[ Upstream commit a88e03cf3d190cf46bc4063a9b7efe87590de5f4 ]
snprintf() returns the number of bytes it would have printed if there
were space. But it does not count the NUL terminator. So that means
that if "count == copied" then this has already overflowed by one
character.
This bug likely isn't super harmful in real life.
Link: https://lkml.kernel.org/r/20210916130404.GA25094@kili
Fixes: c0265342bff4 ("zram: introduce zram memory tracking")
Cc: Minchan Kim <minchan@kernel.org>
Cc: Sergey Senozhatsky <senozhatsky@chromium.org>
commit 57e0076e6575a7b7cef620a0bd2ee2549ef77818 upstream.
writeback_store's return value is overwritten by submit_bio_wait's return
value. Thus, writeback_store will return zero since there was no IO
error. In the end, write syscall from userspace will see the zero as
return value, which could make the process stall to keep trying the write
until it will succeed.
Link: https://lkml.kernel.org/r/20210312173949.2197662-1-minchan@kernel.org
Fixes: 3b82a051c101("drivers/block/zram/zram_drv.c: fix error return codes not being returned in writeback_store")
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: John Dias <joaodias@google.com>
Cc: <stable@vger.kernel.org>
commit 2395928158059b8f9858365fce7713ce7fef62e4 upstream.
There exists multiple path may do zram compaction concurrently.
1. auto-compaction triggered during memory reclaim
2. userspace utils write zram<id>/compaction node
So, multiple threads may call zs_shrinker_scan/zs_compact concurrently.
But pages_compacted is a per zsmalloc pool variable and modification
of the variable is not serialized(through under class->lock).
There are two issues here:
1. the pages_compacted may not equal to total number of pages
freed(due to concurrently add).
2. zs_shrinker_scan may not return the correct number of pages
freed(issued by current shrinker).
The fix is simple:
1. account the number of pages freed in zs_compact locally.
2. use actomic variable pages_compacted to accumulate total number.
Link: https://lkml.kernel.org/r/20210202122235.26885-1-wu-yan@tcl.com
Fixes: 860c707dca155a56 ("zsmalloc: account the number of compacted pages")
Signed-off-by: Rokudo Yan <wu-yan@tcl.com>
commit 853eab68afc80f59f36bbdeb715e5c88c501e680 upstream.
Turns out that the permissions for 0400 really are what we want here,
otherwise any user can read from this file.
[fixed formatting, added changelog, and made attribute static - gregkh]
Reported-by: Wade Mealing <wmealing@redhat.com>
Cc: stable <stable@vger.kernel.org>
Fixes: f40609d1591f ("zram: convert remaining CLASS_ATTR() to CLASS_ATTR_RO()")
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1847832
Reviewed-by: Steffen Maier <maier@linux.ibm.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Link: https://lore.kernel.org/r/20200617114946.GA2131650@kroah.com
writeback_store
[ Upstream commit 3b82a051c10143639a378dcd12019f2353cc9054 ]
Currently when an error code -EIO or -ENOSPC in the for-loop of
writeback_store the error code is being overwritten by a ret = len
assignment at the end of the function and the error codes are being
lost. Fix this by assigning ret = len at the start of the function and
remove the assignment from the end, hence allowing ret to be preserved
when error codes are assigned to it.
Addresses Coverity ("Unused value")
Link: http://lkml.kernel.org/r/20191128122958.178290-1-colin.king@canonical.com
Fixes: a939888ec38b ("zram: support idle/huge page writeback")
CPU0: CPU1:
backing_dev_show backing_dev_store
file = zram->backing_dev;
down_read(&zram->init_lock); down_read(&zram->init_init_lock)
file_path(file, ...); zram->backing_dev = backing_dev;
up_read(&zram->init_lock); up_read(&zram->init_lock);
gets the value of zram->backing_dev too early in backing_dev_show, which
resultin the value being NULL at the beginning, and not NULL later.
backtrace:
d_path+0xcc/0x174
file_path+0x10/0x18
backing_dev_show+0x40/0xb4
dev_attr_show+0x20/0x54
sysfs_kf_seq_show+0x9c/0x10c
kernfs_seq_show+0x28/0x30
seq_read+0x184/0x488
kernfs_fop_read+0x5c/0x1a4
__vfs_read+0x44/0x128
vfs_read+0xa0/0x138
SyS_read+0x54/0xb4
Link: http://lkml.kernel.org/r/1571046839-16814-1-git-send-email-chenwandun@huawei.com
Signed-off-by: Chenwandun <chenwandun@huawei.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: <stable@vger.kernel.org> [4.14+]
When scheduling work item to read page we need to pass down the proper
bvec struct which points to the page to read into. Before this patch it
uses a randomly initialized bvec (only if PAGE_SIZE != 4096) which is
wrong.
Note that without this patch on arch/kernel where PAGE_SIZE != 4096
userspace could read random memory through a zram block device (thought
userspace probably would have no control on the address being read).
Link: http://lkml.kernel.org/r/20190408183219.26377-1-jglisse@redhat.com
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Makoto report a below KASAN error: zram does out-of-bounds read. Because
strscpy copies from source up to count bytes unconditionally. It could
cause out-of-bounds read on next object in slab.
To prevent it, use strlcpy which checks source's length automatically.
BUG: KASAN: slab-out-of-bounds in strscpy+0x68/0x154
Read of size 8 at addr ffffffc0c3495a00 by task system_server/1314
Call trace:
strscpy+0x68/0x154
idle_store+0xc4/0x34c
dev_attr_store+0x50/0x6c
sysfs_kf_write+0x98/0xb4
kernfs_fop_write+0x198/0x260
__vfs_write+0x10c/0x338
vfs_write+0x114/0x238
SyS_write+0xc8/0x168
__sys_trace_return+0x0/0x4
Allocated by task 1314:
__kmalloc+0x280/0x318
kernfs_fop_write+0xac/0x260
Freed by task 2855:
kfree+0x138/0x630
kernfs_put_open_node+0x10c/0x124
kernfs_fop_release+0xd8/0x114
__fput+0x130/0x2a4
____fput+0x1c/0x28
task_work_run+0x16c/0x1c8
do_notify_resume+0x2bc/0x107c
work_pending+0x8/0x10
The buggy address belongs to the object at ffffffc0c3495a00
which belongs to the cache kmalloc-128 of size 128
The buggy address is located 0 bytes inside of
128-byte region [ffffffc0c3495a00, ffffffc0c3495a80)
The buggy address belongs to the page:
page:ffffffbf030d2500 count:1 mapcount:0 mapping: (null) index:0x0 compound_mapcount: 0
flags: 0x4000000000010200(slab|head)
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffffffc0c3495900: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffffffc0c3495980: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffffffc0c3495a00: 04 fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffffffc0c3495a80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffffffc0c3495b00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Link: http://lkml.kernel.org/r/20190319231911.145968-1-minchan@kernel.org
Cc: <stable@vger.kernel.org> [5.0]
Reported-by: Makoto Wu <makotowu@google.com>
lzo-rle gives higher performance and similar compression ratios to lzo.
Link: http://lkml.kernel.org/r/20190205155944.16007-4-dave.rodgman@arm.com
Signed-off-by: Dave Rodgman <dave.rodgman@arm.com>
This patch includes some fixes and cleanup for idle-page writeback.
1. writeback_limit interface
Now writeback_limit interface is rather conusing. For example, once
writeback limit budget is exausted, admin can see 0 from
/sys/block/zramX/writeback_limit which is same semantic with disable
writeback_limit at this moment. IOW, admin cannot tell that zero came
from disable writeback limit or exausted writeback limit.
To make the interface clear, let's sepatate enable of writeback limit to
another knob - /sys/block/zram0/writeback_limit_enable
* before:
while true :
# to re-enable writeback limit once previous one is used up
echo 0 > /sys/block/zram0/writeback_limit
echo $((200<<20)) > /sys/block/zram0/writeback_limit
.. # used up the writeback limit budget
* new
# To enable writeback limit, from the beginning, admin should
# enable it.
echo 1 > /sys/block/zram/0/writeback_limit_enable
while true :
It's much strightforward.
2. fix condition check idle/huge writeback mode check
The mode in writeback_store is not bit opeartion any more so no need to
use bit operations. Furthermore, current condition check is broken in
that it does writeback every pages regardless of huge/idle.
3. clean up idle_store
No need to use goto.
[minchan@kernel.org: missed spin_lock_init]
Link: http://lkml.kernel.org/r/20190103001601.GA255139@google.com
Link: http://lkml.kernel.org/r/20181224033529.19450-1-minchan@kernel.org
Suggested-by: John Dias <joaodias@google.com>
Cc: Srinivas Paladugu <srnvs@google.com>
If there are lots of write IO with flash device, it could have a
wearout problem of storage. To overcome the problem, admin needs
to design write limitation to guarantee flash health
for entire product life.
This patch creates a new knob "writeback_limit" for zram.
writeback_limit's default value is 0 so that it doesn't limit
any writeback. If admin want to measure writeback count in a
certain period, he could know it via /sys/block/zram0/bd_stat's
3rd column.
If admin want to limit writeback as per-day 400M, he could do it
like below.
MB_SHIFT=20
4K_SHIFT=12
echo $((400<<MB_SHIFT>>4K_SHIFT)) > \
/sys/block/zram0/writeback_limit.
If admin want to allow further write again, he could do it like below
If admin want to see remaining writeback budget,
cat /sys/block/zram0/writeback_limit
The writeback_limit count will reset whenever you reset zram (e.g., system
reboot, echo 1 > /sys/block/zramX/reset) so keeping how many of writeback
happened until you reset the zram to allocate extra writeback budget in
next setting is user's job.
[minchan@kernel.org: v4]
Link: http://lkml.kernel.org/r/20181203024045.153534-8-minchan@kernel.org
Link: http://lkml.kernel.org/r/20181127055429.251614-8-minchan@kernel.org
Cc: Joey Pabalinas <joeypabalinas@gmail.com>
bd_stat represents things that happened in the backing device. Currently
it supports bd_counts, bd_reads and bd_writes which are helpful to
understand wearout of flash and memory saving.
Link: http://lkml.kernel.org/r/20181203024045.153534-7-minchan@kernel.org
Link: http://lkml.kernel.org/r/20181127055429.251614-7-minchan@kernel.org
Add a new feature "zram idle/huge page writeback". In the zram-swap use
case, zram usually has many idle/huge swap pages. It's pointless to keep
them in memory (ie, zram).
To solve this problem, this feature introduces idle/huge page writeback to
the backing device so the goal is to save more memory space on embedded
systems.
Normal sequence to use idle/huge page writeback feature is as follows,
while (1) {
# mark allocated zram slot to idle
echo all > /sys/block/zram0/idle
# leave system working for several hours
# Unless there is no access for some blocks on zram,
# they are still IDLE marked pages.
echo "idle" > /sys/block/zram0/writeback
or/and
echo "huge" > /sys/block/zram0/writeback
# write the IDLE or/and huge marked slot into backing device
# and free the memory.
Per the discussion at
https://lore.kernel.org/lkml/20181122065926.GG3441@jagdpanzerIV/T/#u,
This patch removes direct incommpressibe page writeback feature
(d2afd25114f4 ("zram: write incompressible pages to backing device")).
Below concerns from Sergey:
"IDLE writeback" is superior to "incompressible writeback".
"incompressible writeback" is completely unpredictable and uncontrollable;
it depens on data patterns and compression algorithms. While "IDLE
writeback" is predictable.
I even suspect, that, *ideally*, we can remove "incompressible writeback".
"IDLE pages" is a super set which also includes "incompressible" pages.
So, technically, we still can do "incompressible writeback" from "IDLE
writeback" path; but a much more reasonable one, based on a page idling
period.
I understand that you want to keep "direct incompressible writeback"
around. ZRAM is especially popular on devices which do suffer from flash
wearout, so I can see "incompressible writeback" path becoming a dead
code, long term.
Below concerns from Minchan:
My concern is if we enable CONFIG_ZRAM_WRITEBACK in this implementation,
both hugepage/idlepage writeck will turn on. However someuser want to
enable only idlepage writeback so we need to introduce turn on/off knob
for hugepage or new CONFIG_ZRAM_IDLEPAGE_WRITEBACK for those usecase. I
don't want to make it complicated *if possible*.
Long term, I imagine we need to make VM aware of new swap hierarchy a
little bit different with as-is. For example, first high priority swap
can return -EIO or -ENOCOMP, swap try to fallback to next lower priority
swap device. With that, hugepage writeback will work tranparently.
So we could regard it as regression because incompressible pages doesn't
go to backing storage automatically. Instead, user should do it via "echo
huge" > /sys/block/zram/writeback" manually.
Link: http://lkml.kernel.org/r/20181127055429.251614-6-minchan@kernel.org
Reviewed-by: Joey Pabalinas <joeypabalinas@gmail.com>
To support idle page writeback with upcoming patches, this patch
introduces a new ZRAM_IDLE flag.
Userspace can mark zram slots as "idle" via
"echo all > /sys/block/zramX/idle"
which marks every allocated zram slot as ZRAM_IDLE.
User could see it by /sys/kernel/debug/zram/zram0/block_state.
300 75.033841 ...i
301 63.806904 s..i
302 63.806919 ..hi
Once there is IO for the slot, the mark will be disappeared.
300 75.033841 ...
301 63.806904 s..i
302 63.806919 ..hi
Therefore, 300th block is idle zpage. With this feature,
user can how many zram has idle pages which are waste of memory.
Link: http://lkml.kernel.org/r/20181127055429.251614-5-minchan@kernel.org
Rename some variables and restructure some code for better readability in
writeback and zs_free_page.
Link: http://lkml.kernel.org/r/20181127055429.251614-4-minchan@kernel.org
If blkdev_get fails, we shouldn't do blkdev_put. Otherwise, kernel emits
below log. This patch fixes it.
WARNING: CPU: 0 PID: 1893 at fs/block_dev.c:1828 blkdev_put+0x105/0x120
Modules linked in:
CPU: 0 PID: 1893 Comm: swapoff Not tainted 4.19.0+ #453
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
RIP: 0010:blkdev_put+0x105/0x120
Call Trace:
__x64_sys_swapoff+0x46d/0x490
do_syscall_64+0x5a/0x190
entry_SYSCALL_64_after_hwframe+0x49/0xbe
irq event stamp: 4466
hardirqs last enabled at (4465): __free_pages_ok+0x1e3/0x490
hardirqs last disabled at (4466): trace_hardirqs_off_thunk+0x1a/0x1c
softirqs last enabled at (3420): __do_softirq+0x333/0x446
softirqs last disabled at (3407): irq_exit+0xd1/0xe0
Link: http://lkml.kernel.org/r/20181127055429.251614-3-minchan@kernel.org
Patch series "zram idle page writeback", v3.
Inherently, swap device has many idle pages which are rare touched since
it was allocated. It is never problem if we use storage device as swap.
However, it's just waste for zram-swap.
This patchset supports zram idle page writeback feature.
* Admin can define what is idle page "no access since X time ago"
* Admin can define when zram should writeback them
* Admin can define when zram should stop writeback to prevent wearout
Details are in each patch's description.
This patch (of 7):
WARNING: inconsistent lock state
4.19.0+ #390 Not tainted
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
zram_verify/2095 [HC0[0]:SC1[1]:HE1:SE0] takes:
00000000b1828693 (&(&zram->bitmap_lock)->rlock){+.?.}, at: put_entry_bdev+0x1e/0x50
{SOFTIRQ-ON-W} state was registered at:
_raw_spin_lock+0x2c/0x40
zram_make_request+0x755/0xdc9
generic_make_request+0x373/0x6a0
submit_bio+0x6c/0x140
__swap_writepage+0x3a8/0x480
shrink_page_list+0x1102/0x1a60
shrink_inactive_list+0x21b/0x3f0
shrink_node_memcg.constprop.99+0x4f8/0x7e0
shrink_node+0x7d/0x2f0
do_try_to_free_pages+0xe0/0x300
try_to_free_pages+0x116/0x2b0
__alloc_pages_slowpath+0x3f4/0xf80
__alloc_pages_nodemask+0x2a2/0x2f0
__handle_mm_fault+0x42e/0xb50
handle_mm_fault+0x55/0xb0
__do_page_fault+0x235/0x4b0
page_fault+0x1e/0x30
irq event stamp: 228412
hardirqs last enabled at (228412): [<ffffffff98245846>] __slab_free+0x3e6/0x600
hardirqs last disabled at (228411): [<ffffffff98245625>] __slab_free+0x1c5/0x600
softirqs last enabled at (228396): [<ffffffff98e0031e>] __do_softirq+0x31e/0x427
softirqs last disabled at (228403): [<ffffffff98072051>] irq_exit+0xd1/0xe0
Possible unsafe locking scenario:
CPU0
lock(&(&zram->bitmap_lock)->rlock);
<Interrupt>
*** DEADLOCK ***
no locks held by zram_verify/2095.
stack backtrace:
CPU: 5 PID: 2095 Comm: zram_verify Not tainted 4.19.0+ #390
Call Trace:
<IRQ>
dump_stack+0x67/0x9b
print_usage_bug+0x1bd/0x1d3
mark_lock+0x4aa/0x540
__lock_acquire+0x51d/0x1300
lock_acquire+0x90/0x180
zram_free_page+0xf6/0x110
zram_slot_free_notify+0x42/0xa0
end_swap_bio_read+0x5b/0x170
blk_update_request+0x8f/0x340
scsi_end_request+0x2c/0x1e0
scsi_io_completion+0x98/0x650
blk_done_softirq+0x9e/0xd0
__do_softirq+0xcc/0x427
irq_exit+0xd1/0xe0
do_IRQ+0x93/0x120
common_interrupt+0xf/0xf
</IRQ>
With writeback feature, zram_slot_free_notify could be called in softirq
context by end_swap_bio_read. However, bitmap_lock is not aware of that
so lockdep yell out:
get_entry_bdev
spin_lock(bitmap->lock);
irq
softirq
end_swap_bio_read
zram_slot_lock <-- deadlock prone
zram_free_page
put_entry_bdev
spin_lock(bitmap->lock); <-- deadlock prone
With akpm's suggestion (i.e. bitmap operation is already atomic), we
could remove bitmap lock. It might fail to find a empty slot if serious
contention happens. However, it's not severe problem because huge page
writeback has already possiblity to fail if there is severe memory
pressure. Worst case is just keeping the incompressible in memory, not
storage.
The other problem is zram_slot_lock in zram_slot_slot_free_notify. To
make it safe is this patch introduces zram_slot_trylock where
zram_slot_free_notify uses it. Although it's rare to be contented, this
patch adds new debug stat "miss_free" to keep monitoring how often it
happens.
Link: http://lkml.kernel.org/r/20181127055429.251614-2-minchan@kernel.org
Register default sysfs groups during device_add_disk() to avoid a
race condition with udev during startup.
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
The call to strlcpy in backing_dev_store is incorrect. It should take
the size of the destination buffer instead of the size of the source
buffer. Additionally, ignore the newline character (\n) when reading
the new file_name buffer. This makes it possible to set the backing_dev
as follows:
echo /dev/sdX > /sys/block/zram0/backing_dev
The reason it worked before was the fact that strlcpy() copies 'len - 1'
bytes, which is strlen(buf) - 1 in our case, so it accidentally didn't
copy the trailing new line symbol. Which also means that "echo -n
/dev/sdX" most likely was broken.
Signed-off-by: Peter Kalauskas <peskal@google.com>
Link: http://lkml.kernel.org/r/20180813061623.GC64836@rodete-desktop-imager.corp.google.com
Pull block updates from Jens Axboe:
"First pull request for this merge window, there will also be a
followup request with some stragglers.
This pull request contains:
- Fix for a thundering heard issue in the wbt block code (Anchal
Agarwal)
- A few NVMe pull requests:
* Improved tracepoints (Keith)
* Larger inline data support for RDMA (Steve Wise)
* RDMA setup/teardown fixes (Sagi)
* Effects log suppor for NVMe target (Chaitanya Kulkarni)
* Buffered IO suppor for NVMe target (Chaitanya Kulkarni)
* TP4004 (ANA) support (Christoph)
* Various NVMe fixes
- Block io-latency controller support. Much needed support for
properly containing block devices. (Josef)
- Series improving how we handle sense information on the stack
(Kees)
- Lightnvm fixes and updates/improvements (Mathias/Javier et al)
- Zoned device support for null_blk (Matias)
- AIX partition fixes (Mauricio Faria de Oliveira)
- DIF checksum code made generic (Max Gurtovoy)
- Add support for discard in iostats (Michael Callahan / Tejun)
- Set of updates for BFQ (Paolo)
- Removal of async write support for bsg (Christoph)
- Bio page dirtying and clone fixups (Christoph)
- Set of bcache fix/changes (via Coly)
- Series improving blk-mq queue setup/teardown speed (Ming)
- Series improving merging performance on blk-mq (Ming)
- Lots of other fixes and cleanups from a slew of folks"
* tag 'for-4.19/block-20180812' of git://git.kernel.dk/linux-block: (190 commits)
blkcg: Make blkg_root_lookup() work for queues in bypass mode
bcache: fix error setting writeback_rate through sysfs interface
null_blk: add lock drop/acquire annotation
Blk-throttle: reduce tail io latency when iops limit is enforced
block: paride: pd: mark expected switch fall-throughs
block: Ensure that a request queue is dissociated from the cgroup controller
block: Introduce blk_exit_queue()
blkcg: Introduce blkg_root_lookup()
block: Remove two superfluous #include directives
blk-mq: count the hctx as active before allocating tag
block: bvec_nr_vecs() returns value for wrong slab
bcache: trivial - remove tailing backslash in macro BTREE_FLAG
bcache: make the pr_err statement used for ENOENT only in sysfs_attatch section
bcache: set max writeback rate when I/O request is idle
bcache: add code comments for bset.c
bcache: fix mistaken comments in request.c
bcache: fix mistaken code comments in bcache.h
bcache: add a comment in super.c
bcache: avoid unncessary cache prefetch bch_btree_node_get()
bcache: display rate debug parameters to 0 when writeback is not running
If zram supports writeback feature, it's no longer a
BD_CAP_SYNCHRONOUS_IO device beause zram does asynchronous IO operations
for incompressible pages.
Do not pretend to be synchronous IO device. It makes the system very
sluggish due to waiting for IO completion from upper layers.
Furthermore, it causes a user-after-free problem because swap thinks the
opearion is done when the IO functions returns so it can free the page
(e.g., lock_page_or_retry and goto out_release in do_swap_page) but in
fact, IO is asynchronous so the driver could access a just freed page
afterward.
This patch fixes the problem.
BUG: Bad page state in process qemu-system-x86 pfn:3dfab21
page:ffffdfb137eac840 count:0 mapcount:0 mapping:0000000000000000 index:0x1
flags: 0x17fffc000000008(uptodate)
raw: 017fffc000000008 dead000000000100 dead000000000200 0000000000000000
raw: 0000000000000001 0000000000000000 00000000ffffffff 0000000000000000
page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
bad because of flags: 0x8(uptodate)
CPU: 4 PID: 1039 Comm: qemu-system-x86 Tainted: G B 4.18.0-rc5+ #1
Hardware name: Supermicro Super Server/X10SRL-F, BIOS 2.0b 05/02/2017
Call Trace:
dump_stack+0x5c/0x7b
bad_page+0xba/0x120
get_page_from_freelist+0x1016/0x1250
__alloc_pages_nodemask+0xfa/0x250
alloc_pages_vma+0x7c/0x1c0
do_swap_page+0x347/0x920
__handle_mm_fault+0x7b4/0x1110
handle_mm_fault+0xfc/0x1f0
__get_user_pages+0x12f/0x690
get_user_pages_unlocked+0x148/0x1f0
__gfn_to_pfn_memslot+0xff/0x3c0 [kvm]
try_async_pf+0x87/0x230 [kvm]
tdp_page_fault+0x132/0x290 [kvm]
kvm_mmu_page_fault+0x74/0x570 [kvm]
kvm_arch_vcpu_ioctl_run+0x9b3/0x1990 [kvm]
kvm_vcpu_ioctl+0x388/0x5d0 [kvm]
do_vfs_ioctl+0xa2/0x630
ksys_ioctl+0x70/0x80
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x55/0x100
entry_SYSCALL_64_after_hwframe+0x44/0xa9
Link: https://lore.kernel.org/lkml/0516ae2d-b0fd-92c5-aa92-112ba7bd32fc@contabo.de/
Link: http://lkml.kernel.org/r/20180802051112.86174-1-minchan@kernel.org
[minchan@kernel.org: fix changelog, add comment]
Link: http://lkml.kernel.org/r/20180805233722.217347-1-minchan@kernel.org
Reported-by: Tino Lehnig <tino.lehnig@contabo.de>
Tested-by: Tino Lehnig <tino.lehnig@contabo.de>
Cc: <stable@vger.kernel.org> [4.15+]
Add and use a new op_stat_group() function for indexing partition stat
fields rather than indexing them by rq_data_dir() or bio_data_dir().
This function works similarly to op_is_sync() in that it takes the
request::cmd_flags or bio::bi_opf flags and determines which stats
should et updated.
In addition, the second parameter to generic_start_io_acct() and
generic_end_io_acct() is now a REQ_OP rather than simply a read or
write bit and it uses op_stat_group() on the parameter to determine
the stat group.
Note that the partition in_flight counts are not part of the per-cpu
statistics and as such are not indexed via this function. It's now
indexed by op_is_write().
tj: Refreshed on top of v4.17. Updated to pass around REQ_OP.
Signed-off-by: Michael Callahan <michaelcallahan@fb.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Joshua Morris <josh.h.morris@us.ibm.com>
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Matias Bjorling <mb@lightnvm.io>
Cc: Kent Overstreet <kent.overstreet@gmail.com>
Cc: Alasdair Kergon <agk@redhat.com>
c11f0c0b5bb9 ("block/mm: make bdev_ops->rw_page() take a bool for
read/write") replaced @op with boolean @is_write, which limited the
amount of information going into ->rw_page() and more importantly
page_endio(), which removed the need to expose block internals to mm.
Unfortunately, we want to track discards separately and @is_write
isn't enough information. This patch updates bdev_ops->rw_page() to
take REQ_OP instead but leaves page_endio() to take bool @is_write.
This allows the block part of operations to have enough information
while not leaking it to mm.
Cc: Mike Christie <mchristi@redhat.com>
The vzalloc() function has no 2-factor argument form, so multiplication
factors need to be wrapped in array_size(). This patch replaces cases of:
vzalloc(a * b)
with:
vzalloc(array_size(a, b))
as well as handling cases of:
vzalloc(a * b * c)
with:
vzalloc(array3_size(a, b, c))
This does, however, attempt to ignore constant size factors like:
vzalloc(4 * 1024)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
vzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
vzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
vzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
vzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
vzalloc(
- sizeof(char) * (COUNT)
+ COUNT
vzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
vzalloc(
- sizeof(u8) * COUNT
+ COUNT
vzalloc(
- sizeof(__u8) * COUNT
+ COUNT
vzalloc(
- sizeof(char) * COUNT
+ COUNT
vzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
vzalloc(
- sizeof(TYPE) * (COUNT_ID)
+ array_size(COUNT_ID, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * COUNT_ID
vzalloc(
- sizeof(TYPE) * (COUNT_CONST)
+ array_size(COUNT_CONST, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * COUNT_CONST
vzalloc(
- sizeof(THING) * (COUNT_ID)
+ array_size(COUNT_ID, sizeof(THING))
vzalloc(
- sizeof(THING) * COUNT_ID
vzalloc(
- sizeof(THING) * (COUNT_CONST)
+ array_size(COUNT_CONST, sizeof(THING))
vzalloc(
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
vzalloc(
- SIZE * COUNT
+ array_size(COUNT, SIZE)
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
vzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
vzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
vzalloc(
- sizeof(TYPE) * COUNT * STRIDE
vzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
vzalloc(
- sizeof(THING) * (COUNT) * STRIDE
vzalloc(
- sizeof(THING) * COUNT * (STRIDE)
vzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
vzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
vzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
vzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
vzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
vzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
vzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
vzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
vzalloc(
- COUNT * (STRIDE) * SIZE
vzalloc(
- COUNT * STRIDE * (SIZE)
vzalloc(
- (COUNT) * (STRIDE) * SIZE
vzalloc(
- COUNT * (STRIDE) * (SIZE)
vzalloc(
- (COUNT) * STRIDE * (SIZE)
vzalloc(
- (COUNT) * (STRIDE) * (SIZE)
vzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
vzalloc(C1 * C2 * C3, ...)
vzalloc(
- E1 * E2 * E3
+ array3_size(E1, E2, E3)
// And then all remaining 2 factors products when they're not all constants.
expression E1, E2;
constant C1, C2;
vzalloc(C1 * C2, ...)
vzalloc(
- E1 * E2
+ array_size(E1, E2)
zRam as swap is useful for small memory device. However, swap means
those pages on zram are mostly cold pages due to VM's LRU algorithm.
Especially, once init data for application are touched for launching,
they tend to be not accessed any more and finally swapped out. zRAM can
store such cold pages as compressed form but it's pointless to keep in
memory. Better idea is app developers free them directly rather than
remaining them on heap.
This patch tell us last access time of each block of zram via "cat
/sys/kernel/debug/zram/zram0/block_state".
The output is as follows,
300 75.033841 .wh
301 63.806904 s..
302 63.806919 ..h
First column is zram's block index and 3rh one represents symbol (s:
same page w: written page to backing store h: huge page) of the block
state. Second column represents usec time unit of the block was last
accessed. So above example means the 300th block is accessed at
75.033851 second and it was huge so it was written to the backing store.
Admin can leverage this information to catch cold|incompressible pages
of process with *pagemap* once part of heaps are swapped out.
I used the feature a few years ago to find memory hoggers in userspace
to notify them what memory they have wasted without touch for a long
time. With it, they could reduce unnecessary memory space. However, at
that time, I hacked up zram for the feature but now I need the feature
again so I decided it would be better to upstream rather than keeping it
alone. I hope I submit the userspace tool to use the feature soon.
[akpm@linux-foundation.org: fix i386 printk warning]
[minchan@kernel.org: use ktime_get_boottime() instead of sched_clock()]
Link: http://lkml.kernel.org/r/20180420063525.GA253739@rodete-desktop-imager.corp.google.com
[akpm@linux-foundation.org: documentation tweak]
[minchan@kernel.org: fix compile warning]
Link: http://lkml.kernel.org/r/20180508104849.GA8209@rodete-desktop-imager.corp.google.com
[rdunlap@infradead.org: fix printk formats]
Link: http://lkml.kernel.org/r/3652ccb1-96ef-0b0b-05d1-f661d7733dcc@infradead.org
Link: http://lkml.kernel.org/r/20180416090946.63057-5-minchan@kernel.org
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
This patch records last access time of each block of zram so that With
upcoming zram memory tracking, it could help userspace developers to
reduce memory footprint.
Link: http://lkml.kernel.org/r/20180416090946.63057-4-minchan@kernel.org
Mark incompressible pages so that we could investigate who is the owner
of the incompressible pages once the page is swapped out via using
upcoming zram memory tracker feature.
With it, we could prevent such pages to be swapped out by using mlock.
Otherwise we might remove them.
This patch exposes new stat for huge pages via mm_stat.
Link: http://lkml.kernel.org/r/20180416090946.63057-3-minchan@kernel.org
Patch series "zram memory tracking", v5.
memory. As well, it's pointless to store incompressible pages to zram
so better idea is app developers manages them directly like free or
mlock rather than remaining them on heap.
This patch provides a debugfs /sys/kernel/debug/zram/zram0/block_state
to represent each block's state so admin can investigate what memory is
cold|incompressible|same page with using pagemap once the pages are
swapped out.
The output is as follows:
300 75.033841 .wh
301 63.806904 s..
302 63.806919 ..h
This patch (of 4):
ZRAM_ACCESS is used for locking a slot of zram so correct the name. It
is also not a common flag to indicate status of the block so move the
declare position on top of the flag. Lastly, let's move the function to
the top of source code to be able to use it easily without forward
declaration.
Link: http://lkml.kernel.org/r/20180416090946.63057-2-minchan@kernel.org
Merge updates from Andrew Morton:
- a few misc things
- ocfs2 updates
- the v9fs maintainers have been missing for a long time. I've taken
over v9fs patch slinging.
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (116 commits)
mm,oom_reaper: check for MMF_OOM_SKIP before complaining
mm/ksm: fix interaction with THP
mm/memblock.c: cast constant ULLONG_MAX to phys_addr_t
headers: untangle kmemleak.h from mm.h
include/linux/mmdebug.h: make VM_WARN* non-rvals
mm/page_isolation.c: make start_isolate_page_range() fail if already isolated
mm: change return type to vm_fault_t
mm, oom: remove 3% bonus for CAP_SYS_ADMIN processes
mm, page_alloc: wakeup kcompactd even if kswapd cannot free more memory
kernel/fork.c: detect early free of a live mm
mm: make counting of list_lru_one::nr_items lockless
mm/swap_state.c: make bool enable_vma_readahead and swap_vma_readahead() static
block_invalidatepage(): only release page if the full page was invalidated
mm: kernel-doc: add missing parameter descriptions
mm/swap.c: remove @cold parameter description for release_pages()
mm/nommu: remove description of alloc_vm_area
zram: drop max_zpage_size and use zs_huge_class_size()
zsmalloc: introduce zs_huge_class_size()
mm: fix races between swapoff and flush dcache
fs/direct-io.c: minor cleanups in do_blockdev_direct_IO
Remove ZRAM's enforced "huge object" value and use zsmalloc huge-class
watermark instead, which makes more sense.
TEST
- I used a 1G zram device, LZO compression back-end, original
data set size was 444MB. Looking at zsmalloc classes stats the
test ended up to be pretty fair.
BASE ZRAM/ZSMALLOC
zram mm_stat
498978816 191482495 199831552 0 199831552 15634 0
zsmalloc classes
class size almost_full almost_empty obj_allocated obj_used pages_used pages_per_zspage freeable
151 2448 0 0 1240 1240 744 3 0
168 2720 0 0 4200 4200 2800 2 0
190 3072 0 0 10100 10100 7575 3 0
202 3264 0 0 380 380 304 4 0
254 4096 0 0 10620 10620 10620 1 0
Total 7 46 106982 106187 48787 0
PATCHED ZRAM/ZSMALLOC
zram mm_stat
498978816 182579184 194248704 0 194248704 15628 0
zsmalloc classes
202 3264 0 0 7180 7180 5744 4 0
254 4096 0 0 3820 3820 3820 1 0
Total 8 45 106959 106193 47424 0
As we can see, we reduced the number of objects stored in class-4096,
because a huge number of objects which we previously forcibly stored in
class-4096 now stored in non-huge class-3264. This results in lower
memory consumption:
- zsmalloc now uses 47424 physical pages, which is less than 48787 pages
zsmalloc used before.
- objects that we store in class-3264 share zspages. That's why overall
the number of pages that both class-4096 and class-3264 consumed went
down from 10924 to 9564.
[sergey.senozhatsky.work@gmail.com: add pool param to zs_huge_class_size()]
Link: http://lkml.kernel.org/r/20180314081833.1096-3-sergey.senozhatsky@gmail.com
Link: http://lkml.kernel.org/r/20180306070639.7389-3-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
This patch has been generated as follows:
for verb in set_unlocked clear_unlocked set clear; do
replace-in-files queue_flag_${verb} blk_queue_flag_${verb%_unlocked} \
$(git grep -lw queue_flag_${verb} drivers block/bsg*)
done
Except for protecting all queue flag changes with the queue lock
this patch does not change any functionality.
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Shaohua Li <shli@fb.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Remove the disk, partition and bdi sysfs attributes before cleaning up
the request queue associated with the disk.
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Reviewed-by: Ming Lei <ming.lei@redhat.com>
This patch converts to bio_first_bvec_all() & bio_first_page_all() for
retrieving the 1st bvec/page, and prepares for supporting multipage bvec.
Signed-off-by: Ming Lei <ming.lei@redhat.com>
zram_page_end_io() is local to the source and does not need to be in
global scope, so make it static.
Cleans up sparse warning:
symbol 'zram_page_end_io' was not declared. Should it be static?
Link: http://lkml.kernel.org/r/20171016173336.20320-1-colin.king@canonical.com
As discussed at
https://lkml.kernel.org/r/<20170728165604.10455-1-ross.zwisler@linux.intel.com>
someday we will remove rw_page(). If so, we need something to detect
such super-fast storage on which synchronous IO operations like the
current rw_page are always a win.
Introduces BDI_CAP_SYNCHRONOUS_IO to indicate such devices. With it, we
could use various optimization techniques.
Link: http://lkml.kernel.org/r/1505886205-9671-3-git-send-email-minchan@kernel.org
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Ilya Dryomov <idryomov@gmail.com>
Cc: Huang Ying <ying.huang@intel.com>
With fast swap storage, the platform wants to use swap more aggressively
and swap-in is crucial to application latency.
The rw_page() based synchronous devices like zram, pmem and btt are such
fast storage. When I profile swapin performance with zram lz4
decompress test, S/W overhead is more than 70%. Maybe, it would be
bigger in nvdimm.
This patchset reduces swap-in latency by skipping swapcache if the swap
device is a synchronous device like a rw_page() based device.
It enhances by 45% my swapin test (5G sequential swapin, no readahead)
from 2.41sec to 1.64sec.
This patch (of 4):
Commit 19b7ccf8651d ("block: get rid of blk_integrity_revalidate()")
fixed a weird thing (i.e., reset BDI_CAP_STABLE_WRITES flag
unconditionally whenever revalidat_disk is called) so zram doesn't need
to reset the flag any more when revalidating the bdev. Instead, set the
flag just once when the zram device is created.
It shouldn't change any behavior.
Link: http://lkml.kernel.org/r/1505886205-9671-2-git-send-email-minchan@kernel.org
In testing I found handle passed to zs_map_object in __zram_bvec_read is
NULL so eh kernel goes oops in pin_object().
The reason is there is no routine to check the slot's freeing after
getting the slot's lock. This patch fixes it.
[minchan@kernel.org: v2]
Link: http://lkml.kernel.org/r/1505887347-10881-1-git-send-email-minchan@kernel.org
Link: http://lkml.kernel.org/r/1505788488-26723-1-git-send-email-minchan@kernel.org
Fixes: 1f7319c74275 ("zram: partial IO refactoring")
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
zram was the motivation for creating memset_l(). Minchan Kim sees a 7%
performance improvement on x86 with 100MB of non-zero deduplicatable
data:
perf stat -r 10 dd if=/dev/zram0 of=/dev/null
vanilla: 0.232050465 seconds time elapsed ( +- 0.51% )
memset_l: 0.217219387 seconds time elapsed ( +- 0.07% )
Link: http://lkml.kernel.org/r/20170720184539.31609-7-willy@infradead.org
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Tested-by: Minchan Kim <minchan@kernel.org>
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Russell King <rmk+kernel@armlinux.org.uk>
Pull block layer updates from Jens Axboe:
"This is the first pull request for 4.14, containing most of the code
changes. It's a quiet series this round, which I think we needed after
the churn of the last few series. This contains:
- Fix for a registration race in loop, from Anton Volkov.
- Overflow complaint fix from Arnd for DAC960.
- Series of drbd changes from the usual suspects.
- Conversion of the stec/skd driver to blk-mq. From Bart.
- A few BFQ improvements/fixes from Paolo.
- CFQ improvement from Ritesh, allowing idling for group idle.
- A few fixes found by Dan's smatch, courtesy of Dan.
- A warning fixup for a race between changing the IO scheduler and
device remova. From David Jeffery.
- A few nbd fixes from Josef.
- Support for cgroup info in blktrace, from Shaohua.
- Also from Shaohua, new features in the null_blk driver to allow it
to actually hold data, among other things.
- Various corner cases and error handling fixes from Weiping Zhang.
- Improvements to the IO stats tracking for blk-mq from me. Can
drastically improve performance for fast devices and/or big
machines.
- Series from Christoph removing bi_bdev as being needed for IO
submission, in preparation for nvme multipathing code.
- Series from Bart, including various cleanups and fixes for switch
fall through case complaints"
* 'for-4.14/block' of git://git.kernel.dk/linux-block: (162 commits)
kernfs: checking for IS_ERR() instead of NULL
drbd: remove BIOSET_NEED_RESCUER flag from drbd_{md_,}io_bio_set
drbd: Fix allyesconfig build, fix recent commit
drbd: switch from kmalloc() to kmalloc_array()
drbd: abort drbd_start_resync if there is no connection
drbd: move global variables to drbd namespace and make some static
drbd: rename "usermode_helper" to "drbd_usermode_helper"
drbd: fix race between handshake and admin disconnect/down
drbd: fix potential deadlock when trying to detach during handshake
drbd: A single dot should be put into a sequence.
drbd: fix rmmod cleanup, remove _all_ debugfs entries
drbd: Use setup_timer() instead of init_timer() to simplify the code.
drbd: fix potential get_ldev/put_ldev refcount imbalance during attach
drbd: new disk-option disable-write-same
drbd: Fix resource role for newly created resources in events2
drbd: mark symbols static where possible
drbd: Send P_NEG_ACK upon write error in protocol != C
drbd: add explicit plugging when submitting batches
drbd: change list_for_each_safe to while(list_first_entry_or_null)
drbd: introduce drbd_recv_header_maybe_unplug
The .rw_page in struct block_device_operations is used by the swap
subsystem to read/write the page contents from/into the corresponding
swap slot in the swap device. To support the THP (Transparent Huge
Page) swap optimization, the .rw_page is enhanced to support to
read/write THP if possible.
Link: http://lkml.kernel.org/r/20170724051840.2309-6-ying.huang@intel.com
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Reviewed-by: Ross Zwisler <ross.zwisler@intel.com> [for brd.c, zram_drv.c, pmem.c]
Cc: Vishal L Verma <vishal.l.verma@intel.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Shaohua Li <shli@kernel.org>
This patch enables read IO from backing device. For the feature, it
implements two IO read functions to transfer data from backing storage.
One is asynchronous IO function and other is synchronous one.
A reason I need synchrnous IO is due to partial write which need to
complete read IO before the overwriting partial data.
We can make the partial IO's case asynchronous, too but at the moment, I
don't feel adding more complexity to support such rare use cases so want
to go with simple.
[xieyisheng1@huawei.com: read_from_bdev_async(): return 1 to avoid call page_endio() in zram_rw_page()]
Link: http://lkml.kernel.org/r/1502707447-6944-1-git-send-email-xieyisheng1@huawei.com
Link: http://lkml.kernel.org/r/1498459987-24562-9-git-send-email-minchan@kernel.org
Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Juneho Choi <juno.choi@lge.com>
This patch enables write IO to transfer data to backing device. For
that, it implements write_to_bdev function which creates new bio and
chaining with parent bio to make the parent bio asynchrnous.
For rw_page which don't have parent bio, it submit owned bio and handle
IO completion by zram_page_end_io.
Also, this patch defines new flag ZRAM_WB to mark written page for later
read IO.
[xieyisheng1@huawei.com: fix typo in comment]
Link: http://lkml.kernel.org/r/1502707447-6944-2-git-send-email-xieyisheng1@huawei.com
Link: http://lkml.kernel.org/r/1498459987-24562-8-git-send-email-minchan@kernel.org
For upcoming asynchronous IO like writeback, zram_rw_page should be
aware of that whether requested IO was completed or submitted
successfully, otherwise error.
For the goal, zram_bvec_rw has three return values.
-errno: returns error number
0: IO request is done synchronously
1: IO request is issued successfully.
Link: http://lkml.kernel.org/r/1498459987-24562-7-git-send-email-minchan@kernel.org
With backing device, zram needs management of free space of backing
device.
This patch adds bitmap logic to manage free space which is very naive.
However, it would be simple enough as considering uncompressible pages's
frequenty in zram.
Link: http://lkml.kernel.org/r/1498459987-24562-6-git-send-email-minchan@kernel.org
For writeback feature, user should set up backing device before the zram
working.
This patch enables the interface via /sys/block/zramX/backing_dev.
Currently, it supports block device only but it could be enhanced for
file as well.
Link: http://lkml.kernel.org/r/1498459987-24562-5-git-send-email-minchan@kernel.org
zram_decompress_page naming is not proper because it doesn't decompress
if page was dedup hit or stored with compression.
Use more abstract term and consistent with write path function
__zram_bvec_write.
Link: http://lkml.kernel.org/r/1498459987-24562-4-git-send-email-minchan@kernel.org
zram_compress does several things, compress, entry alloc and check
limitation. I did for just readbility but it hurts modulization.:(
So this patch removes zram_compress functions and inline it in
__zram_bvec_write for upcoming patches.
Link: http://lkml.kernel.org/r/1498459987-24562-3-git-send-email-minchan@kernel.org
Patch series "writeback incompressible pages to storage", v1.
zRam is useful for memory saving with compressible pages but sometime,
workload can be changed and system has lots of incompressible pages
which is very harmful for zram.
This patch supports writeback feature of zram so admin can set up a
block device and with it, zram can save the memory via writing out the
incompressile pages once it found it's incompressible pages (1/4 comp
ratio) instead of keeping the page in memory.
[1-3] is just clean up and [4-8] is step by step feature enablement.
[4-8] is logically not bisectable(ie, logical unit separation)
although I tried to compiled out without breaking but I think it would
be better to review.
This patch (of 9):
__zram_bvec_write has some of duplicated logic for zram meta data
handling of same_page|compressed_page. This patch aims to clean it up
without behavior change.
[xieyisheng1@huawei.com: fix compr_data_size stat]
Link: http://lkml.kernel.org/r/1496019048-27016-1-git-send-email-minchan@kernel.org
Link: http://lkml.kernel.org/r/1498459987-24562-2-git-send-email-minchan@kernel.org
comp_algorithm_store() passes the size of the source buffer to strlcpy()
instead of the destination buffer size. Make it explicit that the two
buffers have the same size and use strcpy() instead of strlcpy(). The
latter can be done safely since the function ensures that the string in
the source buffer is terminated.
Link: http://lkml.kernel.org/r/20170803163350.45245-1-mka@chromium.org
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
No functional change in this patch, just in preparation for
basing the inflight mechanism on the queue in question.
Reviewed-by: Omar Sandoval <osandov@fb.com>
