Export 'rd_nr', 'rd_size' and 'max_part' parameters to sysfs so user can
know that how many devices are allowed, how big each device is and how
many partitions are supported. If 'max_part' is 0, it means simply the
device doesn't support partitioning.
Also note that 'max_part' can be adjusted to power of 2 minus 1 form if
needed. User should check this value after the module loading if he/she
want to use that number correctly (i.e. fdisk, mknod, etc.).
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: Laurent Vivier <Laurent.Vivier@bull.net>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
If 'rd_nr' param was not specified, 16 (can be adjusted via
CONFIG_BLK_DEV_RAM_COUNT) devices would be created by default
but comment said 1. Fix it.
When finding or allocating a ram disk device, brd_probe() did not take
partition numbers into account so that it can result to a different
device. Consider following example (I set CONFIG_BLK_DEV_RAM_COUNT=4
for simplicity) :
$ sudo modprobe brd max_part=15
$ ls -l /dev/ram*
brw-rw---- 1 root disk 1, 0 2011-05-25 15:41 /dev/ram0
brw-rw---- 1 root disk 1, 16 2011-05-25 15:41 /dev/ram1
brw-rw---- 1 root disk 1, 32 2011-05-25 15:41 /dev/ram2
brw-rw---- 1 root disk 1, 48 2011-05-25 15:41 /dev/ram3
$ sudo mknod /dev/ram4 b 1 64
$ sudo dd if=/dev/zero of=/dev/ram4 bs=4k count=256
256+0 records in
256+0 records out
1048576 bytes (1.0 MB) copied, 0.00215578 s, 486 MB/s
namhyung@leonhard:linux$ ls -l /dev/ram*
brw-r--r-- 1 root root 1, 64 2011-05-25 15:45 /dev/ram4
brw-rw---- 1 root disk 1, 1024 2011-05-25 15:44 /dev/ram64
After this patch, /dev/ram4 - instead of /dev/ram64 - was
accessed correctly.
In addition, 'range' passed to blk_register_region() should
include all range of dev_t that RAMDISK_MAJOR can address.
It does not need to be limited by partition numbers unless
'rd_nr' param was specified.
Cc: stable@kernel.org
The 'max_part' parameter controls the number of maximum partition
a brd device can have. However if a user specifies very large
value it would exceed the limitation of device minor number and
can cause a kernel panic (or, at least, produce invalid device
nodes in some cases).
On my desktop system, following command kills the kernel. On qemu,
it triggers similar oops but the kernel was alive:
$ sudo modprobe brd max_part=100000
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
IP: [<ffffffff81110a9a>] sysfs_create_dir+0x2d/0xae
PGD 7af1067 PUD 7b19067 PMD 0
Oops: 0000 [#1] SMP
last sysfs file:
CPU 0
Modules linked in: brd(+)
Pid: 44, comm: insmod Tainted: G W 2.6.39-qemu+ #158 Bochs Bochs
RIP: 0010:[<ffffffff81110a9a>] [<ffffffff81110a9a>] sysfs_create_dir+0x2d/0xae
RSP: 0018:ffff880007b15d78 EFLAGS: 00000286
RAX: ffff880007b05478 RBX: ffff880007a52760 RCX: ffff880007b15dc8
RDX: ffff880007a4f900 RSI: ffff880007b15e48 RDI: ffff880007a52760
RBP: ffff880007b15da8 R08: 0000000000000002 R09: 0000000000000000
R10: ffff880007b15e48 R11: ffff880007b05478 R12: 0000000000000000
R13: ffff880007b05478 R14: 0000000000400920 R15: 0000000000000063
FS: 0000000002160880(0063) GS:ffff880007c00000(0000) knlGS:0000000000000000
CR2: 0000000000000058 CR3: 0000000007b1c000 CR4: 00000000000006b0
DR3: 0000000000000000 DR6: 0000000000000000 DR7: 0000000000000000
Process insmod (pid: 44, threadinfo ffff880007b14000, task ffff880007acb980)
Stack:
ffff880007b15dc8 ffff880007b05478 ffff880007b15da8 00000000fffffffe
ffff880007a52760 ffff880007b05478 ffff880007b15de8 ffffffff81143c0a
0000000000400920 ffff880007a52760 ffff880007b05478 0000000000000000
Call Trace:
[<ffffffff81143c0a>] kobject_add_internal+0xdf/0x1a0
[<ffffffff81143da1>] kobject_add_varg+0x41/0x50
[<ffffffff81143e6b>] kobject_add+0x64/0x66
[<ffffffff8113bbe7>] blk_register_queue+0x5f/0xb8
[<ffffffff81140f72>] add_disk+0xdf/0x289
[<ffffffffa00040df>] brd_init+0xdf/0x1aa [brd]
[<ffffffffa0004000>] ? 0xffffffffa0003fff
[<ffffffff8100020a>] do_one_initcall+0x7a/0x12e
[<ffffffff8108516c>] sys_init_module+0x9c/0x1dc
[<ffffffff812ff4bb>] system_call_fastpath+0x16/0x1b
Code: 89 e5 41 55 41 54 53 48 89 fb 48 83 ec 18 48 85 ff 75 04 0f 0b eb fe 48 8b 47 18 49 c7 c4 70 1e 4d 81 48 85 c0 74 04 4c 8b 60 30
8b 44 24 58 45 31 ed 0f b6 c4 85 c0 74 0d 48 8b 43 28 48 89
RIP [<ffffffff81110a9a>] sysfs_create_dir+0x2d/0xae
RSP <ffff880007b15d78>
---[ end trace aebb1175ce1f6739 ]---
brd_refcnt, brd_offset, brd_sizelimit and brd_blocksize in struct
brd_device seem to be copied from struct loop_device but they're
not used anywhere. Let get rid of them.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (23 commits)
ceph: fix cap flush race reentrancy
libceph: subscribe to osdmap when cluster is full
libceph: handle new osdmap down/state change encoding
rbd: handle online resize of underlying rbd image
ceph: avoid inode lookup on nfs fh reconnect
ceph: use LOOKUPINO to make unconnected nfs fh more reliable
rbd: use snprintf for disk->disk_name
rbd: cleanup: make kfree match kmalloc
rbd: warn on update_snaps failure on notify
ceph: check return value for start_request in writepages
ceph: remove useless check
libceph: add missing breaks in addr_set_port
libceph: fix TAG_WAIT case
ceph: fix broken comparison in readdir loop
libceph: fix osdmap timestamp assignment
ceph: fix rare potential cap leak
libceph: use snprintf for unknown addrs
libceph: use snprintf for formatting object name
ceph: use snprintf for dirstat content
libceph: fix uninitialized value when no get_authorizer method is set
* 'for-2.6.40/drivers' of git://git.kernel.dk/linux-2.6-block: (110 commits)
loop: handle on-demand devices correctly
loop: limit 'max_part' module param to DISK_MAX_PARTS
drbd: fix warning
drbd: fix warning
drbd: Fix spelling
drbd: fix schedule in atomic
drbd: Take a more conservative approach when deciding max_bio_size
drbd: Fixed state transitions after async outdate-peer-handler returned
drbd: Disallow the peer_disk_state to be D_OUTDATED while connected
drbd: Fix for the connection problems on high latency links
drbd: fix potential activity log refcount imbalance in error path
drbd: Only downgrade the disk state in case of disk failures
drbd: fix disconnect/reconnect loop, if ping-timeout == ping-int
drbd: fix potential distributed deadlock
lru_cache.h: fix comments referring to ts_ instead of lc_
drbd: Fix for application IO with the on-io-error=pass-on policy
xen/p2m: Add EXPORT_SYMBOL_GPL to the M2P override functions.
xen/p2m/m2p/gnttab: Support GNTMAP_host_map in the M2P override.
xen/blkback: don't fail empty barrier requests
xen/blkback: fix xenbus_transaction_start() hang caused by double xenbus_transaction_end()
* 'for-2.6.40/core' of git://git.kernel.dk/linux-2.6-block: (40 commits)
cfq-iosched: free cic_index if cfqd allocation fails
cfq-iosched: remove unused 'group_changed' in cfq_service_tree_add()
cfq-iosched: reduce bit operations in cfq_choose_req()
cfq-iosched: algebraic simplification in cfq_prio_to_maxrq()
blk-cgroup: Initialize ioc->cgroup_changed at ioc creation time
block: move bd_set_size() above rescan_partitions() in __blkdev_get()
block: call elv_bio_merged() when merged
cfq-iosched: Make IO merge related stats per cpu
cfq-iosched: Fix a memory leak of per cpu stats for root group
backing-dev: Kill set but not used var in bdi_debug_stats_show()
block: get rid of on-stack plugging debug checks
blk-throttle: Make no throttling rule group processing lockless
blk-cgroup: Make cgroup stat reset path blkg->lock free for dispatch stats
blk-cgroup: Make 64bit per cpu stats safe on 32bit arch
blk-throttle: Make dispatch stats per cpu
blk-throttle: Free up a group only after one rcu grace period
blk-throttle: Use helper function to add root throtl group to lists
blk-throttle: Introduce a helper function to fill in device details
blk-throttle: Dynamically allocate root group
blk-cgroup: Allow sleeping while dynamically allocating a group
If we get a notification that the image header has changed, check for
a change in the image size.
Signed-off-by: Sage Weil <sage@newdream.net>
When finding or allocating a loop device, loop_probe() did not take
device. Consider following example:
$ sudo modprobe loop max_part=15
$ ls -l /dev/loop*
brw-rw---- 1 root disk 7, 0 2011-05-24 22:16 /dev/loop0
brw-rw---- 1 root disk 7, 16 2011-05-24 22:16 /dev/loop1
brw-rw---- 1 root disk 7, 32 2011-05-24 22:16 /dev/loop2
brw-rw---- 1 root disk 7, 48 2011-05-24 22:16 /dev/loop3
brw-rw---- 1 root disk 7, 64 2011-05-24 22:16 /dev/loop4
brw-rw---- 1 root disk 7, 80 2011-05-24 22:16 /dev/loop5
brw-rw---- 1 root disk 7, 96 2011-05-24 22:16 /dev/loop6
brw-rw---- 1 root disk 7, 112 2011-05-24 22:16 /dev/loop7
$ sudo mknod /dev/loop8 b 7 128
$ sudo losetup /dev/loop8 ~/temp/disk-with-3-parts.img
$ sudo losetup -a
/dev/loop128: [0805]:278201 (/home/namhyung/temp/disk-with-3-parts.img)
$ ls -l /dev/loop*
brw-rw---- 1 root disk 7, 2048 2011-05-24 22:18 /dev/loop128
brw-rw---- 1 root disk 7, 2049 2011-05-24 22:18 /dev/loop128p1
brw-rw---- 1 root disk 7, 2050 2011-05-24 22:18 /dev/loop128p2
brw-rw---- 1 root disk 7, 2051 2011-05-24 22:18 /dev/loop128p3
brw-r--r-- 1 root root 7, 128 2011-05-24 22:17 /dev/loop8
After this patch, /dev/loop8 - instead of /dev/loop128 - was
accessed correctly.
include all range of dev_t that LOOP_MAJOR can address. It does
not need to be limited by partition numbers unless 'max_loop'
a loop block device can have. However if a user specifies very
large value it would exceed the limitation of device minor number
and can cause a kernel panic (or, at least, produce invalid
device nodes in some cases).
$ sudo modprobe loop max_part0000
kernel BUG at /media/Linux_Data/project/linux/fs/sysfs/group.c:65!
invalid opcode: 0000 [#1] SMP
last sysfs file:
CPU 0
Modules linked in: loop(+)
Pid: 43, comm: insmod Tainted: G W 2.6.39-qemu+ #155 Bochs Bochs
RIP: 0010:[<ffffffff8113ce61>] [<ffffffff8113ce61>] internal_create_group=
+0x2a/0x170
RSP: 0018:ffff880007b3fde8 EFLAGS: 00000246
RAX: 00000000ffffffef RBX: ffff880007b3d878 RCX: 00000000000007b4
RDX: ffffffff8152da50 RSI: 0000000000000000 RDI: ffff880007b3d878
RBP: ffff880007b3fe38 R08: ffff880007b3fde8 R09: 0000000000000000
R10: ffff88000783b4a8 R11: ffff880007b3d878 R12: ffffffff8152da50
R13: ffff880007b3d868 R14: 0000000000000000 R15: ffff880007b3d800
FS: 0000000002137880(0063) GS:ffff880007c00000(0000) knlGS:00000000000000=
00
CR2: 0000000000422680 CR3: 0000000007b50000 CR4: 00000000000006b0
Process insmod (pid: 43, threadinfo ffff880007b3e000, task ffff880007afb9c=
0)
Stack:
ffff880007b3fe58 ffffffff811e66dd ffff880007b3fe58 ffffffff811e570b
0000000000000010 ffff880007b3d800 ffff880007a7b390 ffff880007b3d868
0000000000400920 ffff880007b3d800 ffff880007b3fe48 ffffffff8113cfc8
Call Trace:
[<ffffffff811e66dd>] ? device_add+0x4bc/0x5af
[<ffffffff811e570b>] ? dev_set_name+0x3c/0x3e
[<ffffffff8113cfc8>] sysfs_create_group+0xe/0x12
[<ffffffff810b420e>] blk_trace_init_sysfs+0x14/0x16
[<ffffffff8116a090>] blk_register_queue+0x47/0xf7
[<ffffffff8116f527>] add_disk+0xdf/0x290
[<ffffffffa00060eb>] loop_init+0xeb/0x1b8 [loop]
[<ffffffffa0006000>] ? 0xffffffffa0005fff
[<ffffffff81096804>] sys_init_module+0x9c/0x1e0
[<ffffffff813329bb>] system_call_fastpath+0x16/0x1b
Code: c3 55 48 89 e5 41 57 41 56 41 89 f6 41 55 41 54 49 89 d4 53 48 89 fb=
48 83 ec 28 48 85 ff 74 0b 85 f6 75 0b 48 83 7f 30 00 75 14 <0f> 0b eb fe =
48 83 7f 30 00 b9 ea ff ff ff 0f 84 18 01 00 00 49
RIP [<ffffffff8113ce61>] internal_create_group+0x2a/0x170
RSP <ffff880007b3fde8>
---[ end trace a123eb592043acad ]---
In file included from drivers/block/drbd/drbd_main.c:54: drivers/block/drbd/drbd_int.h:1190: warning: parameter has incomplete type
Forward declarations of enums do not work.
Fix it unpleasantly by moving the prototype.
Signed-off-by: Lars Ellenberg <drbd-dev@lists.linbit.com>
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Found these with the help of ispell -l.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
An administrative detach used to request a state change directly to D_DISKLESS,
first suspending IO to avoid the last put_ldev() occuring from an endio handler,
potentially in irq context.
This is not enough on the receiving side (typically secondary), we may miss
some peer_req on the way to local disk, which then may do the last put_ldev()
from their drbd_peer_request_endio().
This patch makes the detach always go through the intermediate D_FAILED state.
We may consider to rename it D_DETACHING.
Alternative approach would be to create yet an other work item to be scheduled
on the worker, do the destructor work from there, and get the timing right.
manually picked commit 564040f from the drbd 8.4 branch.
The old (optimistic) implementation could shrink the bio size
on an primary device.
Shrinking the bio size on a primary device is bad. Since there
we might get BIOs with the old (bigger) size shortly after
we published the new size.
The new implementation is more conservative, and eventually
increases the max_bio_size on a primary device (which is valid).
It does so, when it knows the local limit AND the remote limit.
We cache the last seen max_bio_size of the peer in the meta
data, and rely on that, to make the operation of single
nodes more efficient.
It seems that the real cause of all the issues where that
we did not noticed in drbd_try_connect() when the other
guy closes one socket if the round trip time gets higher
than 100ms. There were that 100ms hard coded!
It is no longer sufficient to trigger on local WRITE,
we need to check on (rq_state & RQ_IN_ACT_LOG)
before calling drbd_al_complete_io also in the error path.
If there is no replication traffic within the idle timeout
(ping-int seconds), DRBD will send a P_PING,
and adjust the timeout to ping-timeout.
If there is no P_PING_ACK received within this ping-timeout,
DRBD finally drops the connection, and tries to re-establish it.
To decide which timeout was active, we compared the current timeout
with the ping-timeout, and dropped the connection, if that was the case.
By default, ping-int is 10 seconds, ping-timeout is 500 ms.
Unfortunately, if you configure ping-timeout to be the same as ping-int,
expiry of the idle-timeout had been mistaken for a missing ping ack,
and caused an immediate reconnection attempt.
Fix:
Allow both timeouts to be equal, use a local variable
to store which timeout is active.
We limit ourselves to a configurable maximum number of pages used as
temporary bio pages.
If the configured "max_buffers" is not big enough to match the bandwidth
of the respective deployment, a distributed deadlock could be triggered
by e.g. fast online verify and heavy application IO.
TCP connections would block on congestion, because both receivers
would wait on pages to become available.
Fortunately the respective senders in this case would be able to give
back some pages already. So do that.
In case a write failes on the local disk, go into D_INCONSISTENT
disk state. That causes future reads of that block to be shipped
to the peer.
Read retry remote was already in place.
Actually the documentation needs to get fixed now. Since the
application is still shielded from the error. (as long as we have
only a single disk failing) The difference to detach is that
we keep the disk. And therefore might keep all the other, still
working sectors up to date.
After discovering that wide use of prefetch on modern CPUs
could be a net loss instead of a win, net drivers which were
relying on the implicit inclusion of prefetch.h via the list
headers showed up in the resulting cleanup fallout. Give
them an explicit include via the following $0.02 script.
#!/bin/bash
MANUAL=""
for i in `git grep -l 'prefetch(.*)' .` ; do
grep -q '<linux/prefetch.h>' $i
if [ $? = 0 ] ; then
continue
fi
( echo '?^#include <linux/?a'
echo '#include <linux/prefetch.h>'
echo .
echo w
echo q
) | ed -s $i > /dev/null 2>&1
if [ $? != 0 ]; then
echo $i needs manual fixup
MANUAL="$i $MANUAL"
fi
done
echo ------------------- 8\<----------------------
echo vi $MANUAL
Signed-off-by: Paul <paul.gortmaker@windriver.com>
[ Fixed up some incorrect #include placements, and added some
non-network drivers and the fib_trie.c case - Linus ]
Since for-2.6.40/core was forked off the 2.6.39 devel tree, we've
had churn in the core area that makes it difficult to handle
patches for eg cfq or blk-throttle. Instead of requiring that they
be based in older versions with bugs that have been fixed later
in the rc cycle, merge in 2.6.39 final.
Also fixes up conflicts in the below files.
drivers/block/paride/pcd.c
drivers/cdrom/viocd.c
drivers/ide/ide-cd.c
of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen into for-2.6.40/drivers
The sector number on empty barrier requests may (will?) be -1, which,
given that it's being treated as unsigned 64-bit quantity, will almost
always exceed the actual (virtual) disk's size.
Inspired by Konrad's "When writting barriers set the sector number to
zero...".
While at it also add overflow checking to the math in vbd_translate().
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: don't delay blk_run_queue_async
scsi: remove performance regression due to async queue run
blk-throttle: Use task_subsys_state() to determine a task's blkio_cgroup
block: rescan partitions on invalidated devices on -ENOMEDIA too
cdrom: always check_disk_change() on open
block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers
The rbd driver currently splits bios when they span an object boundary.
However, the blk_end_request expects the completions to roll up the results
in block device order, and the split rbd/ceph ops can complete in any
order. This patch adds a struct rbd_req_coll to track completion of split
requests and ensures that the results are passed back up to the block layer
in order.
This fixes errors where the file system gets completion of a read operation
that spans an object boundary before the data has actually arrived. The
bug is easily reproduced with iozone with a working set larger than
available RAM.
Reported-by: Fyodor Ustinov <ufm@ufm.su>
Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
vbd_resize() up_read()'s xs_state.suspend_mutex twice in a row via double
xenbus_transaction_end() calls. The next down_read() in
xenbus_transaction_start() (at eg. the next resize attempt) hangs.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=618317
Acked-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Laszlo Ersek <lersek@redhat.com>
The ops vector must be freed by the rbd_do_request caller.
The recent changes caused this field of the structure to be offset a bit.
And not depend on the driver being built with -DDEBUG flag.
No need for that '_st' and xen_blkif is more apt.
Not point of the blkif.h file. It is not used by the frontend.
CHECK: multiple assignments should be avoided
with more details.
dir.
From the blkif.h header, which was exposed to the frontend.
It is not really used for anything.
To make it easier to read.
