path: root/drivers/block
2011-11-11xen/blkback: Report VBD_WSECT (wr_sect) properly.Konrad Rzeszutek Wilk
commit 5c62cb48602dba95159c81ffeca179d3852e25be upstream. We did not increment the amount of sectors written to disk b/c we tested for the == WRITE which is incorrect - as the operations are more of WRITE_FLUSH, WRITE_ODIRECT. This patch fixes it by doing a & WRITE check. Reported-by: Andy Burns <xen.lists@burns.me.uk> Suggested-by: Ian Campbell <Ian.Campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11cciss: add small delay when using PCI Power Management to reset for kumpMike Miller
commit ab5dbebe33e0c353e8545f09c34553ac3351dad6 upstream. The P600 requires a small delay when changing states. Otherwise we may think the board did not reset and we bail. This for kdump only and is particular to the P600. Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-21floppy: use del_timer_sync() in init cleanupCarsten Emde
When no floppy is found the module code can be released while a timer function is pending or about to be executed. CPU0 CPU1 floppy_init() timer_softirq() spin_lock_irq(&base->lock); detach_timer(); spin_unlock_irq(&base->lock); -> Interrupt del_timer(); return -ENODEV; module_cleanup(); <- EOI call_timer_fn(); OOPS Use del_timer_sync() to prevent this. Signed-off-by: Carsten Emde <C.Emde@osadl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-08-23Merge branch 'stable/for-jens' of ↵Jens Axboe
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen into for-linus
2011-08-22xen-blkback: fixed indentation and commentsJoe Jin
This patch fixes belows: 1. Fix code style issue. 2. Fix incorrect functions name in comments. Signed-off-by: Joe Jin <joe.jin@oracle.com> Cc: Jens Axboe <jaxboe@fusionio.com> Cc: Ian Campbell <Ian.Campbell@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-22xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.Joe Jin
When do block-attach/block-detach test with below steps, umount hangs in the guest. Furthermore shutdown ends up being stuck when umounting file-systems. 1. start guest. 2. attach new block device by xm block-attach in Dom0. 3. mount new disk in guest. 4. execute xm block-detach to detach the block device in dom0 until timeout 5. Any request to the disk will hung. Root cause: This issue is caused when setting backend device's state to 'XenbusStateClosing', which sends to the frontend the XenbusStateClosing notification. When frontend receives the notification it tries to release the disk in blkfront_closing(), but at that moment the disk is still in use by guest, so frontend refuses to close. Specifically it sets the disk state to XenbusStateClosing and sends the notification to backend - when backend receives the event, it disconnects the vbd from real device, and sets the vbd device state to XenbusStateClosing. The backend disconnects the real device/file, and any IO requests to the disk in guest will end up in ether, leaving disk DEAD and set to XenbusStateClosing. When the guest wants to disconnect the disk, umount will hang on blkif_release()->xlvbd_release_gendisk() as it is unable to send any IO to the disk, which prevents clean system shutdown. Solution: Don't disconnect backend until frontend state switched to XenbusStateClosed. Signed-off-by: Joe Jin <joe.jin@oracle.com> Cc: Daniel Stodden <daniel.stodden@citrix.com> Cc: Jens Axboe <jaxboe@fusionio.com> Cc: Annie Li <annie.li@oracle.com> Cc: Ian Campbell <Ian.Campbell@eu.citrix.com> [v1: Modified description a bit] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-09Merge branch 'stable/for-jens' of ↵Jens Axboe
2011-08-09xen/blkback: Make description more obvious.Konrad Rzeszutek Wilk
With the frontend having Xen but the backend not, it just looks odd: <*> Xen virtual block device support <*> Block-device backend driver Fix it to have the 'Xen' in front of it. Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-03block: swim3: fix unterminated of_device_id tableAxel Lin
of_device_id structures need a NULL terminating entry, add it. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-02drivers/block/drbd/drbd_nl.c: use bitmap_parse instead of __bitmap_parseH Hartley Sweeten
The buffer 'sc.cpu_mask' is a kernel buffer. If bitmap_parse is used instead of __bitmap_parse the extra parameter that indicates a kernel buffer is not needed. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Philipp Reisner <philipp.reisner@linbit.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-31loop: fix deadlock when sysfs and LOOP_CLR_FD race against each otherKay Sievers
LOOP_CLR_FD takes lo->lo_ctl_mutex and tries to remove the loop sysfs files. Sysfs calls show() and waits for lo->lo_ctl_mutex. LOOP_CLR_FD waits for show() to finish to remove the sysfs file. cat /sys/class/block/loop0/loop/backing_file mutex_lock_nested+0x176/0x350 ? loop_attr_do_show_backing_file+0x2f/0xd0 [loop] ? loop_attr_do_show_backing_file+0x2f/0xd0 [loop] loop_attr_do_show_backing_file+0x2f/0xd0 [loop] dev_attr_show+0x1b/0x60 ? sysfs_read_file+0x86/0x1a0 ? __get_free_pages+0x12/0x50 sysfs_read_file+0xaf/0x1a0 ioctl(LOOP_CLR_FD): wait_for_common+0x12c/0x180 ? try_to_wake_up+0x2a0/0x2a0 wait_for_completion+0x18/0x20 sysfs_deactivate+0x178/0x180 ? sysfs_addrm_finish+0x43/0x70 ? sysfs_addrm_start+0x1d/0x20 sysfs_addrm_finish+0x43/0x70 sysfs_hash_and_remove+0x85/0xa0 sysfs_remove_group+0x59/0x100 loop_clr_fd+0x1dc/0x3f0 [loop] lo_ioctl+0x223/0x7a0 [loop] Instead of taking the lo_ctl_mutex from sysfs code, take the inner lo->lo_lock, to protect the access to the backing_file data. Thanks to Tejun for help debugging and finding a solution. Cc: Milan Broz <mbroz@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-31loop: add BLK_DEV_LOOP_MIN_COUNT=%i to allow distros 0 pre-allocated loop ↵Kay Sievers
devices Instead of unconditionally creating a fixed number of dead loop devices which need to be investigated by storage handling services, even when they are never used, we allow distros start with 0 loop devices and have losetup(8) and similar switch to the dynamic /dev/loop-control interface instead of searching /dev/loop%i for free devices. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-31loop: add management interface for on-demand device allocationKay Sievers
Loop devices today have a fixed pre-allocated number of usually 8. The number can only be changed at module init time. To find a free device to use, /dev/loop%i needs to be scanned, and all devices need to be opened until a free one is possibly found. This adds a new /dev/loop-control device node, that allows to dynamically find or allocate a free device, and to add and remove loop devices from the running system: LOOP_CTL_ADD adds a specific device. Arg is the number of the device. It returns the device i or a negative error code. LOOP_CTL_REMOVE removes a specific device, Arg is the number the device. It returns the device i or a negative error code. LOOP_CTL_GET_FREE finds the next unbound device or allocates a new one. No arg is given. It returns the device i or a negative error code. The loop kernel module gets automatically loaded when /dev/loop-control is accessed the first time. The alias specified in the module, instructs udev to create this 'dead' device node, even when the module is not loaded. Example: cfd = open("/dev/loop-control", O_RDWR); # add a new specific loop device err = ioctl(cfd, LOOP_CTL_ADD, devnr); # remove a specific loop device err = ioctl(cfd, LOOP_CTL_REMOVE, devnr); # find or allocate a free loop device to use devnr = ioctl(cfd, LOOP_CTL_GET_FREE); sprintf(loopname, "/dev/loop%i", devnr); ffd = open("backing-file", O_RDWR); lfd = open(loopname, O_RDWR); err = ioctl(lfd, LOOP_SET_FD, ffd); Cc: Tejun Heo <tj@kernel.org> Cc: Karel Zak <kzak@redhat.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-31loop: replace linked list of allocated devices with an idr indexKay Sievers
Replace the linked list, that keeps track of allocated devices, with an idr index to allow a more efficient lookup of devices. Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (23 commits) ceph: document unlocked d_parent accesses ceph: explicitly reference rename old_dentry parent dir in request ceph: document locking for ceph_set_dentry_offset ceph: avoid d_parent in ceph_dentry_hash; fix ceph_encode_fh() hashing bug ceph: protect d_parent access in ceph_d_revalidate ceph: protect access to d_parent ceph: handle racing calls to ceph_init_dentry ceph: set dir complete frag after adding capability rbd: set blk_queue request sizes to object size ceph: set up readahead size when rsize is not passed rbd: cancel watch request when releasing the device ceph: ignore lease mask ceph: fix ceph_lookup_open intent usage ceph: only link open operations to directory unsafe list if O_CREAT|O_TRUNC ceph: fix bad parent_inode calc in ceph_lookup_open ceph: avoid carrying Fw cap during write into page cache libceph: don't time out osd requests that haven't been received ceph: report f_bfree based on kb_avail rather than diffing. ceph: only queue capsnap if caps are dirty ceph: fix snap writeback when racing with writes ...
2011-07-26rbd: set blk_queue request sizes to object sizeJosh Durgin
This improves performance since more requests can be merged. Reviewed-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
2011-07-26rbd: cancel watch request when releasing the deviceYehuda Sadeh
We were missing this cleanup, so when a device was released the osd didn't clean up its watchers list, so following notifications could be slow as osd needed to timeout on the client. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
2011-07-25Merge branch 'for-3.1/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.1/drivers' of git://git.kernel.dk/linux-block: cciss: do not attempt to read from a write-only register xen/blkback: Add module alias for autoloading xen/blkback: Don't let in-flight requests defer pending ones. bsg: fix address space warning from sparse bsg: remove unnecessary conditional expressions bsg: fix bsg_poll() to return POLLOUT properly
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22Merge branch 'timers-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mips: Fix i8253 clockevent fallout i8253: Cleanup outb/inb magic arm: Footbridge: Use common i8253 clockevent mips: Use common i8253 clockevent x86: Use common i8253 clockevent i8253: Create common clockevent implementation i8253: Export i8253_lock unconditionally pcpskr: MIPS: Make config dependencies finer grained pcspkr: Cleanup Kconfig dependencies i8253: Move remaining content and delete asm/i8253.h i8253: Consolidate definitions of PIT_LATCH x86: i8253: Consolidate definitions of global_clock_event i8253: Alpha, PowerPC: Remove unused asm/8253pit.h alpha: i8253: Cleanup remaining users of i8253pit.h i8253: Remove I8253_LOCK config i8253: Make pcsp sound driver use the shared i8253_lock i8253: Make pcspkr input driver use the shared i8253_lock i8253: Consolidate all kernel definitions of i8253_lock i8253: Unify all kernel declarations of i8253_lock i8253: Create linux/i8253.h and use it in all 8253 related files
2011-07-22Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: dt: include linux/errno.h in linux/of_address.h of/address: Add of_find_matching_node_by_address helper dt: remove extra xsysace platform_driver registration tty/serial: Add devicetree support for nVidia Tegra serial ports dt: add empty of_property_read_u32[_array] for non-dt dt: bindings: move SEC node under new crypto/ dt: add helper function to read u32 arrays tty/serial: change of_serial to use new of_property_read_u32() api dt: add 'const' for of_property_read_string parameter **out_string dt: add helper functions to read u32 and string property values tty: of_serial: support for 32 bit accesses dt: document the of_serial bindings dt/platform: allow device name to be overridden drivers/amba: create devices from device tree dt: add of_platform_populate() for creating device from the device tree dt: Add default match table for bus ids
2011-07-22Merge branch 'stable/drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pciback: Have 'passthrough' option instead of XEN_PCIDEV_BACKEND_PASS and XEN_PCIDEV_BACKEND_VPCI xen/pciback: Remove the DEBUG option. xen/pciback: Drop two backends, squash and cleanup some code. xen/pciback: Print out the MSI/MSI-X (PIRQ) values xen/pciback: Don't setup an fake IRQ handler for SR-IOV devices. xen: rename pciback module to xen-pciback. xen/pciback: Fine-grain the spinlocks and fix BUG: scheduling while atomic cases. xen/pciback: Allocate IRQ handler for device that is shared with guest. xen/pciback: Disable MSI/MSI-X when reseting a device xen/pciback: guest SR-IOV support for PV guest xen/pciback: Register the owner (domain) of the PCI device. xen/pciback: Cleanup the driver based on checkpatch warnings and errors. xen/pciback: xen pci backend driver. xen: tmem: self-ballooning and frontswap-selfshrinking xen: Add module alias to autoload backend drivers xen: Populate xenbus device attributes xen: Add __attribute__((format(printf... where appropriate xen: prepare tmem shim to handle frontswap xen: allow enable use of VGA console on dom0
2011-07-20kill useless checks for sb->s_op == NULLAl Viro
never is... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-15Merge commit 'v3.0-rc7' into devicetree/nextGrant Likely
2011-07-14xen-blkfront: Fix one off warning about name clashStefan Bader
Avoid telling users to use xvde and onwards when using xvde. Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-14xen-blkfront: Drop name and minor adjustments for emulated scsi devicesStefan Bader
These were intended to avoid the namespace clash when representing emulated IDE and SCSI devices. However that seems to confuse users more than expected (a disk defined as sda becomes xvde). So for now go back to the scheme which does no adjustments. This will break when mixing IDE and SCSI names in the configuration of guests but should be by now expected. Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-14dt: remove extra xsysace platform_driver registrationGrant Likely
After commit 1c48a5c93, "dt: Eliminate of_platform_{,un}register_driver", the xsysace driver attempts to register two platform_drivers with the same name, which a) doesn't work, and b) isn't necessary. This patch merges the two platform_drivers. Reported-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-09cciss: do not attempt to read from a write-only registerStephen M. Cameron
Most smartarrays will tolerate it, but some new ones don't. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Note: this is a regression caused by commit 1ddd5049 Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-30xen/blkback: Add module alias for autoloadingBastian Blank
Add xen-backend:vbd module alias to the xen-blkback module. This allows automatic loading of the module. Signed-off-by: Bastian Blank <waldi@debian.org> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-30xen/blkback: Don't let in-flight requests defer pending ones.Daniel Stodden
Running RING_FINAL_CHECK_FOR_REQUESTS from make_response is a bad idea. It means that in-flight I/O is essentially blocking continued batches. This essentially kills throughput on frontends which unplug (or even just notify) early and rightfully assume addtional requests will be picked up on time, not synchronously. Signed-off-by: Daniel Stodden <daniel.stodden@citrix.com> [v1: Rebased and fixed compile problems] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-30xen: Add __attribute__((format(printf... where appropriateJoe Perches
Use the compiler to verify printf formats and arguments. Fix fallout. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-30Merge branch 'for-3.0-important' of git://git.drbd.org/linux-2.6-drbd into ↵Jens Axboe
for-linus
2011-06-30drbd: we should write meta data updates with FLUSH FUALars Ellenberg
We used to write these with BIO_RW_BARRIER aka REQ_HARDBARRIER (unless disabled in the configuration). The correct semantic now would be to write with FLUSH/FUA. For example, with activity log transactions, FUA alone is not enough, we need the corresponding bitmap update (and all related application updates) on stable storage as well. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-06-30drbd: when receive times out on meta socket, also check last receive time on ↵Lars Ellenberg
data socket If we have an asymetrically congested network, we may send P_PING, but due to congestion, the corresponding P_PING_ACK would time out, and we would drop a (congested, but otherwise) healthy connection ("PingAck did not arrive in time.") Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-06-30drbd: account bitmap IO during resync as resync-(related-)-ioLars Ellenberg
If we have a good resync rate, we will frequently update the on-disk bitmap, which, if not accounted for as resync io, may let an otherwise idle device appear to be "busy", and cause us to throttle resync. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-06-30drbd: don't cond_resched_lock with IRQs disabledLars Ellenberg
The last commit, drbd: add missing spinlock to bitmap receive, introduced a cond_resched_lock(), where the lock in question is taken with irqs disabled. As we must not schedule with IRQs disabled, and cond_resched_lock_irq() does not exist, yet, we re-aquire the spin_lock_irq() for each bitmap page processed in turn. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-06-30drbd: add missing spinlock to bitmap receiveLars Ellenberg
During bitmap exchange, when using the RLE bitmap compression scheme, we have a code path that can set the whole bitmap at once. To avoid holding spin_lock_irq() for too long, we used to lock out other bitmap modifications during bitmap exchange by other means, and then, knowing we have exclusive access to the bitmap, modify it without the spinlock, and with IRQs enabled. Since we now allow local IO to continue, potentially setting additional bits during the bitmap receive phase, this is no longer true, and we get uncoordinated updates of bitmap members, causing bm_set to no longer accurately reflect the total number of set bits. To actually see this, you'd need to have a large bitmap, use RLE bitmap compression, and have busy IO during sync handshake and bitmap exchange. Fix this by taking the spin_lock_irq() in this code path as well, but calling cond_resched_lock() after each page worth of bits processed. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
2011-06-30drbd: Use the correct max_bio_size when creating resync requestsPhilipp Reisner
2011-06-09i8253: Create linux/i8253.h and use it in all 8253 related filesRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> arch/arm/mach-footbridge/isa-timer.c | 2 +- arch/mips/cobalt/time.c | 2 +- arch/mips/jazz/irq.c | 2 +- arch/mips/kernel/i8253.c | 2 +- arch/mips/mti-malta/malta-time.c | 2 +- arch/mips/sgi-ip22/ip22-time.c | 2 +- arch/mips/sni/time.c | 2 +- arch/x86/kernel/apic/apic.c | 2 +- arch/x86/kernel/apm_32.c | 2 +- arch/x86/kernel/hpet.c | 2 +- arch/x86/kernel/i8253.c | 2 +- arch/x86/kernel/time.c | 2 +- drivers/block/hd.c | 2 +- drivers/clocksource/i8253.c | 2 +- drivers/input/gameport/gameport.c | 2 +- drivers/input/joystick/analog.c | 2 +- drivers/input/misc/pcspkr.c | 2 +- include/linux/i8253.h | 11 +++++++++++ sound/drivers/pcsp/pcsp.h | 2 +- 19 files changed, 29 insertions(+), 18 deletions(-)
2011-06-04Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: block: Use hlist_entry() for io_context.cic_list.first cfq-iosched: Remove bogus check in queue_fail path xen/blkback: potential null dereference in error handling xen/blkback: don't call vbd_size() if bd_disk is NULL block: blkdev_get() should access ->bd_disk only after success CFQ: Fix typo and remove unnecessary semicolon block: remove unwanted semicolons Revert "block: Remove extra discard_alignment from hd_struct." nbd: adjust 'max_part' according to part_shift nbd: limit module parameters to a sane value nbd: pass MSG_* flags to kernel_recvmsg() block: improve the bio_add_page() and bio_add_pc_page() descriptions
2011-06-02block: fix mismerge of the DISK_EVENT_MEDIA_CHANGE removalLinus Torvalds
Jens' back-merge commit 698567f3fa79 ("Merge commit 'v2.6.39' into for-2.6.40/core") was incorrectly done, and re-introduced the DISK_EVENT_MEDIA_CHANGE lines that had been removed earlier in commits - 9fd097b14918 ("block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers") - 7eec77a1816a ("ide: unexport DISK_EVENT_MEDIA_CHANGE for ide-gd and ide-cd") because of conflicts with the "g->flags" updates near-by by commit d4dc210f69bc ("block: don't block events on excl write for non-optical devices") As a result, we re-introduced the hanging behavior due to infinite disk media change reports. Tssk, tssk, people! Don't do back-merges at all, and *definitely* don't do them to hide merge conflicts from me - especially as I'm likely better at merging them than you are, since I do so many merges. Reported-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-01xen/blkback: potential null dereference in error handlingDan Carpenter
blkbk->pending_pages can be NULL here so I added a check for it. Signed-off-by: Dan Carpenter <error27@gmail.com> [v1: Redid the loop a bit] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-01xen/blkback: don't call vbd_size() if bd_disk is NULLLaszlo Ersek
...because vbd_size() dereferences bd_disk if bd_part is NULL. Signed-off-by: Laszlo Ersek<lersek@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-30drivers, block: virtio_blk: Replace cryptic number with the macroLiu Yuan
It is easier to figure out the context by reading SCSI_SENSE_BUFFERSIZE instead of plain '96'. Signed-off-by: Liu Yuan <tailai.ly@taobao.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-30virtio_blk: allow re-reading config space at runtimeChristoph Hellwig
Wire up the virtio_driver config_changed method to get notified about config changes raised by the host. For now we just re-read the device size to support online resizing of devices, but once we add more attributes that might be changeable they could be added as well. Note that the config_changed method is called from irq context, so we'll have to use the workqueue infrastructure to provide us a proper user context for our changes. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-29Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param x86 idle: deprecate "no-hlt" cmdline param x86 idle APM: deprecate CONFIG_APM_CPU_IDLE x86 idle floppy: deprecate disable_hlt() x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it x86 idle: clarify AMD erratum 400 workaround idle governor: Avoid lock acquisition to read pm_qos before entering idle cpuidle: menu: fixed wrapping timers at 4.294 seconds
2011-05-29x86 idle floppy: deprecate disable_hlt()Len Brown
Plan to remove floppy_disable_hlt in 2012, an ancient workaround with comments that it should be removed. This allows us to remove clutter and a run-time branch from the idle code. WARN_ONCE() on invocation until it is removed. cc: x86@kernel.org cc: stable@kernel.org # .39.x Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-28nbd: adjust 'max_part' according to part_shiftNamhyung Kim
The 'max_part' parameter determines how many partitions are supported on each nbd device. However the actual number can be changed to the power of 2 minus 1 form during the module initialization as alloc_disk() is called with (1 << part_shift) for some reason. So adjust 'max_part' also at least for consistency with loop and brd. It is exported via sysfs already, and a user should check this value after module loading if [s]he wants to use that number correctly (i.e. fdisk or something). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: Paul Clements <Paul.Clements@steeleye.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-28nbd: limit module parameters to a sane valueNamhyung Kim
The 'max_part' parameter controls the number of maximum partition a nbd device can have. However if a user specifies very large value it would exceed the limitation of device minor number and can cause a kernel oops (or, at least, produce invalid device nodes in some cases). In addition, specifying large 'nbds_max' value causes same problem for the same reason. On my desktop, following command results to the kernel bug: $ sudo modprobe nbd max_part=100000 kernel BUG at /media/Linux_Data/project/linux/fs/sysfs/group.c:65! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/devices/virtual/block/nbd4/range CPU 1 Modules linked in: nbd(+) bridge stp llc kvm_intel kvm asus_atk0110 sg sr_mod cdrom Pid: 2522, comm: modprobe Tainted: G W 2.6.39-leonard+ #159 System manufacturer System Product Name/P5G41TD-M PRO RIP: 0010:[<ffffffff8115aa08>] [<ffffffff8115aa08>] internal_create_group+0x2f/0x166 RSP: 0018:ffff8801009f1de8 EFLAGS: 00010246 RAX: 00000000ffffffef RBX: ffff880103920478 RCX: 00000000000a7bd3 RDX: ffffffff81a2dbe0 RSI: 0000000000000000 RDI: ffff880103920478 RBP: ffff8801009f1e38 R08: ffff880103920468 R09: ffff880103920478 R10: ffff8801009f1de8 R11: ffff88011eccbb68 R12: ffffffff81a2dbe0 R13: ffff880103920468 R14: 0000000000000000 R15: ffff880103920400 FS: 00007f3c49de9700(0000) GS:ffff88011f800000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f3b7fe7c000 CR3: 00000000cd58d000 CR4: 00000000000406e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process modprobe (pid: 2522, threadinfo ffff8801009f0000, task ffff8801009a93a0) Stack: ffff8801009f1e58 ffffffff812e8f6e ffff8801009f1e58 ffffffff812e7a80 ffff880000000010 ffff880103920400 ffff8801002fd0c0 ffff880103920468 0000000000000011 ffff880103920400 ffff8801009f1e48 ffffffff8115ab6a Call Trace: [<ffffffff812e8f6e>] ? device_add+0x4f1/0x5e4 [<ffffffff812e7a80>] ? dev_set_name+0x41/0x43 [<ffffffff8115ab6a>] sysfs_create_group+0x13/0x15 [<ffffffff810b857e>] blk_trace_init_sysfs+0x14/0x16 [<ffffffff811ee58b>] blk_register_queue+0x4c/0xfd [<ffffffff811f3bdf>] add_disk+0xe4/0x29c [<ffffffffa007e2ab>] nbd_init+0x2ab/0x30d [nbd] [<ffffffffa007e000>] ? 0xffffffffa007dfff [<ffffffff8100020f>] do_one_initcall+0x7f/0x13e [<ffffffff8107ab0a>] sys_init_module+0xa1/0x1e3 [<ffffffff814f3542>] system_call_fastpath+0x16/0x1b Code: 41 57 41 56 41 55 41 54 53 48 83 ec 28 0f 1f 44 00 00 48 89 fb 41 89 f6 49 89 d4 48 85 ff 74 0b 85 f6 75 0b 48 83 7f 30 00 75 14 <0f> 0b eb fe b9 ea ff ff ff 48 83 7f 30 00 0f 84 09 01 00 00 49 RIP [<ffffffff8115aa08>] internal_create_group+0x2f/0x166 RSP <ffff8801009f1de8> ---[ end trace 753285ffbf72c57c ]--- Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Laurent Vivier <Laurent.Vivier@bull.net> Cc: Paul Clements <Paul.Clements@steeleye.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
