This is the 4.19.23 stable release
[ Upstream commit 3c9959e025472122a61faebb208525cf26b305d1 ]
Patch series "zram idle page writeback", v3.
Inherently, swap device has many idle pages which are rare touched since
it was allocated. It is never problem if we use storage device as swap.
However, it's just waste for zram-swap.
This patchset supports zram idle page writeback feature.
* Admin can define what is idle page "no access since X time ago"
* Admin can define when zram should writeback them
* Admin can define when zram should stop writeback to prevent wearout
Details are in each patch's description.
This patch (of 7):
WARNING: inconsistent lock state
4.19.0+ #390 Not tainted
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
zram_verify/2095 [HC0[0]:SC1[1]:HE1:SE0] takes:
00000000b1828693 (&(&zram->bitmap_lock)->rlock){+.?.}, at: put_entry_bdev+0x1e/0x50
{SOFTIRQ-ON-W} state was registered at:
_raw_spin_lock+0x2c/0x40
zram_make_request+0x755/0xdc9
generic_make_request+0x373/0x6a0
submit_bio+0x6c/0x140
__swap_writepage+0x3a8/0x480
shrink_page_list+0x1102/0x1a60
shrink_inactive_list+0x21b/0x3f0
shrink_node_memcg.constprop.99+0x4f8/0x7e0
shrink_node+0x7d/0x2f0
do_try_to_free_pages+0xe0/0x300
try_to_free_pages+0x116/0x2b0
__alloc_pages_slowpath+0x3f4/0xf80
__alloc_pages_nodemask+0x2a2/0x2f0
__handle_mm_fault+0x42e/0xb50
handle_mm_fault+0x55/0xb0
__do_page_fault+0x235/0x4b0
page_fault+0x1e/0x30
irq event stamp: 228412
hardirqs last enabled at (228412): [<ffffffff98245846>] __slab_free+0x3e6/0x600
hardirqs last disabled at (228411): [<ffffffff98245625>] __slab_free+0x1c5/0x600
softirqs last enabled at (228396): [<ffffffff98e0031e>] __do_softirq+0x31e/0x427
softirqs last disabled at (228403): [<ffffffff98072051>] irq_exit+0xd1/0xe0
Possible unsafe locking scenario:
CPU0
lock(&(&zram->bitmap_lock)->rlock);
<Interrupt>
*** DEADLOCK ***
no locks held by zram_verify/2095.
stack backtrace:
CPU: 5 PID: 2095 Comm: zram_verify Not tainted 4.19.0+ #390
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
Call Trace:
<IRQ>
dump_stack+0x67/0x9b
print_usage_bug+0x1bd/0x1d3
mark_lock+0x4aa/0x540
__lock_acquire+0x51d/0x1300
lock_acquire+0x90/0x180
zram_free_page+0xf6/0x110
zram_slot_free_notify+0x42/0xa0
end_swap_bio_read+0x5b/0x170
blk_update_request+0x8f/0x340
scsi_end_request+0x2c/0x1e0
scsi_io_completion+0x98/0x650
blk_done_softirq+0x9e/0xd0
__do_softirq+0xcc/0x427
irq_exit+0xd1/0xe0
do_IRQ+0x93/0x120
common_interrupt+0xf/0xf
</IRQ>
With writeback feature, zram_slot_free_notify could be called in softirq
context by end_swap_bio_read. However, bitmap_lock is not aware of that
so lockdep yell out:
get_entry_bdev
spin_lock(bitmap->lock);
irq
softirq
end_swap_bio_read
zram_slot_lock <-- deadlock prone
zram_free_page
put_entry_bdev
spin_lock(bitmap->lock); <-- deadlock prone
With akpm's suggestion (i.e. bitmap operation is already atomic), we
could remove bitmap lock. It might fail to find a empty slot if serious
contention happens. However, it's not severe problem because huge page
writeback has already possiblity to fail if there is severe memory
pressure. Worst case is just keeping the incompressible in memory, not
storage.
The other problem is zram_slot_lock in zram_slot_slot_free_notify. To
make it safe is this patch introduces zram_slot_trylock where
zram_slot_free_notify uses it. Although it's rare to be contented, this
patch adds new debug stat "miss_free" to keep monitoring how often it
happens.
Link: http://lkml.kernel.org/r/20181127055429.251614-2-minchan@kernel.org
Signed-off-by: Minchan Kim <minchan@kernel.org>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reviewed-by: Joey Pabalinas <joeypabalinas@gmail.com>
They're nondeterministic, and lead to ___might_sleep() splats in -rt.
OTOH, they're a lot less wasteful than an rtmutex per page.
Signed-off-by: Mike Galbraith <umgwanakikbuti@gmail.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
zRam as swap is useful for small memory device. However, swap means
those pages on zram are mostly cold pages due to VM's LRU algorithm.
Especially, once init data for application are touched for launching,
they tend to be not accessed any more and finally swapped out. zRAM can
store such cold pages as compressed form but it's pointless to keep in
memory. Better idea is app developers free them directly rather than
remaining them on heap.
This patch tell us last access time of each block of zram via "cat
/sys/kernel/debug/zram/zram0/block_state".
The output is as follows,
300 75.033841 .wh
301 63.806904 s..
302 63.806919 ..h
First column is zram's block index and 3rh one represents symbol (s:
same page w: written page to backing store h: huge page) of the block
state. Second column represents usec time unit of the block was last
accessed. So above example means the 300th block is accessed at
75.033851 second and it was huge so it was written to the backing store.
Admin can leverage this information to catch cold|incompressible pages
of process with *pagemap* once part of heaps are swapped out.
I used the feature a few years ago to find memory hoggers in userspace
to notify them what memory they have wasted without touch for a long
time. With it, they could reduce unnecessary memory space. However, at
that time, I hacked up zram for the feature but now I need the feature
again so I decided it would be better to upstream rather than keeping it
alone. I hope I submit the userspace tool to use the feature soon.
[akpm@linux-foundation.org: fix i386 printk warning]
[minchan@kernel.org: use ktime_get_boottime() instead of sched_clock()]
Link: http://lkml.kernel.org/r/20180420063525.GA253739@rodete-desktop-imager.corp.google.com
[akpm@linux-foundation.org: documentation tweak]
[minchan@kernel.org: fix compile warning]
Link: http://lkml.kernel.org/r/20180508104849.GA8209@rodete-desktop-imager.corp.google.com
[rdunlap@infradead.org: fix printk formats]
Link: http://lkml.kernel.org/r/3652ccb1-96ef-0b0b-05d1-f661d7733dcc@infradead.org
Link: http://lkml.kernel.org/r/20180416090946.63057-5-minchan@kernel.org
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
This patch records last access time of each block of zram so that With
upcoming zram memory tracking, it could help userspace developers to
reduce memory footprint.
Link: http://lkml.kernel.org/r/20180416090946.63057-4-minchan@kernel.org
Mark incompressible pages so that we could investigate who is the owner
of the incompressible pages once the page is swapped out via using
upcoming zram memory tracker feature.
With it, we could prevent such pages to be swapped out by using mlock.
Otherwise we might remove them.
This patch exposes new stat for huge pages via mm_stat.
Link: http://lkml.kernel.org/r/20180416090946.63057-3-minchan@kernel.org
Patch series "zram memory tracking", v5.
memory. As well, it's pointless to store incompressible pages to zram
so better idea is app developers manages them directly like free or
mlock rather than remaining them on heap.
This patch provides a debugfs /sys/kernel/debug/zram/zram0/block_state
to represent each block's state so admin can investigate what memory is
cold|incompressible|same page with using pagemap once the pages are
swapped out.
The output is as follows:
300 75.033841 .wh
301 63.806904 s..
302 63.806919 ..h
This patch (of 4):
ZRAM_ACCESS is used for locking a slot of zram so correct the name. It
is also not a common flag to indicate status of the block so move the
declare position on top of the flag. Lastly, let's move the function to
the top of source code to be able to use it easily without forward
declaration.
Link: http://lkml.kernel.org/r/20180416090946.63057-2-minchan@kernel.org
Merge updates from Andrew Morton:
- a few misc things
- ocfs2 updates
- the v9fs maintainers have been missing for a long time. I've taken
over v9fs patch slinging.
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (116 commits)
mm,oom_reaper: check for MMF_OOM_SKIP before complaining
mm/ksm: fix interaction with THP
mm/memblock.c: cast constant ULLONG_MAX to phys_addr_t
headers: untangle kmemleak.h from mm.h
include/linux/mmdebug.h: make VM_WARN* non-rvals
mm/page_isolation.c: make start_isolate_page_range() fail if already isolated
mm: change return type to vm_fault_t
mm, oom: remove 3% bonus for CAP_SYS_ADMIN processes
mm, page_alloc: wakeup kcompactd even if kswapd cannot free more memory
kernel/fork.c: detect early free of a live mm
mm: make counting of list_lru_one::nr_items lockless
mm/swap_state.c: make bool enable_vma_readahead and swap_vma_readahead() static
block_invalidatepage(): only release page if the full page was invalidated
mm: kernel-doc: add missing parameter descriptions
mm/swap.c: remove @cold parameter description for release_pages()
mm/nommu: remove description of alloc_vm_area
zram: drop max_zpage_size and use zs_huge_class_size()
zsmalloc: introduce zs_huge_class_size()
mm: fix races between swapoff and flush dcache
fs/direct-io.c: minor cleanups in do_blockdev_direct_IO
Remove ZRAM's enforced "huge object" value and use zsmalloc huge-class
watermark instead, which makes more sense.
TEST
- I used a 1G zram device, LZO compression back-end, original
data set size was 444MB. Looking at zsmalloc classes stats the
test ended up to be pretty fair.
BASE ZRAM/ZSMALLOC
zram mm_stat
498978816 191482495 199831552 0 199831552 15634 0
zsmalloc classes
class size almost_full almost_empty obj_allocated obj_used pages_used pages_per_zspage freeable
151 2448 0 0 1240 1240 744 3 0
168 2720 0 0 4200 4200 2800 2 0
190 3072 0 0 10100 10100 7575 3 0
202 3264 0 0 380 380 304 4 0
254 4096 0 0 10620 10620 10620 1 0
Total 7 46 106982 106187 48787 0
PATCHED ZRAM/ZSMALLOC
zram mm_stat
498978816 182579184 194248704 0 194248704 15628 0
zsmalloc classes
202 3264 0 0 7180 7180 5744 4 0
254 4096 0 0 3820 3820 3820 1 0
Total 8 45 106959 106193 47424 0
As we can see, we reduced the number of objects stored in class-4096,
because a huge number of objects which we previously forcibly stored in
class-4096 now stored in non-huge class-3264. This results in lower
memory consumption:
- zsmalloc now uses 47424 physical pages, which is less than 48787 pages
zsmalloc used before.
- objects that we store in class-3264 share zspages. That's why overall
the number of pages that both class-4096 and class-3264 consumed went
down from 10924 to 9564.
[sergey.senozhatsky.work@gmail.com: add pool param to zs_huge_class_size()]
Link: http://lkml.kernel.org/r/20180314081833.1096-3-sergey.senozhatsky@gmail.com
Link: http://lkml.kernel.org/r/20180306070639.7389-3-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
It happens often while I'm preparing a patch for a block driver that
I'm wondering: is a definition of SECTOR_SIZE and/or SECTOR_SHIFT
available for this driver? Do I have to introduce definitions of these
constants before I can use these constants? To avoid this confusion,
move the existing definitions of SECTOR_SIZE and SECTOR_SHIFT into the
<linux/blkdev.h> header file such that these become available for all
block drivers. Make the SECTOR_SIZE definition in the uapi msdos_fs.h
header file conditional to avoid that including that header file after
<linux/blkdev.h> causes the compiler to complain about a SECTOR_SIZE
redefinition.
Note: the SECTOR_SIZE / SECTOR_SHIFT / SECTOR_BITS definitions have
not been removed from uapi header files nor from NAND drivers in
which these constants are used for another purpose than converting
block layer offsets and sizes into a number of sectors.
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Nitin Gupta <ngupta@vflare.org>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
This patch enables write IO to transfer data to backing device. For
that, it implements write_to_bdev function which creates new bio and
chaining with parent bio to make the parent bio asynchrnous.
For rw_page which don't have parent bio, it submit owned bio and handle
IO completion by zram_page_end_io.
Also, this patch defines new flag ZRAM_WB to mark written page for later
read IO.
[xieyisheng1@huawei.com: fix typo in comment]
Link: http://lkml.kernel.org/r/1502707447-6944-2-git-send-email-xieyisheng1@huawei.com
Link: http://lkml.kernel.org/r/1498459987-24562-8-git-send-email-minchan@kernel.org
Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Juneho Choi <juno.choi@lge.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
With backing device, zram needs management of free space of backing
device.
This patch adds bitmap logic to manage free space which is very naive.
However, it would be simple enough as considering uncompressible pages's
frequenty in zram.
Link: http://lkml.kernel.org/r/1498459987-24562-6-git-send-email-minchan@kernel.org
For writeback feature, user should set up backing device before the zram
working.
This patch enables the interface via /sys/block/zramX/backing_dev.
Currently, it supports block device only but it could be enhanced for
file as well.
Link: http://lkml.kernel.org/r/1498459987-24562-5-git-send-email-minchan@kernel.org
It's redundant now. Instead, remove it and use zram structure directly.
Link: http://lkml.kernel.org/r/1492052365-16169-5-git-send-email-minchan@kernel.org
Cc: Hannes Reinecke <hare@suse.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
The idea is that without doing more calculations we extend zero pages to
same element pages for zram. zero page is special case of same element
page with zero element.
1. the test is done under android 7.0
2. startup too many applications circularly
3. sample the zero pages, same pages (none-zero element)
and total pages in function page_zero_filled
the result is listed as below:
ZERO SAME TOTAL
36214 17842 598196
ZERO/TOTAL SAME/TOTAL (ZERO+SAME)/TOTAL ZERO/SAME
AVERAGE 0.060631909 0.024990816 0.085622726 2.663825038
STDEV 0.00674612 0.005887625 0.009707034 2.115881328
MAX 0.069698422 0.030046087 0.094975336 7.56043956
MIN 0.03959586 0.007332205 0.056055193 1.928985507
from the above data, the benefit is about 2.5% and up to 3% of total
swapout pages.
The defect of the patch is that when we recovery a page from non-zero
element the operations are low efficient for partial read.
This patch extends zero_page to same_page so if there is any user to
have monitored zero_pages, he will be surprised if the number is
increased but it's not harmful, I believe.
[minchan@kernel.org: do not free same element pages in zram_meta_free]
Link: http://lkml.kernel.org/r/20170207065741.GA2567@bbox
Link: http://lkml.kernel.org/r/1483692145-75357-1-git-send-email-zhouxianrong@huawei.com
Link: http://lkml.kernel.org/r/1486307804-27903-1-git-send-email-minchan@kernel.org
Signed-off-by: zhouxianrong <zhouxianrong@huawei.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
zram_reset_device() waits for ongoing writepage pages to be completed by
zram->refcount logic. However, it's pointless because before the reset,
we prevent further opening of zram by zram->claim and flush all of
pending IO by fsync_bdev so there should be no pending IO at the
zram_reset_device().
So let's remove that code which is even broken due to the lack of
wake_up elsewhere.
Link: http://lkml.kernel.org/r/1485145031-11661-1-git-send-email-minchan@kernel.org
There is no way to get a string with all the crypto comp algorithms
supported by the crypto comp engine, so we need to maintain our own
backends list. At the same time we additionally need to use
crypto_has_comp() to make sure that the user has requested a compression
algorithm that is recognized by the crypto comp engine. Relying on
/proc/crypto is not an options here, because it does not show
not-yet-inserted compression modules.
Example:
modprobe zram
cat /proc/crypto | grep -i lz4
modprobe lz4
driver : lz4-generic
module : lz4
So the user can't tell exactly if the lz4 is really supported from
/proc/crypto output, unless someone or something has loaded it.
This patch also adds crypto_has_comp() to zcomp_available_show(). We
store all the compression algorithms names in zcomp's `backends' array,
regardless the CONFIG_CRYPTO_FOO configuration, but show only those that
are also supported by crypto engine. This helps user to know the exact
list of compression algorithms that can be used.
Example:
module lz4 is not loaded yet, but is supported by the crypto
engine. /proc/crypto has no information on this module, while
zram's `comp_algorithm' lists it:
cat /sys/block/zram0/comp_algorithm
[lzo] lz4 deflate lz4hc 842
We still use the `backends' array to determine if the requested
compression backend is known to crypto api. This array, however, may not
contain some entries, therefore as the last step we call crypto_has_comp()
function which attempts to insmod the requested compression algorithm to
determine if crypto api supports it. The advantage of this method is that
now we permit the usage of out-of-tree crypto compression modules
(implementing S/W or H/W compression).
[sergey.senozhatsky@gmail.com: zram-use-crypto-api-to-check-alg-availability-v3]
Link: http://lkml.kernel.org/r/20160604024902.11778-4-sergey.senozhatsky@gmail.com
Link: http://lkml.kernel.org/r/20160531122017.2878-5-sergey.senozhatsky@gmail.com
debug_stat sysfs is read-only and represents various debugging data that
zram developers may need. This file is not meant to be used by anyone
else: its content is not documented and will change any time w/o any
notice. Therefore, the output of debug_stat file contains a version
string. To avoid any confusion, we will increase the version number
every time we modify the output.
At the moment this file exports only one value -- the number of
re-compressions, IOW, the number of times compression fast path has
failed. This stat is temporary any will be useful in case if any
per-cpu compression streams regressions will be reported.
Link: http://lkml.kernel.org/r/20160513230834.GB26763@bbox
Link: http://lkml.kernel.org/r/20160511134553.12655-1-sergey.senozhatsky@gmail.com
Remove the internal part of max_comp_streams interface, since we
switched to per-cpu streams. We will keep RW max_comp_streams attr
around, because:
a) we may (silently) switch back to idle compression streams list and
don't want to disturb user space
b) max_comp_streams attr must wait for the next 'lay off cycle'; we
give user space 2 years to adjust before we remove/downgrade the attr,
and there are already several attrs scheduled for removal in 4.11, so
it's too late for max_comp_streams.
This slightly change a user visible behaviour:
- First, reading from max_comp_stream file now will always return the
number of online CPUs.
- Second, writing to max_comp_stream will not take any effect.
Link: http://lkml.kernel.org/r/20160503165546.25201-1-sergey.senozhatsky@gmail.com
`zs_compact_control' accounts the number of migrated objects but it has
a limited lifespan -- we lose it as soon as zs_compaction() returns back
to zram. It worked fine, because (a) zram had it's own counter of
migrated objects and (b) only zram could trigger compaction. However,
this does not work for automatic pool compaction (not issued by zram).
To account objects migrated during auto-compaction (issued by the
shrinker) we need to store this number in zs_pool.
Define a new `struct zs_pool_stats' structure to keep zs_pool's stats
there. It provides only `num_migrated', as of this writing, but it
surely can be extended.
A new zsmalloc zs_pool_stats() symbol exports zs_pool's stats back to
caller.
Use zs_pool_stats() in zram and remove `num_migrated' from zram_stats.
Suggested-by: Minchan Kim <minchan@kernel.org>
[ Original patch from Minchan Kim <minchan@kernel.org> ]
Commit ba6b17d68c8e ("zram: fix umount-reset_store-mount race
condition") introduced bdev->bd_mutex to protect a race between mount
and reset. At that time, we don't have dynamic zram-add/remove feature
so it was okay.
However, as we introduce dynamic device feature, bd_mutex became
trouble.
CPU 0
echo 1 > /sys/block/zram<id>/reset
-> kernfs->s_active(A)
-> zram:reset_store->bd_mutex(B)
CPU 1
echo <id> > /sys/class/zram/zram-remove
->zram:zram_remove: bd_mutex(B)
-> sysfs_remove_group
IOW, AB -> BA deadlock
The reason we are holding bd_mutex for zram_remove is to prevent
any incoming open /dev/zram[0-9]. Otherwise, we could remove zram
others already have opened. But it causes above deadlock problem.
To fix the problem, this patch overrides block_device.open and
it returns -EBUSY if zram asserts he claims zram to reset so any
incoming open will be failed so we don't need to hold bd_mutex
for zram_remove ayn more.
This patch is to prepare for zram-add/remove feature.
[sergey.senozhatsky@gmail.com: simplify reset_store()]
Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Limiting the number of zram devices to 32 (default max_num_devices value)
is confusing, let's drop it. A user with 2TB or 4TB of RAM, for example,
can request as many devices as he can handle.
Now that zsmalloc supports compaction, zram can use it. For the first
step, this patch exports compact knob via sysfs so user can do compaction
via "echo 1 > /sys/block/zram0/compact".
Cc: Gunho Lee <gunho.lee@lge.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Seth Jennings <sjennings@variantweb.net>
Cc: Jerome Marchand <jmarchan@redhat.com>
`struct zram' contains both `struct gendisk' and `struct request_queue'.
the latter can be deleted, because zram->disk carries ->queue pointer, and
->queue carries zram pointer:
create_device()
zram->queue->queuedata = zram
zram->disk->queue = zram->queue
zram->disk->private_data = zram
so zram->queue is not needed, we can access all necessary data anyway.
Admin could reset zram during I/O operation going on so we have used
zram->init_lock as read-side lock in I/O path to prevent sudden zram
meta freeing.
However, the init_lock is really troublesome. We can't do call
zram_meta_alloc under init_lock due to lockdep splat because
zram_rw_page is one of the function under reclaim path and hold it as
read_lock while other places in process context hold it as write_lock.
So, we have used allocation out of the lock to avoid lockdep warn but
it's not good for readability and fainally, I met another lockdep splat
between init_lock and cpu_hotplug from kmem_cache_destroy during working
zsmalloc compaction. :(
Yes, the ideal is to remove horrible init_lock of zram in rw path. This
patch removes it in rw path and instead, add atomic refcount for meta
lifetime management and completion to free meta in process context.
It's important to free meta in process context because some of resource
destruction needs mutex lock, which could be held if we releases the
resource in reclaim context so it's deadlock, again.
As a bonus, we could remove init_done check in rw path because
zram_meta_get will do a role for it, instead.
Cc: Ganesh Mahendran <opensource.ganesh@gmail.com>
In struct zram_table_entry, the element *value* contains obj size and obj
zram flags. Bit 0 to bit (ZRAM_FLAG_SHIFT - 1) represent obj size, and
bit ZRAM_FLAG_SHIFT to the highest bit of unsigned long represent obj
zram_flags. So the first zram flag(ZRAM_ZERO) should be from
ZRAM_FLAG_SHIFT instead of (ZRAM_FLAG_SHIFT + 1).
This patch fixes this cosmetic issue.
Also fix a typo, "page in now accessed" -> "page is now accessed"
Signed-off-by: Mahendran Ganesh <opensource.ganesh@gmail.com>
Acked-by: Weijie Yang <weijie.yang@samsung.com>
Normally, zram user could get maximum memory usage zram consumed via
polling mem_used_total with sysfs in userspace.
But it has a critical problem because user can miss peak memory usage
during update inverval of polling. For avoiding that, user should poll it
with shorter interval(ie, 0.0000000001s) with mlocking to avoid page fault
delay when memory pressure is heavy. It would be troublesome.
This patch adds new knob "mem_used_max" so user could see the maximum
memory usage easily via reading the knob and reset it via "echo 0 >
/sys/block/zram0/mem_used_max".
Reviewed-by: Dan Streetman <ddstreet@ieee.org>
Cc: <juno.choi@lge.com>
Cc: <seungho1.park@lge.com>
Reviewed-by: David Horner <ds2horner@gmail.com>
Since zram has no control feature to limit memory usage, it makes hard to
manage system memrory.
This patch adds new knob "mem_limit" via sysfs to set up the a limit so
that zram could fail allocation once it reaches the limit.
In addition, user could change the limit in runtime so that he could
manage the memory more dynamically.
Initial state is no limit so it doesn't break old behavior.
[akpm@linux-foundation.org: fix typo, per Sergey]
Cc: David Horner <ds2horner@gmail.com>
Since we allocate a temporary buffer in zram_bvec_read to handle partial
page operations in commit 924bd88d703e ("Staging: zram: allow partial
page operations"), our ->failed_reads value may be incorrect as we do
not increase its value when failing to allocate the temporary buffer.
Let's fix this issue and correct the annotation of failed_reads.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Currently, we use a rwlock tb_lock to protect concurrent access to the
whole zram meta table. However, according to the actual access model,
there is only a small chance for upper user to access the same
table[index], so the current lock granularity is too big.
The idea of optimization is to change the lock granularity from whole
meta table to per table entry (table -> table[index]), so that we can
protect concurrent access to the same table[index], meanwhile allow the
maximum concurrency.
With this in mind, several kinds of locks which could be used as a
per-entry lock were tested and compared:
Test environment:
x86-64 Intel Core2 Q8400, system memory 4GB, Ubuntu 12.04,
kernel v3.15.0-rc3 as base, zram with 4 max_comp_streams LZO.
iozone test:
iozone -t 4 -R -r 16K -s 200M -I +Z
(1GB zram with ext4 filesystem, take the average of 10 tests, KB/s)
Test base CAS spinlock rwlock bit_spinlock
Initial write 1381094 1425435 1422860 1423075 1421521
Rewrite 1529479 1641199 1668762 1672855 1654910
Read 8468009 11324979 11305569 11117273 10997202
Re-read 8467476 11260914 11248059 11145336 10906486
Reverse Read 6821393 8106334 8282174 8279195 8109186
Stride read 7191093 8994306 9153982 8961224 9004434
Random read 7156353 8957932 9167098 8980465 8940476
Mixed workload 4172747 5680814 5927825 5489578 5972253
Random write 1483044 1605588 1594329 1600453 1596010
Pwrite 1276644 1303108 1311612 1314228 1300960
Pread 4324337 4632869 4618386 4457870 4500166
To enhance the possibility of access the same table[index] concurrently,
set zram a small disksize(10MB) and let threads run with large loop
count.
fio test:
fio --bs=32k --randrepeat=1 --randseed=100 --refill_buffers
--scramble_buffers=1 --direct=1 --loops=3000 --numjobs=4
--filename=/dev/zram0 --name=seq-write --rw=write --stonewall
--name=seq-read --rw=read --stonewall --name=seq-readwrite
--rw=rw --stonewall --name=rand-readwrite --rw=randrw --stonewall
(10MB zram raw block device, take the average of 10 tests, KB/s)
seq-write 933789 999357 1003298 995961 1001958
seq-read 5634130 6577930 6380861 6243912 6230006
seq-rw 1405687 1638117 1640256 1633903 1634459
rand-rw 1386119 1614664 1617211 1609267 1612471
All the optimization methods show a higher performance than the base,
however, it is hard to say which method is the most appropriate.
On the other hand, zram is mostly used on small embedded system, so we
don't want to increase any memory footprint.
This patch pick the bit_spinlock method, pack object size and page_flag
into an unsigned long table.value, so as to not increase any memory
overhead on both 32-bit and 64-bit system.
On the third hand, even though different kinds of locks have different
performances, we can ignore this difference, because: if zram is used as
zram swapfile, the swap subsystem can prevent concurrent access to the
same swapslot; if zram is used as zram-blk for set up filesystem on it,
the upper filesystem and the page cache also prevent concurrent access
of the same block mostly. So we can ignore the different performances
among locks.
Reviewed-by: Davidlohr Bueso <davidlohr@hp.com>
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
Drop SECTOR_SIZE define, because it's not used.
Cc: Weijie Yang <weijie.yang@samsung.com>
Andrew Morton has recently noted that `struct table' actually represents
table entry and, thus, should be renamed. Rename to `zram_table_entry'.
Add and document `comp_algorithm' device attribute. This attribute allows
to show supported compression and currently selected compression
algorithms:
[lzo] lz4
and change selected compression algorithm:
echo lzo > /sys/block/zram0/comp_algorithm
Existing zram (zcomp) implementation has only one compression stream
(buffer and algorithm private part), so in order to prevent data
corruption only one write (compress operation) can use this compression
stream, forcing all concurrent write operations to wait for stream lock
to be released. This patch changes zcomp to keep a compression streams
list of user-defined size (via sysfs device attr). Each write operation
still exclusively holds compression stream, the difference is that we
can have N write operations (depending on size of streams list)
executing in parallel. See TEST section later in commit message for
performance data.
Introduce struct zcomp_strm_multi and a set of functions to manage
zcomp_strm stream access. zcomp_strm_multi has a list of idle
zcomp_strm structs, spinlock to protect idle list and wait queue, making
it possible to perform parallel compressions.
The following set of functions added:
- zcomp_strm_multi_find()/zcomp_strm_multi_release()
find and release a compression stream, implement required locking
- zcomp_strm_multi_create()/zcomp_strm_multi_destroy()
create and destroy zcomp_strm_multi
zcomp ->strm_find() and ->strm_release() callbacks are set during
initialisation to zcomp_strm_multi_find()/zcomp_strm_multi_release()
correspondingly.
Each time zcomp issues a zcomp_strm_multi_find() call, the following set
of operations performed:
- spin lock strm_lock
- if idle list is not empty, remove zcomp_strm from idle list, spin
unlock and return zcomp stream pointer to caller
- if idle list is empty, current adds itself to wait queue. it will be
awaken by zcomp_strm_multi_release() caller.
zcomp_strm_multi_release():
- add zcomp stream to idle list
- spin unlock, wake up sleeper
Minchan Kim reported that spinlock-based locking scheme has demonstrated
a severe perfomance regression for single compression stream case,
comparing to mutex-based (see https://lkml.org/lkml/2014/2/18/16)
base spinlock mutex
==Initial write ==Initial write ==Initial write
records: 5 records: 5 records: 5
avg: 1642424.35 avg: 699610.40 avg: 1655583.71
std: 39890.95(2.43%) std: 232014.19(33.16%) std: 52293.96
max: 1690170.94 max: 1163473.45 max: 1697164.75
min: 1568669.52 min: 573429.88 min: 1553410.23
==Rewrite ==Rewrite ==Rewrite
avg: 1611775.39 avg: 501406.64 avg: 1684419.11
std: 17144.58(1.06%) std: 15354.41(3.06%) std: 18367.42
max: 1641800.95 max: 531356.78 max: 1706445.84
min: 1593515.27 min: 488817.78 min: 1655335.73
When only one compression stream available, mutex with spin on owner
tends to perform much better than frequent wait_event()/wake_up(). This
is why single stream implemented as a special case with mutex locking.
Introduce and document zram device attribute max_comp_streams. This
attr shows and stores current zcomp's max number of zcomp streams
(max_strm). Extend zcomp's zcomp_create() with `max_strm' parameter.
`max_strm' limits the number of zcomp_strm structs in compression
backend's idle list (max_comp_streams).
max_comp_streams used during initialisation as follows:
-- passing to zcomp_create() max_strm equals to 1 will initialise zcomp
using single compression stream zcomp_strm_single (mutex-based locking).
-- passing to zcomp_create() max_strm greater than 1 will initialise zcomp
using multi compression stream zcomp_strm_multi (spinlock-based locking).
default max_comp_streams value is 1, meaning that zram with single stream
will be initialised.
Later patch will introduce configuration knob to change max_comp_streams
on already initialised and used zcomp.
TEST
iozone -t 3 -R -r 16K -s 60M -I +Z
test base 1 strm (mutex) 3 strm (spinlock)
Initial write 589286.78 583518.39 718011.05
Rewrite 604837.97 596776.38 1515125.72
Random write 584120.11 595714.58 1388850.25
Pwrite 535731.17 541117.38 739295.27
Fwrite 1418083.88 1478612.72 1484927.06
Usage example:
set max_comp_streams to 4
echo 4 > /sys/block/zram0/max_comp_streams
show current max_comp_streams (default value is 1).
cat /sys/block/zram0/max_comp_streams
Do not perform direct LZO compress/decompress calls, initialise
and use zcomp LZO backend (single compression stream) instead.
[akpm@linux-foundation.org: resolve conflicts with zram-delete-zram_init_device-fix.patch]
struct table `count' member is not used.
This is a preparation patch for stats code duplication removal.
1) use atomic64_t for `pages_zero' and `pages_stored' zram stats.
2) `compr_size' and `pages_zero' struct zram_stats members did not
follow the existing device attr naming scheme: zram_stats.ATTR has
ATTR_show() function. rename them:
-- compr_size -> compr_data_size
-- pages_zero -> zero_pages
Minchan Kim's note:
If we really have trouble with atomic stat operation, we could
change it with percpu_counter so that it could solve atomic overhead and
unnecessary memory space by introducing unsigned long instead of 64bit
atomic_t.
Remove `good' and `bad' compressed sub-requests stats. RW request may
cause a number of RW sub-requests. zram used to account `good' compressed
sub-queries (with compressed size less than 50% of original size), `bad'
compressed sub-queries (with compressed size greater that 75% of original
size), leaving sub-requests with compression size between 50% and 75% of
original size not accounted and not reported. zram already accounts each
sub-request's compression size so we can calculate real device compression
ratio.
Introduce init_done() helper function which allows us to drop `init_done'
struct zram member. init_done() uses the fact that ->init_done == 1
equals to ->meta != NULL.
Finally, we separated zram->lock dependency from 32bit stat/ table
handling so there is no reason to use rw_semaphore between read and
write path so this patch removes the lock from read path totally and
changes rw_semaphore with mutex. So, we could do
old:
read-read: OK
read-write: NO
write-write: NO
Now:
read-read: OK
read-write: OK
write-write: NO
The below data proves mixed workload performs well 11 times and there is
also enhance on write-write path because current rw-semaphore doesn't
support SPIN_ON_OWNER. It's side effect but anyway good thing for us.
Write-related tests perform better (from 61% to 1058%) but read path has
good/bad(from -2.22% to 1.45%) but they are all marginal within stddev.
CPU 12
iozone -t -T -l 12 -u 12 -r 16K -s 60M -I +Z -V 0
records: 10 records: 10
avg: 516189.16 avg: 839907.96
std: 22486.53 (4.36%) std: 47902.17 (5.70%)
max: 546970.60 max: 909910.35
min: 481131.54 min: 751148.38
==Rewrite ==Rewrite
avg: 509527.98 avg: 1050156.37
std: 45799.94 (8.99%) std: 40695.44 (3.88%)
max: 611574.27 max: 1111929.26
min: 443679.95 min: 980409.62
==Read ==Read
avg: 4408624.17 avg: 4472546.76
std: 281152.61 (6.38%) std: 163662.78 (3.66%)
max: 4867888.66 max: 4727351.03
min: 4058347.69 min: 4126520.88
==Re-read ==Re-read
avg: 4462147.53 avg: 4363257.75
std: 283546.11 (6.35%) std: 247292.63 (5.67%)
max: 4912894.44 max: 4677241.75
min: 4131386.50 min: 4035235.84
==Reverse Read ==Reverse Read
avg: 4565865.97 avg: 4485818.08
std: 313395.63 (6.86%) std: 248470.10 (5.54%)
max: 5232749.16 max: 4789749.94
min: 4185809.62 min: 3963081.34
==Stride read ==Stride read
avg: 4515981.80 avg: 4418806.01
std: 211192.32 (4.68%) std: 212837.97 (4.82%)
max: 4889287.28 max: 4686967.22
min: 4210362.00 min: 4083041.84
==Random read ==Random read
avg: 4410525.23 avg: 4387093.18
std: 236693.22 (5.37%) std: 235285.23 (5.36%)
max: 4713698.47 max: 4669760.62
min: 4057163.62 min: 3952002.16
==Mixed workload ==Mixed workload
avg: 243234.25 avg: 2818677.27
std: 28505.07 (11.72%) std: 195569.70 (6.94%)
max: 288905.23 max: 3126478.11
min: 212473.16 min: 2484150.69
==Random write ==Random write
avg: 555887.07 avg: 1053057.79
std: 70841.98 (12.74%) std: 35195.36 (3.34%)
max: 683188.28 max: 1096125.73
min: 437299.57 min: 992481.93
==Pwrite ==Pwrite
avg: 501745.93 avg: 810363.09
std: 16373.54 (3.26%) std: 19245.01 (2.37%)
max: 518724.52 max: 833359.70
min: 464208.73 min: 765501.87
==Pread ==Pread
avg: 4539894.60 avg: 4457680.58
std: 197094.66 (4.34%) std: 188965.60 (4.24%)
max: 4877170.38 max: 4689905.53
min: 4226326.03 min: 4095739.72
Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Commit a0c516cbfc74 ("zram: don't grab mutex in zram_slot_free_noity")
introduced free request pending code to avoid scheduling by mutex under
spinlock and it was a mess which made code lenghty and increased
overhead.
Now, we don't need zram->lock any more to free slot so this patch
reverts it and then, tb_lock should protect it.
Currently, the zram table is protected by zram->lock but it's rather
coarse-grained lock and it makes hard for scalibility.
Let's use own rwlock instead of depending on zram->lock. This patch
adds new locking so obviously, it would make slow but this patch is just
prepartion for removing coarse-grained rw_semaphore(ie, zram->lock)
which is hurdle about zram scalability.
Final patch in this patchset series will remove the lock from read-path
and change rw_semaphore with mutex in write path. With bonus, we could
drop pending slot free mess in next patch.
Some of fields in zram->stats are protected by zram->lock which is
rather coarse-grained so let's use atomic operation without explict
locking.
This patch is ready for removing dependency of zram->lock in read path
which is very coarse-grained rw_semaphore. Of course, this patch adds
new atomic operation so it might make slow but my 12CPU test couldn't
spot any regression. All gain/lose is marginal within stddev.
records: 50 records: 50
avg: 412875.17 avg: 415638.23
std: 38543.12 (9.34%) std: 36601.11 (8.81%)
max: 521262.03 max: 502976.72
min: 343263.13 min: 351389.12
==Rewrite ==Rewrite
avg: 416640.34 avg: 397914.33
std: 60798.92 (14.59%) std: 46150.42 (11.60%)
max: 543057.07 max: 522669.17
min: 304071.67 min: 316588.77
==Read ==Read
avg: 4147338.63 avg: 4070736.51
std: 179333.25 (4.32%) std: 223499.89 (5.49%)
max: 4459295.28 max: 4539514.44
min: 3753057.53 min: 3444686.31
==Re-read ==Re-read
avg: 4096706.71 avg: 4117218.57
std: 229735.04 (5.61%) std: 171676.25 (4.17%)
max: 4430012.09 max: 4459263.94
min: 2987217.80 min: 3666904.28
avg: 4062763.83 avg: 4078508.32
std: 186208.46 (4.58%) std: 172684.34 (4.23%)
max: 4401358.78 max: 4424757.22
min: 3381625.00 min: 3679359.94
avg: 4094933.49 avg: 4082170.22
std: 185710.52 (4.54%) std: 196346.68 (4.81%)
max: 4478241.25 max: 4460060.97
min: 3732593.23 min: 3584125.78
avg: 4031070.04 avg: 4074847.49
std: 192065.51 (4.76%) std: 206911.33 (5.08%)
max: 4356931.16 max: 4399442.56
min: 3481619.62 min: 3548372.44
avg: 149925.73 avg: 149675.54
std: 7701.26 (5.14%) std: 6902.09 (4.61%)
max: 191301.56 max: 175162.05
min: 133566.28 min: 137762.87
avg: 404050.11 avg: 393021.47
std: 58887.57 (14.57%) std: 42813.70 (10.89%)
max: 601798.09 max: 524533.43
min: 325176.99 min: 313255.34
==Pwrite ==Pwrite
avg: 411217.70 avg: 411237.96
std: 43114.99 (10.48%) std: 33136.29 (8.06%)
max: 530766.79 max: 471899.76
min: 320786.84 min: 317906.94
==Pread ==Pread
avg: 4154908.65 avg: 4087121.92
std: 151272.08 (3.64%) std: 219505.04 (5.37%)
max: 4459478.12 max: 4435857.38
min: 3730512.41 min: 3101101.67
Add my copyright to the zram source code which I maintain.
Remove the old private compcache project address so upcoming patches
should be sent to LKML because we Linux kernel community will take care.
Zram has lived in staging for a LONG LONG time and have been
fixed/improved by many contributors so code is clean and stable now. Of
course, there are lots of product using zram in real practice.
The major TV companys have used zram as swap since two years ago and
recently our production team released android smart phone with zram
which is used as swap, too and recently Android Kitkat start to use zram
for small memory smart phone. And there was a report Google released
their ChromeOS with zram, too and cyanogenmod have been used zram long
time ago. And I heard some disto have used zram block device for tmpfs.
In addition, I saw many report from many other peoples. For example,
Lubuntu start to use it.
The benefit of zram is very clear. With my experience, one of the
benefit was to remove jitter of video application with backgroud memory
pressure. It would be effect of efficient memory usage by compression
but more issue is whether swap is there or not in the system. Recent
mobile platforms have used JAVA so there are many anonymous pages. But
embedded system normally are reluctant to use eMMC or SDCard as swap
because there is wear-leveling and latency issues so if we do not use
swap, it means we can't reclaim anoymous pages and at last, we could
encounter OOM kill. :(
Although we have real storage as swap, it was a problem, too. Because
it sometime ends up making system very unresponsible caused by slow swap
storage performance.
Quote from Luigi on Google
"Since Chrome OS was mentioned: the main reason why we don't use swap
to a disk (rotating or SSD) is because it doesn't degrade gracefully
and leads to a bad interactive experience. Generally we prefer to
manage RAM at a higher level, by transparently killing and restarting
processes. But we noticed that zram is fast enough to be competitive
with the latter, and it lets us make more efficient use of the
available RAM. " and he announced.
http://www.spinics.net/lists/linux-mm/msg57717.html
Other uses case is to use zram for block device. Zram is block device
so anyone can format the block device and mount on it so some guys on
the internet start zram as /var/tmp.
http://forums.gentoo.org/viewtopic-t-838198-start-0.html
Let's promote zram and enhance/maintain it instead of removing.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Nitin Gupta <ngupta@vflare.org>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Seth Jennings <sjenning@linux.vnet.ibm.com>
