path: root/drivers/block
2009-10-29loop: fix NULL dereference if mount failsAlexey Dobriyan
Commit bb21488482bd36eae6b30b014d93619063773fd4 ("[PATCH] switch loop") started to pass NULL bdev to ioctl hook. Steps to reproduce: [boot with loop.max_part=1] [mount -o loop something so mount fails] BUG: unable to handle kernel NULL pointer dereference at 00000000000000b8 IP: [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 PGD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC last sysfs file: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:35/ACPI0003:00/power_supply/ACAD/online CPU 0 Modules linked in: zfs nvidia(P) [last unloaded: zfs] Pid: 15177, comm: mount Tainted: P 2.6.32-rc4-zfs #2 Satellite X200 RIP: 0010:[<ffffffff811486ee>] [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 RSP: 0018:ffff88003b3d5bb8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 000000000000125f RSI: 0000000000000000 RDI: 0000000000000000 RBP: ffff88003b3d5ce8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 00007ffffffff000 R13: 0000000000000000 R14: ffff880071cef280 R15: 00000000000200da FS: 00007fd77cfe7740(0000) GS:ffff880001600000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000000000b8 CR3: 0000000001001000 CR4: 00000000000026f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process mount (pid: 15177, threadinfo ffff88003b3d4000, task ffff88007572f920) Stack: ffff88003b3d5c38 ffffffff812f95f5 ffff88007eeb6600 0000000000000000 <0> 0000000000000000 ffff88003b3d5c18 ffffffff811547d9 ffff88001bf11ef0 <0> 7fffffffffffffff ffff88001bf11ee8 ffff88001bf11ef0 0000000000000000 Call Trace: [<ffffffff812f95f5>] ? schedule_timeout+0x1f5/0x250 [<ffffffff811547d9>] ? rb_insert_color+0x109/0x140 [<ffffffff812fb754>] ? _spin_unlock_irq+0x14/0x40 [<ffffffff812f84c6>] ? wait_for_common+0x66/0x170 [<ffffffff8105a280>] ? default_wake_function+0x0/0x10 [<ffffffff810f8258>] ioctl_by_bdev+0x38/0x50 [<ffffffff811d2481>] loop_clr_fd+0x1e1/0x210 [<ffffffff811d2522>] lo_release+0x72/0x80 [<ffffffff810f934c>] __blkdev_put+0x1ac/0x1d0 [<ffffffff810f937b>] blkdev_put+0xb/0x10 [<ffffffff810f93b9>] blkdev_close+0x39/0x60 [<ffffffff810ccef3>] __fput+0xd3/0x230 [<ffffffff810cd06d>] fput+0x1d/0x30 [<ffffffff810c9680>] filp_close+0x50/0x80 [<ffffffff81061f11>] put_files_struct+0x81/0x100 [<ffffffff81061fde>] exit_files+0x4e/0x60 [<ffffffff81063ec5>] do_exit+0x6b5/0x730 [<ffffffff8107b279>] ? up_read+0x9/0x10 [<ffffffff8104c86e>] ? do_page_fault+0x18e/0x2a0 [<ffffffff81063f81>] do_group_exit+0x41/0xc0 [<ffffffff81064012>] sys_exit_group+0x12/0x20 [<ffffffff81030deb>] system_call_fastpath+0x16/0x1b Code: f8 48 89 e5 48 81 ec 30 01 00 00 48 89 5d d8 4c 89 6d e8 4c 89 65 e0 4c 89 75 f0 4c 89 7d f8 48 89 bd e8 fe ff ff 49 89 cd 89 f3 <49> 8b 88 b8 00 00 00 81 fa 68 12 00 00 0f 84 57 05 00 00 0f 86 RIP [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 RSP <ffff88003b3d5bb8> CR2: 00000000000000b8 ---[ end trace c0b4d3c3118d1427 ]--- Fixing recursive fault but reboot is needed! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-22virtio_blk: Revert serial number supportRusty Russell
This reverts "Add serial number support for virtio_blk, V4a". Turns out that virtio_pci, lguest and s/390 all have an 8 bit limit on virtio config space, so noone could ever use this. This is coming back later in a cleaner form. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: john cooper <john.cooper@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com>
2009-10-22virtio: let header files include virtio_ids.hChristian Borntraeger
Rusty, commit 3ca4f5ca73057a617f9444a91022d7127041970a virtio: add virtio IDs file moved all device IDs into a single file. While the change itself is a very good one, it can break userspace applications. For example if a userspace tool wanted to get the ID of virtio_net it used to include virtio_net.h. This does no longer work, since virtio_net.h does not include virtio_ids.h. This patch moves all "#include <linux/virtio_ids.h>" from the C files into the header files, making the header files compatible with the old ones. In addition, this patch exports virtio_ids.h to userspace. CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-10-22virtio_blk: revert QUEUE_FLAG_VIRT additionChristoph Hellwig
It seems like the addition of QUEUE_FLAG_VIRT caueses major performance regressions for Fedora users: https://bugzilla.redhat.com/show_bug.cgi?id=509383 https://bugzilla.redhat.com/show_bug.cgi?id=505695 while I can't reproduce those extreme regressions myself I think the flag is wrong. Rationale: QUEUE_FLAG_VIRT expands to QUEUE_FLAG_NONROT which casus the queue unplugged immediately. This is not a good behaviour for at least qemu and kvm where we do have significant overhead for every I/O operations. Even with all the latested speeups (native AIO, MSI support, zero copy) we can only get native speed for up to 128kb I/O requests we already are down to 66% of native performance for 4kb requests even on my laptop running the Intel X25-M SSD for which the QUEUE_FLAG_NONROT was designed. If we ever get virtio-blk overhead low enough that this flag makes sense it should only be set based on a feature flag set by the host. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-10-13cciss: Add cciss_allow_hpsa module parameterStephen M. Cameron
Add cciss_allow_hpsa module parameter. This parameter causes the cciss driver to ignore any Smart Array devices known to be supported by the hpsa driver. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-13cciss: Fix multiple calls to pci_release_regionsStephen M. Cameron
Fix multiple calls to pci_release_regions. If cciss_pci_init fails, it already does any necessary call to pci_release_regions, so this does not need to be done again in cciss_init_one in that case. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-04Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (41 commits) Revert "Seperate read and write statistics of in_flight requests" cfq-iosched: don't delay async queue if it hasn't dispatched at all block: Topology ioctls cfq-iosched: use assigned slice sync value, not default cfq-iosched: rename 'desktop' sysfs entry to 'low_latency' cfq-iosched: implement slower async initiate and queue ramp up cfq-iosched: delay async IO dispatch, if sync IO was just done cfq-iosched: add a knob for desktop interactiveness Add a tracepoint for block request remapping block: allow large discard requests block: use normal I/O path for discard requests swapfile: avoid NULL pointer dereference in swapon when s_bdev is NULL fs/bio.c: move EXPORT* macros to line after function Add missing blk_trace_remove_sysfs to be in pair with blk_trace_init_sysfs cciss: fix build when !PROC_FS block: Do not clamp max_hw_sectors for stacking devices block: Set max_sectors correctly for stacking devices cciss: cciss_host_attr_groups should be const cciss: Dynamically allocate the drive_info_struct for each logical drive. cciss: Add usage_count attribute to each logical drive in /sys ...
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01cciss: fix build when !PROC_FSAlexander Beregalov
Fix these build errors when CONFIG_PROC_FS is not set: drivers/block/cciss.c: In function 'cciss_show_raid_level': drivers/block/cciss.c:623: error: 'RAID_UNKNOWN' undeclared (first use in this function) drivers/block/cciss.c:626: error: 'raid_label' undeclared (first use in this function) drivers/block/cciss.c: In function 'cciss_geometry_inquiry': drivers/block/cciss.c:2696: error: 'RAID_UNKNOWN' undeclared (first use in this function) Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: cciss_host_attr_groups should be constJens Axboe
2009-10-01cciss: Dynamically allocate the drive_info_struct for each logical drive.Stephen M. Cameron
cciss: Dynamically allocate the drive_info_struct for each logical drive. This reduces the size of the per-hba ctlr_info structure from 106936 bytes to 8132 bytes. That's on 32-bit systems. On 64-bit systems, the improvement is even bigger. Without this, the ctlr_info struct is so big that the driver won't even load on a 64 bit system if CISS_MAX_LUN was at it's current setting of 1024 logical drives. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Add usage_count attribute to each logical drive in /sysStephen M. Cameron
Add usage_count attribute to each logical drive at /sys/devices/<dev>/ccissX/cXdY/usage_count for controller X, logical drive Y. The usage count is the number of times the device has currently been opened. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Add a "raid_level" attribute to each logical drive in /sysStephen M. Cameron
and change get rid of some magic numbers in raid lavel decoding. Add raid_level attribute to each logical drive at /sys/devices/<dev>/ccissX/cXdY/raid_level for controller X, logical drive Y Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: fix some magic numbers in the raid-level decodingStephen M. Cameron
cciss: fix some magic numbers in the raid-level decoding Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Add lunid attribute to each logical drive in /sysStephen M. Cameron
Add lunid attribute to each logical drive at /sys/devices/<dev>/ccissX/cXdY/lunid for controller X, logical drive Y Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Don't check h->busy_initializing in cciss_open().Stephen M. Cameron
Don't check h->busy_initializing in cciss_open(). Open won't be called before things are ready, but h->busy_initializing won't be unset until after the initial rebuild_lun_table is finished. But, to read the partitions, cciss_open will be called for each logical drive during rebuild_lun_table. If cciss_open checks h->busy_initializing, then the reading of the partition information during the initial rebuild_lun_table will fail, which is especially bad news if it happens to be your boot device. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Preserve all 8 bytes of LUN ID for logical drives.Stephen M. Cameron
Preserve all 8 bytes of the LunID field returned by CCISS_REPORT_LOGICAL instead of only saving 4 bytes. This fixes a bug with logical volume addressing encountered on an MSA2012. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Silence noisy per-disk messages output by cciss_read_capacityStephen M. Cameron
Silence noisy per-disk messages output by cciss_read_capacity Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Fix excessive gendisk freeing bug on driver unload.Stephen M. Cameron
Fix bug that free_hba was calling put_disk for all gendisk[] pointers -- all 1024 of them -- regardless of whether the were used or not (NULL). This bug could cause rmmod to oops if logical drives had been deleted during the driver's lifetime. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Fix usage_count check in rebuild_lun_table when triggered via sysfs.Stephen M. Cameron
When rebuild_lun_table is reached via sysfs, the usage count that is checked prior to messing with c0d0 has different constraints (must be zero) than if rebuild_lun_table is reached via ioctl (must be one.) Fix rebuild_lun_table to take that into account. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Clear all sysfs-exposed data for deleted logical drives.Stephen M. Cameron
When removing a logical drive, clear all the information that is now exposed by sysfs (e.g. vendor, model, serial number.) Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Handle special case for sysfs attributes of the first logical drive.Stephen M. Cameron
For c0dx where x is not 0, we handle deletion and addition simply, but for c0d0, there is the special case that even when there's no disk, the device node exists so that the controller may be accessed. So, for c0d0, we only create the sysfs entries once, when a controller is added, and only remove them once, when a controller is being taken down. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Handle cases when cciss_add_disk fails.Stephen M. Cameron
Handle cases when cciss_add_disk fails. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Handle failure of blk_init_queue gracefully in cciss_add_disk.Stephen M. Cameron
Handle failure of blk_init_queue gracefully in cciss_add_disk. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Rearrange logical drive sysfs code to make the "changing a disk" path ↵Stephen M. Cameron
work. Rearrange logical drive sysfs code to make the "changing a disk" path work. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Dynamically allocate struct device for each logical drive as needed.Stephen M. Cameron
Dynamically allocate struct device for each logical drive as needed instead of allocating the maximum we would ever need at driver init time. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Remove some unused code in rebuild_lun_table()Stephen M. Cameron
Remove some unused code in rebuild_lun_table() Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Allow triggering of rescan of logical drive topology via sysfs entryAndrew Patterson
Added /sys/bus/pci/devices/<dev>/ccissX/rescan sysfs entry used to kick off a rescan that discovers logical drive topology changes. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Use one scan thread per controller and fix hang during rmmodAndrew Patterson
Replace the use of one scan kthread per controller with one per driver. Use a queue to hold a list of controllers that need to be rescanned with routines to add and remove controllers from the queue. Fix locking and completion handling to prevent a hang during rmmod. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: Remove sysfs entries for logical drives on driver cleanup.Andrew Patterson
Sysfs entries for logical drives need to be removed when a drive is deleted during driver cleanup. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cciss: fix schedule_timeout() parametersRandy Dunlap
Change schedule_timeout() parameter to not be specific to HZ=1000. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Mike Miller <mike.miller@hp.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: "Cameron, Steve" <Steve.Cameron@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01dac960: switch to seq_fileAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Yang Hongyang <yanghy@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01cpqarray: switch to seq_fileAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Chirag Kantharia <chirag.kantharia@hp.com> Cc: Tejun Heo <tj@kernel.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: don't force VIRTIO_F_NOTIFY_ON_EMPTY lguest: cleanup for map_switcher() lguest: use PGDIR_SHIFT for PAE code to allow different PAGE_OFFSET lguest: use set_pte/set_pmd uniformly for real page table entries lguest: move panic notifier registration to its expected place. virtio_blk: add support for cache flush virtio: add virtio IDs file virtio: get rid of redundant VIRTIO_ID_9P definition virtio: make add_buf return capacity remaining virtio_pci: minor MSI-X cleanups
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23dac960: fix undefined behavior on empty stringMichael Buesch
Fix undefined behavior due to a buffer underrun if an empty string is written to the proc file. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23virtio_blk: add support for cache flushChristoph Hellwig
Recent qemu has added a VIRTIO_BLK_F_FLUSH flag to advertise that the virtual disk has a volatile write cache that needs to be flushed. In case we see this feature implement tell the Linux block layer about the fact and use the new VIRTIO_BLK_T_FLUSH to flush the cache when required. This allows for an correct and simple implementation of write barriers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: add virtio IDs fileFernando Luis Vazquez Cao
Virtio IDs are spread all over the tree which makes assigning new IDs bothersome. Putting them together should make the process less error-prone. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: make add_buf return capacity remainingRusty Russell
This API change means that virtio_net can tell how much capacity remains for buffers. It's necessarily fuzzy, since VIRTIO_RING_F_INDIRECT_DESC means we can fit any number of descriptors in one, *if* we can kmalloc. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dinesh Subhraveti <dineshs@us.ibm.com>
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: add __init/__exit macros to DAC960.cPeter Huewe
Trivial patch which adds the __init and __exit macros to the module_init / module_exit functions from drivers/block/DAC960.c Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-19Driver-Core: extend devnode callbacks to provide permissionsKay Sievers
This allows subsytems to provide devtmpfs with non-default permissions for the device node. Instead of the default mode of 0600, null, zero, random, urandom, full, tty, ptmx now have a mode of 0666, which allows non-privileged processes to access standard device nodes in case no other userspace process applies the expected permissions. This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: Driver Core: devtmpfs - kernel-maintained tmpfs-based /dev debugfs: Modify default debugfs directory for debugging pktcdvd. debugfs: Modified default dir of debugfs for debugging UHCI. debugfs: Change debugfs directory of IWMC3200 debugfs: Change debuhgfs directory of trace-events-sample.h debugfs: Fix mount directory of debugfs by default in events.txt hpilo: add poll f_op hpilo: add interrupt handler hpilo: staging for interrupt handling driver core: platform_device_add_data(): use kmemdup() Driver core: Add support for compatibility classes uio: add generic driver for PCI 2.3 devices driver-core: move dma-coherent.c from kernel to driver/base mem_class: fix bug mem_class: use minor as index instead of searching the array driver model: constify attribute groups UIO: remove 'default n' from Kconfig Driver core: Add accessor for device platform data Driver core: move dev_get/set_drvdata to drivers/base/dd.c Driver core: add new device to bus's list before probing
2009-09-15Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (134 commits) powerpc/nvram: Enable use Generic NVRAM driver for different size chips powerpc/iseries: Fix oops reading from /proc/iSeries/mf/*/cmdline powerpc/ps3: Workaround for flash memory I/O error powerpc/booke: Don't set DABR on 64-bit BookE, use DAC1 instead powerpc/perf_counters: Reduce stack usage of power_check_constraints powerpc: Fix bug where perf_counters breaks oprofile powerpc/85xx: Fix SMP compile error and allow NULL for smp_ops powerpc/irq: Improve nanodoc powerpc: Fix some late PowerMac G5 with PCIe ATI graphics powerpc/fsl-booke: Use HW PTE format if CONFIG_PTE_64BIT powerpc/book3e: Add missing page sizes powerpc/pseries: Fix to handle slb resize across migration powerpc/powermac: Thermal control turns system off too eagerly powerpc/pci: Merge ppc32 and ppc64 versions of phb_scan() powerpc/405ex: support cuImage via included dtb powerpc/405ex: provide necessary fixup function to support cuImage powerpc/40x: Add support for the ESTeem 195E (PPC405EP) SBC powerpc/44x: Add Eiger AMCC (AppliedMicro) PPC460SX evaluation board support. powerpc/44x: Update Arches defconfig powerpc/44x: Update Arches dts ... Fix up conflicts in drivers/char/agp/uninorth-agp.c
2009-09-15debugfs: Modify default debugfs directory for debugging pktcdvd.GeunSik Lim
As we all know, We need change default directory for consistency of debugfs by Greg K-H Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15driver model: constify attribute groupsDavid Brownell
Let attribute group vectors be declared "const". We'd like to let most attribute metadata live in read-only sections... this is a start. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (23 commits) at_hdmac: Rework suspend_late()/resume_early() PM: Reset transition_started at dpm_resume_noirq PM: Update kerneldoc comments in drivers/base/power/main.c PM: Add convenience macro to make switching to dev_pm_ops less error-prone hp-wmi: Switch driver to dev_pm_ops floppy: Switch driver to dev_pm_ops PM: Trivial fixes PM / Hibernate / Memory hotplug: Always use for_each_populated_zone() PM/Hibernate: Do not try to allocate too much memory too hard (rev. 2) PM/Hibernate: Do not release preallocated memory unnecessarily (rev. 2) PM/Hibernate: Rework shrinking of memory PM: Fix typo in label name s/Platofrm_finish/Platform_finish/ PM: Run-time PM platform device bus support PM: Introduce core framework for run-time PM of I/O devices (rev. 17) Driver Core: Make PM operations a const pointer PM: Remove platform device suspend_late()/resume_early() V2 USB: Rework musb suspend()/resume_early() I2C: Rework i2c-s3c2410 suspend_late()/resume() V2 I2C: Rework i2c-pxa suspend_late()/resume_early() DMA: Rework txx9dmac suspend_late()/resume_early() ... Fix trivial conflict in drivers/base/platform.c (due to same constification patch being merged in both sides, along with some other PM work in the PM branch)
2009-09-14Merge branch 'for-2.6.32' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.32' of git://git.kernel.dk/linux-2.6-block: (29 commits) block: use blkdev_issue_discard in blk_ioctl_discard Make DISCARD_BARRIER and DISCARD_NOBARRIER writes instead of reads block: don't assume device has a request list backing in nr_requests store block: Optimal I/O limit wrapper cfq: choose a new next_req when a request is dispatched Seperate read and write statistics of in_flight requests aoe: end barrier bios with EOPNOTSUPP block: trace bio queueing trial only when it occurs block: enable rq CPU completion affinity by default cfq: fix the log message after dispatched a request block: use printk_once cciss: memory leak in cciss_init_one() splice: update mtime and atime on files block: make blk_iopoll_prep_sched() follow normal 0/1 return convention cfq-iosched: get rid of must_alloc flag block: use interrupts disabled version of raise_softirq_irqoff() block: fix comment in blk-iopoll.c block: adjust default budget for blk-iopoll block: fix long lines in block/blk-iopoll.c block: add blk-iopoll, a NAPI like approach for block devices ...
