /dev/loop0 mount -t ext2 -o loop /dev/loop0 mnt umount mnt/ Stacktrace: [<c102ec04>] irq_exit+0x36/0x59 [<c101502c>] smp_apic_timer_interrupt+0x6b/0x75 [<c127f639>] apic_timer_interrupt+0x31/0x38 [<c101df88>] mutex_spin_on_owner+0x54/0x5b [<fe2250e9>] lo_release+0x12/0x67 [loop] [<c10c4eae>] __blkdev_put+0x7c/0x10c [<c10a4da5>] fput+0xd5/0x1aa [<fe2250cf>] loop_clr_fd+0x1a9/0x1b1 [loop] [<fe225110>] lo_release+0x39/0x67 [loop] [<c10c4eae>] __blkdev_put+0x7c/0x10c [<c10a59d9>] deactivate_locked_super+0x17/0x36 [<c10b6f37>] sys_umount+0x27e/0x2a5 [<c10b6f69>] sys_oldumount+0xb/0xe [<c1002897>] sysenter_do_call+0x12/0x26 [<ffffffff>] 0xffffffff Regression since 2a48fc0ab24241755dc9, which introduced the private loop_mutex as part of the BKL removal process. As per [1], the mutex can be safely removed. [1] http://www.gossamer-threads.com/lists/linux/kernel/1341930 Addresses: https://bugzilla.novell.com/show_bug.cgi?id=669394 Addresses: https://bugzilla.kernel.org/show_bug.cgi?id=29172 Signed-off-by: Petr Uzel <petr.uzel@suse.cz> Cc: stable@kernel.org Reviewed-by: Nikanth Karthikesan <knikanth@suse.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-02loop: No need to initialize ->queue_lock explicitly before calling ↵Vivek Goyal
blk_cleanup_queue() Now we initialize ->queue_lock at queue allocation time so driver does not have to worry about initializing it before calling blk_cleanup_queue(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-19loop: queue_lock NULL pointer derefence in blk_throtl_exitSergey Senozhatsky
Performing $ sudo mount -o loop -o umask=0 /dev/sdb1 /mnt/ mount: wrong fs type, bad option, bad superblock on /dev/loop0, missing codepage or helper program, or other error In some cases useful info is found in syslog - try dmesg | tail or so $ sudo modprobe -r loop results in oops: BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [<ffffffff812479d4>] do_raw_spin_lock+0x14/0x122 Process modprobe (pid: 6189, threadinfo ffff88009a898000, task ffff880154a88000) Call Trace: [<ffffffff81486788>] _raw_spin_lock_irq+0x4a/0x51 [<ffffffff8123404b>] ? blk_throtl_exit+0x3b/0xa0 [<ffffffff8105b120>] ? cancel_delayed_work_sync+0xd/0xf [<ffffffff8123404b>] blk_throtl_exit+0x3b/0xa0 [<ffffffff81229bc8>] blk_release_queue+0x21/0x65 [<ffffffff8123bb06>] kobject_release+0x51/0x66 [<ffffffff8123bab5>] ? kobject_release+0x0/0x66 [<ffffffff8123ce1e>] kref_put+0x43/0x4d [<ffffffff8123ba27>] kobject_put+0x47/0x4b [<ffffffff8122717c>] blk_cleanup_queue+0x56/0x5b [<ffffffffa01c3824>] loop_exit+0x68/0x844 [loop] [<ffffffff8107cccc>] sys_delete_module+0x1e8/0x25b [<ffffffff814864c9>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff81002112>] system_call_fastpath+0x16/0x1b because of an attempt to acquire NULL queue_lock. I added the same lines as in blk_queue_make_request - index 44e18c0..49e6a54 100644`fall back to embedded per-queue lock'. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-20Fix compile warnings due to missing removal of a 'ret' variableJens Axboe
Commit a8adbe3 forgot to remove the return variable, kill it. drivers/block/loop.c: In function 'lo_splice_actor': drivers/block/loop.c:398: warning: unused variable 'ret' [...] fs/nfsd/vfs.c: In function 'nfsd_splice_actor': fs/nfsd/vfs.c:848: warning: unused variable 'ret' Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-17fs/splice: Pull buf->ops->confirm() from splice_from_pipe actorsMichał Mirosław
This patch pulls calls to buf->ops->confirm() from all actors passed (also indirectly) to splice_from_pipe_feed(). Is avoiding the call to buf->ops->confirm() while splice()ing to /dev/null is an intentional optimization? No other user does that and this will remove this special case. Against current linux.git 6313e3c21743cc88bb5bd8aa72948ee1e83937b6. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: remove REQ_HARDBARRIERChristoph Hellwig
REQ_HARDBARRIER is dead now, so remove the leftovers. What's left at this point is: - various checks inside the block layer. - sanity checks in bio based drivers. - now unused bio_empty_barrier helper. - Xen blockfront use of BLKIF_OP_WRITE_BARRIER - it's dead for a while, but Xen really needs to sort out it's barrier situaton. - setting of ordered tags in uas - dead code copied from old scsi drivers. - scsi different retry for barriers - it's dead and should have been removed when flushes were converted to FS requests. - blktrace handling of barriers - removed. Someone who knows blktrace better should add support for REQ_FLUSH and REQ_FUA, though. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-27loop: Properly clear sysfs in autoclear modeMilan Broz
In autoclear mode bdev is NULL but the sysfs entry should be destroyed otherwise this warning appears: WARNING: at fs/sysfs/dir.c:451 sysfs_add_one+0x82/0x95() sysfs: cannot create duplicate filename '/devices/virtual/block/loop0/loop' Fixes commit ee86273062cbb310665fe49e1f1937d2cf85b0b9 Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-26mm: strictly nested kmap_atomic()Peter Zijlstra
Ensure kmap_atomic() usage is strictly nested Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-22Merge branch 'for-2.6.37/drivers' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/drivers' of git://git.kernel.dk/linux-2.6-block: (95 commits) cciss: fix PCI IDs for new Smart Array controllers drbd: add race-breaker to drbd_go_diskless drbd: use dynamic_dev_dbg to optionally log uuid changes dynamic_debug.h: Fix dynamic_dev_dbg() macro if CONFIG_DYNAMIC_DEBUG not set drbd: cleanup: change "<= 0" to "== 0" drbd: relax the grace period of the md_sync timer again drbd: add some more explicit drbd_md_sync drbd: drop wrong debug asserts, fix recently introduced race drbd: cleanup useless leftover warn/error printk's drbd: add explicit drbd_md_sync to drbd_resync_finished drbd: Do not log an ASSERT for P_OV_REQUEST packets while C_CONNECTED drbd: fix for possible deadlock on IO error during resync drbd: fix unlikely access after free and list corruption drbd: fix for spurious fullsync (uuids rotated too fast) drbd: allow for explicit resync-finished notifications drbd: preparation commit, using full state in receive_state() drbd: drbd_send_ack_dp must not rely on header information drbd: Fix regression in recv_bm_rle_bits (compressed bitmap) drbd: Fixed a stupid copy and paste error drbd: Allow larger values for c-fill-target. ... Fix up trivial conflict in drivers/block/ataflop.c due to BKL removal
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-09-10block/loop: implement REQ_FLUSH/FUA supportTejun Heo
Deprecate REQ_HARDBARRIER and implement REQ_FLUSH/FUA instead. Also, instead of checking file->f_op->fsync() directly, look at the value of vfs_fsync() and ignore -EINVAL return. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: deprecate barrier and replace blk_queue_ordered() with blk_queue_flush()Tejun Heo
Barrier is deemed too heavy and will soon be replaced by FLUSH/FUA requests. Deprecate barrier. All REQ_HARDBARRIERs are failed with -EOPNOTSUPP and blk_queue_ordered() is replaced with simpler blk_queue_flush(). blk_queue_flush() takes combinations of REQ_FLUSH and FUA. If a device has write cache and can flush it, it should set REQ_FLUSH. If the device can handle FUA writes, it should also set REQ_FUA. All blk_queue_ordered() users are converted. * ORDERED_DRAIN is mapped to 0 which is the default value. * ORDERED_DRAIN_FLUSH is mapped to REQ_FLUSH. * ORDERED_DRAIN_FLUSH_FUA is mapped to REQ_FLUSH | REQ_FUA. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block/loop: queue ordered mode should be DRAIN_FLUSHTejun Heo
loop implements FLUSH using fsync but was incorrectly setting its ordered mode to DRAIN. Change it to DRAIN_FLUSH. In practice, this doesn't change anything as loop doesn't make use of the block layer ordered implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-23loop: add some basic read-only sysfs attributesMilan Broz
Create /sys/block/loopX/loop directory and provide these attributes: - backing_file - autoclear - offset - sizelimit This loop directory is present only if loop device is configured. To be used in util-linux-ng (and possibly elsewhere like udev rules) where code need to get loop attributes from kernel (and not store duplicate info in userspace). Moreover loop ioctls are not even able to provide full backing file info because of buffer limits. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-23BLOCK: fix bio.bi_rw handlingJiri Slaby
Return of the bi_rw tests is no longer bool after commit 74450be1. But results of such tests are stored in bools. This doesn't fit in there for some compilers (gcc 4.5 here), so either use !! magic to get real bools or use ulong where the result is assigned somewhere. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .open and .releaseArnd Bergmann
The open and release block_device_operations are currently called with the BKL held. In order to change that, we must first make sure that all drivers that currently rely on this have no regressions. This blindly pushes the BKL into all .open and .release operations for all block drivers to prepare for the next step. The drivers can subsequently replace the BKL with their own locks or remove it completely when it can be shown that it is not needed. The functions blkdev_get and blkdev_put are the only remaining users of the big kernel lock in the block layer, besides a few uses in the ioctl code, none of which need to serialize with blkdev_{get,put}. Most of these two functions is also under the protection of bdev->bd_mutex, including the actual calls to ->open and ->release, and the common code does not access any global data structures that need the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove q->prepare_flush_fn completelyFUJITA Tomonori
This removes q->prepare_flush_fn completely (changes the blk_queue_ordered API). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-21sanitize vfs_fsync calling conventionsChristoph Hellwig
Now that the last user passing a NULL file pointer is gone we can remove the redundant dentry argument and associated hacks inside vfs_fsynmc_range. The next step will be removig the dentry argument from ->fsync, but given the luck with the last round of method prototype changes I'd rather defer this until after the main merge window. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21generate "change" uevent for loop deviceDavid Zeuthen
Recent udev versions probe loop devices for filesystems meaning that the /dev/disk hierarchy may contain useful entries such as $ ls -l /dev/disk/by-label/Fedora-12-x86_64-Live lrwxrwxrwx 1 root root 11 Mar 11 13:41 /dev/disk/by-label/Fedora-12-x86_64-Live -> ../../loop0 Unfortunately, no "change" uevent is generated when the loop device is detached so the symlink persists. Additionally, no "change" uevent is guaranteed to be generated when attaching an fd or changing capacity. For example, user space could open the loop device O_RDONLY (in fact, recent util-linux-ng does this) so udev's OPTIONS+="watch" machinery may not trigger the "change" uevent. This patch ensures that the "change" uevent is generated in all of these cases. As a result, the /dev/disk hierarchy works as expected for loop devices. Signed-off-by: David Zeuthen <davidz@redhat.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-09Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (34 commits) cfq-iosched: Fix the incorrect timeslice accounting with forced_dispatch loop: Update mtime when writing using aops block: expose the statistics in blkio.time and blkio.sectors for the root cgroup backing-dev: Handle class_create() failure Block: Fix block/elevator.c elevator_get() off-by-one error drbd: lc_element_by_index() never returns NULL cciss: unlock on error path cfq-iosched: Do not merge queues of BE and IDLE classes cfq-iosched: Add additional blktrace log messages in CFQ for easier debugging i2o: Remove the dangerous kobj_to_i2o_device macro block: remove 16 bytes of padding from struct request on 64bits cfq-iosched: fix a kbuild regression block: make CONFIG_BLK_CGROUP visible Remove GENHD_FL_DRIVERFS block: Export max number of segments and max segment size in sysfs block: Finalize conversion of block limits functions block: Fix overrun in lcm() and move it to lib vfs: improve writeback_inodes_wb() paride: fix off-by-one test drbd: fix al-to-on-disk-bitmap for 4k logical_block_size ...
2010-04-08loop: Update mtime when writing using aopsNikanth Karthikesan
Update mtime when writing to backing filesystem using the address space operations write_begin and write_end. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-10-29loop: fix NULL dereference if mount failsAlexey Dobriyan
Commit bb21488482bd36eae6b30b014d93619063773fd4 ("[PATCH] switch loop") started to pass NULL bdev to ioctl hook. Steps to reproduce: [boot with loop.max_part=1] [mount -o loop something so mount fails] BUG: unable to handle kernel NULL pointer dereference at 00000000000000b8 IP: [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 PGD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC last sysfs file: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:35/ACPI0003:00/power_supply/ACAD/online CPU 0 Modules linked in: zfs nvidia(P) [last unloaded: zfs] Pid: 15177, comm: mount Tainted: P 2.6.32-rc4-zfs #2 Satellite X200 RIP: 0010:[<ffffffff811486ee>] [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 RSP: 0018:ffff88003b3d5bb8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 000000000000125f RSI: 0000000000000000 RDI: 0000000000000000 RBP: ffff88003b3d5ce8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 00007ffffffff000 R13: 0000000000000000 R14: ffff880071cef280 R15: 00000000000200da FS: 00007fd77cfe7740(0000) GS:ffff880001600000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000000000b8 CR3: 0000000001001000 CR4: 00000000000026f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process mount (pid: 15177, threadinfo ffff88003b3d4000, task ffff88007572f920) Stack: ffff88003b3d5c38 ffffffff812f95f5 ffff88007eeb6600 0000000000000000 <0> 0000000000000000 ffff88003b3d5c18 ffffffff811547d9 ffff88001bf11ef0 <0> 7fffffffffffffff ffff88001bf11ee8 ffff88001bf11ef0 0000000000000000 Call Trace: [<ffffffff812f95f5>] ? schedule_timeout+0x1f5/0x250 [<ffffffff811547d9>] ? rb_insert_color+0x109/0x140 [<ffffffff812fb754>] ? _spin_unlock_irq+0x14/0x40 [<ffffffff812f84c6>] ? wait_for_common+0x66/0x170 [<ffffffff8105a280>] ? default_wake_function+0x0/0x10 [<ffffffff810f8258>] ioctl_by_bdev+0x38/0x50 [<ffffffff811d2481>] loop_clr_fd+0x1e1/0x210 [<ffffffff811d2522>] lo_release+0x72/0x80 [<ffffffff810f934c>] __blkdev_put+0x1ac/0x1d0 [<ffffffff810f937b>] blkdev_put+0xb/0x10 [<ffffffff810f93b9>] blkdev_close+0x39/0x60 [<ffffffff810ccef3>] __fput+0xd3/0x230 [<ffffffff810cd06d>] fput+0x1d/0x30 [<ffffffff810c9680>] filp_close+0x50/0x80 [<ffffffff81061f11>] put_files_struct+0x81/0x100 [<ffffffff81061fde>] exit_files+0x4e/0x60 [<ffffffff81063ec5>] do_exit+0x6b5/0x730 [<ffffffff8107b279>] ? up_read+0x9/0x10 [<ffffffff8104c86e>] ? do_page_fault+0x18e/0x2a0 [<ffffffff81063f81>] do_group_exit+0x41/0xc0 [<ffffffff81064012>] sys_exit_group+0x12/0x20 [<ffffffff81030deb>] system_call_fastpath+0x16/0x1b Code: f8 48 89 e5 48 81 ec 30 01 00 00 48 89 5d d8 4c 89 6d e8 4c 89 65 e0 4c 89 75 f0 4c 89 7d f8 48 89 bd e8 fe ff ff 49 89 cd 89 f3 <49> 8b 88 b8 00 00 00 81 fa 68 12 00 00 0f 84 57 05 00 00 0f 86 RIP [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 RSP <ffff88003b3d5bb8> CR2: 00000000000000b8 ---[ end trace c0b4d3c3118d1427 ]--- Fixing recursive fault but reboot is needed! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-11bio: first step in sanitizing the bio->bi_rw flag testingJens Axboe
Get rid of any functions that test for these bits and make callers use bio_rw_flagged() directly. Then it is at least directly apparent what variable and flag they check. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-11splice: implement default splice_read methodMiklos Szeredi
If f_op->splice_read() is not implemented, fall back to a plain read. Use vfs_readv() to read into previously allocated pages. This will allow splice and functions using splice, such as the loop device, to work on all filesystems. This includes "direct_io" files in fuse which bypass the page cache. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28loop: use BIO list management functionsAkinobu Mita
Now that the bio list management stuff is generic, convert loop to use bio lists instead of its own private bio list implementation. Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07loop: mutex already unlocked in loop_clr_fd()Alexander Beregalov
mount/1865 is trying to release lock (&lo->lo_ctl_mutex) at: but there are no more locks to release! mutex is already unlocked in loop_clr_fd(), we should not try to unlock it in lo_release() again. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-01loop: add ioctl to resize a loop deviceJ. R. Okajima
Add the ability to 'resize' the loop device on the fly. One practical application is a loop file with XFS filesystem, already mounted: You can easily enlarge the file (append some bytes) and then call ioctl(fd, LOOP_SET_CAPACITY, new); The loop driver will learn about the new size and you can use xfs_growfs later on, which will allow you to use full capacity of the loop file without the need to unmount. Test app: #include <linux/fs.h> #include <linux/loop.h> #include <sys/ioctl.h> #include <sys/stat.h> #include <sys/types.h> #include <assert.h> #include <errno.h> #include <fcntl.h> #include <stdio.h> #include <stdlib.h> #include <unistd.h> #define _GNU_SOURCE #include <getopt.h> char *me; void usage(FILE *f) { fprintf(f, "%s [options] loop_dev [backend_file]\n" "-s, --set new_size_in_bytes\n" "\twhen backend_file is given, " "it will be expanded too while keeping the original contents\n", me); } struct option opts[] = { { .name = "set", .has_arg = 1, .flag = NULL, .val = 's' }, { .name = "help", .has_arg = 0, .flag = NULL, .val = 'h' } }; void err_size(char *name, __u64 old) { fprintf(stderr, "size must be larger than current %s (%llu)\n", name, old); } int main(int argc, char *argv[]) { int fd, err, c, i, bfd; ssize_t ssz; size_t sz; __u64 old, new, append; char a[BUFSIZ]; struct stat st; FILE *out; char *backend, *dev; err = EINVAL; out = stderr; me = argv[0]; new = 0; while ((c = getopt_long(argc, argv, "s:h", opts, &i)) != -1) { switch (c) { case 's': errno = 0; new = strtoull(optarg, NULL, 0); if (errno) { err = errno; perror(argv[i]); goto out; } break; case 'h': err = 0; out = stdout; goto err; default: perror(argv[i]); goto err; } } if (optind < argc) dev = argv[optind++]; else goto err; fd = open(dev, O_RDONLY); if (fd < 0) { err = errno; perror(dev); goto out; } err = ioctl(fd, BLKGETSIZE64, &old); if (err) { err = errno; perror("ioctl BLKGETSIZE64"); goto out; } if (!new) { printf("%llu\n", old); goto out; } if (new < old) { err = EINVAL; err_size(dev, old); goto out; } if (optind < argc) { backend = argv[optind++]; bfd = open(backend, O_WRONLY|O_APPEND); if (bfd < 0) { err = errno; perror(backend); goto out; } err = fstat(bfd, &st); if (err) { err = errno; perror(backend); goto out; } if (new < st.st_size) { err = EINVAL; err_size(backend, st.st_size); goto out; } append = new - st.st_size; sz = sizeof(a); while (append > 0) { if (append < sz) sz = append; ssz = write(bfd, a, sz); if (ssz != sz) { err = errno; perror(backend); goto out; } append -= sz; } err = fsync(bfd); if (err) { err = errno; perror(backend); goto out; } } err = ioctl(fd, LOOP_SET_CAPACITY, new); if (err) { err = errno; perror("ioctl LOOP_SET_CAPACITY"); } goto out; err: usage(out); out: return err; } Signed-off-by: J. R. Okajima <hooanon05@yahoo.co.jp> Signed-off-by: Tomas Matejicek <tomas@slax.org> Cc: <util-linux-ng@vger.kernel.org> Cc: Karel Zak <kzak@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-api@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-26loop: fix circular locking in loop_clr_fd()Nikanth Karthikesan
With CONFIG_PROVE_LOCKING enabled $ losetup /dev/loop0 file $ losetup -o 32256 /dev/loop1 /dev/loop0 $ losetup -d /dev/loop1 $ losetup -d /dev/loop0 triggers a [ INFO: possible circular locking dependency detected ] I think this warning is a false positive. Open/close on a loop device acquires bd_mutex of the device before acquiring lo_ctl_mutex of the same device. For ioctl(LOOP_CLR_FD) after acquiring lo_ctl_mutex, fput on the backing_file might acquire the bd_mutex of a device, if backing file is a device and this is the last reference to the file being dropped . But it is guaranteed that it is impossible to have a circular list of backing devices.(say loop2->loop1->loop0->loop2 is not possible), which guarantees that this can never deadlock. So this warning should be suppressed. It is very difficult to annotate lockdep not to warn here in the correct way. A simple way to silence lockdep could be to mark the lo_ctl_mutex in ioctl to be a sub class, but this might mask some other real bugs. @@ -1164,7 +1164,7 @@ static int lo_ioctl(struct block_device *bdev, fmode_t mode, struct loop_device *lo = bdev->bd_disk->private_data; int err; - mutex_lock(&lo->lo_ctl_mutex); + mutex_lock_nested(&lo->lo_ctl_mutex, 1); switch (cmd) { case LOOP_SET_FD: err = loop_set_fd(lo, mode, bdev, arg); Or actually marking the bd_mutex after lo_ctl_mutex as a sub class could be a better solution. Luckily it is easy to avoid calling fput on backing file with lo_ctl_mutex held, so no lockdep annotation is required. If you do not like the special handling of the lo_ctl_mutex just for the LOOP_CLR_FD ioctl in lo_ioctl(), the mutex handling could be moved inside each of the individual ioctl handlers and I could send you another patch. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24loop: support barrier writesNikanth Karthikesan
Honour barrier requests in the loop back block device driver. In case of barrier bios, flush the backing file once before processing the barrier and once after to guarantee ordering. In case of filesystems that does not support fsync, barrier bios would be failed with -EOPNOTSUPP. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-05loop: don't increment p->offset with (size_t) -EINVALRoel Kluin
Upon a 'transfer error block' size is set to -EINVAL, but this becomes positive since size is unsigned: p->offset still gets incremented. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29loop: Do not call loop_unplug for not configured loop device.Milan Broz
In loop_unplug() function is expected that mapping is set and lo->lo_backing_file is not NULL. Unfortunately loop_set_fd() set the request queue unplug function, but loop_clr_fd() doesn't clear that. Loop device allows open of non-configured loop in some situations. If the unplug on request queue is called, loop module oopses because of missing lo_backing_file. Simple reproducer: losetup /dev/loop0 /xxx losetup -d /dev/loop0 dmsetup create x --table "0 1 linear /dev/loop0 0" EIP is at loop_unplug+0x1d/0x3b ... Call Trace: blk_unplug+0x57/0x5e dm_table_unplug_all+0x34/0x77 [dm_mod] destroy_inode+0x27/0x38 generic_delete_inode+0xd5/0xd9 iput+0x4b/0x4e dm_resume+0xca/0xfe [dm_mod] dev_suspend+0x143/0x165 [dm_mod] dm_ctl_ioctl+0x18e/0x1cf [dm_mod] dev_suspend+0x0/0x165 [dm_mod] dm_ctl_ioctl+0x0/0x1cf [dm_mod] vfs_ioctl+0x22/0x69 do_vfs_ioctl+0x39d/0x3c7 trace_hardirqs_on+0xb/0xd remove_vma+0x50/0x56 do_munmap+0x21c/0x237 sys_ioctl+0x2c/0x45 sysenter_do_call+0x12/0x31 Several reports here http://www.kerneloops.org/search.php?search=loop_unplug Fix it by simply clear unplug function together with removing of backing file. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29loop: Flush possible running bios when loop device is released.Milan Broz
When there are still queued bios and reference count drops to zero, loop device must flush all queued bios. Otherwise it can lead to situation that caller closes the device, but some bios are still running and endio() function call later OOpses when uses unallocated mempool. This happens for example when running dm-crypt over loop, here is typical oops backtrace: Oops: 0000 [#1] PREEMPT SMP EIP is at mempool_free+0x12/0x6b ... crypt_dec_pending+0x50/0x54 [dm_crypt] crypt_endio+0x9f/0xa7 [dm_crypt] crypt_endio+0x0/0xa7 [dm_crypt] bio_endio+0x2b/0x2e loop_thread+0x37a/0x3b1 do_lo_send_aops+0x0/0x165 autoremove_wake_function+0x0/0x33 loop_thread+0x0/0x3b1 kthread+0x3b/0x61 kthread+0x0/0x61 kernel_thread_helper+0x7/0x10 (But crash is reproducible with different dm targets running over loop device too.) Patch fixes it by flushing the bios in release call, reusing the flush mechanism for switching backing store. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-14CRED: Wrap task credential accesses in the block loopback driverDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-30fs: remove prepare_write/commit_writeNick Piggin
Nothing uses prepare_write or commit_write. Remove them from the tree completely. [akpm@linux-foundation.org: schedule simple_prepare_write() for unexporting] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-21[PATCH] kill the unused bsize on the send side of /dev/loopAl Viro
