path: root/drivers/block/virtio_blk.c
2012-04-16Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio fixes from Michael S. Tsirkin: "Here are some virtio fixes for 3.4: a test build fix, a patch by Ren fixing naming for systems with a massive number of virtio blk devices, and balloon fixes for powerpc by David Gibson. There was some discussion about Ren's patch for virtio disc naming: some people wanted to move the legacy name mangling function to the block core. But there's no concensus on that yet, and we can always deduplicate later. Added comments in the hope that this will stop people from copying this legacy naming scheme into future drivers." * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: virtio_balloon: fix handling of PAGE_SIZE != 4k virtio_balloon: Fix endian bug virtio_blk: helper function to format disk names tools/virtio: fix up vhost/test module build
2012-04-12virtio_blk: helper function to format disk namesRen Mingxin
The current virtio block's naming algorithm just supports 18278 (26^3 + 26^2 + 26) disks. If there are more virtio blocks, there will be disks with the same name. Based on commit 3e1a7ff8a0a7b948f2684930166954f9e8e776fe, add a function "virtblk_name_format()" for virtio block to support mass of disks naming. Notes: - Our naming scheme is ugly. We are stuck with it for virtio but don't use it for any new driver: new drivers should name their devices PREFIX%d where the sequence number can be allocated by ida - sd_format_disk_name has exactly the same logic. Moving it to a central place was deferred over worries that this will make people keep using the legacy naming in new drivers. We kept code idential in case someone wants to deduplicate later. Signed-off-by: Ren Mingxin <renmx@cn.fujitsu.com> Acked-by: Asias He <asias@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2012-03-29virtio-blk: Call revalidate_disk() upon online disk resizeVivek Goyal
If a virtio disk is open in guest and a disk resize operation is done, (virsh blockresize), new size is not visible to tools like "fdisk -l". This seems to be happening as we update only part->nr_sects and not bdev->bd_inode size. Call revalidate_disk() which should take care of it. I tested growing disk size of already open disk and it works for me. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-14block: add and use scsi_blk_cmd_ioctlPaolo Bonzini
Introduce a wrapper around scsi_cmd_ioctl that takes a block device. The function will then be enhanced to detect partition block devices and, in that case, subject the ioctls to whitelisting. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12virtio: blk: Add freeze, restore handlers to support S4Amit Shah
Delete the vq and flush any pending requests from the block queue on the freeze callback to prepare for hibernation. Re-create the vq in the restore callback to resume normal function. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-12virtio: blk: Move vq initialization to separate functionAmit Shah
The probe and PM restore functions will share this code. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-12virtio_blk: fix config handler raceMichael S. Tsirkin
Fix a theoretical race related to config work handler: a config interrupt might happen after we flush config work but before we reset the device. It will then cause the config work to run during or after reset. Two problems with this: - if this runs after device is gone we will get use after free - access of config while reset is in progress is racy (as layout is changing). As a solution 1. flush after reset when we know there will be no more interrupts 2. add a flag to disable config access before reset Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-12virtio: rename virtqueue_add_buf_gfp to virtqueue_add_bufRusty Russell
Remove wrapper functions. This makes the allocation type explicit in all callers; I used GPF_KERNEL where it seemed obvious, left it at GFP_ATOMIC otherwise. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-02virtio-blk: use ida to allocate disk indexMichael S. Tsirkin
Based on a patch by Mark Wu <dwu@redhat.com> Current index allocation in virtio-blk is based on a monotonically increasing variable "index". This means we'll run out of numbers after a while. It also could cause confusion about the disk name in the case of hot-plugging disks. Change virtio-blk to use ida to allocate index, instead. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-10-31block: Fix files that are modules and hence need module.hPaul Gortmaker
We want to remove the implicit everywhere presence of module.h so fix up the people relying on that implicit presence in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-30drivers, block: virtio_blk: Replace cryptic number with the macroLiu Yuan
It is easier to figure out the context by reading SCSI_SENSE_BUFFERSIZE instead of plain '96'. Signed-off-by: Liu Yuan <tailai.ly@taobao.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-30virtio_blk: allow re-reading config space at runtimeChristoph Hellwig
Wire up the virtio_driver config_changed method to get notified about config changes raised by the host. For now we just re-read the device size to support online resizing of devices, but once we add more attributes that might be changeable they could be added as well. Note that the config_changed method is called from irq context, so we'll have to use the workqueue infrastructure to provide us a proper user context for our changes. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-21virtio_blk: remove BKL leftoversChristoph Hellwig
Remove the BKL usage added in "block: push down BKL into .locked_ioctl". Virtio-blk doesn't use the BKL for anything, and doesn't implement any ioctl command by itself, but only uses the generic scsi_cmd_ioctl which is fine without the BKL. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-10-19Merge branch 'v2.6.36-rc8' into for-2.6.37/barrierJens Axboe
Conflicts: block/blk-core.c drivers/block/loop.c mm/swapfile.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-09virtio-blk: fix request leak.Mike Snitzer
Must drop reference taken by blk_make_request(). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org # .35.x Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-10virtio_blk: drop REQ_HARDBARRIER supportTejun Heo
Remove now unused REQ_HARDBARRIER support. virtio_blk already supports REQ_FLUSH and the usefulness of REQ_FUA for virtio_blk is questionable at this point, so there's nothing else to do to support new REQ_FLUSH/FUA interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: deprecate barrier and replace blk_queue_ordered() with blk_queue_flush()Tejun Heo
Barrier is deemed too heavy and will soon be replaced by FLUSH/FUA requests. Deprecate barrier. All REQ_HARDBARRIERs are failed with -EOPNOTSUPP and blk_queue_ordered() is replaced with simpler blk_queue_flush(). blk_queue_flush() takes combinations of REQ_FLUSH and FUA. If a device has write cache and can flush it, it should set REQ_FLUSH. If the device can handle FUA writes, it should also set REQ_FUA. All blk_queue_ordered() users are converted. * ORDERED_DRAIN is mapped to 0 which is the default value. * ORDERED_DRAIN_FLUSH is mapped to REQ_FLUSH. * ORDERED_DRAIN_FLUSH_FUA is mapped to REQ_FLUSH | REQ_FUA. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: kill QUEUE_ORDERED_BY_TAGTejun Heo
Nobody is making meaningful use of ORDERED_BY_TAG now and queue draining for barrier requests will be removed soon which will render the advantage of tag ordering moot. Kill ORDERED_BY_TAG. The following users are affected. * brd: converted to ORDERED_DRAIN. * virtio_blk: ORDERED_TAG path was already marked deprecated. Removed. * xen-blkfront: ORDERED_TAG case dropped. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-07block: push down BKL into .locked_ioctlArnd Bergmann
As a preparation for the removal of the big kernel lock in the block layer, this removes the BKL from the common ioctl handling code, moving it into every single driver still using it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove q->prepare_flush_fn completelyFUJITA Tomonori
This removes q->prepare_flush_fn completely (changes the blk_queue_ordered API). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07virtio_blk: stop using q->prepare_flush_fnFUJITA Tomonori
use REQ_FLUSH flag instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07virtio_blk: add default case to cmd type switchJens Axboe
On compilation, gcc correctly detects that we do not handle all types: In function ‘blk_done’: warning: enumeration value ‘REQ_TYPE_FS’ not handled in switch warning: enumeration value ‘REQ_TYPE_SENSE’ not handled in switch warning: enumeration value ‘REQ_TYPE_PM_SUSPEND’ not handled in switch warning: enumeration value ‘REQ_TYPE_PM_RESUME’ not handled in switch warning: enumeration value ‘REQ_TYPE_PM_SHUTDOWN’ not handled in switch warning: enumeration value ‘REQ_TYPE_LINUX_BLOCK’ not handled in switch warning: enumeration value ‘REQ_TYPE_ATA_TASKFILE’ not handled in switch warning: enumeration value ‘REQ_TYPE_ATA_PC’ not handled in switch which is a bit pointless since this is at the end of the request processessing. Add a default case that just breaks out. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-05virtio_blk: Remove VBID ioctlRyan Harper
With the availablility of a sysfs device attribute for examining disk serial numbers the ioctl is no longer needed. The user-space changes for this aren't upstream yet so we don't have any users to worry about. Signed-off-by: Ryan Harper <ryanh@us.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05virtio_blk: Add 'serial' attribute to virtio-blk devices (v2)Ryan Harper
Create a new attribute for virtio-blk devices that will fetch the serial number of the block device. This attribute can be used by udev to create disk/by-id symlinks for devices that don't have a UUID (filesystem) associated with them. ATA_IDENTIFY strings are special in that they can be up to 20 chars long and aren't required to be nul-terminated. The buffer is also zero-padded meaning that if the serial is 19 chars or less that we get a nul-terminated string. When copying this value into a string buffer, we must be careful to copy up to the nul (if it present) and only 20 if it is longer and not to attempt to nul terminate; this isn't needed. Changes since v1: - Added BUILD_BUG_ON() for PAGE_SIZE check - Removed min() since BUILD_BUG_ON() handles the check - Replaced serial_sysfs() by copying id directly to buffer Signed-off-by: Ryan Harper <ryanh@us.ibm.com> Signed-off-by: john cooper <john.cooper@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-05virtio_blk: support barriers without FLUSH featureChristoph Hellwig
If we want to support barriers with the cache=writethrough mode in qemu we need to tell the block layer that we only need queue drains to implement a barrier. Follow the model set by SCSI and IDE and assume that there is no volatile write cache if the host doesn't advertize it. While this might imply working barriers on old qemu versions or other hypervisors that actually have a volatile write cache this is only a cosmetic issue - these hypervisors don't guarantee any data integrity with or without this patch, but with the patch we at least provide data ordering. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-06-03virtio-blk: fix minimum number of S/G elementsChristoph Hellwig
We need at least one S/G element to operate properly, as does the block layer which increments it to one anyway. We hit this due to a qemu bug which advertises a sg_elements of 0 under some circumstances. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (tweaked logic)
2010-05-19virtio_blk: use virtqueue_xxx wrappersMichael S. Tsirkin
Switch virtio_blk to new virtqueue_xxx wrappers. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio_blk: remove multichar constant.Rusty Russell
drivers/block/virtio_blk.c:228:13: warning: multi-character character constant Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: john cooper <john.cooper@redhat.com>
2010-05-19Add virtio disk identification ioctljohn cooper
Return serial string to the guest application via ioctl driver call. Note this form of interface to the guest userland was the consensus when the prior version using the ATA_IDENTIFY came under dispute. Signed-off-by: john cooper <john.cooper@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19Add virtio disk identification supportjohn cooper
Add virtio-blk device id (s/n) support via virtio request. Signed-off-by: john cooper <john.cooper@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-04-09Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (34 commits) cfq-iosched: Fix the incorrect timeslice accounting with forced_dispatch loop: Update mtime when writing using aops block: expose the statistics in blkio.time and blkio.sectors for the root cgroup backing-dev: Handle class_create() failure Block: Fix block/elevator.c elevator_get() off-by-one error drbd: lc_element_by_index() never returns NULL cciss: unlock on error path cfq-iosched: Do not merge queues of BE and IDLE classes cfq-iosched: Add additional blktrace log messages in CFQ for easier debugging i2o: Remove the dangerous kobj_to_i2o_device macro block: remove 16 bytes of padding from struct request on 64bits cfq-iosched: fix a kbuild regression block: make CONFIG_BLK_CGROUP visible Remove GENHD_FL_DRIVERFS block: Export max number of segments and max segment size in sysfs block: Finalize conversion of block limits functions block: Fix overrun in lcm() and move it to lib vfs: improve writeback_inodes_wb() paride: fix off-by-one test drbd: fix al-to-on-disk-bitmap for 4k logical_block_size ...
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15block: Finalize conversion of block limits functionsMartin K. Petersen
Remove compatibility wrappers and update remaining drivers. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-01Merge branch 'for-2.6.34' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits) block: don't access jiffies when initialising io_context cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds block: fix for "Consolidate phys_segment and hw_segment limits" cfq-iosched: quantum check tweak blktrace: perform cleanup after setup error blkdev: fix merge_bvec_fn return value checks cfq-iosched: requests "in flight" vs "in driver" clarification cciss: Fix problem with scatter gather elements in the scsi half of the driver cciss: eliminate unnecessary pointer use in cciss scsi code cciss: do not use void pointer for scsi hba data cciss: factor out scatter gather chain block mapping code cciss: fix scatter gather chain block dma direction kludge cciss: simplify scatter gather code cciss: factor out scatter gather chain block allocation and freeing cciss: detect bad alignment of scsi commands at build time cciss: clarify command list padding calculation cfq-iosched: rethink seeky detection for SSDs cfq-iosched: rework seeky detection block: remove padding from io_context on 64bit builds block: Consolidate phys_segment and hw_segment limits ...
2010-02-24virtio_blk: add block topology supportChristoph Hellwig
Allow reading various alignment values from the config page. This allows the guest to much better align I/O requests depending on the storage topology. Note that the formats for the config values appear a bit messed up, but we follow the formats used by ATA and SCSI so they are expected in the storage world. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-01-11block: make virtio device id constantMárton Németh
The id_table field of the struct virtio_driver is constant in <linux/virtio.h> so it is worth to make id_table also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-22virtio_blk: Revert serial number supportRusty Russell
This reverts "Add serial number support for virtio_blk, V4a". Turns out that virtio_pci, lguest and s/390 all have an 8 bit limit on virtio config space, so noone could ever use this. This is coming back later in a cleaner form. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: john cooper <john.cooper@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com>
2009-10-22virtio: let header files include virtio_ids.hChristian Borntraeger
Rusty, commit 3ca4f5ca73057a617f9444a91022d7127041970a virtio: add virtio IDs file moved all device IDs into a single file. While the change itself is a very good one, it can break userspace applications. For example if a userspace tool wanted to get the ID of virtio_net it used to include virtio_net.h. This does no longer work, since virtio_net.h does not include virtio_ids.h. This patch moves all "#include <linux/virtio_ids.h>" from the C files into the header files, making the header files compatible with the old ones. In addition, this patch exports virtio_ids.h to userspace. CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-10-22virtio_blk: revert QUEUE_FLAG_VIRT additionChristoph Hellwig
It seems like the addition of QUEUE_FLAG_VIRT caueses major performance regressions for Fedora users: https://bugzilla.redhat.com/show_bug.cgi?id=509383 https://bugzilla.redhat.com/show_bug.cgi?id=505695 while I can't reproduce those extreme regressions myself I think the flag is wrong. Rationale: QUEUE_FLAG_VIRT expands to QUEUE_FLAG_NONROT which casus the queue unplugged immediately. This is not a good behaviour for at least qemu and kvm where we do have significant overhead for every I/O operations. Even with all the latested speeups (native AIO, MSI support, zero copy) we can only get native speed for up to 128kb I/O requests we already are down to 66% of native performance for 4kb requests even on my laptop running the Intel X25-M SSD for which the QUEUE_FLAG_NONROT was designed. If we ever get virtio-blk overhead low enough that this flag makes sense it should only be set based on a feature flag set by the host. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: don't force VIRTIO_F_NOTIFY_ON_EMPTY lguest: cleanup for map_switcher() lguest: use PGDIR_SHIFT for PAE code to allow different PAGE_OFFSET lguest: use set_pte/set_pmd uniformly for real page table entries lguest: move panic notifier registration to its expected place. virtio_blk: add support for cache flush virtio: add virtio IDs file virtio: get rid of redundant VIRTIO_ID_9P definition virtio: make add_buf return capacity remaining virtio_pci: minor MSI-X cleanups
2009-09-23virtio_blk: add support for cache flushChristoph Hellwig
Recent qemu has added a VIRTIO_BLK_F_FLUSH flag to advertise that the virtual disk has a volatile write cache that needs to be flushed. In case we see this feature implement tell the Linux block layer about the fact and use the new VIRTIO_BLK_T_FLUSH to flush the cache when required. This allows for an correct and simple implementation of write barriers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: add virtio IDs fileFernando Luis Vazquez Cao
Virtio IDs are spread all over the tree which makes assigning new IDs bothersome. Putting them together should make the process less error-prone. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: make add_buf return capacity remainingRusty Russell
This API change means that virtio_net can tell how much capacity remains for buffers. It's necessarily fuzzy, since VIRTIO_RING_F_INDIRECT_DESC means we can fit any number of descriptors in one, *if* we can kmalloc. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dinesh Subhraveti <dineshs@us.ibm.com>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-22Merge branch 'tj-block-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc * 'tj-block-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc: virtio_blk: mark virtio_blk with __refdata to kill spurious section mismatch block: sysfs fix mismatched queue_var_{store,show} in 64bit kernel ataflop: adjust NULL test block: fix failfast merge testing in elv_rq_merge_ok() z2ram: Small cleanup for z2ram.c
2009-07-19virtio_blk: mark virtio_blk with __refdata to kill spurious section mismatchRakib Mullick
The variable virtio_blk references the function virtblk_probe() (which is in .devinit section) and also references the function virtblk_remove() ( which is in .devexit section). So, virtio_blk simultaneously refers .devinit and .devexit section. To avoid this messup, we mark virtio_blk as __refdata. We were warned by the following warning: LD drivers/block/built-in.o WARNING: drivers/block/built-in.o(.data+0xc8dc): Section mismatch in reference from the variable virtio_blk to the function .devinit.text:virtblk_probe() The variable virtio_blk references the function __devinit virtblk_probe() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, WARNING: drivers/block/built-in.o(.data+0xc8e0): Section mismatch in reference from the variable virtio_blk to the function .devexit.text:virtblk_remove() The variable virtio_blk references the function __devexit virtblk_remove() If the reference is valid then annotate the variable with __exit* (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
