path: root/drivers/bus
2015-02-24drivers: bus: Add Simple Power-Managed Bus DriverGeert Uytterhoeven
Add a driver for transparent busses that don't need a real driver, but where the bus controller is part of a PM domain, or under the control of a functional clock. Typically, the bus controller's PM domain and/or clock must be enabled for child devices connected to the bus (either on-SoC or externally) to function. Hence the sole purpose of this driver is to enable its clock and PM domain (if exist(s)), which are specified in the DT and managed from platform and PM domain code, and to probe for child devices. Due to the child-parent relationship with devices connected to the bus, PM domain and clock state transitions are handled in the correct order. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Tested-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2015-02-24drivers: bus: Sort Makefile entries alphabeticallyGeert Uytterhoeven
2015-02-24drivers: bus: Sort Kconfig entries alphabeticallyGeert Uytterhoeven
2015-02-17Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New and updated SoC support. Also included are some cleanups where the platform maintainers hadn't separated cleanups from new developent in separate branches. Some of the larger things worth pointing out: - A large set of changes from Alexandre Belloni and Nicolas Ferre preparing at91 platforms for multiplatform and cleaning up quite a bit in the process. - Removal of CSR's "Marco" SoC platform that never made it out to the market. We love seeing these since it means the vendor published support before product was out, which is exactly what we want! New platforms this release are: - Conexant Digicolor (CX92755 SoC) - Hisilicon HiP01 SoC - CSR/sirf Atlas7 SoC - ST STiH418 SoC - Common code changes for Nvidia Tegra132 (64-bit SoC) We're seeing more and more platforms having a harder time labelling changes as cleanups vs new development -- which is a good sign that we've come quite far on the cleanup effort. So over time we might start combining the cleanup and new-development branches more" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits) ARM: at91/trivial: unify functions and machine names ARM: at91: remove at91_dt_initialize and machine init_early() ARM: at91: change board files into SoC files ARM: at91: remove at91_boot_soc ARM: at91: move alternative initial mapping to board-dt-sama5.c ARM: at91: merge all SOC_AT91SAM9xxx ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init() ARM: digicolor: select syscon and timer ARM: zynq: Simplify SLCR initialization ARM: zynq: PM: Fixed simple typo. ARM: zynq: Setup default gpio number for Xilinx Zynq ARM: digicolor: add low level debug support ARM: initial support for Conexant Digicolor CX92755 SoC ARM: OMAP2+: Add dm816x hwmod support ARM: OMAP2+: Add clock domain support for dm816x ARM: OMAP2+: Add board-generic.c entry for ti81xx ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage ARM: at91: remove unused mach/system_rev.h ARM: at91: stop using HAVE_AT91_DBGUx ARM: at91: fix ordering of SRAM and PM initialization ...
2015-02-13arm: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. * Line termination only requires one extra space at the end of the buffer. Use PAGE_SIZE - 1 instead of PAGE_SIZE - 2 when formatting. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-23Merge tag 'mvebu-fixes-3.19-4' of git://git.infradead.org/linux-mvebu into fixesOlof Johansson
Merge "mvebu/fixes #3" from Andrew Lunn: mvebu fixes for 3.19. (Part 4) bus: mvebu-mbus: fix support of MBus window 13 * tag 'mvebu-fixes-3.19-4' of git://git.infradead.org/linux-mvebu: bus: mvebu-mbus: fix support of MBus window 13 ARM: mvebu: completely disable hardware I/O coherency Signed-off-by: Olof Johansson <olof@lixom.net>
2015-01-19bus: mvebu-mbus: make sure SDRAM CS for DMA don't overlap the MBus bridge windowThomas Petazzoni
The mvebu-mbus driver reads the SDRAM window registers, and make the information about the DRAM CS configuration available to device drivers using the mv_mbus_dram_info() API. This information is used by the DMA-capable device drivers to program their address decoding windows. Until now, we were basically providing the SDRAM window register details as is. However, it turns out that the DMA capability of the CESA cryptographic engine consists in doing DMA being the DRAM and the crypto SRAM mapped as a MBus window. For this case, it is very important that the SDRAM CS information does not overlap with the MBus bridge window. Therefore, this commit improves the mvebu-mbus driver to make sure we adjust the SDRAM CS information so that it doesn't overlap with the MBus bridge window. This problem was reported by Boris Brezillon, while working on the mv_cesa driver for Armada 37x/38x/XP. We use the memblock memory information to know where the usable RAM is located, as this information is guaranteed to be correct on all SoC variants. We could have used the MBus bridge window registers on Armada 370/XP, but they are not really used on Armada 375/38x (Cortex-A9 based), since the PL310 L2 filtering is used instead to discriminate between RAM accesses and I/O accesses. Therefore, using the memblock information is more generic and works accross the different platforms. Reported-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> [Andrew Lunn <andrew@lunn.ch>: Fixed merge conflict] Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2015-01-19bus: mvebu-mbus: fix support of MBus window 13 on Armada XP/375/38xMichal Mazur
On Armada XP, 375 and 38x the MBus window 13 has the remap capability, like windows 0 to 7. However, the mvebu-mbus driver isn't currently taking into account this special case, which means that when window 13 is actually used, the remap registers are left to 0, making the device using this MBus window unavailable. To make things even more fun, the hardware designers have chosen to put the window 13 remap registers in a completely custom location, using a logic that differs from the one used for all other remappable windows. To solve this problem, this commit: * Adds a SoC specific function to calculate offset of remap registers to the mvebu_mbus_soc_data structure. This function, ->win_remap_offset(), returns the offset of the remap registers, or MVEBU_MBUS_NO_REMAP if the window does not have the remap capability. This new function replaces the previous integer field num_remappable_wins, which was insufficient to encode the special case of window 13. * Adds an implementation of the ->win_remap_offset() function for the various SoC families. Some have 2 first windows that are remapable, some the 4 first, some the 8 first, and then the Armada XP/375/38x case where the 8 first are remapable plus the special window 13. This is implemented in functions generic_mbus_win_remap_2_offset(), generic_mbus_win_remap_4_offset(), generic_mbus_win_remap_8_offset() and armada_xp_mbus_win_remap_offset() respectively. * Change the code to use the ->win_remap_offset() function when accessing the remap registers, and also to use a newly introduced mvebu_mbus_window_is_remappable() helper function that tells whether a given window is remapable or not. * Separate Armada 370 from XP/375/38X because the window 13 of Armada 370 does not support the remap capability. [Thomas: adapted for the mainline kernel, minor clarifications in the code, reword the commit log.] Signed-off-by: Michal Mazur <arg@semihalf.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> [Andrew Lunn <andrew@lunn.ch>: Undo the simple fix for stable] Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2015-01-19bus: mvebu-mbus: use automatic I/O synchronization barriersThomas Petazzoni
Instead of using explicit I/O synchronization barriers shoehorned inside the streaming DMA mappings API (in arch/arm/mach-mvebu/coherency.c), we are switching to use automatic I/O synchronization barrier. The primary motivation for this change is that explicit I/O synchronization barriers are not only needed for streaming DMA mappings (which can easily be done by overriding the dma_map_ops), but also for coherent DMA mappings (which is a lot less easy to do, since the kernel assumes such mappings are coherent and don't require any sort of cache maintenance operation to ensure the consistency of the buffers). Switching to automatic I/O synchronization barriers will also allow us to use the existing arm_coherent_dma_ops instead of our custom arm_dma_ops. In order to use automatic I/O synchronization barriers, this commit changes mvebu-mbus in two ways: - It enables automatic I/O synchronization barriers in the 0x84 register of the MBus bridge, by enabling such barriers for all MBus units. This enables automatic barriers for the on-SoC peripherals that are doing DMA. - It enables the SyncEnable bit in the MBus windows, so that PCIe devices also use automatic I/O synchronization barrier. This automatic synchronization barrier relies on the assumption that at least one register of a given hardware unit is read before the driver accesses the DMA mappings modified by this unit. This assumption is guaranteed for PCI devices by vertue of the PCI standard, and we can reasonably verify that this assumption is also true for the limited number of platform drivers doing DMA used on Marvell EBU platforms. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2015-01-19bus: mvebu-mbus: fix support of MBus window 13Andrew Lunn
On Armada XP, 375 and 38x the MBus window 13 has the remap capability, like windows 0 to 7. However, the mvebu-mbus driver isn't currently taking into account this special case, which means that when window 13 is actually used, the remap registers are left to 0, making the device using this MBus window unavailable. As a minimal fix for stable, don't use window 13. A full fix will follow later. Fixes: fddddb52a6c ("bus: introduce an Marvell EBU MBus driver") Cc: <stable@vger.kernel.org> # v3.10+ Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch>
2015-01-16drivers: bus: check cci device tree node statusAbhilash Kesavan
The arm-cci driver completes the probe sequence even if the cci node is marked as disabled. Add a check in the driver to honour the cci status in the device tree. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Acked-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Sudeep Holla <sudeep.holla@arm.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-09Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. The largest single change here this time around is the Tegra iommu/memory controller driver, which gets updated to the new iommu DT binding. More drivers like this are likely to follow for the following merge window, but we should be able to do those through the iommu maintainer. Other notable changes are: - reset controller drivers from the reset maintainer (socfpga, sti, berlin) - fixes for the keystone navigator driver merged last time - at91 rtc driver changes related to the at91 cleanups - ARM perf driver changes from Will Deacon - updates for the brcmstb_gisb driver" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits) clocksource: arch_timer: Allow the device tree to specify uninitialized timer registers clocksource: arch_timer: Fix code to use physical timers when requested memory: Add NVIDIA Tegra memory controller support bus: brcmstb_gisb: Add register offset tables for older chips bus: brcmstb_gisb: Look up register offsets in a table bus: brcmstb_gisb: Introduce wrapper functions for MMIO accesses bus: brcmstb_gisb: Make the driver buildable on MIPS of: Add NVIDIA Tegra memory controller binding ARM: tegra: Move AHB Kconfig to drivers/amba amba: Add Kconfig file clk: tegra: Implement memory-controller clock serial: samsung: Fix serial config dependencies for exynos7 bus: brcmstb_gisb: resolve section mismatch ARM: common: edma: edma_pm_resume may be unused ARM: common: edma: add suspend resume hook powerpc/iommu: Rename iommu_[un]map_sg functions rtc: at91sam9: add DT bindings documentation rtc: at91sam9: use clk API instead of relying on AT91_SLOW_CLOCK ARM: at91: add clk_lookup entry for RTT devices rtc: at91sam9: rework the Kconfig description ...
2014-12-09Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support, notable changes include: - bcm: brcmstb SMP support initial iproc/cygnus support - exynos: Exynos4415 SoC support PMU and suspend support for Exynos5420 PMU support for Exynos3250 pm related maintenance - imx: new LS1021A SoC support vybrid 610 global timer support - integrator: convert to using multiplatform configuration - mediatek: earlyprintk support for mt8127/mt8135 - meson: meson8 soc and l2 cache controller support - mvebu: Armada 38x CPU hotplug support drop support for prerelease Armada 375 Z1 stepping extended suspend support, now works on Armada 370/XP - omap: hwmod related maintenance prcm cleanup - pxa: initial pxa27x DT handling - rockchip: SMP support for rk3288 add cpu frequency scaling support - shmobile: r8a7740 power domain support various small restart, timer, pci apmu changes - sunxi: Allwinner A80 (sun9i) earlyprintk support - ux500: power domain support Overall, a significant chunk of changes, coming mostly from the usual suspects: omap, shmobile, samsung and mvebu, all of which already contain a lot of platform specific code in arch/arm" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (187 commits) ARM: mvebu: use the cpufreq-dt platform_data for independent clocks soc: integrator: Add terminating entry for integrator_cm_match ARM: mvebu: add SDRAM controller description for Armada XP ARM: mvebu: adjust mbus controller description on Armada 370/XP ARM: mvebu: add suspend/resume DT information for Armada XP GP ARM: mvebu: synchronize secondary CPU clocks on resume ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume ARM: mvebu: Armada XP GP specific suspend/resume code ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume ARM: mvebu: implement suspend/resume support for Armada XP clk: mvebu: add suspend/resume for gatable clocks bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration bus: mvebu-mbus: suspend/resume support clocksource: time-armada-370-xp: add suspend/resume support irqchip: armada-370-xp: Add suspend/resume support ARM: add lolevel debug support for asm9260 ARM: add mach-asm9260 ARM: EXYNOS: use u8 for val[] in struct exynos_pmu_conf power: reset: imx-snvs-poweroff: add power off driver for i.mx6 ARM: imx: temporarily remove CONFIG_SOC_FSL from LS1021A ...
2014-12-08Merge branch 'brcm/stb-smp-uart' into next/driversArnd Bergmann
This resolves a nonobvious merge conflict that I got wrong the first time. * brcm/stb-smp-uart: bus: brcmstb_gisb: save and restore GISB timeout bus: brcmstb_gisb: register the fault code hook ARM: brcmstb: Kconfig: drop unneeded symbol selections ARM: brcmstb: reintroduce SMP support ARM: brcmstb: add debug UART for earlyprintk support Conflicts: drivers/bus/brcmstb_gisb.c Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Florian Fainelli <f.fainelli@gmail.com>
2014-12-04Merge tag 'mvebu-soc-suspend-3.19' of git://git.infradead.org/linux-mvebu ↵Arnd Bergmann
into next/soc Pull "mvebu SoC suspend changes for v3.19" from Jason Cooper: - Armada 370/XP suspend/resume support - mvebu SoC driver suspend/resume support - irqchip - clocksource - mbus - clk * tag 'mvebu-soc-suspend-3.19' of git://git.infradead.org/linux-mvebu: ARM: mvebu: add SDRAM controller description for Armada XP ARM: mvebu: adjust mbus controller description on Armada 370/XP ARM: mvebu: add suspend/resume DT information for Armada XP GP ARM: mvebu: synchronize secondary CPU clocks on resume ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume ARM: mvebu: Armada XP GP specific suspend/resume code ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume ARM: mvebu: implement suspend/resume support for Armada XP clk: mvebu: add suspend/resume for gatable clocks bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration bus: mvebu-mbus: suspend/resume support clocksource: time-armada-370-xp: add suspend/resume support irqchip: armada-370-xp: Add suspend/resume support Documentation: dt-bindings: minimal documentation for MVEBU SDRAM controller Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-12-04Merge tag 'arm-soc/for-3.19/brcmstb-drivers' of ↵Arnd Bergmann
https://github.com/brcm/linux into next/drivers This pull request contains the following changes to the Broadcom GISB bus arbiter from Kevin Cernekee: - Extend brcmstb GISB bus driver to work on MIPS (currently ARM-only) and support 65nm and 40nm MIPS-based chips such as: BCM7038, BCM7400 and BCM7435 * tag 'arm-soc/for-3.19/brcmstb-drivers' of https://github.com/brcm/linux: bus: brcmstb_gisb: Add register offset tables for older chips bus: brcmstb_gisb: Look up register offsets in a table bus: brcmstb_gisb: Introduce wrapper functions for MMIO accesses bus: brcmstb_gisb: Make the driver buildable on MIPS Conflicts: drivers/bus/brcmstb_gisb.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-11-30bus: mvebu-mbus: provide a mechanism to save SDRAM window configurationThomas Petazzoni
On Marvell EBU platforms, when doing suspend/resume, the SDRAM window configuration must be saved on suspend, and restored on resume. However, it needs to be restored on resume *before* re-entering the kernel, because the SDRAM window configuration defines the layout of the memory. For this reason, it cannot simply be done in the ->suspend() and ->resume() hooks of the mvebu-mbus driver. Instead, it needs to be restored by the bootloader "boot info" mechanism used when resuming. This mechanism allows the kernel to define a list of (address, value) pairs when suspending, that the bootloader will restore on resume before jumping back into the kernel. This commit therefore adds a new function to the mvebu-mbus driver, called mvebu_mbus_save_cpu_target(), which will be called by the platform code to make the mvebu-mbus driver save the SDRAM window configuration in a way that can be understood by the bootloader "boot info" mechanism. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Link: https://lkml.kernel.org/r/1416585613-2113-8-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-30bus: mvebu-mbus: suspend/resume supportThomas Petazzoni
This commit extends the mvebu-mbus driver to provide suspend/resume support. Since mvebu-mbus is not a platform_driver, the syscore_ops mechanism is used to get ->suspend() and ->resume() hooks called into the driver. In those hooks, we save and restore the MBus windows state, to make sure after resume all Mbus windows are properly restored. Note that while the state of some windows could be gathered by looking again at the Device Tree (for statically described windows), it is not the case of dynamically described windows such as the PCIe memory and I/O windows. Therefore, we take the simple approach of saving and restoring the registers for all MBus windows. In addition, the commit extends the Device Tree binding of the MBus controller, to control the MBus bridge registers (which define which parts of the physical address space is routed to MBus windows vs. normal RAM memory). Those registers must be saved and restored during suspend/resume. The Device Tree binding extension is made is a backward compatible fashion, but of course, suspend/resume will not work without the Device Tree update. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1416585613-2113-7-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-28bus: brcmstb_gisb: Add register offset tables for older chipsKevin Cernekee
This will select the appropriate register layout based on the DT "compatible" string. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2014-11-28bus: brcmstb_gisb: Look up register offsets in a tableKevin Cernekee
There are at least 4 incompatible variations of this hardware block, so let's use the ARB_* constants as a table index instead of hardcoding specific register offsets. Also, allow for the possibility of adding old devices that are missing some of the registers. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2014-11-28bus: brcmstb_gisb: Introduce wrapper functions for MMIO accessesKevin Cernekee
These will be used to abstract out chip-to-chip differences. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2014-11-28bus: brcmstb_gisb: Make the driver buildable on MIPSKevin Cernekee
BCM7xxx ARM and MIPS platforms share a similar hardware block for reporting GISB errors, so they both benefit from the use of this driver. Conditionally compile the ARM-specific bus error handler so that the GISB error IRQ handler works on other architectures. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2014-11-21bus: brcmstb_gisb: resolve section mismatchFlorian Fainelli
Commit f1bee783dd37 moved the call to hook_fault_code in brcmstb_gisb_arb_probe() which now calls a function annotated with __init, so this one must also be annotated with __init. In order to avoid introducing another section mismatch, call platform_driver_probe() manually and remove the .probe assignment from brcmstb_gisb_arb_driver, this is very similar to what drivers/pci/host/pci-imx6.c does since we basically have the same constraints here. Fixes: f1bee783dd37 ("bus: brcmstb_gisb: register the fault code hook") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-11-20Merge tag 'arm-perf-3.19' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into next/drivers Pull "ARM: perf: updates for 3.19" from Will Deacon: This patch series takes us slightly further on the road to big.LITTLE support in perf. The main change enabling this is moving the CCI PMU driver away from the arm-pmu abstraction, allowing the arch code to focus specifically on support for CPU PMUs. * tag 'arm-perf-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/will/linux: arm: perf: fold hotplug notifier into arm_pmu arm: perf: dynamically allocate cpu hardware data arm: perf: fold percpu_pmu into pmu_hw_events arm: perf: kill get_hw_events() arm: perf: limit size of accounting data arm: perf: use IDR types for CPU PMUs arm: perf: make PMU probing data-driven arm: perf: add missing pr_info newlines arm: perf: factor out callchain code ARM: perf: use pr_* instead of printk ARM: perf: remove useless return and check of idx in counter handling bus: cci: move away from arm_pmu framework Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-11-12bus: omap_l3_noc: Correct returning IRQ_HANDLED unconditionally in the irq ↵Keerthy
handler Correct returning IRQ_HANDLED unconditionally in the irq handler. Return IRQ_NONE for some interrupt which we do not expect to be handled in this handler. This prevents kernel stalling with back to back spurious interrupts. Fixes: 2722e56de6 ("OMAP4: l3: Introduce l3-interconnect error handling driver") Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-12bus: omap_l3_noc: Add resume hook to restore contextKeerthy
On certain SoCs such as AM437x SoC, L3_noc error registers are maintained in power domain such as per domain which looses context as part of low power state such as RTC+DDR mode. On these platforms when we mask interrupts which we cannot handle, the source of these interrupts still remain on resume, however, the flag mux registers now contain their reset value (unmasked) - this breaks the system with infinite interrupts since we do not these interrupts to take place ever again. To handle this: restore the masking of interrupts which we have already recorded in the system as ones we cannot handle. Fixes: 2100b595b7 ("bus: omap_l3_noc: ignore masked out unclearable targets") Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-05ARM: OMAP3: Fix errors for omap_l3_smx when booted with device treeTony Lindgren
When booting omap3 in device tree mode, we're currently getting the following errors: omap_l3_smx omap_l3_smx.0: couldn't request debug irq omap_l3_smx: probe of omap_l3_smx.0 failed with error -22 This is because we don't have handling in the driver for the compatible property and instead assume platform data being passed. Note that this binding is already documented, and implemented for the related omap_l3_noc driver for omap4 and later. Looks like the binding somehow never got never implemented for this omap_l3_smx driver though. Let's also remove __exit_p to allow binding and unbinding of the driver while at it. Reported-by: Pavel Machek <pavel@ucw.cz> Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-10-30bus: cci: move away from arm_pmu frameworkMark Rutland
The ARM CPU PMUs and the ARM CCI PMU are using the same framework despite being substantially different in programming model, which makes it difficult to handle either particularly well. This patch migrates the ARM CCI PMU driver away from the arm_pmu framework, matching the style of the CCN PMU driver and other 'uncore' PMU drivers. This will enable refactoring of the arm_pmu framework to better support CPU PMUs. Event context migration on hotplug is not yet added due to a race on event->ctx in the core perf code. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Will Deacon <will.deacon@arm.com> [will: fix whitespace issues] Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-20bus: brcmstb_gisb: save and restore GISB timeoutFlorian Fainelli
When the system enters S3, we will lose the GISB timeout value we have configured, make sure that we do save this timeout value, and restore this timeout value prior to re-enabling interrupts such that the GISB timeout interrupt will fire with the expected timeout. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2014-10-20bus: brcmstb_gisb: register the fault code hookFlorian Fainelli
Commit 44127b771d9c31 ("bus: add Broadcom GISB bus arbiter timeout/error handler") added everything that is required to register an ARM fault handler for imprecise external aborts, except that there is nothing calling this currently. We do not need to export that specific function and have to update arch/arm/mach-bcm/brcmstb.c to call it, simply, register the fault handler during the probe() function of the driver. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2014-10-20bus: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-08Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. Most of the new code is for the Keystone Navigator driver, which is new base support that is going to be needed for their hardware accelerated network driver and other units. Most of the commits are for moving old code around from at91 and omap for things that are done in device drivers nowadays. - at91: move reset, poweroff, memory and clocksource code into drivers directories - socfpga: add edac driver (through arm-soc, as requested by Boris) - omap: move omap-intc code to drivers/irqchip - sunxi: added an RTC driver for sun6i - omap: mailbox driver related changes - keystone: support for the "Navigator" component - versatile: new reboot, led and soc drivers" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (92 commits) bus: arm-ccn: Fix spurious warning message leds: add device tree bindings for register bit LEDs soc: add driver for the ARM RealView power: reset: driver for the Versatile syscon reboot leds: add a driver for syscon-based LEDs drivers/soc: ti: fix build break with modules MAINTAINERS: Add Keystone Multicore Navigator drivers entry soc: ti: add Keystone Navigator DMA support Documentation: dt: soc: add Keystone Navigator DMA bindings soc: ti: add Keystone Navigator QMSS driver Documentation: dt: soc: add Keystone Navigator QMSS bindings rtc: sunxi: Depend on platforms sun4i/sun7i that actually have the rtc rtc: sun6i: Add sun6i RTC driver irqchip: omap-intc: remove unnecessary comments irqchip: omap-intc: correct maximum number or MIR registers irqchip: omap-intc: enable TURBO idle mode irqchip: omap-intc: enable IP protection irqchip: omap-intc: remove unnecesary of_address_to_resource() call irqchip: omap-intc: comment style cleanup irqchip: omap-intc: minor improvement to omap_irq_pending() ...
2014-10-08bus: arm-ccn: Fix spurious warning messagePawel Moll
Because CCN's cycle counter always runs, it will generate an interrupt on overflow even if the relevant perf event was not requested, causing a spurious warning message. Fixed now by warning on only normal counter unwanted overflows. Also cleaning the overflow mask at init now, not to warn on event previously requested by firmware. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-09-11bus: omap_l3_noc: Fix connID for OMAP4Nishanth Menon
Commit d4d8819e205854c ("bus: omap_l3_noc: fix masterid detection") did the right thing in dropping the LSB 2 bits which is not part of the ConnID for NTTP master address. However, as part of that change, we should also have ensured that existing list of OMAP4 connID codes are also shifted by 2 bits to ensure that connIDs map to "Table 13-18. ConnID Values" as provided in Technical Reference Manuals for OMAP4430(Rev AP, April 2014, SWPU220AP) and OMAP4460(Rev AB, April 2014, SWPU234AB) Fixes: d4d8819e205854c ("bus: omap_l3_noc: fix masterid detection") Reported-by: Kristian Otnes <kotnes@cisco.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-05bus: arm-ccn: Move event cleanup routinePawel Moll
The function cleaning up an initialized event was called from the "event_del" handler, instead of being used as the "destroy" callback. In case of events group allocation this caused NULL pointer dereference (as events are added and deleted multiple times then). Fixed now. Signed-off-by: Pawel Moll <mail@pawelmoll.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-08-24bus: arm-ccn: Fix warning messagePawel Moll
A message warning a user about wrong vc value was printing out port instead. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-08-08Merge tag 'drivers-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "A handful of driver-related changes. We've had a bunch of them going in through other branches as well, so it's only a part of what we really have this release. Larger pieces are: - Removal of a now unused PWM driver for atmel [ This includes AVR32 changes that have been appropriately acked ] - Performance counter support for the arm CCN interconnect - OMAP mailbox driver cleanups and consolidation - PCI and SATA PHY drivers for SPEAr 13xx platforms - Redefinition (with backwards compatibility!) of PCI DT bindings for Tegra to better model regulators/power" Note: this merge also fixes up the semantic conflict with the new calling convention for devm_phy_create(), see commit f0ed817638b5 ("phy: core: Let node ptr of PHY point to PHY and not of PHY provider") that came in through Greg's USB tree. Semantic merge patch by Stephen Rothwell <sfr@canb.auug.org.au> through the next tree. * tag 'drivers-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits) bus: arm-ccn: Fix error handling at event allocation mailbox/omap: add a parent structure for every IP instance mailbox/omap: remove the private mailbox structure mailbox/omap: consolidate OMAP mailbox driver mailbox/omap: simplify the fifo assignment by using macros mailbox/omap: remove omap_mbox_type_t from mailbox ops mailbox/omap: remove OMAP1 mailbox driver mailbox/omap: use devm_* interfaces bus: ARM CCN: add PERF_EVENTS dependency bus: ARM CCN PMU driver PCI: spear: Remove spear13xx_pcie_remove() PCI: spear: Fix Section mismatch compilation warning for probe() ARM: tegra: Remove legacy PCIe power supply properties PCI: tegra: Remove deprecated power supply properties PCI: tegra: Implement accurate power supply scheme ARM: SPEAr13xx: Update defconfigs ARM: SPEAr13xx: Add pcie and miphy DT nodes ARM: SPEAr13xx: Add bindings and dt node for misc block ARM: SPEAr13xx: Fix static mapping table phy: Add drivers for PCIe and SATA phy on SPEAr13xx ...
2014-08-08Merge tag 'soc-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This is the bulk of new SoC enablement and other platform changes for 3.17: - Samsung S5PV210 has been converted to DT and multiplatform - Clock drivers and bindings for some of the lower-end i.MX 1/2 platforms - Kirkwood, one of the popular Marvell platforms, is folded into the mvebu platform code, removing mach-kirkwood - Hwmod data for TI AM43xx and DRA7 platforms - More additions of Renesas shmobile platform support - Removal of plat-samsung contents that can be removed with S5PV210 being multiplatform/DT-enabled and the other two old platforms being removed New platforms (most with only basic support right now): - Hisilicon X5HD2 settop box chipset is introduced - Mediatek MT6589 (mobile chipset) is introduced - Broadcom BCM7xxx settop box chipset is introduced + as usual a lot other pieces all over the platform code" * tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits) ARM: hisi: remove smp from machine descriptor power: reset: move hisilicon reboot code ARM: dts: Add hix5hd2-dkb dts file. ARM: debug: Rename Hi3716 to HIX5HD2 ARM: hisi: enable hix5hd2 SoC ARM: hisi: add ARCH_HISI MAINTAINERS: add entry for Broadcom ARM STB architecture ARM: brcmstb: select GISB arbiter and interrupt drivers ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs ARM: configs: enable SMP in bcm_defconfig ARM: add SMP support for Broadcom mobile SoCs Documentation: arm: misc updates to Marvell EBU SoC status Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC ARM: mvebu: fix build without platforms selected ARM: mvebu: add cpuidle support for Armada 38x ARM: mvebu: add cpuidle support for Armada 370 cpuidle: mvebu: add Armada 38x support cpuidle: mvebu: add Armada 370 support cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7 ARM: mvebu: export the SCU address ...
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-07-31bus: arm-ccn: Fix error handling at event allocationPawel Moll
The bitfield allocation function returns error condition as a negative value, but in two cases its result was assigned to an unsigned member of the hw_perf_event structure, thus the error would not be ever detected. Fixed by using an intermediate, signed variable. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-30drivers: CCI: Correct use of ! and &Himangi Saraogi
In commit ae91d60ba88ef0bdb1b5e9b2363bd52fc45d2af7, a bug was fixed that involved converting !x & y to !(x & y). The code below shows the same pattern, and thus should perhaps be fixed in the same way. The Coccinelle semantic patch that makes this change is as follows: // <smpl> @@ expression E1,E2; @@ ( !E1 & !E2 | - !E1 & E2 + !(E1 & E2) ) // </smpl> Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-24bus: ARM CCN: add PERF_EVENTS dependencyArnd Bergmann
The CCN driver makes no sense without PERF_EVENTS, and trying to build it when that option is disabled results in compile errors, so it's best to just add a strong Kconfig dependency. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-07-23bus: ARM CCN PMU driverPawel Moll
Driver providing perf backend for ARM Cache Coherent Network interconnect. Supports counting all hardware events and crosspoint watchpoints. Currently works with CCN-504 only, although there should be no changes required for CCN-508 (just impossible to test it now). Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-07-18bus: imx-weim: populate devices on a simple busLiu Ying
There could be some memory map devices located in a certain chip select region of the i.MX WEIM. The devices could be attached to a simple bus(for example, a AXI bus) whose root node is one child device tree node of the i.MX WEIM device tree node. There should be a bridge(very likely, software transparent) bewteen the i.MX WEIM and the simple bus. This patch makes the i.MX WEIM driver possible to populate devices on a simple bus. In this way, people may try various IPs(in a FPGA, maybe) outside of i.MX chips with the i.MX WEIM embedded. Signed-off-by: Liu Ying <Ying.Liu@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-07-03Merge branch 'component-for-driver' of ↵Greg Kroah-Hartman
git://ftp.arm.linux.org.uk/~rmk/linux-arm into driver-core-next Russell writes: These updates fix one bug in the component helper where the matched components are not properly cleaned up when the master fails to bind. I'll provide a version of this for stable trees if it's deemed that we need to backport it. The second patch causes the component helper to ignore duplicate matches when adding components - this is something that was originally needed for imx-drm, but since that has now been updated, we no longer need to skip over a component which has already been matched. The final patch starts the process of updating the component helper API to achieve two goals: to allow the API to be more efficient when deferred probing occurs, and to allow for future improvements to the component helper without having a major impact on the users. This represents groundwork for some other changes; once this has been merged, I will then send two further pull requests (one for the staging tree, and one for the DRM tree) to update the drivers to the new API. This will result in these three commits being shared with those trees.
2014-06-19devres: remove devm_request_and_ioremap()Jingoo Han
devm_request_and_ioremap() was obsoleted by the commit 7509657 ("lib: devres: Introduce devm_ioremap_resource()") and has been deprecated for a long time. So, let's remove this function. In addition, all usages of devm_request_and_ioremap() are also removed. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-17bus/arm-cci: add dependency on OF && CPU_V7Arnd Bergmann
The arm-cci code uses device tree helpers for initialization that don't work on kernels built without CONFIG_OF. Further, it contains an inline assembly in cci_enable_port_for_self() that uses ARMv7 instructions and fails to build when targetting other ARM instruction set versions. This works around both issues by limiting the scope of the Kconfig symbol to platforms that can actually build this driver cleanly. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Cc: Shawn Guo <shawn.guo@linaro.org>
2014-06-02Merge tag 'drivers-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC driver changes from Olof Johansson: "SoC-near driver changes that we're merging through our tree. Mostly because they depend on other changes we have staged, but in some cases because the driver maintainers preferred that we did it this way. This contains a largeish cleanup series of the omap_l3_noc bus driver, cpuidle rework for Exynos, some reset driver conversions and a long branch of TI EDMA fixes and cleanups, with more to come next release. The TI EDMA cleanups is a shared branch with the dmaengine tree, with a handful of Davinci-specific fixes on top. After discussion at last year's KS (and some more on the mailing lists), we are here adding a drivers/soc directory. The purpose of this is to keep per-vendor shared code that's needed by different drivers but that doesn't fit into the MFD (nor drivers/platform) model. We expect to keep merging contents for this hierarchy through arm-soc so we can keep an eye on what the vendors keep adding here and not making it a free-for-all to shove in crazy stuff" * tag 'drivers-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (101 commits) cpufreq: exynos: Fix driver compilation with ARCH_MULTIPLATFORM tty: serial: msm: Remove direct access to GSBI power: reset: keystone-reset: introduce keystone reset driver Documentation: dt: add bindings for keystone pll control controller Documentation: dt: add bindings for keystone reset driver soc: qcom: fix of_device_id table ARM: EXYNOS: Fix kernel panic when unplugging CPU1 on exynos ARM: EXYNOS: Move the driver to drivers/cpuidle directory ARM: EXYNOS: Cleanup all unneeded headers from cpuidle.c ARM: EXYNOS: Pass the AFTR callback to the platform_data ARM: EXYNOS: Move S5P_CHECK_SLEEP into pm.c ARM: EXYNOS: Move the power sequence call in the cpu_pm notifier ARM: EXYNOS: Move the AFTR state function into pm.c ARM: EXYNOS: Encapsulate the AFTR code into a function ARM: EXYNOS: Disable cpuidle for exynos5440 ARM: EXYNOS: Encapsulate boot vector code into a function for cpuidle ARM: EXYNOS: Pass wakeup mask parameter to function for cpuidle ARM: EXYNOS: Remove ifdef for scu_enable in pm ARM: EXYNOS: Move scu_enable in the cpu_pm notifier ARM: EXYNOS: Use the cpu_pm notifier for pm ...
2014-06-02Merge tag 'soc-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull part one of ARM SoC updates from Olof Johansson: "A quite large set of SoC updates this cycle. In no particular order: - Multi-cluster power management for Samsung Exynos, adding support for big.LITTLE CPU switching on EXYNOS5 - SMP support for Marvell Armada 375 and 38x - SMP rework on Allwinner A31 - Xilinx Zynq support for SOC_BUS, big endian - Marvell orion5x platform cleanup, modernizing the implementation and moving to DT. - _Finally_ moving Samsung Exynos over to support MULTIPLATFORM, so that their platform can be enabled in the same kernel binary as most of the other v7 platforms in the tree. \o/ The work isn't quite complete, there's some driver fixes still needed, but the basics now work. New SoC support added: - Freescale i.MX6SX - LSI Axxia AXM55xx SoCs - Samsung EXYNOS 3250, 5260, 5410, 5420 and 5800 - STi STIH407 plus a large set of various smaller updates for different platforms. I'm probably missing some important one here" * tag 'soc-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (281 commits) ARM: exynos: don't run exynos4 l2x0 setup on other platforms ARM: exynos: Fix "allmodconfig" build errors in mcpm and hotplug ARM: EXYNOS: mcpm rename the power_down_finish ARM: EXYNOS: Enable mcpm for dual-cluster exynos5800 SoC ARM: EXYNOS: Enable multi-platform build support ARM: EXYNOS: Consolidate Kconfig entries ARM: EXYNOS: Add support for EXYNOS5410 SoC ARM: EXYNOS: Support secondary CPU boot of Exynos3250 ARM: EXYNOS: Add Exynos3250 SoC ID ARM: EXYNOS: Add 5800 SoC support ARM: EXYNOS: initial board support for exynos5260 SoC clk: exynos5410: register clocks using common clock framework ARM: debug: qcom: add UART addresses to Kconfig help for APQ8084 ARM: sunxi: allow building without reset controller Documentation: devicetree: arm: sort enable-method entries ARM: rockchip: convert smp bringup to CPU_METHOD_OF_DECLARE clk: exynos5250: Add missing sysmmu clocks for DISP and ISP blocks ARM: dts: axxia: Add reset controller power: reset: Add Axxia system reset driver ARM: axxia: Adding defconfig for AXM55xx ...
