path: root/drivers/bus/Kconfig
2016-10-17bus: qcom-ebi2: depend on ARCH_QCOM or COMPILE_TESTLinus Walleij
This hides the option for people who do not want their Kconfig vision cluttered (i.e. x86) and enables compile testing apart from the supported main arch. Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-10-02bus: qcom-ebi2: depend on HAS_IOMEMLinus Walleij
After being asked to not depend on ARCH_QCOM* or similar, unsurprisingly compilation fails on UM as it has no I/O memory: drivers/built-in.o: In function `qcom_ebi2_probe': >> drivers/bus/qcom-ebi2.c:333: undefined reference to `devm_ioremap_resource' Fix this by letting the Kconfig atleast depend on HAS_IOMEM. Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Gross <andy.gross@linaro.org> Cc: linux-arm-msm@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-09-21Merge tag 'qcom-ebi2-arm-soc' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into next/drivers Pull "Qualcomm EBI2 bindings and bus driver" from Linus Walleij * tag 'qcom-ebi2-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator: bus: qcom: add EBI2 driver bus: qcom: add EBI2 device tree bindings Acked-by: Andy Gross <andy.gross@linaro.org>
2016-09-08bus: qcom: add EBI2 driverLinus Walleij
This adds a driver for the Qualcomm External Bus Interface EBI2 found in the MSM8660 and APQ8060 SoCs (at least). This was tested with the SMSC9112 ethernet on the APQ8060 Dragonboard sitting on top of the SLOW CS2. Some of my understanding if very vague and based on guesses and extrapolations: the documentation in APQ8060 Qualcomm Application Processor User Guide 80-N7150-14 Rev. A describes select features but does not document the register bit fields. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-08-16bus: tegra-aconnect: Make symbol tristateThierry Reding
The driver uses symbols that weren't being exported in earlier versions of the Linux kernel and hence it had to be made bool. The exports have been merged into v4.8-rc1, so the driver can now be built as a module again. Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-07-01bus: Add support for Tegra ACONNECTJon Hunter
Add a bus driver for the Tegra ACONNECT which is used to interface to various devices within the Audio Processing Engine (APE). The purpose of the bus driver is to register child devices that are accessed via the ACONNECT bus and through the device parent child relationship, ensure that the appropriate power domain and clocks are enabled for the ACONNECT when any of the child devices are active. Hence, the ACONNECT driver simply enables runtime-pm for the ACONNECT device so that when a child device is resumed, it will enable the power-domain and clocks associated with the ACONNECT. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-05-09arm-ccn: Enable building as moduleSuzuki K Poulose
arm-ccn driver uses irq_set_affinity, which is not exported and hence cannot be built as a module, eventhough we have all the bits ready. This patch makes use of the exported helper irq_set_affinity_hint() instead. Also, the __free_irq expects the affinity_hint to be NULL when we free the irq. So set the affinity_hint to NULL at clean up. Now that we can build it as a module, update the Kconfig to reflect the change. Cc: Will Deacon <will.deacon@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-04-25Merge tag 'arm-soc/for-4.7/drivers' of http://github.com/Broadcom/stblinux ↵Arnd Bergmann
into next/drivers Merge "Broadcom ARM-based SoCs drivers changes" from Florian Fainelli: - Justin adds a soc_dev driver to properly report to user-space the Broadcom STB SoC family, product and revision - Florian reworks how the brcmstb_gisb driver dependency is done to enable it on Broadcom STB MIPS-based SoCs and remove a select in arch/arm/mach-bcm/Kconfig * tag 'arm-soc/for-4.7/drivers' of http://github.com/Broadcom/stblinux: bus: brcmstb_gisb: Rework dependencies soc: brcmstb: add SoC driver to brcmstb
2016-04-18bus: brcmstb_gisb: Rework dependenciesFlorian Fainelli
Do not have the machine Kconfig entry point need to select BRCMSTB_GISB_ARB, instead, just let it be default ARCH_BRCMSTB which is a better way to deal with this. While at it, also make it default BMIPS_GENERIC so the legacy MIPS-based STB platforms can benefit from the same thing. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-03-28bus: simple-pm-bus: Use ARCH_RENESASSimon Horman
Make use of ARCH_RENESAS in place of ARCH_SHMOBILE. This is part of an ongoing process to migrate from ARCH_SHMOBILE to ARCH_RENESAS the motivation for which being that RENESAS seems to be a more appropriate name than SHMOBILE for the majority of Renesas ARM based SoCs. Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-03-21Merge tag 'arm64-perf' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm[64] perf updates from Will Deacon: "I have another mixed bag of ARM-related perf patches here. It's about 25% CPU and 75% interconnect, but with drivers/bus/ languishing without an obvious maintainer or tree, Olof and I agreed to keep all of these PMU patches together. I suspect a whole load of code from drivers/bus/arm-* can be moved under drivers/perf/, so that's on the radar for the future. Summary: - Initial support for ARMv8.1 CPU PMUs - Support for the CPU PMU in Cavium ThunderX - CPU PMU support for systems running 32-bit Linux in secure mode - Support for the system PMU in ARM CCI-550 (Cache Coherent Interconnect)" * tag 'arm64-perf' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (26 commits) drivers/perf: arm_pmu: avoid NULL dereference when not using devicetree arm64: perf: Extend ARMV8_EVTYPE_MASK to include PMCR.LC arm-cci: remove unused variable arm-cci: don't return value from void function arm-cci: make private functions static arm-cci: CoreLink CCI-550 PMU driver arm-cci500: Rearrange PMU driver for code sharing with CCI-550 PMU arm-cci: CCI-500: Work around PMU counter writes arm-cci: Provide hook for writing to PMU counters arm-cci: Add helper to enable PMU without synchornising counters arm-cci: Add routines to save/restore all counters arm-cci: Get the status of a counter arm-cci: write_counter: Remove redundant check arm-cci: Delay PMU counter writes to pmu::pmu_enable arm-cci: Refactor CCI PMU enable/disable methods arm-cci: Group writes to counter arm-cci: fix handling cpumask_any_but return value arm-cci: simplify sysfs attr handling drivers/perf: arm_pmu: implement CPU_PM notifier arm64: dts: Add Cavium ThunderX specific PMU ...
2016-02-29arm-cci: CoreLink CCI-550 PMU driverSuzuki K Poulose
Add ARM CoreLink CCI-550 cache coherent interconnect PMU driver support. The CCI-550 PMU shares all the attributes of CCI-500 PMU, except for an additional master interface (MI-6 - 0xe). CCI-550 requires the same work around as for CCI-500 to write to the PMU counter. Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2016-02-29arm-cci500: Rearrange PMU driver for code sharing with CCI-550 PMUSuzuki K Poulose
CCI-550 PMU shares most of the CCI-500 PMU attributes including the event format, PMU event codes. The only difference is an additional master interface (MI6 - 0xe). Hence we share the driver code for both, except for a model specific event validate method. This patch renames the common CCI500 symbols to CCI5xx, including the Kconfig symbol. No functional changes to the PMU driver. Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2016-02-01bus: uniphier-system-bus: revive tristate promptMasahiro Yamada
At first, commit 4b7f48d395a7 ("bus: uniphier-system-bus: add UniPhier System Bus driver") introduced this driver as a tristate one. Then, commit 326ea45aa827 ("bus: uniphier: allow only built-in driver") temporarily made it boolean in order to fix a link error in case it is compiled as a module. The root cause was fixed by commit b80443c2211c ("of/platform: export of_default_bus_match_table"). Now this driver can really be a module. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-12-31bus: uniphier: allow only built-in driverArnd Bergmann
Building the newly added uniphier system bus driver as a module causes a link error, so let's only allow it to be built-in for now, to fix allmodconfig: ERROR: "of_default_bus_match_table" [drivers/bus/uniphier-system-bus.ko] undefined! Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-12-22bus: uniphier-system-bus: add UniPhier System Bus driverMasahiro Yamada
The UniPhier System Bus is an external bus that connects on-board devices to the UniPhier SoC. Each bank (chip select) is dynamically mapped to the CPU-viewed address base via the bus controller. The bus controller must be configured before any access to the bus. This driver parses the "ranges" property of the System Bus node and initialized the bus controller. After the bus becomes ready, devices below it are populated. Note: Each bank can be mapped anywhere in the supported address space; there is nothing preventing us from assigning bank 0 on 0x42000000, 0x43000000, or anywhere as long as such region is not used by others. So, the "ranges" is just one possible software configuration, which does not seem to fit in device tree because device tree is a hardware description language. However, of_translate_address() requires "ranges" in every bus node between CPUs and device mapped on the CPU address space. In other words, "ranges" properties must be statically defined in device tree. After some discussion, I decided the dynamic address reassignment by the driver is too bothersome. Instead, the device tree should provide a reasonable translation setup that the OS can rely on. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Rob Herring <robh@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-11-10Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "As we've enabled multiplatform kernels on ARM, and greatly done away with the contents under arch/arm/mach-*, there's still need for SoC-related drivers to go somewhere. Many of them go in through other driver trees, but we still have drivers/soc to hold some of the "doesn't fit anywhere" lowlevel code that might be shared between ARM and ARM64 (or just in general makes sense to not have under the architecture directory). This branch contains mostly such code: - Drivers for qualcomm SoCs for SMEM, SMD and SMD-RPM, used to communicate with power management blocks on these SoCs for use by clock, regulator and bus frequency drivers. - Allwinner Reduced Serial Bus driver, again used to communicate with PMICs. - Drivers for ARM's SCPI (System Control Processor). Not to be confused with PSCI (Power State Coordination Interface). SCPI is used to communicate with the assistant embedded cores doing power management, and we have yet to see how many of them will implement this for their hardware vs abstracting in other ways (or not at all like in the past). - To make confusion between SCPI and PSCI more likely, this release also includes an update of PSCI to interface version 1.0. - Rockchip support for power domains. - A driver to talk to the firmware on Raspberry Pi" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits) soc: qcom: smd-rpm: Correct size of outgoing message bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus bus: sunxi-rsb: Add Allwinner Reduced Serial Bus (RSB) controller bindings ARM: bcm2835: add mutual inclusion protection drivers: psci: make PSCI 1.0 functions initialization version dependent dt-bindings: Correct paths in Rockchip power domains binding document soc: rockchip: power-domain: don't try to print the clock name in error case soc: qcom/smem: add HWSPINLOCK dependency clk: berlin: add cpuclk ARM: berlin: dts: add CLKID_CPU for BG2Q ARM: bcm2835: Add the Raspberry Pi firmware driver soc: qcom: smem: Move RPM message ram out of smem DT node soc: qcom: smd-rpm: Correct the active vs sleep state flagging soc: qcom: smd: delete unneeded of_node_put firmware: qcom-scm: build for correct architecture level soc: qcom: smd: Correct SMEM items for upper channels qcom-scm: add missing prototype for qcom_scm_is_available() qcom-scm: fix endianess issue in __qcom_scm_is_call_available soc: qcom: smd: Reject send of too big packets soc: qcom: smd: Handle big endian CPUs ...
2015-10-26bus: sunxi-rsb: Add driver for Allwinner Reduced Serial BusChen-Yu Tsai
Reduced Serial Bus (RSB) is an Allwinner proprietery interface used to communicate with PMICs and other peripheral ICs. RSB is a two-wire push-pull serial bus that supports 1 master device and up to 15 active slave devices. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Mark Brown <broonie@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-09-28arm-cci500: Don't enable PMU driver by defaultSuzuki K. Poulose
Disable building CCI-500 PMU driver by default. Reported-by: Russell King <linux@arm.linux.org.uk> Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: arm@kernel.org Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-05-29arm-cci: Add CCI-500 PMU supportSuzuki K. Poulose
CCI-500 provides 8 event counters which can count any of the supported events independently. The PMU event id is a 9-bit value made of two parts. bits [8:5] - Source port 0x0-0x6 Slave Ports 0x8-0xD Master Ports 0xf Global Events to CCI 0x7,0xe Reserved bits [0:4] - Event code (specific to each type of port) The generic CCI-500 controlling interface remains the same with CCI-400. However there are some differences in the PMU event counters. - No cycle counter - Upto 8 counters(4 in CCI-400) - Each counter area is 64K(4K in CCI400) - The counter0 starts at offset 0x10000 from the base of CCI Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: devicetree@vger.kernel.org Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29arm-cci: Sanitise CCI400 PMU driver specific codeSuzuki K. Poulose
Rename CCI400 specific defintions from CCI_xxx to CCI400_xxx. Introduce generic ARM_CCI_PMU to cover common code for handling the CCI PMU. Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29arm-cci: Do not enable CCI-400 PMU by defaultSuzuki K. Poulose
Do not enable CCI-400 PMU by default and fix the dependency on PERF_EVENTS than HW_PERF_EVENTS. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: arm@kernel.org Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-04-22Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "Driver updates for v4.1. Some of these are for drivers/soc, where we find more and more SoC-specific drivers these days. Some are for other driver subsystems where we have received acks from the appropriate maintainers. The larger parts of this branch are: - MediaTek support for their PMIC wrapper interface, a high-level interface for talking to the system PMIC over a dedicated I2C interface. - Qualcomm SCM driver has been moved to drivers/firmware. It's used for CPU up/down and needs to be in a shared location for arm/arm64 common code. - cleanup of ARM-CCI PMU code. - another set of cleanusp to the OMAP GPMC code" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits) soc/mediatek: Remove unused variables clocksource: atmel-st: select MFD_SYSCON soc: mediatek: Add PMIC wrapper for MT8135 and MT8173 SoCs arm-cci: Fix CCI PMU event validation arm-cci: Split the code for PMU vs driver support arm-cci: Get rid of secure transactions for PMU driver arm-cci: Abstract the CCI400 PMU specific definitions arm-cci: Rearrange code for splitting PMU vs driver code drivers: cci: reject groups spanning multiple HW PMUs ARM: at91: remove useless include clocksource: atmel-st: remove mach/hardware dependency clocksource: atmel-st: use syscon/regmap ARM: at91: time: move the system timer driver to drivers/clocksource ARM: at91: properly initialize timer ARM: at91: at91rm9200: remove deprecated arm_pm_restart watchdog: at91rm9200: implement restart handler watchdog: at91rm9200: use the system timer syscon mfd: syscon: Add atmel system timer registers definition ARM: at91/dt: declare atmel,at91rm9200-st as a syscon soc: qcom: gsbi: Add support for ADM CRCI muxing ...
2015-04-03Merge tag 'arm-perf-4.1' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into next/drivers Merge "arm-cci PMU updates for 4.1" from Will Deacon: CCI-400 PMU updates This series reworks some of the CCI-400 PMU code so that it can be used on both ARM and ARM64-based systems, without the need to boot in secure mode on the latter. This paves the way for CCI-500 support in future. * tag 'arm-perf-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/will/linux: arm-cci: Fix CCI PMU event validation arm-cci: Split the code for PMU vs driver support arm-cci: Get rid of secure transactions for PMU driver arm-cci: Abstract the CCI400 PMU specific definitions arm-cci: Rearrange code for splitting PMU vs driver code drivers: cci: reject groups spanning multiple HW PMUs + Linux 4.0-rc4 Signed-off-by: Olof Johansson <olof@lixom.net>
2015-03-31MIPS: Add CDMM bus supportJames Hogan
Add MIPS Common Device Memory Map (CDMM) support in the form of a bus in the standard Linux device model. Each device attached via CDMM is discoverable via an 8-bit type identifier and may contain a number of blocks of memory mapped registers in the CDMM region. IRQs are expected to be handled separately. Due to the per-cpu (per-VPE for MT cores) nature of the CDMM devices, all the driver callbacks take place from workqueues which are run on the right CPU for the device in question, so that the driver doesn't need to be as concerned about which CPU it is running on. Callbacks also exist for when CPUs are taken offline, so that any per-CPU resources used by the driver can be disabled so they don't get forcefully migrated. CDMM devices are created as children of the CPU device they are attached to. Any existing CDMM configuration by the bootloader will be inherited, however platforms wishing to enable CDMM should implement the weak mips_cdmm_phys_base() function (see asm/cdmm.h) so that the bus driver knows where it should put the CDMM region in the physical address space if the bootloader hasn't already enabled it. A mips_cdmm_early_probe() function is also provided to allow early boot or particularly low level code to set up the CDMM region and probe for a specific device type, for example early console or KGDB IO drivers for the EJTAG Fast Debug Channel (FDC) CDMM device. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/9599/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-03-27arm-cci: Split the code for PMU vs driver supportSuzuki K. Poulose
This patch separates the PMU driver code from the low level CCI driver code and enables the PMU driver for ARM64. Introduces config options for both. ARM_CCI400_PORT_CTRL - controls the low level driver code for CCI400 ports. ARM_CCI400_PMU - controls the PMU driver code ARM_CCI400_COMMON - Common defintions for CCI400 This patch also changes: ARM_CCI - common code for probing the CCI devices. This can be used for adding support for newer CCI versions(e.g, CCI-500). Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Kukjin Kim <kgene@kernel.org> Cc: Abhilash Kesavan <a.kesavan@samsung.com> Cc: Liviu Dudau <liviu.dudau@arm.com> Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-02-24drivers: bus: Add Simple Power-Managed Bus DriverGeert Uytterhoeven
Add a driver for transparent busses that don't need a real driver, but where the bus controller is part of a PM domain, or under the control of a functional clock. Typically, the bus controller's PM domain and/or clock must be enabled for child devices connected to the bus (either on-SoC or externally) to function. Hence the sole purpose of this driver is to enable its clock and PM domain (if exist(s)), which are specified in the DT and managed from platform and PM domain code, and to probe for child devices. Due to the child-parent relationship with devices connected to the bus, PM domain and clock state transitions are handled in the correct order. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Tested-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2015-02-24drivers: bus: Sort Kconfig entries alphabeticallyGeert Uytterhoeven
2014-11-28bus: brcmstb_gisb: Make the driver buildable on MIPSKevin Cernekee
BCM7xxx ARM and MIPS platforms share a similar hardware block for reporting GISB errors, so they both benefit from the use of this driver. Conditionally compile the ARM-specific bus error handler so that the GISB error IRQ handler works on other architectures. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2014-07-24bus: ARM CCN: add PERF_EVENTS dependencyArnd Bergmann
The CCN driver makes no sense without PERF_EVENTS, and trying to build it when that option is disabled results in compile errors, so it's best to just add a strong Kconfig dependency. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-07-23bus: ARM CCN PMU driverPawel Moll
Driver providing perf backend for ARM Cache Coherent Network interconnect. Supports counting all hardware events and crosspoint watchpoints. Currently works with CCN-504 only, although there should be no changes required for CCN-508 (just impossible to test it now). Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-06-17bus/arm-cci: add dependency on OF && CPU_V7Arnd Bergmann
The arm-cci code uses device tree helpers for initialization that don't work on kernels built without CONFIG_OF. Further, it contains an inline assembly in cci_enable_port_for_self() that uses ARMv7 instructions and fails to build when targetting other ARM instruction set versions. This works around both issues by limiting the scope of the Kconfig symbol to platforms that can actually build this driver cleanly. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Cc: Shawn Guo <shawn.guo@linaro.org>
2014-06-02Merge tag 'drivers-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC driver changes from Olof Johansson: "SoC-near driver changes that we're merging through our tree. Mostly because they depend on other changes we have staged, but in some cases because the driver maintainers preferred that we did it this way. This contains a largeish cleanup series of the omap_l3_noc bus driver, cpuidle rework for Exynos, some reset driver conversions and a long branch of TI EDMA fixes and cleanups, with more to come next release. The TI EDMA cleanups is a shared branch with the dmaengine tree, with a handful of Davinci-specific fixes on top. After discussion at last year's KS (and some more on the mailing lists), we are here adding a drivers/soc directory. The purpose of this is to keep per-vendor shared code that's needed by different drivers but that doesn't fit into the MFD (nor drivers/platform) model. We expect to keep merging contents for this hierarchy through arm-soc so we can keep an eye on what the vendors keep adding here and not making it a free-for-all to shove in crazy stuff" * tag 'drivers-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (101 commits) cpufreq: exynos: Fix driver compilation with ARCH_MULTIPLATFORM tty: serial: msm: Remove direct access to GSBI power: reset: keystone-reset: introduce keystone reset driver Documentation: dt: add bindings for keystone pll control controller Documentation: dt: add bindings for keystone reset driver soc: qcom: fix of_device_id table ARM: EXYNOS: Fix kernel panic when unplugging CPU1 on exynos ARM: EXYNOS: Move the driver to drivers/cpuidle directory ARM: EXYNOS: Cleanup all unneeded headers from cpuidle.c ARM: EXYNOS: Pass the AFTR callback to the platform_data ARM: EXYNOS: Move S5P_CHECK_SLEEP into pm.c ARM: EXYNOS: Move the power sequence call in the cpu_pm notifier ARM: EXYNOS: Move the AFTR state function into pm.c ARM: EXYNOS: Encapsulate the AFTR code into a function ARM: EXYNOS: Disable cpuidle for exynos5440 ARM: EXYNOS: Encapsulate boot vector code into a function for cpuidle ARM: EXYNOS: Pass wakeup mask parameter to function for cpuidle ARM: EXYNOS: Remove ifdef for scu_enable in pm ARM: EXYNOS: Move scu_enable in the cpu_pm notifier ARM: EXYNOS: Use the cpu_pm notifier for pm ...
2014-05-26ARM: vexpress: refine dependencies for new codeArnd Bergmann
The versatile express changes for 3.16 introduced a number of build regressions for randconfig kernels by not tracking dependencies between the components right. This patch tries to rectify that: * the mach-vexpress code cannot link without the syscfg driver, which in turn needs MFD_VEXPRESS_SYSREG * various drivers call devm_regmap_init_vexpress_config(), which has to be exported so it can be used by loadable modules * the configuration bus uses OF DT helper functions that are not available to platforms disable CONFIG_OF * The sysreg driver exports GPIOs through gpiolib, which can be disabled on some platforms. * The clocksource code cannot be built on platforms that don't use modern timekeeping but rely on gettimeoffset. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-24bus: add Broadcom GISB bus arbiter timeout/error handlerFlorian Fainelli
This patch adds support for the Broadcom GISB arbiter bus timeout/error handler. GISB is a proprietary bus used by Broadcom Set Top Box System-on-a-chip devices (BCM7xxx) which allows multiple masters and clients to be interfaced with each other. The bus arbiter offers support for generating two interrupts towards the host CPU, thus allowing us to "catch" clock gated masters, or masters being volontarily blocked for powersaving purposes, or do general system troubleshooting. We also register a hook with the ARM fault exception handling to allow printing a more informative message than "imprecise external abort at 0x00000000" for instance. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-15mfd: vexpress: Convert custom func API to regmapPawel Moll
Components of the Versatile Express platform (configuration microcontrollers on motherboard and daughterboards in particular) talk to each other over a custom configuration bus. They provide miscellaneous functions (from clock generator control to energy sensors) which are represented as platform devices (and Device Tree nodes). The transactions on the bus can be generated by different "bridges" in the system, some of which are universal for the whole platform (for the price of high transfer latencies), others restricted to a subsystem (but much faster). Until now drivers for such functions were using custom "func" API, which is being replaced in this patch by regmap calls. This required: * a rework (and move to drivers/bus directory, as suggested by Samuel and Arnd) of the config bus core, which is much simpler now and uses device model infrastructure (class) to keep track of the bridges; non-DT case (soon to be retired anyway) is simply covered by a special device registration function * the new config-bus driver also takes over device population, so there is no need for special matching table for of_platform_populate nor "simple-bus" hack in the arm64 model dtsi file (relevant bindings documentation has been updated); this allows all the vexpress devices fit into normal device model, making it possible to remove plenty of early inits and other hacks in the near future * adaptation of the syscfg bridge implementation in the sysreg driver, again making it much simpler; there is a special case of the "energy" function spanning two registers, where they should be both defined in the tree now, but backward compatibility is maintained in the code * modification of the relevant drivers: * hwmon - just a straight-forward API change * power/reset driver - API change * regulator - API change plus error handling simplification * osc clock driver - this one required larger rework in order to turn in into a standard platform driver Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Mark Brown <broonie@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mike Turquette <mturquette@linaro.org>
2013-08-16drivers: bus: imx-weim: Add support for i.MX1/21/25/27/31/35/50/51/53Alexander Shiyan
This patch adds WEIM support for all i.MX CPUs supported by the kernel. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-07-02Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree changes from Arnd Bergmann: "These changes from 30 individual branches for the most part update device tree files, but there are also a few source code changes that have crept in this time, usually in order to atomically move over a driver from using hardcoded data to DT probing. A number of platforms change their DT files to use the C preprocessor, which is causing a bit of churn, but that is hopefully only this once" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits) ARM: at91: dt: rm9200ek: add spi support ARM: at91: dt: rm9200: add spi support ARM: at91/DT: at91sam9n12: add SPI DMA client infos ARM: at91/DT: sama5d3: add SPI DMA client infos ARM: at91/DT: fix SPI compatibility string ARM: Kirkwood: Fix the internal register ranges translation ARM: dts: bcm281xx: change comment to C89 style ARM: mmc: bcm281xx SDHCI driver (dt mods) ARM: nomadik: add the new clocks to the device tree clk: nomadik: implement the Nomadik clocks properly ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency ARM: dts: omap4-panda: Fix DVI EDID reads ARM: dts: omap4-panda: Add USB Host support arm: mvebu: enable mini-PCIe connectors on Armada 370 RD ARM: shmobile: irqpin: add a DT property to enable masking on parent ARM: dts: AM43x EPOS EVM support ARM: dts: OMAP5: Add bandgap DT entry ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone ...
2013-06-17drivers: bus: add a new driver for WEIMHuang Shijie
The WEIM(Wireless External Interface Module) works like a bus. You can attach many different devices on it, such as NOR, onenand. In the case of i.MX6q-sabreauto, the NOR is connected to WEIM. This patch also adds the devicetree binding document. The driver only works when the devicetree is enabled. Signed-off-by: Huang Shijie <b32955@freescale.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-05-29drivers: bus: add ARM CCI supportLorenzo Pieralisi
On ARM multi-cluster systems coherency between cores running on different clusters is managed by the cache-coherent interconnect (CCI). It allows broadcasting of TLB invalidates and memory barriers and it guarantees cache coherency at system level through snooping of slave interfaces connected to it. This patch enables the basic infrastructure required in Linux to handle and programme the CCI component. Non-local variables used by the CCI management functions called by power down function calls after disabling the cache must be flushed out to main memory in advance, otherwise incoherency of those values may occur if they are sitting in the cache of some other CPU when power down functions execute. Driver code ensures that relevant data structures are flushed from inner and outer caches after the driver probe is completed. CCI slave port resources are linked to set of CPUs through bus masters phandle properties that link the interface resources to masters node in the device tree. Documentation describing the CCI DT bindings is provided with the patch. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2013-03-28bus: introduce an Marvell EBU MBus driverThomas Petazzoni
The Marvell EBU SoCs have a configurable physical address space layout: the physical ranges of memory used to address PCI(e) interfaces, NOR flashes, SRAM and various other types of memory are configurable by software, through a mechanism of so-called 'address decoding windows'. This new driver mvebu-mbus consolidates the existing code to address the configuration of these memory ranges, which is spread into mach-mvebu, mach-orion5x, mach-mv78xx0, mach-dove and mach-kirkwood. Following patches convert each Marvell EBU SoC family to use this driver, therefore removing the old code that was configuring the address decoding windows. It is worth mentioning that the MVEBU_MBUS Kconfig option is intentionally added as a blind option. The new driver implements and exports the mv_mbus_dram_info() function, which is used by various Marvell drivers throughout the tree to get access to window configuration parameters that they require. This function is also implemented in arch/arm/plat-orion/addr-map.c, which ultimately gets removed at the end of this patch series. So, in order to preserve bisectability, we want to ensure that *either* this new driver, *or* the legacy code in plat-orion/addr-map.c gets compiled in. By making MVEBU_MBUS a blind option, we are sure that only a platform that does 'select MVEBU_MBUS' will get this new driver compiled in. Therefore, throughout the next patches that convert the Marvell sub-architectures one after the other to this new driver, we add the 'select MVEBU_MBUS' and also ensure to remove plat-orion/addr-map.c from the build for this specific sub-architecture. This ensures that bisectability is preserved. Ealier versions of this driver had a DT binding, but since those were not yet agreed upon, they were removed. The driver still uses of_device_id to find the SoC specific details according to the string passed to mvebu_mbus_init(). The plan is to re-introduce a proper DT binding as a followup set of patches. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-12-16ARM: OMAP: Fix drivers to depend on omap for internal devicesTony Lindgren
These devices are not available on other architectures, so let's limit them to omap. If the driver subsystem maintainers want to build test system wide changes without building for each target, it's easy to carry a test patch that just strips out the depends entries from Kconfig files. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-19drivers: bus: Move the OMAP interconnect driver to drivers/bus/Santosh Shilimkar
OMAP interconnect drivers are used for the interconnect error handling. Since they are bus driver, lets move it to newly created drivers/bus. Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-22drivers: bus: add a new driver for omap-ocp2scpKishon Vijay Abraham I
Adds a new driver *omap-ocp2scp*. This driver takes the responsibility of creating all the devices that is connected to OCP2SCP. In the case of OMAP4, USB2PHY is connected to ocp2scp. This also includes device tree support for ocp2scp driver and the documentation with device tree binding information is updated. Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
