This improves performance since more requests can be merged.
Reviewed-by: Yehuda Sadeh <yehuda@hq.newdream.net>
Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
We were missing this cleanup, so when a device was released
the osd didn't clean up its watchers list, so following notifications
could be slow as osd needed to timeout on the client.
Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
If we get a notification that the image header has changed, check for
a change in the image size.
Signed-off-by: Sage Weil <sage@newdream.net>
The rbd driver currently splits bios when they span an object boundary.
However, the blk_end_request expects the completions to roll up the results
in block device order, and the split rbd/ceph ops can complete in any
order. This patch adds a struct rbd_req_coll to track completion of split
requests and ensures that the results are passed back up to the block layer
in order.
This fixes errors where the file system gets completion of a read operation
that spans an object boundary before the data has actually arrived. The
bug is easily reproduced with iozone with a working set larger than
available RAM.
Reported-by: Fyodor Ustinov <ufm@ufm.su>
The ops vector must be freed by the rbd_do_request caller.
ceph_osdc_alloc_request returns NULL on failure.
Send notifications when we change the rbd header (e.g. create a snapshot)
and wait for such notifications. This allows synchronizing the snapshot
creation between different rbd clients/rools.
Previously we didn't clean up the sysfs entry that was just
created.
The new interface creates directories per mapped image
and under each it creates a subdir per available snapshot.
This allows keeping a cleaner interface within the sysfs
guidelines. The ABI documentation was updated too.
We should be passing "buf" here insead of "bv". This is tricky because
it's not the same as kmap() and kunmap(). GCC does warn about it if you
compile on i386 with CONFIG_HIGHMEM.
ceph_alloc_page_vector() returns ERR_PTR(-ENOMEM) on errors.
rbd_get_segment() can't return a negative value, we don't need to check
the return output.
rbd_client_create() doesn't free rbdc, this leads to many leaks.
seg_len in rbd_do_op() is unsigned, so (seg_len < 0) makes no sense.
Also if fixed check fails then seg_name is leaked.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
The rados block device (rbd), based on osdblk, creates a block device
that is backed by objects stored in the Ceph distributed object storage
cluster. Each device consists of a single metadata object and data
striped over many data objects.
The rbd driver supports read-only snapshots.
