path: root/drivers/block
2011-06-04Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: block: Use hlist_entry() for io_context.cic_list.first cfq-iosched: Remove bogus check in queue_fail path xen/blkback: potential null dereference in error handling xen/blkback: don't call vbd_size() if bd_disk is NULL block: blkdev_get() should access ->bd_disk only after success CFQ: Fix typo and remove unnecessary semicolon block: remove unwanted semicolons Revert "block: Remove extra discard_alignment from hd_struct." nbd: adjust 'max_part' according to part_shift nbd: limit module parameters to a sane value nbd: pass MSG_* flags to kernel_recvmsg() block: improve the bio_add_page() and bio_add_pc_page() descriptions
2011-06-02block: fix mismerge of the DISK_EVENT_MEDIA_CHANGE removalLinus Torvalds
Jens' back-merge commit 698567f3fa79 ("Merge commit 'v2.6.39' into for-2.6.40/core") was incorrectly done, and re-introduced the DISK_EVENT_MEDIA_CHANGE lines that had been removed earlier in commits - 9fd097b14918 ("block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers") - 7eec77a1816a ("ide: unexport DISK_EVENT_MEDIA_CHANGE for ide-gd and ide-cd") because of conflicts with the "g->flags" updates near-by by commit d4dc210f69bc ("block: don't block events on excl write for non-optical devices") As a result, we re-introduced the hanging behavior due to infinite disk media change reports. Tssk, tssk, people! Don't do back-merges at all, and *definitely* don't do them to hide merge conflicts from me - especially as I'm likely better at merging them than you are, since I do so many merges. Reported-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-01xen/blkback: potential null dereference in error handlingDan Carpenter
blkbk->pending_pages can be NULL here so I added a check for it. Signed-off-by: Dan Carpenter <error27@gmail.com> [v1: Redid the loop a bit] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-01xen/blkback: don't call vbd_size() if bd_disk is NULLLaszlo Ersek
...because vbd_size() dereferences bd_disk if bd_part is NULL. Signed-off-by: Laszlo Ersek<lersek@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-30drivers, block: virtio_blk: Replace cryptic number with the macroLiu Yuan
It is easier to figure out the context by reading SCSI_SENSE_BUFFERSIZE instead of plain '96'. Signed-off-by: Liu Yuan <tailai.ly@taobao.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-30virtio_blk: allow re-reading config space at runtimeChristoph Hellwig
Wire up the virtio_driver config_changed method to get notified about config changes raised by the host. For now we just re-read the device size to support online resizing of devices, but once we add more attributes that might be changeable they could be added as well. Note that the config_changed method is called from irq context, so we'll have to use the workqueue infrastructure to provide us a proper user context for our changes. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-29Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param x86 idle: deprecate "no-hlt" cmdline param x86 idle APM: deprecate CONFIG_APM_CPU_IDLE x86 idle floppy: deprecate disable_hlt() x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it x86 idle: clarify AMD erratum 400 workaround idle governor: Avoid lock acquisition to read pm_qos before entering idle cpuidle: menu: fixed wrapping timers at 4.294 seconds
2011-05-29x86 idle floppy: deprecate disable_hlt()Len Brown
Plan to remove floppy_disable_hlt in 2012, an ancient workaround with comments that it should be removed. This allows us to remove clutter and a run-time branch from the idle code. WARN_ONCE() on invocation until it is removed. cc: x86@kernel.org cc: stable@kernel.org # .39.x Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-28nbd: adjust 'max_part' according to part_shiftNamhyung Kim
The 'max_part' parameter determines how many partitions are supported on each nbd device. However the actual number can be changed to the power of 2 minus 1 form during the module initialization as alloc_disk() is called with (1 << part_shift) for some reason. So adjust 'max_part' also at least for consistency with loop and brd. It is exported via sysfs already, and a user should check this value after module loading if [s]he wants to use that number correctly (i.e. fdisk or something). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: Paul Clements <Paul.Clements@steeleye.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-28nbd: limit module parameters to a sane valueNamhyung Kim
The 'max_part' parameter controls the number of maximum partition a nbd device can have. However if a user specifies very large value it would exceed the limitation of device minor number and can cause a kernel oops (or, at least, produce invalid device nodes in some cases). In addition, specifying large 'nbds_max' value causes same problem for the same reason. On my desktop, following command results to the kernel bug: $ sudo modprobe nbd max_part=100000 kernel BUG at /media/Linux_Data/project/linux/fs/sysfs/group.c:65! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/devices/virtual/block/nbd4/range CPU 1 Modules linked in: nbd(+) bridge stp llc kvm_intel kvm asus_atk0110 sg sr_mod cdrom Pid: 2522, comm: modprobe Tainted: G W 2.6.39-leonard+ #159 System manufacturer System Product Name/P5G41TD-M PRO RIP: 0010:[<ffffffff8115aa08>] [<ffffffff8115aa08>] internal_create_group+0x2f/0x166 RSP: 0018:ffff8801009f1de8 EFLAGS: 00010246 RAX: 00000000ffffffef RBX: ffff880103920478 RCX: 00000000000a7bd3 RDX: ffffffff81a2dbe0 RSI: 0000000000000000 RDI: ffff880103920478 RBP: ffff8801009f1e38 R08: ffff880103920468 R09: ffff880103920478 R10: ffff8801009f1de8 R11: ffff88011eccbb68 R12: ffffffff81a2dbe0 R13: ffff880103920468 R14: 0000000000000000 R15: ffff880103920400 FS: 00007f3c49de9700(0000) GS:ffff88011f800000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f3b7fe7c000 CR3: 00000000cd58d000 CR4: 00000000000406e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process modprobe (pid: 2522, threadinfo ffff8801009f0000, task ffff8801009a93a0) Stack: ffff8801009f1e58 ffffffff812e8f6e ffff8801009f1e58 ffffffff812e7a80 ffff880000000010 ffff880103920400 ffff8801002fd0c0 ffff880103920468 0000000000000011 ffff880103920400 ffff8801009f1e48 ffffffff8115ab6a Call Trace: [<ffffffff812e8f6e>] ? device_add+0x4f1/0x5e4 [<ffffffff812e7a80>] ? dev_set_name+0x41/0x43 [<ffffffff8115ab6a>] sysfs_create_group+0x13/0x15 [<ffffffff810b857e>] blk_trace_init_sysfs+0x14/0x16 [<ffffffff811ee58b>] blk_register_queue+0x4c/0xfd [<ffffffff811f3bdf>] add_disk+0xe4/0x29c [<ffffffffa007e2ab>] nbd_init+0x2ab/0x30d [nbd] [<ffffffffa007e000>] ? 0xffffffffa007dfff [<ffffffff8100020f>] do_one_initcall+0x7f/0x13e [<ffffffff8107ab0a>] sys_init_module+0xa1/0x1e3 [<ffffffff814f3542>] system_call_fastpath+0x16/0x1b Code: 41 57 41 56 41 55 41 54 53 48 83 ec 28 0f 1f 44 00 00 48 89 fb 41 89 f6 49 89 d4 48 85 ff 74 0b 85 f6 75 0b 48 83 7f 30 00 75 14 <0f> 0b eb fe b9 ea ff ff ff 48 83 7f 30 00 0f 84 09 01 00 00 49 RIP [<ffffffff8115aa08>] internal_create_group+0x2f/0x166 RSP <ffff8801009f1de8> ---[ end trace 753285ffbf72c57c ]--- Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: Paul Clements <Paul.Clements@steeleye.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-28nbd: pass MSG_* flags to kernel_recvmsg()Namhyung Kim
Unlike kernel_sendmsg(), kernel_recvmsg() requires passing flags explicitly via last parameter instead of struct msghdr.msg_flags. Therefore calls to sock_xmit(lo, 0, ..., MSG_WAITALL) have not been processed properly by tcp layer wrt. the flag. Fix it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Paul Clements <Paul.Clements@steeleye.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-27loop: export module parametersNamhyung Kim
Export 'max_loop' and 'max_part' parameters to sysfs so user can know that how many devices are allowed and how many partitions are supported. If 'max_loop' is 0, there is no restriction on the number of loop devices. User can create/use the devices as many as minor numbers available. If 'max_part' is 0, it means simply the device doesn't support partitioning. Also note that 'max_part' can be adjusted to power of 2 minus 1 form if needed. User should check this value after the module loading if he/she want to use that number correctly (i.e. fdisk, mknod, etc.). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-26brd: export module parametersNamhyung Kim
Export 'rd_nr', 'rd_size' and 'max_part' parameters to sysfs so user can know that how many devices are allowed, how big each device is and how many partitions are supported. If 'max_part' is 0, it means simply the device doesn't support partitioning. Also note that 'max_part' can be adjusted to power of 2 minus 1 form if needed. User should check this value after the module loading if he/she want to use that number correctly (i.e. fdisk, mknod, etc.). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-26brd: fix comment on initial device creationNamhyung Kim
If 'rd_nr' param was not specified, 16 (can be adjusted via CONFIG_BLK_DEV_RAM_COUNT) devices would be created by default but comment said 1. Fix it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-26brd: handle on-demand devices correctlyNamhyung Kim
When finding or allocating a ram disk device, brd_probe() did not take partition numbers into account so that it can result to a different device. Consider following example (I set CONFIG_BLK_DEV_RAM_COUNT=4 for simplicity) : $ sudo modprobe brd max_part=15 $ ls -l /dev/ram* brw-rw---- 1 root disk 1, 0 2011-05-25 15:41 /dev/ram0 brw-rw---- 1 root disk 1, 16 2011-05-25 15:41 /dev/ram1 brw-rw---- 1 root disk 1, 32 2011-05-25 15:41 /dev/ram2 brw-rw---- 1 root disk 1, 48 2011-05-25 15:41 /dev/ram3 $ sudo mknod /dev/ram4 b 1 64 $ sudo dd if=/dev/zero of=/dev/ram4 bs=4k count=256 256+0 records in 256+0 records out 1048576 bytes (1.0 MB) copied, 0.00215578 s, 486 MB/s namhyung@leonhard:linux$ ls -l /dev/ram* brw-rw---- 1 root disk 1, 0 2011-05-25 15:41 /dev/ram0 brw-rw---- 1 root disk 1, 16 2011-05-25 15:41 /dev/ram1 brw-rw---- 1 root disk 1, 32 2011-05-25 15:41 /dev/ram2 brw-rw---- 1 root disk 1, 48 2011-05-25 15:41 /dev/ram3 brw-r--r-- 1 root root 1, 64 2011-05-25 15:45 /dev/ram4 brw-rw---- 1 root disk 1, 1024 2011-05-25 15:44 /dev/ram64 After this patch, /dev/ram4 - instead of /dev/ram64 - was accessed correctly. In addition, 'range' passed to blk_register_region() should include all range of dev_t that RAMDISK_MAJOR can address. It does not need to be limited by partition numbers unless 'rd_nr' param was specified. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-26brd: limit 'max_part' module param to DISK_MAX_PARTSNamhyung Kim
The 'max_part' parameter controls the number of maximum partition a brd device can have. However if a user specifies very large value it would exceed the limitation of device minor number and can cause a kernel panic (or, at least, produce invalid device nodes in some cases). On my desktop system, following command kills the kernel. On qemu, it triggers similar oops but the kernel was alive: $ sudo modprobe brd max_part=100000 BUG: unable to handle kernel NULL pointer dereference at 0000000000000058 IP: [<ffffffff81110a9a>] sysfs_create_dir+0x2d/0xae PGD 7af1067 PUD 7b19067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: CPU 0 Modules linked in: brd(+) Pid: 44, comm: insmod Tainted: G W 2.6.39-qemu+ #158 Bochs Bochs RIP: 0010:[<ffffffff81110a9a>] [<ffffffff81110a9a>] sysfs_create_dir+0x2d/0xae RSP: 0018:ffff880007b15d78 EFLAGS: 00000286 RAX: ffff880007b05478 RBX: ffff880007a52760 RCX: ffff880007b15dc8 RDX: ffff880007a4f900 RSI: ffff880007b15e48 RDI: ffff880007a52760 RBP: ffff880007b15da8 R08: 0000000000000002 R09: 0000000000000000 R10: ffff880007b15e48 R11: ffff880007b05478 R12: 0000000000000000 R13: ffff880007b05478 R14: 0000000000400920 R15: 0000000000000063 FS: 0000000002160880(0063) GS:ffff880007c00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000058 CR3: 0000000007b1c000 CR4: 00000000000006b0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 0000000000000000 DR7: 0000000000000000 Process insmod (pid: 44, threadinfo ffff880007b14000, task ffff880007acb980) Stack: ffff880007b15dc8 ffff880007b05478 ffff880007b15da8 00000000fffffffe ffff880007a52760 ffff880007b05478 ffff880007b15de8 ffffffff81143c0a 0000000000400920 ffff880007a52760 ffff880007b05478 0000000000000000 Call Trace: [<ffffffff81143c0a>] kobject_add_internal+0xdf/0x1a0 [<ffffffff81143da1>] kobject_add_varg+0x41/0x50 [<ffffffff81143e6b>] kobject_add+0x64/0x66 [<ffffffff8113bbe7>] blk_register_queue+0x5f/0xb8 [<ffffffff81140f72>] add_disk+0xdf/0x289 [<ffffffffa00040df>] brd_init+0xdf/0x1aa [brd] [<ffffffffa0004000>] ? 0xffffffffa0003fff [<ffffffffa0004000>] ? 0xffffffffa0003fff [<ffffffff8100020a>] do_one_initcall+0x7a/0x12e [<ffffffff8108516c>] sys_init_module+0x9c/0x1dc [<ffffffff812ff4bb>] system_call_fastpath+0x16/0x1b Code: 89 e5 41 55 41 54 53 48 89 fb 48 83 ec 18 48 85 ff 75 04 0f 0b eb fe 48 8b 47 18 49 c7 c4 70 1e 4d 81 48 85 c0 74 04 4c 8b 60 30 8b 44 24 58 45 31 ed 0f b6 c4 85 c0 74 0d 48 8b 43 28 48 89 RIP [<ffffffff81110a9a>] sysfs_create_dir+0x2d/0xae RSP <ffff880007b15d78> CR2: 0000000000000058 ---[ end trace aebb1175ce1f6739 ]--- Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-26brd: get rid of unused members from struct brd_deviceNamhyung Kim
brd_refcnt, brd_offset, brd_sizelimit and brd_blocksize in struct brd_device seem to be copied from struct loop_device but they're not used anywhere. Let get rid of them. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (23 commits) ceph: fix cap flush race reentrancy libceph: subscribe to osdmap when cluster is full libceph: handle new osdmap down/state change encoding rbd: handle online resize of underlying rbd image ceph: avoid inode lookup on nfs fh reconnect ceph: use LOOKUPINO to make unconnected nfs fh more reliable rbd: use snprintf for disk->disk_name rbd: cleanup: make kfree match kmalloc rbd: warn on update_snaps failure on notify ceph: check return value for start_request in writepages ceph: remove useless check libceph: add missing breaks in addr_set_port libceph: fix TAG_WAIT case ceph: fix broken comparison in readdir loop libceph: fix osdmap timestamp assignment ceph: fix rare potential cap leak libceph: use snprintf for unknown addrs libceph: use snprintf for formatting object name ceph: use snprintf for dirstat content libceph: fix uninitialized value when no get_authorizer method is set ...
2011-05-25Merge branch 'for-2.6.40/drivers' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.40/drivers' of git://git.kernel.dk/linux-2.6-block: (110 commits) loop: handle on-demand devices correctly loop: limit 'max_part' module param to DISK_MAX_PARTS drbd: fix warning drbd: fix warning drbd: Fix spelling drbd: fix schedule in atomic drbd: Take a more conservative approach when deciding max_bio_size drbd: Fixed state transitions after async outdate-peer-handler returned drbd: Disallow the peer_disk_state to be D_OUTDATED while connected drbd: Fix for the connection problems on high latency links drbd: fix potential activity log refcount imbalance in error path drbd: Only downgrade the disk state in case of disk failures drbd: fix disconnect/reconnect loop, if ping-timeout == ping-int drbd: fix potential distributed deadlock lru_cache.h: fix comments referring to ts_ instead of lc_ drbd: Fix for application IO with the on-io-error=pass-on policy xen/p2m: Add EXPORT_SYMBOL_GPL to the M2P override functions. xen/p2m/m2p/gnttab: Support GNTMAP_host_map in the M2P override. xen/blkback: don't fail empty barrier requests xen/blkback: fix xenbus_transaction_start() hang caused by double xenbus_transaction_end() ...
2011-05-25Merge branch 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-block: (40 commits) cfq-iosched: free cic_index if cfqd allocation fails cfq-iosched: remove unused 'group_changed' in cfq_service_tree_add() cfq-iosched: reduce bit operations in cfq_choose_req() cfq-iosched: algebraic simplification in cfq_prio_to_maxrq() blk-cgroup: Initialize ioc->cgroup_changed at ioc creation time block: move bd_set_size() above rescan_partitions() in __blkdev_get() block: call elv_bio_merged() when merged cfq-iosched: Make IO merge related stats per cpu cfq-iosched: Fix a memory leak of per cpu stats for root group backing-dev: Kill set but not used var in bdi_debug_stats_show() block: get rid of on-stack plugging debug checks blk-throttle: Make no throttling rule group processing lockless blk-cgroup: Make cgroup stat reset path blkg->lock free for dispatch stats blk-cgroup: Make 64bit per cpu stats safe on 32bit arch blk-throttle: Make dispatch stats per cpu blk-throttle: Free up a group only after one rcu grace period blk-throttle: Use helper function to add root throtl group to lists blk-throttle: Introduce a helper function to fill in device details blk-throttle: Dynamically allocate root group blk-cgroup: Allow sleeping while dynamically allocating a group ...
2011-05-24rbd: handle online resize of underlying rbd imageSage Weil
If we get a notification that the image header has changed, check for a change in the image size. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-24rbd: use snprintf for disk->disk_nameSage Weil
2011-05-24rbd: cleanup: make kfree match kmallocSage Weil
2011-05-24loop: handle on-demand devices correctlyNamhyung Kim
When finding or allocating a loop device, loop_probe() did not take partition numbers into account so that it can result to a different device. Consider following example: $ sudo modprobe loop max_part=15 $ ls -l /dev/loop* brw-rw---- 1 root disk 7, 0 2011-05-24 22:16 /dev/loop0 brw-rw---- 1 root disk 7, 16 2011-05-24 22:16 /dev/loop1 brw-rw---- 1 root disk 7, 32 2011-05-24 22:16 /dev/loop2 brw-rw---- 1 root disk 7, 48 2011-05-24 22:16 /dev/loop3 brw-rw---- 1 root disk 7, 64 2011-05-24 22:16 /dev/loop4 brw-rw---- 1 root disk 7, 80 2011-05-24 22:16 /dev/loop5 brw-rw---- 1 root disk 7, 96 2011-05-24 22:16 /dev/loop6 brw-rw---- 1 root disk 7, 112 2011-05-24 22:16 /dev/loop7 $ sudo mknod /dev/loop8 b 7 128 $ sudo losetup /dev/loop8 ~/temp/disk-with-3-parts.img $ sudo losetup -a /dev/loop128: [0805]:278201 (/home/namhyung/temp/disk-with-3-parts.img) $ ls -l /dev/loop* brw-rw---- 1 root disk 7, 0 2011-05-24 22:16 /dev/loop0 brw-rw---- 1 root disk 7, 16 2011-05-24 22:16 /dev/loop1 brw-rw---- 1 root disk 7, 2048 2011-05-24 22:18 /dev/loop128 brw-rw---- 1 root disk 7, 2049 2011-05-24 22:18 /dev/loop128p1 brw-rw---- 1 root disk 7, 2050 2011-05-24 22:18 /dev/loop128p2 brw-rw---- 1 root disk 7, 2051 2011-05-24 22:18 /dev/loop128p3 brw-rw---- 1 root disk 7, 32 2011-05-24 22:16 /dev/loop2 brw-rw---- 1 root disk 7, 48 2011-05-24 22:16 /dev/loop3 brw-rw---- 1 root disk 7, 64 2011-05-24 22:16 /dev/loop4 brw-rw---- 1 root disk 7, 80 2011-05-24 22:16 /dev/loop5 brw-rw---- 1 root disk 7, 96 2011-05-24 22:16 /dev/loop6 brw-rw---- 1 root disk 7, 112 2011-05-24 22:16 /dev/loop7 brw-r--r-- 1 root root 7, 128 2011-05-24 22:17 /dev/loop8 After this patch, /dev/loop8 - instead of /dev/loop128 - was accessed correctly. In addition, 'range' passed to blk_register_region() should include all range of dev_t that LOOP_MAJOR can address. It does not need to be limited by partition numbers unless 'max_loop' param was specified. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-24loop: limit 'max_part' module param to DISK_MAX_PARTSNamhyung Kim
The 'max_part' parameter controls the number of maximum partition a loop block device can have. However if a user specifies very large value it would exceed the limitation of device minor number and can cause a kernel panic (or, at least, produce invalid device nodes in some cases). On my desktop system, following command kills the kernel. On qemu, it triggers similar oops but the kernel was alive: $ sudo modprobe loop max_part0000 ------------[ cut here ]------------ kernel BUG at /media/Linux_Data/project/linux/fs/sysfs/group.c:65! invalid opcode: 0000 [#1] SMP last sysfs file: CPU 0 Modules linked in: loop(+) Pid: 43, comm: insmod Tainted: G W 2.6.39-qemu+ #155 Bochs Bochs RIP: 0010:[<ffffffff8113ce61>] [<ffffffff8113ce61>] internal_create_group= +0x2a/0x170 RSP: 0018:ffff880007b3fde8 EFLAGS: 00000246 RAX: 00000000ffffffef RBX: ffff880007b3d878 RCX: 00000000000007b4 RDX: ffffffff8152da50 RSI: 0000000000000000 RDI: ffff880007b3d878 RBP: ffff880007b3fe38 R08: ffff880007b3fde8 R09: 0000000000000000 R10: ffff88000783b4a8 R11: ffff880007b3d878 R12: ffffffff8152da50 R13: ffff880007b3d868 R14: 0000000000000000 R15: ffff880007b3d800 FS: 0000000002137880(0063) GS:ffff880007c00000(0000) knlGS:00000000000000= 00 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000422680 CR3: 0000000007b50000 CR4: 00000000000006b0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 0000000000000000 DR7: 0000000000000000 Process insmod (pid: 43, threadinfo ffff880007b3e000, task ffff880007afb9c= 0) Stack: ffff880007b3fe58 ffffffff811e66dd ffff880007b3fe58 ffffffff811e570b 0000000000000010 ffff880007b3d800 ffff880007a7b390 ffff880007b3d868 0000000000400920 ffff880007b3d800 ffff880007b3fe48 ffffffff8113cfc8 Call Trace: [<ffffffff811e66dd>] ? device_add+0x4bc/0x5af [<ffffffff811e570b>] ? dev_set_name+0x3c/0x3e [<ffffffff8113cfc8>] sysfs_create_group+0xe/0x12 [<ffffffff810b420e>] blk_trace_init_sysfs+0x14/0x16 [<ffffffff8116a090>] blk_register_queue+0x47/0xf7 [<ffffffff8116f527>] add_disk+0xdf/0x290 [<ffffffffa00060eb>] loop_init+0xeb/0x1b8 [loop] [<ffffffffa0006000>] ? 0xffffffffa0005fff [<ffffffff8100020a>] do_one_initcall+0x7a/0x12e [<ffffffff81096804>] sys_init_module+0x9c/0x1e0 [<ffffffff813329bb>] system_call_fastpath+0x16/0x1b Code: c3 55 48 89 e5 41 57 41 56 41 89 f6 41 55 41 54 49 89 d4 53 48 89 fb= 48 83 ec 28 48 85 ff 74 0b 85 f6 75 0b 48 83 7f 30 00 75 14 <0f> 0b eb fe = 48 83 7f 30 00 b9 ea ff ff ff 0f 84 18 01 00 00 49 RIP [<ffffffff8113ce61>] internal_create_group+0x2a/0x170 RSP <ffff880007b3fde8> ---[ end trace a123eb592043acad ]--- Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-24drbd: fix warningAndrew Morton
In file included from drivers/block/drbd/drbd_main.c:54: drivers/block/drbd/drbd_int.h:1190: warning: parameter has incomplete type Forward declarations of enums do not work. Fix it unpleasantly by moving the prototype. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Lars Ellenberg <drbd-dev@lists.linbit.com> Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2011-05-24drbd: fix warningPhilipp Reisner
2011-05-24drbd: Fix spellingBart Van Assche
Found these with the help of ispell -l. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
2011-05-24drbd: fix schedule in atomicLars Ellenberg
An administrative detach used to request a state change directly to D_DISKLESS, first suspending IO to avoid the last put_ldev() occuring from an endio handler, potentially in irq context. This is not enough on the receiving side (typically secondary), we may miss some peer_req on the way to local disk, which then may do the last put_ldev() from their drbd_peer_request_endio(). This patch makes the detach always go through the intermediate D_FAILED state. We may consider to rename it D_DETACHING. Alternative approach would be to create yet an other work item to be scheduled on the worker, do the destructor work from there, and get the timing right. manually picked commit 564040f from the drbd 8.4 branch. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-05-24drbd: Take a more conservative approach when deciding max_bio_sizePhilipp Reisner
The old (optimistic) implementation could shrink the bio size on an primary device. Shrinking the bio size on a primary device is bad. Since there we might get BIOs with the old (bigger) size shortly after we published the new size. The new implementation is more conservative, and eventually increases the max_bio_size on a primary device (which is valid). It does so, when it knows the local limit AND the remote limit. We cache the last seen max_bio_size of the peer in the meta data, and rely on that, to make the operation of single nodes more efficient. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-05-24drbd: Fixed state transitions after async outdate-peer-handler returnedPhilipp Reisner
2011-05-24drbd: Disallow the peer_disk_state to be D_OUTDATED while connectedPhilipp Reisner
2011-05-24drbd: Fix for the connection problems on high latency linksPhilipp Reisner
It seems that the real cause of all the issues where that we did not noticed in drbd_try_connect() when the other guy closes one socket if the round trip time gets higher than 100ms. There were that 100ms hard coded! Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-05-24drbd: fix potential activity log refcount imbalance in error pathLars Ellenberg
It is no longer sufficient to trigger on local WRITE, we need to check on (rq_state & RQ_IN_ACT_LOG) before calling drbd_al_complete_io also in the error path. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-05-24drbd: Only downgrade the disk state in case of disk failuresPhilipp Reisner
2011-05-24drbd: fix disconnect/reconnect loop, if ping-timeout == ping-intLars Ellenberg
If there is no replication traffic within the idle timeout (ping-int seconds), DRBD will send a P_PING, and adjust the timeout to ping-timeout. If there is no P_PING_ACK received within this ping-timeout, DRBD finally drops the connection, and tries to re-establish it. To decide which timeout was active, we compared the current timeout with the ping-timeout, and dropped the connection, if that was the case. By default, ping-int is 10 seconds, ping-timeout is 500 ms. Unfortunately, if you configure ping-timeout to be the same as ping-int, expiry of the idle-timeout had been mistaken for a missing ping ack, and caused an immediate reconnection attempt. Fix: Allow both timeouts to be equal, use a local variable to store which timeout is active. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-05-24drbd: fix potential distributed deadlockLars Ellenberg
We limit ourselves to a configurable maximum number of pages used as temporary bio pages. If the configured "max_buffers" is not big enough to match the bandwidth of the respective deployment, a distributed deadlock could be triggered by e.g. fast online verify and heavy application IO. TCP connections would block on congestion, because both receivers would wait on pages to become available. Fortunately the respective senders in this case would be able to give back some pages already. So do that. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-05-24drbd: Fix for application IO with the on-io-error=pass-on policyPhilipp Reisner
In case a write failes on the local disk, go into D_INCONSISTENT disk state. That causes future reads of that block to be shipped to the peer. Read retry remote was already in place. Actually the documentation needs to get fixed now. Since the application is still shielded from the error. (as long as we have only a single disk failing) The difference to detach is that we keep the disk. And therefore might keep all the other, still working sectors up to date. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20Merge commit 'v2.6.39' into for-2.6.40/coreJens Axboe
Since for-2.6.40/core was forked off the 2.6.39 devel tree, we've had churn in the core area that makes it difficult to handle patches for eg cfq or blk-throttle. Instead of requiring that they be based in older versions with bugs that have been fixed later in the rc cycle, merge in 2.6.39 final. Also fixes up conflicts in the below files. Conflicts: drivers/block/paride/pcd.c drivers/cdrom/viocd.c drivers/ide/ide-cd.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-19rbd: warn on update_snaps failure on notifySage Weil
2011-05-19Merge branches 'for-jens/xen-backend-fixes' and 'for-jens/xen-blkback-v3.3' ↵Jens Axboe
of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen into for-2.6.40/drivers
2011-05-18xen/blkback: don't fail empty barrier requestsJan Beulich
The sector number on empty barrier requests may (will?) be -1, which, given that it's being treated as unsigned 64-bit quantity, will almost always exceed the actual (virtual) disk's size. Inspired by Konrad's "When writting barriers set the sector number to zero...". While at it also add overflow checking to the math in vbd_translate(). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blocklatestLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: don't delay blk_run_queue_async scsi: remove performance regression due to async queue run blk-throttle: Use task_subsys_state() to determine a task's blkio_cgroup block: rescan partitions on invalidated devices on -ENOMEDIA too cdrom: always check_disk_change() on open block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers
2011-05-13rbd: fix split bio handlingYehuda Sadeh
The rbd driver currently splits bios when they span an object boundary. However, the blk_end_request expects the completions to roll up the results in block device order, and the split rbd/ceph ops can complete in any order. This patch adds a struct rbd_req_coll to track completion of split requests and ensures that the results are passed back up to the block layer in order. This fixes errors where the file system gets completion of a read operation that spans an object boundary before the data has actually arrived. The bug is easily reproduced with iozone with a working set larger than available RAM. Reported-by: Fyodor Ustinov <ufm@ufm.su> Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-13xen/blkback: fix xenbus_transaction_start() hang caused by double ↵Laszlo Ersek
xenbus_transaction_end() vbd_resize() up_read()'s xs_state.suspend_mutex twice in a row via double xenbus_transaction_end() calls. The next down_read() in xenbus_transaction_start() (at eg. the next resize attempt) hangs. Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=618317 Acked-by: Jan Beulich <jbeulich@novell.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Laszlo Ersek <lersek@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12rbd: fix leak of ops structSage Weil
The ops vector must be freed by the rbd_do_request caller. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-12xen/blkback: Align the tabs on the structure.Konrad Rzeszutek Wilk
The recent changes caused this field of the structure to be offset a bit. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12xen/blkback: if log_stats is enabled print out the data.Konrad Rzeszutek Wilk
And not depend on the driver being built with -DDEBUG flag. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12xen/blkback: Add the prefix XEN in the common.h.Konrad Rzeszutek Wilk
