Linux 4.1.41
* tag 'v4.1.41': (473 commits)
Linux 4.1.41
mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thp
xc2028: Fix use-after-free bug properly
iio: proximity: as3935: fix as3935_write
ipx: call ipxitf_put() in ioctl error path
sched/fair: Initialize throttle_count for new task-groups lazily
sched/fair: Do not announce throttled next buddy in dequeue_task_fair()
iio: dac: ad7303: fix channel description
mwifiex: pcie: fix cmd_buf use-after-free in remove/reset
rtlwifi: rtl8821ae: setup 8812ae RFE according to device type
ARM: tegra: paz00: Mark panel regulator as enabled on boot
fs/xattr.c: zero out memory copied to userspace in getxattr
vfio/type1: Remove locked page accounting workqueue
crypto: algif_aead - Require setkey before accept(2)
staging: gdm724x: gdm_mux: fix use-after-free on module unload
drm/ttm: fix use-after-free races in vm fault handling
f2fs: sanity check segment count
ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf
ipv6: initialize route null entry in addrconf_init()
rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME string
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit 441ad62d6c3f131f1dbd7dcdd9cbe3f74dbd8501 ]
T: Bus=01 Lev=01 Prnt=01 Port=07 Cnt=04 Dev#= 5 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=04ca ProdID=3018 Rev=00.01
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
Signed-off-by: Dmitry Tunin <hanipouspilot@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: stable@vger.kernel.org
Linux 4.1.33
* tag 'v4.1.33': (1760 commits)
Linux 4.1.33
Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()"
x86/AMD: Apply erratum 665 on machines without a BIOS fix
x86/paravirt: Do not trace _paravirt_ident_*() functions
ovl: listxattr: use strnlen()
ovl: remove posix_acl_default from workdir
serial: 8250: added acces i/o products quad and octal serial cards
sysfs: correctly handle read offset on PREALLOC attrs
sysfs: correctly handle short reads on PREALLOC attrs.
kernfs: don't depend on d_find_any_alias() when generating notifications
dm crypt: fix free of bad values after tfm allocation failure
dm crypt: fix error with too large bios
dm log writes: fix check of kthread_run() return value
dm log writes: fix bug with too large bios
dm log writes: move IO accounting earlier to fix error path
NFSv4.x: Fix a refcount leak in nfs_callback_up_net
xfs: prevent dropping ioend completions during buftarg wait
xfs: fix superblock inprogress check
USB: serial: option: add WeTelecom 0x6802 and 0x6803 products
USB: avoid left shift by -1
[ Upstream commit 12d868964f7352e8b18e755488f7265a93431de1 ]
T: Bus=01 Lev=01 Prnt=01 Port=07 Cnt=05 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3490 Rev=00.01
BugLink: https://bugs.launchpad.net/bugs/1600623
[ Upstream commit 72f9f8b58bc743e6b6abdc68f60db98486c3ffcf ]
Add hw id to ath3k usb device list and btusb blacklist
T: Bus=01 Lev=01 Prnt=01 Port=08 Cnt=02 Dev#= 4 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3487 Rev=00.02
Requires these firmwares:
ar3k/AthrBT_0x11020100.dfu and ar3k/ramps_0x11020100_40.dfu
Firmwares are available in linux-firmware.
Device found in a laptop ASUS model N552VW. It's an Atheros AR9462 chip.
Signed-off-by: Lauro Costa <lauro@polilinux.com.br>
[ Upstream commit c7c999cb18da88a881e10e07f0724ad0bfaff770 ]
hci_vhci driver creates a hci device object dynamically upon each
HCI_VENDOR_PKT write. Although it checks the already created object
and returns an error, it's still racy and may build multiple hci_dev
objects concurrently when parallel writes are performed, as the device
tracks only a single hci_dev object.
This patch introduces a mutex to protect against the concurrent device
creations.
Cc: <stable@vger.kernel.org>
[ Upstream commit 13407376b255325fa817798800117a839f3aa055 ]
The write handler allocates skbs and queues them into data->readq.
Read side should read them, if there is any. If there is none, skbs
should be dropped by hdev->flush. But this happens only if the device
is HCI_UP, i.e. hdev->power_on work was triggered already. When it was
not, skbs stay allocated in the queue when /dev/vhci is closed. So
purge the queue in ->release.
Program to reproduce:
#include <err.h>
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <sys/uio.h>
int main()
char buf[] = { 0xff, 0 };
struct iovec iov = {
.iov_base = buf,
.iov_len = sizeof(buf),
int fd;
while (1) {
fd = open("/dev/vhci", O_RDWR);
if (fd < 0)
err(1, "open");
usleep(50);
if (writev(fd, &iov, 1) < 0)
err(1, "writev");
usleep(50);
close(fd);
return 0;
Result:
kmemleak: 4609 new suspected memory leaks
unreferenced object 0xffff88059f4d5440 (size 232):
comm "vhci", pid 1084, jiffies 4294912542 (age 37569.296s)
hex dump (first 32 bytes):
20 f0 23 87 05 88 ff ff 20 f0 23 87 05 88 ff ff .#..... .#.....
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff81ece010>] __alloc_skb+0x0/0x5a0
[<ffffffffa021886c>] vhci_create_device+0x5c/0x580 [hci_vhci]
[<ffffffffa0219436>] vhci_write+0x306/0x4c8 [hci_vhci]
Fixes: 23424c0d31 (Bluetooth: Add support creating virtual AMP controllers)
Cc: stable 3.13+ <stable@vger.kernel.org>
[ Upstream commit 373a32c848ae3a1c03618517cce85f9211a6facf ]
Both vhci_get_user and vhci_release race with open_timeout work. They
both contain cancel_delayed_work_sync, but do not test whether the
work actually created hdev or not. Since the work can be in progress
and _sync will wait for finishing it, we can have data->hdev allocated
when cancel_delayed_work_sync returns. But the call sites do 'if
(data->hdev)' *before* cancel_delayed_work_sync.
As a result:
* vhci_get_user allocates a second hdev and puts it into
data->hdev. The former is leaked.
* vhci_release does not release data->hdev properly as it thinks there
is none.
Fix both cases by moving the actual test *after* the call to
This can be hit by this program:
#include <err.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <unistd.h>
int main(int argc, char **argv)
int fd;
srand(time(NULL));
while (1) {
const int delta = (rand() % 200 - 100) * 100;
if (fd < 0)
err(1, "open");
usleep(1000000 + delta);
close(fd);
return 0;
And the result is:
BUG: KASAN: use-after-free in skb_queue_tail+0x13e/0x150 at addr ffff88006b0c1228
Read of size 8 by task kworker/u13:1/32068
BUG kmalloc-192 (Tainted: G E ): kasan: bad access detected
Disabling lock debugging due to kernel taint
INFO: Allocated in vhci_open+0x50/0x330 [hci_vhci] age=260 cpu=3 pid=32040
kmem_cache_alloc_trace+0x150/0x190
misc_open+0x35b/0x4e0
chrdev_open+0x23b/0x510
INFO: Freed in vhci_release+0xa4/0xd0 [hci_vhci] age=9 cpu=2 pid=32040
__slab_free+0x204/0x310
INFO: Slab 0xffffea0001ac3000 objects=16 used=13 fp=0xffff88006b0c1e00 flags=0x5fffff80004080
INFO: Object 0xffff88006b0c1200 @offset=4608 fp=0xffff88006b0c0600
Bytes b4 ffff88006b0c11f0: 09 df 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff88006b0c1200: 00 06 0c 6b 00 88 ff ff 00 00 00 00 00 00 00 00 ...k............
Object ffff88006b0c1210: 10 12 0c 6b 00 88 ff ff 10 12 0c 6b 00 88 ff ff ...k.......k....
Object ffff88006b0c1220: c0 46 c2 6b 00 88 ff ff c0 46 c2 6b 00 88 ff ff .F.k.....F.k....
Object ffff88006b0c1230: 01 00 00 00 01 00 00 00 e0 ff ff ff 0f 00 00 00 ................
Object ffff88006b0c1240: 40 12 0c 6b 00 88 ff ff 40 12 0c 6b 00 88 ff ff @..k....@..k....
Object ffff88006b0c1250: 50 0d 6e a0 ff ff ff ff 00 02 00 00 00 00 ad de P.n.............
Object ffff88006b0c1260: 00 00 00 00 00 00 00 00 ab 62 02 00 01 00 00 00 .........b......
Object ffff88006b0c1270: 90 b9 19 81 ff ff ff ff 38 12 0c 6b 00 88 ff ff ........8..k....
Object ffff88006b0c1280: 03 00 20 00 ff ff ff ff ff ff ff ff 00 00 00 00 .. .............
Object ffff88006b0c1290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff88006b0c12a0: 00 00 00 00 00 00 00 00 00 80 cd 3d 00 88 ff ff ...........=....
Object ffff88006b0c12b0: 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 . ..............
Redzone ffff88006b0c12c0: bb bb bb bb bb bb bb bb ........
Padding ffff88006b0c13f8: 00 00 00 00 00 00 00 00 ........
CPU: 3 PID: 32068 Comm: kworker/u13:1 Tainted: G B E 4.4.6-0-default #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.8.1-0-g4adadbd-20151112_172657-sheep25 04/01/2014
Workqueue: hci0 hci_cmd_work [bluetooth]
00000000ffffffff ffffffff81926cfa ffff88006be37c68 ffff88006bc27180
ffff88006b0c1200 ffff88006b0c1234 ffffffff81577993 ffffffff82489320
ffff88006bc24240 0000000000000046 ffff88006a100000 000000026e51eb80
Call Trace:
[<ffffffff81ec8ebe>] ? skb_queue_tail+0x13e/0x150
[<ffffffffa06e027c>] ? vhci_send_frame+0xac/0x100 [hci_vhci]
[<ffffffffa0c61268>] ? hci_send_frame+0x188/0x320 [bluetooth]
[<ffffffffa0c61515>] ? hci_cmd_work+0x115/0x310 [bluetooth]
[<ffffffff811a1375>] ? process_one_work+0x815/0x1340
[<ffffffff811a1f85>] ? worker_thread+0xe5/0x11f0
[<ffffffff811a1ea0>] ? process_one_work+0x1340/0x1340
[<ffffffff811b3c68>] ? kthread+0x1c8/0x230
Memory state around the buggy address:
ffff88006b0c1100: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff88006b0c1180: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff88006b0c1200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff88006b0c1280: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
ffff88006b0c1300: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Cc: Dmitry Vyukov <dvyukov@google.com>
[ Upstream commit 75c6aca4765dbe3d0c1507ab5052f2e373dc2331 ]
T: Bus=01 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3472 Rev=00.01
BugLink: https://bugs.launchpad.net/bugs/1552925
[ Upstream commit 81d90442eac779938217c3444b240aa51fd3db47 ]
T: Bus=01 Lev=01 Prnt=01 Port=04 Cnt=03 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=04ca ProdID=3014 Rev=00.02
BugLink: https://bugs.launchpad.net/bugs/1546694
[ Upstream commit 28c971d82fb58ef7cba22e5308be6d2d2590473d ]
T: Bus=01 Lev=01 Prnt=01 Port=04 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=0489 ProdID=e095 Rev=00.01
This device requires ar3k/AthrBT_0x31010100.dfu and
ar3k/ramps_0x31010100_40.dfu firmware files that are not in
linux-firmware yet.
BugLink: https://bugs.launchpad.net/bugs/1542944
[ Upstream commit 609574eb46335cfac1421a07c0505627cbbab1f0 ]
T: Bus=03 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3395 Rev=00.01
BugLink: https://bugs.launchpad.net/bugs/1542564
Reported-and-tested-by: Christopher Simerly <kilikopela29@gmail.com>
[ Upstream commit 1623d0bf847d3b38d8cf24367b3689ba0e3fe2aa ]
BugLink: https://bugs.launchpad.net/bugs/1522949
T: Bus=03 Lev=02 Prnt=02 Port=05 Cnt=02 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0930 ProdID=0225 Rev=01.12
S: Manufacturer=Broadcom Corp
S: Product=BCM43142A0
S: SerialNumber=4CBB58034671
C: #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=(none)
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=01 Prot=01 Driver=(none)
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=01 Driver=(none)
Packets with a variable length value equal to zero were not received.
Since no more data expected (and input buffer entirely consumed), we
need to complete/forward the packet immediately instead of waiting for
more data.
Signed-off-by: Loic Poulain <loic.poulain@intel.com>
Signed-off-by: Fugang Duan <B38611@freescale.com>
If h4_recv_buf() return ERR_PTR instead sk_buff pointer, it should be
cleared once PTR_ERR is completed for the further dereference such as
h4_recv(), or h4_close().
(No this patch, BT suspend/resume will cause kernel crash)
Signed-off-by: Chan-yeol Park <chanyeol.park@samsung.com>
commit 18e0afab8ce3f1230ce3fef52b2e73374fd9c0e7 upstream.
T: Bus=04 Lev=02 Prnt=02 Port=04 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=0cf3 ProdID=817b Rev=00.02
BugLink: https://bugs.launchpad.net/bugs/1506615
commit cd355ff071cd37e7197eccf9216770b2b29369f7 upstream.
This adapter works with the existing linux-firmware.
T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=0930 ProdID=021c Rev=00.01
BugLink: https://bugs.launchpad.net/bugs/1502781
commit 7bee8b08c428b63aa4a3765bb907602e36355378 upstream.
Commit 1c8ba6d013 moved around the setup code for broadcomm chips,
and also added btbcm_read_verbose_config() to read extra information
about the hardware. It's returning errors on some macbooks:
Bluetooth: hci0: BCM: Read verbose config info failed (-16)
Which makes us error out of the setup function. Since this
probe isn't critical to operate the chip, this patch just changes
things to carry on when it fails.
Signed-off-by: Chris Mason <clm@fb.com>
commit 2eeac871697ac24a77b6d7953bd711b490e83ac7 upstream.
That patch corrects the typo in usb vendor id for Roper Class 1 Bluetooth
Dongle. Problem with typo is present since 4.0 kernel.
Content /sys/kernel/debug/usb/devices for these dongle:
T: Bus=05 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
P: Vendor=1310 ProdID=0001 Rev=15.00
S: Manufacturer=SiW
S: Product=SiW
S: SerialNumber=E7BB050D0B00
C:* #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr= 50mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Aleksei Volkov <info@dv2c.ru>
commit e66890a96abbb746e1229c3067471be36dc49b34 upstream.
This patch fixes the command length alignment issue for Intel Bluetooth
8260.
The length of parameters in the firmware downloading command must be
multiplication of 4. If not, the command must append Intel_NOP command
with extra parameters, zeros, at the end, and the firmware file is
already included Intel_NOP command for alignment.
This patch checks the next command and if the next command is Intel_NOP
command, it reads the Intel_NOP command and send them together.
For example, if the data from the firmware file looks like this:
8E FC 03 11 22 33 02 FC 03 00 00 00
Previously, btusb sends two commands:
09 FC 06 8E FC 03 11 22 33
09 FC 06 02 FC 03 00 00 00
This won't work because the length of parameters are 6 which violates
the 4 byte alignment.
This patch will append them together and send as one command:
09 FC 0C 8E FC 03 11 22 33 02 FC 03 00 00 00
Based on previous work from Tedd Ho-Jeong An <tedd.an@intel.com>
Reported-by: Tedd Ho-Jeong An <tedd.an@intel.com>
Tested-by: Tedd Ho-Jeong An <tedd.an@intel.com>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
commit ecffc80478cdce122f0ecb6a4e4f909132dd5c47 upstream.
The SKB returned from the Intel specific version information command is
missing a kfree_skb.
commit 0d0cef6183aec0fb6d0c9f00a09ff51ee086bbe2 upstream.
BugLink: https://bugs.launchpad.net/bugs/1427680
This device requires new firmware files
AthrBT_0x11020100.dfu and ramps_0x11020100_40.dfu added to
/lib/firmware/ar3k/ that are not included in linux-firmware yet.
P: Vendor=13d3 ProdID=3474 Rev=00.01
commit 692c062e7c282164fd7cda68077f79dafd176eaf upstream.
BugLink: https://bugs.launchpad.net/bugs/1462614
T: Bus=03 Lev=01 Prnt=01 Port=09 Cnt=06 Dev#= 7 Spd=12 MxCh= 0
P: Vendor=0489 ProdID=e076 Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=(none)
commit 7e730c7f3d1f39c25cf5f7cf70c0ff4c28d7bec7 upstream.
BugLink: https://bugs.launchpad.net/bugs/1394368
T: Bus=02 Lev=01 Prnt=01 Port=04 Cnt=03 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=04ca ProdID=300d Rev= 0.01
BugLink: https://bugs.launchpad.net/bugs/1449730
P: Vendor=04ca ProdID=300f Rev=00.01
Device 0cf3:e007 is one of the QCA ROME family.
T: Bus=01 Lev=01 Prnt=01 Port=05 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.01 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0cf3 ProdID=e007 Rev= 0.01
Signed-off-by: Wen-chien Jesse Sung <jesse.sung@canonical.com>
Device info in /sys/kernel/debug/usb/devices:
P: Vendor=0cf3 ProdID=e006 Rev= 0.01
The ">" should be ">=" so that we don't read past the end of the array.
Fixes: 9d9a113e3695 ('Bluetooth: btusb: Add Realtek 8723A/8723B/8761A/8821A support')
Reviewed-by: Daniel Drake <drake@endlessm.com>
ERROR: spaces required around that '<' (ctx:WxV)
+ if (err <0)
ERROR: code indent should use tabs where possible
+^I^I^I^I sizeof(ver));$
Realtek ship a variety of bluetooth USB devices that identify
themselves with standard USB Bluetooth device class values, but
require a special driver to actually work. Without that driver,
you never get any scan results.
More recently however, Realtek appear to have wisened up and simply
posted a firmware update that makes these devices comply with
normal btusb protocols. The firmware needs to be uploaded on each boot.
Based on Realtek code from https://github.com/lwfinger/rtl8723au_bt
('new' branch).
This enables bluetooth support in the Gigabyte Brix GB-BXBT-2807 which
has this RTL8723BE USB device:
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=13d3 ProdID=3410 Rev= 2.00
S: Manufacturer=Realtek
S: Product=Bluetooth Radio
S: SerialNumber=00e04c000001
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=500mA
There is no change to the USB descriptor after firmware update,
however the version read by HCI_OP_READ_LOCAL_VERSION changes from
0x8723 to 0x3083.
This has also been tested on RTL8723AE and RTL8821AE. Support for
RTL8761A has also been added, but that is untested.
Signed-off-by: Daniel Drake <drake@endlessm.com>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
The Atheros support for missing the support for configuration of the
Bluetooth public address. Add support for the vendor specific command.
The driver callbacks in the Atheros support were all in a random order
and did not help readability of this driver. So reorder them to make
them aligned with what other Bluetooth UART drivers do. This patch is
not changing any actual code.
This isolates the Broadcom patchram download procedure as separate
function so that it can be easily used from USB and UART based drivers.
I think the comments are used to debug, and we don't need them in
mainline code
Signed-off-by: DingXiang <dingxiang@huawei.com>
The Intel vendors events indicating firmware loading result and the
bootup of the operational firmware are currently hardcoded byte
comparisons. So intead of doing that, provide proper data structures
and actually use them.
The Bluetooth address setting for Intel devices is provided by a generic
module now. Start using that module instead of relying it being included
in the driver.
Since the Intel Bluetooth support has its own header, it makes sense
to move all command structs into it.
The Bluetooth address handling for Intel devices is provided by a generic
in the driver.
The majority of Intel Bluetooth vendor commands are shared between USB
and UART transports. This creates a separate module that eventually
will hold all Intel specific commands, but for now just start with the
commands to change the Bluetooth public address and check for the
default address.
Future H:4 based UART drivers require custom packet types and custom
receive functions. To support this, extended the h4_recv_buf function
with a packet definition table.
For the default H:4 packets types of ACL data, SCO data and events,
provide helpers to reduce the amount of code duplication.
The Broadcom UART based devices seem to use a little bit different
firmare naming prefix. So add a separate table for these devices.
This adds the protocol support for Broadcom based UART devices to
enable firmware and patchram download procedure. It is a pretty
straight forward H:4 driver with the exception of actually having
its own setup and address configuration callbacks.
The setup callback got wrongly inserted between the enqueue and dequeue
callbacks. Move it to a better location.
The version number is cosmetic, but pretty handy for debugging purposes
and since the Broadcom protocol support is now optional, just increase
it to indicate the difference.
The quirks for Broadcom devices can be set from the setup function and
to keep the code simple, just move them into Broadcom support module.
With the generic Broadcom Bluetooth support module, it is possible to
turn support for firmware and patchram download into an optional
feature.
To keep backwards compatibility with previous kernel configurations,
the new option defaults to enabled.
To unify the controller setup of Broadcom devices between USB and UART
transport, add the patchram download support into the Broadcom module.
The new Broadcom Bluetooth support module provides generic functionality
for changing and checking the Bluetooth device address. Use these new
features instead of keeping a duplicate in the driver.
The majority of Broadcom Bluetooth vendor commands are shared between
USB and UART transports. This creates a separate module that eventually
will hold all Broadcom specific commands, but for now just start with
the commands to change the Bluetooth public address and check for the
default address.
