commit fd865802c66bc451dc515ed89360f84376ce1a56 upstream.
There's been numerous reported instances where BTUSB_QCA_ROME
bluetooth controllers stop functioning upon resume from suspend. These
devices seem to be losing power during suspend. Patch will detect a status
change on resume and perform a reset.
Signed-off-by: Leif Liddy <leif.linux@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: Kai Heng Feng <kai.heng.feng@canonical.com>
[ Upstream commit 9af02d86e11dc409e5c3de46e81c0a492ba58905 ]
It's much the same as what we did for mwifiex in:
b9da4d2 mwifiex: avoid double-disable_irq() race
"We have a race where the wakeup IRQ might be in flight while we're
calling mwifiex_disable_wake() from resume(). This can leave us
disabling the IRQ twice.
Let's disable the IRQ and enable it in case if we have double-disabled
it."
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
Reviewed-by: Brian Norris <briannorris@chromium.org>
commit a81d72d2002d6a932bd83022cbf8c442b1b97512 upstream.
T: Bus=02 Lev=01 Prnt=01 Port=03 Cnt=03 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=13d3 ProdID=3494 Rev= 2.00
S: Manufacturer=Realtek
S: Product=Bluetooth Radio
S: SerialNumber=00e04c000001
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Dmitry Tunin <hanipouspilot@gmail.com>
commit dcb9cfaa5ea9aa0ec08aeb92582ccfe3e4c719a9 upstream.
Make sure to check the tty-device pointer before looking up the sibling
platform device to avoid dereferencing a NULL-pointer when the tty is
one end of a Unix98 pty.
Fixes: 74cdad37cd24 ("Bluetooth: hci_intel: Add runtime PM support")
Fixes: 1ab1f239bf17 ("Bluetooth: hci_intel: Add support for platform driver")
Cc: Loic Poulain <loic.poulain@intel.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 95065a61e9bf25fb85295127fba893200c2bbbd8 upstream.
Fixes: 0395ffc1ee05 ("Bluetooth: hci_bcm: Add PM for BCM devices")
Cc: Frederic Danis <frederic.danis@linux.intel.com>
commit 441ad62d6c3f131f1dbd7dcdd9cbe3f74dbd8501 upstream.
T: Bus=01 Lev=01 Prnt=01 Port=07 Cnt=04 Dev#= 5 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=04ca ProdID=3018 Rev=00.01
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
Probe functions should return 0 on success. This driver's probe
returns the value returned by hci_register_dev(), which is the hci
index. This works for systems with only one hci device (id = 0) but
for systems where the btwilink device ends up with an id larger than
0, things will start to fall apart.
Make the probe function return 0 on success.
Signed-off-by: Jacob Siverskog <jacob@teenage.engineering>
ACPI table for BCM2E55 of Lenovo ThinkPad 8 is not correct.
Set correctly IRQ polarity for this device, fixing the issue of bluetooth
never resuming after autosuspend PM.
Signed-off-by: Jérôme de Bretagne <jerome.debretagne@gmail.com>
Move usb_autopm_get_interface() ahead of setup_on_usb() to prevent
device from sending usb control message in usb suspend mode.
The error message is as below:
[ 83.944103] btusb 1-2:1.1: usb_suspend_interface: status 0
[ 83.944107] btusb 1-2:1.0: usb_suspend_interface: status 0
[ 83.960132] usb 1-2: usb auto-suspend, wakeup 0
[ 83.976156] usb 1-2: usb_suspend_device: status 0
[ 83.976162] usb 1-2: usb_suspend_both: status 0
[ 298.689106] Bluetooth: hci0
[ 298.689399] Bluetooth: hci0: Failed to access otp area (-113)
Signed-off-by: Ethan Hsieh <ethan.hsieh@canonical.com>
btusb_set_bdaddr_marvell() configures BD address for Marvell chipsets.
This patch adds new chipset 8997 in the list so that BD address feature
would be available for it.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Pull networking updates from David Miller:
1) BBR TCP congestion control, from Neal Cardwell, Yuchung Cheng and
co. at Google. https://lwn.net/Articles/701165/
2) Do TCP Small Queues for retransmits, from Eric Dumazet.
3) Support collect_md mode for all IPV4 and IPV6 tunnels, from Alexei
Starovoitov.
4) Allow cls_flower to classify packets in ip tunnels, from Amir Vadai.
5) Support DSA tagging in older mv88e6xxx switches, from Andrew Lunn.
6) Support GMAC protocol in iwlwifi mwm, from Ayala Beker.
7) Support ndo_poll_controller in mlx5, from Calvin Owens.
8) Move VRF processing to an output hook and allow l3mdev to be
loopback, from David Ahern.
9) Support SOCK_DESTROY for UDP sockets. Also from David Ahern.
10) Congestion control in RXRPC, from David Howells.
11) Support geneve RX offload in ixgbe, from Emil Tantilov.
12) When hitting pressure for new incoming TCP data SKBs, perform a
partial rathern than a full purge of the OFO queue (which could be
huge). From Eric Dumazet.
13) Convert XFRM state and policy lookups to RCU, from Florian Westphal.
14) Support RX network flow classification to igb, from Gangfeng Huang.
15) Hardware offloading of eBPF in nfp driver, from Jakub Kicinski.
16) New skbmod packet action, from Jamal Hadi Salim.
17) Remove some inefficiencies in snmp proc output, from Jia He.
18) Add FIB notifications to properly propagate route changes to
hardware which is doing forwarding offloading. From Jiri Pirko.
19) New dsa driver for qca8xxx chips, from John Crispin.
20) Implement RFC7559 ipv6 router solicitation backoff, from Maciej
Żenczykowski.
21) Add L3 mode to ipvlan, from Mahesh Bandewar.
22) Support 802.1ad in mlx4, from Moshe Shemesh.
23) Support hardware LRO in mediatek driver, from Nelson Chang.
24) Add TC offloading to mlx5, from Or Gerlitz.
25) Convert various drivers to ethtool ksettings interfaces, from
Philippe Reynes.
26) TX max rate limiting for cxgb4, from Rahul Lakkireddy.
27) NAPI support for ath10k, from Rajkumar Manoharan.
28) Support XDP in mlx5, from Rana Shahout and Saeed Mahameed.
29) UDP replicast support in TIPC, from Richard Alpe.
30) Per-queue statistics for qed driver, from Sudarsana Reddy Kalluru.
31) Support BQL in thunderx driver, from Sunil Goutham.
32) TSO support in alx driver, from Tobias Regnery.
33) Add stream parser engine and use it in kcm.
34) Support async DHCP replies in ipconfig module, from Uwe
Kleine-König.
35) DSA port fast aging for mv88e6xxx driver, from Vivien Didelot.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1715 commits)
mlxsw: switchx2: Fix misuse of hard_header_len
mlxsw: spectrum: Fix misuse of hard_header_len
net/faraday: Stop NCSI device on shutdown
net/ncsi: Introduce ncsi_stop_dev()
net/ncsi: Rework the channel monitoring
net/ncsi: Allow to extend NCSI request properties
net/ncsi: Rework request index allocation
net/ncsi: Don't probe on the reserved channel ID (0x1f)
net/ncsi: Introduce NCSI_RESERVED_CHANNEL
net/ncsi: Avoid unused-value build warning from ia64-linux-gcc
net: Add netdev all_adj_list refcnt propagation to fix panic
net: phy: Add Edge-rate driver for Microsemi PHYs.
vmxnet3: Wake queue from reset work
i40e: avoid NULL pointer dereference and recursive errors on early PCI error
qed: Add RoCE ll2 & GSI support
qed: Add support for memory registeration verbs
qed: Add support for QP verbs
qed: PD,PKEY and CQ verb support
qed: Add support for RoCE hw init
qede: Add qedr framework
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull usb/phy/extcon updates from Greg KH:
"Here is the big USB, and PHY, and extcon, patchsets for 4.9-rc1.
Full details are in the shortlog, but generally a lot of new hardware
support, usb gadget updates, and Wolfram's great cleanup of USB error
message handling, making the kernel image a tad bit smaller.
All of this has been in linux-next with no reported issues"
* tag 'usb-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (343 commits)
Revert "usbtmc: convert to devm_kzalloc"
USB: serial: cp210x: Add ID for a Juniper console
usb: Kconfig: using select for USB_COMMON dependency
bluetooth: bcm203x: don't print error when allocating urb fails
mmc: host: vub300: don't print error when allocating urb fails
usb: hub: change CLEAR_FEATURE to SET_FEATURE
usb: core: Introduce a USB port LED trigger
USB: bcma: drop Northstar PHY 2.0 initialization code
usb: core: hcd: add missing header dependencies
usb: musb: da8xx: fix error handling message in probe
usb: musb: Fix session based PM for first invalid VBUS
usb: musb: Fix PM runtime for disconnect after unconfigure
musb: Export musb_root_disconnect for use in modules
usb: misc: legousbtower: Fix NULL pointer deference
cdc-acm: hardening against malicious devices
Revert "usb: gadget: NCM: Protect dev->port_usb using dev->lock"
include: extcon: Fix compilation error caused because of incomplete merge
MAINTAINERS: add tree entry for USB Serial
phy-twl4030-usb: initialize charging-related stuff via pm_runtime
phy-twl4030-usb: better handle musb_mailbox() failure
kmalloc will print enough information in case of failure.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
Remove multiple return statements in hci_uart_tty_ioctl() call and
added a single return statement.
This code re-organisation allows subsequent locking to be easily
added.
Signed-off-by: Vignesh Raman <Vignesh_Raman@mentor.com>
Signed-off-by: Dean Jenkins <Dean_Jenkins@mentor.com>
Signed-off-by: Rajeev Kumar <rajeev_kumar@mentor.com>
Send an ACK frame with the current txack value in response to
every received reliable frame unless a TX reliable frame is being
sent. This modification allows re-transmitted frames from the remote
peer to be acknowledged rather than ignored. It means that the remote
peer knows which frame number to start re-transmitting from.
Without this modification, the recovery time to a missing frame
from the remote peer was unnecessarily being extended because the
headers of the out of order reliable frames were being discarded rather
than being processed. The frame headers of received frames will
indicate whether the local peer's transmissions have been
acknowledged by the remote peer. Therefore, the local peer may
unnecessarily re-transmit despite the remote peer already indicating
that the frame had been acknowledged in out of order reliable frame.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
drivers/bluetooth/hci_bcsp.c contains some style issues as
highlighted by
./scripts/checkpatch.pl --strict -f drivers/bluetooth/hci_bcsp.c
a) comments - maintainer prefers network style comments
b) positioning of lines in multi-line statements
c) spaces after casts
d) missing blank lines after declarations
Therefore, tidy-up the above to make it easier to apply
future code changes that have conforming style.
Running with KASAN produces some messages:
BUG: KASAN: use-after-free in ti_st_send_frame+0x9c/0x16c at addr
ffffffc064868fe8
Read of size 1 by task kworker/u17:1/1266
<KASAN output trimmed>
Hardware name: HiKey Development Board (DT)
Workqueue: hci0 hci_cmd_work
Call trace:
[<ffffffc00008c00c>] dump_backtrace+0x0/0x178
[<ffffffc00008c1a4>] show_stack+0x20/0x28
[<ffffffc00067da38>] dump_stack+0xa8/0xe0
[<ffffffc000288430>] print_trailer+0x110/0x174
[<ffffffc00028aedc>] object_err+0x4c/0x5c
[<ffffffc00028f714>] kasan_report_error+0x254/0x54c
[<ffffffc00028fa70>] kasan_report+0x64/0x70
[<ffffffc00028eb8c>] __asan_load1+0x4c/0x54
[<ffffffc000b59b24>] ti_st_send_frame+0x9c/0x16c
[<ffffffc000ee8dcc>] hci_send_frame+0xb4/0x118
[<ffffffc000ee8efc>] hci_cmd_work+0xcc/0x154
[<ffffffc0000f6c48>] process_one_work+0x26c/0x7a4
[<ffffffc0000f721c>] worker_thread+0x9c/0x73c
[<ffffffc000100250>] kthread+0x138/0x154
[<ffffffc000085c50>] ret_from_fork+0x10/0x40
The packet is being accessed for statistics after it has been freed.
Save the packet type before sending for statistics afterwards.
Signed-off-by: Laura Abbott <labbott@redhat.com>
BugLink: https://bugs.launchpad.net/bugs/1535802
T: Bus=01 Lev=02 Prnt=02 Port=04 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=04ca ProdID=3011 Rev=00.01
Cc: stable@vger.kernel.org
This patch introduces support for Marvell Bluetooth controller over
UART (8897 for now). In order to send the final firmware at full speed,
a helper firmware is firstly sent. Firmware download is driven by the
controller which sends request firmware packets (including expected
size).
This driver is a global rework of the one proposed by
Amitkumar Karwar <akarwar@marvell.com>.
Signed-off-by: Loic Poulain <loic.poulain@intel.com>
Will be used by hci_nokia extra protocol.
Use full name instead of abbreviation.
The RTL8822BE is a new Realtek wifi and BT device. Support for the BT
part is hereby added.
As this device is similar to most of the other Realtek BT devices, the
changes are minimal. The main difference is that the 8822BE needs a
configuration file for enabling and disabling features. Thus code is
added to select and load this configuration file. Although not needed
at the moment, hooks are added for the other devices that might need
such configuration files.
One additional change is to the routine that tests that the project
ID contained in the firmware matches the hardware. As the project IDs
are not sequential, continuing to use the position in the array as the
expected value of the ID would require adding extra unused entries in
the table, and any subsequant rearrangment of the array would break the
code. To fix these problems, the array elements now contain both the
hardware ID and the expected value for the project ID.
Signed-off-by: 陆朱伟 <alex_lu@realsil.com.cn>
edl->data is an array of __u8 so the null check is unneccessary,
so remove it.
Conwise CW6622 seems to have a problem with the stored link key
commands so just mark it as broken.
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0
> HCI Event: Command Complete (0x0e) plen 12
Read Local Supported Features (0x04|0x0003) ncmd 1
status 0x00
Features: 0xff 0x3e 0x85 0x38 0x18 0x18 0x00 0x00
< HCI Command: Read Local Version Information (0x04|0x0001) plen 0
Read Local Version Information (0x04|0x0001) ncmd 1
status 0x00
HCI Version: 2.0 (0x3) HCI Revision: 0x1f4
LMP Version: 2.0 (0x3) LMP Subversion: 0x1f4
Manufacturer: CONWISE Technology Corporation Ltd (66)
< HCI Command: Read Local Supported Commands (0x04|0x0002) plen 0
> HCI Event: Command Complete (0x0e) plen 68
Read Local Supported Commands (0x04|0x0002) ncmd 1
status 0x00
Commands: 7fffef03cedfffffffffff1ff20ff8ff3f
< HCI Command: Read Stored Link Key (0x03|0x000d) plen 7
bdaddr 00:00:00:00:00:00 all 1
> HCI Event: Command Complete (0x0e) plen 8
Read Stored Link Key (0x03|0x000d) ncmd 1
status 0x11 max 0 num 0
Error: Unsupported Feature or Parameter Value
Signed-off-by: Szymon Janc <szymon.janc@codecoup.pl>
The workqueue "workqueue" queues multiple work items viz &qca->ws_awake_rx
&qca->ws_rx_vote_off, &qca->ws_awake_device, &qca->ws_tx_vote_off which
require strict execution ordering. Hence, an ordered dedicated workqueue
has been used to replace the deprecated create_singlethread_workqueue
instance.
WQ_MEM_RECLAIM has not been set since the driver is not being used on a
memory reclaim path.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
The newly added bluetooth driver is based on the soc-specific support,
but lacks the obvious compile-time dependency on that:
drivers/bluetooth/btqcomsmd.o: In function `btqcomsmd_probe':
btqcomsmd.c:(.text.btqcomsmd_probe+0x40): undefined reference to `qcom_wcnss_open_channel'
btqcomsmd.c:(.text.btqcomsmd_probe+0x5c): undefined reference to `qcom_wcnss_open_channel'
Makefile:969: recipe for target 'vmlinux' failed
Fixes: 90c107dc8b2c ("Bluetooth: Introduce Qualcomm WCNSS SMD based HCI driver")
Device 0cf3:e009 is one of the QCA ROME family.
T: Bus=01 Lev=01 Prnt=01 Port=07 Cnt=04 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.01 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0cf3 ProdID=e009 Rev=00.01
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
wait_on_bit_timeout() returns one of the following three values:
* 0 to indicate success.
* -EINTR to indicate that a signal has been received;
* -EAGAIN to indicate timeout;
Make the wait_on_bit_timeout() callers check for these values.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
The Qualcomm WCNSS chip provides two SMD channels to the BT core; one
for command and one for event packets. This driver exposes the two
channels as a hci device.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
This patch removes module_init()/module_exit() from driver code by using
module_misc_device() macro. All modules in this patch has a print
statement which is removed when module_misc_device() macro is used.
If undesirable this patch can be dropped entirely, this is the only
purpose of making this as a separate patch.
Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
is_suspending flag remains on when host sleep fails to enable. Data
path is unnecessarily blocked after this. This patch ensures to
reset the flag in failure path.
The Digianswer sniffer devices allow for reading a firmware specific
information string. If it is available, then inform the Bluetooth core
about it via hci_set_fw_info. That exposes it via debugfs like this:
# cat /sys/kernel/debug/bluetooth/hci0/firmware_info
SNIF_102,BB930,02/01/18,10:37:56
On mips and parisc:
drivers/bluetooth/btwilink.c: In function 'ti_st_open':
drivers/bluetooth/btwilink.c:174:21: warning: overflow in implicit constant conversion [-Woverflow]
hst->reg_status = -EINPROGRESS;
drivers/nfc/nfcwilink.c: In function 'nfcwilink_open':
drivers/nfc/nfcwilink.c:396:31: warning: overflow in implicit constant conversion [-Woverflow]
drv->st_register_cb_status = -EINPROGRESS;
There are actually two issues:
1. Whether "char" is signed or unsigned depends on the architecture.
As the completion callback data is used to pass a (negative) error
code, it should always be signed.
2. EINPROGRESS is 150 on mips, 245 on parisc.
Hence -EINPROGRESS doesn't fit in a signed 8-bit number.
Change the callback status from "char" to "int" to fix these.
Acked-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
T: Bus=01 Lev=01 Prnt=01 Port=07 Cnt=05 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3490 Rev=00.01
BugLink: https://bugs.launchpad.net/bugs/1600623
LPM can be enabled via a DDC write command at specific DDC ID.
As any other DDC value, this is up to the DDC config file to
include (or not) the low power mode configuration.
Signed-off-by: Loic Poulain <loic.poulain@gmail.com>
The HCI_BREDR naming is confusing since it actually stands for Primary
Bluetooth Controller. Which is a term that has been used in the latest
standard. However from a legacy point of view there only really have
been Basic Rate (BR) and Enhanced Data Rate (EDR). Recent versions of
Bluetooth introduced Low Energy (LE) and made this terminology a little
bit confused since Dual Mode Controllers include BR/EDR and LE. To
simplify this the name HCI_PRIMARY stands for the Primary Controller
which can be a single mode or dual mode controller.
With current btusb.ko kernel module, Bluetooth pretends to be active
but there is no real activity.
I'm using an Acer Aspire VN7-791.
Output of lsusb:
Bus 003 Device 007: ID 0489:e092 Foxconn / Hon Hai
On my laptop, this device is actually used as a combo with wifi chipset
Atheros Qualcomm Killer N1525 Wireless-AC [168c:003e],
* Fix by adding a declaration in kernel sources drivers/bluetooth/btusb.c
{ USB_DEVICE(0x0489, 0xe092), .driver_info = BTUSB_QCA_ROME },
* Compiled extra module /lib/modules/4.4.0-22-generic/extra/btusb.ko
* Successfully tested against my phone (obex file transfer)
Signed-off-by: Yvain THONNART <yvain.thonnart@m4x.org>
Kasan reported slab-out-of-bounds access in btmrvl_sdio:
[ 33.055400] ==================================================================
[ 33.062585] BUG: KASAN: slab-out-of-bounds in memcpy+0x24/0x50 at addr ffffffc0d89b4a00
[ 33.070529] Read of size 256 by task btmrvl_main_ser/3576
[ 33.075885] =============================================================================
[ 33.084002] BUG kmalloc-256 (Tainted: G B ): kasan: bad access detected
[ 33.091511] -----------------------------------------------------------------------------
<snip...>
[ 33.413498] Call trace:
[ 33.415928] [<ffffffc00020a440>] dump_backtrace+0x0/0x190
[ 33.421288] [<ffffffc00020a5ec>] show_stack+0x1c/0x28
[ 33.426305] [<ffffffc000b3288c>] dump_stack+0xa0/0xf8
[ 33.431320] [<ffffffc000396130>] print_trailer+0x158/0x16c
[ 33.436765] [<ffffffc0003962cc>] object_err+0x48/0x5c
[ 33.441780] [<ffffffc00039be24>] kasan_report+0x344/0x510
[ 33.447141] [<ffffffc00039afd8>] __asan_loadN+0x20/0x150
[ 33.452413] [<ffffffc00039b60c>] memcpy+0x20/0x50
[ 33.457084] [<ffffffc000595fcc>] swiotlb_tbl_map_single+0x2ec/0x310
[ 33.463305] [<ffffffc000596b54>] map_single+0x24/0x30
[ 33.468320] [<ffffffc0005970c8>] swiotlb_map_sg_attrs+0xec/0x21c
[ 33.474286] [<ffffffc000219d4c>] __swiotlb_map_sg_attrs+0x48/0xec
[ 33.480339] [<ffffffc0008ea610>] msdc_prepare_data.isra.11+0xf0/0x11c
[ 33.486733] [<ffffffc0008ecbd0>] msdc_ops_request+0x74/0xf0
[ 33.492266] [<ffffffc0008c6b38>] __mmc_start_request+0x78/0x8c
[ 33.498057] [<ffffffc0008c6d6c>] mmc_start_request+0x220/0x240
[ 33.503848] [<ffffffc0008c6e04>] mmc_wait_for_req+0x78/0x250
[ 33.509468] [<ffffffc0008d70fc>] mmc_io_rw_extended+0x2ec/0x388
[ 33.515347] [<ffffffc0008d8fc0>] sdio_io_rw_ext_helper+0x160/0x268
[ 33.521483] [<ffffffc0008d93fc>] sdio_writesb+0x40/0x50
[ 33.526677] [<ffffffbffc338b38>] btmrvl_sdio_host_to_card+0x124/0x1bc [btmrvl_sdio]
[ 33.534283] [<ffffffbffc3290a0>] btmrvl_service_main_thread+0x384/0x428 [btmrvl]
[ 33.541626] [<ffffffc0002518e8>] kthread+0x140/0x158
[ 33.546550] Memory state around the buggy address:
[ 33.551305] ffffffc0d89b4980: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 33.558474] ffffffc0d89b4a00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 33.565643] >ffffffc0d89b4a80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 fc
[ 33.572809] ^
[ 33.579889] ffffffc0d89b4b00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 33.587055] ffffffc0d89b4b80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 33.594221] ==================================================================
The cause of this is that btmrvl_sdio_host_to_card can access memory region
out of its allocated space due to:
1. the requested block size is smaller than SDIO_BLOCK_SIZE, and/or
2. the allocated memory is not BTSDIO_DMA_ALIGN-aligned.
This patch fixes the issue by allocating a buffer which is big enough for
SDIO_BLOCK_SIZE transfer and/or BTSDIO_DMA_ALIGN address relocation.
Signed-off-by: Ricky Liang <jcliang@chromium.org>
The format of Intel Bluetooth firmware filename for bootloader product
is ibt-<hw_variant>-<device_revision_id>.sfi
Currently the driver uses a constant value 11 (0x0b) for hw_variant
to support LnP/SfP product. But new product like WsP product has
a different value such as 12 (0x0c).
To support the multiple products, this patch replaces the constant
value of hw_variant to the actual hw_variant value read from
the device.
Signed-off-by: Tedd Ho-Jeong An <tedd.an@intel.com>
This patch adds support for Intel Bluetooth device 3168 also known
as Sandy Peak (SdP).
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=8087 ProdID=0aa7 Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=1ms
Add hw id to ath3k usb device list and btusb blacklist
T: Bus=01 Lev=01 Prnt=01 Port=08 Cnt=02 Dev#= 4 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3487 Rev=00.02
Requires these firmwares:
ar3k/AthrBT_0x11020100.dfu and ar3k/ramps_0x11020100_40.dfu
Firmwares are available in linux-firmware.
Device found in a laptop ASUS model N552VW. It's an Atheros AR9462 chip.
Signed-off-by: Lauro Costa <lauro@polilinux.com.br>
This patch adds support for Intel Bluetooth device 8265 also known
as Windstorm Peak (WsP).
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 6 Spd=12 MxCh= 0
P: Vendor=8087 ProdID=0a2b Rev= 0.10
gpiod_get_optional can return either ERR_PTR or NULL pointer.
NULL case is not tested and then dereferenced later in desc_to_gpio.
Fix this by using non optional version which returns ERR_PTR in any
error case (this is not an optional gpio).
Use the same non optional version for the host-wake gpio.
Fixes: 765ea3abd116 ("Bluetooth: hci_intel: Retrieve host-wake IRQ")
On some arm-based platforms, we need to configure platform specific
parameters by device tree node and also define our node as a child
node of parent SDIO host controller.
This patch parses these parameters from device tree. It includes
calibration data download to firmware, wakeup pin configured to firmware,
and soc specific wake up gpio, which will be set as wakeup interrupt pin.
Signed-off-by: Xinming Hu <huxm@marvell.com>
We could print an uninitialized value in the error message.
hci_vhci driver creates a hci device object dynamically upon each
HCI_VENDOR_PKT write. Although it checks the already created object
and returns an error, it's still racy and may build multiple hci_dev
objects concurrently when parallel writes are performed, as the device
tracks only a single hci_dev object.
This patch introduces a mutex to protect against the concurrent device
creations.
Cc: <stable@vger.kernel.org>
This commit fixed:
trailing "*/"
trailing spaces
mixed indent
space between ~ and (
Signed-off-by: Maxim Zhukov <mussitantesmortem@gmail.com>
The write handler allocates skbs and queues them into data->readq.
Read side should read them, if there is any. If there is none, skbs
should be dropped by hdev->flush. But this happens only if the device
is HCI_UP, i.e. hdev->power_on work was triggered already. When it was
not, skbs stay allocated in the queue when /dev/vhci is closed. So
purge the queue in ->release.
Program to reproduce:
#include <err.h>
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <sys/uio.h>
int main()
char buf[] = { 0xff, 0 };
struct iovec iov = {
.iov_base = buf,
.iov_len = sizeof(buf),
int fd;
while (1) {
fd = open("/dev/vhci", O_RDWR);
if (fd < 0)
err(1, "open");
usleep(50);
if (writev(fd, &iov, 1) < 0)
err(1, "writev");
usleep(50);
close(fd);
return 0;
Result:
kmemleak: 4609 new suspected memory leaks
unreferenced object 0xffff88059f4d5440 (size 232):
comm "vhci", pid 1084, jiffies 4294912542 (age 37569.296s)
hex dump (first 32 bytes):
20 f0 23 87 05 88 ff ff 20 f0 23 87 05 88 ff ff .#..... .#.....
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff81ece010>] __alloc_skb+0x0/0x5a0
[<ffffffffa021886c>] vhci_create_device+0x5c/0x580 [hci_vhci]
[<ffffffffa0219436>] vhci_write+0x306/0x4c8 [hci_vhci]
Fixes: 23424c0d31 (Bluetooth: Add support creating virtual AMP controllers)
Cc: stable 3.13+ <stable@vger.kernel.org>
Both vhci_get_user and vhci_release race with open_timeout work. They
both contain cancel_delayed_work_sync, but do not test whether the
work actually created hdev or not. Since the work can be in progress
and _sync will wait for finishing it, we can have data->hdev allocated
when cancel_delayed_work_sync returns. But the call sites do 'if
(data->hdev)' *before* cancel_delayed_work_sync.
As a result:
* vhci_get_user allocates a second hdev and puts it into
data->hdev. The former is leaked.
* vhci_release does not release data->hdev properly as it thinks there
is none.
Fix both cases by moving the actual test *after* the call to
This can be hit by this program:
#include <err.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <unistd.h>
int main(int argc, char **argv)
int fd;
srand(time(NULL));
while (1) {
const int delta = (rand() % 200 - 100) * 100;
if (fd < 0)
err(1, "open");
usleep(1000000 + delta);
close(fd);
return 0;
And the result is:
BUG: KASAN: use-after-free in skb_queue_tail+0x13e/0x150 at addr ffff88006b0c1228
Read of size 8 by task kworker/u13:1/32068
BUG kmalloc-192 (Tainted: G E ): kasan: bad access detected
Disabling lock debugging due to kernel taint
INFO: Allocated in vhci_open+0x50/0x330 [hci_vhci] age=260 cpu=3 pid=32040
kmem_cache_alloc_trace+0x150/0x190
misc_open+0x35b/0x4e0
chrdev_open+0x23b/0x510
INFO: Freed in vhci_release+0xa4/0xd0 [hci_vhci] age=9 cpu=2 pid=32040
__slab_free+0x204/0x310
INFO: Slab 0xffffea0001ac3000 objects=16 used=13 fp=0xffff88006b0c1e00 flags=0x5fffff80004080
INFO: Object 0xffff88006b0c1200 @offset=4608 fp=0xffff88006b0c0600
Bytes b4 ffff88006b0c11f0: 09 df 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff88006b0c1200: 00 06 0c 6b 00 88 ff ff 00 00 00 00 00 00 00 00 ...k............
Object ffff88006b0c1210: 10 12 0c 6b 00 88 ff ff 10 12 0c 6b 00 88 ff ff ...k.......k....
Object ffff88006b0c1220: c0 46 c2 6b 00 88 ff ff c0 46 c2 6b 00 88 ff ff .F.k.....F.k....
Object ffff88006b0c1230: 01 00 00 00 01 00 00 00 e0 ff ff ff 0f 00 00 00 ................
Object ffff88006b0c1240: 40 12 0c 6b 00 88 ff ff 40 12 0c 6b 00 88 ff ff @..k....@..k....
Object ffff88006b0c1250: 50 0d 6e a0 ff ff ff ff 00 02 00 00 00 00 ad de P.n.............
Object ffff88006b0c1260: 00 00 00 00 00 00 00 00 ab 62 02 00 01 00 00 00 .........b......
Object ffff88006b0c1270: 90 b9 19 81 ff ff ff ff 38 12 0c 6b 00 88 ff ff ........8..k....
Object ffff88006b0c1280: 03 00 20 00 ff ff ff ff ff ff ff ff 00 00 00 00 .. .............
Object ffff88006b0c1290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff88006b0c12a0: 00 00 00 00 00 00 00 00 00 80 cd 3d 00 88 ff ff ...........=....
Object ffff88006b0c12b0: 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 . ..............
Redzone ffff88006b0c12c0: bb bb bb bb bb bb bb bb ........
Padding ffff88006b0c13f8: 00 00 00 00 00 00 00 00 ........
CPU: 3 PID: 32068 Comm: kworker/u13:1 Tainted: G B E 4.4.6-0-default #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.8.1-0-g4adadbd-20151112_172657-sheep25 04/01/2014
Workqueue: hci0 hci_cmd_work [bluetooth]
00000000ffffffff ffffffff81926cfa ffff88006be37c68 ffff88006bc27180
ffff88006b0c1200 ffff88006b0c1234 ffffffff81577993 ffffffff82489320
ffff88006bc24240 0000000000000046 ffff88006a100000 000000026e51eb80
Call Trace:
[<ffffffff81ec8ebe>] ? skb_queue_tail+0x13e/0x150
[<ffffffffa06e027c>] ? vhci_send_frame+0xac/0x100 [hci_vhci]
[<ffffffffa0c61268>] ? hci_send_frame+0x188/0x320 [bluetooth]
[<ffffffffa0c61515>] ? hci_cmd_work+0x115/0x310 [bluetooth]
[<ffffffff811a1375>] ? process_one_work+0x815/0x1340
[<ffffffff811a1f85>] ? worker_thread+0xe5/0x11f0
[<ffffffff811a1ea0>] ? process_one_work+0x1340/0x1340
[<ffffffff811b3c68>] ? kthread+0x1c8/0x230
ffff88006b0c1100: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff88006b0c1180: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff88006b0c1200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff88006b0c1280: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
ffff88006b0c1300: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Cc: Dmitry Vyukov <dvyukov@google.com>
