path: root/drivers/bluetooth
2012-05-07bluetooth: tibluesleep: clean up tibluesleep driverNagarjuna Kristam
Remove UART clock enable code, as UART clock gating is not needed in tibluesleep driver. Remove un-wanted tasklets, workqueues and wakelocks Remove extra lines and spaces Change-Id: I422e09ece2c736c4a98911a5bd84029ad654cb08 Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com> Reviewed-on: http://git-master/r/96944 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-03-21Bluetooth: remove DEBUG macro from btwilink driverNagarjuna Kristam
Change-Id: I1721115a1d500f1101c856809ec3fd3ac4a3fe67 Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com> Reviewed-on: http://git-master/r/89409 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-03-15misc: bluetooth: clean ti_bluesleep patchRakesh Goyal
Remove dead code Remove whitespace Remove platform callback function and add wake_lock/wake_unlock Fix compilation warnings Bug 933054 Bug 931931 Change-Id: I5b0947ad2053f9e0437ffe89879df2c84786ec9c Signed-off-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-on: http://git-master/r/89274 Reviewed-by: Nagarjuna Kristam <nkristam@nvidia.com> Tested-by: Nagarjuna Kristam <nkristam@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2012-03-15TI Wl128x support of bluesleep & Wake on BT Driver changesAnjan Rao
Bug 933054 Bug 931931 Change-Id: Id84bcc1791114a50d26547de41daeb4774f6026b Signed-off-by: Anjan Rao <anjan.rao@ti.com> Reviewed-on: http://git-master/r/89136 Reviewed-by: Nagarjuna Kristam <nkristam@nvidia.com> Tested-by: Nagarjuna Kristam <nkristam@nvidia.com> Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2011-12-26bluetooth: bluesleep: call free_irq during driver unload onlyVarun Wadekar
Change-Id: Iabad9617752af43c7184d0335177c60fba6bd715 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/67654 Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User
2011-12-23bluesleep: disable run time UART clock gatingRakesh Goyal
There is no signaficant power saving by UART clock gating. Bug 913214 Change-Id: I9266c812bae080ba50fa89d11684f18de2f05eab Signed-off-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-on: http://git-master/r/71879 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Om Prakash Singh <omp@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com> Reviewed-by: Sheshagiri Shenoy <sshenoy@nvidia.com>
2011-12-08bluetooth: bluesleep: enable wake-on-bluetoothOm Prakash Singh
Bug 910402 Change-Id: I6835cacd12573c2bc6adb86ea3742d934d0fc118 Signed-off-by: Om Prakash Singh <omp@nvidia.com> Reviewed-on: http://git-master/r/66614 Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2011-11-30bluetooth: bluesleep: remove blocking call in bluesleep_startMatt Wagner
bluesleep_start is not allowed to sleep because it's called by an atomic_notifier, so we move request_irq to the probe function Change-Id: I428bd6c9ab07cf7e5ab2029975cc9a617fea03b0 Reviewed-on: http://git-master/r/65018 Tested-by: Matt Wagner <mwagner@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Rebase-Id: R20e192cd7167915b6749a6ee267184b2e0a142fb
2011-11-30bluetooth: bluesleep: workaround to enable bluesleep functionalityOm Prakash Singh
Enable_irq_wake function is returning error while registering bank irqs. Commenting out enable_irq_wake,disable_irq_wake function will not affect bluesleep functionality except wake-on-bluethooth. Bug 890309 Change-Id: I268361372de037b07bbac5373560c94fc9b131b0 Reviewed-on: http://git-master/r/61090 Reviewed-by: Om Prakash Singh <omp@nvidia.com> Tested-by: Om Prakash Singh <omp@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> Rebase-Id: R4b5334848a954ed107a7294131d78b9162bfb711
2011-11-30bluetooth: bluesleep: add suspend and resumeRakesh Goyal
suspend and resume function() to avoid uart api call when uart driver is not resumed. bug 863564 Original-Change-Id: I036260f244b2067200050fd5252d91ec23518b86 Reviewed-on: http://git-master/r/48716 Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Tested-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com> Rebase-Id: Rbc220cc73cd014ff114be3bda7ce5461a29a31f7
2011-11-30bluetooth: bluesleep: Exit early if device not registeredDan Willemsen
If the device isn't registered for this board, return out of the init function early. Original-Change-Id: Ic806b4be1671a77a8fedc1c0376362bc177b0604 Reviewed-on: http://git-master/r/24254 Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com> Tested-by: Daniel Willemsen <dwillemsen@nvidia.com> Reviewed-by: Anantha Idapalapati <aidapalapati@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Rebase-Id: R8d68fc165c4054e76d3681949985f50d00161179
2011-11-30bluetooth: Fixed ld mismatched symbolsChao Jiang
The driver data structure referenced a function point which is defined as __init data. This caused symbol mismatch error. This could be fixed by defined driver data with __init macro, otherwise, by cancel __init on probe function. Have this done in a safe way. This file is removed in upstream. It seems that is the only chance to fix it in our own repository. Original-Change-Id: I3eba3578c84d8ec67707a276841d72f98c47267d Reviewed-on: http://git-master/r/20931 Reviewed-by: David Schalig <dschalig@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Chao Jiang <chaoj@nvidia.com> Rebase-Id: R9fb630dbae997619ba5c0e0c337d64d3e1ea0581
2011-11-30tegra bluesleep: Bluetooth active power management driverAnantha Idapalapati
A new driver is implemented to actively manage the bluetooth module power. bluesleep also tries to manage the power of the transport used. Two signals (GPIOs) are used to manage the power events. BT_WAKE : signal from HOST to BT chip to intimate BT chip can sleep. HOST_WAKE: signal from BT chip to HOST to intimate HOST should wakeup/ activate the transport modules required for BT communication. Bug 791669, 773186 (cherry picked from commit 111f4ccd3c4cfde2fa52ae4c0c56a2288c3af3a8) Original-Change-Id: Iff1e81bb22d9bd43113f7cdd01329da3ae852a15 Reviewed-on: http://git-master/r/19858 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com> Rebase-Id: R1eca7f2f51475daf6104e71e90ad5db1213fa6ea
2011-09-17Bluetooth: add support for 2011 mac miniJurgen Kramer
Today I noticed that the usb bluetooth adapter (BCM2046B1) on my 2011 mac mini was not working. I've created a patch to get it going. Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-09-17Bluetooth: Add MacBookAir4,1 supportPieter-Augustijn Van Malleghem
This patch against current git adds the hardware ID for the Apple MacBookAir4,1, released in July 2011. The device features a BCM2046 USB chip. The patch was inspired by the previous modifications adding support for the MacBookAir3,x. Signed-off-by: Pieter-Augustijn Van Malleghem <p-a@scarlet.be> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-09-17Bluetooth: Fixed BT ST Channel reg orderChen Ganir
Reordered the BT ST channel registration, to make sure that the event channel is registered before all others. This prevents a situation where incoming events may cause kernel panic in the ST driver if the event channel is not yet registered to handle incoming events.In addition, the deregistration of the channels was also modified, to be in the reversed order of the registration, to allow the event channel to be the last one unregistered. Signed-off-by: Chen Ganir <chen.ganir@ti.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-08-11Bluetooth: Add Toshiba laptops AR30XX device IDRicardo Mendoza
Blacklist Toshiba-branded AR3011 based AR5B195 [0930:0215] and add to ath3k.c for firmware loading. Signed-off-by: Ricardo Mendoza <ricmm@gentoo.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-08-11Bluetooth: btusb: be quiet on device disconnectPaul Bolle
Disabling the bluetooth usb device embedded in (some) ThinkPads tends to lead to errors like these: btusb_bulk_complete: hci0 urb ffff88011b9bfd68 failed to resubmit (19) btusb_intr_complete: hci0 urb ffff88011b46a318 failed to resubmit (19) btusb_bulk_complete: hci0 urb ffff88011b46a000 failed to resubmit (19) That is because usb_disconnect() doesn't "quiesces" pending urbs. Disconnecting a device is a normal thing to happen so it's no big deal that usb_submit_urb() returns -ENODEV. The simplest way to get rid of these errors is to stop treating that return as an error. Trivial, actually. While we're at it, add comments to be explicit about the reasons we're not complaining about -EPERM and -ENODEV. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-07-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: net/bluetooth/l2cap_core.c
2011-07-01Bluetooth: Add Atheros AR3012 one PID/VID supportedSteven.Li
The new Ath3k needs to download patch and radio table, and it keeps same PID/VID even after downloading the patch and radio table. This patch is to use the bcdDevice (Device Release Number) to judge whether the chip has been patched or not. The init bcdDevice value of the chip is 0x0001, this value increases after patch and radio table downloading. Signed-off-by: Steven.Li <yongli@qca.qualcomm.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-06-17Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into for-davem
2011-06-10Bluetooth: Do not ignore errors returned from strict_strtol()David Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-06-09Bluetooth: Do not ignore errors returned from strict_strtol()David Miller
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-16Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-tx.c net/mac80211/sta_info.h
2011-05-11Bluetooth: Device ids for ath3k on Pegatron Lucid tabletsAndy Ross
New ath3k device IDs used on the Pegatron Lucid (ExoPC and WeTab) units. Signed-off-by: Andy Ross <andy.ross@windriver.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-04-25Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/rt2x00/rt2x00queue.c drivers/net/wireless/rt2x00/rt2x00queue.h
2011-04-22tty: make receive_buf() return the amout of bytes receivedFelipe Balbi
it makes it simpler to keep track of the amount of bytes received and simplifies how flush_to_ldisc counts the remaining bytes. It also fixes a bug of lost bytes on n_tty when flushing too many bytes via the USB serial gadget driver. Tested-by: Stefan Bigler <stefan.bigler@keymile.com> Tested-by: Toby Gray <toby.gray@realvnc.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13Bluetooth: btmrvl: support Marvell Bluetooth device SD8787Kevin Gan
The SD8787 firmware image is shared with mwifiex driver. Whoever gets loaded first will be responsible for firmware downloading. Signed-off-by: Kevin Gan <ganhy@marvell.com> Signed-off-by: Tristan Xu <xurf@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-04-13Bluetooth: Check return value of hci_recv_stream_fragment()Gustavo F. Padovan
It may return error and in this case we do add to the stats. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-04-13Bluetooth: hci_uart: check the return value of recv()Jiejing Zhang
Check the return value of hu->proto->recv() in hci_uart_tty_receive() the recv() may return error, check it, not add this to statistics. Signed-off-by: Jiejing Zhang <jiejing.zhang@freescale.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-04-13Bluetooth: Clean up ath3k_load_firmware()Gustavo F. Padovan
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-03-31Bluetooth: Fix sending LE data over USBVinicius Costa Gomes
Now that we have support for LE connections, before discarding a frame we must check if there's a LE connection over that transport. Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org> Acked-by: Ville Tervo <ville.tervo@nokia.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-03-31Bluetooth: add support for Apple MacBook Pro 8,2Marc-Antoine Perennou
Just adding the vendor details makes it work fine. Signed-off-by: Marc-Antoine Perennou <Marc-Antoine@Perennou.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-03-24Bluetooth: Fix sending LE data over USBVinicius Costa Gomes
2011-03-24Bluetooth: add support for Apple MacBook Pro 8,2Marc-Antoine Perennou
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (961 commits) staging: hv: fix memory leaks staging: hv: Remove NULL check before kfree Staging: hv: Get rid of vmbus_child_dev_add() Staging: hv: Change the signature for vmbus_child_device_register() Staging: hv: Get rid of vmbus_cleanup() function Staging: hv: Get rid of vmbus_dev_rm() function Staging: hv: Change the signature for vmbus_on_isr() Staging: hv: Eliminate vmbus_event_dpc() Staging: hv: Get rid of the function vmbus_msg_dpc() Staging: hv: Change the signature for vmbus_cleanup() Staging: hv: Simplify root device management staging: rtl8192e: Don't copy dev pointer to skb staging: rtl8192e: Pass priv to cmdpkt functions staging: rtl8192e: Pass priv to firmware download functions staging: rtl8192e: Pass priv to rtl8192_interrupt staging: rtl8192e: Pass rtl8192_priv to dm functions staging: rtl8192e: Pass ieee80211_device to callbacks staging: rtl8192e: Pass ieee80211_device to callbacks staging: rtl8192e: Pass ieee80211_device to callbacks staging: rtl8192e: Pass ieee80211_device to callbacks ...
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-02-24Merge 2.6.38-rc6 into tty-nextGreg Kroah-Hartman
This was to resolve a merge issue with drivers/char/Makefile and drivers/tty/serial/68328serial.c Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-23Revert "Bluetooth: Enable USB autosuspend by default on btusb"Linus Torvalds
This reverts commit 556ea928f78a390fe16ae584e6433dff304d3014. Jeff Chua reports that it can cause some bluetooth devices (he mentions an Bluetooth Intermec scanner) to just stop responding after a while with messages like [ 4533.361959] btusb 8-1:1.0: no reset_resume for driver btusb? [ 4533.361964] btusb 8-1:1.1: no reset_resume for driver btusb? from the kernel. See also https://bugzilla.kernel.org/show_bug.cgi?id=26182 for other reports. Reported-by: Jeff Chua <jeff.chua.linux@gmail.com> Reported-by: Andrew Meakovski <meako@bigmir.net> Reported-by: Jim Faulkner <jfaulkne@ccs.neu.edu> Acked-by: Greg KH <gregkh@suse.de> Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> Cc: stable@kernel.org (for 2.6.37) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-23Bluetooth: btwilink driverPavan Savoy
This is the bluetooth protocol driver for the TI WiLink7 chipsets. Texas Instrument's WiLink chipsets combine wireless technologies like BT, FM, GPS and WLAN onto a single chip. This Bluetooth driver works on top of the TI_ST shared transport line discipline driver which also allows other drivers like FM V4L2 and GPS character driver to make use of the same UART interface. Kconfig and Makefile modifications to enable the Bluetooth driver for Texas Instrument's WiLink 7 chipset. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-18Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6John W. Linville
Conflicts: drivers/bluetooth/ath3k.c drivers/bluetooth/btusb.c
