Today I noticed that the usb bluetooth adapter (BCM2046B1) on my 2011
mac mini was not working. I've created a patch to get it going.
Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
This patch against current git adds the hardware ID for the Apple
MacBookAir4,1, released in July 2011. The device features a BCM2046
USB chip. The patch was inspired by the previous modifications adding
support for the MacBookAir3,x.
Signed-off-by: Pieter-Augustijn Van Malleghem <p-a@scarlet.be>
Blacklist Toshiba-branded AR3011 based AR5B195 [0930:0215] and add to
ath3k.c for firmware loading.
Signed-off-by: Ricardo Mendoza <ricmm@gentoo.org>
Disabling the bluetooth usb device embedded in (some) ThinkPads tends to
lead to errors like these:
btusb_bulk_complete: hci0 urb ffff88011b9bfd68 failed to resubmit (19)
btusb_intr_complete: hci0 urb ffff88011b46a318 failed to resubmit (19)
btusb_bulk_complete: hci0 urb ffff88011b46a000 failed to resubmit (19)
That is because usb_disconnect() doesn't "quiesces" pending urbs.
Disconnecting a device is a normal thing to happen so it's no big deal
that usb_submit_urb() returns -ENODEV. The simplest way to get rid of
these errors is to stop treating that return as an error. Trivial,
actually.
While we're at it, add comments to be explicit about the reasons we're
not complaining about -EPERM and -ENODEV.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The new Ath3k needs to download patch and radio table,
and it keeps same PID/VID even after downloading the patch and radio
table. This patch is to use the bcdDevice (Device Release Number) to
judge whether the chip has been patched or not. The init bcdDevice
value of the chip is 0x0001, this value increases after patch and
radio table downloading.
Signed-off-by: Steven.Li <yongli@qca.qualcomm.com>
New ath3k device IDs used on the Pegatron Lucid (ExoPC and WeTab) units.
Signed-off-by: Andy Ross <andy.ross@windriver.com>
Now that we have support for LE connections, before discarding a
frame we must check if there's a LE connection over that transport.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Acked-by: Ville Tervo <ville.tervo@nokia.com>
Just adding the vendor details makes it work fine.
Signed-off-by: Marc-Antoine Perennou <Marc-Antoine@Perennou.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
drivers/net/bnx2x/bnx2x.h
This reverts commit 556ea928f78a390fe16ae584e6433dff304d3014.
Jeff Chua reports that it can cause some bluetooth devices (he mentions
an Bluetooth Intermec scanner) to just stop responding after a while
with messages like
[ 4533.361959] btusb 8-1:1.0: no reset_resume for driver btusb?
[ 4533.361964] btusb 8-1:1.1: no reset_resume for driver btusb?
from the kernel. See also
https://bugzilla.kernel.org/show_bug.cgi?id=26182
for other reports.
Reported-by: Jeff Chua <jeff.chua.linux@gmail.com>
Reported-by: Andrew Meakovski <meako@bigmir.net>
Reported-by: Jim Faulkner <jfaulkne@ccs.neu.edu>
Acked-by: Greg KH <gregkh@suse.de>
Acked-by: Matthew Garrett <mjg@redhat.com>
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi>
Cc: stable@kernel.org (for 2.6.37)
drivers/bluetooth/ath3k.c
drivers/bluetooth/btusb.c
Instead set urb structure directly we call usb_fill_int_urb() to set the
values to us.
Add the btusb.c blacklist [0489:e02c] for Atheros AR5BBU12 BT
and add to ath3k.c supported this device.
Signed-off-by: Cho, Yu-Chen <acho@novell.com>
Quirky dongles sometimes do not use the iso interface which
causes a crash with runtime PM
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Blacklisted AR3012 PID in btusb and added the same
in ath3k to load patch and sysconfig files.
Signed-off-by: Bala Shanmugam <sbalashanmugam@atheros.com>
Add the btusb.c blacklist [03f0:311d] for Atheros AR9285 Malbec BT
and add to ath3k.c ath3-1.fw (md5:1211fa34c09e10ba48381586b7c3883d)
Fix a bunch of
warning: ‘inline’ is not at beginning of declaration
messages when building a 'make allyesconfig' kernel with -Wextra.
These warnings are trivial to kill, yet rather annoying when building with
-Wextra.
The more we can cut down on pointless crap like this the better (IMHO).
A previous patch to do this for a 'allnoconfig' build has already been
merged. This just takes the cleanup a little further.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Atheros 3011 has small sflash firmware and needs to be
blacklisted in transport driver to load actual firmware
in DFU driver.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
If a device is autosuspended an inability to resubmit URBs is
to be expected. Check the error code and only log real errors.
(Now that autosuspend is default enabled for btusb, those log
messages were happening all the time e.g. with a BT mouse)
Signed-off-by: Stefan Seyfried <seife+kernel@b1-systems.com>
Adding the new MacBookAir3,1(2) to btusb.
Output without the patch and btusb loaded :
T: Bus=03 Lev=02 Prnt=03 Port=02 Cnt=01 Dev#= 6 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=05ac ProdID=821b Rev= 0.34
S: Manufacturer=Apple Inc.
S: Product=Bluetooth USB Host Controller
C:* #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=(none)
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
E: Ad=83(I) Atr=01(Isoc) MxPS= 32 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 32 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
E: Ad=83(I) Atr=01(Isoc) MxPS= 64 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 64 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=84(I) Atr=02(Bulk) MxPS= 32 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 32 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=01 Driver=(none)
Output with the patch and btusb loaded :
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=btusb
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
Signed-off-by: Edgar (gimli) Hucek <gimli@dark-green.com>
We've done this for a while in Fedora without any obvious problems other
than some interaction with input devices. Those should be fixed now, so
let's try this in mainline.
Bluetooth controller of MacbookPro 7,1 does not work.
Because Device Class of these controllers was set 255 (Vendor Sepecific Class).
T: Bus=04 Lev=02 Prnt=04 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=05ac ProdID=8213 Rev=01.86
S: SerialNumber=5C5948C81B99
C: #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=00 Driver=(none)
Bluetooth controller of MacbookPro 6,2 does not work.
T: Bus=01 Lev=03 Prnt=03 Port=02 Cnt=03 Dev#= 8 Spd=12 MxCh= 0
P: Vendor=05ac ProdID=8218 Rev=00.22
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=(none)
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
I: If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=01 Driver=(none)
did_iso_resume keeps only a bit-field value, so moving that to a proper
flags place.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Device class is ff(vend.) instead of e0(wlcon).
Output from command `usb-devices`:
T: Bus=01 Lev=03 Prnt=03 Port=00 Cnt=01 Dev#= 6 Spd=12 MxCh= 0
P: Vendor=05ac ProdID=8215 Rev=01.82
S: SerialNumber=7C6D62936607
Signed-off-by: Cyril Lacoux <clacoux@ifeelgood.org>
The hdev->type is misnamed and should be actually hdev->bus instead. So
convert it now.
The device must be marked busy as it receives data.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Tested-by: Matthew Garrett <mjg@redhat.com>
This patch (as1302) removes the auto_pm flag from struct usb_device.
The flag's only purpose was to distinguish between autosuspends and
external suspends, but that information is now available in the
pm_message_t argument passed to suspend methods.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
If the waker is killed before it can replay outstanding URBs, these URBs
won't be freed or will be replayed at the next open. This patch closes
the window by explicitely discarding outstanding URBs.
Rafael debugged a resume-time hang (with oopses in workqueue handling)
on his laptop that was due to the 'waker' workqueue entry being
disconnected and then released without the workqueue entry having been
synchronized.
Several people were involved, with Oleg Nesterov doing a debugging patch
showing what workqueue entry was corrupt etc.
This was a regression introduced by commit 7bee549e19 ("Bluetooth: Add
USB autosuspend support to btusb driver") as Rafael points out (not
actually bisected, but it became clear once the bug was found).
Tested-and-reported-by: Rafael J. Wysocki <rjw@sisk.pl>
Acked-by: Oliver Neukum <oliver@neukum.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Marcel Holtmann <marcel@holtmann.org>
This patch adds support of USB autosuspend to the btusb driver.
If the device doesn't support remote wakeup, simple support based on
up/down is provided. If the device supports remote wakeup, additional
support for autosuspend while the interface is up is provided. This is
done by queueing URBs in an anchor structure and waking the device up
from a work queue on sending. Reception triggers remote wakeup.
The last busy facility of the USB autosuspend code is used. To close
a race between autosuspend and transmission, a counter of ongoing
transmissions is maintained.
Add #ifdefs for CONFIG_PM as necessary.
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
This patch increases the receive buffer size to HCI_MAX_FRAME_SIZE
which improves the RX throughput considerably.
Tested against BRM/Atheros/CSR USB Dongles with PAN profile using
iperf and chariot. This gave significant (around 40%) increase
in performance (increased from 0.8 to 1.5 Mb/s in Sheld room)
Signed-off-by: Vikram Kandukuri <vikram.kandukuri@atheros.com>
Submitting the bulk URBs for ACL data transfers only on demand has no
real benefit compared to just submit them when a Bluetooth device gets
opened. So when submitting the interrupt URBs for HCI events, just
submit the bulk URBs, too.
This solves a problem with some Bluetooth USB dongles that has been
reported over the last few month. These devices require that the bulk
URBs are actually present. These devices are really broken, but there
is nothing we can do about it.
With the introduction of CONFIG_DYNAMIC_PRINTK_DEBUG it is possible to
allow debugging without having to recompile the kernel. This patch turns
all BT_DBG() calls into pr_debug() to support dynamic debug messages.
As a side effect all CONFIG_BT_*_DEBUG statements are now removed and
some broken debug entries have been fixed.
This patch allows the Asus WL-BTD202 dongle to be used with a mono
headset without having to specify "options btusb force_scofix=1".
Based on a patch from Guillaume Bedot <littletux@zarb.org>
The Bluetooth subsystem was not using the HCI Reset command when doing
device initialization. The Bluetooth 1.0b specification was ambiguous
on how the device firmware was suppose to handle it. Almost every device
was triggering a transport reset at the same time. In case of USB this
ended up in disconnects from the bus.
All modern Bluetooth dongles handle this perfectly fine and a lot of
them actually require that HCI Reset is sent. If not then they are
either stuck in their HID Proxy mode or their internal structures for
inquiry and paging are not correctly setup.
To handle old and new devices smoothly the Bluetooth subsystem contains
a quirk to force the HCI Reset on initialization. However maintaining
such a quirk becomes more and more complicated. This patch turns the
logic around and lets the old devices disable the HCI Reset command.
The only device where the HCI_QUIRK_NO_RESET is still needed are the
original Digianswer devices and dongles with an early CSR firmware.
CSR reported that they fixed this for version 12 firmware. The last
official release of version 11 firmware is build ID 115. The first
version 12 candidate was build ID 117.
During suspend it is important that all URBs are cancelled and then on
resume re-submitted. This gives initial suspend/resume support.
Based on initial work from Oliver Neukum <oneukum@suse.de>
With the addition of usb_unlink_anchored_urbs() it is possible to fully
control the bulk URBs from the notify callback. There is no need to
schedule work and so only do this for the ISOC URBs.
The URB submission routines need more fine grained control for the
mem_flags used by kmalloc(), usb_alloc_urb() and usb_submit_urb() to
better support different caller situations. Add a mem_flags parameter
and give the caller full control.
The new A-Link Bluetooth dongle is another one based on the BCM2046 chip
from Broadcom and it also needs to send HCI_Reset before it becomes fully
operational. Without the quirk it will show a lot of I/O errors.
Targus and Belkin have come out with new Bluetooth 2.1 capable dongles
using the latest BCM2046 chip from Broadcom. Both of them are so called
HID proxy dongles and they need to send HCI_Reset before they become
fully operational.
The transfer buffer of an URB will be automatically freed when using
the URB_FREE_BUFFER transfer_flag. So the extra calls to kfree() will
cause a double free.
Reported-by: Justin Mattock <justinmattock@gmail.com>
Signed-off-by: Rabin Vincent <rabin@rab.in>
The USB transport specification for Bluetooth splits the ACL and SCO
handling into two separate interfaces. In Linux it possible to probe
and disconnect these interfaces independently. So make sure that both
interfaces are tightly bound together.
This fixes the suspend regression that some people have expierenced.
The btusb driver contains two typos that result in some buggy behavior,
but the impact is not immediately visible.
During initialization the submitting of interrupt URBs might fail and
then make sure to remove the correct flag and not one of the hci_dev
flags.
When closing down the interface make sure to kill the anchor for the
ISOC URBs and not kill the interrupt URBs twice.
Also cancel any scheduled work when closing down the interface.
The newer MacBooks contain a Broadcom based Bluetooth chip and to make
this work properly, HCI_Reset must be send first. If HCI_Reset is not
used then a lot of I/O errors show up and its triggers packets from
non-existent ACL links.
The new generic driver for Bluetooth USB devices was missing proper
SCO support. The driver now claims the second interface for these USB
devices to allow the flow of SCO packets. It also handles switching
of the alternate setting and re-submission of isochronous URBs.
The btusb driver is now a full replacement for hci_usb and thus the
experimental tag has been removed and this driver is promoted as
preferred one.
This implements all the quirk handling from the hci_usb driver to the
new btusb driver.
This patch adds a new generic driver for Bluetooth USB devices. This
driver is still experimental at this point, but it is cleaner and
easier to maintain than the current Bluetooth USB driver. It is a
much better starting point for power management improvements.
