path: root/drivers/block/mg_disk.c
2010-08-23block: switch s390 tape_block and mg_disk to elevator_change()Jens Axboe
Now that we have this API, switch the two in-kernel users to it. Resolves an oops introduced by commit 1abec4fdbb142e3ccb6ce99832fae42129134a96. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-22drivers/block/mg_disk.c: use resource_size()H Hartley Sweeten
Use resource_size() for ioremap. The ioremap appears to be passing the incorrect size for the platform resource. Unfortunately, I can't locate a user in mainline to verify this. Using resource_size should be the correct fix. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: unsik Kim <donari75@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-28mg_disk: Add missing ready status check on mg_write()unsik Kim
When last sector is written, ready bit of status register should be checked. Signed-off-by: unsik Kim <donari75@gmail.com> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-28mg_disk: fix issue with data integrity on error in mg_write()Bartlomiej Zolnierkiewicz
We cannot acknowledge the sector write before checking its status (which is done on the next loop iteration) and we also need to do the final status register check after writing the last sector. Fix mg_write() to match mg_write_intr() in this regard. While at it: - add mg_read_one() and mg_write_one() helpers - always use MG_SECTOR_SIZE and remove MG_STORAGE_BUFFER_SIZE [bart: thanks to Tejun for porting the patch over recent block changes] Cc: unsik Kim <donari75@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> =================================================================== Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-28mg_disk: fix reading invalid status when use polling driverunsik Kim
When using polling driver, little delay is required to access status register. Without this, host might read invalid status. Signed-off-by: unsik Kim <donari75@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-28mg_disk: remove prohibited sleep operationunsik Kim
mflash's polling driver operate in standard request_fn_proc's context, sleep in this isn't permitted. Signed-off-by: unsik Kim <donari75@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-16mg_disk: seperate mg_disk.h againunsik Kim
eec9462088a26c046d4db3100796a340a50890b8 fold mg_disk.h into mg_disk.c, but mg_disk platform driver needs private data for operation. This also make mg_disk.c as machine independent. Seperate only needed structure and defines to mg_disk.h Signed-off-by: unsik Kim <donari75@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11mg_disk: dequeue and track in-flight requestTejun Heo
mg_disk has at most single request in flight per device. Till now, whenever it needs to access the in-flight request it called elv_next_request(). This patch makes mg_disk track the in-flight request directly using mg_host->req and dequeue it when processing starts. q->queuedata is set to mg_host so that mg_host can be determined without fetching request from the queue. [ Impact: dequeue in-flight request, one elv_next_request() per request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: unsik Kim <donari75@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11mg_disk: fix queue hang / infinite retry on !fs requestsTejun Heo
Both request functions in mg_disk simply return when they encounter a !fs request, which means the request will never be cleared from the queue causing queue hang and indefinite retry of the request. Fix it. While at it, flatten condition checks and add unlikely to !fs tests. [ Impact: fix possible queue hang / infinite retry of !fs requests ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: unsik Kim <donari75@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28mg_disk: use defines from <linux/ata.h>Bartlomiej Zolnierkiewicz
While at it: - remove MG_REG_HEAD_MUST_BE_ON define - remove MG_REG_CTRL_INTR_ENABLE define - remove MG_REG_HEAD_LBA_MODE define - remove unused defines Cc: unsik Kim <donari75@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28mg_disk: fix dependency on libataBartlomiej Zolnierkiewicz
Add local copies of ata_id_string() and ata_id_c_string() to mg_disk so there is no need for the driver to depend on ATA and SCSI. [ Impact: break dependency on libata by copying ata id string functions ] Cc: unsik Kim <donari75@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28mg_disk: clean up request completion pathsTejun Heo
mg_disk implements its own partial completion. Convert to standard block layer partial completion. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: unsik Kim <donari75@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28mg_disk: fold mg_disk.h into mg_disk.cTejun Heo
include/linux/mg_disk.h is used only by drivers/block/mg_disk.c. No reason to put it in a separate header. Fold it into mg_disk.c. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: unsik Kim <donari75@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28amiflop,ataflop,xd,mg_disk: clean up unnecessary stuff from block driversTejun Heo
rq_data_dir() can only be READ or WRITE and rq->sector and nr_sectors are always automatically updated after partial request completion. Don't worry about rq_data_dir() not being either READ or WRITE or manually update sector and nr_sectors. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jörg Dorchain <joerg@dorchain.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: unsik Kim <donari75@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: replace end_request() with [__]blk_end_request_cur()Tejun Heo
end_request() has been kept around for backward compatibility; however, it's about time for it to go away. * There aren't too many users left. * Its use of @updtodate is pretty confusing. * In some cases, newer code ends up using mixture of end_request() and [__]blk_end_request[_all](), which is way too confusing. So, add [__]blk_end_request_cur() and replace end_request() with it. Most conversions are straightforward. Noteworthy ones are... * paride/pcd: next_request() updated to take 0/-errno instead of 1/0. * paride/pf: pf_end_request() and next_request() updated to take 0/-errno instead of 1/0. * xd: xd_readwrite() updated to return 0/-errno instead of 1/0. * mtd/mtd_blkdevs: blktrans_discard_request() updated to return 0/-errno instead of 1/0. Unnecessary local variable res initialization removed from mtd_blktrans_thread(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Joerg Dorchain <joerg@dorchain.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Laurent Vivier <Laurent@lvivier.info> Cc: Tim Waugh <tim@cyberelk.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: unsik Kim <donari75@gmail.com>
2009-04-28mg_disk: fix CONFIG_LBD=y warningBartlomiej Zolnierkiewicz
drivers/block/mg_disk.c: In function ‘mg_dump_status’: drivers/block/mg_disk.c:265: warning: format ‘%ld’ expects type ‘long int’, but argument 2 has type ‘sector_t’ [ Impact: kill build warning ] Cc: unsik Kim <donari75@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-28mg_disk: fix lockingTejun Heo
IRQ and timeout handlers call functions which expect locked queue lock without locking it. Fix it. While at it, convert 0s used as null pointer constant to NULLs. [ Impact: fix locking, cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: unsik Kim <donari75@gmail.com>
2009-04-07mflash: initial supportunsik Kim
This driver supports mflash IO mode for linux. Mflash is embedded flash drive and mainly targeted mobile and consumer electronic devices. Internally, mflash has nand flash and other hardware logics and supports 2 different operation (ATA, IO) modes. ATA mode doesn't need any new driver and currently works well under standard IDE subsystem. Actually it's one chip SSD. IO mode is ATA-like custom mode for the host that doesn't have IDE interface. Followings are brief descriptions about IO mode. A. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) B. IO mode uses SRAM bus interface. C. IO mode supports 4kB boot area, so host can boot from mflash. This driver is quitely similar to a standard ATA driver, but because of following reasons it is currently seperated with ATA layer. 1. ATA layer deals standard ATA protocol. ATA layer have many low- level device specific interface, but data transfer keeps ATA rule. But, mflash IO mode doesn't. 2. Even though currently not used in mflash driver code, mflash has some custom command and modes. (nand fusing, firmware patch, etc) If this feature supported in linux kernel, ATA layer more altered. 3. Currently PATA platform device driver doesn't support interrupt. (I'm not sure) But, mflash uses interrupt (polling mode is just for debug). 4. mflash is somewhat under-develop product. Even though some company already using mflash their own product, I think more time is needed for standardization of custom command and mode. That time (maybe October) I will talk to with ATA people. If they accept integration, I will integrate. Signed-off-by: unsik Kim <donari75@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
